path: root/Documentation
2011-01-09Merge branch 'dccp' of git://eden-feed.erg.abdn.ac.uk/net-next-2.6David S. Miller
2011-01-07Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits) spi/omap: Fix DMA API usage in OMAP MCSPI driver spi/imx: correct the test on platform_get_irq() return value spi/topcliff: Typo fix threhold to threshold spi/dw_spi Typo change diable to disable. spi/fsl_espi: change the read behaviour of the SPIRF spi/mpc52xx-psc-spi: move probe/remove to proper sections spi/dw_spi: add DMA support spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs spi/dw_spi: Fix too short timeout in spi polling loop spi/pl022: convert running variable spi/pl022: convert busy flag to a bool spi/pl022: pass the returned sglen to the DMA engine spi/pl022: map the buffers on the DMA engine spi/topcliff_pch: Fix data transfer issue spi/imx: remove autodetection spi/pxa2xx: pass of_node to spi device and set a parent device spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes. spi/pxa2xx: Add chipselect support for Sodaville spi/pxa2xx: Consider CE4100's FIFO depth spi/pxa2xx: Add CE4100 support ...
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2011-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (58 commits) Input: wacom_w8001 - support pen or touch only devices Input: wacom_w8001 - use __set_bit to set keybits Input: bu21013_ts - fix misuse of logical operation in place of bitop Input: i8042 - add Acer Aspire 5100 to the Dritek list Input: wacom - add support for digitizer in Lenovo W700 Input: psmouse - disable the synaptics extension on OLPC machines Input: psmouse - fix up Synaptics comment Input: synaptics - ignore bogus mt packet Input: synaptics - add multi-finger and semi-mt support Input: synaptics - report clickpad property input: mt: Document interface updates Input: fix double equality sign in uevent Input: introduce device properties hid: egalax: Add support for Wetab (726b) Input: include MT library as source for kerneldoc MAINTAINERS: Update input-mt entry hid: egalax: Add support for Samsung NB30 netbook hid: egalax: Document the new devices in Kconfig hid: egalax: Add support for Wetab hid: egalax: Convert to MT slots ... Fixed up trivial conflict in drivers/input/keyboard/Kconfig
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2011-01-07Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits) USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004) USB: serial: ftdi_sio: add support for TIOCSERGETLSR USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport USB: atmel_usba_udc: fix freeing irq in usba_udc_remove() usb: ehci-omap: fix tll channel enable mask usb: ohci-omap3: fix trivial typo USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096 USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's USB: gadget: update ci13xxx to work with g_ether USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers Revert "USB: musb: pm: don't rely fully on clock support" Revert "USB: musb: blackfin: pm: make it work" USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added ... Manually fix up trivial conflicts in USB Kconfig changes in: arch/arm/mach-omap2/Kconfig arch/sh/Kconfig drivers/usb/Kconfig drivers/usb/host/ehci-hcd.c and annoying chip clock data conflicts in: arch/arm/mach-omap2/clock3xxx_data.c arch/arm/mach-omap2/clock44xx_data.c
2011-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (147 commits) [SCSI] arcmsr: fix write to device check [SCSI] lpfc: lower stack use in lpfc_fc_frame_check [SCSI] eliminate an unnecessary local variable from scsi_remove_target() [SCSI] libiscsi: use bh locking instead of irq with session lock [SCSI] libiscsi: do not take host lock in queuecommand [SCSI] be2iscsi: fix null ptr when accessing task hdr [SCSI] be2iscsi: fix gfp use in alloc_pdu [SCSI] libiscsi: add more informative failure message during iscsi scsi eh [SCSI] gdth: Add missing call to gdth_ioctl_free [SCSI] bfa: remove unused defintions and misc cleanups [SCSI] bfa: remove inactive functions [SCSI] bfa: replace bfa_assert with WARN_ON [SCSI] qla2xxx: Use sg_next to fetch next sg element while walking sg list. [SCSI] qla2xxx: Fix to avoid recursive lock failure during BSG timeout. [SCSI] qla2xxx: Remove code to not reset ISP82xx on failure. [SCSI] qla2xxx: Display mailbox register 4 during 8012 AEN for ISP82XX parts. [SCSI] qla2xxx: Don't perform a BIG_HAMMER if Get-ID (0x20) mailbox command fails on CNAs. [SCSI] qla2xxx: Remove redundant module parameter permission bits [SCSI] qla2xxx: Add sysfs node for displaying board temperature. [SCSI] qla2xxx: Code cleanup to remove unwanted comments and code. ...
2011-01-07Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: (57 commits) fs: scale mntget/mntput fs: rename vfsmount counter helpers fs: implement faster dentry memcmp fs: prefetch inode data in dcache lookup fs: improve scalability of pseudo filesystems fs: dcache per-inode inode alias locking fs: dcache per-bucket dcache hash locking bit_spinlock: add required includes kernel: add bl_list xfs: provide simple rcu-walk ACL implementation btrfs: provide simple rcu-walk ACL implementation ext2,3,4: provide simple rcu-walk ACL implementation fs: provide simple rcu-walk generic_check_acl implementation fs: provide rcu-walk aware permission i_ops fs: rcu-walk aware d_revalidate method fs: cache optimise dentry and inode for rcu-walk fs: dcache reduce branches in lookup path fs: dcache remove d_mounted fs: fs_struct use seqlock fs: rcu-walk for path lookup ...
2011-01-07dccp: make upper bound for seq_window consistent on 32/64 bitGerrit Renker
The 'seq_window' sysctl sets the initial value for the DCCP Sequence Window, which may range from 32..2^46-1 (RFC 4340, 7.5.2). The patch sets the upper bound consistently to 2^32-1 on both 32 and 64 bit systems, which should be sufficient - with a RTT of 1sec and 1-byte packets, a seq_window of 2^32-1 corresponds to a link speed of 34 Gbps. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (243 commits) omap2: Make OMAP2PLUS select OMAP_DM_TIMER OMAP4: hwmod data: Fix alignment and end of line in structurefields OMAP4: hwmod data: Move the DMA structures OMAP4: hwmod data: Move the smartreflex structures OMAP4: hwmod data: Fix missing SIDLE_SMART_WKUP in smartreflexsysc arm: omap: tusb6010: add name for MUSB IRQ arm: omap: craneboard: Add USB EHCI support omap2+: Initialize serial port for dynamic remuxing for n8x0 omap2+: Add struct omap_board_data and use it for platform level serial init omap2+: Allow hwmod state changes to mux pads based on the state changes omap2+: Add support for hwmod specific muxing of devices omap2+: Add omap_mux_get_by_name OMAP2: PM: fix compile error when !CONFIG_SUSPEND MAINTAINERS: OMAP: hwmod: update hwmod code, data maintainership OMAP4: Smartreflex framework extensions OMAP4: hwmod: Add inital data for smartreflex modules. OMAP4: PM: Program correct init voltages for scalable VDDs OMAP4: Adding voltage driver support OMAP4: Register voltage PMIC parameters with the voltage layer OMAP3: PM: Program correct init voltages for VDD1 and VDD2 ... Fix up trivial conflict in arch/arm/plat-omap/Kconfig
2011-01-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (255 commits) [media] radio-aimslab.c: Fix gcc 4.5+ bug [media] cx25821: Fix compilation breakage due to BKL dependency [media] v4l2-compat-ioctl32: fix compile warning [media] zoran: fix compiler warning [media] tda18218: fix compile warning [media] ngene: fix compile warning [media] DVB: IR support for TechnoTrend CT-3650 [media] cx23885, cimax2.c: Fix case of two CAM insertion irq [media] ir-nec-decoder: fix repeat key issue [media] staging: se401 depends on USB [media] staging: usbvideo/vicam depends on USB [media] soc_camera: Add the ability to bind regulators to soc_camedra devices [media] V4L2: Add a v4l2-subdev (soc-camera) driver for OmniVision OV2640 sensor [media] v4l: soc-camera: switch to .unlocked_ioctl [media] v4l: ov772x: simplify pointer dereference [media] ov9640: fix OmniVision OV9640 sensor driver's priv data retrieving [media] ov9640: use macro to request OmniVision OV9640 sensor private data [media] ivtv-i2c: Fix two warnings [media] staging/lirc: Update lirc TODO files [media] cx88: Remove the obsolete i2c_adapter.id field ...
2011-01-06Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (416 commits) ARM: DMA: add support for DMA debugging ARM: PL011: add DMA burst threshold support for ST variants ARM: PL011: Add support for transmit DMA ARM: PL011: Ensure IRQs are disabled in UART interrupt handler ARM: PL011: Separate hardware FIFO size from TTY FIFO size ARM: PL011: Allow better handling of vendor data ARM: PL011: Ensure error flags are clear at startup ARM: PL011: include revision number in boot-time port printk ARM: vexpress: add sched_clock() for Versatile Express ARM i.MX53: Make MX53 EVK bootable ARM i.MX53: Some bug fix about MX53 MSL code ARM: 6607/1: sa1100: Update platform device registration ARM: 6606/1: sa1100: Fix platform device registration ARM i.MX51: rename IPU irqs ARM i.MX51: Add ipu clock support ARM: imx/mx27_3ds: Add PMIC support ARM: DMA: Replace page_to_dma()/dma_to_page() with pfn_to_dma()/dma_to_pfn() mx51: fix usb clock support MX51: Add support for usb host 2 arch/arm/plat-mxc/ehci.c: fix errors/typos ...
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: (55 commits) video: udlfb: Kill off special printk wrappers, use pr_fmt(). video: udlfb: Kill off some magic constants for EDID sizing. video: udlfb: deifdefify (yes, that's a word). fbdev: modedb: Add a new mode for 864x480 TAAL panels. drivers/video/i810/i810-i2c.c: fix i2c bus handling video: Fix the HGA framebuffer driver drivers/video/carminefb.c: improve error handling video: imxfb: Fix the maximum value for yres fbdev: sh_mobile_lcdcfb: Enable 32 bpp and 24 bpp support fbdev: sh_mipi_dsi: use platform provided register layout and values ARM: mach-shmobile: specify sh7372 MIPI DSI register layout fbdev: sh_mipi_dsi: support different register layouts ARM: mach-shmobile: improve MIPI DSI clock configuration fbdev: sh-mobile: implement MIPI DSI runtime PM support sisfb: eliminate compiler warnings sisfb: delete unused register I/O macros sisfb: replace setSISIDXREG with SiS_SetRegANDOR sisfb: replace andSISIDXREG with SiS_SetRegAND sisfb: replace orSISIDXREG with SiS_SetRegOR sisfb: replace outSISIDXREG with SiS_SetReg ...
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits) cassini: Use local-mac-address prom property for Cassini MAC address net: remove the duplicate #ifdef __KERNEL__ net: bridge: check the length of skb after nf_bridge_maybe_copy_header() netconsole: clarify stopping message netconsole: don't announce stopping if nothing happened cnic: Fix the type field in SPQ messages netfilter: fix export secctx error handling netfilter: fix the race when initializing nf_ct_expect_hash_rnd ipv4: IP defragmentation must be ECN aware net: r6040: Return proper error for r6040_init_one dcb: use after free in dcb_flushapp() dcb: unlock on error in dcbnl_ieee_get() net: ixp4xx_eth: Return proper error for eth_init_one include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel net: add POLLPRI to sock_def_readable() af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks. net_sched: pfifo_head_drop problem mac80211: remove stray extern mac80211: implement off-channel TX using hw r-o-c offload mac80211: implement hardware offload for remain-on-channel ...
2011-01-06Merge branch 'x86-tsc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-tsc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Check tsc available/disabled in the delayed init function x86: Improve TSC calibration using a delayed workqueue x86: Make tsc=reliable override boot time stability checks
2011-01-06Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, earlyprintk: Move mrst early console to platform/ and fix a typo x86, apbt: Setup affinity for apb timers acting as per-cpu timer ce4100: Add errata fixes for UART on CE4100 x86: platform: Move iris to x86/platform where it belongs x86, mrst: Check platform_device_register() return code x86/platform: Add Eurobraille/Iris power off support x86, mrst: Add explanation for using 1960 as the year offset for vrtc x86, mrst: Fix dependencies of "select INTEL_SCU_IPC" x86, mrst: The shutdown for MRST requires the SCU IPC mechanism x86: Ce4100: Add reboot_fixup() for CE4100 ce4100: Add PCI register emulation for CE4100 x86: Add CE4100 platform support x86: mrst: Set vRTC's IRQ to level trigger type x86: mrst: Add audio driver bindings rtc: Add drivers/rtc/rtc-mrst.c x86: mrst: Add vrtc driver which serves as a wall clock device x86: mrst: Add Moorestown specific reboot/shutdown support x86: mrst: Parse SFI timer table for all timer configs x86/mrst: Add SFI platform device parsing code
2011-01-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) sched: Change wait_for_completion_*_timeout() to return a signed long sched, autogroup: Fix reference leak sched, autogroup: Fix potential access to freed memory sched: Remove redundant CONFIG_CGROUP_SCHED ifdef sched: Fix interactivity bug by charging unaccounted run-time on entity re-weight sched: Move periodic share updates to entity_tick() printk: Use this_cpu_{read|write} api on printk_pending sched: Make pushable_tasks CONFIG_SMP dependant sched: Add 'autogroup' scheduling feature: automated per session task groups sched: Fix unregister_fair_sched_group() sched: Remove unused argument dest_cpu to migrate_task() mutexes, sched: Introduce arch_mutex_cpu_relax() sched: Add some clock info to sched_debug cpu: Remove incorrect BUG_ON cpu: Remove unused variable sched: Fix UP build breakage sched: Make task dump print all 15 chars of proc comm sched: Update tg->shares after cpu.shares write sched: Allow update_cfs_load() to update global load sched: Implement demand based update_cfs_load() ...
2011-01-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (146 commits) tools, perf: Documentation for the power events API perf: Add calls to suspend trace point perf script: Make some lists static perf script: Use the default lost event handler perf session: Warn about errors when processing pipe events too perf tools: Fix perf_event.h header usage perf test: Clarify some error reports in the open syscall test x86, NMI: Add touch_nmi_watchdog to io_check_error delay x86: Avoid calling arch_trigger_all_cpu_backtrace() at the same time x86: Only call smp_processor_id in non-preempt cases perf timechart: Adjust perf timechart to the new power events perf: Clean up power events by introducing new, more generic ones perf: Do not export power_frequency, but power_start event perf test: Add test for counting open syscalls perf evsel: Auto allocate resources needed for some methods perf evsel: Use {cpu,thread}_map to shorten list of parameters perf tools: Refactor all_tids to hold nr and the map perf tools: Refactor cpumap to hold nr and the map perf evsel: Introduce per cpu and per thread open helpers perf evsel: Steal the counter reading routines from stat ...
2011-01-06Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: remove unused __list_for_each_rcu() macro rculist: fix borked __list_for_each_rcu() macro rcu: reduce __call_rcu()-induced contention on rcu_node structures rcu: limit rcu_node leaf-level fanout rcu: fine-tune grace-period begin/end checks rcu: Keep gpnum and completed fields synchronized rcu: Stop chasing QS if another CPU did it for us rcu: increase synchronize_sched_expedited() batching rcu: Make synchronize_srcu_expedited() fast if running readers rcu: fix race condition in synchronize_sched_expedited() rcu: update documentation/comments for Lai's adoption patch rcu,cleanup: simplify the code when cpu is dying rcu,cleanup: move synchronize_sched_expedited() out of sched.c rcu: get rid of obsolete "classic" names in TREE_RCU tracing rcu: Distinguish between boosting and boosted rcu: document TINY_RCU and TINY_PREEMPT_RCU tracing. rcu: add tracing for TINY_RCU and TINY_PREEMPT_RCU rcu: priority boosting for TINY_PREEMPT_RCU rcu: move TINY_RCU from softirq to kthread rcu: add priority-inversion testing to rcutorture
2011-01-06Documentation: update kernel-docs.txtNicolas Kaiser
Fixed typos, and removed duplicated entries. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Documentation/dontdiff: add further autogenerated files to ignore listMichael Prokop
Mainly resulting from (but not limited to) autogenerated files of lib/raid6 and drivers/gpu/drm/radeon. List generated as result of a diff of a clean 2.6.36 tree against a built one. Signed-off-by: Michael Prokop <mika@grml.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Merge branch 'master' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/video/sh_mobile_lcdcfb.c Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-06Merge branch 'fbdev/udlfb'Paul Mundt
2011-01-05tools, perf: Documentation for the power events APIJean Pihet
Provides documentation for the following: - the new power trace API, - the old (legacy) power trace API, - the DEPRECATED Kconfig option usage. Signed-off-by: Jean Pihet <j-pihet@ti.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: trenn@suse.de Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: linux-pm@lists.linux-foundation.org LKML-Reference: <1294253342-29056-3-git-send-email-j-pihet@ti.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-05Merge commit 'v2.6.37' into perf/coreIngo Molnar
Merge reason: Add the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-05Merge commit 'v2.6.37' into sched/coreIngo Molnar
Merge reason: Merge the final .37 tree. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-04remove trim_fs method from Documentation/filesystems/LockingChristoph Hellwig
The ->trim_fs has been removed meanwhile, so remove it from the documentation as well. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-04Merge commit 'v2.6.37-rc8' into perf/coreIngo Molnar
Merge reason: pick up latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-03watchdog: Improve initialisation error message and documentationBen Hutchings
The error message 'NMI watchdog failed to create perf event...' does not make it clear that this is a fatal error for the watchdog. It also currently prints the error value as a pointer, rather than extracting the error code with PTR_ERR(). Fix that. Add a note to the description of the 'nowatchdog' kernel parameter to associate it with this message. Reported-by: Cesare Leonardi <celeonar@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: 599368@bugs.debian.org Cc: 608138@bugs.debian.org Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: <stable@kernel.org> # .37.x and later LKML-Reference: <1294009362.3167.126.camel@localhost> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-30update Documentation/filesystems/LockingChristoph Hellwig
Mostly inspired by all the recent BKL removal changes, but a lot of older updates also weren't properly recorded. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-29[media] bt819: the ioctls in the header are internal to the kernelHans Verkuil
Remove bt819.h from ioctl-number.txt and make a note in the header that these ioctls are for internal use only. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] saa6588: rename rds.h to saa6588.hHans Verkuil
The naming of the media/rds.h header suggested that it was a generic RDS header, when in fact it is just a saa6588 module API that is internal to the kernel. Rename the header and the struct and defines in it to make this clear. Also removed the header include in radio-si470x.h (not used anymore) and from ioctl-number.txt (it's internal to the kernel and never called from userspace). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] cardlist: Update lists for em28xx and saa7134Mauro Carvalho Chehab
PS.: The cardlists are auto-generated via scripts. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] saa7134: Add support for Compro VideoMate Vista M1FRamiro Morales
Signed-off-by: Pavel Osnova <pvosnova@gmail.com> Signed-off-by: Ramiro Morales <ramiro@rmorales.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] feature_removal_schedule.txt: mark VIDIOC_*_OLD ioctls to dieMauro Carvalho Chehab
There are some old broken definitions of ioctl's, where the read/write arguments were marked wrong. The last one were added on 2.6.6 kernel. Remove them, in order to cleanup some copy_from_user/copy_to_user logic done inside V4L core. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Remove the old V4L1 v4lgrab.c fileMauro Carvalho Chehab
This example file uses the old V4L1 API. It also doesn't use libv4l. So, it is completely obsolete. A good example already exists at v4l-utils (v4l2grab.c): http://git.linuxtv.org/v4l-utils.git Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Fix videodev.h references at the V4L DocBookMauro Carvalho Chehab
2010-12-29[media] Documentation/ioctl/ioctl-number.txt: Remove some now freed ioctl rangesMauro Carvalho Chehab
The V4L1 removal patches removed a few ioctls. Update it at the docspace. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] V4L1 removal: Remove linux/videodev.hMauro Carvalho Chehab
There's no sense on keeping it on 2.6.38, as nobody is using it anymore, at the kernel tree, and installing it at the userspace API. As two deprecated drivers still need it, move it to their internal directories. Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] feature-removal: update V4L1 removal statusHans Verkuil
While the V4L1 compatibility module has been removed, we still have two V4L1 drivers that prevent full V4L1 removal. Those drivers have been moved to staging and will be removed in 2.6.39, together with the last V4L1 support. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
