commit a2fd6419174470f5ae6383f5037d0ee21ed9833f upstream.
Both the PowerPC hypervisor and Xen hypervisor can utilize the
hvc driver.
Cc: Greg KH <gregkh@linuxfoundation.org>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1361825650-14031-3-git-send-email-konrad.wilk@oracle.com
commit 2482a92e7d17187301d7313cfe5021b13393a0b4 upstream.
The earlyprintk for Xen PV guests utilizes a simple hypercall
(console_io) to provide output to Xen emergency console.
Note that the Xen hypervisor should be booted with 'loglevel=all'
to output said information.
Reported-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1361825650-14031-2-git-send-email-konrad.wilk@oracle.com
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ]
Implement the RFC 5691 mitigation against Blind
Reset attack using RST bit.
Idea is to validate incoming RST sequence,
to match RCV.NXT value, instead of previouly accepted
window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND)
If sequence is in window but not an exact match, send
a "challenge ACK", so that the other part can resend an
RST with the appropriate sequence.
Add a new sysctl, tcp_challenge_ack_limit, to limit
number of challenge ACK sent per second.
Add a new SNMP counter to count number of challenge acks sent.
(netstat -s | grep TCPChallengeACK)
Cc: Kiran Kumar Kella <kkiran@broadcom.com>
commit 1102dcab849313bd5a340b299b5cf61b518fbc0f upstream.
TjMax for the CE4100 series of Atom CPUs was previously reported to be
110 degrees C.
cpuinfo logs on the web show existing CPU types CE4110, CE4150, and CE4170,
reported as "model name : Intel(R) Atom(TM) CPU CE41{1|5|7}0 @ 1.{2|6}0GHz"
with model 28 (0x1c) and stepping 10 (0x0a). Add the three known variants
to the tjmax table.
Acked-by: Jean Delvare <khali@linux-fr.org>
commit 5592906f8b01282ea3c2acaf641fd067ad4bb3dc upstream.
Document the Atom series D2000 and N2000 (Cedar Trail) as being supported.
List and set TjMax for those series.
Cc: "R, Durgadoss" <durgadoss.r@intel.com>
commit fcc14ac1a86931f38da047cf8fb634c6db7b58bc upstream.
Document the new Atom series (Tunnel Creek and Medfield) as being
supported, and list TjMax for the Atom E600 series.
Also enable the Atom tjmax heuristic for these Atom CPU models.
Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Alexander Stein <alexander.stein@systec-electronic.com>
commit 25ec43d3e6306978cf66060ed18c4160ce8fc302 upstream.
The previous website doesn't exist anymore. Update it to one site that
actually exists.
commit 9a5a8f19b43430752067ecaee62fc59e11e88fa6 upstream.
oom_badness() takes a totalpages argument which says how many pages are
available and it uses it as a base for the score calculation. The value
is calculated by mem_cgroup_get_limit which considers both limit and
total_swap_pages (resp. memsw portion of it).
This is usually correct but since fe35004fbf9e ("mm: avoid swapping out
with swappiness==0") we do not swap when swappiness is 0 which means
that we cannot really use up all the totalpages pages. This in turn
confuses oom score calculation if the memcg limit is much smaller than
the available swap because the used memory (capped by the limit) is
negligible comparing to totalpages so the resulting score is too small
if adj!=0 (typically task with CAP_SYS_ADMIN or non zero oom_score_adj).
A wrong process might be selected as result.
The problem can be worked around by checking mem_cgroup_swappiness==0
and not considering swap at all in such a case.
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit f6365201d8a21fb347260f89d6e9b3e718d63c70 upstream.
The X86_32-only disable_hlt/enable_hlt mechanism was used by the
32-bit floppy driver. Its effect was to replace the use of the
HLT instruction inside default_idle() with cpu_relax() - essentially
it turned off the use of HLT.
This workaround was commented in the code as:
"disable hlt during certain critical i/o operations"
"This halt magic was a workaround for ancient floppy DMA
wreckage. It should be safe to remove."
H. Peter Anvin additionally adds:
"To the best of my knowledge, no-hlt only existed because of
flaky power distributions on 386/486 systems which were sold to
run DOS. Since DOS did no power management of any kind,
including HLT, the power draw was fairly uniform; when exposed
to the much hhigher noise levels you got when Linux used HLT
caused some of these systems to fail.
They were by far in the minority even back then."
Alan Cox further says:
"Also for the Cyrix 5510 which tended to go castors up if a HLT
occurred during a DMA cycle and on a few other boxes HLT during
DMA tended to go astray.
Do we care ? I doubt it. The 5510 was pretty obscure, the 5520
fixed it, the 5530 is probably the oldest still in any kind of
use."
So, let's finally drop this.
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Stephen Hemminger <shemminger@vyatta.com
Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org
[ If anyone cares then alternative instruction patching could be
used to replace HLT with a one-byte NOP instruction. Much simpler. ]
[bwh: Backported to 3.2: adjust filename, context]
commit ca16f580a5db7e60bfafe59a50bb133bd3347491 upstream.
We usually got away with ->next on the final entry being NULL, but it
finally bit me.
[bwh: Backported to 3.2: adjust filename]
commit 4a8f1ddde942e232387e6129ce4f4c412e43802f upstream.
Add the SMBus Device IDs for the Intel Lynx Point-LP PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit 062737fb6d90c632439b1f77ad6a4965cfc84a20 upstream.
Add the SMBus controller device IDs for the Intel Lynx Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
commit a46d2619d7180bda12bad2bf15bbd0731dfc2dcf upstream.
The binding doc and dts use properties "fsl,{cd,wp}-internal" while
esdhc driver uses "fsl,{cd,wp}-controller". Fix binding doc and dts
to get them match driver code.
Reported-by: Chris Ball <cjb@laptop.org>
Acked-by: Chris Ball <cjb@laptop.org>
commit 108cc108a3bb42fe4705df1317ff98e1e29428a6 upstream.
Also add a model/fixup string "lenovo-dock", so that other Thinkpad
users will be able to test this fixup easily, to see if it enables
dock I/O for them as well.
BugLink: https://bugs.launchpad.net/bugs/1026953
Tested-by: John McCarron <john.mccarron@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 2584f5212d97b664be250ad5700a2d0fee31a10d upstream.
Also add information on where the respective trees are.
Acked-by: Rob Landley <rob@landley.net>
commit eb3979f64d25120d60b9e761a4c58f70b1a02f86 upstream.
Distribution kernel maintainers routinely backport fixes for users that
were deemed important but not "something critical" as defined by the
rules. To users of these kernels they are very serious and failing to fix
them reduces the value of -stable.
The problem is that the patches fixing these issues are often subtle and
prone to regressions in other ways and need greater care and attention.
To combat this, these "serious" backports should have a higher barrier
to entry.
This patch relaxes the rules to allow a distribution maintainer to merge
to -stable a backported patch or small series that fixes a "serious"
user-visible performance issue. They should include additional information on
the user-visible bug affected and a link to the bugzilla entry if available.
The same rules about the patch being already in mainline still apply.
commit 591bfc6bf9e5e25e464fd4c87d64afd5135667c4 upstream.
The HOWTO document needed updating for the new kernel versioning. The
git URI for -next was updated as well.
[ Upstream commit b49960a05e32121d29316cfdf653894b88ac9190 ]
tcp_adv_win_scale default value is 2, meaning we expect a good citizen
skb to have skb->len / skb->truesize ratio of 75% (3/4)
In 2.6 kernels we (mis)accounted for typical MSS=1460 frame :
1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392.
So these skbs were considered as not bloated.
With recent truesize fixes, a typical MSS=1460 frame truesize is now the
more precise :
2048 + 256 = 2304. But 2304 * 3/4 = 1728.
So these skb are not good citizen anymore, because 1460 < 1728
(GRO can escape this problem because it build skbs with a too low
truesize.)
This also means tcp advertises a too optimistic window for a given
allocated rcvspace : When receiving frames, sk_rmem_alloc can hit
sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often,
especially when application is slow to drain its receive queue or in
case of losses (netperf is fast, scp is slow). This is a major latency
source.
We should adjust the len/truesize ratio to 50% instead of 75%
This patch :
1) changes tcp_adv_win_scale default to 1 instead of 2
2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account
better truesize tracking and to allow autotuning tcp receive window to
reach same value than before. Note that same amount of kernel memory is
consumed compared to 2.6 kernels.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
commit fecfb64422d91a9621a3f96ab75c3a5f13e80b58 upstream.
Intersil reports that all chips supported by the zl6100 driver require
an interval between chip accesses, even ZL2004 and ZL6105 which were thought
to be safe.
Reported-by: Vivek Gani <vgani@intersil.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit aacb6b0052692c72fe0cb94c6b547202def6ef46 upstream.
Properly set the source of temp2 for the W83627UHG. Also fix a
comment right before that, and document the W83627UHG as reporting up
to 3 temperatures.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
commit 1bd612a25855f4cc9345052b53d7da697dba6358 upstream.
Also update IDT datasheet locations.
commit 4de86126a712ba83fa038d277c8282f7ed466a4b upstream.
These are fully compatible with Jedec JC 42.4 as far as I can see.
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream.
The documentation for usbmon is out of date; the usbfs "devices" file
now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This
patch (as1505) updates the documentation accordingly, and also
mentions that the necessary information can be found by running lsusb.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Pete Zaitcev <zaitcev@redhat.com>
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream.
The Japanese/Korean/Chinese versions still need updating.
Also, the stable kernel 2.6.x.y descriptions are out of date
and should be updated as well.
Unlike all of the other cpuid bits, the TSC deadline timer bit is set
unconditionally, regardless of what userspace wants.
This is broken in several ways:
- if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC
deadline timer feature, a guest that uses the feature will break
- live migration to older host kernels that don't support the TSC deadline
timer will cause the feature to be pulled from under the guest's feet;
breaking it
- guests that are broken wrt the feature will fail.
Fix by not enabling the feature automatically; instead report it to userspace.
Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee
will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not
KVM_GET_SUPPORTED_CPUID.
Fixes the Illumos guest kernel, which uses the TSC deadline timer feature.
[avi: add the KVM_CAP + documentation]
Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Only allow KVM device assignment to attach to devices which:
- Are not bridges
- Have BAR resources (assume others are special devices)
- The user has permissions to use
Assigning a bridge is a configuration error, it's not supported, and
typically doesn't result in the behavior the user is expecting anyway.
Devices without BAR resources are typically chipset components that
also don't have host drivers. We don't want users to hold such devices
captive or cause system problems by fencing them off into an iommu
domain. We determine "permission to use" by testing whether the user
has access to the PCI sysfs resource files. By default a normal user
will not have access to these files, so it provides a good indication
that an administration agent has granted the user access to the device.
[Yang Bai: add missing #include]
[avi: fix comment style]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Yang Bai <hamo.by@gmail.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This option has no users and it exposes a security hole that we
can allow devices to be assigned without iommu protection. Make
KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: add missing spin_unlock at ceph_mdsc_build_path()
ceph: fix SEEK_CUR, SEEK_SET regression
crush: fix mapping calculation when force argument doesn't exist
ceph: use i_ceph_lock instead of i_lock
rbd: remove buggy rollback functionality
rbd: return an error when an invalid header is read
ceph: fix rasize reporting by ceph_show_options
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
* 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
MAINTAINERS: Update amd-iommu F: patterns
iommu/amd: Fix typo in kernel-parameters.txt
iommu/msm: Fix compile error in mach-msm/devices-iommu.c
Fix comparison using wrong pointer variable in dma debug code
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda/realtek - Fix lost speaker volume controls
ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins
ALSA: hda/realtek - Don't create extra controls with channel suffix
ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes
ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs
ASoC: Provide a more complete DMA driver stub
ASoC: Remove references to corgi and spitz from machine driver document
ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C
ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700
ASoC: uda1380: Return proper error in uda1380_modinit failure path
ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C
ASoC: Mark WM8994 ADC muxes as virtual
ALSA: hda/realtek - Fix Oops in alc_mux_select()
ALSA: sis7019 - give slow codecs more time to reset
This doesn't interact with resizing well, since it doesn't set the
size of the device to the size at the snapshot. It's also an expensive
operation to be synchronous. Rollback can still be done with the
userspace rbd tool.
Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Silence seq_scale() unused warning
ipv4:correct description for tcp_max_syn_backlog
pasemi_mac: Fix building as module
netback: Fix alert message.
r8169: fix Rx index race between FIFO overflow recovery and NAPI handler.
r8169: Rx FIFO overflow fixes.
ipv4: Fix peer validation on cached lookup.
ipv4: make sure RTO_ONLINK is saved in routing cache
iwlwifi: change the default behavior of watchdog timer
iwlwifi: do not re-configure HT40 after associated
iwlagn: fix HW crypto for TX-only keys
Revert "mac80211: clear sta.drv_priv on reconfiguration"
mac80211: fill rate filter for internal scan requests
cfg80211: amend regulatory NULL dereference fix
cfg80211: fix race on init and driver registration
Since commit c5ed63d66f24(tcp: fix three tcp sysctls tuning),
sysctl_max_syn_backlog is determined by tcp_hashinfo->ehash_mask,
and the minimal value is 128, and it will increase in proportion to the
memory of machine.
The original description for tcp_max_syn_backlog and sysctl_max_syn_backlog
are out of date.
Changelog:
V2: update description for sysctl_max_syn_backlog
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
Reviewed-by: Shan Wei <shanwei88@gmail.com>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
They're not currently actively worked on, the hardware being rather
obsolete by now.
Commit dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties
on AMD family 15h") introduced a kernel command line parameter
called 'align_va_addr' which still refers to arguments used in
an earlier version of the patch and which got changed without
updating the documentation. Correct that omission.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Frank Arnold <frank.arnold@amd.com>
Link: http://lkml.kernel.org/r/1321873819-29541-1-git-send-email-bp@amd64.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (21 commits)
usb: ftdi_sio: add PID for Propox ISPcable III
Revert "xHCI: reset-on-resume quirk for NEC uPD720200"
xHCI: fix bug in xhci_clear_command_ring()
usb: gadget: fsl_udc: fix dequeuing a request in progress
usb: fsl_mxc_udc.c: Remove compile-time dependency of MX35 SoC type
usb: fsl_mxc_udc.c: Fix build issue by including missing header file
USB: fsl_udc_core: use usb_endpoint_xfer_isoc to judge ISO XFER
usb: udc: Fix gadget driver's speed check in various UDC drivers
usb: gadget: fix g_serial regression
usb: renesas_usbhs: fixup driver speed
usb: renesas_usbhs: fixup gadget.dev.driver when udc_stop.
usb: renesas_usbhs: fixup signal the driver that cable was disconnected
usb: renesas_usbhs: fixup device_register timing
usb: musb: PM: fix context save/restore in suspend/resume path
USB: linux-cdc-acm.inf: add support for the acm_ms gadget
EHCI : Fix a regression in the ISO scheduler
USB: whci-hcd: fix endian conversion in qset_clear()
USB: usb-storage: unusual_devs entry for Kingston DT 101 G2
usb: option: add SIMCom SIM5218
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: fix meta data raid-repair merge problem
Btrfs: skip allocation attempt from empty cluster
Btrfs: skip block groups without enough space for a cluster
Btrfs: start search for new cluster at the beginning
Btrfs: reset cluster's max_size when creating bitmap
Btrfs: initialize new bitmaps' list
Btrfs: fix oops when calling statfs on readonly device
Btrfs: Don't error on resizing FS to same size
Btrfs: fix deadlock on metadata reservation when evicting a inode
Fix URL of btrfs-progs git repository in docs
btrfs scrub: handle -ENOMEM from init_ipath()
* 'dt-for-linus' of git://sources.calxeda.com/kernel/linux:
of: Add Silicon Image vendor prefix
of/irq: of_irq_init: add check for parent equal to child node
The location of the btrfs-progs repository has been changed.
This patch updates the documentation accordingly.
Signed-off-by: Arnd Hannemann <arnd@arndnet.de>
"sil" is the most commonly used abbreviation for Silicon
Image products.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Support for the acm_ms usb gadget on windows.
Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de>
The system wakeup section of Documentation/power/devices.txt is
outdated, so make it agree with the current code.
The runtime PM core code behavior related to the power.irq_safe
device flag has changed recently and the documentation should be
modified to reflect it.
The documentation file Documentation/power/devices.txt contains some
information that isn't correct any more due to code modifications
made after that file had been created (or updated last time). Fix
this.
The current power management documentation in Documentation/power/
either doesn't cover PM domains at all, or gives inaccurate
information about them, so update the relevant files in there to
follow the code.
10-bit addresses overlap with traditional 7-bit addresses, leading in
device name collisions. Add an arbitrary offset to 10-bit addresses to
prevent this collision. The offset was chosen so that the address is
still easily recognizable.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: ldisc, wait for ldisc infinitely in hangup
TTY: ldisc, move wait idle to caller
TTY: ldisc, allow waiting for ldisc arbitrarily long
Revert "tty/serial: Prevent drop of DCD on suspend for Tegra UARTs"
RS485: fix inconsistencies in the meaning of some variables
pch_uart: Fix DMA resource leak issue
serial,mfd: Fix CMSPAR setup
pch_uart: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor
pch_uart: Support new device LAPIS Semiconductor ML7831 IOH
pch_uart: Fix hw-flow control issue
tty: hvc_dcc: Fix duplicate character inputs
jsm: Change maintainership
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base/node.c: fix compilation error with older versions of gcc
uio: documentation fixups
device.h: Fix struct member documentation
