path: root/Documentation
2012-10-28dt: Document: correct tegra20/30 pinctrl slew-rate namePritesh Raithatha
commit d6ec6b60a56a1e7d99da1fc69c031fa5ab54ba94 upstream. change nvidia,slew_rate* to nvidia,slew-rate* Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28hwmon: (coretemp) Add support for Atom CE4110/4150/4170Guenter Roeck
commit 1102dcab849313bd5a340b299b5cf61b518fbc0f upstream. TjMax for the CE4100 series of Atom CPUs was previously reported to be 110 degrees C. cpuinfo logs on the web show existing CPU types CE4110, CE4150, and CE4170, reported as "model name : Intel(R) Atom(TM) CPU CE41{1|5|7}0 @ 1.{2|6}0GHz" with model 28 (0x1c) and stepping 10 (0x0a). Add the three known variants to the tjmax table. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-21vfio: Trivial Documentation correctionAlex Williamson
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
2012-09-10i2c-i801: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
Add the SMBus Device IDs for the Intel Lynx Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-09-06Merge tag '3.6-pci-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Power management - PCI/PM: Enable D3/D3cold by default for most devices - PCI/PM: Keep parent bridge active when probing device - PCI/PM: Fix config reg access for D3cold and bridge suspending - PCI/PM: Add ABI document for sysfs file d3cold_allowed Core - PCI: Don't print anything while decoding is disabled" * tag '3.6-pci-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Don't print anything while decoding is disabled PCI/PM: Add ABI document for sysfs file d3cold_allowed PCI/PM: Fix config reg access for D3cold and bridge suspending PCI/PM: Keep parent bridge active when probing device PCI/PM: Enable D3/D3cold by default for most devices
2012-09-06Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC bug fixes from Olof Johansson: "Mostly Renesas and Atmel bugfixes this time, targeting boot and build problems. A couple of patches for gemini and kirkwood as well. On a whole nothing very controversial." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: gemini: fix the gemini build ARM: shmobile: armadillo800eva: enable rw rootfs mount ARM: Kirkwood: Fix 'SZ_1M' undeclared here for db88f6281-bp-setup.c ARM: shmobile: mackerel: fixup usb module order ARM: shmobile: armadillo800eva: fixup: sound card detection order ARM: shmobile: marzen: fixup smsc911x id for regulator ARM: at91/feature-removal-schedule: delay at91_mci removal ARM: mach-shmobile: armadillo800eva: Enable power button as wakeup source ARM: mach-shmobile: armadillo800eva: Fix GPIO buttons descriptions ARM: at91/dts: remove partial parameter in at91sam9g25ek.dts ARM: at91/clock: fix PLLA overclock warning ARM: at91: fix rtc-at91sam9 irq issue due to sparse irq support ARM: at91: fix system timer irq issue due to sparse irq support ARM: shmobile: sh73a0: fixup RELOC_BASE of intca_irq_pins_desc
2012-08-29watchdog: fix watchdog-test.c build warningRandy Dunlap
Fix compiler warning by making the function static: Documentation/watchdog/src/watchdog-test.c:34:6: warning: no previous prototype for 'term' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-08-27Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesOlof Johansson
Fixes for AT91 related to: - move to sparse IRQ: some drivers were forgotten - a DTS typo - the delay for removal of old at91_mci driver * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91/feature-removal-schedule: delay at91_mci removal ARM: at91/dts: remove partial parameter in at91sam9g25ek.dts ARM: at91/clock: fix PLLA overclock warning ARM: at91: fix rtc-at91sam9 irq issue due to sparse irq support ARM: at91: fix system timer irq issue due to sparse irq support
2012-08-27ARM: at91/feature-removal-schedule: delay at91_mci removalLudovic Desroches
Delay sd/mmc driver at91_mci.c removal because of tight schedule to move platform data to new driver atmel-mci. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-08-25Merge tag 'fixes-3.6-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc fixes from Arnd Bergmann: "Bug fixes for various ARM platforms. About half of these are for OMAP and submitted before but did not make it into v3.6-rc2." * tag 'fixes-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits) ARM: ux500: don't select LEDS_GPIO for snowball ARM: imx: build i.MX6 functions only when needed ARM: imx: select CPU_FREQ_TABLE when needed ARM: imx: fix ksz9021rn_phy_fixup ARM: imx: build pm-imx5 code only when PM is enabled ARM: omap: allow building omap44xx without SMP ARM: dts: imx51-babbage: fix esdhc cd/wp properties ARM: imx6: spin the cpu until hardware takes it down ARM: ux500: Ensure probing of Audio devices when Device Tree is enabled ARM: ux500: Fix merge error, no matching driver name for 'snd_soc_u8500' ARM i.MX6q: Add virtual 1/3.5 dividers in the LDB clock path ARM: Kirkwood: fix Makefile.boot ARM: Kirkwood: Fix iconnect leds ARM: Orion: Set eth packet size csum offload limit ARM: mv78xx0: fix win_cfg_base prototype ARM: OMAP: dmtimers: Fix locking issue in omap_dm_timer_request*() ARM: mmp: fix potential NULL dereference ARM: OMAP4: Register the OPP table only for 4430 device cpufreq: OMAP: Handle missing frequency table on SMP systems ARM: OMAP4: sleep: Save the complete used register stack frame ...
2012-08-25Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block-related fixes from Jens Axboe: - Improvements to the buffered and direct write IO plugging from Fengguang. - Abstract out the mapping of a bio in a request, and use that to provide a blk_bio_map_sg() helper. Useful for mapping just a bio instead of a full request. - Regression fix from Hugh, fixing up a patch that went into the previous release cycle (and marked stable, too) attempting to prevent a loop in __getblk_slow(). - Updates to discard requests, fixing up the sizing and how we align them. Also a change to disallow merging of discard requests, since that doesn't really work properly yet. - A few drbd fixes. - Documentation updates. * 'for-linus' of git://git.kernel.dk/linux-block: block: replace __getblk_slow misfix by grow_dev_page fix drbd: Write all pages of the bitmap after an online resize drbd: Finish requests that completed while IO was frozen drbd: fix drbd wire compatibility for empty flushes Documentation: update tunable options in block/cfq-iosched.txt Documentation: update tunable options in block/cfq-iosched.txt Documentation: update missing index files in block/00-INDEX block: move down direct IO plugging block: remove plugging at buffered write time block: disable discard request merge temporarily bio: Fix potential memory leak in bio_find_or_create_slab() block: Don't use static to define "void *p" in show_partition_start() block: Add blk_bio_map_sg() helper block: Introduce __blk_segment_map_sg() helper fs/block-dev.c:fix performance regression in O_DIRECT writes to md block devices block: split discard into aligned requests block: reorganize rounding of max_discard_sectors
2012-08-23ARM: dts: imx51-babbage: fix esdhc cd/wp propertiesShawn Guo
The binding doc and dts use properties "fsl,{cd,wp}-internal" while esdhc driver uses "fsl,{cd,wp}-controller". Fix binding doc and dts to get them match driver code. Reported-by: Chris Ball <cjb@laptop.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: <stable@vger.kernel.org> Acked-by: Chris Ball <cjb@laptop.org>
2012-08-21Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge fixes from Andrew Morton. Random drivers and some VM fixes. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (17 commits) mm: compaction: Abort async compaction if locks are contended or taking too long mm: have order > 0 compaction start near a pageblock with free pages rapidio/tsi721: fix unused variable compiler warning rapidio/tsi721: fix inbound doorbell interrupt handling drivers/rtc/rtc-rs5c348.c: fix hour decoding in 12-hour mode mm: correct page->pfmemalloc to fix deactivate_slab regression drivers/rtc/rtc-pcf2123.c: initialize dynamic sysfs attributes mm/compaction.c: fix deferring compaction mistake drivers/misc/sgi-xp/xpc_uv.c: SGI XPC fails to load when cpu 0 is out of IRQ resources string: do not export memweight() to userspace hugetlb: update hugetlbpage.txt checkpatch: add control statement test to SINGLE_STATEMENT_DO_WHILE_MACRO mm: hugetlbfs: correctly populate shared pmd cciss: fix incorrect scsi status reporting Documentation: update mount option in filesystem/vfat.txt mm: change nr_ptes BUG_ON to WARN_ON cs5535-clockevt: typo, it's MFGPT, not MFPGT
2012-08-21Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "For bug fixes, at soc_camera, si470x, uvcvideo, iguanaworks IR driver, radio_shark Kbuild fixes, and at the V4L2 core (radio fixes)." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] media: soc_camera: don't clear pix->sizeimage in JPEG mode [media] media: mx2_camera: Fix clock handling for i.MX27 [media] video: mx2_camera: Use clk_prepare_enable/clk_disable_unprepare [media] video: mx1_camera: Use clk_prepare_enable/clk_disable_unprepare [media] media: mx3_camera: buf_init() add buffer state check [media] radio-shark2: Only compile led support when CONFIG_LED_CLASS is set [media] radio-shark: Only compile led support when CONFIG_LED_CLASS is set [media] radio-shark*: Call cancel_work_sync from disconnect rather then release [media] radio-shark*: Remove work-around for dangling pointer in usb intfdata [media] Add USB dependency for IguanaWorks USB IR Transceiver [media] Add missing logging for rangelow/high of hwseek [media] VIDIOC_ENUM_FREQ_BANDS fix [media] mem2mem_testdev: fix querycap regression [media] si470x: v4l2-compliance fixes [media] DocBook: Remove a spurious character [media] uvcvideo: Reset the bytesused field when recycling an erroneous buffer
2012-08-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking update from David Miller: "A couple weeks of bug fixing in there. The largest chunk is all the broken crap Amerigo Wang found in the netpoll layer." 1) netpoll and it's users has several serious bugs: a) uses GFP_KERNEL with locks held b) interfaces requiring interrupts disabled are called with them enabled c) and vice versa d) VLAN tag demuxing, as per all other RX packet input paths, is not applied All from Amerigo Wang. 2) Hopefully cure the ipv4 mapped ipv6 address TCP early demux bugs for good, from Neal Cardwell. 3) Unlike AF_UNIX, AF_PACKET sockets don't set a default credentials when the user doesn't specify one explicitly during sendmsg(). Instead we attach an empty (zero) SCM credential block which is definitely not what we want. Fix from Eric Dumazet. 4) IPv6 illegally invokes netdevice notifiers with RCU lock held, fix from Ben Hutchings. 5) inet_csk_route_child_sock() checks wrong inet options pointer, fix from Christoph Paasch. 6) When AF_PACKET is used for transmit, packet loopback doesn't behave properly when a socket fanout is enabled, from Eric Leblond. 7) On bluetooth l2cap channel create failure, we leak the socket, from Jaganath Kanakkassery. 8) Fix all the netprio file handling bugs found by Al Viro, from John Fastabend. 9) Several error return and NULL deref bug fixes in networking drivers from Julia Lawall. 10) A large smattering of struct padding et al. kernel memory leaks to userspace found of Mathias Krause. 11) Conntrack expections in netfilter can access an uninitialized timer, fix from Pablo Neira Ayuso. 12) Several netfilter SIP tracker bug fixes from Patrick McHardy. 13) IPSEC ipv6 routes are not initialized correctly all the time, resulting in an OOPS in inet_putpeer(). Also from Patrick McHardy. 14) Bridging does rcu_dereference() outside of RCU protected area, from Stephen Hemminger. 15) Fix routing cache removal performance regression when looking up output routes that have a local destination. From Zheng Yan. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) af_netlink: force credentials passing [CVE-2012-3520] ipv4: fix ip header ident selection in __ip_make_skb() ipv4: Use newinet->inet_opt in inet_csk_route_child_sock() tcp: fix possible socket refcount problem net: tcp: move sk_rx_dst_set call after tcp_create_openreq_child() net/core/dev.c: fix kernel-doc warning netconsole: remove a redundant netconsole_target_put() net: ipv6: fix oops in inet_putpeer() net/stmmac: fix issue of clk_get for Loongson1B. caif: Do not dereference NULL in chnl_recv_cb() af_packet: don't emit packet on orig fanout group drivers/net/irda: fix error return code drivers/net/wan/dscc4.c: fix error return code drivers/net/wimax/i2400m/fw.c: fix error return code smsc75xx: add missing entry to MAINTAINERS net: qmi_wwan: new devices: UML290 and K5006-Z net: sh_eth: Add eth support for R8A7779 device netdev/phy: skip disabled mdio-mux nodes dt: introduce for_each_available_child_of_node, of_get_next_available_child net: netprio: fix cgrp create and write priomap race ...
2012-08-21hugetlb: update hugetlbpage.txtZhouping Liu
Commit f0f57b2b1488 ("mm: move hugepage test examples to tools/testing/selftests/vm") moved map_hugetlb.c, hugepage-shm.c and hugepage-mmap.c tests into tools/testing/selftests/vm/ directory, but it didn't update hugetlbpage.txt Signed-off-by: Zhouping Liu <sanweidaying@gmail.com> Acked-by: Dave Young <dyoung@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-21Documentation: update mount option in filesystem/vfat.txtNamjae Jeon
Update two mount options(discard, nfs) in vfat.txt. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-21PCI/PM: Add ABI document for sysfs file d3cold_allowedHuang Ying
This patch adds ABI document for the following sysfs file: /sys/bus/pci/devices/.../d3cold_allowed Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-08-21Merge tag 'pinctrl-fixes-v3.6-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control fixes from Linus Walleij: - Fixed Nomadik errorpath - Fixed documentation spelling errors - Forward-declare struct device in a header file - Remove some extraneous code lines when getting pinctrl states - Correct the i.MX51 configure register number - Fix the Nomadik keypad function group list * tag 'pinctrl-fixes-v3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl/nomadik: add kp_b_2 keyboard function group list pinctrl: imx51: fix .conf_reg of MX51_PAD_SD2_CMD__CSPI_MOSI trivial: pinctrl core: remove extraneous code lines pinctrl: header: trivial: declare struct device Documentation/pinctrl.txt: Fix some misspelled macros pinctrl/nomadik: fix null in irqdomain errorpath
2012-08-20Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver update from Matthew Garrett: "Some small updates for a few drivers, and some hardware enablement for new Ideapads and the gmux hardware in the latest Macs. This code won't run on older devices and has been well tested on new ones, so low risk of regressions." * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: ideapad: add Lenovo IdeaPad Z570 support (part 3) ideapad: add Lenovo IdeaPad Z570 support (part 2) ideapad: add Lenovo IdeaPad Z570 support (part 1) classmate-laptop: always call input_sync() after input_report_switch() thinkpad-acpi: recognize latest V-Series using DMI_BIOS_VENDOR dell-laptop: Fixed typo in touchpad LED quirk vga_switcheroo: Don't require handler init callback vga_switcheroo: Remove assumptions about registration/unregistration ordering apple-gmux: Add display mux support apple-gmux: Fix kconfig dependencies asus-wmi: record wlan status while controlled by userapp apple_gmux: Fix ACPI video unregister apple_gmux: Add support for newer hardware gmux: Add generic write32 function
2012-08-20Merge tag 'regulator-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "A bunch of fixes which are a combination of minor fixes that have been shaken down due to greater testing exposure, the biggest block of which are for the Palmas driver which hadn't had all the changes required for mainline properly tested when it was merged." * tag 'regulator-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: twl-regulator: fix up VINTANA1/VINTANA2 regulator: core: request only valid gpio pins for regulator enable regulator: twl: Remove references to the twl4030 regulator regulator: gpio-regulator: Split setting of voltages and currents regulator: ab3100: add missing voltage table regulator: anatop: Fix wrong mask used in anatop_get_voltage_sel regulator: tps6586x: correct vin pin for sm0/sm1/sm2 regulator: palmas: Fix palmas_probe error handling regulator: palmas: Call palmas_ldo_[read|write] in palmas_ldo_init regulator: palmas: Fix regmap offsets for PALMAS_REG_SMPS10 vsel_reg regulator: palmas: Fix calculating selector in palmas_map_voltage_ldo
2012-08-20ideapad: add Lenovo IdeaPad Z570 support (part 3)Maxim Mikityanskiy
The patch adds support for Lenovo IdeaPad Z570 laptop. It makes all special keys working, adds possibility to control fan like Windows does, controls Touchpad Disabled LED, toggles touchpad state via keyboard controller and corrects touchpad behavior on resume from suspend. It is new, modified version of patch. Now it does not depend on psmouse and does not need patching of input subsystem. Signed-off-by: Maxim Mikityanskiy <maxtram95@gmail.com> This is the part 3 for fan control Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2012-08-17Merge tag 'char-misc-3.6-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull Char / Misc driver fixes from Greg Kroah-Hartman: "Here are some small misc and w1 driver fixes for 3.6-rc3. Nothing major, just some some bugfixes and a new device id for a w1 driver. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'char-misc-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: 1-Wire: Add support for the maxim ds1825 temperature sensor ti-st: Fix check for pdata->chip_awake function pointer mei: add mei_quirk_probe function mei: fix device stall after wd is stopped
2012-08-17Documentation/pinctrl.txt: Fix some misspelled macrosDaniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-08-161-Wire: Add support for the maxim ds1825 temperature sensorRaphael Assenat
This patch adds support for maxim ds1825 based 1-wire temperature sensors. Signed-off-by: Raphael Assenat <raph@8d.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-14netconsole.txt: revision of examples for the receiver of kernel messagesDirk Gouders
There are at least 4 implementations of netcat with the BSD-based being the only one that has to be used without the -p switch to specify the listening port. Jan Engelhardt suggested to add an example for socat(1). Signed-off-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-11[media] DocBook: Remove a spurious characterHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-10Yama: higher restrictions should block PTRACE_TRACEMEKees Cook
The higher ptrace restriction levels should be blocking even PTRACE_TRACEME requests. The comments in the LSM documentation are misleading about when the checks happen (the parent does not go through security_ptrace_access_check() on a PTRACE_TRACEME call). Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org # 3.5.x and later Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-08-09Documentation: update tunable options in block/cfq-iosched.txtNamjae Jeon
Update tunable options in block/cfq-iosched.txt. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-09Documentation: update missing index files in block/00-INDEXNamjae Jeon
Update missing index files in block/00-INDEX. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-07regulator: tps6586x: correct vin pin for sm0/sm1/sm2Laxman Dewangan
As per datasheet, the vin pin for the regulator is named as vin_sm0, vin_sm1, vin_sm2 for sm0, sm1 and sm2 respectively. Correcting the names in driver and documentation to match with datasheet. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reported-by: Stephen Warren <swarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-04Documentation: fix the VM knobs descritpion WRT pdflushArtem Bityutskiy
The pdflush thread is long gone, however we still mention it incorrectly in the kernel documentation. This patch fixes the situation. Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-04Documentation: get rid of write_superArtem Bityutskiy
The '->write_super' superblock method is gone, and this patch removes all the references to 'write_super' from various pieces of the kernel documentation. Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-02Merge tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc Marvell Orion device-tree updates from Olof Johansson: "This contains a set of device-tree conversions for Marvell Orion platforms that were staged early but took a few tries to get the branch into a format where it was suitable for us to pick up. Given that most people working on these platforms are hobbyists with limited time, we were a bit more flexible with merging it even though it came in late." * tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits) ARM: Kirkwood: Replace mrvl with marvell ARM: Kirkwood: Describe GoFlex Net LEDs and SATA in DT. ARM: Kirkwood: Describe Dreamplug LEDs in DT. ARM: Kirkwood: Describe iConnects LEDs in DT. ARM: Kirkwood: Describe iConnects temperature sensor in DT. ARM: Kirkwood: Describe IB62x0 LEDs in DT. ARM: Kirkwood: Describe IB62x0 gpio-keys in DT. ARM: Kirkwood: Describe DNS32? gpio-keys in DT. ARM: Kirkwood: Move common portions into a kirkwood-dnskw.dtsi ARM: Kirkwood: Replace DNS-320/DNS-325 leds with dt bindings ARM: Kirkwood: Describe DNS325 temperature sensor in DT. ARM: Kirkwood: Use DT to configure SATA device. ARM: kirkwood: use devicetree for SPI on dreamplug ARM: kirkwood: Add LS-XHL and LS-CHLv2 support ARM: Kirkwood: Initial DTS support for Kirkwood GoFlex Net ARM: Kirkwood: Add basic device tree support for QNAP TS219. ATA: sata_mv: Add device tree support ARM: Orion: DTify the watchdog timer. ARM: Orion: Add arch support needed for I2C via DT. ARM: kirkwood: use devicetree for orion-spi ... Conflicts: drivers/watchdog/orion_wdt.c
2012-08-01Merge branch 'dmaengine' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM DMA engine updates from Russell King: "This looks scary at first glance, but what it is is: - a rework of the sa11x0 DMA engine driver merged during the previous cycle, to extract a common set of helper functions for DMA engine implementations. - conversion of amba-pl08x.c to use these helper functions. - addition of OMAP DMA engine driver (using these helper functions), and conversion of some of the OMAP DMA users to use DMA engine. Nothing in the helper functions is ARM specific, so I hope that other implementations can consolidate some of their code by making use of these helpers. This has been sitting in linux-next most of the merge cycle, and has been tested by several OMAP folk. I've tested it on sa11x0 platforms, and given it my best shot on my broken platforms which have the amba-pl08x controller. The last point is the addition to feature-removal-schedule.txt, which will have a merge conflict. Between myself and TI, we're planning to remove the old TI DMA implementation next year." Fix up trivial add/add conflicts in Documentation/feature-removal-schedule.txt and drivers/dma/{Kconfig,Makefile} * 'dmaengine' of git://git.linaro.org/people/rmk/linux-arm: (53 commits) ARM: 7481/1: OMAP2+: omap2plus_defconfig: enable OMAP DMA engine ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel request fails Add feature removal of old OMAP private DMA implementation mtd: omap2: remove private DMA API implementation mtd: omap2: add DMA engine support spi: omap2-mcspi: remove private DMA API implementation spi: omap2-mcspi: add DMA engine support ARM: omap: remove mmc platform data dma_mask and initialization mmc: omap: remove private DMA API implementation mmc: omap: add DMA engine support mmc: omap_hsmmc: remove private DMA API implementation mmc: omap_hsmmc: add DMA engine support dmaengine: omap: add support for cyclic DMA dmaengine: omap: add support for setting fi dmaengine: omap: add support for returning residue in tx_state method dmaengine: add OMAP DMA engine driver dmaengine: sa11x0-dma: add cyclic DMA support dmaengine: sa11x0-dma: fix DMA residue support dmaengine: PL08x: ensure all descriptors are freed when channel is released dmaengine: PL08x: get rid of write only pool_ctr and free_txd locking ...
2012-08-01Merge tag 'fbdev-updates-for-3.6' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: - large updates for OMAP - support for LCD3 overlay manager (omap5) - omapdss output cleanup - removal of passive matrix LCD support as there are no drivers for such panels for DSS or DSS2 and nobody complained (cleanup) - large updates for SH Mobile - overlay support - separating MERAM (cache) from framebuffer driver - some updates for Exynos and da8xx-fb - various other small patches * tag 'fbdev-updates-for-3.6' of git://github.com/schandinat/linux-2.6: (78 commits) da8xx-fb: fix compile issue due to missing include fbdev: Make pixel_to_pat() failure mode more friendly da8xx-fb: do not turn ON LCD backlight unless LCDC is enabled fbdev: sh_mobile_lcdc: Fix vertical panning step video: exynos mipi dsi: Fix mipi dsi regulators handling issue video: da8xx-fb: do clock reset of revision 2 LCDC before enabling arm: da850: configure LCDC fifo threshold video: da8xx-fb: configure FIFO threshold to reduce underflow errors video: da8xx-fb: fix flicker due to 1 frame delay in updated frame video: da8xx-fb rev2: fix disabling of palette completion interrupt da8xx-fb: add missing FB_BLANK operations video: exynos_dp: use usleep_range instead of delay video: exynos_dp: check the only INTERLANE_ALIGN_DONE bit during Link Training fb: epson1355fb: Fix section mismatch video: exynos_dp: fix wrong DPCD address during Link Training video/smscufx: fix line counting in fb_write aty128fb: Fix coding style issues fbdev: sh_mobile_lcdc: Fix pan offset computation in YUV mode fbdev: sh_mobile_lcdc: Fix overlay registers update during pan operation fbdev: sh_mobile_lcdc: Support horizontal panning ...
2012-08-01Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A collection of small fixes that have been found recently. Most of the commits are regression fixes in HD-audio and some other random drivers." * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: snd-usb: fix clock source validity index ALSA: hda - Fix mute-LED GPIO initialization for IDT codecs ALSA: hda - Add descriptions for missing IDT 92HD83x models ALSA: hda - Fix polarity of mute LED on HP Mini 210 ALSA: es1688 - freeup resources on init failure ALSA: hda - Workaround for silent output on VAIO Z with ALC889 ALSA: hda - Fix WARNING from HDMI/DP parser ALSA: hda - Detach from converter at closing in patch_hdmi.c ALSA: hda - Fix mute-LED GPIO setup for HP Mini 210 ALSA: mpu401: Fix missing initialization of irq field ALSA: hda - Fix invalid D3 of headphone DAC on VT202x codecs
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-08-01Merge branch 'for-3.6/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO bits from Jens Axboe: "The most complicated part if this is the request allocation rework by Tejun, which has been queued up for a long time and has been in for-next ditto as well. There are a few commits from yesterday and today, mostly trivial and obvious fixes. So I'm pretty confident that it is sound. It's also smaller than usual." * 'for-3.6/core' of git://git.kernel.dk/linux-block: block: remove dead func declaration block: add partition resize function to blkpg ioctl block: uninitialized ioc->nr_tasks triggers WARN_ON block: do not artificially constrain max_sectors for stacking drivers blkcg: implement per-blkg request allocation block: prepare for multiple request_lists block: add q->nr_rqs[] and move q->rq.elvpriv to q->nr_rqs_elvpriv blkcg: inline bio_blkcg() and friends block: allocate io_context upfront block: refactor get_request[_wait]() block: drop custom queue draining used by scsi_transport_{iscsi|fc} mempool: add @gfp_mask to mempool_create_node() blkcg: make root blkcg allocation use %GFP_KERNEL blkcg: __blkg_lookup_create() doesn't need radix preload
2012-08-01Merge branch 'for-next' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from NeilBrown. * 'for-next' of git://neil.brown.name/md: DM RAID: Add support for MD RAID10 md/RAID1: Add missing case for attempting to repair known bad blocks. md/raid5: For odirect-write performance, do not set STRIPE_PREREAD_ACTIVE. md/raid1: don't abort a resync on the first badblock. md: remove duplicated test on ->openers when calling do_md_stop() raid5: Add R5_ReadNoMerge flag which prevent bio from merging at block layer md/raid1: prevent merging too large request md/raid1: read balance chooses idlest disk for SSD md/raid1: make sequential read detection per disk based MD RAID10: Export md_raid10_congested MD: Move macros from raid1*.h to raid1*.c MD RAID1: rename mirror_info structure MD RAID10: rename mirror_info structure MD RAID10: Fix compiler warning. raid5: add a per-stripe lock raid5: remove unnecessary bitmap write optimization raid5: lockless access raid5 overrided bi_phys_segments raid5: reduce chance release_stripe() taking device_lock
2012-08-01locks: remove unused lm_release_privateJ. Bruce Fields
In commit 3b6e2723f32d ("locks: prevent side-effects of locks_release_private before file_lock is initialized") we removed the last user of lm_release_private without removing the field itself. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-01DM RAID: Add support for MD RAID10Jonathan Brassow
Support the MD RAID10 personality through dm-raid.c Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-07-31Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irqdomain changes from Grant Likely: "Round of refactoring and enhancements to irq_domain infrastructure. This series starts the process of simplifying irqdomain. The ultimate goal is to merge LEGACY, LINEAR and TREE mappings into a single system, but had to back off from that after some last minute bugs. Instead it mainly reorganizes the code and ensures that the reverse map gets populated when the irq is mapped instead of the first time it is looked up. Merging of the irq_domain types is deferred to v3.7 In other news, this series adds helpers for creating static mappings on a linear or tree mapping." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: irqdomain: Improve diagnostics when a domain mapping fails irqdomain: eliminate slow-path revmap lookups irqdomain: Fix irq_create_direct_mapping() to test irq_domain type. irqdomain: Eliminate dedicated radix lookup functions irqdomain: Support for static IRQ mapping and association. irqdomain: Always update revmap when setting up a virq irqdomain: Split disassociating code into separate function irq_domain: correct a minor wrong comment for linear revmap irq_domain: Standardise legacy/linear domain selection irqdomain: Make ops->map hook optional irqdomain: Remove unnecessary test for IRQ_DOMAIN_MAP_LEGACY irqdomain: Simple NUMA awareness. devicetree: add helper inline for retrieving a node's full name
2012-07-31Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's second set of patches: - MM - a few random fixes - a couple of RTC leftovers * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits) rtc/rtc-88pm80x: remove unneed devm_kfree rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables tmpfs: distribute interleave better across nodes mm: remove redundant initialization mm: warn if pg_data_t isn't initialized with zero mips: zero out pg_data_t when it's allocated memcg: gix memory accounting scalability in shrink_page_list mm/sparse: remove index_init_lock mm/sparse: more checks on mem_section number mm/sparse: optimize sparse_index_alloc memcg: add mem_cgroup_from_css() helper memcg: further prevent OOM with too many dirty pages memcg: prevent OOM with too many dirty pages mm: mmu_notifier: fix freed page still mapped in secondary MMU mm: memcg: only check anon swapin page charges for swap cache mm: memcg: only check swap cache pages for repeated charging mm: memcg: split swapin charge function into private and public part mm: memcg: remove needless !mm fixup to init_mm when charging mm: memcg: remove unneeded shmem charge type ...
2012-07-31Merge tag 'vfio-for-v3.6' of git://github.com/awilliam/linux-vfioLinus Torvalds
Pull VFIO core from Alex Williamson: "This series includes the VFIO userspace driver interface for the 3.6 kernel merge window. This driver is intended to provide a secure interface for device access using IOMMU protection for applications like assignment of physical devices to virtual machines. Qemu will be the first user of this interface, enabling assignment of PCI devices to Qemu guests. This interface is intended to eventually replace the x86-specific assignment mechanism currently available in KVM. This interface has the advantage of being more secure, by working with IOMMU groups to ensure device isolation and providing it's own filtered resource access mechanism, and also more flexible, in not being x86 or KVM specific (extensions to enable POWER are already working). This driver is originally the work of Tom Lyon, but has since been handed over to me and gone through a complete overhaul thanks to the input from David Gibson, Ben Herrenschmidt, Chris Wright, Joerg Roedel, and others. This driver has been available in linux-next for the last month." Paul Mackerras says: "I would be glad to see it go in since we want to use it with KVM on PowerPC. If possible we'd like the PowerPC bits for it to go in as well." * tag 'vfio-for-v3.6' of git://github.com/awilliam/linux-vfio: vfio: Add PCI device driver vfio: Type1 IOMMU implementation vfio: Add documentation vfio: VFIO core
2012-07-31Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random subsystem patches from Ted Ts'o: "This patch series contains a major revamp of how we collect entropy from interrupts for /dev/random and /dev/urandom. The goal is to addresses weaknesses discussed in the paper "Mining your Ps and Qs: Detection of Widespread Weak Keys in Network Devices", by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman, which will be published in the Proceedings of the 21st Usenix Security Symposium, August 2012. (See https://factorable.net for more information and an extended version of the paper.)" Fix up trivial conflicts due to nearby changes in drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c} * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits) random: mix in architectural randomness in extract_buf() dmi: Feed DMI table to /dev/random driver random: Add comment to random_initialize() random: final removal of IRQF_SAMPLE_RANDOM um: remove IRQF_SAMPLE_RANDOM which is now a no-op sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op [ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op ...
2012-07-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull second set of media updates from Mauro Carvalho Chehab: - radio API: add support to work with radio frequency bands - new AM/FM radio drivers: radio-shark, radio-shark2 - new Remote Controller USB driver: iguanair - conversion of several drivers to the v4l2 core control framework - new board additions at existing drivers - the remaining (and vast majority of the patches) are due to drivers/DocBook fixes/cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits) [media] radio-tea5777: use library for 64bits div [media] tlg2300: Declare MODULE_FIRMWARE usage [media] lgs8gxx: Declare MODULE_FIRMWARE usage [media] xc5000: Add MODULE_FIRMWARE statements [media] s2255drv: Add MODULE_FIRMWARE statement [media] dib8000: move dereference after check for NULL [media] Documentation: Update cardlists [media] bttv: add support for Aposonic W-DVR [media] cx25821: Remove bad strcpy to read-only char* [media] pms.c: remove duplicated include [media] smiapp-core.c: remove duplicated include [media] via-camera: pass correct format settings to sensor [media] rtl2832.c: minor cleanup [media] Add support for the IguanaWorks USB IR Transceiver [media] Minor cleanups for MCE USB [media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry [media] Use a named union in struct v4l2_ioctl_info [media] mceusb: Add Twisted Melon USB IDs [media] staging/media/solo6x10: use module_pci_driver macro [media] staging/media/dt3155v4l: use module_pci_driver macro ... Conflicts: Documentation/feature-removal-schedule.txt
2012-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking update from David S. Miller: "I think Eric Dumazet and I have dealt with all of the known routing cache removal fallout. Some other minor fixes all around. 1) Fix RCU of cached routes, particular of output routes which require liberation via call_rcu() instead of call_rcu_bh(). From Eric Dumazet. 2) Make sure we purge net device references in cached routes properly. 3) TG3 driver bug fixes from Michael Chan. 4) Fix reported 'expires' value in ipv6 routes, from Li Wei. 5) TUN driver ioctl leaks kernel bytes to userspace, from Mathias Krause." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (22 commits) ipv4: Properly purge netdev references on uncached routes. ipv4: Cache routes in nexthop exception entries. ipv4: percpu nh_rth_output cache ipv4: Restore old dst_free() behavior. bridge: make port attributes const ipv4: remove rt_cache_rebuild_count net: ipv4: fix RCU races on dst refcounts net: TCP early demux cleanup tun: Fix formatting. net/tun: fix ioctl() based info leaks tg3: Update version to 3.124 tg3: Fix race condition in tg3_get_stats64() tg3: Add New 5719 Read DMA workaround tg3: Fix Read DMA workaround for 5719 A0. tg3: Request APE_LOCK_PHY before PHY access ipv6: fix incorrect route 'expires' value passed to userspace mISDN: Bugfix only few bytes are transfered on a connection seeq: use PTR_RET at init_module of driver bnx2x: remove cast around the kmalloc in bnx2x_prev_mark_path ipv4: clean up put_child ...
2012-07-31mm: add support for a filesystem to activate swap files and use direct_IO ↵Mel Gorman
for writing swap pages Currently swapfiles are managed entirely by the core VM by using ->bmap to allocate space and write to the blocks directly. This effectively ensures that the underlying blocks are allocated and avoids the need for the swap subsystem to locate what physical blocks store offsets within a file. If the swap subsystem is to use the filesystem information to locate the blocks, it is critical that information such as block groups, block bitmaps and the block descriptor table that map the swap file were resident in memory. This patch adds address_space_operations that the VM can call when activating or deactivating swap backed by a file. int swap_activate(struct file *); int swap_deactivate(struct file *); The ->swap_activate() method is used to communicate to the file that the VM relies on it, and the address_space should take adequate measures such as reserving space in the underlying device, reserving memory for mempools and pinning information such as the block descriptor table in memory. The ->swap_deactivate() method is called on sys_swapoff() if ->swap_activate() returned success. After a successful swapfile ->swap_activate, the swapfile is marked SWP_FILE and swapper_space.a_ops will proxy to sis->swap_file->f_mappings->a_ops using ->direct_io to write swapcache pages and ->readpage to read. It is perfectly possible that direct_IO be used to read the swap pages but it is an unnecessary complication. Similarly, it is possible that ->writepage be used instead of direct_io to write the pages but filesystem developers have stated that calling writepage from the VM is undesirable for a variety of reasons and using direct_IO opens up the possibility of writing back batches of swap pages in the future. [a.p.zijlstra@chello.nl: Original patch] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: David S. Miller <davem@davemloft.net> Cc: Eric B Munson <emunson@mgebm.net> Cc: Eric Paris <eparis@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Neil Brown <neilb@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
