path: root/Documentation
2014-05-06hung_task: check the value of "sysctl_hung_task_timeout_sec"Liu Hua
commit 80df28476505ed4e6701c3448c63c9229a50c655 upstream. As sysctl_hung_task_timeout_sec is unsigned long, when this value is larger then LONG_MAX/HZ, the function schedule_timeout_interruptible in watchdog will return immediately without sleep and with print : schedule_timeout: wrong timeout value ffffffffffffff83 and then the funtion watchdog will call schedule_timeout_interruptible again and again. The screen will be filled with "schedule_timeout: wrong timeout value ffffffffffffff83" This patch does some check and correction in sysctl, to let the function schedule_timeout_interruptible allways get the valid parameter. Signed-off-by: Liu Hua <sdu.liu@huawei.com> Tested-by: Satoru Takeuchi <satoru.takeuchi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06media: media: gspca: sn9c20x: add ID for Genius Look 1320 V2Wolfram Sang
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06spi: efm32: use $vendor,$device scheme for compatible stringUwe Kleine-König
commit 12f6dd860cf8bf036c0bec38c00a53da71bcd43a upstream. Wolfram Sang pointed out that "efm32,$device" is non-standard. So use the common scheme and prefix device with "efm32-". The old compatible string is left in place until arch/arm/boot/dts/efm32* is fixed. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-24net: micrel : ks8851-ml: add vdd-supply supportNishanth Menon
Few platforms use external regulator to keep the ethernet MAC supplied. So, request and enable the regulator for driver functionality. Fixes: 66fda75f47dc (regulator: core: Replace direct ops->disable usage) Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Suggested-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20netlink: fix setsockopt in mmap examples in documentationstephen hemminger
The documentation for how to use netlink mmap interface is incorrect. The calls to setsockopt() require an additional argument. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "I know this is a bit more than you want to see, and I've told the wireless folks under no uncertain terms that they must severely scale back the extent of the fixes they are submitting this late in the game. Anyways: 1) vmxnet3's netpoll doesn't perform the equivalent of an ISR, which is the correct implementation, like it should. Instead it does something like a NAPI poll operation. This leads to crashes. From Neil Horman and Arnd Bergmann. 2) Segmentation of SKBs requires proper socket orphaning of the fragments, otherwise we might access stale state released by the release callbacks. This is a 5 patch fix, but the initial patches are giving variables and such significantly clearer names such that the actual fix itself at the end looks trivial. From Michael S. Tsirkin. 3) TCP control block release can deadlock if invoked from a timer on an already "owned" socket. Fix from Eric Dumazet. 4) In the bridge multicast code, we must validate that the destination address of general queries is the link local all-nodes multicast address. From Linus Lüssing. 5) The x86 BPF JIT support for negative offsets puts the parameter for the helper function call in the wrong register. Fix from Alexei Starovoitov. 6) The descriptor type used for RTL_GIGA_MAC_VER_17 chips in the r8169 driver is incorrect. Fix from Hayes Wang. 7) The xen-netback driver tests skb_shinfo(skb)->gso_type bits to see if a packet is a GSO frame, but that's not the correct test. It should use skb_is_gso(skb) instead. Fix from Wei Liu. 8) Negative msg->msg_namelen values should generate an error, from Matthew Leach. 9) at86rf230 can deadlock because it takes the same lock from it's ISR and it's hard_start_xmit method, without disabling interrupts in the latter. Fix from Alexander Aring. 10) The FEC driver's restart doesn't perform operations in the correct order, so promiscuous settings can get lost. Fix from Stefan Wahren. 11) Fix SKB leak in SCTP cookie handling, from Daniel Borkmann. 12) Reference count and memory leak fixes in TIPC from Ying Xue and Erik Hugne. 13) Forced eviction in inet_frag_evictor() must strictly make sure all frags are deleted, otherwise module unload (f.e. 6lowpan) can crash. Fix from Florian Westphal. 14) Remove assumptions in AF_UNIX's use of csum_partial() (which it uses as a hash function), which breaks on PowerPC. From Anton Blanchard. The main gist of the issue is that csum_partial() is defined only as a value that, once folded (f.e. via csum_fold()) produces a correct 16-bit checksum. It is legitimate, therefore, for csum_partial() to produce two different 32-bit values over the same data if their respective alignments are different. 15) Fix endiannes bug in MAC address handling of ibmveth driver, also from Anton Blanchard. 16) Error checks for ipv6 exthdrs offload registration are reversed, from Anton Nayshtut. 17) Externally triggered ipv6 addrconf routes should count against the garbage collection threshold. Fix from Sabrina Dubroca. 18) The PCI shutdown handler added to the bnx2 driver can wedge the chip if it was not brought up earlier already, which in particular causes the firmware to shut down the PHY. Fix from Michael Chan. 19) Adjust the sanity WARN_ON_ONCE() in qdisc_list_add() because as currently coded it can and does trigger in legitimate situations. From Eric Dumazet. 20) BNA driver fails to build on ARM because of a too large udelay() call, fix from Ben Hutchings. 21) Fair-Queue qdisc holds locks during GFP_KERNEL allocations, fix from Eric Dumazet. 22) The vlan passthrough ops added in the previous release causes a regression in source MAC address setting of outgoing headers in some circumstances. Fix from Peter Boström" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (70 commits) ipv6: Avoid unnecessary temporary addresses being generated eth: fec: Fix lost promiscuous mode after reconnecting cable bonding: set correct vlan id for alb xmit path at86rf230: fix lockdep splats net/mlx4_en: Deregister multicast vxlan steering rules when going down vmxnet3: fix building without CONFIG_PCI_MSI MAINTAINERS: add networking selftests to NETWORKING net: socket: error on a negative msg_namelen MAINTAINERS: Add tools/net to NETWORKING [GENERAL] packet: doc: Spelling s/than/that/ net/mlx4_core: Load the IB driver when the device supports IBoE net/mlx4_en: Handle vxlan steering rules for mac address changes net/mlx4_core: Fix wrong dump of the vxlan offloads device capability xen-netback: use skb_is_gso in xenvif_start_xmit r8169: fix the incorrect tx descriptor version tools/net/Makefile: Define PACKAGE to fix build problems x86: bpf_jit: support negative offsets bridge: multicast: enable snooping on general queries only bridge: multicast: add sanity check for general query destination tcp: tcp_release_cb() should release socket ownership ...
2014-03-12packet: doc: Spelling s/than/that/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Cc: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-09Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from from Olof Johansson: "A collection of fixes for ARM platforms. A little large due to us missing to do one last week, but there's nothing in particular here that is in itself large and scary. Mostly a handful of smaller fixes all over the place. The majority is made up of fixes for OMAP, but there are a few for others as well. In particular, there was a decision to rename a binding for the Broadcom pinctrl block that we need to go in before the final release since we then treat it as ABI" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: omap3-gta04: Add ti,omap36xx to compatible property to avoid problems with booting ARM: tegra: add LED options back into tegra_defconfig ARM: dts: omap3-igep: fix boot fail due wrong compatible match ARM: OMAP3: Fix pinctrl interrupts for core2 pinctrl: Rename Broadcom Capri pinctrl binding pinctrl: refer to updated dt binding string. Update dtsi with new pinctrl compatible string ARM: OMAP: Kill warning in CPUIDLE code with !CONFIG_SMP ARM: OMAP2+: Add support for thumb mode on DT booted N900 ARM: OMAP2+: clock: fix clkoutx2 with CLK_SET_RATE_PARENT ARM: OMAP4: hwmod: Fix SOFTRESET logic for OMAP4 ARM: DRA7: hwmod data: correct the sysc data for spinlock ARM: OMAP5: PRM: Fix reboot handling ARM: sunxi: dt: Change the touchscreen compatibles ARM: sun7i: dt: Fix interrupt trigger types
2014-03-07Merge tag 'dm-3.14-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: - dm-cache memory allocation failure fix - fix DM's Kconfig identation - dm-snapshot metadata corruption fix for bug introduced in 3.14-rc1 - important refcount < 0 fix for the DM persistent data library's space map metadata interface which fixes corruption reported by a few dm-thinp users and last but not least: - more extensive fixes than ideal for dm-thinp's data resize capability (which has had growing pain much like we've seen from -ENOSPC handling of filesystems that mature). The end result is dm-thinp now handles metadata operation failure and no data space error conditions much better than before. * tag 'dm-3.14-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm space map metadata: fix refcount decrement below 0 which caused corruption dm thin: fix Documentation for held metadata root feature dm thin: fix noflush suspend IO queueing dm thin: fix deadlock in __requeue_bio_list dm thin: fix out of data space handling dm thin: ensure user takes action to validate data and metadata consistency dm thin: synchronize the pool mode during suspend dm snapshot: fix metadata corruption dm: fix Kconfig indentation dm cache mq: fix memory allocation failure for large cache devices
2014-03-06net: Improve SO_TIMESTAMPING documentation and fix a minor code bugAndrew Lutomirski
The original documentation was very unclear. The code fix is presumably related to the formerly unclear documentation: SOCK_TIMESTAMPING_RX_SOFTWARE has no effect on __sock_recv_timestamp's behavior, so calling __sock_recv_ts_and_drops from sock_recv_ts_and_drops if only SOCK_TIMESTAMPING_RX_SOFTWARE is set is pointless. This should have no user-observable effect. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-06dm thin: fix Documentation for held metadata root featureMike Snitzer
The Documentation for the thin provisioning target's held metadata root feature was incorrect. It is now available and the value for the held metadata root is in block units (not 512b sectors). Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2014-03-05dm thin: ensure user takes action to validate data and metadata consistencyMike Snitzer
If a thin metadata operation fails the current transaction will abort, whereby causing potential for IO layers up the stack (e.g. filesystems) to have data loss. As such, set THIN_METADATA_NEEDS_CHECK_FLAG in the thin metadata's superblock which: 1) requires the user verify the thin metadata is consistent (e.g. use thin_check, etc) 2) suggests the user verify the thin data is consistent (e.g. use fsck) The only way to clear the superblock's THIN_METADATA_NEEDS_CHECK_FLAG is to run thin_repair. On metadata operation failure: abort current metadata transaction, set pool in read-only mode, and now set the needs_check flag. As part of this change, constraints are introduced or relaxed: * don't allow a pool to transition to write mode if needs_check is set * don't allow data or metadata space to be resized if needs_check is set * if a thin pool's metadata space is exhausted: the kernel will now force the user to take the pool offline for repair before the kernel will allow the metadata space to be extended. Also, update Documentation to include information about when the thin provisioning target commits metadata, how it handles metadata failures and running out of space. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Joe Thornber <ejt@redhat.com>
2014-03-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix memory leak in ieee80211_prep_connection(), sta_info leaked on error. From Eytan Lifshitz. 2) Unintentional switch case fallthrough in nft_reject_inet_eval(), from Patrick McHardy. 3) Must check if payload lenth is a power of 2 in nft_payload_select_ops(), from Nikolay Aleksandrov. 4) Fix mis-checksumming in xen-netfront driver, ip_hdr() is not in the correct place when we invoke skb_checksum_setup(). From Wei Liu. 5) TUN driver should not advertise HW vlan offload features in vlan_features. Fix from Fernando Luis Vazquez Cao. 6) IPV6_VTI needs to select NET_IPV_TUNNEL to avoid build errors, fix from Steffen Klassert. 7) Add missing locking in xfrm_migrade_state_find(), we must hold the per-namespace xfrm_state_lock while traversing the lists. Fix from Steffen Klassert. 8) Missing locking in ath9k driver, access to tid->sched must be done under ath_txq_lock(). Fix from Stanislaw Gruszka. 9) Fix two bugs in TCP fastopen. First respect the size argument given to tcp_sendmsg() in the fastopen path, and secondly prevent tcp_send_syn_data() from potentially using order-5 allocations. From Eric Dumazet. 10) Fix handling of default neigh garbage collection params, from Jiri Pirko. 11) Fix cwnd bloat and over-inflation of RTT when transmit segmentation is in use. From Eric Dumazet. 12) Missing initialization of Realtek r8169 driver's statistics seqlocks. Fix from Kyle McMartin. 13) Fix RTNL assertion failures in 802.3ad and AB ARP monitor of bonding driver, from Ding Tianhong. 14) Bonding slave release race can cause divide by zero, fix from Nikolay Aleksandrov. 15) Overzealous return from neigh_periodic_work() causes reachability time to not be computed. Fix from Duain Jiong. 16) Fix regression in ipv6_find_hdr(), it should not return -ENOENT when a specific target is specified and found. From Hans Schillstrom. 17) Fix VLAN tag stripping regression in BNA driver, from Ivan Vecera. 18) Tail loss probe can calculate bogus RTTs due to missing packet marking on retransmit. Fix from Yuchung Cheng. 19) We cannot do skb_dst_drop() in iptunnel_pull_header() because multicast loopback detection in later code paths need access to skb_rtable(). Fix from Xin Long. 20) The macvlan driver regresses in that it propagates lower device offload support disables into itself, causing severe slowdowns when running over a bridge. Provide the software offloads always on macvlan devices to deal with this and the regression is gone. From Vlad Yasevich. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits) macvlan: Add support for 'always_on' offload features net: sctp: fix sctp_sf_do_5_1D_ce to verify if we/peer is AUTH capable ip_tunnel:multicast process cause panic due to skb->_skb_refdst NULL pointer net: cpsw: fix cpdma rx descriptor leak on down interface be2net: isolate TX workarounds not applicable to Skyhawk-R be2net: Fix skb double free in be_xmit_wrokarounds() failure path be2net: clear promiscuous bits in adapter->flags while disabling promiscuous mode be2net: Fix to reset transparent vlan tagging qlcnic: dcb: a couple off by one bugs tcp: fix bogus RTT on special retransmission hsr: off by one sanity check in hsr_register_frame_in() can: remove CAN FD compatibility for CAN 2.0 sockets can: flexcan: factor out soft reset into seperate funtion can: flexcan: flexcan_remove(): add missing netif_napi_del() can: flexcan: fix transition from and to freeze mode in chip_{,un}freeze can: flexcan: factor out transceiver {en,dis}able into seperate functions can: flexcan: fix transition from and to low power mode in chip_{en,dis}able can: flexcan: flexcan_open(): fix error path if flexcan_chip_start() fails can: flexcan: fix shutdown: first disable chip, then all interrupts USB AX88179/178A: Support D-Link DUB-1312 ...
2014-03-03Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clk framework fixes from Mike Turquette: "Clock framework and driver fixes, all of which fix user-visible regressions. There is a single framework fix that prevents dereferencing a NULL pointer when calling clk_get. The range of fixes for clock driver regressions spans memory leak fixes, touching the wrong registers that cause things to explode, misconfigured clock rates that result in non-responsive devices and even some boot failures. The most benign fix is DT binding doc typo. It is a stable ABI exposed from the kernel that was introduced in -rc1, so best to fix it now" * tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux: (25 commits) clk:at91: Fix memory leak in of_at91_clk_master_setup() clk: nomadik: fix multiplatform problem clk: Correct handling of NULL clk in __clk_{get, put} clk: shmobile: Fix typo in MSTP clock DT bindings clk: shmobile: rcar-gen2: Fix qspi divisor clk: shmobile: rcar-gen2: Fix clock parent for all non-PLL clocks clk: tegra124: remove gr2d and gr3d clocks clk: tegra: Fix vic03 mux index clk: shmobile: rcar-gen2: Fix qspi divisor clk: shmobile: rcar-gen2: Fix clock parent all non-PLL clocks clk: tegra: use max divider if divider overflows clk: tegra: cclk_lp has a pllx/2 divider clk: tegra: fix sdmmc clks on Tegra1x4 clk: tegra: fix host1x clock on Tegra124 clk: tegra: PLLD2 fixes for hdmi clk: tegra: Fix PLLD mnp table clk: tegra: Fix PLLP rate table clk: tegra: Correct clock number for UARTE clk: tegra: Add missing Tegra20 fuse clks ARM: keystone: dts: fix clkvcp3 control register address ...
2014-03-03can: remove CAN FD compatibility for CAN 2.0 socketsOliver Hartkopp
In commit e2d265d3b587 (canfd: add support for CAN FD in CAN_RAW sockets) CAN FD frames with a payload length up to 8 byte are passed to legacy sockets where the CAN FD support was not enabled by the application. After some discussions with developers at a fair this well meant feature leads to confusion as no clean switch for CAN / CAN FD is provided to the application programmer. Additionally a compatibility like this for legacy CAN_RAW sockets requires some compatibility handling for the sending, e.g. make CAN2.0 frames a CAN FD frame with BRS at transmission time (?!?). This will become a mess when people start to develop applications with real CAN FD hardware. This patch reverts the bad compatibility code together with the documentation describing the removed feature. Acked-by: Stephane Grosjean <s.grosjean@peak-system.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-03-01Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dma fixes from Vinod Koul: "This request brings you two small fixes. First one for fixing dereference of freed descriptor and second for fixing sdma bindings for it to work for imx25. I was planning to send this about 10days ago but then I had to proceed on my paternity leave and didnt get chance to send this. Now got a bit of time from dady duties :)" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dma: sdma: Add imx25 compatible dma: ste_dma40: don't dereference free:d descriptor
2014-02-24pinctrl: Rename Broadcom Capri pinctrl bindingSherman Yin
The compatible string of the Broadcom Capri pinctrl driver is renamed to "brcm,bcm11351-pinctrl" to match the machine binding here: Documentation/devicetree/bindings/arm/bcm/bcm11351.txt Signed-off-by: Sherman Yin <syin@broadcom.com> Reviewed-by: Matt Porter <mporter@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Christian Daudt <bcm@fixthebug.org>
2014-02-24clk: shmobile: Fix typo in MSTP clock DT bindingsLaurent Pinchart
The DT bindings document a renesas,indices property, while the code, the DT example and the DT sources all use renesas,clock-indices. Fix the documentation. The shmobile mstp DT bindings have been merged in v3.14-rc1 with a bug in the DT ABI, a fix during the -rc series is appropriate. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Simon Horman <horms@verge.net.au>
2014-02-23Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A collection of fixes for ARM platforms. Most are fixes for DTS files, mostly from DT conversion on OMAP which is still finding a few issues here and there. There's a couple of small stale code removal patches that we usually queue for the next release instead, but they seemed harmless enough to bring in now. Also, a fix for backlight on some PXA platforms, and a cache configuration fix for Tegra, etc" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) MAINTAINERS: add additional ARM BCM281xx/BCM11xxx maintainer ARM: tegra: only run PL310 init on systems with one ARM: tegra: Add head numbers to display controllers ARM: imx6: build pm-imx6q.c independently of CONFIG_PM ARM: tegra: fix RTC0 alias for Cardhu ARM: dove: dt: revert PMU interrupt controller node Documentation: dt: OMAP: Update Overo/Tobi ARM: dts: Add support for both OMAP35xx and OMAP36xx Overo/Tobi ARM: dts: omap3-tobi: Use the correct vendor prefix ARM: dts: omap3-tobi: Fix boot with OMAP36xx-based Overo ARM: OMAP2+: Remove legacy macros for zoom platforms ARM: OMAP2+: Remove MACH_NOKIA_N800 ARM: dts: N900: add missing compatible property ARM: dts: N9/N950: fix boot hang with 3.14-rc1 ARM: OMAP1: nokia770: enable tahvo-usb ARM: OMAP2+: gpmc: fix: DT ONENAND child nodes not probed when MTD_ONENAND is built as module ARM: OMAP2+: gpmc: fix: DT NAND child nodes not probed when MTD_NAND is built as module ARM: dts: omap3-gta04: Fix mmc1 properties. ARM: dts: omap3-gta04: Fix 'aux' gpio key flags. ARM: OMAP2+: add missing ARCH_HAS_OPP ...
2014-02-23Merge tag 'tty-3.14-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull TTY revert from Greg KH: "Here is a single commit, a revert of a sysfs file change that ended up breaking a userspace tool" * tag 'tty-3.14-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: Revert "tty: Set correct tty name in 'active' sysfs attribute"
2014-02-22Revert "tty: Set correct tty name in 'active' sysfs attribute"Greg Kroah-Hartman
This reverts commit d8a5dc3033af2fd6d16030d2ee4fbd073460fe54. This breaks plymouth installs, either because plymouth is using the file "incorrectly" or because the patch is incorrect. Either way, this needs to be reverted until it is all figured out. Reported-by: Josh Boyer <jwboyer@fedoraproject.org> Reported-by: Ray Strode <halfline@gmail.com> Cc: Lennart Poettering <lennart@poettering.net> Cc: Kay Sievers <kay@vrfy.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Werner Fink <werner@suse.de> Cc: Hannes Reinecke <hare@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20Merge tag 'pci-v3.14-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "The most interesting thing here is the change to enable INTx (by clearing PCI_COMMAND_INTX_DISABLE) if the BIOS left INTx disabled. Apparently the Baytrail BIOS does this, which means EHCI doesn't work. Also, fix an AHCI MSI regression and other issues with the recent MSI changes. This also adds pci_enable_msi_exact() and pci_enable_msix_exact(), which aren't regression fixes, but will keep us from touching drivers twice (once to stop using the deprecated pci_enable_msi(), etc., and again to use the *_exact() variants). There's also a minor MVEBU fix. Summary: MSI: - Fix AHCI single-MSI fallback (Alexander Gordeev) - Fix populate_msi_sysfs() error paths (Greg Kroah-Hartman) - Fix htmldocs problem (Masanari Iida) - Add pci_enable_msi_exact() and pci_enable_msix_exact() (Alexander Gordeev) - Update documentation (Alexander Gordeev) Miscellaneous: - mvebu: expose device ID & revision via lspci (Andrew Lunn) - Enable INTx if the BIOS left them disabled (Bjorn Helgaas)" * tag 'pci-v3.14-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: ahci: Fix broken fallback to single MSI mode PCI: Enable INTx if BIOS left them disabled PCI/MSI: Add pci_enable_msi_exact() and pci_enable_msix_exact() PCI/MSI: Fix cut-and-paste errors in documentation PCI/MSI: Add pci_enable_msi() documentation back PCI/MSI: Fix pci_msix_vec_count() htmldocs failure PCI/MSI: Fix leak of msi_attrs PCI/MSI: Check kmalloc() return value, fix leak of name PCI: mvebu: Use Device ID and revision from underlying endpoint
2014-02-19net: ethoc: document OF bindingsMax Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-18Merge tag 'omap-for-v3.14/fixes-against-rc1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Fixes for omaps, mostly to deal with the 34xx vs 36xx SoC configuration for overo boards. * tag 'omap-for-v3.14/fixes-against-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: Documentation: dt: OMAP: Update Overo/Tobi ARM: dts: Add support for both OMAP35xx and OMAP36xx Overo/Tobi ARM: dts: omap3-tobi: Use the correct vendor prefix ARM: dts: omap3-tobi: Fix boot with OMAP36xx-based Overo ARM: OMAP2+: Remove legacy macros for zoom platforms ARM: OMAP2+: Remove MACH_NOKIA_N800 ARM: dts: N900: add missing compatible property ARM: dts: N9/N950: fix boot hang with 3.14-rc1 ARM: OMAP1: nokia770: enable tahvo-usb ARM: OMAP2+: gpmc: fix: DT ONENAND child nodes not probed when MTD_ONENAND is built as module ARM: OMAP2+: gpmc: fix: DT NAND child nodes not probed when MTD_NAND is built as module ARM: dts: omap3-gta04: Fix mmc1 properties. ARM: dts: omap3-gta04: Fix 'aux' gpio key flags. ARM: OMAP2+: add missing ARCH_HAS_OPP ARM: dts: am335x-evmsk: Fix mmc1 support ARM: DTS: am335x-evmsk: Correct audio clock frequency ARM: dts: omap3-gta04: Add EOC irq gpio line handling. Signed-off-by: Olof Johansson <olof@lixom.net>
2014-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) kvaser CAN driver has fixed limits of some of it's table, validate that we won't exceed those limits at probe time. Fix from Olivier Sobrie. 2) Fix rtl8192ce disabling interrupts for too long, from Olivier Langlois. 3) Fix botched shift in ath5k driver, from Dan Carpenter. 4) Fix corruption of deferred packets in TIPC, from Erik Hugne. 5) Fix newlink error path in macvlan driver, from Cong Wang. 6) Fix netpoll deadlock in bonding, from Ding Tianhong. 7) Handle GSO packets properly in forwarding path when fragmentation is necessary on egress, from Florian Westphal. 8) Fix axienet build errors, from Michal Simek. 9) Fix refcounting of ubufs on tx in vhost net driver, from Michael S Tsirkin. 10) Carrier status isn't set properly in hyperv driver, from Haiyang Zhang. 11) Missing pci_disable_device() in tulip_remove_one), from Ingo Molnar. 12) AF_PACKET qdisc bypass mode doesn't adhere to driver provided TX queue selection method. Add a fallback method mechanism to fix this bug, from Daniel Borkmann. 13) Fix regression in link local route handling on GRE tunnels, from Nicolas Dichtel. 14) Bonding can assign dup aggregator IDs in some sequences of configuration, fix by making the allocation counter per-bond instead of global. From Jiri Bohac. 15) sctp_connectx() needs compat translations, from Daniel Borkmann. 16) Fix of_mdio PHY interrupt parsing, from Ben Dooks * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits) MAINTAINERS: add entry for the PHY library of_mdio: fix phy interrupt passing net: ethernet: update dependency and help text of mvneta NET: fec: only enable napi if we are successful af_packet: remove a stray tab in packet_set_ring() net: sctp: fix sctp_connectx abi for ia32 emulation/compat mode ipv4: fix counter in_slow_tot irtty-sir.c: Do not set_termios() on irtty_close() bonding: 802.3ad: make aggregator_identifier bond-private usbnet: remove generic hard_header_len check gre: add link local route when local addr is any batman-adv: fix potential kernel paging error for unicast transmissions batman-adv: avoid double free when orig_node initialization fails batman-adv: free skb on TVLV parsing success batman-adv: fix TT CRC computation by ensuring byte order batman-adv: fix potential orig_node reference leak batman-adv: avoid potential race condition when adding a new neighbour batman-adv: properly check pskb_may_pull return value batman-adv: release vlan object after checking the CRC batman-adv: fix TT-TVLV parsing on OGM reception ...
2014-02-18dma: sdma: Add imx25 compatibleMarkus Pargmann
imx25 did not work without a firmware previously. This patch adds a DT compatible to pass the correct data with the default script addresses for imx25. Add imx25 compatible to the list of compatibles in the binding documentation. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-02-15Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "i2c has a bugfix and documentation improvements for you" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: Documentation: i2c: mention ACPI method for instantiating devices Documentation: i2c: describe devicetree method for instantiating devices i2c: mv64xxx: refactor message start to ensure proper initialization
2014-02-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: "A collection of ARM SoC fixes for v3.14-rc1. Mostly a collection of Kconfig, device tree data and compilation fixes along with fix to drivers/phy that fixes a boot regression on some Marvell mvebu platforms" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: dma: mv_xor: Silence a bunch of LPAE-related warnings ARM: ux500: disable msp2 device tree node ARM: zynq: Reserve not DMAable space in front of the kernel ARM: multi_v7_defconfig: Select CONFIG_SOC_DRA7XX ARM: imx6: Initialize low-power mode early again ARM: pxa: fix various compilation problems ARM: pxa: fix compilation problem on AM300EPD board ARM: at91: add Atmel's SAMA5D3 Xplained board spi/atmel: document clock properties mmc: atmel-mci: document clock properties ARM: at91: enable USB host on at91sam9n12ek board ARM: at91/dt: fix sama5d3 ohci hclk clock reference ARM: at91/dt: sam9263: fix compatibility string for the I2C ata: sata_mv: Fix probe failures with optional phys drivers: phy: Add support for optional phys drivers: phy: Make NULL a valid phy reference ARM: fix HAVE_ARM_TWD selection for OMAP and shmobile ARM: moxart: move DMA_OF selection to driver ARM: hisi: fix kconfig warning on HAVE_ARM_TWD
2014-02-15Documentation: i2c: mention ACPI method for instantiating devicesWolfram Sang
Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Guenter Roeck <linux@roeck-us.net>
2014-02-15Documentation: i2c: describe devicetree method for instantiating devicesWolfram Sang
2014-02-14Merge tag 'tty-3.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver fixes from Greg KH: "Here are a small number of tty/serial driver fixes to resolve reported issues with 3.14-rc and earlier (in the case of the vt bugfix). Some of these have been tested and reported by a number of people as the tty bugfix was pretty commonly hit on some platforms. All have been in linux-next for a while" * tag 'tty-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: vt: Fix secure clear screen serial: 8250: Support XR17V35x fraction divisor n_tty: Fix stale echo output serial: sirf: fix kernel panic caused by unpaired spinlock serial: 8250_pci: unbreak last serial ports on NetMos 9865 cards n_tty: Fix poll() when TIME_CHAR and MIN_CHAR == 0 serial: omap: fix rs485 probe on defered pinctrl serial: 8250_dw: fix compilation warning when !CONFIG_PM_SLEEP serial: omap-serial: Move info message to probe function tty: Set correct tty name in 'active' sysfs attribute tty: n_gsm: Fix for modems with brk in modem status control drivers/tty/hvc: don't use module_init in non-modular hyp. console code
2014-02-14Merge tag 'char-misc-3.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc fixes from Greg KH: "Here are some small char/misc driver fixes, along with some documentation updates, for 3.14-rc3. Nothing major, just a number of fixes for reported issues" * tag 'char-misc-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Revert "misc: eeprom: sunxi: Add new compatibles" Revert "ARM: sunxi: dt: Convert to the new SID compatibles" misc: mic: fix possible signed underflow (undefined behavior) in userspace API ARM: sunxi: dt: Convert to the new SID compatibles misc: eeprom: sunxi: Add new compatibles misc: genwqe: Fix potential memory leak when pinning memory Documentation:Update Documentation/zh_CN/arm64/memory.txt Documentation:Update Documentation/zh_CN/arm64/booting.txt Documentation:Chinese translation of Documentation/arm64/tagged-pointers.txt raw: set range for MAX_RAW_DEVS raw: test against runtime value of max_raw_minors Drivers: hv: vmbus: Don't timeout during the initial connection with host Drivers: hv: vmbus: Specify the target CPU that should receive notification VME: Correct read/write alignment algorithm mei: don't unset read cb ptr on reset mei: clear write cb from waiting list on reset
2014-02-14Revert "misc: eeprom: sunxi: Add new compatibles"Greg Kroah-Hartman
This reverts commit f0de8e04a7201a2000f3c6d09732c11e7f35d42d, it is incorrect, a future patch will fix this up properly. Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-14Merge tag 'for-v3.14-fixes' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery fixes from Dmitry Eremin-Solenikov: - Fix NULL pointer dereference in max17040 driver - Add bq2415x dts bindings documentation - Fix misleading comment in ds2782 driver - Remove useless check in isp1704 charger driver. * tag 'for-v3.14-fixes' of git://git.infradead.org/battery-2.6: power: max17040: Fix NULL pointer dereference when there is no platform_data dt: binding documentation for bq2415x charger isp1704_charger: remove useless check in isp1704_charger_probe() power: ds2782_battery: Typo in comment
2014-02-14Documentation: dt: OMAP: Update Overo/TobiFlorian Vaussard
Update the compatible string for Overo/Tobi to reflect the latest changes. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-02-13Documentation/networking: delete orphaned 3c505.txt file.Paul Gortmaker
In the commit 0e245dbaac9fa1c2fd0f4e2af7b9f6d874083a8b ("drivers/net: delete the 3Com 3c505/3c507 intel i825xx support") we clobbered the 3c505 driver (over a year ago) along with other abandoned ISA drivers. However, this orphaned README file escaped detection at that time, and has lived on until today. Get rid of it now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-13net: stmmac:sti: Add STi SOC glue driver.Srinivas Kandagatla
STi series SOCs have a glue layer on top of the synopsis gmac IP, this glue layer needs to be configured before the gmac driver starts using the IP. This patch adds a support to this glue layer which is configured via stmmac setup, init, exit callbacks. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-13PCI/MSI: Add pci_enable_msi_exact() and pci_enable_msix_exact()Alexander Gordeev
The new functions are special cases for pci_enable_msi_range() and pci_enable_msix_range() when a particular number of MSI or MSI-X is needed. By contrast with pci_enable_msi_range() and pci_enable_msix_range() functions, pci_enable_msi_exact() and pci_enable_msix_exact() return zero in case of success, which indicates MSI or MSI-X interrupts have been successfully allocated. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-13PCI/MSI: Fix cut-and-paste errors in documentationAlexander Gordeev
Function pci_enable_msi_range() is used in examples where pci_enable_msix_range() should have been used instead. Reported-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-13PCI/MSI: Add pci_enable_msi() documentation backAlexander Gordeev
We deprecated pci_enable_msi() in 302a2523c277 ("PCI/MSI: Add pci_enable_msi_range() and pci_enable_msix_range()"). But we changed our minds after noticing that: - pci_enable_msi() doesn't have confusing return values like pci_enable_msi_block() and pci_enable_msix() did, and - pci_enable_msi() has a hundred or so callers that we don't want to change. This adds back the pci_enable_msi() documentation. [bhelgaas: changelog] Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-12Merge tag 'spi-v3.14-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi fixes from Mark Brown: "A few driver and documentation fixes, plus a fix for double error handling which had crept in due to the confusing documentation - it wasn't clear if the core or the driver was responsible for cleanup in error cases so both tried to do it with unfortunate results" * tag 'spi-v3.14-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: spi: nuc900: Set SPI_LSB_FIRST for master->mode_bits if hw->pdata->lsb is true spi: rspi: Document support for Renesas QSPI in Kconfig spi: Fix crash with double message finalisation on error handling spi: correct the transfer_one_message documentation wording spi: document the transfer_one spi_master callback spi: spi.h: clarify the documentation of transfer_one
2014-02-11Merge tag 'dt-fixes-for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: - Fix compile error drivers/spi/spi-rspi.c with !CONFIG_OF - Fix warnings for unused/uninitialized variables with !CONFIG_OF - Fix PCIe bus matching for powerpc - Add documentation for various vendor strings * tag 'dt-fixes-for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: DT: Add vendor prefix for Spansion Inc. of/device: Nullify match table in of_match_device() for CONFIG_OF=n dt-bindings: add vendor-prefix for neonode of: fix PCI bus match for PCIe slots of: restructure for_each macros to fix compile warnings of: add vendor prefix for Honeywell of: Update qcom vendor prefix description of: add vendor prefix for Allwinner Technology
2014-02-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix flexcan build on big endian, from Arnd Bergmann 2) Correctly attach cpsw to GPIO bitbang MDIO drive, from Stefan Roese 3) udp_add_offload has to use GFP_ATOMIC since it can be invoked from non-sleepable contexts. From Or Gerlitz 4) vxlan_gro_receive() does not iterate over all possible flows properly, fix also from Or Gerlitz 5) CAN core doesn't use a proper SKB destructor when it hooks up sockets to SKBs. Fix from Oliver Hartkopp 6) ip_tunnel_xmit() can use an uninitialized route pointer, fix from Eric Dumazet 7) Fix address family assignment in IPVS, from Michal Kubecek 8) Fix ath9k build on ARM, from Sujith Manoharan 9) Make sure fail_over_mac only applies for the correct bonding modes, from Ding Tianhong 10) The udp offload code doesn't use RCU correctly, from Shlomo Pongratz 11) Handle gigabit features properly in generic PHY code, from Florian Fainelli 12) Don't blindly invoke link operations in rtnl_link_get_slave_info_data_size, they are optional. Fix from Fernando Luis Vazquez Cao 13) Add USB IDs for Netgear Aircard 340U, from Bjørn Mork 14) Handle netlink packet padding properly in openvswitch, from Thomas Graf 15) Fix oops when deleting chains in nf_tables, from Patrick McHardy 16) Fix RX stalls in xen-netback driver, from Zoltan Kiss 17) Fix deadlock in mac80211 stack, from Emmanuel Grumbach 18) inet_nlmsg_size() forgets to consider ifa_cacheinfo, fix from Geert Uytterhoeven 19) tg3_change_mtu() can deadlock, fix from Nithin Sujir 20) Fix regression in setting SCTP local source addresses on accepted sockets, caused by some generic ipv6 socket changes. Fix from Matija Glavinic Pecotic 21) IPPROTO_* must be pure defines, otherwise module aliases don't get constructed properly. Fix from Jan Moskyto 22) IPV6 netconsole setup doesn't work properly unless an explicit source address is specified, fix from Sabrina Dubroca 23) Use __GFP_NORETRY for high order skb page allocations in sock_alloc_send_pskb and skb_page_frag_refill. From Eric Dumazet 24) Fix a regression added in netconsole over bridging, from Cong Wang 25) TCP uses an artificial offset of 1ms for SRTT, but this doesn't jive well with TCP pacing which needs the SRTT to be accurate. Fix from Eric Dumazet 26) Several cases of missing header file includes from Rashika Kheria 27) Add ZTE MF667 device ID to qmi_wwan driver, from Raymond Wanyoike 28) TCP Small Queues doesn't handle nonagle properly in some corner cases, fix from Eric Dumazet 29) Remove extraneous read_unlock in bond_enslave, whoops. From Ding Tianhong 30) Fix 9p trans_virtio handling of vmalloc buffers, from Richard Yao * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (136 commits) 6lowpan: fix lockdep splats alx: add missing stats_lock spinlock init 9p/trans_virtio.c: Fix broken zero-copy on vmalloc() buffers bonding: remove unwanted bond lock for enslave processing USB2NET : SR9800 : One chip USB2.0 USB2NET SR9800 Device Driver Support tcp: tsq: fix nonagle handling bridge: Prevent possible race condition in br_fdb_change_mac_address bridge: Properly check if local fdb entry can be deleted when deleting vlan bridge: Properly check if local fdb entry can be deleted in br_fdb_delete_by_port bridge: Properly check if local fdb entry can be deleted in br_fdb_change_mac_address bridge: Fix the way to check if a local fdb entry can be deleted bridge: Change local fdb entries whenever mac address of bridge device changes bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_address bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddr bridge: Fix the way to find old local fdb entries in br_fdb_changeaddr tcp: correct code comment stating 3 min timeout for FIN_WAIT2, we only do 1 min net: vxge: Remove unused device pointer net: qmi_wwan: add ZTE MF667 3c59x: Remove unused pointer in vortex_eisa_cleanup() net: fix 'ip rule' iif/oif device rename ...
2014-02-11Merge remote-tracking branches 'spi/fix/doc', 'spi/fix/nuc900' and ↵Mark Brown
'spi/fix/rspi' into spi-linus
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesKevin Hilman
From Nicolas Ferre: First series of AT91 fixes for 3.14. All of them are DT-related. - fixes for typos in i2c and ohci clocks - addition of a USB host node for at91sam9n12ek - 2 DT documentation updates that have been sent a long time ago - a new board based on the sama5d36 SoC * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91: add Atmel's SAMA5D3 Xplained board spi/atmel: document clock properties mmc: atmel-mci: document clock properties ARM: at91: enable USB host on at91sam9n12ek board ARM: at91/dt: fix sama5d3 ohci hclk clock reference ARM: at91/dt: sam9263: fix compatibility string for the I2C Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-02-07misc: eeprom: sunxi: Add new compatiblesMaxime Ripard
The Allwinner A10 compatibles were following a slightly different compatible patterns than the rest of the SoCs for historical reasons. Add compatibles matching the other pattern to the SID driver for consistency, and keep the older one for backward compatibility. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Documentation:Update Documentation/zh_CN/arm64/memory.txtFu Wei
This is a update of Chinese documentation:Documentation/zh_CN/arm64/memory.txt It is based on the modifications of Documentation/arm64/memory.txt in submission: "2475ff9d", "847264fb", "aa4a73a0", "e29a074b". Update maintainer's Email address. Signed-off-by: Fu Wei <wefu@redhat.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Documentation:Update Documentation/zh_CN/arm64/booting.txtFu Wei
This is a update of Chinese documentation: Documentation/zh_CN/arm64/booting.txt It is based on the modifications of Documentation/arm64/booting.txt in submission: "4d5e0b15", "4370eec0", "4fcd6e14". Update maintainer's Email address. Signed-off-by: Fu Wei <wefu@redhat.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Documentation:Chinese translation of Documentation/arm64/tagged-pointers.txtFu Wei
This is a Chinese translated version of Documentation/arm64/tagged-pointers.txt It is based on the modifications of Documentation/arm64/tagged-pointers.txt in submission: "d50240a5", "374ed9d1". Signed-off-by: Fu Wei <wefu@redhat.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
