This is the 4.1.5 stable release
The driver currently does not take into account the minimum sample time
as per the Figure 6-8 Chapter 9.1.1 12-bit ADC electrical characteristics.
We set a static amount of cycles instead of considering the sample time
as a given value, which depends on hardware characteristics.
Determine sampling frequencies by first reading the device tree property
node and then calculating the required Long Sample Time Adder (LSTAdder)
value, based on the ADC clock frequency and sample time value obtained
from the device tree. This LSTAdder value is then used for calculating
the sampling frequencies possible.
In case the sample time property is not specified through the device
tree, a safe default value of 1000ns is assumed.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
[moved adck_rate calculation before sample time calculation]
commit 0d6aaffc3a6db642e0a165ba4d17d6d7bbaf5201 upstream.
pwm attributes have well defined names, which should be used.
Cc: Vadim V. Vlasov <vvlasov@dev.rtsoft.ru>
commit 61754c18752ffb78145671e94f053fb202fff041 upstream.
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command
line options), the arch Makefile is included earlier by the main
Makefile, preventing the arc architecture to set its -O3 compiler
option. Since there might be more use cases for an arch Makefile to
fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and
ARCH_CFLAGS variables that are appended to the respective kbuild
variables. The user still has the final say via the KCPPFLAGS, KAFLAGS
and KCFLAGS variables.
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
This is the 4.1.4 stable release
Add device-tree bindings of Vybrids LPDDR2/DDR3 SDRAM Memory
Controller. Access to the device is required to put the memory
into self-refresh mode.
commit 24fd03c87695a76f0517df42a37e51b1597d2c8a upstream.
This patch defines a builtin measurement policy "tcb", similar to the
existing "ima_tcb", but with additional rules to also measure files
based on the effective uid and to measure files opened with the "read"
mode bit set (eg. read, read-write).
Changing the builtin "ima_tcb" policy could potentially break existing
users. Instead of defining a new separate boot command line option each
time the builtin measurement policy is modified, this patch defines a
single generic boot command line option "ima_policy=" to specify the
builtin policy and deprecates the use of the builtin ima_tcb policy.
[The "ima_policy=" boot command line option is based on Roberto Sassu's
"ima: added new policy type exec" patch.]
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org>
commit 4351c294b8c1028077280f761e158d167b592974 upstream.
The current "mask" policy option matches files opened as MAY_READ,
MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask"
option to match files opened containing one of these modes. For
example, "mask=^MAY_READ" would match files opened read-write.
commit 139069eff7388407f19794384c42a534d618ccd7 upstream.
The new "euid" policy condition measures files with the specified
effective uid (euid). In addition, for CAP_SETUID files it measures
files with the specified uid or suid.
Changelog:
- fixed checkpatch.pl warnings
- fixed avc denied {setuid} messages - based on Roberto's feedback
commit cd025f7f94108995383edddfb61fc8afea6c66a9 upstream.
Include don't appraise or measure rules for the NSFS filesystem
in the builtin ima_tcb and ima_appraise_tcb policies.
Changelog:
- Update documentation
commit 6438de9f3fb5180d78a0422695d0b88c687757d3 upstream.
This patch adds a rule in the default measurement policy to skip inodes
in the cgroupfs filesystem. Measurements for this filesystem can be
avoided, as all the digests collected have the same value of the digest of
an empty file.
Furthermore, this patch updates the documentation of IMA policies in
Documentation/ABI/testing/ima_policy to make it consistent with
the policies set in security/integrity/ima/ima_policy.c.
Signed-off-by: Roberto Sassu <rsassu@suse.de>
commit 50f0a44991516b5b9744ecb2c080c2ec6ad21b25 upstream.
To please checkpatch and the tiresome reader, add the "atmel," prefix to the
USB udc compatible string.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit f303074160d3401970ccae082014e1ee5a9a52c5 upstream.
Create a sysfs "trim" attribute for each ata_device that displays
whether DSM TRIM is "unsupported", "unqueued", "forced_unqueued"
(blacklisted) or "queued".
Reviewed-by: Hannes Reinecke <hare@suse.de>
commit bdc10d57f236b534fb675a4bbefd10017aeb2b26 upstream.
Current description for proximity measurement is ambiguous. While
the first part says that proximity is measured by observing
reflectivity, the second part incorrectly infers that reported values
should behave like a distance.
This is because of AS3935 lightning sensor which uses the proximity
API, while not being a true proximity sensor.
Note this is marked for stable as it accompanies a fix in ABI usage
to the sx9500 driver which would otherwise appear to be correct.
Fixes: 614e8842ddf ("iio: ABI: add clarification for proximity")
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit ea78b9511a54d0de026e04b5da86b30515072f31 upstream.
There was a mistake in the definition of the functions for MPP48 on
Marvell Armada XP. The second function is dev(clkout), and not tclk.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP")
commit 80b3d04feab5e69d51cb2375eb989a7165e43e3b upstream.
The latest version of the Armada XP datasheet no longer documents the
VDD cpu_pd functions, which might indicate they are not working and/or
not supported. This commit ensures the pinctrl driver matches the
datasheet.
commit bc99357f3690c11817756adfee0ece811a3db2e7 upstream.
After updating to a more recent version of the Armada XP datasheet, we
realized that some of the pins documented as having a NAND-related
functionality in fact did not have such functionality. This commit
updates the pinctrl driver accordingly.
commit 331642fbf24a1c16b2669ca0a6479b5fcd6dd5b2 upstream.
A new revision of the Marvell Armada 38x hardware datasheet unveiled
that the definition of some of the PCIe functions were not
correct. This commit fixes the pinctrl driver accordingly.
Some PCIe functions simply do not exist, some of the PCIe functions in
fact were corresponding to other functions, and some PCIe functions
have been added.
Note: the seemingly unrelated removal of spi(cs2) on MPP47 is related:
this function is in fact implemented on MPP43, instead of a PCIe
function.
Fixes: ca6d9a084b56f ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 380/385")
commit e5447d26092c72ef3346615ee558c9112ef8063f upstream.
After updating to a more recent version of the Armada 375, we realized
Fixes: ce3ed59dcddd ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 375")
commit 438881dfddb9107ef0eb30b49368e91e092f0b3e upstream.
Due to a mistake, the CS0 and CS1 SPI0 functions were incorrectly
named "spi0-1" instead of just "spi0". This commit fixes that.
This DT binding change does not affect any of the in-tree users.
Fixes: 5f597bb2be57 ("pinctrl: mvebu: add pinctrl driver for Armada 370")
commit 3a9ad0b4fdcd57f775d3615004c8c64c021a9e7d upstream.
David Ahern reported that d63e2e1f3df9 ("sparc/PCI: Clip bridge windows
to fit in upstream windows") fails to boot on sparc/T5-8:
pci 0000:06:00.0: reg 0x184: can't handle BAR above 4GB (bus address 0x110204000)
The problem is that sparc64 assumed that dma_addr_t only needed to hold DMA
addresses, i.e., bus addresses returned via the DMA API (dma_map_single(),
etc.), while the PCI core assumed dma_addr_t could hold *any* bus address,
including raw BAR values. On sparc64, all DMA addresses fit in 32 bits, so
dma_addr_t is a 32-bit type. However, BAR values can be 64 bits wide, so
they don't fit in a dma_addr_t. d63e2e1f3df9 added new checking that
tripped over this mismatch.
Add pci_bus_addr_t, which is wide enough to hold any PCI bus address,
including both raw BAR values and DMA addresses. This will be 64 bits
on 64-bit platforms and on platforms with a 64-bit dma_addr_t. Then
dma_addr_t only needs to be wide enough to hold addresses from the DMA API.
[bhelgaas: changelog, bugzilla, Kconfig to ensure pci_bus_addr_t is at
least as wide as dma_addr_t, documentation]
Fixes: d63e2e1f3df9 ("sparc/PCI: Clip bridge windows to fit in upstream windows")
Fixes: 23b13bc76f35 ("PCI: Fail safely if we can't handle BARs larger than 4GB")
Link: http://lkml.kernel.org/r/CAE9FiQU1gJY1LYrxs+ma5LCTEEe4xmtjRG0aXJ9K_Tsu+m9Wuw@mail.gmail.com
Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96231
Reported-by: David Ahern <david.ahern@oracle.com>
Tested-by: David Ahern <david.ahern@oracle.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit ea6055c46eda1e19e02209814955e13f334bbe1b upstream.
Since commit 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data")
the 'num-cs' parameter cannot be passed through platform data when probing
with devicetree. Instead, it's a required devicetree property.
Fix the binding documentation so the property is properly specified.
Fixes: 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data")
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Signed-off-by: Mark Brown <broonie@kernel.org>
This is the 4.1.2 stable release
[ Upstream commit f522a975a8101895a85354b9c143f41b8248e71a ]
The mvneta driver supports the Ethernet IP found in the Armada 370, XP,
380 and 385 SoCs. Since at least one more hardware feature is available
for the Armada XP SoCs then a way to identify them is needed.
This patch introduces a new compatible string "marvell,armada-xp-neta".
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit")
Cc: <stable@vger.kernel.org> # v3.8+
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
This adds device tree binding documentation for the Colibri VF50
touchscreen driver.
Support configurable conversion mode through sysfs. So far, the
mode used was low-power, which is enabled by default now. Beside
that, the modes normal and high-speed are selectable as well.
Use the new device tree property which specifies the maximum ADC
conversion clock frequencies. Depending on the mode used, the
available resulting conversion frequency are calculated
dynamically.
Acked-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
This patch adds the document for DCU framebuffer driver under
Documentation/devicetree/bindings/fb/.
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk fixes from Michael Turquette:
"Very late clk regression fixes for the ARM-based AT91 platform.
These went unnoticed by me until recently, hence the late pull
request"
* tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux:
clk: at91: fix h32mx prototype inclusion in pmc header
clk: at91: trivial: typo in peripheral clock description
clk: at91: fix PERIPHERAL_MAX_SHIFT definition
clk: at91: pll: fix input range validity check
https://github.com/bbrezillon/linux-at91 into clk-fixes
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
I copied the wrong shell code into the documentation. Sorry to all who
tried to get sense out of this current example :/ Slight rewording while
we are here.
Reported-by: Tim Bakker <bakkert@mymail.vcu.edu>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
Pull networking fixes from David Miller:
1) Fix uninitialized struct station_info in cfg80211_wireless_stats(),
from Johannes Berg.
2) Revert commit attempt to fix ipv6 protocol resubmission, it adds
regressions.
3) Endless loops can be created in bridge port lists, fix from Nikolay
Aleksandrov.
4) Don't WARN_ON() if sk->sk_forward_alloc is non-zero in
sk_clear_memalloc, it is a legal situation during swap deactivation.
Fix from Mel Gorman.
5) Fix order of disabling interrupts and unlocking NAPI in enic driver
to avoid a race. From Govindarajulu Varadarajan.
6) High and low register writes are swapped when programming the start
of periodic output in igb driver. From Richard Cochran.
7) Fix device rename handling in mpls stack, from Robert Shearman.
8) Do not trigger compaction synchronously when optimistically trying
to allocate an order 3 page in alloc_skb_with_frags() and
skb_page_frag_refill(). From Shaohua Li.
9) Authentication with COOKIE_ECHO is not handled properly in SCTP, fix
from Marcelo Ricardo Leitner.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
Doc: networking: Fix URL for wiki.wireshark.org in udplite.txt
sctp: allow authenticating DATA chunks that are bundled with COOKIE_ECHO
net: don't wait for order-3 page allocation
mpls: handle device renames for per-device sysctls
net: igb: fix the start time for periodic output signals
enic: fix memory leak in rq_clean
enic: check return value for stat dump
enic: unlock napi busy poll before unmasking intr
net, swap: Remove a warning and clarify why sk_mem_reclaim is required when deactivating swap
bridge: fix multicast router rlist endless loop
tipc: disconnect socket directly after probe failure
Revert "ipv6: Fix protocol resubmission"
cfg80211: wext: clear sinfo struct before calling driver
This patch fix URL (http to https) for wiki.wireshark.org.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Pull VT-d hardware workarounds from David Woodhouse:
"This contains a workaround for hardware issues which I *thought* were
never going to be seen on production hardware. I'm glad I checked
that before the 4.1 release...
Firstly, PASID support is so broken on existing chips that we're just
going to declare the old capability bit 28 as 'reserved' and change
the VT-d spec to move PASID support to another bit. So any existing
hardware doesn't support SVM; it only sets that (now) meaningless bit
28.
That patch *wasn't* imperative for 4.1 because we don't have PASID
support yet. But *even* the extended context tables are broken — if
you just enable the wider tables and use none of the new bits in them,
which is precisely what 4.1 does, you find that translations don't
work. It's this problem which I thought was caught in time to be
fixed before production, but wasn't.
To avoid triggering this issue, we now *only* enable the extended
context tables on hardware which also advertises "we have PASID
support and we actually tested it this time" with the new PASID
feature bit.
In addition, I've added an 'intel_iommu=ecs_off' command line
parameter to allow us to disable it manually if we need to"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: Only enable extended context tables if PASID is supported
iommu/vt-d: Change PASID support to bit 40 of Extended Capability Register
Although the extended tables are theoretically a completely orthogonal
feature to PASID and anything else that *uses* the newly-available bits,
some of the early hardware has problems even when all we do is enable
them and use only the same bits that were in the old context tables.
For now, there's no motivation to support extended tables unless we're
going to use PASID support to do SVM. So just don't use them unless
PASID support is advertised too. Also add a command-line bailout just in
case later chips also have issues.
The equivalent problem for PASID support has already been fixed with the
upcoming VT-d spec update and commit bd00c606a ("iommu/vt-d: Change
PASID support to bit 40 of Extended Capability Register"), because the
problematic platforms use the old definition of the PASID-capable bit,
which is now marked as reserved and meaningless.
So with this change, we'll magically start using ECS again only when we
see the new hardware advertising "hey, we have PASID support and we
actually tested it this time" on bit 40.
The VT-d hardware architect has promised that we are not going to have
any reason to support ECS *without* PASID any time soon, and he'll make
sure he checks with us before changing that.
In the future, if hypothetical new features also use new bits in the
context tables and can be seen on implementations *without* PASID support,
we might need to add their feature bits to the ecs_enabled() macro.
Pull ARM SoC fixes from Kevin Hilman:
"About 10 days worth of small bug fixes, and the (hopefully) final
round fixes for from arm-soc land for the -rc cycle. Nothing special
to note, but here's a brief summary of fixes by SoC type:
- OMAP:
small set of misc DT fixes; boot fix for THUMB2 kernel
- mediatek:
PMIC fixes; DT fix for model name
- exynos:
wakeup interupt fixes for 3250
- mvebu:
revert mbus patch which broke DMA masters
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: am335x-boneblack: disable RTC-only sleep to avoid hardware damage
ARM: dts: AM35xx: fix system control module clocks
arm64: dts: mt8173-evb: fix model name
ARM: exynos: Fix wake-up interrupts for Exynos3250
ARM: dts: Fix n900 dts file to work around 4.1 touchscreen regression on n900
ARM: dts: Fix dm816x to use right compatible flag for MUSB
ARM: OMAP3: Fix booting with thumb2 kernel
Revert "bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus bridge window"
bus: mvebu-mbus: do not set WIN_CTRL_SYNCBARRIER on non io-coherent platforms.
ARM: mvebu: armada-xp-linksys-mamba: Disable internal RTC
soc: mediatek: Add compile dependency to pmic-wrapper
soc: mediatek: PMIC wrap: Fix register state machine handling
soc: mediatek: PMIC wrap: Fix clock rate handling
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Merge omap fixes for v4.1, urgent fix to avoid potential hardware damage From Tony Lindgren:
Omap fixes for the -rc cycle, including a fix for potential hardware
breakage on BeagleBones:
- BeagleBones don't support RTC-only mode, it can cause hardware
damage if system-power-controller is specified without
ti,pmic-shutdown-controller
- Fix a recent regression to am3517 SoCs caused by the recent clock
move that was not noticed until now despite automated boot
testing
- Fix a regression for n900 touchscreen triggered by recent
recent input changes
- Fix compatible property for dm816x USB to avoid errors with
USB Ethernet
- Fix oops for omap3 when built with CONFIG_THUMB2_KERNEL
* tag 'omap-for-v4.1/fixes-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB and PHY driver fixes from Greg KH:
"Here are some USB and PHY driver fixes that resolve some reported
regressions. Also in here are some new device ids.
All of the details are in the shortlog and these patches have been in
linux-next with no problems"
* tag 'usb-4.1-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (22 commits)
USB: cp210x: add ID for HubZ dual ZigBee and Z-Wave dongle
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
usb: renesas_usbhs: Fix fifo unclear in usbhsf_prepare_pop
usb: gadget: f_fs: fix check in read operation
usb: musb: fix order of conditions for assigning end point operations
usb: gadget: f_uac1: check return code from config_ep_by_speed
usb: gadget: ffs: fix: Always call ffs_closed() in ffs_data_clear()
usb: gadget: g_ffs: Fix counting of missing_functions
usb: s3c2410_udc: correct reversed pullup logic
usb: dwc3: gadget: Fix incorrect DEPCMD and DGCMD status macros
usb: phy: tahvo: Pass the IRQF_ONESHOT flag
usb: phy: ab8500-usb: Pass the IRQF_ONESHOT flag
usb: renesas_usbhs: Revise the binding document about the dma-names
usb: host: xhci: add mutex for non-thread-safe data
usb: make module xhci_hcd removable
USB: serial: ftdi_sio: Add support for a Motion Tracker Development Board
usb: gadget: f_midi: fix segfault when reading empty id
phy: phy-rcar-gen2: Fix USBHS_UGSTS_LOCK value
phy: omap-usb2: invoke pm_runtime_disable on error path
phy: fix Kconfig dependencies
Pull SCSI target fixes from Nicholas Bellinger:
"These are mostly minor fixes, with the exception of the following that
address fall-out from recent v4.1-rc1 changes:
- regression fix related to the big fabric API registration changes
and configfs_depend_item() usage, that required cherry-picking one
of HCH's patches from for-next to address the issue for v4.1 code.
- remaining TCM-USER -v2 related changes to enforce full CDB
passthrough from Andy + Ilias.
Also included is a target_core_pscsi driver fix from Andy that
addresses a long standing issue with a Scsi_Host reference being
leaked on PSCSI device shutdown"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iser-target: Fix error path in isert_create_pi_ctx()
target: Use a PASSTHROUGH flag instead of transport_types
target: Move passthrough CDB parsing into a common function
target/user: Only support full command pass-through
target/user: Update example code for new ABI requirements
target/pscsi: Don't leak scsi_host if hba is VIRTUAL_HOST
target: Fix se_tpg_tfo->tf_subsys regression + remove tf_subsystem
target: Drop signal_pending checks after interruptible lock acquire
target: Add missing parentheses
target: Fix bidi command handling
target/user: Disallow full passthrough (pass_level=0)
ISCSI: fix minor memory leak
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
"Some late hwmon patches, all headed for -stable
- fix sysfs attribute initialization in nct6775 and nct6683 drivers
- do not attempt to auto-detect tmp435 on I2C address 0x37
- ensure iio channel is of type IIO_VOLTAGE in ntc_thermistor driver"
* tag 'hwmon-for-linus-v4.1-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (nct6683) Add missing sysfs attribute initialization
hwmon: (nct6775) Add missing sysfs attribute initialization
hwmon: (tmp401) Do not auto-detect chip on I2C address 0x37
hwmon: (ntc_thermistor) Ensure iio channel is of type IIO_VOLTAGE
After much discussion, give up on only passing a subset of SCSI commands
to userspace and pass them all. Based on what pscsi is doing, make sure
to set SCF_SCSI_DATA_CDB for I/O ops, and define attributes identical to
pscsi.
Make hw_block_size configurable via dev param.
Remove mention of command filtering from tcmu-design.txt.
Signed-off-by: Andy Grover <agrover@redhat.com>
Reviewed-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
We now require that the userspace handler set a bit if the command is not
handled.
Update calls to tcmu_hdr_get_op for v2.
I2C address 0x37 may be used by EEPROMs, which can result in false
positives. Do not attempt to detect a chip at this address.
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Cc: stable@vger.kernel.org # v4.0+
Fix dts to match what the Linux kernel expects. This works around
touchscreen problems in 4.1 linux on Nokia n900.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Pull x86 fixes from Ingo Molnar:
"This tree includes:
- a fix that disables the compacted FPU XSAVE format by disabling
XSAVES support: the fixes are too complex and the breakages
ABI-affecting, so we want this to be quirked off in a robust way
and backported, to make sure no broken kernel is exposed to the new
hardware (which exposure is still very limited).
- an MCE printk message fix
- a documentation fix"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu: Disable XSAVES* support for now
x86/Documentation: Update the contact email for L3 cache index disable functionality
x86/mce: Fix MCE severity messages
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus
Felipe writes:
usb: fixes for v4.1-rc5
A few late important fixes which have been pending
on mailing list due to my vacations.
The important fixes are a fix for DEPCMD and DGCMD
status bitfields on DWC3, a couple fixes for Renesas
USB Controller, one of which prevents a broken DT
binding from reaching v4.1-final, and an old fix for
s3c2410-udc where pullup logic was reversed.
Signed-off-by: Felipe Balbi <balbi@ti.com>
