There are some situations (e.g. in __pm_generic_call()), where
pm_runtime_suspended() is used to decide whether or not to execute
a device's (system) ->suspend() callback. The callback is not
executed if pm_runtime_suspended() returns true, but it does so
for devices that don't even support runtime PM, because the
power.disable_depth device field is ignored by it. This leads to
problems (i.e. devices are not suspened when they should), so rework
pm_runtime_suspended() so that it returns false if the device's
power.disable_depth field is different from zero.
Cc: stable@kernel.org
This patch contains changes to /drivers files
Contains all checkpatch and copyright fixes.
Acked-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
This bases on work done earlier by Lennert Buytenhek and Mark A. Greer.
Compared to their approach zreladdr isn't guessed based on the pc
register but the bootloader is expected to pass PHYS_OFFSET in r3. If
that value doesn't look right (e.g. isn't aligned) it is guessed based
on the value of sp. This should work for CONFIG_ZBOOT_ROM, too.
To use it for your machine removing the definition of PHYS_OFFSET from
<mach/memory.h> and selecting CONFIG_RUNTIME_PHYS_OFFSET should be
enough.
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Steve Chen <schen@mvista.com>
Cc: Mark A. Greer <mgreer@mvista.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Fix __task_cred()'s lockdep check by removing the following validation
condition:
lockdep_tasklist_lock_is_held()
as commit_creds() does not take the tasklist_lock, and nor do most of the
functions that call it, so this check is pointless and it can prevent
detection of the RCU lock not being held if the tasklist_lock is held.
Instead, add the following validation condition:
task->exit_state >= 0
to permit the access if the target task is dead and therefore unable to change
its own credentials.
Fix __task_cred()'s comment to:
(1) discard the bit that says that the caller must prevent the target task
from being deleted. That shouldn't need saying.
(2) Add a comment indicating the result of __task_cred() should not be passed
directly to get_cred(), but rather than get_task_cred() should be used
instead.
Also put a note into the documentation to enforce this point there too.
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Commit 2a6b69765ad794389f2fc3e14a0afa1a995221c2
(ACPI: Store NVS state even when entering suspend to RAM) caused the
ACPI suspend code save the NVS area during suspend and restore it
during resume unconditionally, although it is known that some systems
need to use acpi_sleep=s4_nonvs for hibernation to work. To allow
the affected systems to avoid saving and restoring the NVS area
during suspend to RAM and resume, introduce kernel command line
option acpi_sleep=nonvs and make acpi_sleep=s4_nonvs work as its
alias temporarily (add acpi_sleep=s4_nonvs to the feature removal
file).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16396 .
Reported-and-tested-by: tomas m <tmezzadra@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Having both IO-mapping.txt and io-mapping.txt in Documentation/
was confusing and/or bothersome to some people, so rename
IO-mapping.txt to bus-virt-phys-mapping.txt. Also update
Documentation/00-INDEX for both of these files.
Cc: Kees Bakker <kees.bakker@xs4all.nl>
Cc: Keith Packard <keithp@keithp.com>
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Add an entry for imx2_wdt in watchdog-parameters.txt
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Commit c7f486567c1d0acd2e4166c47069835b9f75e77b
(PCI PM: PCIe PME root port service driver) causes the native PCIe
PME signaling to be used by default, if the BIOS allows the kernel to
control the standard configuration registers of PCIe root ports.
However, the native PCIe PME is coupled to the native PCIe hotplug
and calling pcie_pme_acpi_setup() makes some BIOSes expect that
the native PCIe hotplug will be used as well. That, in turn, causes
problems to appear on systems where the PCIe hotplug driver is not
loaded. The usual symptom, as reported by Jaroslav Kameník and
others, is that the ACPI GPE associated with PCIe hotplug keeps
firing continuously causing kacpid to take substantial percentage
of CPU time.
To work around this issue, change the default so that the native
PCIe PME signaling is only used if directly requested with the help
of the pcie_pme= command line switch.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15924 , which is
a listed regression from 2.6.33.
Reported-by: Jaroslav Kameník <jaroslav@kamenik.cz>
Tested-by: Antoni Grzymala <antekgrzymala@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: clear bridge resource range if BIOS assigned bad one
PCI: hotplug/cpqphp, fix NULL dereference
Revert "PCI: create function symlinks in /sys/bus/pci/slots/N/"
PCI: change resource collision messages from KERN_ERR to KERN_INFO
This reverts commit 75568f8094eb0333e9c2109b23cbc8b82d318a3c.
Since they're just a convenience anyway, remove these symlinks since
they're causing duplicate filename errors in the wild.
Acked-by: Alex Chiang <achiang@canonical.com>
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: improve xfs_isilocked
xfs: skip writeback from reclaim context
xfs: remove done roadmap item from xfs-delayed-logging-design.txt
xfs: fix race in inode cluster freeing failing to stale inodes
xfs: fix access to upper inodes without inode64
xfs: fix might_sleep() warning when initialising per-ag tree
fs/xfs/quota: Add missing mutex_unlock
xfs: remove duplicated #include
xfs: convert more trace events to DEFINE_EVENT
xfs: xfs_trace.c: remove duplicated #include
xfs: Check new inode size is OK before preallocating
xfs: clean up xlog_align
xfs: cleanup log reservation calculactions
xfs: be more explicit if RT mount fails due to config
xfs: replace E2BIG with EFBIG where appropriate
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/i7core
* 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/i7core: (83 commits)
i7core_edac: Better describe the supported devices
Add support for Westmere to i7core_edac driver
i7core_edac: don't free on success
i7core_edac: Add support for X5670
Always call i7core_[ur]dimm_check_mc_ecc_err
i7core_edac: fix memory leak of i7core_dev
EDAC: add __init to i7core_xeon_pci_fixup
i7core_edac: Fix wrong device id for channel 1 devices
i7core: add support for Lynnfield alternate address
i7core_edac: Add initial support for Lynnfield
i7core_edac: do not export static functions
edac: fix i7core build
edac: i7core_edac produces undefined behaviour on 32bit
i7core_edac: Use a more generic approach for probing PCI devices
i7core_edac: PCI device is called NONCORE, instead of NOCORE
i7core_edac: Fix ringbuffer maxsize
i7core_edac: First store, then increment
i7core_edac: Better parse "any" addrmask
i7core_edac: Use a lockless ringbuffer
edac: Create an unique instance for each kobj
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (87 commits)
V4L/DVB: ivtv: Timing tweaks and code re-order to try and improve stability
V4L/DVB: ivtv: Avoid accidental video standard change
V4L/DVB: ivtvfb : Module load / unload fixes
V4L/DVB: cx2341x: Report correct temporal setting for log-status
V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email address
V4L/DVB: drivers/media: Eliminate a NULL pointer dereference
V4L/DVB: dvb-core: Fix ULE decapsulation bug
V4L/DVB: Bug fix: make IR work again for dm1105
V4L/DVB: media/IR: nec-decoder needs to select BITREV
V4L/DVB: video/saa7134: change dprintk() to i2cdprintk()
V4L/DVB: video/saa7134: remove duplicate break
V4L/DVB: IR/imon: add auto-config for 0xffdc rf device
V4L/DVB: IR/imon: clean up usage of bools
V4L/DVB: em28xx: remove unneeded null checks
V4L/DVB: ngene: remove unused #include <linux/version.h>
V4L/DVB: ak881x needs slab.h
V4L/DVB: FusionHDTV: Use quick reads for I2C IR device probing
V4L/DVB: Technotrend S2-3200 ships with a TT 1500 remote
V4L/DVB: drivers/media: Use kzalloc
V4L/DVB: m920x: Select simple tuner
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: Eliminate us to pm ticks conversion in common path
ACPI: Fix the incorrect calculation about C-state idle time
ACPI: update feature-removal.txt to reflect deleted acpi=ht option
ACPI / EC / PM: Fix names of functions that block/unblock EC transactions
ACPI / EC / PM: Fix race between EC transactions and system suspend
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Remove all i2c_set_clientdata(client, NULL) in drivers
i2c/busses: Move two drivers to embedded section
i2c: Rename i2c_check_addr to i2c_check_addr_busy
i2c: Document reserved I2C addresses
i2c: Check for address validity on client registration
i2c: Share the I2C device presence detection code
Documentation/i2c: Checkpatch cleanup
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (41 commits)
drm/radeon/kms: make sure display hw is disabled when suspending
drm/vmwgfx: Allow userspace to change default layout. Bump minor.
drm/vmwgfx: Fix framebuffer modesetting
drm/vmwgfx: Fix vga save / restore with display topology.
vgaarb: use MIT license
vgaarb: convert pr_devel() to pr_debug()
drm: fix typos in Linux DRM Developer's Guide
drm/radeon/kms/pm: voltage fixes
drm/radeon/kms/pm: radeon_set_power_state fixes
drm/radeon/kms/pm: patch default power state with default clocks/voltages on r6xx+
drm/radeon/kms/pm: enable SetVoltage on r7xx/evergreen
drm/radeon/kms/pm: add support for SetVoltage cmd table (V2)
drm/radeon/kms/evergreen: add initial CS parser
drm/kms: disable/enable poll around switcheroo on/off
drm/nouveau: fixup confusion over which handle the DSM is hanging off.
drm/nouveau: attempt to get bios from ACPI v3
drm/nv50: cast IGP memory location to u64 before shifting
drm/ttm: Fix ttm_page_alloc.c
drm/ttm: Fix cached TTM page allocation.
drm/vmwgfx: Remove some leftover debug messages.
Remove all trailing whitespace in Documentation/i2c.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
A few typos in the DRM Developer's Guide.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Acked-by: Jesse Barnes <jesse.barnes@intel.com>
We should only build hpet_example on x86[-64], where it is implemented.
It can cause build errors on other architectures.
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Per plan, acpi=ht was removed in 2.6.35-rc1.
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits)
kbuild: Revert part of e8d400a to resolve a conflict
kbuild: Fix checking of scm-identifier variable
gconfig: add support to show hidden options that have prompts
menuconfig: add support to show hidden options which have prompts
gconfig: remove show_debug option
gconfig: remove dbg_print_ptype() and dbg_print_stype()
kconfig: fix zconfdump()
kconfig: some small fixes
add random binaries to .gitignore
kbuild: Include gen_initramfs_list.sh and the file list in the .d file
kconfig: recalc symbol value before showing search results
.gitignore: ignore *.lzo files
headerdep: perlcritic warning
scripts/Makefile.lib: Align the output of LZO
kbuild: Generate modules.builtin in make modules_install
Revert "kbuild: specify absolute paths for cscope"
kbuild: Do not unnecessarily regenerate modules.builtin
headers_install: use local file handles
headers_check: fix perl warnings
export_report: fix perl warnings
A trivial change to update my email address from my dead awalls@radix.net
address to my current awalls@md.metrocast.net address.
This change adds support for Avermedia M733A. The original version for
linux 2.6.31 was sent to me from Avermedia, original author is unknown.
I ported it to current kernels, expanded and fixed key code handling for
RM-K6 remote control, and added an additional pci id also supported.
[mchehab@redhat.com: make checkpatch.pl happier]
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Make explicit what should happen when the input signal is missing,
unreliable or does not map to a supported preset.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Warren Bosworth Focke <wbfocke@gmail.com>
Signed-off-by: Jean-François Moine <moinejf@free.fr>
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits)
ACPI: Don't let acpi_pad needlessly mark TSC unstable
drivers/acpi/sleep.h: Checkpatch cleanup
ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion
ACPI: delete unused c-state promotion/demotion data strucutures
ACPI: video: fix acpi_backlight=video
ACPI: EC: Use kmemdup
drivers/acpi: use kasprintf
ACPI, APEI, EINJ injection parameters support
Add x64 support to debugfs
ACPI, APEI, Use ERST for persistent storage of MCE
ACPI, APEI, Error Record Serialization Table (ERST) support
ACPI, APEI, Generic Hardware Error Source memory error support
ACPI, APEI, UEFI Common Platform Error Record (CPER) header
Unified UUID/GUID definition
ACPI Hardware Error Device (PNP0C33) support
ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup
ACPI, APEI, Document for APEI
ACPI, APEI, EINJ support
ACPI, APEI, HEST table parsing
ACPI, APEI, APEI supporting infrastructure
* 'for-linus/2635-updates' of git://git.fluff.org/bjdooks/linux:
ARM: S5PV210: serial: Fix section mismatch warning
ARM: s3c2410_defconfig: Add new machines
ARM: s3c6400_defconfig: Add framebuffer and basic LCD
ARM: s3c6400_defconfig: Add RTC driver support
ARM: s3c6400_defconfig: Enable USB host side
ARM: s3c6400_defconfig: Add SPI driver
ARM: s3c6400_defconfig: Update compiled machines
ARM: S5P: Regoster clk_xusbxti clock for hsotg driver
ARM: S3C64XX: Add USB OTG HCLK to the list of clocks
ARM: SAMSUNG: gpio-cfg.h: update documentation
ARM: SAMSUNG: Documentation: add documentation on GPIO code
ARM: SAMSUNG: Fix documentation for s3c_gpio_cfgpin()
ARM: S3C24XX: Documentation: add section on gpiolib changes
ARM: S3C24XX: Documentation: update GPIO documentation
ARM: S3C24XX: Documentation: update documentation overview
ARM: SAMSUNG: Documentation: update directory layout
ARM: SAMSUNG: Documentation: update the list of SoCs supported
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
remove detritus left by "mm: make read_cache_page synchronous"
fix fs/sysv s_dirt handling
fat: convert to use the new truncate convention.
ext2: convert to use the new truncate convention.
tmpfs: convert to use the new truncate convention
fs: convert simple fs to new truncate
kill spurious reference to vmtruncate
fs: introduce new truncate sequence
fs/super: fix kernel-doc warning
fs/minix: bugfix, number of indirect block ptrs per block depends on block size
rename the generic fsync implementations
drop unused dentry argument to ->fsync
fs: Add missing mutex_unlock
Fix racy use of anon_inode_getfd() in perf_event.c
get rid of the magic around f_count in aio
VFS: fix recent breakage of FS_REVAL_DOT
Revert "anon_inode: set S_IFREG on the anon_inode"
Add some documentation in Documentation/arm/Samsung for the GPIO code
and where to look for the necessary functions. Update the S3C24XX case
as well.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Add section to the S3C24XX GPIO documentation on the recent changes
to move towards gpiolib integration.
Upate the S3C24XX GPIO documentation after the changes for gpiolib
and show which calls are being replaced by gpiolib or the new s3c
generic calls.
Add the two new SoCs added in this release cycle and update the notes
on the gpiolib conversion.
Update the directory layout in Documentation/arm/Samsung/Overview.txt
to reflect the changes that have been made in the latest kernel
updates.
Update the list of SoCs supported for the plat-s5p range.
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than
setattr > vmtruncate > truncate, have filesystems call their truncate sequence
from ->setattr if filesystem specific operations are required. vmtruncate is
deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced
previously should be used.
simple_setattr is introduced for simple in-ram filesystems to implement
the new truncate sequence. Eventually all filesystems should be converted
to implement a setattr, and the default code in notify_change should go
away.
simple_setsize is also introduced to perform just the ATTR_SIZE portion
of simple_setattr (ie. changing i_size and trimming pagecache).
To implement the new truncate sequence:
- filesystem specific manipulations (eg freeing blocks) must be done in
the setattr method rather than ->truncate.
- vmtruncate can not be used by core code to trim blocks past i_size in
the event of write failure after allocation, so this must be performed
in the fs code.
- convert usage of helpers block_write_begin, nobh_write_begin,
cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed
variants. These avoid calling vmtruncate to trim blocks (see previous).
- inode_setattr should not be used. generic_setattr is a new function
to be used to copy simple attributes into the generic inode.
- make use of the better opportunity to handle errors with the new sequence.
Big problem with the previous calling sequence: the filesystem is not called
until i_size has already changed. This means it is not allowed to fail the
call, and also it does not know what the previous i_size was. Also, generic
code calling vmtruncate to truncate allocated blocks in case of error had
no good way to return a meaningful error (or, for example, atomically handle
block deallocation).
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Nick Piggin <npiggin@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: implement dump_id force param
libata: disable ATAPI AN by default
libata-sff: make BMDMA optional
libata-sff: kill dummy BMDMA ops from sata_qstor and pata_octeon_cf
libata-sff: separate out BMDMA init
libata-sff: separate out BMDMA irq handler
libata-sff: ata_sff_irq_clear() is BMDMA specific
sata_mv: drop unncessary EH callback resetting
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (23 commits)
hwmon: (lm75) Add support for the Texas Instruments TMP105
hwmon: (ltc4245) Read only one GPIO pin
hwmon: (dme1737) Add SCH5127 support
hwmon: (tmp102) Don't always stop chip at exit
hwmon: (tmp102) Fix suspend and resume functions
hwmon: (tmp102) Various fixes
hwmon: Driver for TI TMP102 temperature sensor
hwmon: EMC1403 thermal sensor support
hwmon: (applesmc) Add temperature sensor labels to sysfs interface
hwmon: (applesmc) Add generic support for MacBook Pro 7
hwmon: (applesmc) Add generic support for MacBook Pro 6
hwmon: (applesmc) Add support for MacBook Pro 5,3 and 5,4
hwmon: (tmp401) Reorganize code to get rid of static forward declarations
hwmon: (tmp401) Use constants for sysfs file permissions
hwmon: (adm1031) Allow setting update rate
hwmon: Add description of the update_rate sysfs attribute
hwmon: (lm90) Use programmed update rate
hwmon: (f71882fg) Acquire I/O regions while we're working with them
hwmon: (f71882fg) Code cleanup
hwmon: (f71882fg) Use strict_stro(l|ul) instead of simple_strto$1
Read only one of the GPIO pins as an analog voltage. The ADC can be
switched to a different GPIO pin at runtime, but this is not supported.
Previously, this driver would report the analog voltage of the currently
selected GPIO pin as all three GPIO voltages: in9_input, in10_input and
in11_input.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Add support for the hardware monitoring capabilities of the SCH5127
chip to the dme1737 driver.
Signed-off-by: Juerg Haefliger <juergh@gmail.com>
Tested-by: Jeff Rickman <jrickman@myamigos.us>
Fixes from my driver review:
http://lists.lm-sensors.org/pipermail/lm-sensors/2010-March/028051.html
Only the small changes are in there, more important changes will come
later separately as time permits.
* Drop the remnants of the now gone detect function
* The TMP102 has no known compatible chip
* Include the right header files
* Clarify why byte swapping of register values is needed
* Strip resolution info bit from temperature register value
* Set cache lifetime to 1/3 second
* Don't arbitrarily reject limit values; clamp as needed
* Make limit writing unconditional
* Don't check for transaction types the driver doesn't use
* Properly check for error when setting configuration
* Report error on failed probe
* Make the driver load automatically where needed
* Various other minor fixes
Cc: Steven King <sfking@fdwdc.com>
Driver for the TI TMP102.
The TI TMP102 is similar to the LM75. It differs from the LM75 by
having a 16-bit conf register and the temp registers have a minimum
resolution of 12 bits; the extended conf register can select 13-bit
resolution (which this driver does) and also change the update rate
(which this driver currently doesn't use).
[JD: Fix tmp102_exit tag, must be __exit, not __init.]
Signed-off-by: Steven King <sfking@fdwdc.com>
The update_rate attribute can be used by drivers to let userspace choose
the update rate of the chip, if it is configurable.
The LM64 appears to be an LM63 with added GPIO lines. Add support for the
hwmon functionality - GPIO can be added at some later stage if someone
has a need for them.
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6
* 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6:
SFI: add sysfs interface for SFI tables.
SFI: add support for v0.81 spec
