There are (probably rare) situations when a system crashed and the system
console becomes unresponsive but the network icmp layer still is alive.
Wouldn't it be wonderful, if we then could submit a sysreq command via ping?
This patch provides this facility. Please consult the updated documentation
Documentation/sysrq.txt for details.
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
Jon Masters developed this wonderful SMI detector. For details please
consult Documentation/hwlat_detector.txt. It could be ported to Linux
3.0 RT without any major change.
This patch provides a recording mechanism to store data of potential
sources of system latencies. The recordings separately determine the
latency caused by a delayed timer expiration, by a delayed wakeup of the
related user space program and by the sum of both. The histograms can be
enabled and reset individually. The data are accessible via the debug
filesystem. For details please consult Documentation/trace/histograms.txt.
Unlike all of the other cpuid bits, the TSC deadline timer bit is set
unconditionally, regardless of what userspace wants.
This is broken in several ways:
- if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC
deadline timer feature, a guest that uses the feature will break
- live migration to older host kernels that don't support the TSC deadline
timer will cause the feature to be pulled from under the guest's feet;
breaking it
- guests that are broken wrt the feature will fail.
Fix by not enabling the feature automatically; instead report it to userspace.
Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee
will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not
KVM_GET_SUPPORTED_CPUID.
Fixes the Illumos guest kernel, which uses the TSC deadline timer feature.
[avi: add the KVM_CAP + documentation]
Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Only allow KVM device assignment to attach to devices which:
- Are not bridges
- Have BAR resources (assume others are special devices)
- The user has permissions to use
Assigning a bridge is a configuration error, it's not supported, and
typically doesn't result in the behavior the user is expecting anyway.
Devices without BAR resources are typically chipset components that
also don't have host drivers. We don't want users to hold such devices
captive or cause system problems by fencing them off into an iommu
domain. We determine "permission to use" by testing whether the user
has access to the PCI sysfs resource files. By default a normal user
will not have access to these files, so it provides a good indication
that an administration agent has granted the user access to the device.
[Yang Bai: add missing #include]
[avi: fix comment style]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Yang Bai <hamo.by@gmail.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This option has no users and it exposes a security hole that we
can allow devices to be assigned without iommu protection. Make
KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: add missing spin_unlock at ceph_mdsc_build_path()
ceph: fix SEEK_CUR, SEEK_SET regression
crush: fix mapping calculation when force argument doesn't exist
ceph: use i_ceph_lock instead of i_lock
rbd: remove buggy rollback functionality
rbd: return an error when an invalid header is read
ceph: fix rasize reporting by ceph_show_options
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
* 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
MAINTAINERS: Update amd-iommu F: patterns
iommu/amd: Fix typo in kernel-parameters.txt
iommu/msm: Fix compile error in mach-msm/devices-iommu.c
Fix comparison using wrong pointer variable in dma debug code
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda/realtek - Fix lost speaker volume controls
ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins
ALSA: hda/realtek - Don't create extra controls with channel suffix
ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes
ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs
ASoC: Provide a more complete DMA driver stub
ASoC: Remove references to corgi and spitz from machine driver document
ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C
ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700
ASoC: uda1380: Return proper error in uda1380_modinit failure path
ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C
ASoC: Mark WM8994 ADC muxes as virtual
ALSA: hda/realtek - Fix Oops in alc_mux_select()
ALSA: sis7019 - give slow codecs more time to reset
This doesn't interact with resizing well, since it doesn't set the
size of the device to the size at the snapshot. It's also an expensive
operation to be synchronous. Rollback can still be done with the
userspace rbd tool.
Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Silence seq_scale() unused warning
ipv4:correct description for tcp_max_syn_backlog
pasemi_mac: Fix building as module
netback: Fix alert message.
r8169: fix Rx index race between FIFO overflow recovery and NAPI handler.
r8169: Rx FIFO overflow fixes.
ipv4: Fix peer validation on cached lookup.
ipv4: make sure RTO_ONLINK is saved in routing cache
iwlwifi: change the default behavior of watchdog timer
iwlwifi: do not re-configure HT40 after associated
iwlagn: fix HW crypto for TX-only keys
Revert "mac80211: clear sta.drv_priv on reconfiguration"
mac80211: fill rate filter for internal scan requests
cfg80211: amend regulatory NULL dereference fix
cfg80211: fix race on init and driver registration
Since commit c5ed63d66f24(tcp: fix three tcp sysctls tuning),
sysctl_max_syn_backlog is determined by tcp_hashinfo->ehash_mask,
and the minimal value is 128, and it will increase in proportion to the
memory of machine.
The original description for tcp_max_syn_backlog and sysctl_max_syn_backlog
are out of date.
Changelog:
V2: update description for sysctl_max_syn_backlog
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
Reviewed-by: Shan Wei <shanwei88@gmail.com>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
They're not currently actively worked on, the hardware being rather
obsolete by now.
Commit dfb09f9b7ab0 ("x86, amd: Avoid cache aliasing penalties
on AMD family 15h") introduced a kernel command line parameter
called 'align_va_addr' which still refers to arguments used in
an earlier version of the patch and which got changed without
updating the documentation. Correct that omission.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Frank Arnold <frank.arnold@amd.com>
Link: http://lkml.kernel.org/r/1321873819-29541-1-git-send-email-bp@amd64.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (21 commits)
usb: ftdi_sio: add PID for Propox ISPcable III
Revert "xHCI: reset-on-resume quirk for NEC uPD720200"
xHCI: fix bug in xhci_clear_command_ring()
usb: gadget: fsl_udc: fix dequeuing a request in progress
usb: fsl_mxc_udc.c: Remove compile-time dependency of MX35 SoC type
usb: fsl_mxc_udc.c: Fix build issue by including missing header file
USB: fsl_udc_core: use usb_endpoint_xfer_isoc to judge ISO XFER
usb: udc: Fix gadget driver's speed check in various UDC drivers
usb: gadget: fix g_serial regression
usb: renesas_usbhs: fixup driver speed
usb: renesas_usbhs: fixup gadget.dev.driver when udc_stop.
usb: renesas_usbhs: fixup signal the driver that cable was disconnected
usb: renesas_usbhs: fixup device_register timing
usb: musb: PM: fix context save/restore in suspend/resume path
USB: linux-cdc-acm.inf: add support for the acm_ms gadget
EHCI : Fix a regression in the ISO scheduler
USB: whci-hcd: fix endian conversion in qset_clear()
USB: usb-storage: unusual_devs entry for Kingston DT 101 G2
usb: option: add SIMCom SIM5218
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: fix meta data raid-repair merge problem
Btrfs: skip allocation attempt from empty cluster
Btrfs: skip block groups without enough space for a cluster
Btrfs: start search for new cluster at the beginning
Btrfs: reset cluster's max_size when creating bitmap
Btrfs: initialize new bitmaps' list
Btrfs: fix oops when calling statfs on readonly device
Btrfs: Don't error on resizing FS to same size
Btrfs: fix deadlock on metadata reservation when evicting a inode
Fix URL of btrfs-progs git repository in docs
btrfs scrub: handle -ENOMEM from init_ipath()
* 'dt-for-linus' of git://sources.calxeda.com/kernel/linux:
of: Add Silicon Image vendor prefix
of/irq: of_irq_init: add check for parent equal to child node
The location of the btrfs-progs repository has been changed.
This patch updates the documentation accordingly.
Signed-off-by: Arnd Hannemann <arnd@arndnet.de>
"sil" is the most commonly used abbreviation for Silicon
Image products.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
Support for the acm_ms usb gadget on windows.
Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de>
The system wakeup section of Documentation/power/devices.txt is
outdated, so make it agree with the current code.
The runtime PM core code behavior related to the power.irq_safe
device flag has changed recently and the documentation should be
modified to reflect it.
The documentation file Documentation/power/devices.txt contains some
information that isn't correct any more due to code modifications
made after that file had been created (or updated last time). Fix
this.
The current power management documentation in Documentation/power/
either doesn't cover PM domains at all, or gives inaccurate
information about them, so update the relevant files in there to
follow the code.
10-bit addresses overlap with traditional 7-bit addresses, leading in
device name collisions. Add an arbitrary offset to 10-bit addresses to
prevent this collision. The offset was chosen so that the address is
still easily recognizable.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: ldisc, wait for ldisc infinitely in hangup
TTY: ldisc, move wait idle to caller
TTY: ldisc, allow waiting for ldisc arbitrarily long
Revert "tty/serial: Prevent drop of DCD on suspend for Tegra UARTs"
RS485: fix inconsistencies in the meaning of some variables
pch_uart: Fix DMA resource leak issue
serial,mfd: Fix CMSPAR setup
pch_uart: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor
pch_uart: Support new device LAPIS Semiconductor ML7831 IOH
pch_uart: Fix hw-flow control issue
tty: hvc_dcc: Fix duplicate character inputs
jsm: Change maintainership
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base/node.c: fix compilation error with older versions of gcc
uio: documentation fixups
device.h: Fix struct member documentation
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (86 commits)
ipv4: fix redirect handling
ping: dont increment ICMP_MIB_INERRORS
sky2: fix hang in napi_disable
sky2: enforce minimum ring size
bonding: Don't allow mode change via sysfs with slaves present
f_phonet: fix page offset of first received fragment
stmmac: fix pm functions avoiding sleep on spinlock
stmmac: remove spin_lock in stmmac_ioctl.
stmmac: parameters auto-tuning through HW cap reg
stmmac: fix advertising 1000Base capabilties for non GMII iface
stmmac: use mdelay on timeout of sw reset
sky2: version 1.30
sky2: used fixed RSS key
sky2: reduce default Tx ring size
sky2: rename up/down functions
sky2: pci posting issues
sky2: fix hang on shutdown (and other irq issues)
r6040: fix check against MCRO_HASHEN bit in r6040_multicast_list
MAINTAINERS: change email address for shemminger
pch_gbe: Move #include of module.h
* 'for-linus' of git://git.kernel.dk/linux-block:
block: add missed trace_block_plug
paride: fix potential information leak in pg_read()
bio: change some signed vars to unsigned
block: avoid unnecessary plug list flush
cciss: auto engage SCSI mid layer at driver load time
loop: cleanup set_status interface
include/linux/bio.h: use a static inline function for bio_integrity_clone()
loop: prevent information leak after failed read
block: Always check length of all iov entries in blk_rq_map_user_iov()
The Windows driver .inf disables ASPM on all cciss devices. Do the same.
backing-dev: ensure wakeup_timer is deleted
block: Revert "[SCSI] genhd: add a new attribute "alias" in gendisk"
ALSA: hda - Fix the connection selection of ADCs on Cirrus codecs
ALSA: hda - Update URLs in document
ALSA: hda - move eld->spk_alloc fixup to hdmi_update_eld()
ALSA: hda - delayed ELD repoll
ALSA: hda - fix ELD memory leak
ALSA: hda/realtek: remove redundant semicolon
ALSA: hda - pwr_nids cleanup for IDT codecs
Some stuff was moved from kernel.org to other places.
A long time ago, probably in 2002, one of the distros, or maybe more than
one, loaded block drivers prior to loading the SCSI mid layer. This meant
that the cciss driver, being a block driver, could not engage the SCSI mid
layer at init time without panicking, and relied on being poked by a
userland program after the system was up (and the SCSI mid layer was
therefore present) to engage the SCSI mid layer.
This is no longer the case, and cciss can safely rely on the SCSI mid
layer being present at init time and engage the SCSI mid layer straight
away. This means that users will see their tape drives and medium
changers at driver load time without need for a script in /etc/rc.d that
does this:
for x in /proc/driver/cciss/cciss*
do
echo "engage scsi" > $x
done
However, if no tape drives or medium changers are detected, the SCSI mid
layer will not be engaged. If a tape drive or medium change is later
hot-added to the system it will then be necessary to use the above script
or similar for the device(s) to be acceesible.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
The crisv10.c and the atmel_serial.c serial drivers intepret the fields of the
serial_rs485 structure in a different way.
In particular, crisv10.c uses SER_RS485_RTS_AFTER_SEND and
SER_RS485_RTS_ON_SEND for the voltage of the RTS pin; atmel_serial.c,
instead, uses these values to know if a delay must be set before and
after sending. This patch makes the usage of these variables consistent
across all drivers and fixes the Documentation as well.
From now on, SER_RS485_RTS_AFTER_SEND and SER_RS485_RTS_ON_SEND will be
used to set the voltage of the RTS pin (as in the crisv10.c driver); the
delay will be understood by looking only at the value of
delay_rts_before_send and delay_rts_after_send.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Signed-off-by: Darron Black <darron@griffin.net>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
The 'name' attribute of struct uio_mem wasn't documented, and the note
about 'kobj' is stale and needs to be changed to 'map'.
Signed-off-by: Geoff Thorpe <geoff@geoffthorpe.net>
Signed-off-by: "Hans J. Koch" <hjk@hansjkoch.de>
ALSA: usb-audio: Use kmemdup rather than duplicating its implementation
ALSA: hda - Re-enable the check NO_PRESENCE misc bit
ALSA: vmaster - Free slave-links when freeing the master element
ALSA: hda - Don't add elements of other codecs to vmaster slave
ALSA: intel8x0: improve virtual environment detection
ALSA: intel8x0: move virtual environment detection code into one place
ALSA: snd_usb_audio: add Logitech HD Webcam c510 to quirk-384
ALSA: hda - fix internal mic on Dell Vostro 3500 laptop
ALSA: HDA: Remove quirk for Toshiba T110
ALSA: usb-audio - Fix the missing volume quirks at delayed init
ALSA: hda - Mute unused capture sources for Realtek codecs
ALSA: intel8x0: Improve comments for VM optimization
ASoC: Ensure we get an impedence reported for WM8958 jack detect
ASoC: Don't use wm8994->control_data when requesting IRQs
ASoC: Don't use wm8994->control_data in wm8994_readable_register()
ASoC: Update git repository URL
This reverts commit a72c5e5eb738033938ab30d6a634b74d1d060f10.
The commit introduced alias for block devices which is intended to be
used during logging although actual usage hasn't been committed yet.
This approach adds very limited benefit (raw log might be easier to
follow) which can be trivially implemented in userland but has a lot
of problems.
It is much worse than netif renames because it doesn't rename the
actual device but just adds conveninence name which isn't used
universally or enforced. Everything internal including device lookup
and sysfs still uses the internal name and nothing prevents two
devices from using conflicting alias - ie. sda can have sdb as its
alias.
This has been nacked by people working on device driver core, block
layer and kernel-userland interface and shouldn't have been
upstreamed. Revert it.
http://thread.gmane.org/gmane.linux.kernel/1155104
http://thread.gmane.org/gmane.linux.scsi/68632
http://thread.gmane.org/gmane.linux.scsi/69776
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Nao Nishijima <nao.nishijima.xt@hitachi.com>
Cc: Alan Cox <alan@linux.intel.com>
Fix the not working internal mic on Dell Vostro 3500 laptop by introducing the
new model dell-vostro-3500.
Signed-off-by: Julian Wollrath <jwollrath@web.de>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs
* 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: (45 commits)
DocBook/drm: Clean up a todo-note
DocBook/drm: `device aware' -> `device-aware'
DocBook/drm: `(device|driver) specific' -> `(device|driver)-specific'
DocBook/drm: Clean up the paragraph on framebuffer objects
DocBook/drm: Use `; otherwise,'
DocBook/drm: Better flow with `, and then'
DocBook/drm: Refer to the domain-setting function as a device-specific ioctl
DocBook/drm: Improve flow of GPU/CPU coherence sentence
DocBook/drm: Use an <itemizelist> for fundamental GEM operations
DocBook/drm: Insert a comma
DocBook/drm: Use a <variablelist> for vblank ioctls
DocBook/drm: Use an itemizedlist for what an encoder needs to provide
DocBook/drm: Insert `the' for readability, and change `set' to `setting'
DocBook/drm: Remove extraneous commas
DocBook/drm: Use a colon
DocBook/drm: Clarify `final initialization' via better formatting
DocBook/drm: Remove redundancy
DocBook/drm: Insert `it' for smooth reading
DocBook/drm: The word `so-called'; I do not think it connotes what you think it connotes
DocBook/drm: Use a singular subject for grammatical cleanliness
Small fix in Documentation, since min_pmtu is 512 + 20 + 20 = 552
Fix a typo in Documentation/cgroups/freezer-subsystem.txt.
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
cpuidle: Single/Global registration of idle states
cpuidle: Split cpuidle_state structure and move per-cpu statistics fields
cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare()
cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state
ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning
ACPI: Export FADT pm_profile integer value to userspace
thermal: Prevent polling from happening during system suspend
ACPI: Drop ACPI_NO_HARDWARE_INIT
ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast()
PNPACPI: Simplify disabled resource registration
ACPI: Fix possible recursive locking in hwregs.c
ACPI: use kstrdup()
mrst pmu: update comment
tools/power turbostat: less verbose debugging
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
docs-move
There are a lot userspace approaches to detect the usage of the
platform (laptop, workstation, server, ...) and adjust kernel tunables
accordingly (io/process scheduler, power management, ...).
These approaches need constant maintaining and are ugly to implement
(detect PCMCIA controller -> laptop,
does not work on recent systems anymore, ...)
On ACPI systems there is an easy and reliable way (if implemented
in BIOS and most recent platforms have this value set).
-> export it to userspace.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Len Brown <len.brown@intel.com>
* git://github.com/rustyrussell/linux:
module,bug: Add TAINT_OOT_MODULE flag for modules not built in-tree
module: Enable dynamic debugging regardless of taint
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/p3060qds: Add support for P3060QDS board
powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX
powerpc/85xx: Make kexec to interate over online cpus
powerpc/fsl_booke: Fix comment in head_fsl_booke.S
powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices
powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver
powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver
powerpc/86xx: Correct Gianfar support for GE boards
powerpc/cpm: Clear muram before it is in use.
drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager
powerpc/fsl_msi: add support for "msi-address-64" property
powerpc/85xx: Setup secondary cores PIR with hard SMP id
powerpc/fsl-booke: Fix settlbcam for 64-bit
powerpc/85xx: Adding DCSR node to dtsi device trees
powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards
powerpc/85xx: fix PHYS_64BIT selection for P1022DS
powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map
powerpc: respect mem= setting for early memory limit setup
powerpc: Update corenet64_smp_defconfig
powerpc: Update mpc85xx/corenet 32-bit defconfigs
Fix up trivial conflicts in:
- arch/powerpc/configs/40x/hcu4_defconfig
removed stale file, edited elsewhere
- arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c:
added opal and gelic drivers vs added ePAPR driver
- drivers/tty/serial/8250.c
moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
Use of the GPL or a compatible licence doesn't necessarily make the code
any good. We already consider staging modules to be suspect, and this
should also be true for out-of-tree modules which may receive very
little review.
Reviewed-by: Dave Jones <davej@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (patched oops-tracing.txt)
