path: root/Documentation
2013-04-20Merge branch 'x86-kdump-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull kdump fixes from Peter Anvin: "The kexec/kdump people have found several problems with the support for loading over 4 GiB that was introduced in this merge cycle. This is partly due to a number of design problems inherent in the way the various pieces of kdump fit together (it is pretty horrifically manual in many places.) After a *lot* of iterations this is the patchset that was agreed upon, but of course it is now very late in the cycle. However, because it changes both the syntax and semantics of the crashkernel option, it would be desirable to avoid a stable release with the broken interfaces." I'm not happy with the timing, since originally the plan was to release the final 3.9 tomorrow. But apparently I'm doing an -rc8 instead... * 'x86-kdump-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: kexec: use Crash kernel for Crash kernel low x86, kdump: Change crashkernel_high/low= to crashkernel=,high/low x86, kdump: Retore crashkernel= to allocate under 896M x86, kdump: Set crashkernel_low automatically
2013-04-20Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "Three groups of fixes: 1. Make sure we don't execute the early microcode patching if family < 6, since it would touch MSRs which don't exist on those families, causing crashes. 2. The Xen partial emulation of HyperV can be dealt with more gracefully than just disabling the driver. 3. More EFI variable space magic. In particular, variables hidden from runtime code need to be taken into account too." * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode: Verify the family before dispatching microcode patching x86, hyperv: Handle Xen emulation of Hyper-V more gracefully x86,efi: Implement efi_no_storage_paranoia parameter efi: Export efi_query_variable_store() for efivars.ko x86/Kconfig: Make EFI select UCS2_STRING efi: Distinguish between "remaining space" and actually used space efi: Pass boot services variable info to runtime code Move utf16 functions to kernel core and rename x86,efi: Check max_size only if it is non-zero. x86, efivars: firmware bug workarounds should be in platform code
2013-04-19Merge remote-tracking branch 'efi/urgent' into x86/urgentH. Peter Anvin
Matt Fleming (1): x86, efivars: firmware bug workarounds should be in platform code Matthew Garrett (3): Move utf16 functions to kernel core and rename efi: Pass boot services variable info to runtime code efi: Distinguish between "remaining space" and actually used space Richard Weinberger (2): x86,efi: Check max_size only if it is non-zero. x86,efi: Implement efi_no_storage_paranoia parameter Sergey Vlasov (2): x86/Kconfig: Make EFI select UCS2_STRING efi: Export efi_query_variable_store() for efivars.ko Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17x86, kdump: Change crashkernel_high/low= to crashkernel=,high/lowYinghai Lu
Per hpa, use crashkernel=X,high crashkernel=Y,low instead of crashkernel_hign=X crashkernel_low=Y. As that could be extensible. -v2: according to Vivek, change delimiter to ; -v3: let hign and low only handle simple form and it conforms to description in kernel-parameters.txt still keep crashkernel=X override any crashkernel=X,high crashkernel=Y,low -v4: update get_last_crashkernel returning and add more strict checking in parse_crashkernel_simple() found by HATAYAMA. -v5: Change delimiter back to , according to HPA. also separate parse_suffix from parse_simper according to vivek. so we can avoid @pos in that path. -v6: Tight the checking about crashkernel=X,highblahblah,high found by HTYAYAMA. Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1366089828-19692-5-git-send-email-yinghai@kernel.org Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17x86, kdump: Retore crashkernel= to allocate under 896MYinghai Lu
Vivek found old kexec-tools does not work new kernel anymore. So change back crashkernel= back to old behavoir, and add crashkernel_high= to let user decide if buffer could be above 4G, and also new kexec-tools will be needed. -v2: let crashkernel=X override crashkernel_high= update description about _high will be ignored by crashkernel=X -v3: update description about kernel-parameters.txt according to Vivek. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1366089828-19692-4-git-send-email-yinghai@kernel.org Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17x86, kdump: Set crashkernel_low automaticallyYinghai Lu
Chao said that kdump does does work well on his system on 3.8 without extra parameter, even iommu does not work with kdump. And now have to append crashkernel_low=Y in first kernel to make kdump work. We have now modified crashkernel=X to allocate memory beyong 4G (if available) and do not allocate low range for crashkernel if the user does not specify that with crashkernel_low=Y. This causes regression if iommu is not enabled. Without iommu, swiotlb needs to be setup in first 4G and there is no low memory available to second kernel. Set crashkernel_low automatically if the user does not specify that. For system that does support IOMMU with kdump properly, user could specify crashkernel_low=0 to save that 72M low ram. -v3: add swiotlb_size() according to Konrad. -v4: add comments what 8M is for according to hpa. also update more crashkernel_low= in kernel-parameters.txt -v5: update changelog according to Vivek. -v6: Change description about swiotlb referring according to HATAYAMA. Reported-by: WANG Chao <chaowang@redhat.com> Tested-by: WANG Chao <chaowang@redhat.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1366089828-19692-2-git-send-email-yinghai@kernel.org Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17x86,efi: Implement efi_no_storage_paranoia parameterRichard Weinberger
Using this parameter one can disable the storage_size/2 check if he is really sure that the UEFI does sane gc and fulfills the spec. This parameter is useful if a devices uses more than 50% of the storage by default. The Intel DQSW67 desktop board is such a sucker for exmaple. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-04-12Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of ten bug fixes (and two consisting of copyright year update and version number change) pretty much all of which involve either a crash or a hang except the removal of the random sleep from the qla2xxx driver (which is a coding error so bad, we want it gone before anyone has a chance to copy it)." * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: [SCSI] lpfc: fix potential NULL pointer dereference in lpfc_sli4_rq_put() [SCSI] libsas: fix handling vacant phy in sas_set_ex_phy() [SCSI] ibmvscsi: Fix slave_configure deadlock [SCSI] qla2xxx: Update the driver version to 8.04.00.13-k. [SCSI] qla2xxx: Remove debug code that msleeps for random duration. [SCSI] qla2xxx: Update copyright dates information in LICENSE.qla2xxx file. [SCSI] qla2xxx: Fix crash during firmware dump procedure. [SCSI] Revert "qla2xxx: Add setting of driver version string for vendor application." [SCSI] ipr: dlpar failed when adding an adapter back [SCSI] ipr: fix addition of abort command to HRRQ free queue [SCSI] st: Take additional queue ref in st_probe [SCSI] libsas: use right function to alloc smp response [SCSI] ipr: ipr_test_msi() fails when running with msi-x enabled adapter
2013-04-10Merge tag 'tty-3.9-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg Kroah-Hartman: "Here are 4 small tty/serial fixes for 3.9. One fixes a bug where we broke the documentation build, and the others fix reported problems in some serial drivers. All have been in linux-next for a while" * tag 'tty-3.9-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: mxser: fix cycle termination condition in mxser_probe() and mxser_module_init() Revert "tty/8250_pnp: serial port detection regression since v3.7" OMAP/serial: Revert bad fix of Rx FIFO threshold granularity tty: Documentation: fix a path in a DocBook template
2013-04-06[SCSI] qla2xxx: Update copyright dates information in LICENSE.qla2xxx file.Saurav Kashyap
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-04-05Merge tag 'sound-3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This contains slightly more volumes than usual at this stage, mostly because of my vacation in the last week. Nothing to scare, all small and/or trivial fixes: - Fix loop path handling in ASoC DAPM - Some memory handling fixes in ASoC core - Fix spear_pcm to adapt to the updated API - HD-audio HDMI ELD handling fixes - Fix for CM6331 USB-audio SRC change bugs - Revert power_save_controller option change due to user-space usage - A few other small ASoC and HD-audio fixes" * tag 'sound-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/generic - fix uninitialized variable Revert "ALSA: hda - Allow power_save_controller option override DCAPS" ALSA: hda - fix typo in proc output ALSA: hda - Enabling Realtek ALC 671 codec ALSA: usb: Work around CM6631 sample rate change bug ALSA: hda - bug fix on HDMI ELD debug message ALSA: hda - bug fix on return value when getting HDMI ELD info ASoC: dma-sh7760: Fix compile error ASoC: core: fix invalid free of devm_ allocated data ASoC: spear_pcm: Update to new pcm_new() API ASoC:: max98090: Remove executable bit ASoC: dapm: Fix pointer dereference in is_connected_output_ep() ASoC: pcm030 audio fabric: remove __init from probe ASoC: imx-ssi: Fix occasional AC97 reset failure ASoC: core: fix possible memory leak in snd_soc_bytes_put() ASoC: wm_adsp: fix possible memory leak in wm_adsp_load_coeff() ASoC: dapm: Fix handling of loops ASoC: si476x: Add missing break for SNDRV_PCM_FORMAT_S8 switch case
2013-04-04Revert "ALSA: hda - Allow power_save_controller option override DCAPS"Takashi Iwai
This reverts commit 6ab317419c62850a71e2adfd1573e5ee87d8774f. The commit [6ab317419c: ALSA: hda - Allow power_save_controller option override DCAPS] changed the behavior of power_save_controller so that it can override the driver capability. This assumed that this option is rarely changed dynamically unlike power_save option. Too naive. It turned out that the user-space power-management tool tries to set power_save_controller option to 1 together with power_save option without knowing what's actually doing. This enabled forcibly the runtime PM of the controller, which is known to be broken om many chips thus disabled as default. So, the only sane fix is to revert this commit again. It was intended to ease debugging/testing for runtime PM enablement, but obviously we need another way for it. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=56171 Reported-and-tested-by: Nikita Tsukanov <keks9n@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-03tty: Documentation: fix a path in a DocBook templateGuennadi Liakhovetski
A wrong path to a driver breaks DocBook built. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Always increment IPV4 ID field in encapsulated GSO packets, even when DF is set. Regression fix from Pravin B Shelar. 2) Fix per-net subsystem initialization in netfilter conntrack, otherwise we may access dynamically allocated memory before it is actually allocated. From Gao Feng. 3) Fix DMA buffer lengths in iwl3945 driver, from Stanislaw Gruszka. 4) Fix race between submission of sync vs async commands in mwifiex driver, from Amitkumar Karwar. 5) Add missing cancel of command timer in mwifiex driver, from Bing Zhao. 6) Missing SKB free in rtlwifi USB driver, from Jussi Kivilinna. 7) Thermal layer tries to use a genetlink multicast string that is longer than the 16 character limit. Fix it and add a BUG check to prevent this kind of thing from happening in the future. From Masatake YAMATO. 8) Fix many bugs in the handling of the teardown of L2TP connections, UDP encapsulation instances, and sockets. From Tom Parkin. 9) Missing socket release in IRDA, from Kees Cook. 10) Fix fec driver modular build, from Fabio Estevam. 11) Erroneous use of kfree() instead of free_netdev() in lantiq_etop, from Wei Yongjun. 12) Fix bugs in handling of queue numbers and steering rules in mlx4 driver, from Moshe Lazer, Hadar Hen Zion, and Or Gerlitz. 13) Some FOO_DIAG_MAX constants were defined off by one, fix from Andrey Vagin. 14) TCP segmentation deferral is unintentionally done too strongly, breaking ACK clocking. Fix from Eric Dumazet. 15) net_enable_timestamp() can legitimately be invoked from software interrupts, and in a way that is safe, so remove the WARN_ON(). Also from Eric Dumazet. 16) Fix use after free in VLANs, from Cong Wang. 17) Fix TCP slow start retransmit storms after SACK reneging, from Yuchung Cheng. 18) Unix socket release should mark a socket dead before NULL'ing out sock->sk, otherwise we can race. Fix from Paul Moore. 19) IPV6 addrconf code can try to free static memory, from Hong Zhiguo. 20) Fix register mis-programming, NULL pointer derefs, and wrong PHC clock frequency in IGB driver. From Lior LevyAlex Williamson, Jiri Benc, and Jeff Kirsher. 21) skb->ip_summed logic in pch_gbe driver is reversed, breaking packet forwarding. Fix from Veaceslav Falico. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) ipv4: Fix ip-header identification for gso packets. bonding: remove already created master sysfs link on failure af_unix: dont send SCM_CREDENTIAL when dest socket is NULL pch_gbe: fix ip_summed checksum reporting on rx igb: fix PHC stopping on max freq igb: make sensor info static igb: SR-IOV init reordering igb: Fix null pointer dereference igb: fix i350 anti spoofing config ixgbevf: don't release the soft entries ipv6: fix bad free of addrconf_init_net unix: fix a race condition in unix_release() tcp: undo spurious timeout after SACK reneging bnx2x: fix assignment of signed expression to unsigned variable bridge: fix crash when set mac address of br interface 8021q: fix a potential use-after-free net: remove a WARN_ON() in net_enable_timestamp() tcp: preserve ACK clocking in TSO net: fix *_DIAG_MAX constants net/mlx4_core: Disallow releasing VF QPs which have steering rules ...
2013-03-23Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "One bugfix for the tegra driver. Two updates regarding email addresses and MAINTAINERS which I like to have up-to-date so people can be reached immediately. While we are here, there is on PCI_ID addition." * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: MAINTAINERS: add maintainer entry for atmel i2c driver i2c: Fix my e-mail address in drivers and documentation i2c: iSMT: add Intel Avoton DeviceIDs i2c: tegra: check the clk_prepare_enable() return value
2013-03-22Merge tag 'sound-3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Mostly HD-audio and USB-audio regression fixes: - Oops fix at unloading of snd-hda-codec-conexant module - A few trivial regression fixes for Cirrus and Conexant HD-audio codecs - Relax the USB-audio descriptor parse errors as non-fatal - Fix locking of HD-audio CA0132 DSP loader - Fix the generic HD-audio parser for VIA codecs" * tag 'sound-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix DAC assignment for independent HP ALSA: hda - Fix abuse of snd_hda_lock_devices() for DSP loader ALSA: hda - Fix typo in checking IEC958 emphasis bit ALSA: snd-usb: mixer: ignore -EINVAL in snd_usb_mixer_controls() ALSA: snd-usb: mixer: propagate errors up the call chain ALSA: usb: Parse UAC2 extension unit like for UAC1 ALSA: hda - Fix yet missing GPIO/EAPD setup in cirrus driver ALSA: hda/cirrus - Fix the digital beep registration ALSA: hda - Fix missing beep detach in patch_conexant.c ALSA: documentation: Fix typo in Documentation/sound
2013-03-22i2c: Fix my e-mail address in drivers and documentationGuenter Roeck
My old e-mail address is no longer working. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-03-20Merge branch 'master' of git://1984.lsi.us.es/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains 7 Netfilter/IPVS fixes for 3.9-rc, they are: * Restrict IPv6 stateless NPT targets to the mangle table. Many users are complaining that this target does not work in the nat table, which is the wrong table for it, from Florian Westphal. * Fix possible use before initialization in the netns init path of several conntrack protocol trackers (introduced recently while improving conntrack netns support), from Gao Feng. * Fix incorrect initialization of copy_range in nfnetlink_queue, spotted by Eric Dumazet during the NFWS2013, patch from myself. * Fix wrong calculation of next SCTP chunk in IPVS, from Julian Anastasov. * Remove rcu_read_lock section in IPVS while calling ipv4_update_pmtu not required anymore after change introduced in 3.7, again from Julian. * Fix SYN looping in IPVS state sync if the backup is used a real server in DR/TUN modes, this required a new /proc entry to disable the director function when acting as backup, also from Julian. * Remove leftover IP_NF_QUEUE Kconfig after ip_queue removal, noted by Paul Bolle. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-19ipvs: add backup_only flag to avoid loopsJulian Anastasov
Dmitry Akindinov is reporting for a problem where SYNs are looping between the master and backup server when the backup server is used as real server in DR mode and has IPVS rules to function as director. Even when the backup function is enabled we continue to forward traffic and schedule new connections when the current master is using the backup server as real server. While this is not a problem for NAT, for DR and TUN method the backup server can not determine if a request comes from client or from director. To avoid such loops add new sysctl flag backup_only. It can be needed for DR/TUN setups that do not need backup and director function at the same time. When the backup function is enabled we stop any forwarding and pass the traffic to the local stack (real server mode). The flag disables the director function when the backup function is enabled. For setups that enable backup function for some virtual services and director function for other virtual services there should be another more complex solution to support DR/TUN mode, may be to assign per-virtual service syncid value, so that we can differentiate the requests. Reported-by: Dmitry Akindinov <dimak@stalker.com> Tested-by: German Myzovsky <lawyer@sipnet.ru> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2013-03-18hwmon: (lm75) Fix tcn75 prefixJean Delvare
The TCN75 has its own prefix for a long time now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2013-03-17ALSA: documentation: Fix typo in Documentation/soundMasanari Iida
Correct spelling typos in Documentation/sound/alsa Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-15Merge tag 'mfd-fixes-3.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes Pull MFD fixes from Samuel Ortiz: "This is the first batch of MFD fixes for 3.9. With this one we have: - An ab8500 build failure fix. - An ab8500 device tree parsing fix. - A fix for twl4030_madc remove routine to work properly (when built-in). - A fix for properly registering palmas interrupt handler. - A fix for omap-usb init routine to actually write into the hostconfig register. - A couple of warning fixes for ab8500-gpadc and tps65912" * tag 'mfd-fixes-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes: mfd: twl4030-madc: Remove __exit_p annotation mfd: ab8500: Kill "reg" property from binding mfd: ab8500-gpadc: Complain if we fail to enable vtvout LDO mfd: wm831x: Don't forward declare enum wm831x_auxadc mfd: twl4030-audio: Fix argument type for twl4030_audio_disable_resource() mfd: tps65912: Declare and use tps65912_irq_exit() mfd: palmas: Provide irq flags through DT/platform data mfd: Make AB8500_CORE select POWER_SUPPLY to fix build error mfd: omap-usb-host: Actually update hostconfig
2013-03-13Merge tag 'tty-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg Kroah-Hartman: "Here are some tty/serial driver fixes for 3.9 We finally mute the annoying WARN_ON that lots of people are hitting and it turns out isn't needed anymore. Also add a few new device ids and a some other minor fixes." * tag 'tty-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: serial: fix typo "SERIAL_S3C2412" serial: 8250: Keep 8250.<xxxx> module options functional after driver rename tty: serial: fix typo "ARCH_S5P6450" tty/8250_pnp: serial port detection regression since v3.7 serial: bcm63xx_uart: fix compilation after "TTY: switch tty_insert_flip_char" serial: 8250_pci: add support for another kind of NetMos Technology PCI 9835 Multi-I/O Controller Fix 4 port and add support for 8 port 'Unknown' PCI serial port cards tty/serial: Add support for Altera serial port tty: serial: vt8500: Unneccessary duplicated clock code removed tty: serial: mpc5xxx: fix PSC clock name bug TTY: disable debugging warning
2013-03-12tty/serial: Add support for Altera serial portLey Foon Tan
Add support for Altera 8250/16550 compatible serial port. Signed-off-by: Ley Foon Tan <lftan@altera.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12mfd: ab8500: Kill "reg" property from bindingArnd Bergmann
The ab8500 device is a child of the prcmu device, which is a memory mapped bus device, whose children are addressable using physical memory addresses, not using mailboxes, so a mailbox number in the ab8500 node cannot be parsed by DT. Nothing uses this number, since it was only introduced as part of the failed attempt to clean up prcmu mailbox handling, and we can simply remove it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-03-11Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc minor fixes mostly related to tracing" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: s390: Fix a header dependencies related build error tracing: update documentation of snapshot utility tracing: Do not return EINVAL in snapshot when not allocated tracing: Add help of snapshot feature when snapshot is empty ftrace: Update the kconfig for DYNAMIC_FTRACE
2013-03-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Missing cancel of work items in mac80211 MLME, from Ben Greear. 2) Fix DMA mapping handling in iwlwifi by using coherent DMA for command headers, from Johannes Berg. 3) Decrease the amount of pressure on the page allocator by using order 1 pages less in iwlwifi, from Emmanuel Grumbach. 4) Fix mesh PS broadcast OOPS in mac80211, from Marco Porsch. 5) Don't forget to recalculate idle state in mac80211 monitor interface, from Felix Fietkau. 6) Fix varargs in netfilter conntrack handler, from Joe Perches. 7) Need to reset entire chip when command queue fills up in iwlwifi, from Emmanuel Grumbach. 8) The TX antenna value must be valid when calibrations are performed in iwlwifi, fix from Dor Shaish. 9) Don't generate netfilter audit log entries when audit is disabled, from Gao Feng. 10) Deal with DMA unit hang on e1000e during power state transitions, from Bruce Allan. 11) Remove BUILD_BUG_ON check from igb driver, from Alexander Duyck. 12) Fix lockdep warning on i2c handling of igb driver, from Carolyn Wyborny. 13) Fix several TTY handling issues in IRDA ircomm tty driver, from Peter Hurley. 14) Several QFQ packet scheduler fixes from Paolo Valente. 15) When VXLAN encapsulates on transmit, we have to reset the netfilter state. From Zang MingJie. 16) Fix jiffie check in net_rx_action() so that we really cap the processing at 2HZ. From Eric Dumazet. 17) Fix erroneous trigger of IP option space exhaustion, when routers are pre-specified and we are looking to see if we can insert a timestamp, we will have the space. From David Ward. 18) Fix various issues in benet driver wrt waiting for firmware to finish POST after resets or errors. From Gavin Shan and Sathya Perla. 19) Fix TX locking in SFC driver, from Ben Hutchings. 20) Like the VXLAN fix above, when we encap in a TUN device we have to reset the netfilter state. This should fix several strange crashes reported by Dave Jones and others. From Eric Dumazet. 21) Don't forget to clean up MAC address resources when shutting down a port in mlx4 driver, from Yan Burman. 22) Fix divide by zero in vmxnet3 driver, from Bhavesh Davda. 23) Fix device statistic regression in tg3 when the driver is using phylib, from Nithin Sujir. 24) Fix info leak in several netlink handlers, from Mathias Krause. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits) 6lowpan: Fix endianness issue in is_addr_link_local(). rrunner.c: fix possible memory leak in rr_init_one() dcbnl: fix various netlink info leaks rtnl: fix info leak on RTM_GETLINK request for VF devices bridge: fix mdb info leaks tg3: Update link_up flag for phylib devices ipv6: stop multicast forwarding to process interface scoped addresses bridging: fix rx_handlers return code netlabel: fix build problems when CONFIG_IPV6=n drivers/isdn: checkng length to be sure not memory overflow net/rds: zero last byte for strncpy bnx2x: Fix SFP+ misconfiguration in iSCSI boot scenario bnx2x: Fix intermittent long KR2 link up time macvlan: Set IFF_UNICAST_FLT flag to prevent unnecessary promisc mode. team: unsyc the devices addresses when port is removed bridge: add missing vid to br_mdb_get() Fix: sparse warning in inet_csk_prepare_forced_close afkey: fix a typo MAINTAINERS: Update qlcnic maintainers list netlabel: correctly list all the static label mappings ...
2013-03-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "Except for the largish change to the ALPS driver adding "Dolphin V1" support and Wacom getting a new signature of yet another device, the rest are straightforward driver fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: mms114 - Fix regulator enable and disable paths Input: ads7864 - check return value of regulator enable Input: tc3589x-keypad - fix keymap size Input: wacom - add support for 0x10d Input: ALPS - update documentation for recent touchpad driver mods Input: ALPS - add "Dolphin V1" touchpad support Input: ALPS - remove unused argument to alps_enter_command_mode() Input: cypress_ps2 - fix trackpadi found in Dell XPS12
2013-03-08Randy has movedRandy Dunlap
Update email address and CREDITS info. xenotime.net is defunct. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Harry Wei <harryxiyou@gmail.com> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-08tracing: update documentation of snapshot utilityHiraku Toyooka
Now, "snapshot" file returns success on a reset of snapshot buffer even if the buffer wasn't allocated, instead of returning EINVAL. This patch updates snapshot desctiption according to the change. Link: http://lkml.kernel.org/r/51399409.4090207@hitachi.com Signed-off-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-07Merge tag 'pm+acpi-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael J Wysocki: - Two fixes for the new intel_pstate driver from Dirk Brandewie. - Fix for incorrect usage of the .find_bridge() callback from struct acpi_bus_type in the USB core and subsequent removal of that callback from Rafael J Wysocki. - ACPI processor driver cleanups from Chen Gang and Syam Sidhardhan. - ACPI initialization and error messages fix from Joe Perches. - Operating Performance Points documentation improvement from Nishanth Menon. - Fixes for memory leaks and potential concurrency issues and sysfs attributes leaks during device removal in the core device PM QoS code from Rafael J Wysocki. - Calxeda Highbank cpufreq driver simplification from Emilio López. - cpufreq comment cleanup from Namhyung Kim. - Fix for a section mismatch in Calxeda Highbank interprocessor communication code from Mark Langsdorf (this is not a PM fix strictly speaking, but the code in question went in through the PM tree). * tag 'pm+acpi-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq / intel_pstate: Do not load on VM that does not report max P state. cpufreq / intel_pstate: Fix intel_pstate_init() error path ACPI / glue: Drop .find_bridge() callback from struct acpi_bus_type ACPI / glue: Add .match() callback to struct acpi_bus_type ACPI / porocessor: Beautify code, pr->id is u32 which is never < 0 ACPI / processor: Remove redundant NULL check before kfree ACPI / Sleep: Avoid interleaved message on errors PM / QoS: Remove device PM QoS sysfs attributes at the right place PM / QoS: Fix concurrency issues and memory leaks in device PM QoS cpufreq: highbank: do not initialize array with a loop PM / OPP: improve introductory documentation cpufreq: Fix a typo in comment mailbox, pl320-ipc: remove __init from probe function
2013-03-07Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon patches from Guenter Roeck: "Bug fixes for sht15 and ltc2978 driver plus some documentation updates" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (sht15) Check return value of regulator_enable() hwmon: (adt7410) Document ADT7420 support hwmon: (pmbus/ltc2978) Use detected chip ID to select supported functionality hwmon: (pmbus/ltc2978) Fix peak attribute handling hwmon: (pmbus/ltc2978) Update datasheet links hwmon: Update my e-mail address in driver documentation
2013-03-06net: docs: document multiqueue tuntap APIJason Wang
Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-05Merge tag 'md-3.9' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from NeilBrown: "Mostly little bugfixes. Only "feature" is a new RAID10 layout which slightly improves the number of sets of devices that can concurrently fail, without data loss." * tag 'md-3.9' of git://neil.brown.name/md: md: expedite metadata update when switching read-auto -> active md: remove CONFIG_MULTICORE_RAID456 md/raid1,raid10: fix deadlock with freeze_array() md/raid0: improve error message when converting RAID4-with-spares to RAID0 md: raid0: fix error return from create_stripe_zones. md: fix two bugs when attempting to resize RAID0 array. DM RAID: Add support for MD's RAID10 "far" and "offset" algorithms MD RAID10: Improve redundancy for 'far' and 'offset' algorithms (part 2) MD RAID10: Improve redundancy for 'far' and 'offset' algorithms (part 1) MD RAID10: Minor non-functional code changes md: raid1,10: Handle REQ_WRITE_SAME flag in write bios md: protect against crash upon fsync on ro array
2013-03-04PM / OPP: improve introductory documentationNishanth Menon
Make Operating Performance Points (OPP) library introductory chapter a little more reader-friendly. Split the chapter into two sections, highlight the definition with an example and minor rewording to be verbose. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-03hwmon: (adt7410) Document ADT7420 supportJean Delvare
The adt7410 driver supports the ADT7420, but its documentation file makes no mention of that. Add this refrence, and a brief a description of the differences between the ADT7410 and the ADT7420. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Hartmut Knaack <knaack.h@gmx.de> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-03-03hwmon: (pmbus/ltc2978) Update datasheet linksGuenter Roeck
Links to datasheets are no longer valid. Provide links to product information instead (which provides links to the datasheets and is hopefully more persistent). Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2013-03-03hwmon: Update my e-mail address in driver documentationGuenter Roeck
Most of the hwmon driver documentation still listed my old invalid e-mail address. Fix it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-03Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - fixes and improvements - devicetree bindings - conversion to watchdog generic framework of the following drivers: - booke_wdt - bcm47xx_wdt.c - at91sam9_wdt - Removal of old STMP3xxx driver - Addition of following new drivers: - new driver for STMP3xxx and i.MX23/28 - Retu watchdog driver" * git://www.linux-watchdog.org/linux-watchdog: (30 commits) watchdog: sp805_wdt depends on ARM watchdog: davinci_wdt: update to devm_* API watchdog: davinci_wdt: use devm managed clk get watchdog: at91rm9200: add DT support watchdog: add timeout-sec property binding watchdog: at91sam9_wdt: Convert to use the watchdog framework watchdog: omap_wdt: Add option nowayout watchdog: core: dt: add support for the timeout-sec dt property watchdog: bcm47xx_wdt.c: add hard timer watchdog: bcm47xx_wdt.c: rename wdt_time to timeout watchdog: bcm47xx_wdt.c: rename ops methods watchdog: bcm47xx_wdt.c: use platform device watchdog: bcm47xx_wdt.c: convert to watchdog core api watchdog: Convert BookE watchdog driver to watchdog infrastructure watchdog: s3c2410_wdt: Use devm_* functions watchdog: remove old STMP3xxx driver watchdog: add new driver for STMP3xxx and i.MX23/28 rtc: stmp3xxx: add wdt-accessor function watchdog: introduce retu_wdt driver watchdog: intel_scu_watchdog: fix Kconfig dependency ...
2013-03-03Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull second set of slave-dmaengine updates from Vinod Koul: "Arnd's patch moves the dw_dmac to use generic DMA binding. I agreed to merge this late as it will avoid the conflicts between trees. The second patch from Matt adding a dma_request_slave_channel_compat API was supposed to be picked up, but somehow never got picked up. Some patches dependent on this are already in -next :(" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: dw_dmac: move to generic DMA binding dmaengine: add dma_request_slave_channel_compat()
2013-03-03Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Mostly relatively small updates, along with some hardware enablement for Sony hardware and a pile of updates to Google's Chromebook driver" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (49 commits) ideapad-laptop: Depend on BACKLIGHT_CLASS_DEVICE instead of selecting it ideapad: depends on backlight subsystem and update comment Platform: x86: chromeos_laptop - add i915 gmbuses to adapter names Platform: x86: chromeos_laptop - Add isl light sensor for Pixel Platform: x86: chromeos_laptop - Add a more general add_i2c_device Platform: x86: chromeos_laptop - Add Pixel Touchscreen Platform: x86: chromeos_laptop - Add support for probing devices Platform: x86: chromeos_laptop - Add Pixel Trackpad hp-wmi: fix handling of platform device sony-laptop: leak in error handling sony_nc_lid_resume_setup() hp-wmi: Add support for SMBus hotkeys asus-wmi: Fix unused function build warning acer-wmi: avoid the warning of 'devices' may be used uninitialized drivers/platform/x86/thinkpad_acpi.c: Handle HKEY event 0x6040 Platform: x86: chromeos_laptop - Add HP Pavilion 14 Platform: x86: chromeos_laptop - Add Taos tsl2583 device Platform: x86: chromeos_laptop - Add Taos tsl2563 device Platform: x86: chromeos_laptop - Add Acer C7 trackpad Platform: x86: chromeos_laptop - Rename setup_lumpy_tp to setup_cyapa_smbus_tp asus-laptop: always report brightness key events ...
2013-03-02Merge tag 'for-linus-20130301' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from David Woodhouse: "Fairly unexciting MTD merge for 3.9: - misc clean-ups in the MTD command-line partitioning parser (cmdlinepart) - add flash locking support for STmicro chips serial flash chips, as well as for CFI command set 2 chips. - new driver for the ELM error correction HW module found in various TI chips, enable the OMAP NAND driver to use the ELM HW error correction - added number of new serial flash IDs - various fixes and improvements in the gpmi NAND driver - bcm47xx NAND driver improvements - make the mtdpart module actually removable" * tag 'for-linus-20130301' of git://git.infradead.org/linux-mtd: (45 commits) mtd: map: BUG() in non handled cases mtd: bcm47xxnflash: use pr_fmt for module prefix in messages mtd: davinci_nand: Use managed resources mtd: mtd_torturetest can cause stack overflows mtd: physmap_of: Convert device allocation to managed devm_kzalloc() mtd: at91: atmel_nand: for PMECC, add code to check the ONFI parameter ECC requirement. mtd: atmel_nand: make pmecc-cap, pmecc-sector-size in dts is optional. mtd: atmel_nand: avoid to report an error when lookup table offset is 0. mtd: bcm47xxsflash: adjust names of bus-specific functions mtd: bcm47xxpart: improve probing of nvram partition mtd: bcm47xxpart: add support for other erase sizes mtd: bcm47xxnflash: register this as normal driver mtd: bcm47xxnflash: fix message mtd: bcm47xxsflash: register this as normal driver mtd: bcm47xxsflash: write number of written bytes mtd: gpmi: add sanity check for the ECC mtd: gpmi: set the Golois Field bit for mx6q's BCH mtd: devices: elm: Removes <xx> literals in elm DT node mtd: gpmi: fix a dereferencing freed memory error mtd: fix the wrong timeo for panic_nand_wait() ...
2013-03-02metag: Basic documentationJames Hogan
Add basic metag documentation. This includes an outline description of the ABIs (including syscall ABI) and calling conventions, similar to the one in Documentation/frv/. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Rob Landley <rob@landley.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: linux-doc@vger.kernel.org
2013-03-02metag: Internal and external irqchipsJames Hogan
Meta core internal interrupts (from HWSTATMETA and friends) are vectored onto the TR1 core trigger for the current thread. This is demultiplexed in irq-metag.c to individual Linux IRQs for each internal interrupt. External SoC interrupts (from HWSTATEXT and friends) are vectored onto the TR2 core trigger for the current thread. This is demultiplexed in irq-metag-ext.c to individual Linux IRQs for each external SoC interrupt. The external irqchip has devicetree bindings for configuring the number of irq banks and the type of masking available. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Rob Landley <rob@landley.net> Cc: Dom Cobley <popcornmix@gmail.com> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: devicetree-discuss@lists.ozlabs.org Cc: linux-doc@vger.kernel.org
2013-03-02Merge tag 'dm-3.9-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper update from Alasdair G Kergon: "The main addition here is a long-desired target framework to allow an SSD to be used as a cache in front of a slower device. Cache tuning is delegated to interchangeable policy modules so these can be developed independently of the mechanics needed to shuffle the data around. Other than that, kcopyd users acquire a throttling parameter, ioctl buffer usage gets streamlined, more mempool reliance is reduced and there are a few other bug fixes and tidy-ups." * tag 'dm-3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (30 commits) dm cache: add cleaner policy dm cache: add mq policy dm: add cache target dm persistent data: add bitset dm persistent data: add transactional array dm thin: remove cells from stack dm bio prison: pass cell memory in dm persistent data: add btree_walk dm: add target num_write_bios fn dm kcopyd: introduce configurable throttling dm ioctl: allow message to return data dm ioctl: optimize functions without variable params dm ioctl: introduce ioctl_flags dm: merge io_pool and tio_pool dm: remove unused _rq_bio_info_cache dm: fix limits initialization when there are no data devices dm snapshot: add missing module aliases dm persistent data: set some btree fn parms const dm: refactor bio cloning dm: rename bio cloning functions ...
2013-03-02Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI updates from James Bottomley: "This is an assorted set of stragglers into the merge window with driver updates for qla2xxx, megaraid_sas, storvsc and ufs. It also includes pulls of the uapi tree (all the remaining SCSI pieces) and the fcoe tree (updates to fcoe and libfc)" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (81 commits) [SCSI] ufs: Separate PCI code into glue driver [SCSI] ufs: Segregate PCI Specific Code [SCSI] scsi: fix lpfc build when wmb() is defined as mb() [SCSI] storvsc: Handle dynamic resizing of the device [SCSI] storvsc: Restructure error handling code on command completion [SCSI] storvsc: avoid usage of WRITE_SAME [SCSI] aacraid: suppress two GCC warnings [SCSI] hpsa: check for dma_mapping_error in hpsa_passthru ioctls [SCSI] hpsa: reorganize error handling in hpsa_passthru_ioctl [SCSI] hpsa: check for dma_mapping_error in hpsa_map_sg_chain_block [SCSI] hpsa: Check for dma_mapping_error for all code paths using fill_cmd [SCSI] hpsa: Check for dma_mapping_error in hpsa_map_one [SCSI] dc395x: uninitialized variable in device_alloc() [SCSI] Fix range check in scsi_host_dif_capable() [SCSI] storvsc: Initialize the sglist [SCSI] mpt2sas: Add support for OEM specific controller [SCSI] ipr: Fix oops while resetting an ipr adapter [SCSI] fnic: Fnic Trace Utility [SCSI] fnic: New debug flags and debug log messages [SCSI] fnic: fnic driver may hit BUG_ON on device reset ...
2013-03-02x86, ACPI, mm: Revert movablemem_map supportYinghai Lu
Tim found: WARNING: at arch/x86/kernel/smpboot.c:324 topology_sane.isra.2+0x6f/0x80() Hardware name: S2600CP sched: CPU #1's llc-sibling CPU #0 is not on the same node! [node: 1 != 0]. Ignoring dependency. smpboot: Booting Node 1, Processors #1 Modules linked in: Pid: 0, comm: swapper/1 Not tainted 3.9.0-0-generic #1 Call Trace: set_cpu_sibling_map+0x279/0x449 start_secondary+0x11d/0x1e5 Don Morris reproduced on a HP z620 workstation, and bisected it to commit e8d195525809 ("acpi, memory-hotplug: parse SRAT before memblock is ready") It turns out movable_map has some problems, and it breaks several things 1. numa_init is called several times, NOT just for srat. so those nodes_clear(numa_nodes_parsed) memset(&numa_meminfo, 0, sizeof(numa_meminfo)) can not be just removed. Need to consider sequence is: numaq, srat, amd, dummy. and make fall back path working. 2. simply split acpi_numa_init to early_parse_srat. a. that early_parse_srat is NOT called for ia64, so you break ia64. b. for (i = 0; i < MAX_LOCAL_APIC; i++) set_apicid_to_node(i, NUMA_NO_NODE) still left in numa_init. So it will just clear result from early_parse_srat. it should be moved before that.... c. it breaks ACPI_TABLE_OVERIDE...as the acpi table scan is moved early before override from INITRD is settled. 3. that patch TITLE is total misleading, there is NO x86 in the title, but it changes critical x86 code. It caused x86 guys did not pay attention to find the problem early. Those patches really should be routed via tip/x86/mm. 4. after that commit, following range can not use movable ram: a. real_mode code.... well..funny, legacy Node0 [0,1M) could be hot-removed? b. initrd... it will be freed after booting, so it could be on movable... c. crashkernel for kdump...: looks like we can not put kdump kernel above 4G anymore. d. init_mem_mapping: can not put page table high anymore. e. initmem_init: vmemmap can not be high local node anymore. That is not good. If node is hotplugable, the mem related range like page table and vmemmap could be on the that node without problem and should be on that node. We have workaround patch that could fix some problems, but some can not be fixed. So just remove that offending commit and related ones including: f7210e6c4ac7 ("mm/memblock.c: use CONFIG_HAVE_MEMBLOCK_NODE_MAP to protect movablecore_map in memblock_overlaps_region().") 01a178a94e8e ("acpi, memory-hotplug: support getting hotplug info from SRAT") 27168d38fa20 ("acpi, memory-hotplug: extend movablemem_map ranges to the end of node") e8d195525809 ("acpi, memory-hotplug: parse SRAT before memblock is ready") fb06bc8e5f42 ("page_alloc: bootmem limit with movablecore_map") 42f47e27e761 ("page_alloc: make movablemem_map have higher priority") 6981ec31146c ("page_alloc: introduce zone_movable_limit[] to keep movable limit for nodes") 34b71f1e04fc ("page_alloc: add movable_memmap kernel parameter") 4d59a75125d5 ("x86: get pg_data_t's memory from other node") Later we should have patches that will make sure kernel put page table and vmemmap on local node ram instead of push them down to node0. Also need to find way to put other kernel used ram to local node ram. Reported-by: Tim Gardner <tim.gardner@canonical.com> Reported-by: Don Morris <don.morris@hp.com> Bisected-by: Don Morris <don.morris@hp.com> Tested-by: Don Morris <don.morris@hp.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Tejun Heo <tj@kernel.org> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-02Merge tag 'arc-v3.9-rc1-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull new ARC architecture from Vineet Gupta: "Initial ARC Linux port with some fixes on top for 3.9-rc1: I would like to introduce the Linux port to ARC Processors (from Synopsys) for 3.9-rc1. The patch-set has been discussed on the public lists since Nov and has received a fair bit of review, specially from Arnd, tglx, Al and other subsystem maintainers for DeviceTree, kgdb... The arch bits are in arch/arc, some asm-generic changes (acked by Arnd), a minor change to PARISC (acked by Helge). The series is a touch bigger for a new port for 2 main reasons: 1. It enables a basic kernel in first sub-series and adds ptrace/kgdb/.. later 2. Some of the fallout of review (DeviceTree support, multi-platform- image support) were added on top of orig series, primarily to record the revision history. This updated pull request additionally contains - fixes due to our GNU tools catching up with the new syscall/ptrace ABI - some (minor) cross-arch Kconfig updates." * tag 'arc-v3.9-rc1-late' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (82 commits) ARC: split elf.h into uapi and export it for userspace ARC: Fixup the current ABI version ARC: gdbserver using regset interface possibly broken ARC: Kconfig cleanup tracking cross-arch Kconfig pruning in merge window ARC: make a copy of flat DT ARC: [plat-arcfpga] DT arc-uart bindings change: "baud" => "current-speed" ARC: Ensure CONFIG_VIRT_TO_BUS is not enabled ARC: Fix pt_orig_r8 access ARC: [3.9] Fallout of hlist iterator update ARC: 64bit RTSC timestamp hardware issue ARC: Don't fiddle with non-existent caches ARC: Add self to MAINTAINERS ARC: Provide a default serial.h for uart drivers needing BASE_BAUD ARC: [plat-arcfpga] defconfig for fully loaded ARC Linux ARC: [Review] Multi-platform image #8: platform registers SMP callbacks ARC: [Review] Multi-platform image #7: SMP common code to use callbacks ARC: [Review] Multi-platform image #6: cpu-to-dma-addr optional ARC: [Review] Multi-platform image #5: NR_IRQS defined by ARC core ARC: [Review] Multi-platform image #4: Isolate platform headers ARC: [Review] Multi-platform image #3: switch to board callback ...
2013-03-02Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: o Add basic support for the Mediatek/Ralink Wireless SoC family. o The Qualcomm Atheros platform is extended by support for the new QCA955X SoC series as well as a bunch of patches that get the code ready for OF support. o Lantiq and BCM47XX platform have a few improvements and bug fixes. o MIPS has sent a few patches that get the kernel ready for the upcoming microMIPS support. o The rest of the series is made up of small bug fixes and cleanups that relate to various parts of the MIPS code. The biggy in there is a whitespace cleanup. After I was sent another set of whitespace cleanup patches I decided it was the time to clean the whitespace "issues" for once and and that touches many files below arch/mips/. Fix up silly conflicts, mostly due to whitespace cleanups. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (105 commits) MIPS: Quit exporting kernel internel break codes to uapi/asm/break.h MIPS: remove broken conditional inside vpe loader code MIPS: SMTC: fix implicit declaration of set_vi_handler MIPS: early_printk: drop __init annotations MIPS: Probe for and report hardware virtualization support. MIPS: ath79: add support for the Qualcomm Atheros AP136-010 board MIPS: ath79: add USB controller registration code for the QCA955X SoCs MIPS: ath79: add PCI controller registration code for the QCA955X SoCs MIPS: ath79: add WMAC registration code for the QCA955X SoCs MIPS: ath79: register UART for the QCA955X SoCs MIPS: ath79: add QCA955X specific glue to ath79_device_reset_{set, clear} MIPS: ath79: add GPIO setup code for the QCA955X SoCs MIPS: ath79: add IRQ handling code for the QCA955X SoCs MIPS: ath79: add clock setup code for the QCA955X SoCs MIPS: ath79: add SoC detection code for the QCA955X SoCs MIPS: ath79: add early printk support for the QCA955X SoCs MIPS: ath79: fix WMAC IRQ resource assignment mips: reserve elfcorehdr mips: Make sure kernel memory is in iomem MIPS: ath79: use dynamically allocated USB platform devices ...
