path: root/Documentation
2006-06-30Documentation/IPMI typosMatt LaPlante
Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-30Documentation/DocBook/mtdnand.tmpl: typo fixesPatrick Pletscher
2006-06-30typo fixes in Documentation/networking/pktgen.txtAdrian Bunk
Three typos in only one line... Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-30typo fixes: occuring -> occurringAdrian Bunk
2006-06-30typo fixes: disadvantadge -> disadvantageAdrian Bunk
2006-06-30typo fixes: aquire -> acquireAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-29Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: ocfs2: remove redundant NULL checks in ocfs2_direct_IO_get_blocks() ocfs2: clean up some osb fields ocfs2: fix init of uuid_net_key ocfs2: silence a debug print ocfs2: silence ENOENT during lookup of broken links ocfs2: Cleanup message prints ocfs2: silence -EEXIST from ocfs2_extent_map_insert/lookup [PATCH] fs/ocfs2/dlm/dlmrecovery.c: make dlm_lockres_master_requery() static ocfs2: warn the user on a dead timeout mismatch ocfs2: OCFS2_FS must depend on SYSFS ocfs2: Compile-time disabling of ocfs2 debugging output. configfs: Clear up a few extra spaces where there should be TABs. configfs: Release memory in configfs_example.
2006-06-29configfs: Release memory in configfs_example.Joel Becker
The configfs_example module was missing a ->release(). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-29Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (33 commits) [MIPS] Add missing backslashes to macro definitions. [MIPS] Death list of board support to be removed after 2.6.18. [MIPS] Remove BSD and Sys V compat data types. [MIPS] ioc3.h: Uses u8, so include <linux/types.h>. [MIPS] 74K: Assume it will also have an AR bit in config7 [MIPS] Treat CPUs with AR bit as physically indexed. [MIPS] Oprofile: Support VSMP on 34K. [MIPS] MIPS32/MIPS64 S-cache fix and cleanup [MIPS] excite: PCI makefile needs to use += if it wants a chance to work. [MIPS] excite: plat_setup -> plat_mem_setup. [MIPS] au1xxx: export dbdma functions [MIPS] au1xxx: dbdma, no sleeping under spin_lock [MIPS] au1xxx: fix PSC_SMBTXRX_RSR. [MIPS] Early printk for IP27. [MIPS] Fix handling of 0 length I & D caches. [MIPS] Typo fixes. [MIPS] MIPS32/MIPS64 secondary cache management [MIPS] Fix FIXADDR_TOP for TX39/TX49. [MIPS] Remove first timer interrupt setup in wrppmc_timer_setup() [MIPS] Fix configuration of R2 CPU features and multithreading. ...
2006-06-29[MIPS] Death list of board support to be removed after 2.6.18.Ralf Baechle
As usual fixes would be prefered. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29Remove au1x00_uart from feature-removal-schedule.txt.Ralf Baechle
The driver has been removed a while ago already. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: [ALSA] echoaudio - Remove kfree_nocheck() [ALSA] echoaudio - Fix Makefile [ALSA] Add Intel D965 board support [ALSA] Fix/add support of Realtek ALC883 / ALC888 and ALC861 codecs [ALSA] Fix a typo in echoaudio/midi.c [ALSA] snd-aoa: enable dual-edge in GPIOs [ALSA] snd-aoa: support iMac G5 iSight [ALSA] snd-aoa: not experimental [ALSA] Add echoaudio sound drivers [ALSA] ak4xxx-adda - Code clean-up [ALSA] Remove CONFIG_EXPERIMENTAL from intel8x0m driver [ALSA] Stereo controls for M-Audio Revolution cards [ALSA] Fix misuse of __list_add() in seq_ports.c [ALSA] hda-codec - Add model entry for Samsung X60 Chane [ALSA] make CONFIG_SND_DYNAMIC_MINORS non-experimental [ALSA] Fix wrong dependencies of snd-aoa driver [ALSA] fix build failure due to snd-aoa [ALSA] AD1888 mixer controls for DC mode [ALSA] Suppress irq handler mismatch messages in ALSA ISA drivers [ALSA] usb-audio support for Turtle Beach Roadie
2006-06-29Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (28 commits) [S390] rework of channel measurement facility. [S390] appldata enhancements. [S390] Add vmpanic parameter. [S390] add PAV support to the dasd driver. [S390] remove export of sys_call_table [S390] remove unused macros from binfmt_elf32.c [S390] fix duplicate export of overflow{ug}id [S390] cio chpid offline. [S390] avenrun export in appdata_base.c Convert s390_collect_crw_info() in s390mach.c from being started [S390] dasd eer data format. [S390] preempt_count initialization. [S390] head.S code moving. [S390] dasd whitespace and other cosmetics. [S390] virtual cpu accounting vs. machine checks. [S390] add __cpuinit to appldata cpu hotplug notifier. [S390] dasd_eckd_dump_sense bug. [S390] missing check in dasd_eer_open. [S390] modular 3270 driver. [S390] console_unblank woes. ...
2006-06-29[PATCH] genirq: irq: document what an IRQ isEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rajesh Shah <rajesh.shah@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: "Protasevich, Natalie" <Natalie.Protasevich@UNISYS.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: doc: add design documentationThomas Gleixner
Add docbook file - includes API documentation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] Keys: Allow in-kernel key requestor to pass auxiliary data to upcallerDavid Howells
The proposed NFS key type uses its own method of passing key requests to userspace (upcalling) rather than invoking /sbin/request-key. This is because the responsible userspace daemon should already be running and will be contacted through rpc_pipefs. This patch permits the NFS filesystem to pass auxiliary data to the upcall operation (struct key_type::request_key) so that the upcaller can use a pre-existing communications channel more easily. Signed-off-by: David Howells <dhowells@redhat.com> Acked-By: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[S390] Add vmpanic parameter.Peter Oberparleiter
Implementation of new kernel parameter vmpanic that provides a means to perform a z/VM CP command after a kernel panic occurred. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-06-28Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] Documentation/watchdog update [WATCHDOG] convert AT91RM9200 watchdog to platform driver [WATCHDOG] add WDIOC_GETTIMELEFT ioctl [WATCHDOG] Pre-Timeout flags
2006-06-28[PATCH] Add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPLArjan van de Ven
Temporarily add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPL. These will be used as a transition measure for symbols that aren't used in the kernel and are on the way out. When a module uses such a symbol, a warning is printk'd at modprobe time. The main reason for removing unused exports is size: eacho export takes roughly between 100 and 150 bytes of kernel space in the binary. This patch gives users the option to immediately get this size gain via a config option. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[WATCHDOG] Documentation/watchdog updateRandy Dunlap
Documentation/watchdog/: Expose example and tool source files in the Documentation/ directory in their own files instead of being buried (almost hidden) in readme/txt files. This will make them more visible/usable to users who may need to use them, to developers who may need to test with them, and to janitors who would update them if they were more visible. Also, if any of these possibly should not be in the kernel tree at all, it will be clearer that they are here and we can discuss if they should be removed. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-06-28[ALSA] Fix/add support of Realtek ALC883 / ALC888 and ALC861 codecsTakashi Iwai
Patch from Realtek: - Fix ALC883 support code - Add support of ALC888 codec - Add ALC660 support (ALC861-compatible) - Add HP xw4400/6400/8400/9400 support (model=hp-bpc) - Code clean-up: fix spaces and indentation Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] Add echoaudio sound driversGiuliano Pochini
From: Giuliano Pochini <pochini@shiny.it>Add echoaudio sound drivers (darla20, darla24, echo3g, gina20, gina24, indigo, indigodj, indigoio, layla20, lala24, mia, mona) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-27Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (26 commits) V4L/DVB (4263): Fix warning when compiling on 64 bit machines V4L/DVB (4261): Included required header for in-kernel compilation V4L/DVB (4260): Stradis.c: make 2 functions static V4L/DVB (4259): Pass an explicit log prefix to cx2341x_log_status V4L/DVB (4257): Fix 64-bit compile warnings. V4L/DVB (4255): Tda9887 default TOP value is 0x10 V4L/DVB (4254): Remove obsoleted tuner_debug option. V4L/DVB (4253): IVTV VBI format description too long. V4L/DVB (4252): Remove duplicate 'tda9887' in info messages. V4L/DVB (4245): Reduce the amount of pvrusb2-sourced noise going into the system log V4L/DVB (4244): Implement use of cx2341x module in pvrusb2 driver V4L/DVB (4243): Exploit new V4L control features in pvrusb2 V4L/DVB (4242): Don't suspend encoder when changing its attributes (in pvrusb2) V4L/DVB (4241): Fix faulty encoder error recovery in pvrusb2 V4L/DVB (4240): Various V4L control enhancements in pvrusb2 V4L/DVB (4239): Handle boolean controls in pvrusb2 V4L/DVB (4238): Make sure flags field is initialized when quering a control in pvrusb2 V4L/DVB (4237): Move LOG_STATUS bracketing to a different part of the pvrusb2 driver V4L/DVB (4236): Rearrange things in pvrusb2 driver in preparation for using cx2341x module V4L/DVB (4235): Increase the maximum number of controls that pvrusb2-sysfs.c can handle. ...
2006-06-27[PATCH] pi-futex: rt mutex docsSteven Rostedt
Add rt-mutex documentation. [rostedt@goodmis.org: Update rt-mutex-design.txt as per Randy Dunlap suggestions] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: robust futex docs fixIngo Molnar
Fix typo in Documentation/robust-futexes.txt. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rcutorture: add ops vector and Classic RCU opsPaul E. McKenney
Add an ops vector to rcutorture, and add the ops for Classic RCU. Update the rcutorture documentation to reflect slight change to the dmesg formats. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rcutorture: catchup doc fixes for idle-hz testsPaul E. McKenney
This just catches the RCU torture documentation up with the recent fixes that test RCU for architectures that turn of the scheduling-clock interrupt for idle CPUs and the addition of a SUCCESS/FAILURE indication, fixing up an obsolete comment as well. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] vdso: randomize the i386 vDSO by moving it into a vmaIngo Molnar
Move the i386 VDSO down into a vma and thus randomize it. Besides the security implications, this feature also helps debuggers, which can COW a vma-backed VDSO just like a normal DSO and can thus do single-stepping and other debugging features. It's good for hypervisors (Xen, VMWare) too, which typically live in the same high-mapped address space as the VDSO, hence whenever the VDSO is used, they get lots of guest pagefaults and have to fix such guest accesses up - which slows things down instead of speeding things up (the primary purpose of the VDSO). There's a new CONFIG_COMPAT_VDSO (default=y) option, which provides support for older glibcs that still rely on a prelinked high-mapped VDSO. Newer distributions (using glibc 2.3.3 or later) can turn this option off. Turning it off is also recommended for security reasons: attackers cannot use the predictable high-mapped VDSO page as syscall trampoline anymore. There is a new vdso=[0|1] boot option as well, and a runtime /proc/sys/vm/vdso_enabled sysctl switch, that allows the VDSO to be turned on/off. (This version of the VDSO-randomization patch also has working ELF coredumping, the previous patch crashed in the coredumping code.) This code is a combined work of the exec-shield VDSO randomization code and Gerd Hoffmann's hypervisor-centric VDSO patch. Rusty Russell started this patch and i completed it. [akpm@osdl.org: cleanups] [akpm@osdl.org: compile fix] [akpm@osdl.org: compile fix 2] [akpm@osdl.org: compile fix 3] [akpm@osdl.org: revernt MAXMEM change] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Cc: Gerd Hoffmann <kraxel@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Zachary Amsden <zach@vmware.com> Cc: Andi Kleen <ak@muc.de> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27V4L/DVB (4228a): pvrusb2 to kernel 2.6.18Mike Isely
Implement V4L2 driver for the Hauppauge PVR USB2 TV tuner. The Hauppauge PVR USB2 is a USB connected TV tuner with an embedded cx23416 hardware MPEG2 encoder. There are two major variants of this device; this driver handles both. Any V4L2 application which understands MPEG2 video stream data should be able to work with this device. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-26Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3657/1: S3C24XX: Documentation update of Overview.txt [ARM] Update mach-types [ARM] 3656/1: S3C2412: Add S3C2412 and S3C2413 documenation [ARM] 3654/1: add ajeco 1arm sbc support [ARM] fix drivers/mfd/ucb1x00-core.c IRQ probing bug [ARM] 3651/1: S3C24XX: Make arch list more detailed [ARM] 3650/1: S3C2412: Update s3c2410_defconfig [ARM] 3649/1: S3C24XX: Fix capitalisation of CPU on SMDK2440 [ARM] 3612/1: make pci bus optional for ixp4xx platform [ARM] Remove MODE_(SVC|IRQ|FIQ|USR) and DEFAULT_FIQ [ARM] Remove save_lr/restore_pc macros [ARM] Remove partial non-v6 binutils compatibility [ARM] Remove LOADREGS macro [ARM] Remove RETINSTR macro
2006-06-26[ARM] 3657/1: S3C24XX: Documentation update of Overview.txtBen Dooks
Patch from Ben Dooks Update the list of supported devices, and remove the changelog. Add SMDK2413 information.-- Signed-off-by: Ben Dooks <ben-linux@fluff.org>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: typo fixes Clean up 'inline is not at beginning' warnings for usb storage Storage class should be first i386: Trivial typo fixes ixj: make ixj_set_tone_off() static spelling fixes fix paniced->panicked typos Spelling fixes for Documentation/atomic_ops.txt move acknowledgment for Mark Adler to CREDITS remove the bouncing email address of David Campbell
2006-06-26[PATCH] devfs: Remove it from the feature_removal.txt fileGreg Kroah-Hartman
This file was created due to the issue regarding how to notify people that devfs was going to be removed. Finally remove the entry as it has served its purpose. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.Greg Kroah-Hartman
Just removes a few unused #defines and fixes some comments due to devfs now being gone. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs documentation from the kernel treeGreg Kroah-Hartman
Removes the Documentaiton/filesystems/devfs/ directory Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[ARM] 3656/1: S3C2412: Add S3C2412 and S3C2413 documenationBen Dooks
Patch from Ben Dooks Add some basic documentation about the support for the S3C2412 and S3C2413 CPUs-- Signed-off-by: Ben Dooks <ben-linux@fluff.org>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: trivial fixes in Makefile kbuild: adding symbols in Kconfig and defconfig to TAGS kbuild: replace abort() with exit(1) kbuild: support for %.symtypes files kbuild: fix silentoldconfig recursion kbuild: add option for stripping modules while installing them kbuild: kill some false positives from modpost kbuild: export-symbol usage report generator kbuild: fix make -rR breakage kbuild: append -dirty for updated but uncommited changes kbuild: append git revision for all untagged commits kbuild: fix module.symvers parsing in modpost kbuild: ignore make's built-in rules & variables kbuild: bugfix with initramfs kbuild: modpost build fix kbuild: check license compatibility when building modules kbuild: export-type enhancement to modpost.c kbuild: add dependency on kernel.release to the package targets kbuild: `make kernelrelease' speedup kconfig: KCONFIG_OVERWRITECONFIG ...
2006-06-26Merge branch 'x86-64'Linus Torvalds
* x86-64: (83 commits) [PATCH] x86_64: x86_64 stack usage debugging [PATCH] x86_64: (resend) x86_64 stack overflow debugging [PATCH] x86_64: msi_apic.c build fix [PATCH] x86_64: i386/x86-64 Add nmi watchdog support for new Intel CPUs [PATCH] x86_64: Avoid broadcasting NMI IPIs [PATCH] x86_64: fix apic error on bootup [PATCH] x86_64: enlarge window for stack growth [PATCH] x86_64: Minor string functions optimizations [PATCH] x86_64: Move export symbols to their C functions [PATCH] x86_64: Standardize i386/x86_64 handling of NMI_VECTOR [PATCH] x86_64: Fix modular pc speaker [PATCH] x86_64: remove sys32_ni_syscall() [PATCH] x86_64: Do not use -ffunction-sections for modules [PATCH] x86_64: Add cpu_relax to apic_wait_icr_idle [PATCH] x86_64: adjust kstack_depth_to_print default [PATCH] i386/x86-64: adjust /proc/interrupts column headings [PATCH] x86_64: Fix race in cpu_local_* on preemptible kernels [PATCH] x86_64: Fix fast check in safe_smp_processor_id [PATCH] x86_64: x86_64 setup.c - printing cmp related boottime information [PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status ... Manual resolve of trivial conflict in arch/i386/kernel/Makefile
2006-06-26[PATCH] x86_64: Calgary IOMMU - Calgary specific bitsJon Mason
This patch hooks Calgary into the build, the x86-64 IOMMU initialization paths, and introduces the Calgary specific bits. The implementation draws inspiration from both PPC (which has support for the same chip but requires firmware support which we don't have on x86-64) and gart. Calgary is different from gart in that it support a translation table per PHB, as opposed to the single gart aperture. Changes from previous version: * Addition of boot-time disablement for bus-level translation/isolation (e.g, enable userspace DMA for things like X) * Usage of newer IOMMU abstraction functions Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26typo fixesolecom@mail.ru
2006-06-26[PATCH] md: Allow the write_mostly flag to be set via sysfsNeilBrown
It appears in /sys/mdX/md/dev-YYY/state and can be set or cleared by writing 'writemostly' or '-writemostly' respectively. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: Allow resync_start to be set and queried via sysfsNeilBrown
2006-06-26[PATCH] md: Allow raid 'layout' to be read and set via sysfsNeilBrown
2006-06-26[PATCH] md: Allow rdev state to be set via sysfsNeilBrown
The md/dev-XXX/state file can now be written: "faulty" simulates an error on the device "remove" removes the device from the array (if it is not busy) Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: Set/get state of array via sysfsNeilBrown
This allows the state of an md/array to be directly controlled via sysfs and adds the ability to stop and array without tearing it down. Array states/settings: clear No devices, no size, no level Equivalent to STOP_ARRAY ioctl inactive May have some settings, but array is not active all IO results in error When written, doesn't tear down array, but just stops it suspended (not supported yet) All IO requests will block. The array can be reconfigured. Writing this, if accepted, will block until array is quiescent readonly no resync can happen. no superblocks get written. write requests fail read-auto like readonly, but behaves like 'clean' on a write request. clean - no pending writes, but otherwise active. When written to inactive array, starts without resync If a write request arrives then if metadata is known, mark 'dirty' and switch to 'active'. if not known, block and switch to write-pending If written to an active array that has pending writes, then fails. active fully active: IO and resync can be happening. When written to inactive array, starts with resync write-pending (not supported yet) clean, but writes are blocked waiting for 'active' to be written. active-idle like active, but no writes have been seen for a while (100msec). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md: increase the delay before marking metadata clean, and make it ↵NeilBrown
configurable When a md array has been idle (no writes) for 20msecs it is marked as 'clean'. This delay turns out to be too short for some real workloads. So increase it to 200msec (the time to update the metadata should be a tiny fraction of that) and make it sysfs-configurable. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] VT binding: Update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt and Documentatin/console/console.txt to reflect the following changes: 1. sysfs attributes are relocated to /sys/class/vtconsole 2. feature is selectable in Kconfig 3. add sample scripts to fbcon.txt Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] VT binding: Add new doc file describing the featureAntonino A. Daplas
This newly added file will: - Describe the characteristics of 2 general types of console drivers - How to use the sysfs to unbind and bind console drivers - Uses for this feature Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] VT binding: fbcon: Update documentationAntonino A. Daplas
Update Documentation/fb/fbcon.txt to reflect the following changes: 1. Simple illustration of the binding of the console down to individual framebuffer drivers 2. Usage of userspace tools to help with recovery of text console 3. How to use the attributes in /sys/class/tty/console to unload fbcon and the framebuffer drivers Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
