commit 11930c530f3edf81160e4962e363d579f5cdce7e upstream.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit d6ec6b60a56a1e7d99da1fc69c031fa5ab54ba94 upstream.
change nvidia,slew_rate* to nvidia,slew-rate*
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
commit 1102dcab849313bd5a340b299b5cf61b518fbc0f upstream.
TjMax for the CE4100 series of Atom CPUs was previously reported to be
110 degrees C.
cpuinfo logs on the web show existing CPU types CE4110, CE4150, and CE4170,
reported as "model name : Intel(R) Atom(TM) CPU CE41{1|5|7}0 @ 1.{2|6}0GHz"
with model 28 (0x1c) and stepping 10 (0x0a). Add the three known variants
to the tjmax table.
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Add the SMBus Device IDs for the Intel Lynx Point-LP PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Power management
- PCI/PM: Enable D3/D3cold by default for most devices
- PCI/PM: Keep parent bridge active when probing device
- PCI/PM: Fix config reg access for D3cold and bridge suspending
- PCI/PM: Add ABI document for sysfs file d3cold_allowed
Core
- PCI: Don't print anything while decoding is disabled"
* tag '3.6-pci-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
Pull ARM SoC bug fixes from Olof Johansson:
"Mostly Renesas and Atmel bugfixes this time, targeting boot and build
problems. A couple of patches for gemini and kirkwood as well. On a
whole nothing very controversial."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: gemini: fix the gemini build
ARM: shmobile: armadillo800eva: enable rw rootfs mount
ARM: Kirkwood: Fix 'SZ_1M' undeclared here for db88f6281-bp-setup.c
ARM: shmobile: mackerel: fixup usb module order
ARM: shmobile: armadillo800eva: fixup: sound card detection order
ARM: shmobile: marzen: fixup smsc911x id for regulator
ARM: at91/feature-removal-schedule: delay at91_mci removal
ARM: mach-shmobile: armadillo800eva: Enable power button as wakeup source
ARM: mach-shmobile: armadillo800eva: Fix GPIO buttons descriptions
ARM: at91/dts: remove partial parameter in at91sam9g25ek.dts
ARM: at91/clock: fix PLLA overclock warning
ARM: at91: fix rtc-at91sam9 irq issue due to sparse irq support
ARM: at91: fix system timer irq issue due to sparse irq support
ARM: shmobile: sh73a0: fixup RELOC_BASE of intca_irq_pins_desc
Fix compiler warning by making the function static:
Documentation/watchdog/src/watchdog-test.c:34:6: warning: no previous prototype for 'term'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Fixes for AT91 related to:
- move to sparse IRQ: some drivers were forgotten
- a DTS typo
- the delay for removal of old at91_mci driver
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
Delay sd/mmc driver at91_mci.c removal because of tight schedule to
move platform data to new driver atmel-mci.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Pull arm-soc fixes from Arnd Bergmann:
"Bug fixes for various ARM platforms. About half of these are for OMAP
and submitted before but did not make it into v3.6-rc2."
* tag 'fixes-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits)
ARM: ux500: don't select LEDS_GPIO for snowball
ARM: imx: build i.MX6 functions only when needed
ARM: imx: select CPU_FREQ_TABLE when needed
ARM: imx: fix ksz9021rn_phy_fixup
ARM: imx: build pm-imx5 code only when PM is enabled
ARM: omap: allow building omap44xx without SMP
ARM: dts: imx51-babbage: fix esdhc cd/wp properties
ARM: imx6: spin the cpu until hardware takes it down
ARM: ux500: Ensure probing of Audio devices when Device Tree is enabled
ARM: ux500: Fix merge error, no matching driver name for 'snd_soc_u8500'
ARM i.MX6q: Add virtual 1/3.5 dividers in the LDB clock path
ARM: Kirkwood: fix Makefile.boot
ARM: Kirkwood: Fix iconnect leds
ARM: Orion: Set eth packet size csum offload limit
ARM: mv78xx0: fix win_cfg_base prototype
ARM: OMAP: dmtimers: Fix locking issue in omap_dm_timer_request*()
ARM: mmp: fix potential NULL dereference
ARM: OMAP4: Register the OPP table only for 4430 device
cpufreq: OMAP: Handle missing frequency table on SMP systems
ARM: OMAP4: sleep: Save the complete used register stack frame
Pull block-related fixes from Jens Axboe:
- Improvements to the buffered and direct write IO plugging from
Fengguang.
- Abstract out the mapping of a bio in a request, and use that to
provide a blk_bio_map_sg() helper. Useful for mapping just a bio
instead of a full request.
- Regression fix from Hugh, fixing up a patch that went into the
previous release cycle (and marked stable, too) attempting to prevent
a loop in __getblk_slow().
- Updates to discard requests, fixing up the sizing and how we align
them. Also a change to disallow merging of discard requests, since
that doesn't really work properly yet.
- A few drbd fixes.
- Documentation updates.
* 'for-linus' of git://git.kernel.dk/linux-block:
block: replace __getblk_slow misfix by grow_dev_page fix
drbd: Write all pages of the bitmap after an online resize
drbd: Finish requests that completed while IO was frozen
drbd: fix drbd wire compatibility for empty flushes
Documentation: update tunable options in block/cfq-iosched.txt
Documentation: update missing index files in block/00-INDEX
block: move down direct IO plugging
block: remove plugging at buffered write time
block: disable discard request merge temporarily
bio: Fix potential memory leak in bio_find_or_create_slab()
block: Don't use static to define "void *p" in show_partition_start()
block: Add blk_bio_map_sg() helper
block: Introduce __blk_segment_map_sg() helper
fs/block-dev.c:fix performance regression in O_DIRECT writes to md block devices
block: split discard into aligned requests
block: reorganize rounding of max_discard_sectors
The binding doc and dts use properties "fsl,{cd,wp}-internal" while
esdhc driver uses "fsl,{cd,wp}-controller". Fix binding doc and dts
to get them match driver code.
Reported-by: Chris Ball <cjb@laptop.org>
Cc: <stable@vger.kernel.org>
Acked-by: Chris Ball <cjb@laptop.org>
Merge fixes from Andrew Morton.
Random drivers and some VM fixes.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (17 commits)
mm: compaction: Abort async compaction if locks are contended or taking too long
mm: have order > 0 compaction start near a pageblock with free pages
rapidio/tsi721: fix unused variable compiler warning
rapidio/tsi721: fix inbound doorbell interrupt handling
drivers/rtc/rtc-rs5c348.c: fix hour decoding in 12-hour mode
mm: correct page->pfmemalloc to fix deactivate_slab regression
drivers/rtc/rtc-pcf2123.c: initialize dynamic sysfs attributes
mm/compaction.c: fix deferring compaction mistake
drivers/misc/sgi-xp/xpc_uv.c: SGI XPC fails to load when cpu 0 is out of IRQ resources
string: do not export memweight() to userspace
hugetlb: update hugetlbpage.txt
checkpatch: add control statement test to SINGLE_STATEMENT_DO_WHILE_MACRO
mm: hugetlbfs: correctly populate shared pmd
cciss: fix incorrect scsi status reporting
Documentation: update mount option in filesystem/vfat.txt
mm: change nr_ptes BUG_ON to WARN_ON
cs5535-clockevt: typo, it's MFGPT, not MFPGT
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"For bug fixes, at soc_camera, si470x, uvcvideo, iguanaworks IR driver,
radio_shark Kbuild fixes, and at the V4L2 core (radio fixes)."
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] media: soc_camera: don't clear pix->sizeimage in JPEG mode
[media] media: mx2_camera: Fix clock handling for i.MX27
[media] video: mx2_camera: Use clk_prepare_enable/clk_disable_unprepare
[media] video: mx1_camera: Use clk_prepare_enable/clk_disable_unprepare
[media] media: mx3_camera: buf_init() add buffer state check
[media] radio-shark2: Only compile led support when CONFIG_LED_CLASS is set
[media] radio-shark: Only compile led support when CONFIG_LED_CLASS is set
[media] radio-shark*: Call cancel_work_sync from disconnect rather then release
[media] radio-shark*: Remove work-around for dangling pointer in usb intfdata
[media] Add USB dependency for IguanaWorks USB IR Transceiver
[media] Add missing logging for rangelow/high of hwseek
[media] VIDIOC_ENUM_FREQ_BANDS fix
[media] mem2mem_testdev: fix querycap regression
[media] si470x: v4l2-compliance fixes
[media] DocBook: Remove a spurious character
[media] uvcvideo: Reset the bytesused field when recycling an erroneous buffer
Pull networking update from David Miller:
"A couple weeks of bug fixing in there. The largest chunk is all the
broken crap Amerigo Wang found in the netpoll layer."
1) netpoll and it's users has several serious bugs:
a) uses GFP_KERNEL with locks held
b) interfaces requiring interrupts disabled are called with them
enabled
c) and vice versa
d) VLAN tag demuxing, as per all other RX packet input paths, is not
applied
All from Amerigo Wang.
2) Hopefully cure the ipv4 mapped ipv6 address TCP early demux bugs for
good, from Neal Cardwell.
3) Unlike AF_UNIX, AF_PACKET sockets don't set a default credentials
when the user doesn't specify one explicitly during sendmsg().
Instead we attach an empty (zero) SCM credential block which is
definitely not what we want. Fix from Eric Dumazet.
4) IPv6 illegally invokes netdevice notifiers with RCU lock held, fix
from Ben Hutchings.
5) inet_csk_route_child_sock() checks wrong inet options pointer, fix
from Christoph Paasch.
6) When AF_PACKET is used for transmit, packet loopback doesn't behave
properly when a socket fanout is enabled, from Eric Leblond.
7) On bluetooth l2cap channel create failure, we leak the socket, from
Jaganath Kanakkassery.
8) Fix all the netprio file handling bugs found by Al Viro, from John
Fastabend.
9) Several error return and NULL deref bug fixes in networking drivers
from Julia Lawall.
10) A large smattering of struct padding et al. kernel memory leaks to
userspace found of Mathias Krause.
11) Conntrack expections in netfilter can access an uninitialized timer,
fix from Pablo Neira Ayuso.
12) Several netfilter SIP tracker bug fixes from Patrick McHardy.
13) IPSEC ipv6 routes are not initialized correctly all the time,
resulting in an OOPS in inet_putpeer(). Also from Patrick McHardy.
14) Bridging does rcu_dereference() outside of RCU protected area, from
Stephen Hemminger.
15) Fix routing cache removal performance regression when looking up
output routes that have a local destination. From Zheng Yan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits)
af_netlink: force credentials passing [CVE-2012-3520]
ipv4: fix ip header ident selection in __ip_make_skb()
ipv4: Use newinet->inet_opt in inet_csk_route_child_sock()
tcp: fix possible socket refcount problem
net: tcp: move sk_rx_dst_set call after tcp_create_openreq_child()
net/core/dev.c: fix kernel-doc warning
netconsole: remove a redundant netconsole_target_put()
net: ipv6: fix oops in inet_putpeer()
net/stmmac: fix issue of clk_get for Loongson1B.
caif: Do not dereference NULL in chnl_recv_cb()
af_packet: don't emit packet on orig fanout group
drivers/net/irda: fix error return code
drivers/net/wan/dscc4.c: fix error return code
drivers/net/wimax/i2400m/fw.c: fix error return code
smsc75xx: add missing entry to MAINTAINERS
net: qmi_wwan: new devices: UML290 and K5006-Z
net: sh_eth: Add eth support for R8A7779 device
netdev/phy: skip disabled mdio-mux nodes
dt: introduce for_each_available_child_of_node, of_get_next_available_child
net: netprio: fix cgrp create and write priomap race
Commit f0f57b2b1488 ("mm: move hugepage test examples to
tools/testing/selftests/vm") moved map_hugetlb.c, hugepage-shm.c and
hugepage-mmap.c tests into tools/testing/selftests/vm/ directory, but it
didn't update hugetlbpage.txt
Signed-off-by: Zhouping Liu <sanweidaying@gmail.com>
Acked-by: Dave Young <dyoung@redhat.com>
Update two mount options(discard, nfs) in vfat.txt.
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
This patch adds ABI document for the following sysfs file:
/sys/bus/pci/devices/.../d3cold_allowed
Signed-off-by: Huang Ying <ying.huang@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
- Fixed Nomadik errorpath
- Fixed documentation spelling errors
- Forward-declare struct device in a header file
- Remove some extraneous code lines when getting pinctrl states
- Correct the i.MX51 configure register number
- Fix the Nomadik keypad function group list
* tag 'pinctrl-fixes-v3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl/nomadik: add kp_b_2 keyboard function group list
pinctrl: imx51: fix .conf_reg of MX51_PAD_SD2_CMD__CSPI_MOSI
trivial: pinctrl core: remove extraneous code lines
pinctrl: header: trivial: declare struct device
Documentation/pinctrl.txt: Fix some misspelled macros
pinctrl/nomadik: fix null in irqdomain errorpath
Pull x86 platform driver update from Matthew Garrett:
"Some small updates for a few drivers, and some hardware enablement for
new Ideapads and the gmux hardware in the latest Macs.
This code won't run on older devices and has been well tested on new
ones, so low risk of regressions."
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86:
ideapad: add Lenovo IdeaPad Z570 support (part 3)
ideapad: add Lenovo IdeaPad Z570 support (part 2)
ideapad: add Lenovo IdeaPad Z570 support (part 1)
classmate-laptop: always call input_sync() after input_report_switch()
thinkpad-acpi: recognize latest V-Series using DMI_BIOS_VENDOR
dell-laptop: Fixed typo in touchpad LED quirk
vga_switcheroo: Don't require handler init callback
vga_switcheroo: Remove assumptions about registration/unregistration ordering
apple-gmux: Add display mux support
apple-gmux: Fix kconfig dependencies
asus-wmi: record wlan status while controlled by userapp
apple_gmux: Fix ACPI video unregister
apple_gmux: Add support for newer hardware
gmux: Add generic write32 function
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A bunch of fixes which are a combination of minor fixes that have been
shaken down due to greater testing exposure, the biggest block of
which are for the Palmas driver which hadn't had all the changes
required for mainline properly tested when it was merged."
* tag 'regulator-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: twl-regulator: fix up VINTANA1/VINTANA2
regulator: core: request only valid gpio pins for regulator enable
regulator: twl: Remove references to the twl4030 regulator
regulator: gpio-regulator: Split setting of voltages and currents
regulator: ab3100: add missing voltage table
regulator: anatop: Fix wrong mask used in anatop_get_voltage_sel
regulator: tps6586x: correct vin pin for sm0/sm1/sm2
regulator: palmas: Fix palmas_probe error handling
regulator: palmas: Call palmas_ldo_[read|write] in palmas_ldo_init
regulator: palmas: Fix regmap offsets for PALMAS_REG_SMPS10 vsel_reg
regulator: palmas: Fix calculating selector in palmas_map_voltage_ldo
The patch adds support for Lenovo IdeaPad Z570 laptop. It makes all special
keys working, adds possibility to control fan like Windows does, controls
Touchpad Disabled LED, toggles touchpad state via keyboard controller and
corrects touchpad behavior on resume from suspend. It is new, modified
version of patch. Now it does not depend on psmouse and does not need patching
of input subsystem.
Signed-off-by: Maxim Mikityanskiy <maxtram95@gmail.com>
This is the part 3 for fan control
Signed-off-by: Ike Panhc <ike.pan@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull Char / Misc driver fixes from Greg Kroah-Hartman:
"Here are some small misc and w1 driver fixes for 3.6-rc3. Nothing
major, just some some bugfixes and a new device id for a w1 driver.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'char-misc-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
1-Wire: Add support for the maxim ds1825 temperature sensor
ti-st: Fix check for pdata->chip_awake function pointer
mei: add mei_quirk_probe function
mei: fix device stall after wd is stopped
Signed-off-by: Daniel Mack <zonque@gmail.com>
This patch adds support for maxim ds1825 based 1-wire temperature sensors.
Signed-off-by: Raphael Assenat <raph@8d.com>
There are at least 4 implementations of netcat with the BSD-based
being the only one that has to be used without the -p switch to
specify the listening port.
Jan Engelhardt suggested to add an example for socat(1).
Signed-off-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de>
Signed-off-by: Cong Wang <amwang@redhat.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
The higher ptrace restriction levels should be blocking even
PTRACE_TRACEME requests. The comments in the LSM documentation are
misleading about when the checks happen (the parent does not go through
security_ptrace_access_check() on a PTRACE_TRACEME call).
Cc: stable@vger.kernel.org # 3.5.x and later
Signed-off-by: James Morris <james.l.morris@oracle.com>
Update tunable options in block/cfq-iosched.txt.
Update missing index files in block/00-INDEX.
As per datasheet, the vin pin for the regulator is named
as vin_sm0, vin_sm1, vin_sm2 for sm0, sm1 and sm2 respectively.
Correcting the names in driver and documentation to match with
datasheet.
Reported-by: Stephen Warren <swarren@nvidia.com>
The pdflush thread is long gone, however we still mention it incorrectly in the
kernel documentation. This patch fixes the situation.
Cc: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
The '->write_super' superblock method is gone, and this patch removes all the
references to 'write_super' from various pieces of the kernel documentation.
Pull arm-soc Marvell Orion device-tree updates from Olof Johansson:
"This contains a set of device-tree conversions for Marvell Orion
platforms that were staged early but took a few tries to get the
branch into a format where it was suitable for us to pick up.
Given that most people working on these platforms are hobbyists with
limited time, we were a bit more flexible with merging it even though
it came in late."
* tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits)
ARM: Kirkwood: Replace mrvl with marvell
ARM: Kirkwood: Describe GoFlex Net LEDs and SATA in DT.
ARM: Kirkwood: Describe Dreamplug LEDs in DT.
ARM: Kirkwood: Describe iConnects LEDs in DT.
ARM: Kirkwood: Describe iConnects temperature sensor in DT.
ARM: Kirkwood: Describe IB62x0 LEDs in DT.
ARM: Kirkwood: Describe IB62x0 gpio-keys in DT.
ARM: Kirkwood: Describe DNS32? gpio-keys in DT.
ARM: Kirkwood: Move common portions into a kirkwood-dnskw.dtsi
ARM: Kirkwood: Replace DNS-320/DNS-325 leds with dt bindings
ARM: Kirkwood: Describe DNS325 temperature sensor in DT.
ARM: Kirkwood: Use DT to configure SATA device.
ARM: kirkwood: use devicetree for SPI on dreamplug
ARM: kirkwood: Add LS-XHL and LS-CHLv2 support
ARM: Kirkwood: Initial DTS support for Kirkwood GoFlex Net
ARM: Kirkwood: Add basic device tree support for QNAP TS219.
ATA: sata_mv: Add device tree support
ARM: Orion: DTify the watchdog timer.
ARM: Orion: Add arch support needed for I2C via DT.
ARM: kirkwood: use devicetree for orion-spi
drivers/watchdog/orion_wdt.c
Pull ARM DMA engine updates from Russell King:
"This looks scary at first glance, but what it is is:
- a rework of the sa11x0 DMA engine driver merged during the previous
cycle, to extract a common set of helper functions for DMA engine
implementations.
- conversion of amba-pl08x.c to use these helper functions.
- addition of OMAP DMA engine driver (using these helper functions),
and conversion of some of the OMAP DMA users to use DMA engine.
Nothing in the helper functions is ARM specific, so I hope that other
implementations can consolidate some of their code by making use of
these helpers.
This has been sitting in linux-next most of the merge cycle, and has
been tested by several OMAP folk. I've tested it on sa11x0 platforms,
and given it my best shot on my broken platforms which have the
amba-pl08x controller.
The last point is the addition to feature-removal-schedule.txt, which
will have a merge conflict. Between myself and TI, we're planning to
remove the old TI DMA implementation next year."
Fix up trivial add/add conflicts in Documentation/feature-removal-schedule.txt
and drivers/dma/{Kconfig,Makefile}
* 'dmaengine' of git://git.linaro.org/people/rmk/linux-arm: (53 commits)
ARM: 7481/1: OMAP2+: omap2plus_defconfig: enable OMAP DMA engine
ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel request fails
Add feature removal of old OMAP private DMA implementation
mtd: omap2: remove private DMA API implementation
mtd: omap2: add DMA engine support
spi: omap2-mcspi: remove private DMA API implementation
spi: omap2-mcspi: add DMA engine support
ARM: omap: remove mmc platform data dma_mask and initialization
mmc: omap: remove private DMA API implementation
mmc: omap: add DMA engine support
mmc: omap_hsmmc: remove private DMA API implementation
mmc: omap_hsmmc: add DMA engine support
dmaengine: omap: add support for cyclic DMA
dmaengine: omap: add support for setting fi
dmaengine: omap: add support for returning residue in tx_state method
dmaengine: add OMAP DMA engine driver
dmaengine: sa11x0-dma: add cyclic DMA support
dmaengine: sa11x0-dma: fix DMA residue support
dmaengine: PL08x: ensure all descriptors are freed when channel is released
dmaengine: PL08x: get rid of write only pool_ctr and free_txd locking
Pull fbdev updates from Florian Tobias Schandinat:
- large updates for OMAP
- support for LCD3 overlay manager (omap5)
- omapdss output cleanup
- removal of passive matrix LCD support as there are no drivers for
such panels for DSS or DSS2 and nobody complained (cleanup)
- large updates for SH Mobile
- overlay support
- separating MERAM (cache) from framebuffer driver
- some updates for Exynos and da8xx-fb
- various other small patches
* tag 'fbdev-updates-for-3.6' of git://github.com/schandinat/linux-2.6: (78 commits)
da8xx-fb: fix compile issue due to missing include
fbdev: Make pixel_to_pat() failure mode more friendly
da8xx-fb: do not turn ON LCD backlight unless LCDC is enabled
fbdev: sh_mobile_lcdc: Fix vertical panning step
video: exynos mipi dsi: Fix mipi dsi regulators handling issue
video: da8xx-fb: do clock reset of revision 2 LCDC before enabling
arm: da850: configure LCDC fifo threshold
video: da8xx-fb: configure FIFO threshold to reduce underflow errors
video: da8xx-fb: fix flicker due to 1 frame delay in updated frame
video: da8xx-fb rev2: fix disabling of palette completion interrupt
da8xx-fb: add missing FB_BLANK operations
video: exynos_dp: use usleep_range instead of delay
video: exynos_dp: check the only INTERLANE_ALIGN_DONE bit during Link Training
fb: epson1355fb: Fix section mismatch
video: exynos_dp: fix wrong DPCD address during Link Training
video/smscufx: fix line counting in fb_write
aty128fb: Fix coding style issues
fbdev: sh_mobile_lcdc: Fix pan offset computation in YUV mode
fbdev: sh_mobile_lcdc: Fix overlay registers update during pan operation
fbdev: sh_mobile_lcdc: Support horizontal panning
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"A collection of small fixes that have been found recently. Most of
the commits are regression fixes in HD-audio and some other random
drivers."
* tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: snd-usb: fix clock source validity index
ALSA: hda - Fix mute-LED GPIO initialization for IDT codecs
ALSA: hda - Add descriptions for missing IDT 92HD83x models
ALSA: hda - Fix polarity of mute LED on HP Mini 210
ALSA: es1688 - freeup resources on init failure
ALSA: hda - Workaround for silent output on VAIO Z with ALC889
ALSA: hda - Fix WARNING from HDMI/DP parser
ALSA: hda - Detach from converter at closing in patch_hdmi.c
ALSA: hda - Fix mute-LED GPIO setup for HP Mini 210
ALSA: mpu401: Fix missing initialization of irq field
ALSA: hda - Fix invalid D3 of headphone DAC on VT202x codecs
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
Pull core block IO bits from Jens Axboe:
"The most complicated part if this is the request allocation rework by
Tejun, which has been queued up for a long time and has been in
for-next ditto as well.
There are a few commits from yesterday and today, mostly trivial and
obvious fixes. So I'm pretty confident that it is sound. It's also
smaller than usual."
* 'for-3.6/core' of git://git.kernel.dk/linux-block:
block: remove dead func declaration
block: add partition resize function to blkpg ioctl
block: uninitialized ioc->nr_tasks triggers WARN_ON
block: do not artificially constrain max_sectors for stacking drivers
blkcg: implement per-blkg request allocation
block: prepare for multiple request_lists
block: add q->nr_rqs[] and move q->rq.elvpriv to q->nr_rqs_elvpriv
blkcg: inline bio_blkcg() and friends
block: allocate io_context upfront
block: refactor get_request[_wait]()
block: drop custom queue draining used by scsi_transport_{iscsi|fc}
mempool: add @gfp_mask to mempool_create_node()
blkcg: make root blkcg allocation use %GFP_KERNEL
blkcg: __blkg_lookup_create() doesn't need radix preload
Pull md updates from NeilBrown.
* 'for-next' of git://neil.brown.name/md:
DM RAID: Add support for MD RAID10
md/RAID1: Add missing case for attempting to repair known bad blocks.
md/raid5: For odirect-write performance, do not set STRIPE_PREREAD_ACTIVE.
md/raid1: don't abort a resync on the first badblock.
md: remove duplicated test on ->openers when calling do_md_stop()
raid5: Add R5_ReadNoMerge flag which prevent bio from merging at block layer
md/raid1: prevent merging too large request
md/raid1: read balance chooses idlest disk for SSD
md/raid1: make sequential read detection per disk based
MD RAID10: Export md_raid10_congested
MD: Move macros from raid1*.h to raid1*.c
MD RAID1: rename mirror_info structure
MD RAID10: rename mirror_info structure
MD RAID10: Fix compiler warning.
raid5: add a per-stripe lock
raid5: remove unnecessary bitmap write optimization
raid5: lockless access raid5 overrided bi_phys_segments
raid5: reduce chance release_stripe() taking device_lock
In commit 3b6e2723f32d ("locks: prevent side-effects of
locks_release_private before file_lock is initialized") we removed the
last user of lm_release_private without removing the field itself.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Support the MD RAID10 personality through dm-raid.c
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Pull irqdomain changes from Grant Likely:
"Round of refactoring and enhancements to irq_domain infrastructure.
This series starts the process of simplifying irqdomain. The ultimate
goal is to merge LEGACY, LINEAR and TREE mappings into a single
system, but had to back off from that after some last minute bugs.
Instead it mainly reorganizes the code and ensures that the reverse
map gets populated when the irq is mapped instead of the first time it
is looked up.
Merging of the irq_domain types is deferred to v3.7
In other news, this series adds helpers for creating static mappings
on a linear or tree mapping."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6:
irqdomain: Improve diagnostics when a domain mapping fails
irqdomain: eliminate slow-path revmap lookups
irqdomain: Fix irq_create_direct_mapping() to test irq_domain type.
irqdomain: Eliminate dedicated radix lookup functions
irqdomain: Support for static IRQ mapping and association.
irqdomain: Always update revmap when setting up a virq
irqdomain: Split disassociating code into separate function
irq_domain: correct a minor wrong comment for linear revmap
irq_domain: Standardise legacy/linear domain selection
irqdomain: Make ops->map hook optional
irqdomain: Remove unnecessary test for IRQ_DOMAIN_MAP_LEGACY
irqdomain: Simple NUMA awareness.
devicetree: add helper inline for retrieving a node's full name
Merge Andrew's second set of patches:
- MM
- a few random fixes
- a couple of RTC leftovers
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits)
rtc/rtc-88pm80x: remove unneed devm_kfree
rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails
mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables
tmpfs: distribute interleave better across nodes
mm: remove redundant initialization
mm: warn if pg_data_t isn't initialized with zero
mips: zero out pg_data_t when it's allocated
memcg: gix memory accounting scalability in shrink_page_list
mm/sparse: remove index_init_lock
mm/sparse: more checks on mem_section number
mm/sparse: optimize sparse_index_alloc
memcg: add mem_cgroup_from_css() helper
memcg: further prevent OOM with too many dirty pages
memcg: prevent OOM with too many dirty pages
mm: mmu_notifier: fix freed page still mapped in secondary MMU
mm: memcg: only check anon swapin page charges for swap cache
mm: memcg: only check swap cache pages for repeated charging
mm: memcg: split swapin charge function into private and public part
mm: memcg: remove needless !mm fixup to init_mm when charging
mm: memcg: remove unneeded shmem charge type
Pull VFIO core from Alex Williamson:
"This series includes the VFIO userspace driver interface for the 3.6
kernel merge window. This driver is intended to provide a secure
interface for device access using IOMMU protection for applications
like assignment of physical devices to virtual machines.
Qemu will be the first user of this interface, enabling assignment of
PCI devices to Qemu guests. This interface is intended to eventually
replace the x86-specific assignment mechanism currently available in
KVM.
This interface has the advantage of being more secure, by working with
IOMMU groups to ensure device isolation and providing it's own
filtered resource access mechanism, and also more flexible, in not
being x86 or KVM specific (extensions to enable POWER are already
working).
This driver is originally the work of Tom Lyon, but has since been
handed over to me and gone through a complete overhaul thanks to the
input from David Gibson, Ben Herrenschmidt, Chris Wright, Joerg
Roedel, and others. This driver has been available in linux-next for
the last month."
Paul Mackerras says:
"I would be glad to see it go in since we want to use it with KVM on
PowerPC. If possible we'd like the PowerPC bits for it to go in as
well."
* tag 'vfio-for-v3.6' of git://github.com/awilliam/linux-vfio:
vfio: Add PCI device driver
vfio: Type1 IOMMU implementation
vfio: Add documentation
vfio: VFIO core
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random subsystem patches from Ted Ts'o:
"This patch series contains a major revamp of how we collect entropy
from interrupts for /dev/random and /dev/urandom.
The goal is to addresses weaknesses discussed in the paper "Mining
your Ps and Qs: Detection of Widespread Weak Keys in Network Devices",
by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman,
which will be published in the Proceedings of the 21st Usenix Security
Symposium, August 2012. (See https://factorable.net for more
information and an extended version of the paper.)"
Fix up trivial conflicts due to nearby changes in
drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c}
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits)
random: mix in architectural randomness in extract_buf()
dmi: Feed DMI table to /dev/random driver
random: Add comment to random_initialize()
random: final removal of IRQF_SAMPLE_RANDOM
um: remove IRQF_SAMPLE_RANDOM which is now a no-op
sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op
[ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op
board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op
isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op
pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op
omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op
goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out
uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op
drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op
xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op
n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op
pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op
i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op
input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op
mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op
Pull second set of media updates from Mauro Carvalho Chehab:
- radio API: add support to work with radio frequency bands
- new AM/FM radio drivers: radio-shark, radio-shark2
- new Remote Controller USB driver: iguanair
- conversion of several drivers to the v4l2 core control framework
- new board additions at existing drivers
- the remaining (and vast majority of the patches) are due to
drivers/DocBook fixes/cleanups.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits)
[media] radio-tea5777: use library for 64bits div
[media] tlg2300: Declare MODULE_FIRMWARE usage
[media] lgs8gxx: Declare MODULE_FIRMWARE usage
[media] xc5000: Add MODULE_FIRMWARE statements
[media] s2255drv: Add MODULE_FIRMWARE statement
[media] dib8000: move dereference after check for NULL
[media] Documentation: Update cardlists
[media] bttv: add support for Aposonic W-DVR
[media] cx25821: Remove bad strcpy to read-only char*
[media] pms.c: remove duplicated include
[media] smiapp-core.c: remove duplicated include
[media] via-camera: pass correct format settings to sensor
[media] rtl2832.c: minor cleanup
[media] Add support for the IguanaWorks USB IR Transceiver
[media] Minor cleanups for MCE USB
[media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry
[media] Use a named union in struct v4l2_ioctl_info
[media] mceusb: Add Twisted Melon USB IDs
[media] staging/media/solo6x10: use module_pci_driver macro
[media] staging/media/dt3155v4l: use module_pci_driver macro
Pull networking update from David S. Miller:
"I think Eric Dumazet and I have dealt with all of the known routing
cache removal fallout. Some other minor fixes all around.
1) Fix RCU of cached routes, particular of output routes which require
liberation via call_rcu() instead of call_rcu_bh(). From Eric
Dumazet.
2) Make sure we purge net device references in cached routes properly.
3) TG3 driver bug fixes from Michael Chan.
4) Fix reported 'expires' value in ipv6 routes, from Li Wei.
5) TUN driver ioctl leaks kernel bytes to userspace, from Mathias
Krause."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (22 commits)
ipv4: Properly purge netdev references on uncached routes.
ipv4: Cache routes in nexthop exception entries.
ipv4: percpu nh_rth_output cache
ipv4: Restore old dst_free() behavior.
bridge: make port attributes const
ipv4: remove rt_cache_rebuild_count
net: ipv4: fix RCU races on dst refcounts
net: TCP early demux cleanup
tun: Fix formatting.
net/tun: fix ioctl() based info leaks
tg3: Update version to 3.124
tg3: Fix race condition in tg3_get_stats64()
tg3: Add New 5719 Read DMA workaround
tg3: Fix Read DMA workaround for 5719 A0.
tg3: Request APE_LOCK_PHY before PHY access
ipv6: fix incorrect route 'expires' value passed to userspace
mISDN: Bugfix only few bytes are transfered on a connection
seeq: use PTR_RET at init_module of driver
bnx2x: remove cast around the kmalloc in bnx2x_prev_mark_path
ipv4: clean up put_child
