path: root/Documentation
2012-03-02ping-sysrq.patchCarsten Emde
There are (probably rare) situations when a system crashed and the system console becomes unresponsive but the network icmp layer still is alive. Wouldn't it be wonderful, if we then could submit a sysreq command via ping? This patch provides this facility. Please consult the updated documentation Documentation/sysrq.txt for details. Signed-off-by: Carsten Emde <C.Emde@osadl.org>
2012-03-02hwlatdetect.patchCarsten Emde
Jon Masters developed this wonderful SMI detector. For details please consult Documentation/hwlat_detector.txt. It could be ported to Linux 3.0 RT without any major change. Signed-off-by: Carsten Emde <C.Emde@osadl.org>
2012-03-02latency-hist.patchCarsten Emde
This patch provides a recording mechanism to store data of potential sources of system latencies. The recordings separately determine the latency caused by a delayed timer expiration, by a delayed wakeup of the related user space program and by the sum of both. The histograms can be enabled and reset individually. The data are accessible via the debug filesystem. For details please consult Documentation/trace/histograms.txt. Signed-off-by: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-01-12USB: update documentation for usbmonAlan Stern
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream. The documentation for usbmon is out of date; the usbfs "devices" file now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This patch (as1505) updates the documentation accordingly, and also mentions that the necessary information can be found by running lsusb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12Documentation: Update stable addressJoe Perches
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream. The Japanese/Korean/Chinese versions still need updating. Also, the stable kernel 2.6.x.y descriptions are out of date and should be updated as well. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-26KVM: Don't automatically expose the TSC deadline timer in cpuidJan Kiszka
Unlike all of the other cpuid bits, the TSC deadline timer bit is set unconditionally, regardless of what userspace wants. This is broken in several ways: - if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC deadline timer feature, a guest that uses the feature will break - live migration to older host kernels that don't support the TSC deadline timer will cause the feature to be pulled from under the guest's feet; breaking it - guests that are broken wrt the feature will fail. Fix by not enabling the feature automatically; instead report it to userspace. Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not KVM_GET_SUPPORTED_CPUID. Fixes the Illumos guest kernel, which uses the TSC deadline timer feature. [avi: add the KVM_CAP + documentation] Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-25KVM: Device assignment permission checksAlex Williamson
Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-25KVM: Remove ability to assign a device without iommu supportAlex Williamson
This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: add missing spin_unlock at ceph_mdsc_build_path() ceph: fix SEEK_CUR, SEEK_SET regression crush: fix mapping calculation when force argument doesn't exist ceph: use i_ceph_lock instead of i_lock rbd: remove buggy rollback functionality rbd: return an error when an invalid header is read ceph: fix rasize reporting by ceph_show_options
2011-12-09Merge branch 'iommu/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu * 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: MAINTAINERS: Update amd-iommu F: patterns iommu/amd: Fix typo in kernel-parameters.txt iommu/msm: Fix compile error in mach-msm/devices-iommu.c Fix comparison using wrong pointer variable in dma debug code
2011-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Fix lost speaker volume controls ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins ALSA: hda/realtek - Don't create extra controls with channel suffix ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs ASoC: Provide a more complete DMA driver stub ASoC: Remove references to corgi and spitz from machine driver document ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700 ASoC: uda1380: Return proper error in uda1380_modinit failure path ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C ASoC: Mark WM8994 ADC muxes as virtual ALSA: hda/realtek - Fix Oops in alc_mux_select() ALSA: sis7019 - give slow codecs more time to reset
2011-12-07rbd: remove buggy rollback functionalityJosh Durgin
This doesn't interact with resizing well, since it doesn't set the size of the device to the size at the snapshot. It's also an expensive operation to be synchronous. Rollback can still be done with the userspace rbd tool. Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
2011-12-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: Silence seq_scale() unused warning ipv4:correct description for tcp_max_syn_backlog pasemi_mac: Fix building as module netback: Fix alert message. r8169: fix Rx index race between FIFO overflow recovery and NAPI handler. r8169: Rx FIFO overflow fixes. ipv4: Fix peer validation on cached lookup. ipv4: make sure RTO_ONLINK is saved in routing cache iwlwifi: change the default behavior of watchdog timer iwlwifi: do not re-configure HT40 after associated iwlagn: fix HW crypto for TX-only keys Revert "mac80211: clear sta.drv_priv on reconfiguration" mac80211: fill rate filter for internal scan requests cfg80211: amend regulatory NULL dereference fix cfg80211: fix race on init and driver registration
2011-12-06ipv4:correct description for tcp_max_syn_backlogPeter Pan(潘卫平)
Since commit c5ed63d66f24(tcp: fix three tcp sysctls tuning), sysctl_max_syn_backlog is determined by tcp_hashinfo->ehash_mask, and the minimal value is 128, and it will increase in proportion to the memory of machine. The original description for tcp_max_syn_backlog and sysctl_max_syn_backlog are out of date. Changelog: V2: update description for sysctl_max_syn_backlog Signed-off-by: Weiping Pan <panweiping3@gmail.com> Reviewed-by: Shan Wei <shanwei88@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-06iommu/amd: Fix typo in kernel-parameters.txtSedat Dilek
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-12-06Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-12-05ASoC: Remove references to corgi and spitz from machine driver documentMark Brown
They're not currently actively worked on, the hardware being rather obsolete by now. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-05x86, AMD: Correct align_va_addr documentationBorislav Petkov
Commit dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties on AMD family 15h") introduced a kernel command line parameter called 'align_va_addr' which still refers to arguments used in an earlier version of the patch and which got changed without updating the documentation. Correct that omission. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Frank Arnold <frank.arnold@amd.com> Link: http://lkml.kernel.org/r/1321873819-29541-1-git-send-email-bp@amd64.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-02Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (21 commits) usb: ftdi_sio: add PID for Propox ISPcable III Revert "xHCI: reset-on-resume quirk for NEC uPD720200" xHCI: fix bug in xhci_clear_command_ring() usb: gadget: fsl_udc: fix dequeuing a request in progress usb: fsl_mxc_udc.c: Remove compile-time dependency of MX35 SoC type usb: fsl_mxc_udc.c: Fix build issue by including missing header file USB: fsl_udc_core: use usb_endpoint_xfer_isoc to judge ISO XFER usb: udc: Fix gadget driver's speed check in various UDC drivers usb: gadget: fix g_serial regression usb: renesas_usbhs: fixup driver speed usb: renesas_usbhs: fixup gadget.dev.driver when udc_stop. usb: renesas_usbhs: fixup signal the driver that cable was disconnected usb: renesas_usbhs: fixup device_register timing usb: musb: PM: fix context save/restore in suspend/resume path USB: linux-cdc-acm.inf: add support for the acm_ms gadget EHCI : Fix a regression in the ISO scheduler xHCI: reset-on-resume quirk for NEC uPD720200 USB: whci-hcd: fix endian conversion in qset_clear() USB: usb-storage: unusual_devs entry for Kingston DT 101 G2 usb: option: add SIMCom SIM5218 ...
2011-12-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix meta data raid-repair merge problem Btrfs: skip allocation attempt from empty cluster Btrfs: skip block groups without enough space for a cluster Btrfs: start search for new cluster at the beginning Btrfs: reset cluster's max_size when creating bitmap Btrfs: initialize new bitmaps' list Btrfs: fix oops when calling statfs on readonly device Btrfs: Don't error on resizing FS to same size Btrfs: fix deadlock on metadata reservation when evicting a inode Fix URL of btrfs-progs git repository in docs btrfs scrub: handle -ENOMEM from init_ipath()
2011-11-30Merge branch 'dt-for-linus' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
* 'dt-for-linus' of git://sources.calxeda.com/kernel/linux: of: Add Silicon Image vendor prefix of/irq: of_irq_init: add check for parent equal to child node
2011-11-30Fix URL of btrfs-progs git repository in docsArnd Hannemann
The location of the btrfs-progs repository has been changed. This patch updates the documentation accordingly. Signed-off-by: Arnd Hannemann <arnd@arndnet.de>
2011-11-29of: Add Silicon Image vendor prefixPawel Moll
"sil" is the most commonly used abbreviation for Silicon Image products. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2011-11-29USB: linux-cdc-acm.inf: add support for the acm_ms gadgetKlaus Schwarzkopf
Support for the acm_ms usb gadget on windows. Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-28PM / Sleep: Update documentation related to system wakeupRafael J. Wysocki
The system wakeup section of Documentation/power/devices.txt is outdated, so make it agree with the current code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-28PM / Runtime: Make documentation follow the new behavior of irq_safeRafael J. Wysocki
The runtime PM core code behavior related to the power.irq_safe device flag has changed recently and the documentation should be modified to reflect it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-28PM / Sleep: Correct inaccurate information in devices.txtRafael J. Wysocki
The documentation file Documentation/power/devices.txt contains some information that isn't correct any more due to code modifications made after that file had been created (or updated last time). Fix this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-28PM / Domains: Document how PM domains are used by the PM coreRafael J. Wysocki
The current power management documentation in Documentation/power/ either doesn't cover PM domains at all, or gives inaccurate information about them, so update the relevant files in there to follow the code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-23i2c: Fix device name for 10-bit slave addressJean Delvare
10-bit addresses overlap with traditional 7-bit addresses, leading in device name collisions. Add an arbitrary offset to 10-bit addresses to prevent this collision. The offset was chosen so that the address is still easily recognizable. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-11-21Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: TTY: ldisc, wait for ldisc infinitely in hangup TTY: ldisc, move wait idle to caller TTY: ldisc, allow waiting for ldisc arbitrarily long Revert "tty/serial: Prevent drop of DCD on suspend for Tegra UARTs" RS485: fix inconsistencies in the meaning of some variables pch_uart: Fix DMA resource leak issue serial,mfd: Fix CMSPAR setup tty/serial: Prevent drop of DCD on suspend for Tegra UARTs pch_uart: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor pch_uart: Support new device LAPIS Semiconductor ML7831 IOH pch_uart: Fix hw-flow control issue tty: hvc_dcc: Fix duplicate character inputs jsm: Change maintainership
2011-11-21Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: drivers/base/node.c: fix compilation error with older versions of gcc uio: documentation fixups device.h: Fix struct member documentation
2011-11-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (86 commits) ipv4: fix redirect handling ping: dont increment ICMP_MIB_INERRORS sky2: fix hang in napi_disable sky2: enforce minimum ring size bonding: Don't allow mode change via sysfs with slaves present f_phonet: fix page offset of first received fragment stmmac: fix pm functions avoiding sleep on spinlock stmmac: remove spin_lock in stmmac_ioctl. stmmac: parameters auto-tuning through HW cap reg stmmac: fix advertising 1000Base capabilties for non GMII iface stmmac: use mdelay on timeout of sw reset sky2: version 1.30 sky2: used fixed RSS key sky2: reduce default Tx ring size sky2: rename up/down functions sky2: pci posting issues sky2: fix hang on shutdown (and other irq issues) r6040: fix check against MCRO_HASHEN bit in r6040_multicast_list MAINTAINERS: change email address for shemminger pch_gbe: Move #include of module.h ...
2011-11-18Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: add missed trace_block_plug paride: fix potential information leak in pg_read() bio: change some signed vars to unsigned block: avoid unnecessary plug list flush cciss: auto engage SCSI mid layer at driver load time loop: cleanup set_status interface include/linux/bio.h: use a static inline function for bio_integrity_clone() loop: prevent information leak after failed read block: Always check length of all iov entries in blk_rq_map_user_iov() The Windows driver .inf disables ASPM on all cciss devices. Do the same. backing-dev: ensure wakeup_timer is deleted block: Revert "[SCSI] genhd: add a new attribute "alias" in gendisk"
2011-11-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix the connection selection of ADCs on Cirrus codecs ALSA: hda - Update URLs in document ALSA: hda - move eld->spk_alloc fixup to hdmi_update_eld() ALSA: hda - delayed ELD repoll ALSA: hda - fix ELD memory leak ALSA: hda/realtek: remove redundant semicolon ALSA: hda - pwr_nids cleanup for IDT codecs
2011-11-16ALSA: hda - Update URLs in documentTakashi Iwai
Some stuff was moved from kernel.org to other places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-16cciss: auto engage SCSI mid layer at driver load timeStephen M. Cameron
A long time ago, probably in 2002, one of the distros, or maybe more than one, loaded block drivers prior to loading the SCSI mid layer. This meant that the cciss driver, being a block driver, could not engage the SCSI mid layer at init time without panicking, and relied on being poked by a userland program after the system was up (and the SCSI mid layer was therefore present) to engage the SCSI mid layer. This is no longer the case, and cciss can safely rely on the SCSI mid layer being present at init time and engage the SCSI mid layer straight away. This means that users will see their tape drives and medium changers at driver load time without need for a script in /etc/rc.d that does this: for x in /proc/driver/cciss/cciss* do echo "engage scsi" > $x done However, if no tape drives or medium changers are detected, the SCSI mid layer will not be engaged. If a tape drive or medium change is later hot-added to the system it will then be necessary to use the above script or similar for the device(s) to be acceesible. Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-15RS485: fix inconsistencies in the meaning of some variablesClaudio Scordino
The crisv10.c and the atmel_serial.c serial drivers intepret the fields of the serial_rs485 structure in a different way. In particular, crisv10.c uses SER_RS485_RTS_AFTER_SEND and SER_RS485_RTS_ON_SEND for the voltage of the RTS pin; atmel_serial.c, instead, uses these values to know if a delay must be set before and after sending. This patch makes the usage of these variables consistent across all drivers and fixes the Documentation as well. From now on, SER_RS485_RTS_AFTER_SEND and SER_RS485_RTS_ON_SEND will be used to set the voltage of the RTS pin (as in the crisv10.c driver); the delay will be understood by looking only at the value of delay_rts_before_send and delay_rts_after_send. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Darron Black <darron@griffin.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15uio: documentation fixupsGeoff Thorpe
The 'name' attribute of struct uio_mem wasn't documented, and the note about 'kobj' is stale and needs to be changed to 'map'. Signed-off-by: Geoff Thorpe <geoff@geoffthorpe.net> Signed-off-by: "Hans J. Koch" <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: usb-audio: Use kmemdup rather than duplicating its implementation ALSA: hda - Re-enable the check NO_PRESENCE misc bit ALSA: vmaster - Free slave-links when freeing the master element ALSA: hda - Don't add elements of other codecs to vmaster slave ALSA: intel8x0: improve virtual environment detection ALSA: intel8x0: move virtual environment detection code into one place ALSA: snd_usb_audio: add Logitech HD Webcam c510 to quirk-384 ALSA: hda - fix internal mic on Dell Vostro 3500 laptop ALSA: HDA: Remove quirk for Toshiba T110 ALSA: usb-audio - Fix the missing volume quirks at delayed init ALSA: hda - Mute unused capture sources for Realtek codecs ALSA: intel8x0: Improve comments for VM optimization ASoC: Ensure we get an impedence reported for WM8958 jack detect ASoC: Don't use wm8994->control_data when requesting IRQs ASoC: Don't use wm8994->control_data in wm8994_readable_register() ASoC: Update git repository URL
2011-11-10block: Revert "[SCSI] genhd: add a new attribute "alias" in gendisk"Tejun Heo
This reverts commit a72c5e5eb738033938ab30d6a634b74d1d060f10. The commit introduced alias for block devices which is intended to be used during logging although actual usage hasn't been committed yet. This approach adds very limited benefit (raw log might be easier to follow) which can be trivially implemented in userland but has a lot of problems. It is much worse than netif renames because it doesn't rename the actual device but just adds conveninence name which isn't used universally or enforced. Everything internal including device lookup and sysfs still uses the internal name and nothing prevents two devices from using conflicting alias - ie. sda can have sdb as its alias. This has been nacked by people working on device driver core, block layer and kernel-userland interface and shouldn't have been upstreamed. Revert it. http://thread.gmane.org/gmane.linux.kernel/1155104 http://thread.gmane.org/gmane.linux.scsi/68632 http://thread.gmane.org/gmane.linux.scsi/69776 Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Nao Nishijima <nao.nishijima.xt@hitachi.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-09ALSA: hda - fix internal mic on Dell Vostro 3500 laptopJulian Wollrath
Fix the not working internal mic on Dell Vostro 3500 laptop by introducing the new model dell-vostro-3500. Signed-off-by: Julian Wollrath <jwollrath@web.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-08Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: (45 commits) DocBook/drm: Clean up a todo-note DocBook/drm: `device aware' -> `device-aware' DocBook/drm: `(device|driver) specific' -> `(device|driver)-specific' DocBook/drm: Clean up the paragraph on framebuffer objects DocBook/drm: Use `; otherwise,' DocBook/drm: Better flow with `, and then' DocBook/drm: Refer to the domain-setting function as a device-specific ioctl DocBook/drm: Improve flow of GPU/CPU coherence sentence DocBook/drm: Use an <itemizelist> for fundamental GEM operations DocBook/drm: Insert a comma DocBook/drm: Use a <variablelist> for vblank ioctls DocBook/drm: Use an itemizedlist for what an encoder needs to provide DocBook/drm: Insert `the' for readability, and change `set' to `setting' DocBook/drm: Remove extraneous commas DocBook/drm: Use a colon DocBook/drm: Clarify `final initialization' via better formatting DocBook/drm: Remove redundancy DocBook/drm: Insert `it' for smooth reading DocBook/drm: The word `so-called'; I do not think it connotes what you think it connotes DocBook/drm: Use a singular subject for grammatical cleanliness ...
2011-11-08net: min_pmtu default is 552Eric Dumazet
Small fix in Documentation, since min_pmtu is 512 + 20 + 20 = 552 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-07Documentation: Fix typo in freezer-subsystem.txtRafael J. Wysocki
Fix a typo in Documentation/cgroups/freezer-subsystem.txt. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2011-11-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: cpuidle: Single/Global registration of idle states cpuidle: Split cpuidle_state structure and move per-cpu statistics fields cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare() cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning ACPI: Export FADT pm_profile integer value to userspace thermal: Prevent polling from happening during system suspend ACPI: Drop ACPI_NO_HARDWARE_INIT ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast() PNPACPI: Simplify disabled resource registration ACPI: Fix possible recursive locking in hwregs.c ACPI: use kstrdup() mrst pmu: update comment tools/power turbostat: less verbose debugging
2011-11-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (226 commits) mtd: tests: annotate as DANGEROUS in Kconfig mtd: tests: don't use mtd0 as a default mtd: clean up usage of MTD_DOCPROBE_ADDRESS jffs2: add compr=lzo and compr=zlib options jffs2: implement mount option parsing and compression overriding mtd: nand: initialize ops.mode mtd: provide an alias for the redboot module name mtd: m25p80: don't probe device which has status of 'disabled' mtd: nand_h1900 never worked mtd: Add DiskOnChip G3 support mtd: m25p80: add EON flash EN25Q32B into spi flash id table mtd: mark block device queue as non-rotational mtd: r852: make r852_pm_ops static mtd: m25p80: add support for at25df321a spi data flash mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks mtd: nand: switch `check_pattern()' to standard `memcmp()' mtd: nand: invalidate cache on unaligned reads mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set mtd: nand: wait to set BBT version mtd: nand: scrub BBT on ECC errors ... Fix up trivial conflicts: - arch/arm/mach-at91/board-usb-a9260.c Merged into board-usb-a926x.c - drivers/mtd/maps/lantiq-flash.c add_mtd_partitions -> mtd_device_register vs changed to use mtd_device_parse_register.
2011-11-06Merge branch 'docs/docbook/drm' of git://github.com/mfwitten/linux into ↵Randy Dunlap
docs-move
2011-11-06ACPI: Export FADT pm_profile integer value to userspaceThomas Renninger
There are a lot userspace approaches to detect the usage of the platform (laptop, workstation, server, ...) and adjust kernel tunables accordingly (io/process scheduler, power management, ...). These approaches need constant maintaining and are ugly to implement (detect PCMCIA controller -> laptop, does not work on recent systems anymore, ...) On ACPI systems there is an easy and reliable way (if implemented in BIOS and most recent platforms have this value set). -> export it to userspace. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2011-11-06Merge git://github.com/rustyrussell/linuxLinus Torvalds
* git://github.com/rustyrussell/linux: module,bug: Add TAINT_OOT_MODULE flag for modules not built in-tree module: Enable dynamic debugging regardless of taint
2011-11-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits) powerpc/p3060qds: Add support for P3060QDS board powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX powerpc/85xx: Make kexec to interate over online cpus powerpc/fsl_booke: Fix comment in head_fsl_booke.S powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver powerpc/86xx: Correct Gianfar support for GE boards powerpc/cpm: Clear muram before it is in use. drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager powerpc/fsl_msi: add support for "msi-address-64" property powerpc/85xx: Setup secondary cores PIR with hard SMP id powerpc/fsl-booke: Fix settlbcam for 64-bit powerpc/85xx: Adding DCSR node to dtsi device trees powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards powerpc/85xx: fix PHYS_64BIT selection for P1022DS powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map powerpc: respect mem= setting for early memory limit setup powerpc: Update corenet64_smp_defconfig powerpc: Update mpc85xx/corenet 32-bit defconfigs ... Fix up trivial conflicts in: - arch/powerpc/configs/40x/hcu4_defconfig removed stale file, edited elsewhere - arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c: added opal and gelic drivers vs added ePAPR driver - drivers/tty/serial/8250.c moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
