Allow the mma8452 to be described in the device tree.
Since no device specific binding attributes exist the trivial
I2C binding is sufficient to describe the compatible string.
Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This adds some basic, simple device tree bindings to the STMicro
MEMS sensor drivers.
Cc: devicetree@vger.kernel.org
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Denis CIOCCA <denis.ciocca@st.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Second round of new drivers and cleanups for IIO in the 3.17 cycle.
New drivers
* mcp4902, mcp4912 and mcp4922 SPI DAC driver.
* max1027, max1029 and max1031 SPI ADC driver.
Cleanups
* cm32181 - use devm APIs to simplify error paths.
* ak8975 - use devm APIs to simplify error paths.
* ad9850 - drop some unused defines and an unnecessary goto.
* hmc5843 - add missing devices to the device id table and the documentation.
* ad9832 - small formatting cleanups.
* sca3000 - hide direct use of the stufftoread element by adding a
data_available function. This is a precursor for the addition of buffer
watermarks to the subsystem but stands as a good cleanup on its own.
Signed-off-by: Marek Belisko <marek@goldelico.com>
This driver add partial support of the
maxim 1027/1029/1031. Differential mode is not
supported.
It was tested on armadeus apf27 board.
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
Reviewed-by: Hartmut Knaack <knaack.h@gmx.de>
We want the staging fixes here as well.
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c new drivers from Wolfram Sang:
"Here is a pull request from i2c hoping for the "new driver" rule.
Originally, I wanted to send this request during the merge window, but
code checkers with very recent additions complained, so a few fixups
were needed. So, some more time went by and I merged rc1 to get a
stable base"
So the "new driver" rule is really about drivers that people absolutely
need for the kernel to work on new hardware, which is not so much the
case for i2c. So I considered not pulling this, but eventually
relented.
Just for FYI: the whole (and only) point of "new drivers" is not that
new drivers cannot regress things (they can, and they have - by
triggering badly tested code on machines that never triggered that code
before), but because they can bring to life machines that otherwise
wouldn't be useful at all without the drivers.
So the new driver rule is for essential things that actual consumers
would care about, ie devices like networking or disk drivers that matter
to normal people (not server people - they run old kernels anyway, so
mainlining new drivers is irrelevant for them).
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: sun6-p2wi: fix call to snprintf
i2c: rk3x: add NULL entry to the end of_device_id array
i2c: sun6i-p2wi: use proper return value in probe
i2c: sunxi: add P2WI (Push/Pull 2 Wire Interface) controller support
i2c: sunxi: add P2WI DT bindings documentation
i2c: rk3x: add driver for Rockchip RK3xxx SoC I2C adapter
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild fixes from Michal Marek:
"There are three fixes for regressions caused by the relative paths
series: deb-pkg, tar-pkg and *docs did not work with O=.
Plus, there is a fix for the linux-headers deb package and a fixed
typo. These are not regression fixes but are safe enough"
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: fix a typo in a kbuild document
builddeb: fix missing headers in linux-headers package
Documentation: Fix DocBook build with relative $(srctree)
kbuild: Fix tar-pkg with relative $(objtree)
deb-pkg: Fix for relative paths
Pull ACPI and power management fixes from Rafael Wysocki:
"These are fixes mostly (ia64 regression related to the ACPI
enumeration of devices, cpufreq regressions, fix for I2C controllers
included in Intel SoCs, mvebu cpuidle driver fix related to sysfs)
plus additional kernel command line arguments from Kees to make it
possible to build kernel images with hibernation and the kernel
address space randomization included simultaneously, a new ACPI
battery driver quirk for a system with a broken BIOS and a couple of
ACPI core cleanups.
Specifics:
- Fix for an ia64 regression introduced during the 3.11 cycle by a
commit that modified the hardware initialization ordering and made
device discovery fail on some systems.
- Fix for a build problem on systems where the cpufreq-cpu0 driver is
built-in and the cpu-thermal driver is modular from Arnd Bergmann.
- Fix for a recently introduced computational mistake in the
intel_pstate driver that leads to excessive rounding errors from
Doug Smythies.
- Fix for a failure code path in cpufreq_update_policy() that fails
to unlock the locks acquired previously from Aaron Plattner.
- Fix for the cpuidle mvebu driver to use shorter state names which
will prevent the sysfs interface from returning mangled strings.
From Gregory Clement.
- ACPI LPSS driver fix to make sure that the I2C controllers included
in BayTrail SoCs are not held in the reset state while they are
being probed from Mika Westerberg.
- New kernel command line arguments making it possible to build
kernel images with hibernation and kASLR included at the same time
and to select which of them will be used via the command line (they
are still functionally mutually exclusive, though). From Kees
Cook.
- ACPI battery driver quirk for Acer Aspire V5-573G that fails to
send battery status change notifications timely from Alexander
Mezin.
- Two ACPI core cleanups from Christoph Jaeger and Fabian Frederick"
* tag 'pm+acpi-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpuidle: mvebu: Fix the name of the states
cpufreq: unlock when failing cpufreq_update_policy()
intel_pstate: Correct rounding in busy calculation
ACPI: use kstrto*() instead of simple_strto*()
ACPI / processor replace __attribute__((packed)) by __packed
ACPI / battery: add quirk for Acer Aspire V5-573G
ACPI / battery: use callback for setting up quirks
ACPI / LPSS: Take I2C host controllers out of reset
x86, kaslr: boot-time selectable with hibernation
PM / hibernate: introduce "nohibernate" boot parameter
cpufreq: cpufreq-cpu0: fix CPU_THERMAL dependency
ACPI / ia64 / sba_iommu: Restore the working initialization ordering
Jonathan writes:
First round of new drivers, cleanups and functionality for the 3.17 cycle.
New drivers
* t5403 barometric pressure sensor
* kxcjk1013 accelerometer (with a locking followup fix).
* ak09911 digital compass
Documentation
* ABI docs for proximity added (interface has been there a long time but
somehow snuck through without being documented)
* Move iio-trig-sysfs documentation out of staging (got left behind when
the driver moved some time ago).
Cleanups
* drop the timestamp argument from iio_trigger_poll(_chained) as
nothing has been done with it for some time.
* ad799x kerneldoc for ad799x_chip brought up to date.
* replace a number of reimplementations of the GENMASK macro and
use the BIT macro to cleanup a few locations.
* bring the iio_event_monitor example program up to date with new
device types.
* fix some incorrect function prototypes in iio_utils.h example code.
* INDIO_RING_TRIGGERED to INDIO_BUFFER_TRIGGERED fix in docs. This
got left behind after we renamed it a long time back.
* fix error handling in the generic_buffer example program.
* small tidy ups in the iio-trig-periodic-rtc driver.
* Allow reseting iio-trig-periodic-rtc frequency to 0 (default) after
it has changed.
* Trivial tidy ups in coding style in iio_simply_dummy
After commits 890676c6 (kbuild: Use relative path when building in the source
tree) and 9da0763b (kbuild: Use relative path when building in a subdir
of the source tree), the $(srctree) variable can be a relative path.
This breaks Documentation/DocBook/media/Makefile, because it tries to
create symlinks from a subdirectory of the object tree to the source
tree. Fix this by using a full path in this case.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
Merge a stable base (Linux 3.16-rc1)
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-next
This is bigger because it regenerates the internal firmwares after a fix.
* 'drm-nouveau-next' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
drm/nouveau/doc: update the thermal documentation
drm/nouveau/pwr: fix typo in fifo wrap handling
drm/nv50/disp: fix a potential oops in supervisor handling
drm/nouveau/disp/dp: don't touch link config after success
drm/nouveau/kms: reference vblank for crtc during pageflip.
drm/gk104/fb/ram: fixups from an earlier search+replace
drm/nv50/gr: remove an unneeded write while initialising PGRAPH
drm/nv50/gr: fix overlap while zeroing zcull regions
drm/gf100-/gr: report class data to host on fwmthd failure
drm/gk104/ibus: increase various random timeouts
drm/gk104/clk: only touch divider for mode we'll be using
Changes:
- Change the maintainer's address (the labri address will expire soon);
- Drop the note about not all families supporting all fan modes;
- Add a note about the reported RPM not being accurate when driven outside
the vbios-defined PWM range.
Signed-off-by: Martin Peres <martin.peres@free.fr>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Changes kASLR from being compile-time selectable (blocked by
CONFIG_HIBERNATION), to being boot-time selectable (with hibernation
available by default) via the "kaslr" kernel command line.
Acked-by: Pavel Machek <pavel@ucw.cz>
To support using kernel features that are not compatible with hibernation,
this creates the "nohibernate" kernel boot parameter to disable both
hibernation and resume. This allows hibernation support to be a boot-time
choice instead of only a compile-time choice.
git://git.linaro.org/people/mike.turquette/linux
Pull more clock framework updates from Mike Turquette:
"This contains the second half the of the clk changes for 3.16.
They are simply fixes and code refactoring for the OMAP clock drivers.
The sunxi clock driver changes include splitting out the one
mega-driver into several smaller pieces and adding support for the A31
SoC clocks"
* tag 'clk-for-linus-3.16-part2' of git://git.linaro.org/people/mike.turquette/linux: (25 commits)
clk: sunxi: document PRCM clock compatible strings
clk: sunxi: add PRCM (Power/Reset/Clock Management) clks support
clk: sun6i: Protect SDRAM gating bit
clk: sun6i: Protect CPU clock
clk: sunxi: Rework clock protection code
clk: sunxi: Move the GMAC clock to a file of its own
clk: sunxi: Move the 24M oscillator to a file of its own
clk: sunxi: Remove calls to clk_put
clk: sunxi: document new A31 USB clock compatible
clk: sunxi: Implement A31 USB clock
ARM: dts: OMAP5/DRA7: use omap5-mpu-dpll-clock capable of dealing with higher frequencies
CLK: TI: dpll: support OMAP5 MPU DPLL that need special handling for higher frequencies
ARM: OMAP5+: dpll: support Duty Cycle Correction(DCC)
CLK: TI: clk-54xx: Set the rate for dpll_abe_m2x2_ck
CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic)
dt:/bindings: DRA7 ATL (Audio Tracking Logic) clock bindings
ARM: dts: dra7xx-clocks: Correct name for atl clkin3 clock
CLK: TI: gate: add composite interface clock to OMAP2 only build
ARM: OMAP2: clock: add DT boot support for cpufreq_ck
CLK: TI: OMAP2: add clock init support
Pull x86 vdso fixes from Peter Anvin:
"Fixes for x86/vdso.
One is a simple build fix for bigendian hosts, one is to make "make
vdso_install" work again, and the rest is about working around a bug
in Google's Go language -- two are documentation patches that improves
the sample code that the Go coders took, modified, and broke; the
other two implements a workaround that keeps existing Go binaries from
segfaulting at least"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso: Fix vdso_install
x86/vdso: Hack to keep 64-bit Go programs working
x86/vdso: Add PUT_LE to store little-endian values
x86/vdso/doc: Make vDSO examples more portable
x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.c
x86, vdso: Remove one final use of htole16()
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon updates from Guenter Roeck:
- new driver for Sensirion SHTC1 humidity / temperature sensor
- convert ltc4151 and vexpress drivers to use devm functions
- drop generic chip detection from lm85 driver
- avoid forward declarations in atxp1 driver
- fix sign extensions in ina2xx driver
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: vexpress: Use devm helper for hwmon device registration
hwmon: (atxp1) Avoid forward declaration
hwmon: add support for Sensirion SHTC1 sensor
hwmon: (ltc4151) Convert to devm_hwmon_device_register_with_groups
hwmon: (lm85) Drop generic detection
hwmon: (ina2xx) Cast to s16 on shunt and current regs
iio-trig-sysfs has left staging with commit e64e7d5c
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Pull kbuild misc updates from Michal Marek:
"This is the non-critical part of kbuild for v3.16-rc1:
- make deb-pkg can do s390x and arm64
- new patterns in scripts/tags.sh
- scripts/tags.sh skips userspace tools' sources (which sometimes
have copies of kernel structures) and symlinks
- improvements to the objdiff tool
- two new coccinelle patches
- other minor fixes"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts: objdiff: support directories for the augument of record command
scripts: objdiff: fix a comment
scripts: objdiff: change the extension of disassembly from .o to .dis
scripts: objdiff: improve path flexibility for record command
scripts: objdiff: remove unnecessary code
scripts: objdiff: direct error messages to stderr
scripts: objdiff: get the path to .tmp_objdiff more simply
deb-pkg: Add automatic support for s390x architecture
coccicheck: Add unneeded return variable test
kbuild: Fix a typo in documentation
kbuild: trivial - use tabs for code indent where possible
kbuild: trivial - remove trailing empty lines
coccinelle: Check for missing NULL terminators in of_device_id tables
scripts/tags.sh: ignore symlink'ed source files
scripts/tags.sh: add regular expression replacement pattern for memcg
builddeb: add arm64 in the supported architectures
builddeb: use $OBJCOPY variable instead of objcopy
scripts/tags.sh: ignore code of user space tools
scripts/tags.sh: add pattern for DEFINE_HASHTABLE
.gitignore: ignore Module.symvers in all directories
Pull more perf updates from Ingo Molnar:
"A second round of perf updates:
- wide reaching kprobes sanitization and robustization, with the hope
of fixing all 'probe this function crashes the kernel' bugs, by
Masami Hiramatsu.
- uprobes updates from Oleg Nesterov: tmpfs support, corner case
fixes and robustization work.
- perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo
et al:
* Add support to accumulate hist periods (Namhyung Kim)
* various fixes, refactorings and enhancements"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits)
perf: Differentiate exec() and non-exec() comm events
perf: Fix perf_event_comm() vs. exec() assumption
uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates
perf/documentation: Add description for conditional branch filter
perf/x86: Add conditional branch filtering support
perf/tool: Add conditional branch filter 'cond' to perf record
perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND'
uprobes: Teach copy_insn() to support tmpfs
uprobes: Shift ->readpage check from __copy_insn() to uprobe_register()
perf/x86: Use common PMU interrupt disabled code
perf/ARM: Use common PMU interrupt disabled code
perf: Disable sampled events if no PMU interrupt
perf: Fix use after free in perf_remove_from_context()
perf tools: Fix 'make help' message error
perf record: Fix poll return value propagation
perf tools: Move elide bool into perf_hpp_fmt struct
perf tools: Remove elide setup for SORT_MODE__MEMORY mode
perf tools: Fix "==" into "=" in ui_browser__warning assignment
perf tools: Allow overriding sysfs and proc finding with env var
perf tools: Consider header files outside perf directory in tags target
This adds a new vdso_test.c that's written entirely in C. It also
makes all of the vDSO examples work on 32-bit x86.
Cc: Stefani Seibold <stefani@seibold.net>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/62b701fc44b79f118ac2b2d64d19965fc5c291fb.1402620737.git.luto@amacapital.net
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
This thing is hopelessly x86_64-specific: it's an example of how to
access the vDSO without any runtime support at all.
Link: http://lkml.kernel.org/r/3efc170e0e166e15f0150c9fdb37d52488b9c0a4.1402620737.git.luto@amacapital.net
Pull more locking changes from Ingo Molnar:
"This is the second round of locking tree updates for v3.16, offering
large system scalability improvements:
- optimistic spinning for rwsems, from Davidlohr Bueso.
- 'qrwlocks' core code and x86 enablement, from Waiman Long and PeterZ"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, locking/rwlocks: Enable qrwlocks on x86
locking/rwlocks: Introduce 'qrwlocks' - fair, queued rwlocks
locking/mutexes: Documentation update/rewrite
locking/rwsem: Fix checkpatch.pl warnings
locking/rwsem: Fix warnings for CONFIG_RWSEM_GENERIC_SPINLOCK
locking/rwsem: Support optimistic spinning
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull more PCI updates from Bjorn Helgaas:
"Here are some more things I'd like to see in v3.16-rc1:
- DMA alias iterator, part of some work to fix IOMMU issues
- MVEBU, Tegra, DesignWare changes that I forgot to include before
- Some whitespace code cleanup
Details:
IOMMU
- Add DMA alias iterator (Alex Williamson)
- Add DMA alias quirks for ASMedia, ITE, Tundra bridges (Alex Williamson)
- Add DMA alias quirks for Marvell, Ricoh devices (Alex Williamson)
- Add DMA alias quirk for HighPoint devices (Jérôme Carretero)
MSI
- Fix leak in free_msi_irqs() (Alexei Starovoitov)
Marvell MVEBU
- Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray)
- Avoid setting an undefined window size (Jason Gunthorpe)
- Allow several windows with the same target/attribute (Thomas Petazzoni)
- Split PCIe BARs into multiple MBus windows when needed (Thomas Petazzoni)
- Fix off-by-one in the computed size of the mbus windows (Willy Tarreau)
NVIDIA Tegra
- Use new OF interrupt mapping when possible (Lucas Stach)
Synopsys DesignWare
- Split Exynos and i.MX bindings (Lucas Stach)
- Fix comment for setting number of lanes (Mohit Kumar)
- Fix iATU programming for cfg1, io and mem viewport (Mohit Kumar)
Miscellaneous
- EXPORT_SYMBOL cleanup (Ryan Desfosses)
- Whitespace cleanup (Ryan Desfosses)
- Merge multi-line quoted strings (Ryan Desfosses)"
* tag 'pci-v3.16-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (21 commits)
PCI: Add function 1 DMA alias quirk for HighPoint RocketRaid 642L
PCI/MSI: Fix memory leak in free_msi_irqs()
PCI: Merge multi-line quoted strings
PCI: Whitespace cleanup
PCI: Move EXPORT_SYMBOL so it immediately follows function/variable
PCI: Add bridge DMA alias quirk for ITE bridge
PCI: designware: Split Exynos and i.MX bindings
PCI: Add bridge DMA alias quirk for ASMedia and Tundra bridges
PCI: Add support for PCIe-to-PCI bridge DMA alias quirks
PCI: Add function 1 DMA alias quirk for Marvell devices
PCI: Add function 0 DMA alias quirk for Ricoh devices
PCI: Add support for DMA alias quirks
PCI: Convert pci_dev_flags definitions to bit shifts
PCI: Add DMA alias iterator
PCI: mvebu: Use '%pa' for printing 'phys_addr_t' type
PCI: mvebu: Remove unnecessary use of 'conf_lock' spinlock
PCI: designware: Remove unnecessary use of 'conf_lock' spinlock
PCI: designware: Use new OF interrupt mapping when possible
PCI: designware: Fix iATU programming for cfg1, io and mem viewport
PCI: designware: Fix comment for setting number of lanes
Pull more ACPI and power management updates from Rafael Wysocki:
"These are fixups on top of the previous PM+ACPI pull request,
regression fixes (ACPI hotplug, cpufreq ppc-corenet), other bug fixes
(ACPI reset, cpufreq), new PM trace points for system suspend
profiling and a copyright notice update.
Specifics:
- I didn't remember correctly that the Hans de Goede's ACPI video
patches actually didn't flip the video.use_native_backlight
default, although we had discussed that and decided to do that.
Since I said we would do that in the previous PM+ACPI pull request,
make that change for real now.
- ACPI bus check notifications for PCI host bridges don't cause the
bus below the host bridge to be checked for changes as they should
because of a mistake in the ACPI-based PCI hotplug (ACPIPHP)
subsystem that forgets to add hotplug contexts to PCI host bridge
ACPI device objects. Create hotplug contexts for PCI host bridges
too as appropriate.
- Revert recent cpufreq commit related to the big.LITTLE cpufreq
driver that breaks arm64 builds.
- Fix for a regression in the ppc-corenet cpufreq driver introduced
during the 3.15 cycle and causing the driver to use the remainder
from do_div instead of the quotient. From Ed Swarthout.
- Resets triggered by panic activate a BUG_ON() in vmalloc.c on
systems where the ACPI reset register is located in memory address
space. Fix from Randy Wright.
- Fix for a problem with cpufreq governors that decisions made by
them may be suboptimal due to the fact that deferrable timers are
used by them for CPU load sampling. From Srivatsa S Bhat.
- Fix for a problem with the Tegra cpufreq driver where the CPU
frequency is temporarily switched to a "stable" level that is
different from both the initial and target frequencies during
transitions which causes udelay() to expire earlier than it should
sometimes. From Viresh Kumar.
- New trace points and rework of some existing trace points for
system suspend/resume profiling from Todd Brandt.
- Assorted cpufreq fixes and cleanups from Stratos Karafotis and
Viresh Kumar.
- Copyright notice update for suspend-and-cpuhotplug.txt from
Srivatsa S Bhat"
* tag 'pm+acpi-3.16-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / hotplug / PCI: Add hotplug contexts to PCI host bridges
PM / sleep: trace events for device PM callbacks
cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR
cpufreq: tegra: update comment for clarity
cpufreq: intel_pstate: Remove duplicate CPU ID check
cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag
PM / Documentation: Update copyright in suspend-and-cpuhotplug.txt
cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info'
cpufreq: governor: Be friendly towards latency-sensitive bursty workloads
PM / sleep: trace events for suspend/resume
cpufreq: ppc-corenet-cpu-freq: do_div use quotient
Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64"
cpufreq: Tegra: implement intermediate frequency callbacks
cpufreq: add support for intermediate (stable) frequencies
ACPI / video: Change the default for video.use_native_backlight to 1
ACPI: Fix bug when ACPI reset register is implemented in system memory
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED updates from Bryan Wu:
"I just found merge window is open and I'm quite busy and almost forget
to send out this pull request. Thanks Russell and Alexandre ping me
about this.
So basically we got some clean up and leds-pwm fixing patches from
Russell"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds:
leds: Remove duplicated OOM message for individual driver
drivers/leds: Replace __get_cpu_var use through this_cpu_ptr
leds: lp55xx: add DT bindings for LP55231
leds: 88pm860x: Fix missing refcount decrement for parent of_node
leds: 88pm860x: Use of_get_child_by_name
leds: leds-pwm: add DT support for LEDs wired to supply
leds: leds-pwm: implement PWM inversion
leds: leds-pwm: convert OF parsing code to use led_pwm_add()
leds: leds-pwm: provide a common function to setup a single led-pwm device
leds: pca9685: Remove leds-pca9685 driver
dell-led: add mic mute led interface
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull more MFD updates from Lee Jones:
"I missed collecting these patches due to a branch/tag naming
ambiguity. Completely my own fault, as I mindlessly named a branch
and tag identically. Sorry for the fuss.
This pull-request contains some misplaced patches from Tony Lindgren
that should have been part of the initial one"
* tag 'mfd-for-linus-3.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd:
mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle
mfd: twl4030-power: Add support for board specific configuration
mfd: twl4030-power: Add recommended idle configuration
mfd: twl4030-power: Add generic reset configuration
mfd: twl4030-power: Fix some defines for SW_EVENTS
mfd: twl4030-power: Fix hang on reboot if sleep configuration was loaded earlier
Pull drm updates from Dave Airlie:
"This is the main drm merge window pull request, changes all over the
place, mostly normal levels of churn.
Highlights:
Core drm:
More cleanups, fix race on connector/encoder naming, docs updates,
object locking rework in prep for atomic modeset
i915:
mipi DSI support, valleyview power fixes, cursor size fixes,
execlist refactoring, vblank improvements, userptr support, OOM
radeon:
GPUVM tuning and large page size support, gart fixes, deep color
HDMI support, HDMI audio cleanups
nouveau:
- displayport rework should fix lots of issues
- initial gk20a support
- gk110b support
- gk208 fixes
exynos:
probe order fixes, HDMI changes, IPP consolidation
msm:
debugfs updates, misc fixes
ast:
ast2400 support, sync with UMS driver
tegra:
cleanups, hdmi + hw cursor for Tegra 124.
panel:
fixes existing panels add some new ones.
ipuv3:
moved from staging to drivers/gpu"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits)
drm/nouveau/disp/dp: fix tmds passthrough on dp connector
drm/nouveau/dp: probe dpcd to determine connectedness
drm/nv50-: trigger update after all connectors disabled
drm/nv50-: prepare for attaching a SOR to multiple heads
drm/gf119-/disp: fix debug output on update failure
drm/nouveau/disp/dp: make use of postcursor when its available
drm/g94-/disp/dp: take max pullup value across all lanes
drm/nouveau/bios/dp: parse lane postcursor data
drm/nouveau/dp: fix support for dpms
drm/nouveau: register a drm_dp_aux channel for each dp connector
drm/g94-/disp: add method to power-off dp lanes
drm/nouveau/disp/dp: maintain link in response to hpd signal
drm/g94-/disp: bash and wait for something after changing lane power regs
drm/nouveau/disp/dp: split link config/power into two steps
drm/nv50/disp: train PIOR-attached DP from second supervisor
drm/nouveau/disp/dp: make use of existing output data for link training
drm/gf119/disp: start removing direct vbios parsing from supervisor
drm/nv50/disp: start removing direct vbios parsing from supervisor
drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal
drm/nouveau/disp/dp: create subclass for dp outputs
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
Add support for Sensirion SHTC1 and compatible temperature and humidity
sensors.
Signed-off-by: Tomas Pop <tomas.pop@sensirion.com>
* pm-cpufreq:
Backmerge of dcache.c changes from mainline. It's that, or complete
rebase...
fs/splice.c
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Most of this is cleaning up various driver sysfs permissions so we can
re-add the perm check (we unified the module param and sysfs checks,
but the module ones were stronger so we weakened them temporarily).
Param parsing gets documented, and also "--" now forces args to be
handed to init (and ignored by the kernel).
Module NX/RO protections get tightened: we now set them before calling
parse_args()"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: set nx before marking module MODULE_STATE_COMING.
samples/kobject/: avoid world-writable sysfs files.
drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files.
drivers/staging/speakup/: avoid world-writable sysfs files.
drivers/regulator/virtual: avoid world-writable sysfs files.
drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files.
drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files.
drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files.
drivers/mtd/devices/docg3.c: avoid world-writable sysfs files.
speakup: fix incorrect perms on speakup_acntsa.c
cpumask.h: silence warning with -Wsign-compare
Documentation: Update kernel-parameters.tx
param: hand arguments after -- straight to init
modpost: Fix resource leak in read_dump()
This patch adds a description of eBPFs instruction encoding in order
to bring the documentation in line with the implementation.
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Since the term eBPF is used anyway on mailing list discussions, lets
also document that in the main BPF documentation file and replace a
couple of occurrences with eBPF terminology to be more clear.
P2WI (Push/Pull 2 Wire Interface) is an SMBus like bus used to communicate
with some PMICs (like the AXP221).
Document P2WI DT bindings which are pretty much the same as the one defined
for the marvell's mv64xxx controller.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Driver for the native I2C adapter found in Rockchip RK3xxx SoCs.
Configuration is only possible through devicetree. The driver is
interrupt driven and supports the I2C_M_IGNORE_NAK mangling bit.
Signed-off-by: Max Schwarz <max.schwarz@online.de>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management update from Zhang Rui:
"Specifics:
- fix a bug in Exynos thermal driver, which overwrites the hardware
trip point threshold when updating software trigger levels and
results in emergency shutdown. From: Tushar Behera.
- add thermal sensor support for Armada 375 and 38x SoCs. From
Ezequiel Garcia.
- add TMU (Thermal Management Unit) support for Exynos5260 and
Exynos5420 SoCs. From Naveen Krishna Chatradhi.
- add support for the additional digital temperature sensors in the
Intel SoCs like Bay Trail. From: Srinivas Pandruvada.
- a couple of cleanups and small fixes from Jingoo Han, Bartlomiej
Zolnierkiewicz, Geert Uytterhoeven, Jacob Pan, Paul Walmsley and
Lan,Tianyu"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (21 commits)
thermal: spear: remove unnecessary OOM messages
thermal: exynos: remove unnecessary OOM messages
thermal: rcar: remove unnecessary OOM messages
thermal: armada: Support Armada 380 SoC
thermal: armada: Support Armada 375 SoC
thermal: armada: Allow to specify an 'inverted readout' sensor
thermal: armada: Pass the platform_device to init_sensor()
thermal: armada: Add generic infrastructure to handle the sensor
thermal: armada: Add infrastructure to support generic formulas
thermal: armada: Rename armada_thermal_ops struct
thermal/intel_powerclamp: add newer cpu ids
thermal: rcar: Use pm_runtime_put() i.s.o. pm_runtime_put_sync()
thermal: samsung: Only update available threshold limits
Thermal/int3403: Fix thermal hysteresis unit conversion
thermal: Intel SoC DTS thermal
thermal: samsung: Add TMU support for Exynos5260 SoCs
thermal: samsung: Add TMU support for Exynos5420 SoCs
thermal: samsung: change base_common to more meaningful base_second
thermal: samsung: replace inten_ bit fields with intclr_
thermal: offer Samsung thermal support only when ARCH_EXYNOS is defined
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm changes from Thierry Reding:
"The majority of these changes are cleanups and fixes across all
drivers. Redundant error messages are removed and more PWM
controllers set the .can_sleep flag to signal that they can't be used
in atomic context.
Support is added for the Broadcom Kona family of SoCs and the Intel
LPSS driver can now probe PCI devices in addition to ACPI devices.
Upon shutdown, the pwm-backlight driver will now power off the
backlight. It also uses the new descriptor-based GPIO API for more
concise GPIO handling.
A large chunk of these changes also converts platforms to use the
lookup mechanism rather than relying on the global number space to
reference PWM devices. This is largely in preparation for more
unification and cleanups in future patches. Eventually it will allow
the legacy PWM API to be removed"
* tag 'pwm/for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (38 commits)
pwm: fsl-ftm: set pwm_chip can_sleep flag
pwm: ab8500: Fix wrong value shift for disable/enable PWM
pwm: samsung: do not set manual update bit in pwm_samsung_config
pwm: lp3943: Set pwm_chip can_sleep flag
pwm: atmel: set pwm_chip can_sleep flag
pwm: mxs: set pwm_chip can_sleep flag
pwm: tiehrpwm: inline accessor functions
pwm: tiehrpwm: don't build PM related functions when not needed
pwm-backlight: retrieve configured PWM period
leds: leds-pwm: retrieve configured PWM period
ARM: pxa: hx4700: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: shmobile: armadillo: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: OMAP3: Beagle: use PWM_LOOKUP to initialize struct pwm_lookup
pwm: modify PWM_LOOKUP to initialize all struct pwm_lookup members
ARM: pxa: hx4700: initialize all the struct pwm_lookup members
ARM: OMAP3: Beagle: initialize all the struct pwm_lookup members
pwm: renesas-tpu: remove unused struct tpu_pwm_platform_data
ARM: shmobile: armadillo: initialize all struct pwm_lookup members
pwm: add period and polarity to struct pwm_lookup
pwm: twl: Really disable twl6030 PWMs
Pull MTD updates from Brian Norris:
- refactor m25p80.c driver for use as a general SPI NOR framework for
other drivers which may speak to SPI NOR flash without providing full
SPI support (i.e., not part of drivers/spi/)
- new Freescale QuadSPI driver (utilizing new SPI NOR framework)
- updates for the STMicro "FSM" SPI NOR driver
- fix sync/flush behavior on mtd_blkdevs
- fixup subpage write support on a few NAND drivers
- correct the MTD OOB test for odd-sized OOB areas
- add BCH-16 support for OMAP NAND
- fix warnings and trivial refactoring
- utilize new ECC DT bindings in pxa3xx NAND driver
- new LPDDR NVM driver
- address a few assorted bugs caught by Coverity
- add new imx6sx support for GPMI NAND
- use a bounce buffer for NAND when non-DMA-able buffers are used
* tag 'for-linus-20140610' of git://git.infradead.org/linux-mtd: (77 commits)
mtd: gpmi: add gpmi support for imx6sx
mtd: maps: remove check for CONFIG_MTD_SUPERH_RESERVE
mtd: bf5xx_nand: use the managed version of kzalloc
mtd: pxa3xx_nand: make the driver work on big-endian systems
mtd: nand: omap: fix omap_calculate_ecc_bch() for-loop error
mtd: nand: r852: correct write_buf loop bounds
mtd: nand_bbt: handle error case for nand_create_badblock_pattern()
mtd: nand_bbt: remove unused variable
mtd: maps: sc520cdp: fix warnings
mtd: slram: fix unused variable warning
mtd: pfow: remove unused variable
mtd: lpddr: fix Kconfig dependency, for I/O accessors
mtd: nand: pxa3xx: Add supported ECC strength and step size to the DT binding
mtd: nand: pxa3xx: Use ECC strength and step size devicetree binding
mtd: nand: pxa3xx: Clean pxa_ecc_init() error handling
mtd: nand: Warn the user if the selected ECC strength is too weak
mtd: nand: omap: Documentation: How to select correct ECC scheme for your device ?
mtd: nand: omap: add support for BCH16_ECC - NAND driver updates
mtd: nand: omap: add support for BCH16_ECC - ELM driver updates
mtd: nand: omap: add support for BCH16_ECC - GPMC driver updates
Document new compatible strings for clock provided by the PRCM
(Power/Reset/Clock Management) unit.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Support for the USB gates and resets on A31 has been recently added
using a new compatible, so let's document it here.
The macro 'A' used in internal BPF interpreter:
#define A regs[insn->a_reg]
was easily confused with the name of classic BPF register 'A', since
'A' would mean two different things depending on context.
This patch is trying to clean up the naming and clarify its usage in the
following way:
- A and X are names of two classic BPF registers
- BPF_REG_A denotes internal BPF register R0 used to map classic register A
in internal BPF programs generated from classic
- BPF_REG_X denotes internal BPF register R7 used to map classic register X
- internal BPF instruction format:
struct sock_filter_int {
__u8 code; /* opcode */
__u8 dst_reg:4; /* dest register */
__u8 src_reg:4; /* source register */
__s16 off; /* signed offset */
__s32 imm; /* signed immediate constant */
- BPF_X/BPF_K is 1 bit used to encode source operand of instruction
In classic:
BPF_X - means use register X as source operand
BPF_K - means use 32-bit immediate as source operand
In internal:
BPF_X - means use 'src_reg' register as source operand
Suggested-by: Chema Gonzalez <chema@google.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Chema Gonzalez <chema@google.com>
Pull watchdog updates from Wim Van Sebroeck:
"This contains:
- addition of the Intel MID watchdog
- removal of W83697HF and W83697UG drivers (code was merged into
w83627hf_wdt driver)
- addition of Armada 375/380 SoC support
- conversion of imx2_wdt to regmap API and to watchdog core API
- lots of other small improvements and fixes"
[ Wim was also tagged by gmail as a spammer, but not delayed by days
unlike Ben ]
* git://www.linux-watchdog.org/linux-watchdog: (25 commits)
x86: intel-mid: add watchdog platform code for Merrifield
watchdog: add Intel MID watchdog driver support
watchdog: sp805: Set watchdog_device->timeout from ->set_timeout()
booke/watchdog: refine and clean up the codes
watchdog: iop_wdt only builds for mach-iop13xx
watchdog: Remove drivers for W83697HF and W83697UG
watchdog: w83627hf_wdt: Add early_disable module parameter
ARM: mvebu: Add A375/A380 watchdog binding documentation
watchdog: orion: Add Armada 375/380 SoC support
watchdog: orion: Introduce per-SoC enabled() function
watchdog: orion: Introduce per-SoC stop() function
watchdog: orion: Remove unneeded atomic access
watchdog: orion: Introduce a SoC-specific RSTOUT mapping
watchdog: orion: Move the register ioremap'ing to its own function
watchdog: xilinx: Make of_device_id array const
watchdog: imx2_wdt: convert to watchdog core api
watchdog: imx2_wdt: convert to use regmap API.
watchdog: imx2_wdt: Sort the header files alphabetically
watchdog: ath79_wdt: switch to clk_prepare/clk_disable
watchdog: ath79_wdt: avoid spurious restarts on AR934x
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"Here is the bulk of the powerpc changes for this merge window. It got
a bit delayed in part because I wasn't paying attention, and in part
because I discovered I had a core PCI change without a PCI maintainer
ack in it. Bjorn eventually agreed it was ok to merge it though we'll
probably improve it later and I didn't want to rebase to add his ack.
There is going to be a bit more next week, essentially fixes that I
still want to sort through and test.
The biggest item this time is the support to build the ppc64 LE kernel
with our new v2 ABI. We previously supported v2 userspace but the
kernel itself was a tougher nut to crack. This is now sorted mostly
thanks to Anton and Rusty.
We also have a fairly big series from Cedric that add support for
64-bit LE zImage boot wrapper. This was made harder by the fact that
traditionally our zImage wrapper was always 32-bit, but our new LE
toolchains don't really support 32-bit anymore (it's somewhat there
but not really "supported") so we didn't want to rely on it. This
meant more churn that just endian fixes.
This brings some more LE bits as well, such as the ability to run in
LE mode without a hypervisor (ie. under OPAL firmware) by doing the
right OPAL call to reinitialize the CPU to take HV interrupts in the
right mode and the usual pile of endian fixes.
There's another series from Gavin adding EEH improvements (one day we
*will* have a release with less than 20 EEH patches, I promise!).
Another highlight is the support for the "Split core" functionality on
P8 by Michael. This allows a P8 core to be split into "sub cores" of
4 threads which allows the subcores to run different guests under KVM
(the HW still doesn't support a partition per thread).
And then the usual misc bits and fixes ..."
[ Further delayed by gmail deciding that BenH is a dirty spammer.
Google knows. ]
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (155 commits)
powerpc/powernv: Add missing include to LPC code
selftests/powerpc: Test the THP bug we fixed in the previous commit
powerpc/mm: Check paca psize is up to date for huge mappings
powerpc/powernv: Pass buffer size to OPAL validate flash call
powerpc/pseries: hcall functions are exported to modules, need _GLOBAL_TOC()
powerpc: Exported functions __clear_user and copy_page use r2 so need _GLOBAL_TOC()
powerpc/powernv: Set memory_block_size_bytes to 256MB
powerpc: Allow ppc_md platform hook to override memory_block_size_bytes
powerpc/powernv: Fix endian issues in memory error handling code
powerpc/eeh: Skip eeh sysfs when eeh is disabled
powerpc: 64bit sendfile is capped at 2GB
powerpc/powernv: Provide debugfs access to the LPC bus via OPAL
powerpc/serial: Use saner flags when creating legacy ports
powerpc: Add cpu family documentation
powerpc/xmon: Fix up xmon format strings
powerpc/powernv: Add calls to support little endian host
powerpc: Document sysfs DSCR interface
powerpc: Fix regression of per-CPU DSCR setting
powerpc: Split __SYSFS_SPRSETUP macro
arch: powerpc/fadump: Cleaning up inconsistent NULL checks
Pull x86 platform driver updates from Matthew Garrett:
"Very little of excitement here - the most significant is a new driver
for detecting device freefall on Dells, other than that it's pretty
much entirely minor fixes for specific machines"
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86:
hp-wmi: Enable hotkeys on some systems
thinkpad_acpi: Add mappings for F9 - F12 hotkeys on X240 / T440 / T540
platform: x86: dell-smo8800: Dell Latitude freefall driver (ACPI SMO8800/SMO8810)
ideapad_laptop: Introduce the use of the managed version of kzalloc
platform/x86: Fix run-time dependencies of OLPC drivers
platform: x86: asus-wmi.c: Cleaning up uninitialized variables
ix86/mid/thermal: Introduce the use of the managed version of kzalloc
platform x86 Kconfig: Refer to the laptop list in the Compal driver help
Documentation: Add list of laptop models supported by the Compal driver
ideapad-laptop: Blacklist rfkill control on the Lenovo Yoga 2 11
asus-wmi: Set WAPF to 4 for Asus X550CA
alienware-wmi: For WMAX HDMI method, introduce a way to query HDMI cable status
alienware-wmi: Update WMAX brightness method limit to 15
pvpanic: Set high notifier priority
platform/x86: samsung-laptop: Add support for Samsung's NP7[34]0U3E models.
toshiba_acpi: Add alternative keymap support for Satellite M840
platform-drivers-x86: intel_pmic_gpio: Fix off-by-one valid offset range check
