Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Greg KH <greg@kroah.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su>
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
- remove the PCI DMA API description in DMA-API.txt
- remove the descriptions of dma_unmap macros since
PCI-DMA-mapping.txt has the same description.
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
- replace the PCI DMA API (i.e. pci_dma_*) with the generic DMA API.
- make the document more generic (use the PCI specific explanation as
an example).
[akpm@linux-foundation.org: fix things Randy noticed]
dma_set_coherent_mask corresponds to pci_set_consistent_dma_mask. This is
necessary to move to the generic device model DMA API from the PCI bus
specific API in the long term.
dma_set_coherent_mask works in the exact same way that
pci_set_consistent_dma_mask does. So this patch also changes
pci_set_consistent_dma_mask to call dma_set_coherent_mask.
Cc: James Bottomley <James.Bottomley@suse.de>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Adds the following macros:
DECLARE_DMA_UNMAP_ADDR(ADDR_NAME)
DECLARE_DMA_UNMAP_LEN(LEN_NAME)
dma_unmap_addr(PTR, ADDR_NAME)
dma_unmap_addr_set(PTR, ADDR_NAME, VAL)
dma_unmap_len(PTR, LEN_NAME)
dma_unmap_len_set(PTR, LEN_NAME, VAL)
The API corresponds to the pci_unmap state API. We'll move to this new
generic API from the PCI specific API in the long term. As
include/asm-generic/pci-dma-compat.h does, the pci_unmap API simply calls
the new generic API for some time.
dma_sync_single_for_cpu/for_device supports a partial sync so there is no
point to have dma_sync_single_range (also dma_sync_single was obsoleted
long ago, replaced with dma_sync_single_for_cpu/for_device).
There is no user of dma_sync_single_range() in mainline and only Alpha
architecture supports dma_sync_single_range(). So it's unlikely that
someone out of the tree uses it.
Acked-by: David Miller <davem@davemloft.net>
Acked-by: James Bottomley <James.Bottomley@suse.de>
This adds the description of the following eight function:
pci_dma_sync_single_for_cpu
dma_sync_single_for_device
pci_dma_sync_single_for_device
dma_sync_sg_for_cpu
pci_dma_sync_sg_for_cpu
dma_sync_sg_for_device
pci_dma_sync_sg_for_device
It was unclear that the API permits a partial sync (some network drivers
already do though). I made it clear that the sync_single API can do a
partial sync but the sync_sg API can't.
We could do a partial sync with the sync_sg API too, however, it's
difficult for driver writers to correctly use the sync_sg API for a
partial sync since the scatterlists passed in to the mapping API can't be
modified. It's unlikely that driver writers want to do a partial sync
with the sync_sg API (because the sync_sg API are usually used for block
drivers). So I think that it's better to forbid a partial sync with the
sync_sg API.
dma_sync_single(), pci_dma_sync_single(), dma_sync_sg(), and
pci_dma_sync_sg() are deprecated. We should not advertise them.
Acked-by: Joerg Roedel <joro@8bytes.org>
In some cases kipmid can use a lot of CPU. This adds a way to tune the
CPU used by kipmid to help in those cases. By setting kipmid_max_busy_us
to a value between 100 and 500, it is possible to bring down kipmid CPU
load to practically 0 without loosing too much ipmi throughput
performance. Not setting the value, or setting the value to zero,
operation is unaffected.
Signed-off-by: Martin Wilck <martin.wilck@ts.fujitsu.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Decription of sanity check for memory thresholds.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Dan Malek <dan@embeddedalley.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
An example of cgroup notification API usage.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Presently, if panic_on_oom=2, the whole system panics even if the oom
happend in some special situation (as cpuset, mempolicy....). Then,
panic_on_oom=2 means painc_on_oom_always.
Now, memcg doesn't check panic_on_oom flag. This patch adds a check.
BTW, how it's useful ?
kdump+panic_on_oom=2 is the last tool to investigate what happens in
oom-ed system. When a task is killed, the sysytem recovers and there will
be few hint to know what happnes. In mission critical system, oom should
never happen. Then, panic_on_oom=2+kdump is useful to avoid next OOM by
knowing precise information via snapshot.
TODO:
- For memcg, it's for isolate system's memory usage, oom-notiifer and
freeze_at_oom (or rest_at_oom) should be implemented. Then, management
daemon can do similar jobs (as kdump) or taking snapshot per cgroup.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Nick Piggin <npiggin@suse.de>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Update memcg_test.txt to describe how to test the move-charge feature.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
It allows to register multiple memory and memsw thresholds and gets
notifications when it crosses.
To register a threshold application need:
- create an eventfd;
- open memory.usage_in_bytes or memory.memsw.usage_in_bytes;
- write string like "<event_fd> <memory.usage_in_bytes> <threshold>" to
cgroup.event_control.
Application will be notified through eventfd when memory usage crosses
threshold in any direction.
It's applicable for root and non-root cgroup.
It uses stats to track memory usage, simmilar to soft limits. It checks
if we need to send event to userspace on every 100 page in/out. I guess
it's good compromise between performance and accuracy of thresholds.
[nishimura@mxp.nes.nec.co.jp: fix documentation merge issue]
Cc: Vladislav Buzov <vbuzov@embeddedalley.com>
Cc: Alexander Shishkin <virtuoso@slind.org>
This patchset introduces eventfd-based API for notifications in cgroups
and implements memory notifications on top of it.
It uses statistics in memory controler to track memory usage.
Output of time(1) on building kernel on tmpfs:
Root cgroup before changes:
make -j2 506.37 user 60.93s system 193% cpu 4:52.77 total
Non-root cgroup before changes:
make -j2 507.14 user 62.66s system 193% cpu 4:54.74 total
Root cgroup after changes (0 thresholds):
make -j2 507.13 user 62.20s system 193% cpu 4:53.55 total
Non-root cgroup after changes (0 thresholds):
make -j2 507.70 user 64.20s system 193% cpu 4:55.70 total
Root cgroup after changes (1 thresholds, never crossed):
make -j2 506.97 user 62.20s system 193% cpu 4:53.90 total
Non-root cgroup after changes (1 thresholds, never crossed):
make -j2 507.55 user 64.08s system 193% cpu 4:55.63 total
This patch:
Introduce the write-only file "cgroup.event_control" in every cgroup.
To register new notification handler you need:
- open a control file to be monitored. Callbacks register_event() and
unregister_event() must be defined for the control file;
- write "<event_fd> <control_fd> <args>" to cgroup.event_control.
Interpretation of args is defined by control file implementation;
eventfd will be woken up by control file implementation or when the
cgroup is removed.
To unregister notification handler just close eventfd.
If you need notification functionality for a control file you have to
implement callbacks register_event() and unregister_event() in the
struct cftype.
[kamezawa.hiroyu@jp.fujitsu.com: Kconfig fix]
Cc: Davide Libenzi <davidel@xmailserver.org>
This patch is another core part of this move-charge-at-task-migration
feature. It enables moving charges of anonymous swaps.
To move the charge of swap, we need to exchange swap_cgroup's record.
In current implementation, swap_cgroup's record is protected by:
- page lock: if the entry is on swap cache.
- swap_lock: if the entry is not on swap cache.
This works well in usual swap-in/out activity.
But this behavior make the feature of moving swap charge check many
conditions to exchange swap_cgroup's record safely.
So I changed modification of swap_cgroup's recored(swap_cgroup_record())
to use xchg, and define a new function to cmpxchg swap_cgroup's record.
This patch also enables moving charge of non pte_present but not uncharged
swap caches, which can be exist on swap-out path, by getting the target
pages via find_get_page() as do_mincore() does.
[kosaki.motohiro@jp.fujitsu.com: fix ia64 build]
[akpm@linux-foundation.org: fix typos]
In current memcg, charges associated with a task aren't moved to the new
cgroup at task migration. Some users feel this behavior to be strange.
These patches are for this feature, that is, for charging to the new
cgroup and, of course, uncharging from the old cgroup at task migration.
This patch adds "memory.move_charge_at_immigrate" file, which is a flag
file to determine whether charges should be moved to the new cgroup at
task migration or not and what type of charges should be moved. This
patch also adds read and write handlers of the file.
This patch also adds no-op handlers for this feature. These handlers will
be implemented in later patches. And you cannot write any values other
than 0 to move_charge_at_immigrate yet.
Add a forgotten item into CONTENTS.
Acked-by: Paul Menage <menage@google.com>
Provides support for unloading modular subsystems.
This patch adds a new function cgroup_unload_subsys which is to be used
for removing a loaded subsystem during module deletion. Reference
counting of the subsystems' modules is moved from once (at load time) to
once per attached hierarchy (in parse_cgroupfs_options and
rebind_subsystems) (i.e., 0 or 1).
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Add interface between cgroups subsystem management and module loading
This patch implements rudimentary module-loading support for cgroups -
namely, a cgroup_load_subsys (similar to cgroup_init_subsys) for use as a
module initcall, and a struct module pointer in struct cgroup_subsys.
Several functions that might be wanted by modules have had EXPORT_SYMBOL
added to them, but it's unclear exactly which functions want it and which
won't.
Add cancel_attach() operation to struct cgroup_subsys. cancel_attach()
can be used when can_attach() operation prepares something for the subsys,
but we should rollback what can_attach() operation has prepared if attach
task fails after we've succeeded in can_attach().
Reviewed-by: Paul Menage <menage@google.com>
Gmail web gui does not work for sending patches now even with firefox
"view source with" extension. It will use windows style line breaks to
wrap lines automatically when sening email.
Rewrite the gmail web gui part of email client documentation.
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Martin Bligh <mbligh@mbligh.org>
x86/Voyager support has been removed a year ago.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Inspired-by: Jonathan Corbet <corbet@lwn.net>
Add header file requirements. Compliments of Stephen Rothwell.
Stephen calls this Rule #1, so I put it there, but I didn't want to demote
any of the others in the list, so I made one of them number 2b.
Documentation/vm/:
Expose example and tool source files in the Documentation/ directory in
their own files instead of being buried (almost hidden) in readme/txt files.
This should help to prevent bitrot.
This will make them more visible/usable to users who may need
to use them, to developers who may need to test with them, and
to anyone who would fix/update them if they were more visible.
Also, if any of these possibly should not be in the kernel tree at
all, it will be clearer that they are here and we can discuss if
they should be removed.
Also build the recently-added map_hugetlb.c.
Make several functions static to prevent linker warnings.
Acked-by: Eric B Munson <ebmunson@us.ibm.com>
Make dnotify_test.c source file and add it to Makefile so that
bitrot can be prevented.
Documentation/laptops/laptop-mode.txt:
Documentation/timers/hpet.txt:
Expose example and tool source files in the Documentation/timers/ directory in
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (62 commits)
msi-laptop: depends on RFKILL
msi-laptop: Detect 3G device exists by standard ec command
msi-laptop: Add resume method for set the SCM load again
msi-laptop: Support some MSI 3G netbook that is need load SCM
msi-laptop: Add threeg sysfs file for support query 3G state by standard 66/62 ec command
msi-laptop: Support standard ec 66/62 command on MSI notebook and nebook
Driver core: create lock/unlock functions for struct device
sysfs: fix for thinko with sysfs_bin_attr_init()
sysfs: Kill unused sysfs_sb variable.
sysfs: Pass super_block to sysfs_get_inode
driver core: Use sysfs_rename_link in device_rename
sysfs: Implement sysfs_rename_link
sysfs: Pack sysfs_dirent more tightly.
sysfs: Serialize updates to the vfs inode
sysfs: windfarm: init sysfs attributes
sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on module dynamic attributes
sysfs: Document sysfs_attr_init and sysfs_bin_attr_init
sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on dynamic attributes
sysfs: Use one lockdep class per sysfs attribute.
sysfs: Only take active references on attributes.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ALSA: hdmi - show debug message on changing audio infoframe
ALSA: hdmi - merge common code for intelhdmi and nvhdmi
ALSA: hda - Add ASRock mobo to MSI blacklist
ALSA: hda: uninitialized variable fix
ALSA: hda: Use LPIB for a Biostar Microtech board
ALSA: usb/audio.h: Fix field order
ALSA: fix jazz16 compile (udelay)
ALSA: hda: Use LPIB for Dell Latitude 131L
ALSA: hda - Build hda_eld into snd-hda-codec module
ALSA: hda - Support NVIDIA MCP89 and GT21x hdmi audio
ALSA: hda - Support max codecs to 8 for nvidia hda controller
ALSA: riptide: clean up while loop
ALSA: usbaudio - remove debug "SAMPLE BYTES" printk line
ALSA: timer - pass real event in snd_timer_notify1() to instance callback
ALSA: oxygen: change || to &&
ALSA: opti92x: use PnP data to select Master Control port
ASoC: fix ak4104 register array access
ASoC: soc_pcm_open: Add missing bailout tag
ALSA: usbaudio: Fix wrong bitrate for Creative Creative VF0470 Live Cam
ALSA: ua101: removing debugging code
Constify struct sysfs_ops.
This is part of the ops structure constification
effort started by Arjan van de Ven et al.
Benefits of this constification:
* prevents modification of data that is shared
(referenced) by many other structure instances
at runtime
* detects/prevents accidental (but not intentional)
modification attempts on archs that enforce
read-only kernel data at runtime
* potentially better optimized code as the compiler
can assume that the const data cannot be changed
* the compiler/linker move const data into .rodata
and therefore exclude them from false sharing
Signed-off-by: Emese Revfy <re.emese@gmail.com>
Acked-by: David Teigland <teigland@redhat.com>
Acked-by: Matt Domsch <Matt_Domsch@dell.com>
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
One of the roles which -mm fulfilled some time ago (to offer an
integration testing ground) has been taken over by -next. This is still
news to Documentation/HOWTO, so mention it there.
Also add a word on how patchwork is used to track patches as they make
their way into subsystem trees. Remove some arbitrary links to
subsystem repositories; they can all be found in the MAINTAINERS
database.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
* 'x86-mrst-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits)
x86, mrst: Fix whitespace breakage in apb_timer.c
x86, mrst: Fix APB timer per cpu clockevent
x86, mrst: Remove X86_MRST dependency on PCI_IOAPIC
x86, olpc: Use pci subarch init for OLPC
x86, pci: Add arch_init to x86_init abstraction
x86, mrst: Add Kconfig dependencies for Moorestown
x86, pci: Exclude Moorestown PCI code if CONFIG_X86_MRST=n
x86, numaq: Make CONFIG_X86_NUMAQ depend on CONFIG_PCI
x86, pci: Add sanity check for PCI fixed bar probing
x86, legacy_irq: Remove duplicate vector assigment
x86, legacy_irq: Remove left over nr_legacy_irqs
x86, mrst: Platform clock setup code
x86, apbt: Moorestown APB system timer driver
x86, mrst: Add vrtc platform data setup code
x86, mrst: Add platform timer info parsing code
x86, mrst: Fill in PCI functions in x86_init layer
x86, mrst: Add dummy legacy pic to platform setup
x86/PCI: Moorestown PCI support
x86, ioapic: Add dummy ioapic functions
x86, ioapic: Early enable ioapic for timer irq
Fixed up semantic conflict of new clocksources due to commit
17622339af25 ("clocksource: add argument to resume callback").
* 'for-linus/i2c' of git://git.fluff.org/bjdooks/linux:
i2c: Add support for Xilinx XPS IIC Bus Interface
i2c: omap: Add support for 16-bit registers
i2c-pnx: fix setting start/stop condition
powerpc: doc/dts-bindings: update doc of FSL I2C bindings
i2c-mpc: add support for the MPC512x processors from Freescale
i2c-mpc: rename "setclock" initialization functions to "setup"
i2c-mpc: use __devinit[data] for initialization functions and data
i2c/imx: don't add probe function to the driver struct
i2c: Add support for Ux500/Nomadik I2C controller
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Provide generic subsystem-level callbacks
PM / Runtime: Document power.runtime_auto and related functions
This patch adds the MPC5121 to the list of supported devices,
enhances the doc of the "clock-frequency" property and removes
the obsolete "cell-index", "device_type" and "fsl-i2c" property.
Furthermore an example for the MPC5121 has been added.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Fix cast warning in pcc driver.
[CPUFREQ] Processor Clocking Control interface driver
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs:
[LogFS] Change magic number
[LogFS] Remove h_version field
[LogFS] Check feature flags
[LogFS] Only write journal if dirty
[LogFS] Fix bdev erases
[LogFS] Silence gcc
[LogFS] Prevent 64bit divisions in hash_index
[LogFS] Plug memory leak on error paths
[LogFS] Add MAINTAINERS entry
[LogFS] add new flash file system
Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in
fs/logfs/inode.c introduced by write_inode() being changed to use
writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d
("pass writeback_control to ->write_inode")
There are subsystems whose power management callbacks only need to
invoke the callbacks provided by device drivers. Still, their system
sleep PM callbacks should play well with the runtime PM callbacks,
so that devices suspended at run time can be left in that state for
a system sleep transition.
Provide a set of generic PM callbacks for such subsystems and
define convenience macros for populating dev_pm_ops structures.
The power.runtime_auto device flag and the helper functions
pm_runtime_allow() and pm_runtime_forbid() used to modify it are a
part of the run-time power management framework and therefore they
should be described in Documentation/power/runtime_pm.txt.
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm raid1: fix deadlock when suspending failed device
dm: eliminate some holes data structures
dm ioctl: introduce flag indicating uevent was generated
dm: free dm_io before bio_endio not after
dm table: remove unused dm_get_device range parameters
dm ioctl: only issue uevent on resume if state changed
dm raid1: always return error if all legs fail
dm mpath: refactor pg_init
dm mpath: wait for pg_init completion when suspending
dm mpath: hold io until all pg_inits completed
dm mpath: avoid storing private suspended state
dm: document when snapshot has finished merging
dm table: remove dm_get from dm_table_get_md
dm mpath: skip activate_path for failed paths
dm mpath: pass struct pgpath to pg init done
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (23 commits)
hwmon: Remove the deprecated adt7473 driver
hwmon: Fix off-by-one kind values
hwmon: (tmp421) Fix temperature conversions
hwmon: (tmp421) Restore missing inputs
hwmon: Driver for Andigilog aSC7621 family monitoring chips
hwmon: (adt7411) Improve locking
hwmon: Add driver for ADT7411 voltage and temperature sensor
hwmon: (w83793) Add watchdog functionality
hwmon: (g760a) Make rpm_from_cnt static
hwmon: (it87) Validate auto pwm settings
hwmon: (it87) Add support for old automatic fan speed control
hwmon: (it87) Drop dead web links in documentation
hwmon: (it87) Add an entry in MAINTAINERS
hwmon: (it87) Use strict_strtol instead of simple_strtol
hwmon: (it87) Fix many checkpatch errors and warnings
hwmon: (it87) Add support for beep on alarm
hwmon: (it87) Create vid attributes by group
hwmon: (it87) Refactor attributes creation and removal
hwmon: (it87) Expose the PWM/temperature mappings
hwmon: (it87) Display fan outputs in automatic mode as such
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: (22 commits)
nfsd4: fix minor memory leak
svcrpc: treat uid's as unsigned
nfsd: ensure sockets are closed on error
Revert "sunrpc: move the close processing after do recvfrom method"
Revert "sunrpc: fix peername failed on closed listener"
sunrpc: remove unnecessary svc_xprt_put
NFSD: NFSv4 callback client should use RPC_TASK_SOFTCONN
xfs_export_operations.commit_metadata
commit_metadata export operation replacing nfsd_sync_dir
lockd: don't clear sm_monitored on nsm_reboot_lookup
lockd: release reference to nsm_handle in nlm_host_rebooted
nfsd: Use vfs_fsync_range() in nfsd_commit
NFSD: Create PF_INET6 listener in write_ports
SUNRPC: NFS kernel APIs shouldn't return ENOENT for "transport not found"
SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt()
NFSD: Support AF_INET6 in svc_addsock() function
SUNRPC: Use rpc_pton() in ip_map_parse()
nfsd: 4.1 has an rfc number
nfsd41: Create the recovery entry for the NFSv4.1 client
nfsd: use vfs_fsync for non-directories
gpio_request() without initial configuration of the GPIO is normally
useless, introduce gpio_request_one() together with GPIOF_ flags for
input/output direction and initial output level.
gpio_{request,free}_array() for multiple GPIOs.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Ben Nizette <bn@niasdigital.com>
Add adds a debugfs interface and additional failure modes to LKDTM to
provide similar functionality to the provoke-crash driver submitted here:
http://lwn.net/Articles/371208/
Crashes can now be induced either through module parameters (as before)
or through the debugfs interface as in provoke-crash.
The patch also provides a new "direct" interface, where KPROBES are not
used, i.e., the crash is invoked directly upon write to the debugfs
file. When built without KPROBES configured, only this mode is available.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Cc: M. Mohan Kumar <mohan@in.ibm.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>,
- new Documentation/init.txt file describing various forms of failure
trying to load the init binary after kernel bootup
- extend the init/main.c init failure message to direct to
Signed-off-by: Andreas Mohr <andi@lisas.de>
Add a bare description of what /sys/devices/system/node/nodeX is. Others
will follow in time but right now, none of that tree is documented. The
existence of this file might at least encourage people to document new
entries.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
