commit 9d8dad742ad1c74d7e7210ee05d0b44961d5ea16 upstream.
The higher ptrace restriction levels should be blocking even
PTRACE_TRACEME requests. The comments in the LSM documentation are
misleading about when the checks happen (the parent does not go through
security_ptrace_access_check() on a PTRACE_TRACEME call).
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 2584f5212d97b664be250ad5700a2d0fee31a10d upstream.
Also add information on where the respective trees are.
Acked-by: Rob Landley <rob@landley.net>
commit 108cc108a3bb42fe4705df1317ff98e1e29428a6 upstream.
Also add a model/fixup string "lenovo-dock", so that other Thinkpad
users will be able to test this fixup easily, to see if it enables
dock I/O for them as well.
BugLink: https://bugs.launchpad.net/bugs/1026953
Tested-by: John McCarron <john.mccarron@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
The referenced html file does not exist anymore. Replace the URL with
the current project homepage.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull late pinctrl fixes from Linus Walleij:
- Two fixes to the i.MX driver
* tag 'fixes-for-v3.5-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: pinctrl-imx6q: add missed mux function for USBOTG_ID
pinctrl: pinctrl-imx: only print debug message when DEBUG is defined
The original pin registers table is derived from u-boot mainline,
but somehow it was found missing some mux functions for USBOTG_ID.
We added it at the bottom by following the exist pin function ids,
then it will not break the exist using of pin function id in dts file.
Reported-by: Richard Zhao <richard.zhao@freescale.com>
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- Some regression fixes at the audio part for devices with
cx23885/cx25840
- A DMA corruption fix at cx231xx
- two fixes at the winbond IR driver
- Several fixes for the EXYNOS media driver (s5p)
- two fixes at the OMAP3 preview driver
- one fix at the dvb core failure path
- an include missing (slab.h) at smiapp-core causing compilation
breakage
- em28xx was not loading the IR driver driver anymore.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (31 commits)
[media] Revert "[media] V4L: JPEG class documentation corrections"
[media] s5p-fimc: Add missing FIMC-LITE file operations locking
[media] omap3isp: preview: Fix contrast and brightness handling
[media] omap3isp: preview: Fix output size computation depending on input format
[media] winbond-cir: Initialise timeout, driver_type and allowed_protos
[media] winbond-cir: Fix txandrx module info
[media] cx23885: Silence unknown command warnings
[media] cx23885: add support for HVR-1255 analog (cx23888 variant)
[media] cx23885: make analog support work for HVR_1250 (cx23885 variant)
[media] cx25840: fix vsrc/hsrc usage on cx23888 designs
[media] cx25840: fix regression in HVR-1800 analog audio
[media] cx25840: fix regression in analog support hue/saturation controls
[media] cx25840: fix regression in HVR-1800 analog support
[media] s5p-mfc: Fixed setup of custom controls in decoder and encoder
[media] cx231xx: don't DMA to random addresses
[media] em28xx: fix em28xx-rc load
[media] dvb-core: Release semaphore on error path dvb_register_device()
[media] s5p-fimc: Stop media entity pipeline if fimc_pipeline_validate fails
[media] s5p-fimc: Fix compiler warning in fimc-lite.c
[media] s5p-fimc: media_entity_pipeline_start() may fail
Pull late MTD fixes from David Woodhouse:
- fix 'sparse warning fix' regression which totally breaks MXC NAND
- fix GPMI NAND regression when used with UBI
- update/correct sysfs documentation for new 'bitflip_threshold' field
- fix nandsim build failure
* tag 'for-linus-20120712' of git://git.infradead.org/linux-mtd:
mtd: nandsim: don't open code a do_div helper
mtd: ABI documentation: clarification of bitflip_threshold
mtd: gpmi-nand: fix read page when reading to vmalloced area
mtd: mxc_nand: use 32bit copy functions
The documentation didn't actually mention how to enable no_new_privs.
This also adds a note about possible interactions between
no_new_privs and LSMs (i.e. why teaching systemd to set no_new_privs
is not necessarily a good idea), and it references the new docs
from include/linux/prctl.h.
Suggested-by: Rob Landley <rob@landley.net>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
This reverts commit feed0258e11e04b7e0, as the same issues
are already covered in another version of that patch that
was also applied (579e92ffac65c717c9c8a50feb755a).
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
The -EUCLEAN return value applies to mtd_read_oob() as well as mtd_read(), but
only mtd_read() was mentioned in the blurd on bitflip_threshold in the ABI
documentation.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Pull KVM fix from Marcelo Tosatti:
"Memory leak and oops on the x86 mmu code, and sanitization of the
KVM_IRQFD ioctl."
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: MMU: fix shrinking page from the empty mmu
KVM: fix fault page leak
KVM: Sanitize KVM_IRQFD flags
KVM: Add missing KVM_IRQFD API documentation
KVM: Pass kvm_irqfd to functions
Pull DT fixes from Rob Herring:
"Mainly some documentation updates and 2 fixes:
- An export symbol fix for of_platform_populate from Stephen W.
- A fix for the order compatible entries are matched to ensure the
first compatible string is matched when there are multiple matches."
Normally these would go through Grant Likely (thus the "fixes-for-grant"
branch name), but Grant is in the middle of moving to Scotland, and is
practically offline until sometime in August. So pull directly from Rob.
* 'fixes-for-grant' of git://sources.calxeda.com/kernel/linux:
of: match by compatible property first
dt: mc13xxx.txt: Fix gpio number assignment
dt: fsl-fec.txt: Fix gpio number assignment
dt: fsl-mma8450.txt: Add missing 'reg' description
dt: fsl-imx-esdhc.txt: Fix gpio number assignment
dt: fsl-imx-cspi.txt: Fix comment about GPIOs used for chip selects
of: Add Avionic Design vendor prefix
of: export of_platform_populate()
Pull block bits from Jens Axboe:
"As vacation is coming up, thought I'd better get rid of my pending
changes in my for-linus branch for this iteration. It contains:
- Two patches for mtip32xx. Killing a non-compliant sysfs interface
and moving it to debugfs, where it belongs.
- A few patches from Asias. Two legit bug fixes, and one killing an
interface that is no longer in use.
- A patch from Jan, making the annoying partition ioctl warning a bit
less annoying, by restricting it to !CAP_SYS_RAWIO only.
- Three bug fixes for drbd from Lars Ellenberg.
- A fix for an old regression for umem, it hasn't really worked since
the plugging scheme was changed in 3.0.
- A few fixes from Tejun.
- A splice fix from Eric Dumazet, fixing an issue with pipe
resizing."
* 'for-linus' of git://git.kernel.dk/linux-block:
scsi: Silence unnecessary warnings about ioctl to partition
block: Drop dead function blk_abort_queue()
block: Mitigate lock unbalance caused by lock switching
block: Avoid missed wakeup in request waitqueue
umem: fix up unplugging
splice: fix racy pipe->buffers uses
drbd: fix null pointer dereference with on-congestion policy when diskless
drbd: fix list corruption by failing but already aborted reads
drbd: fix access of unallocated pages and kernel panic
xen/blkfront: Add WARN to deal with misbehaving backends.
blkcg: drop local variable @q from blkg_destroy()
mtip32xx: Create debugfs entries for troubleshooting
mtip32xx: Remove 'registers' and 'flags' from sysfs
blkcg: fix blkg_alloc() failure path
block: blkcg_policy_cfq shouldn't be used if !CONFIG_CFQ_GROUP_IOSCHED
block: fix return value on cfq_init() failure
mtip32xx: Remove version.h header file inclusion
xen/blkback: Copy id field when doing BLKIF_DISCARD.
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull device-mapper fixes from Alasdair G Kergon:
"Four minor thin provisioning fixes and correct and update dm-verity
documentation."
* tag 'dm-3.5-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm:
dm: verity fix documentation
dm persistent data: fix allocation failure in space map checker init
dm persistent data: handle space map checker creation failure
dm persistent data: fix shadow_info_leak on dm_tm_destroy
dm thin: commit metadata before creating metadata snapshot
Veritysetup is now part of cryptsetup package.
Remove on-disk header description (which is not parsed in kernel)
and point users to cryptsetup where it the format is documented.
Mention units for block size paramaters.
Fix target line specification and dmsetup parameters.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Cc: stable@kernel.org
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Document no_new_privs.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver Core fixes from Greg Kroah-Hartman:
"Here is a number of printk() fixes, specifically a few reported by the
crazy blog program that ships in SUSE releases (that's "boot log" and
not "web log", it predates the general "blog" terminology by many
years), and the restoration of the continuation line functionality
reported by Stephen and others. Yes, the changes seem a bit big this
late in the cycle, but I've been beating on them for a while now, and
Stephen has even optimized it a bit, so all looks good to me.
The other change in here is a Documentation update for the stable
kernel rules describing how some distro patches should be backported,
to hopefully drive a bit more response from the distros to the stable
kernel releases.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'driver-core-3.5-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
printk: Optimize if statement logic where newline exists
printk: flush continuation lines immediately to console
syslog: fill buffer with more than a single message for SYSLOG_ACTION_READ
Revert "printk: return -EINVAL if the message len is bigger than the buf size"
printk: fix regression in SYSLOG_ACTION_CLEAR
stable: Allow merging of backports for serious user-visible performance issues
Pull media fixes from Mauro Carvalho Chehab.
Trivial conflict due to new USB HID ID's being added next to each other
(Baanto vs Axentia).
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (44 commits)
[media] smia: Fix compile failures
[media] Fix VIDIOC_DQEVENT docbook entry
[media] s5p-fimc: Fix control creation function
[media] s5p-mfc: Fix checkpatch error in s5p_mfc_shm.h file
[media] s5p-mfc: Fix setting controls
[media] v4l/s5p-mfc: added image size align in VIDIOC_TRY_FMT
[media] v4l/s5p-mfc: corrected encoder v4l control definitions
[media] v4l: mem2mem_testdev: Fix race conditions in driver
[media] s5p-mfc: Bug fix of timestamp/timecode copy mechanism
[media] cxd2820r: Fix an incorrect modulation type bitmask
[media] em28xx: Show a warning if the board does not support remote controls
[media] em28xx: Add remote control support for Terratec's Cinergy HTC Stick HD
[media] USB: Staging: media: lirc: initialize spinlocks before usage
[media] Revert "[media] media: mx2_camera: Fix mbus format handling"
[media] bw-qcam: driver and pixfmt documentation fixes
[media] cx88: fix firmware load on big-endian systems
[media] cx18: support big-endian systems
[media] ivtv: fix support for big-endian systems
[media] tuner-core: return the frequency range of the correct tuner
[media] v4l2-dev.c: fix g_parm regression in determine_valid_ioctls()
Distribution kernel maintainers routinely backport fixes for users that
were deemed important but not "something critical" as defined by the
rules. To users of these kernels they are very serious and failing to fix
them reduces the value of -stable.
The problem is that the patches fixing these issues are often subtle and
prone to regressions in other ways and need greater care and attention.
To combat this, these "serious" backports should have a higher barrier
to entry.
This patch relaxes the rules to allow a distribution maintainer to merge
to -stable a backported patch or small series that fixes a "serious"
user-visible performance issue. They should include additional information on
the user-visible bug affected and a link to the bugzilla entry if available.
The same rules about the patch being already in mainline still apply.
Cc: stable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree fixes from Greg Kroah-Hartman:
"Here are a number of small fixes for the drivers/staging tree, as well
as iio and pstore drivers (which came from the staging tree in the
3.5-rc1 merge). All of these are tiny, but resolve issues that people
have been reporting.
There's also a documentation update to reflect what the iio drivers
really are doing, which is good to get straightened out.
* tag 'staging-3.5-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: r8712u: Add new USB IDs
staging: gdm72xx: Release netlink socket properly
iio: drop wrong reference from Kconfig
pstore/inode: Make pstore_fill_super() static
pstore/ram: Should zap persistent zone on unlink
pstore/ram_core: Factor persistent_ram_zap() out of post_init()
pstore/ram_core: Do not reset restored zone's position and size
pstore/ram: Should update old dmesg buffer before reading
staging:iio:ad7298: Fix linker error due to missing IIO kfifo buffer
Revert "staging: usbip: bugfix for stack corruption on 64-bit architectures"
staging/comedi: fix build for USB not enabled
staging: omapdrm: fix crash when freeing bad fb
staging:iio:ad7606: Re-add missing scale attribute
iio: Fix potential use after free
staging:iio: remove num_interrupt_lines from documentation
iio: documentation: Add out_altvoltage and friends
* emailed from Andrew Morton <akpm@linux-foundation.org>: (21 patches)
mm/memblock: fix overlapping allocation when doubling reserved array
c/r: prctl: Move PR_GET_TID_ADDRESS to a proper place
pidns: find_new_reaper() can no longer switch to init_pid_ns.child_reaper
pidns: guarantee that the pidns init will be the last pidns process reaped
fault-inject: avoid call to random32() if fault injection is disabled
Viresh has moved
get_maintainer: Fix --help warning
mm/memory.c: fix kernel-doc warnings
mm: fix kernel-doc warnings
mm: correctly synchronize rss-counters at exit/exec
mm, thp: print useful information when mmap_sem is unlocked in zap_pmd_range
h8300: use the declarations provided by <asm/sections.h>
h8300: fix use of extinct _sbss and _ebss
xtensa: use the declarations provided by <asm/sections.h>
xtensa: use "test -e" instead of bashism "test -a"
xtensa: replace xtensa-specific _f{data,text} by _s{data,text}
memcg: fix use_hierarchy css_is_ancestor oops regression
mm, oom: fix and cleanup oom score calculations
nilfs2: ensure proper cache clearing for gc-inodes
thp: avoid atomic64_read in pmd_read_atomic for 32bit PAE
viresh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with viresh.linux@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'
Signed-off-by: Viresh Kumar <viresh.linux@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
Tjmax values from Intel datasheets.
Document the Atom series D2000 and N2000 (Cedar Trail) as being supported.
List and set TjMax for those series.
Cc: "R, Durgadoss" <durgadoss.r@intel.com>
Document the new Atom series (Tunnel Creek and Medfield) as being
supported, and list TjMax for the Atom E600 series.
Also enable the Atom tjmax heuristic for these Atom CPU models.
Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Alexander Stein <alexander.stein@systec-electronic.com>
Pull networking fixes from David S. Miller:
This has the fix for the wireless issues I ran into the other week as
well as:
1) Fix CAN c_can driver transmit handling resulting in BUG check
triggers, from AnilKumar Ch.
2) Fix packet drop monitor sleeping in atomic context, from Eric
Dumazet.
3) Fix mv643xx_eth driver build regression, from Andrew Lunn.
4) Inetpeer freeing needs an RCU grace period in order to avoid races
during tree invalidation. From Eric Dumazet.
5) Fix endianness bugs in xt_HMARK netfilter module, from Hans
Schillstrom.
6) Add proper module refcounting to l2tp_eth to avoid crash on module
unload, from Eric Dumazet.
7) Fix truncation of neighbour entry dumps due to logic errors in
neigh_dump_info() and friends, from Eric Dumazet.
8) The conversion of fib6_age() to dst_neigh_lookup() accidently
reversed the logic of a flags test, fix from Thomas Graf.
9) Fix checksum configuration in newer sky2 chips, from Stephen
Hemminger.
10) Revert BQL support in NIU driver, doesn't work.
11) l2tp_ip_sendmsg() illegally uses a route without a proper reference.
From Eric Dumazet.
12) be2net driver references an SKB after it's potentially been freed,
also from Eric Dumazet.
13) Fix RCU stalls in dummy net driver init. Also from Eric Dumazet.
14) lpc_eth has several bugs in it's transmit engine leading to packet
leaks and improper queue wakes, from Eric Dumazet.
15) Apply short DMA workaround to more tg3 chips, from Matt Carlson.
16) Add tilegx network driver.
17) Bonding queue mapping for a packet can get corrupted, fix from Eric
Dumazet.
18) Fix bug in netpoll_send_udp() SKB management that can leave garbage
in the payload in certain situations. From Eric Dumazet.
19) bnx2x driver interprets chip RX checksum offload incorrectly in
encapsulation situations. Fix from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits)
bnx2x: fix checksum validation
netpoll: fix netpoll_send_udp() bugs
bonding: Fix corrupted queue_mapping
bonding:record primary when modify it via sysfs
tilegx network driver: initial support
tg3: Apply short DMA frag workaround to 5906
net: stmmac: Fix clock en-/disable calls
lpc_eth: fix tx completion
lpc_eth: add missing ndo_change_mtu()
dummy: fix rcu_sched self-detected stalls
net: Reorder initialization in ip_route_output to fix gcc warning
virtio-net: fix a race on 32bit arches
r8169: avoid NAPI scheduling delay.
net: Make linux/tcp.h C++ friendly (trivial)
netdev: fix drivers/net/phy/ kernel-doc warnings
net/core: fix kernel-doc warnings
be2net: fix a race in be_xmit()
l2tp: fix a race in l2tp_ip_sendmsg()
mac80211: add back channel change flag
NFC: Fix possible NULL ptr deref when getting the name of a socket
Fix gpio number assignment, so that it can match the number stated in the comment.
Add missing 'reg' description.
.../devicetree/bindings/input/fsl-mma8450.txt | 1 +
1 files changed, 1 insertions(+), 0 deletions(-)
Cc:
The gpio numbers does not match the comment.
Fix the comments for GPIOs used for chip selects.
This commit adds a device tree vendor prefix for Avionic Design GmbH.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: devicetree-discuss@lists.ozlabs.org
Cc: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Fix the documentation of the Y4 and Y6 formats.
Fix a poll() issue, add support for enum_frmsizes, set the proper
parent device and fix a few compliance issues.
Tested with an actual Connectix B&W parallel port webcam, both on a
little-endian and a big-endian platform. This driver has never been
so good, doing 320x240 at 1 frame per second :-)
I know, nobody cares, but still it is cool that linux can still support
this old webcam.
Two small docbook fixes:
- prepare-buf was not positioned in alphabetical order, moved to the right place.
- the format field in create_bufs had the wrong type in the documentation
Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Patch id 6016af82eafcb6e086a8f2a2197b46029a843d68 ("[media] v4l2: use __u32
rather than enums in ioctl() structs") unintentionally changes the type of
the format field in struct v4l2_create_buffers from struct v4l2_format to
__u32. Revert that change.
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Fixed the driver's documentation that was obsolete and didn't
report new platform fields (recently added).
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
git://git.pengutronix.de/git/wsa/linux
Pull embedded i2c update from Wolfram Sang:
"This only contains one new driver which had multiple dependencies
(pinctrl, i2c-mux-rework, new devm_* functions), so I decided to wait
for rc1. Plus, it had to wait a little for the ack of a devicetree
maintainer since the bindings were not trivial enough for me to pass
through.
So, given that, I hope there is still something like the "new driver
rule", so we could have the driver in 3.5 and people can start using
it. That would make merging support for some boards easier for 3.6
since the dependency on this driver is gone then."
* 'i2c-embedded/for-current' of git://git.pengutronix.de/git/wsa/linux:
i2c: Add generic I2C multiplexer using pinctrl API
This patch removes entries 'registers' and 'flags' from sysfs. Updated ABI file
to reflect this change.
Reported-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com>
Continuous frequency/clock generating devices, such as DDSs or PLLs
should use out_altvoltage.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm
Pull frontswap feature from Konrad Rzeszutek Wilk:
"Frontswap provides a "transcendent memory" interface for swap pages.
In some environments, dramatic performance savings may be obtained
because swapped pages are saved in RAM (or a RAM-like device) instead
of a swap disk. This tag provides the basic infrastructure along with
some changes to the existing backends."
Fix up trivial conflict in mm/Makefile due to removal of swap token code
changing a line next to the new frontswap entry.
This pull request came in before the merge window even opened, it got
delayed to after the merge window by me just wanting to make sure it had
actual users. Apparently IBM is using this on their embedded side, and
Jan Beulich says that it's already made available for SLES and OpenSUSE
users.
Also acked by Rik van Riel, and Konrad points to other people liking it
too. So in it goes.
By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2)
via Konrad Rzeszutek Wilk
* tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm:
frontswap: s/put_page/store/g s/get_page/load
MAINTAINER: Add myself for the frontswap API
mm: frontswap: config and doc files
mm: frontswap: core frontswap functionality
mm: frontswap: core swap subsystem hooks and headers
mm: frontswap: add frontswap header file
Pull timer updates from Thomas Gleixner:
"The clocksource driver is pure hardware enablement and the skew option
is default off, well tested and non dangerous."
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tick: Move skew_tick option into the HIGH_RES_TIMER section
clocksource: em_sti: Add DT support
clocksource: em_sti: Emma Mobile STI driver
clockevents: Make clockevents_config() a global symbol
tick: Add tick skew boot option
This is useful for SoCs whose I2C module's signals can be routed to
different sets of pins at run-time, using the pinctrl API.
| dev | | dev |
| SoC | | |
| +---+ +------+ | child bus A, on first set of pins
| |I2C|---|Pinmux| |
| +---+ +------+ | child bus B, on second set of pins
| dev | | dev | | dev |
Acked-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Pull device-mapper updates from Alasdair G Kergon:
"Improve multipath's retrying mechanism in some defined circumstances
and provide a simple reserve/release mechanism for userspace tools to
access thin provisioning metadata while the pool is in use."
* tag 'dm-3.5-changes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm:
dm thin: provide userspace access to pool metadata
dm thin: use slab mempools
dm mpath: allow ioctls to trigger pg init
dm mpath: delay retry of bypassed pg
dm mpath: reduce size of struct multipath
This patch implements two new messages that can be sent to the thin
pool target allowing it to take a snapshot of the _metadata_. This,
read-only snapshot can be accessed by userland, concurrently with the
live target.
Only one metadata snapshot can be held at a time. The pool's status
line will give the block location for the current msnap.
Since version 0.1.5 of the userland thin provisioning tools, the
thin_dump program displays the msnap as follows:
thin_dump -m <msnap root> <metadata dev>
Available here: https://github.com/jthornber/thin-provisioning-tools
Now that userland can access the metadata we can do various things
that have traditionally been kernel side tasks:
i) Incremental backups.
By using metadata snapshots we can work out what blocks have
changed over time. Combined with data snapshots we can ensure
the data doesn't change while we back it up.
A short proof of concept script can be found here:
https://github.com/jthornber/thinp-test-suite/blob/master/incremental_backup_example.rb
ii) Migration of thin devices from one pool to another.
iii) Merging snapshots back into an external origin.
iv) Asyncronous replication.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Pull straggler x86 fixes from Peter Anvin:
"Three groups of patches:
- EFI boot stub documentation and the ability to print error messages;
- Removal for PTRACE_ARCH_PRCTL for x32 (obsolete interface which
should never have been ported, and the port is broken and
potentially dangerous.)
- ftrace stack corruption fixes. I'm not super-happy about the
technical implementation, but it is probably the least invasive in
the short term. In the future I would like a single method for
nesting the debug stack, however."
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, x32, ptrace: Remove PTRACE_ARCH_PRCTL for x32
x86, efi: Add EFI boot stub documentation
x86, efi; Add EFI boot stub console support
x86, efi: Only close open files in error path
ftrace/x86: Do not change stacks in DEBUG when calling lockdep
x86: Allow nesting of the debug stack IDT setting
x86: Reset the debug_stack update counter
ftrace: Use breakpoint method to update ftrace caller
ftrace: Synchronize variable setting with breakpoints
Pull fbdev updates from Florian Tobias Schandinat:
- driver for AUO-K1900 and AUO-K1901 epaper controller
- large updates for OMAP (e.g. decouple HDMI audio and video)
- some updates for Exynos and SH Mobile
- various other small fixes and cleanups
* tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits)
video: bfin_adv7393fb: Fix cleanup code
video: exynos_dp: reduce delay time when configuring video setting
video: exynos_dp: move sw reset prioir to enabling sw defined function
video: exynos_dp: use devm_ functions
fb: handle NULL pointers in framebuffer release
OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request
OMAPDSS: Apply VENC timings even if panel is disabled
OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC
OMAPDSS: DISPC: Support rotation through TILER
OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n
OMAPFB: remove compiler warnings when CONFIG_BUG=n
OMAPDSS: remove compiler warnings when CONFIG_BUG=n
OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv
OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays
OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods
OMAPDSS: DISPC: Update Accumulator configuration for chroma plane
drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers
video: exynos mipi dsi: support reverse panel type
video: exynos mipi dsi: Properly interpret the interrupt source flags
video: exynos mipi dsi: Avoid races in probe()
Pull mtd update from David Woodhouse:
- More robust parsing especially of xattr data in JFFS2
- Updates to mxc_nand and gpmi drivers to support new boards and device tree
- Improve consistency of information about ECC strength in NAND devices
- Clean up partition handling of plat_nand
- Support NAND drivers without dedicated access to OOB area
- BCH hardware ECC support for OMAP
- Other fixes and cleanups, and a few new device IDs
Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to
added include files next to each other.
* tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits)
mtd: mxc_nand: move ecc strengh setup before nand_scan_tail
mtd: block2mtd: fix recursive call of mtd_writev
mtd: gpmi-nand: define ecc.strength
mtd: of_parts: fix breakage in Kconfig
mtd: nand: fix scan_read_raw_oob
mtd: docg3 fix in-middle of blocks reads
mtd: cfi_cmdset_0002: Slight cleanup of fixup messages
mtd: add fixup for S29NS512P NOR flash.
jffs2: allow to complete xattr integrity check on first GC scan
jffs2: allow to discriminate between recoverable and non-recoverable errors
mtd: nand: omap: add support for hardware BCH ecc
ARM: OMAP3: gpmc: add BCH ecc api and modes
mtd: nand: check the return code of 'read_oob/read_oob_raw'
mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw'
mtd: m25p80: Add support for Winbond W25Q80BW
jffs2: get rid of jffs2_sync_super
jffs2: remove unnecessary GC pass on sync
jffs2: remove unnecessary GC pass on umount
jffs2: remove lock_super
mtd: gpmi: add gpmi support for mx6q
