path: root/Documentation
2010-03-06mm: count swap usageKAMEZAWA Hiroyuki
A frequent questions from users about memory management is what numbers of swap ents are user for processes. And this information will give some hints to oom-killer. Besides we can count the number of swapents per a process by scanning /proc/<pid>/smaps, this is very slow and not good for usual process information handler which works like 'ps' or 'top'. (ps or top is now enough slow..) This patch adds a counter of swapents to mm_counter and update is at each swap events. Information is exported via /proc/<pid>/status file as [kamezawa@bluextal memory]$ cat /proc/self/status Name: cat State: R (running) Tgid: 2910 Pid: 2910 PPid: 2823 TracerPid: 0 Uid: 500 500 500 500 Gid: 500 500 500 500 FDSize: 256 Groups: 500 VmPeak: 82696 kB VmSize: 82696 kB VmLck: 0 kB VmHWM: 432 kB VmRSS: 432 kB VmData: 172 kB VmStk: 84 kB VmExe: 48 kB VmLib: 1568 kB VmPTE: 40 kB VmSwap: 0 kB <=============== this. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: avoid false sharing of mm_counterKAMEZAWA Hiroyuki
Considering the nature of per mm stats, it's the shared object among threads and can be a cache-miss point in the page fault path. This patch adds per-thread cache for mm_counter. RSS value will be counted into a struct in task_struct and synchronized with mm's one at events. Now, in this patch, the event is the number of calls to handle_mm_fault. Per-thread value is added to mm at each 64 calls. rough estimation with small benchmark on parallel thread (2threads) shows [before] 4.5 cache-miss/faults [after] 4.0 cache-miss/faults Anyway, the most contended object is mmap_sem if the number of threads grows. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05Merge branch 'slab-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slab-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: SLUB: Fix per-cpu merge conflict failslab: add ability to filter slab caches slab: fix regression in touched logic dma kmalloc handling fixes slub: remove impossible condition slab: initialize unused alien cache entry as NULL at alloc_alien_cache(). SLUB: Make slub statistics use this_cpu_inc SLUB: this_cpu: Remove slub kmem_cache fields SLUB: Get rid of dynamic DMA kmalloc cache allocation SLUB: Use this_cpu operations in slub
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05Merge branch 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.34' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (145 commits) KVM: x86: Add KVM_CAP_X86_ROBUST_SINGLESTEP KVM: VMX: Update instruction length on intercepted BP KVM: Fix emulate_sys[call, enter, exit]()'s fault handling KVM: Fix segment descriptor loading KVM: Fix load_guest_segment_descriptor() to inject page fault KVM: x86 emulator: Forbid modifying CS segment register by mov instruction KVM: Convert kvm->requests_lock to raw_spinlock_t KVM: Convert i8254/i8259 locks to raw_spinlocks KVM: x86 emulator: disallow opcode 82 in 64-bit mode KVM: x86 emulator: code style cleanup KVM: Plan obsolescence of kernel allocated slots, paravirt mmu KVM: x86 emulator: Add LOCK prefix validity checking KVM: x86 emulator: Check CPL level during privilege instruction emulation KVM: x86 emulator: Fix popf emulation KVM: x86 emulator: Check IOPL level during io instruction emulation KVM: x86 emulator: fix memory access during x86 emulation KVM: x86 emulator: Add Virtual-8086 mode of emulation KVM: x86 emulator: Add group9 instruction decoding KVM: x86 emulator: Add group8 instruction decoding KVM: do not store wqh in irqfd ... Trivial conflicts in Documentation/feature-removal-schedule.txt
2010-03-05Merge branch 'perf-probes-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-probes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Issue at least one memory barrier in stop_machine_text_poke() perf probe: Correct probe syntax on command line help perf probe: Add lazy line matching support perf probe: Show more lines after last line perf probe: Check function address range strictly in line finder perf probe: Use libdw callback routines perf probe: Use elfutils-libdw for analyzing debuginfo perf probe: Rename probe finder functions perf probe: Fix bugs in line range finder perf probe: Update perf probe document perf probe: Do not show --line option without dwarf support kprobes: Add documents of jump optimization kprobes/x86: Support kprobes jump optimization on x86 x86: Add text_poke_smp for SMP cross modifying code kprobes/x86: Cleanup save/restore registers kprobes/x86: Boost probes when reentering kprobes: Jump optimization sysctl interface kprobes: Introduce kprobes jump optimization kprobes: Introduce generic insn_slot framework kprobes/x86: Cleanup RELATIVEJUMP_INSTRUCTION to RELATIVEJUMP_OPCODE
2010-03-05dquot: cleanup dquot initialize routineChristoph Hellwig
Get rid of the initialize dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_initialize helper to __dquot_initialize and vfs_dq_init to dquot_initialize to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot drop routineChristoph Hellwig
Get rid of the drop dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_drop helper to __dquot_drop and vfs_dq_drop to dquot_drop to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot transfer routineChristoph Hellwig
Get rid of the transfer dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_transfer helper to __dquot_transfer and vfs_dq_transfer to dquot_transfer to have a consistent namespace, and make the new dquot_transfer return a normal negative errno value which all callers expect. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup inode allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_inode and free_inode dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Also get rid of the vfs_dq_alloc/vfs_dq_free wrappers and always call the lowlevel dquot_alloc_inode / dqout_free_inode routines directly, which now lose the number argument which is always 1. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup space allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_space, free_space, reserve_space, claim_space and release_rsv dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Move shared logic into the common __dquot_alloc_space, dquot_claim_space_nodirty and __dquot_free_space low-level methods, and rationalize the wrappers around it to move as much as possible code into the common block for CONFIG_QUOTA vs not. Also rename all these helpers to be named dquot_* instead of vfs_dq_*. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-next-2.6: (49 commits) drivers/ide: Fix continuation line formats ide: fixed section mismatch warning in cmd640.c ide: ide_timing_compute() fixup ide: make ide_get_best_pio_mode() static via82cxxx: use ->pio_mode value to determine pair device speed tx493xide: use ->pio_mode value to determine pair device speed siimage: use ->pio_mode value to determine pair device speed palm_bk3710: use ->pio_mode value to determine pair device speed it821x: use ->pio_mode value to determine pair device speed cs5536: use ->pio_mode value to determine pair device speed cs5535: use ->pio_mode value to determine pair device speed cmd64x: fix handling of address setup timings amd74xx: use ->pio_mode value to determine pair device speed alim15x3: fix handling of UDMA enable bit alim15x3: fix handling of DMA timings alim15x3: fix handling of command timings alim15x3: fix handling of address setup timings ide-timings: use ->pio_mode value to determine fastest PIO speed ide: change ->set_dma_mode method parameters ide: change ->set_pio_mode method parameters ...
2010-03-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (28 commits) ioat: cleanup ->timer_fn() and ->cleanup_fn() prototypes ioat3: interrupt coalescing ioat: close potential BUG_ON race in the descriptor cleanup path ioat2: kill pending flag ioat3: use ioat2_quiesce() ioat3: cleanup, don't enable DCA completion writes DMAENGINE: COH 901 318 lli sg offset fix DMAENGINE: COH 901 318 configure channel direction DMAENGINE: COH 901 318 remove irq counting DMAENGINE: COH 901 318 descriptor pool refactoring DMAENGINE: COH 901 318 cleanups dma: Add MPC512x DMA driver Debugging options for the DMA engine subsystem iop-adma: redundant/wrong tests in iop_*_count()? dmatest: fix handling of an even number of xor_sources dmatest: correct raid6 PQ test fsldma: Fix cookie issues fsldma: Fix cookie issues dma: cases IPU_PIX_FMT_BGRA32, BGR32 and ABGR32 are the same in ipu_ch_param_set_size() dma: make Open Firmware device id constant ...
2010-03-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) init: Open /dev/console from rootfs mqueue: fix typo "failues" -> "failures" mqueue: only set error codes if they are really necessary mqueue: simplify do_open() error handling mqueue: apply mathematics distributivity on mq_bytes calculation mqueue: remove unneeded info->messages initialization mqueue: fix mq_open() file descriptor leak on user-space processes fix race in d_splice_alias() set S_DEAD on unlink() and non-directory rename() victims vfs: add NOFOLLOW flag to umount(2) get rid of ->mnt_parent in tomoyo/realpath hppfs can use existing proc_mnt, no need for do_kern_mount() in there Mirror MS_KERNMOUNT in ->mnt_flags get rid of useless vfsmount_lock use in put_mnt_ns() Take vfsmount_lock to fs/internal.h get rid of insanity with namespace roots in tomoyo take check for new events in namespace (guts of mounts_poll()) to namespace.c Don't mess with generic_permission() under ->d_lock in hpfs sanitize const/signedness for udf nilfs: sanitize const/signedness in dealing with ->d_name.name ... Fix up fairly trivial (famous last words...) conflicts in drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
2010-03-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: disable pcmcia ioctl for !ARM, prepare for removal pcmcia: CodingStyle fixes pcmcia: alchemy: fixup wrong comments pcmcia: remove irq_list parameter from pd6729 yenta_socket: ENE CB712 CardBus bridge needs special treatment with Echo Audio Indigo soundcards
2010-03-04Merge branches 'slab/cleanups', 'slab/failslab', 'slab/fixes' and ↵Pekka Enberg
'slub/percpu' into slab-for-linus
2010-03-03add several pieces to shared subtree documentationAl Viro
* document locking * add the missing part of data structure invariants (relationship between mnt_share and mnt_slave lists in case of a peer group among slaves). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: add reader's lock for cno in nilfs_ioctl_sync nilfs2: delete unnecessary condition in load_segment_summary nilfs2: move iterator to write log into segment buffer nilfs2: get rid of s_dirt flag use nilfs2: get rid of nilfs_segctor_req struct nilfs2: delete unnecessary condition in nilfs_dat_translate nilfs2: fix potential hang in nilfs_error on errors=remount-ro nilfs2: use mnt_want_write in ioctls where write access is needed nilfs2: issue discard request after cleaning segments
2010-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (220 commits) USB: backlight, appledisplay: fix incomplete registration failure handling USB: pl2303: remove unnecessary reset of usb_device in urbs USB: ftdi_sio: remove obsolete check in unthrottle USB: ftdi_sio: remove unused tx_bytes counter USB: qcaux: driver for auxiliary serial ports on Qualcomm devices USB: pl2303: initial TIOCGSERIAL support USB: option: add Longcheer/Longsung vendor ID USB: fix I2C API usage in ohci-pnx4008. USB: usbmon: mask seconds properly in text API USB: sisusbvga: no unnecessary GFP_ATOMIC USB: storage: onetouch: unnecessary GFP_ATOMIC USB: serial: ftdi: add CONTEC vendor and product id USB: remove references to port->port.count from the serial drivers USB: tty: Prune uses of tty_request_room in the USB layer USB: tty: Add a function to insert a string of characters with the same flag USB: don't read past config->interface[] if usb_control_msg() fails in usb_reset_configuration() USB: tty: kill request_room for USB ACM class USB: tty: sort out the request_room handling for whiteheat USB: storage: fix misplaced parenthesis USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., devices and spectrometers ...
2010-03-03Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) x86: Fix out of order of gsi x86: apic: Fix mismerge, add arch_probe_nr_irqs() again x86, irq: Keep chip_data in create_irq_nr and destroy_irq xen: Remove unnecessary arch specific xen irq functions. smp: Use nr_cpus= to set nr_cpu_ids early x86, irq: Remove arch_probe_nr_irqs sparseirq: Use radix_tree instead of ptrs array sparseirq: Change irq_desc_ptrs to static init: Move radix_tree_init() early irq: Remove unnecessary bootmem code x86: Add iMac9,1 to pci_reboot_dmi_table x86: Convert i8259_lock to raw_spinlock x86: Convert nmi_lock to raw_spinlock x86: Convert ioapic_lock and vector_lock to raw_spinlock x86: Avoid race condition in pci_enable_msix() x86: Fix SCI on IOAPIC != 0 x86, ia32_aout: do not kill argument mapping x86, irq: Move __setup_vector_irq() before the first irq enable in cpu online path x86, irq: Update the vector domain for legacy irqs handled by io-apic x86, irq: Don't block IRQ0_VECTOR..IRQ15_VECTOR's on all cpu's ...
2010-03-03Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (45 commits) compal-laptop: Make it depend on CONFIG_RFKILL classmate-laptop: Added some keys present in other devices MAINTAINERS: Add git tree to x86 Platform Drivers asus-acpi: remove duplicate comparison of asus_model strings toshiba-acpi: fix multimedia keys on some machines dell-laptop: Fix errors on failure and exit paths dell-laptop: Fix build error by making buffer_mutex static asus-laptop: fix style problems reported by checkpath.pl asus-laptop: use device_create_file() instead of platform_group asus-laptop: clean led code asus-laptop: add gps rfkill asus-laptop: set initial lcd state asus-laptop: leds, remove dead code and fix asus_led_exit()/asus_led_init() asus-laptop: add backlight changes notifications asus-laptop: add bluetooth keys found on M9V asus-laptop: switch to sparse keymap library asus-laptop: rename wireless_status to wlan_status to avoid confusion asus-laptop: add error check for write_acpi_int calls asus-laptop: stop using ASUS_HANDLE and use relative methods instead asus-laptop: rename function talking directly to acpi with asus_xxx scheme ...
2010-03-03Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Document the message size limit i2c-algo-pca: Drop duplicate variable i2c: Hook up runtime PM support i2c-parport-light: Add SMBus alert support i2c-parport: Add SMBus alert support i2c: Separate Kconfig option for i2c-smbus i2c: Add SMBus alert support i2c-parport: Give powered devices some time to settle i2c-tiny-usb: Fix a comment on bus frequency i2c-i801: Add Intel Cougar Point device IDs i2c: Make PCI device ids constant
2010-03-03docbook: fix errors from x86 headers mergerRandy Dunlap
Fix docbook errors for x86 headers that were recently merged: docproc: arch/x86/include/asm/atomic_32.h: No such file or directory docproc: arch/x86/include/asm/io_32.h: No such file or directory Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Brian Gerst <brgerst@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/ide-2.6
2010-03-03pcmcia: disable pcmcia ioctl for !ARM, prepare for removalDominik Brodowski
The PCMCIA ioctl -- deprecated for years -- suffers from insufficient locking. As it already has been deprecated for years, with its removal long overdue, limit it to !SMP and !PREEMPT. Furthermore, the last legitimate use of the ioctl to be reported relates to the ARM architecture in 2008.[1] Attempts to resolve this issue turned out unsuccessful so far.[2] Other usages have only been reported as hear-say. If there are any legitiate and necessary use-cases remaining, please speak out before the end of the grace period until 2.6.3{5,6}(-rc1). [1] http://lists.infradead.org/pipermail/linux-pcmcia/2008-April/005440.html see also: http://lkml.org/lkml/2008/2/27/291 [2] http://lists.infradead.org/pipermail/linux-pcmcia/2008-April/005450.html http://lists.infradead.org/pipermail/linux-pcmcia/2010-January/006740.html see also: http://lists.infradead.org/pipermail/linux-pcmcia/2008-April/005453.html CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: Robert P. J. Day <rpjday@crashcourse.ca> CC: Jaswinder Singh Rajput <jaswinder@kernel.org> CC: linux-kernel@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-02USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., ↵Dennis O'Brien
devices and spectrometers This patch removes the vstusb driver and support from the Linux tree. This driver provided support for Vernier Software & Technology devices and spectrometers (Ocean Optics). This driver is being replaced by a user space - libusb - implementation. Signed-off-by: Jim Collar <jim.collar@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: convert to the runtime PM frameworkAlan Stern
This patch (as1329) converts the USB stack over to the PM core's runtime PM framework. This involves numerous changes throughout usbcore, especially to hub.c and driver.c. Perhaps the most notable change is that CONFIG_USB_SUSPEND now depends on CONFIG_PM_RUNTIME instead of CONFIG_PM. Several fields in the usb_device and usb_interface structures are no longer needed. Some code which used to depend on CONFIG_USB_PM now depends on CONFIG_USB_SUSPEND (requiring some rearrangement of header files). The only visible change in behavior should be that following a system sleep (resume from RAM or resume from hibernation), autosuspended USB devices will be resumed just like everything else. They won't remain suspended. But if they aren't in use then they will naturally autosuspend again in a few seconds. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: implement usb_enable_autosuspendAlan Stern
This patch (as1326) adds usb_enable_autosuspend() and usb_disable_autosuspend() routines for use by drivers. If a driver knows that its device can handle suspends and resumes correctly, it can enable autosuspend all by itself. This is equivalent to the user writing "auto" to the device's power/level attribute. The implementation differs slightly from what it used to be. Now autosuspend is disabled simply by doing usb_autoresume_device() (to increment the usage counter) and enabled by doing usb_autosuspend_device() (to decrement the usage counter). The set_level() attribute method is updated to use the new routines, and the USB Power-Management documentation is updated. The patch adds a usb_enable_autosuspend() call to the hub driver's probe routine, allowing the special-case code for hubs in quirks.c to be removed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: Export QUIRK_RESET_MORPHS through sysfsOliver Neukum
Some devices which use mode switching revert to their primary mode as they are reset. They must not be reset for error handling. As user spaces makes the switch it also has to tell the kernel that a device is quirky. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: check the endpoint type against the pipe typeAlan Stern
This patch (as1316) adds some error checking to usb_submit_urb(). It's conditional on CONFIG_USB_DEBUG, so it won't affect normal users. The new check makes sure that the actual type of the endpoint described by urb->pipe agrees with the type encoded in the pipe value. The USB error code documentation is updated to include the code returned by the new check, and the usbfs SUBMITURB handler is updated to use the correct pipe type when legacy user code tries to submit a bulk transfer to an interrupt endpoint. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: cxacru: remove cxacru-cf.bin loaderSimon Arlott
This has never worked properly because wsize passed to cxacru_cm() is incorrectly set to the number of values instead of the data bytes. The maximum number of values that can be set at once is 7 which means the device will not get enough data to work with and none of the configuration values will be used. At least one existing cxacru-cf.bin file contains invalid data which will prevent the modem from syncing properly. Fixing it is likely to break existing systems, and the new sysfs interface for setting configuration parameters can provide the same functionality. A script is provided to convert from the original format. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: cxacru: add write-only sysfs attribute for modem configurationSimon Arlott
The modem can be configured using CM_REQUEST_CARD_DATA_SET, although CM_REQUEST_CARD_DATA_GET does not return any data. Tested by setting the modulation (0x0a) option. There is a list of parameters in the following archive, but the meaning of many of them is not well documented: http://sourceforge.net/project/shownotes.php?release_id=301825 This source also indicates that the highest parameter set is 0x4a but this varies by model so an arbitrary limit of 0x7f has been used (the index is a 32-bit integer). Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: cxacru: return an empty value for modulation if there is no connectionSimon Arlott
When there is no connection, return an empty string instead of "0" for the connection modulation. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1341 commits) virtio_net: remove forgotten assignment be2net: fix tx completion polling sis190: fix cable detect via link status poll net: fix protocol sk_buff field bridge: Fix build error when IGMP_SNOOPING is not enabled bnx2x: Tx barriers and locks scm: Only support SCM_RIGHTS on unix domain sockets. vhost-net: restart tx poll on sk_sndbuf full vhost: fix get_user_pages_fast error handling vhost: initialize log eventfd context pointer vhost: logging thinko fix wireless: convert to use netdev_for_each_mc_addr ethtool: do not set some flags, if others failed ipoib: returned back addrlen check for mc addresses netlink: Adding inode field to /proc/net/netlink axnet_cs: add new id bridge: Make IGMP snooping depend upon BRIDGE. bridge: Add multicast count/interval sysfs entries bridge: Add hash elasticity/max sysfs entries bridge: Add multicast_snooping sysfs toggle ... Trivial conflicts in Documentation/feature-removal-schedule.txt
2010-03-02Merge branch 'for-upstream/platform-x86_tpacpi' of ↵Matthew Garrett
git://repo.or.cz/linux-2.6/linux-acpi-2.6/ibm-acpi-2.6 into x86-platform
2010-03-02i2c: Document the message size limitZhangfei Gao
i2c_master_send & i2c_master_recv do not support more than 64 kb transfer, since msg.len is u16. Signed-off-by: Zhangfei Gao <zgao6@marvell.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-02i2c-parport-light: Add SMBus alert supportJean Delvare
Add support for the SMBus alert mechanism to the i2c-parport-light driver. The ADM1032 evaluation board at least is properly wired for this. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-02i2c-parport: Add SMBus alert supportJean Delvare
Add support for the SMBus alert mechanism to the i2c-parport driver. The ADM1032 evaluation board at least is properly wired for this. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-02i2c: Add SMBus alert supportJean Delvare
SMBus alert support. The SMBus alert protocol allows several SMBus slave devices to share a single interrupt pin on the SMBus master, while still allowing the master to know which slave triggered the interrupt. This is based on preliminary work by David Brownell. The key difference between David's implementation and mine is that his was part of i2c-core, while mine is split into a separate, standalone module named i2c-smbus. The i2c-smbus module is meant to include support for all SMBus extensions to the I2C protocol in the future. The benefit of this approach is a zero cost for I2C bus segments which do not need SMBus alert support. Where David's implementation increased the size of struct i2c_adapter by 7% (40 bytes on i386), mine doesn't touch it. Where David's implementation added over 150 lines of code to i2c-core (+10%), mine doesn't touch it. The only change that touches all the users of the i2c subsystem is a new callback in struct i2c_driver (common to both implementations.) I seem to remember Trent was worried about the footprint of David'd implementation, hopefully mine addresses the issue. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-02i2c-i801: Add Intel Cougar Point device IDsSeth Heasley
Add the Intel Cougar Point (PCH) SMBus controller device IDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (62 commits) Input: atkbd - release previously reserved keycodes 248 - 254 Input: add KEY_WPS_BUTTON definition Input: ads7846 - add regulator support Input: winbond-cir - fix suspend/resume Input: gamecon - use pr_err() and friends Input: gamecon - constify some of the setup structures Input: gamecon - simplify pad type handling Input: gamecon - simplify coordinate calculation for PSX Input: gamecon - fix some formatting issues Input: gamecon - add rumble support for N64 pads Input: wacom - add device type to device name string Input: s3c24xx_ts - report touch only when stylus is down Input: s3c24xx_ts - re-enable IRQ on resume Input: wacom - constify product features data Input: wacom - use per-device instance of wacom_features Input: sh_keysc - enable building on SH-Mobile ARM Input: wacom - get features from driver info Input: rotary-encoder - set gpio direction for each requested gpio Input: sh_keysc - update the driver with mode 6 Input: sh_keysc - switch to using bitmaps ...
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-03-01Merge branch 'for-2.6.34' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits) block: don't access jiffies when initialising io_context cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds block: fix for "Consolidate phys_segment and hw_segment limits" cfq-iosched: quantum check tweak blktrace: perform cleanup after setup error blkdev: fix merge_bvec_fn return value checks cfq-iosched: requests "in flight" vs "in driver" clarification cciss: Fix problem with scatter gather elements in the scsi half of the driver cciss: eliminate unnecessary pointer use in cciss scsi code cciss: do not use void pointer for scsi hba data cciss: factor out scatter gather chain block mapping code cciss: fix scatter gather chain block dma direction kludge cciss: simplify scatter gather code cciss: factor out scatter gather chain block allocation and freeing cciss: detect bad alignment of scsi commands at build time cciss: clarify command list padding calculation cfq-iosched: rethink seeky detection for SSDs cfq-iosched: rework seeky detection block: remove padding from io_context on 64bit builds block: Consolidate phys_segment and hw_segment limits ...
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (252 commits) ASoC: Check progress when reporting periods from i.MX FIQ handler ASoC: Remove a unused variables from i.MX FIQ runtime data ALSA: hda - Add/fix ALC269 FSC and Quanta models ALSA: hda - Add ALC670 codec support OMAP4: PMIC: Add support for twl6030 codec ALSA: hda - remove unnecessary msleep on power state transitions usb/gadget/{f_audio,gmidi}.c: follow recent changes in audio.h ASoC: fsi: Modify over/under run error settlement ASoC: OMAP4: Add McPDM platform driver ASoC: OMAP4: Add support for McPDM ASoC: OMAP: data_type and sync_mode configurable in audio dma ALSA: hda - Add missing description in HD-Audio-Models.txt ALSA: add support for Macbook Air 2,1 internal speaker ALSA: usbaudio: consolidate header files ALSA: usbmixer: bail out early when parsing audio class v2 descriptors ALSA: usbaudio: implement basic set of class v2.0 parser ALSA: usbaudio: introduce new types for audio class v2 ALSA: usbaudio: parse USB descriptors with structs ALSA: hda - enable snoop for Intel Cougar Point ALSA: hda - Remove identical definitions for macmini3 model ...
2010-03-01KVM: Plan obsolescence of kernel allocated slots, paravirt mmuAvi Kivity
These features are unused by modern userspace and can go away. Paravirt mmu needs to stay a little longer for live migration. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: trivial document fixesWu Fengguang
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01Merge git://git.iksaif.net/acpi4asus into x86-platformMatthew Garrett
2010-03-01Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-03-01Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-02-28Merge branch 'next' into for-linusDmitry Torokhov
