This adds support for the LVDS Display Bridge contained
in i.MX5 and i.MX6 SoCs.
Bit mapping, data width, and video timings are configurable
via device tree. Dual-channel mode is supported for a single
high-resolution source.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
We want the fixes in here as well.
Pull block layer fixes from Jens Axboe:
"Outside of bcache (which really isn't super big), these are all
few-liners. There are a few important fixes in here:
- Fix blk pm sleeping when holding the queue lock
- A small collection of bcache fixes that have been done and tested
since bcache was included in this merge window.
- A fix for a raid5 regression introduced with the bio changes.
- Two important fixes for mtip32xx, fixing an oops and potential data
corruption (or hang) due to wrong bio iteration on stacked devices."
* 'for-linus' of git://git.kernel.dk/linux-block:
scatterlist: sg_set_buf() argument must be in linear mapping
raid5: Initialize bi_vcnt
pktcdvd: silence static checker warning
block: remove refs to XD disks from documentation
blkpm: avoid sleep when holding queue lock
mtip32xx: Correctly handle bio->bi_idx != 0 conditions
mtip32xx: Fix NULL pointer dereference during module unload
bcache: Fix error handling in init code
bcache: clarify free/available/unused space
bcache: drop "select CLOSURES"
bcache: Fix incompatible pointer type warning
Add support for the at91sam9x5-family which must use the shadow
interrupt mask due to a hardware issue (causing RTC_IMR to always be
zero).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Douglas Gilbert <dgilbert@interlog.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Ludovic Desroches <ludovic.desroches@atmel.com>
Cc: Robert Nelson <Robert.Nelson@digikey.com>
update ABI documentation with current paths related to scan_elements folder
Paths changed long time ago in commit: 26d25ae3f0d8ffe350aacc75b71198d6b35bd1f4
Signed-off-by: Alexandre Relange <alexandre@relange.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch adds support for the AD7303. The AD7303 is a simple 2 channel 8 bit
DAC with an SPI interface.
Per review feedback from Lars-Peter Clausen <lars@metafoo.de>
Changes since V1:
Fix return value handling of adf4350_parse_dt()
Use of_get_gpio
Avoid abbreviations in devicetree properties
Fix typo in docs
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Pull slave-dmaengine fixes from Vinod Koul:
"Fix from Andy is for dmatest regression reported by Will and Rabin has
fixed runtime ref counting for st_dma40"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmatest: do not allow to interrupt ongoing tests
dmaengine: ste_dma40: fix pm runtime ref counting
When user interrupts ongoing transfers the dmatest may end up with console
lockup, oops, or data mismatch. This patch prevents user to abort any ongoing
test.
Documentation is updated accordingly.
Reported-by: Will Deacon <will.deacon@arm.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Pull more xfs updates from Ben Myers:
"Here are several fixes for filesystems with CRC support turned on:
fixes for quota, remote attributes, and recovery. There is also some
feature work related to CRCs: the implementation of CRCs for the inode
unlinked lists, disabling noattr2/attr2 options when appropriate, and
bumping the maximum number of ACLs.
I would have preferred to defer this last category of items to 3.11.
This would require setting a feature bit for the on-disk changes, so
there is some pressure to get these in 3.10. I believe this
represents the end of the CRC related queue.
- Rework of dquot CRCs
- Fix for remote attribute invalidation of a leaf
- Fix ordering of transaction replay in recovery
- Implement CRCs for inode unlinked list
- Disable noattr2/attr2 mount options when CRCs are enabled
- Bump the limitation of ACL entries for v5 superblocks"
* tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfs:
xfs: increase number of ACL entries for V5 superblocks
xfs: disable noattr2/attr2 mount options for CRC enabled filesystems
xfs: inode unlinked list needs to recalculate the inode CRC
xfs: fix log recovery transaction item reordering
xfs: fix remote attribute invalidation for a leaf
xfs: rework dquot CRCs
attr2 format is always enabled for v5 superblock filesystems, so the
mount options to enable or disable it need to be cause mount errors.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit d3eaace84e40bf946129e516dcbd617173c1cf14)
transactions
When in an active transaction that takes a signal, we need to be careful with
the stack. It's possible that the stack has moved back up after the tbegin.
The obvious case here is when the tbegin is called inside a function that
returns before a tend. In this case, the stack is part of the checkpointed
transactional memory state. If we write over this non transactionally or in
suspend, we are in trouble because if we get a tm abort, the program counter
and stack pointer will be back at the tbegin but our in memory stack won't be
valid anymore.
To avoid this, when taking a signal in an active transaction, we need to use
the stack pointer from the checkpointed state, rather than the speculated
state. This ensures that the signal context (written tm suspended) will be
written below the stack required for the rollback. The transaction is aborted
becuase of the treclaim, so any memory written between the tbegin and the
signal will be rolled back anyway.
For signals taken in non-TM or suspended mode, we use the
normal/non-checkpointed stack pointer.
Tested with 64 and 32 bit signals
Signed-off-by: Michael Neuling <mikey@neuling.org>
Cc: <stable@vger.kernel.org> # v3.9
If we are emulating an instruction inside an active user transaction that
touches memory, the kernel can't emulate it as it operates in transactional
suspend context. We need to abort these transactions and send them back to
userspace for the hardware to rollback.
We can service these if the user transaction is in suspend mode, since the
kernel will operate in the same suspend context.
This adds a check to all alignment faults and to specific instruction
emulations (only string instructions for now). If the user process is in an
active (non-suspended) transaction, we abort the transaction go back to
userspace allowing the HW to roll back the transaction and tell the user of the
failure. This also adds new tm abort cause codes to report the reason of the
persistent error to the user.
Crappy test case here http://neuling.org/devel/junkcode/aligntm.c
Cc: <stable@vger.kernel.org> # 3.9 only
We want the changes here, and we resolve the merge conflict that was
happening in the nvec_kbd.c file.
Merge fixes from Andrew Morton:
"A bunch of fixes and one simple fbdev driver which missed the merge
window because people will still talking about it (to no great
effect)."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits)
aio: fix kioctx not being freed after cancellation at exit time
mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas
drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing
ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()
random: fix accounting race condition with lockless irq entropy_count update
drivers/char/random.c: fix priming of last_data
mm/memory_hotplug.c: fix printk format warnings
nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary
drivers/block/brd.c: fix brd_lookup_page() race
fbdev: FB_GOLDFISH should depend on HAS_DMA
drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq()
auditfilter.c: fix kernel-doc warnings
aio: fix io_getevents documentation
revert "selftest: add simple test for soft-dirty bit"
drivers/leds/leds-ot200.c: fix error caused by shifted mask
mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer
linux/kernel.h: fix kernel-doc warning
mm compaction: fix of improper cache flush in migration code
rapidio/tsi721: fix bug in MSI interrupt handling
hfs: avoid crash in hfs_bnode_create
A simple frame-buffer describes a raw memory region that may be rendered
to, with the assumption that the display hardware has already been set
up to scan out from that buffer.
This is useful in cases where a bootloader exists and has set up the
display hardware, but a Linux driver doesn't yet exist for the display
hardware.
Examples use-cases include:
* The built-in LCD panels on the Samsung ARM chromebook, and Tegra
devices, and likely many other ARM or embedded systems. These cannot
yet be supported using a full graphics driver, since the panel control
should be provided by the CDF (Common Display Framework), which has been
stuck in design/review for quite some time. One could support these
panels using custom SoC-specific code, but there is a desire to use
common infra-structure rather than having each SoC vendor invent their
own code, hence the desire to wait for CDF.
* Hardware for which a full graphics driver is not yet available, and
the path to obtain one upstream isn't yet clear. For example, the
Raspberry Pi.
* Any hardware in early stages of upstreaming, before a full graphics
driver has been tackled. This driver can provide a graphical boot
console (even full X support) much earlier in the upstreaming process,
thus making new SoC or board support more generally useful earlier.
[akpm@linux-foundation.org: make simplefb_formats[] static]
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Olof Johansson <olof@lixom.net>
Cc: Rob Clark <robclark@gmail.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Update RapidIO documentation to reflect changes made to
enumeration/discovery build configuration and user space triggering
mechanism.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Andre van Herk <andre.van.herk@Prodrive.nl>
Cc: Micha Nelissen <micha.nelissen@Prodrive.nl>
Add support for parsing 'gpios' property when initializing
from oftree.
This patch adds also the binding documentation file.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
From Nicolas Ferre:
An important revert on at91rm9200 platform related
to timers that prevented the platform to boot properly.
Then one pinctrl adjustments for SPI CS and a couple of
trivial typos.
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
ARM: at91: rm9200 fix time support
ARM: at91: dts: request only spi cs-gpios used on sama5d3x cpu module
ARM: at91/trivial: typo in GEM compatible string
ARM: at91/trivial: fix model name for SAM9X25-EK
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen fixes from Konrad Rzeszutek Wilk:
- Regression fix in xen privcmd fixing a memory leak.
- Add Documentation for tmem driver.
- Simplify and remove code in the tmem driver.
- Cleanups.
* tag 'stable/for-linus-3.10-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: Fixed assignment error in if statement
xen/xenbus: Fixed over 80 character limit issue
xen/xenbus: Fixed indentation error in switch case
xen/tmem: Don't use self[ballooning|shrinking] if frontswap is off.
xen/tmem: Remove the usage of '[no|]selfballoon' and use 'tmem.selfballooning' bool instead.
xen/tmem: Remove the usage of 'noselfshrink' and use 'tmem.selfshrink' bool instead.
xen/tmem: Remove the boot options and fold them in the tmem.X parameters.
xen/tmem: s/disable_// and change the logic.
xen/tmem: Fix compile warning.
xen/tmem: Split out the different module/boot options.
xen/tmem: Move all of the boot and module parameters to the top of the file.
xen/tmem: Cleanup. Remove the parts that say temporary.
xen/privcmd: fix condition in privcmd_close()
Pull device tree fixes from Grant Likely:
"Device tree bug fixes and documentation updates for v3.10
Nothing earth shattering here. A build failure fix, and fix for
releasing nodes and some documenation updates."
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
Documentation/devicetree: make semantic of initrd-end more explicit
of/base: release the node correctly in of_parse_phandle_with_args()
of/documentation: move video device bindings to a common place
<linux/of_platform.h>: fix compilation warnings with DT disabled
Commit d1a6f4f19728d6e90480e53601a90fc9f6a348ad
"block: delete super ancient PC-XT driver for 1980's hardware"
deleted the XD disk driver, but there are still a few
references to it in the documentation directory. Delete
the remnants and thus also free up the major block device
13 for reuse.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Pull power management and ACPI fixes from Rafael Wysocki:
- intel_pstate driver fixes and cleanups from Dirk Brandewie and Wei
Yongjun.
- cpufreq fixes related to ARM big.LITTLE support and the cpufreq-cpu0
driver from Viresh Kumar.
- Assorted cpufreq fixes from Srivatsa S Bhat, Borislav Petkov, Wolfram
Sang, Alexander Shiyan, and Nishanth Menon.
- Assorted ACPI fixes from Catalin Marinas, Lan Tianyu, Alex Hung,
Jan-Simon Möller, and Rafael J Wysocki.
- Fix for a kfree() under spinlock in the PM core from Shuah Khan.
- PM documentation updates from Borislav Petkov and Zhang Rui.
* tag 'pm+acpi-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (30 commits)
cpufreq: Preserve sysfs files across suspend/resume
ACPI / scan: Fix memory leak on acpi_scan_init_hotplug() error path
PM / hibernate: Correct documentation
PM / Documentation: remove inaccurate suspend/hibernate transition lantency statement
PM: Documentation update for freeze state
cpufreq / intel_pstate: use vzalloc() instead of vmalloc()/memset(0)
cpufreq, ondemand: Remove leftover debug line
PM: Avoid calling kfree() under spinlock in dev_pm_put_subsys_data()
cpufreq / kirkwood: don't check resource with devm_ioremap_resource
cpufreq / intel_pstate: remove #ifdef MODULE compile fence
cpufreq / intel_pstate: Remove idle mode PID
cpufreq / intel_pstate: fix ffmpeg regression
cpufreq / intel_pstate: use lowest requested max performance
cpufreq / intel_pstate: remove idle time and duration from sample and calculations
cpufreq: Fix incorrect dependecies for ARM SA11xx drivers
cpufreq: ARM big LITTLE: Fix Kconfig entries
cpufreq: cpufreq-cpu0: Free parent node for error cases
cpufreq: cpufreq-cpu0: defer probe when regulator is not ready
cpufreq: Issue CPUFREQ_GOV_POLICY_EXIT notifier before dropping policy refcount
cpufreq: governors: Fix CPUFREQ_GOV_POLICY_{INIT|EXIT} notifiers
Pull core fixes from Thomas Gleixner:
- Two fixlets for the fallout of the generic idle task conversion
- Documentation update
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
rcu/idle: Wrap cpu-idle poll mode within rcu_idle_enter/exit
idle: Fix hlt/nohlt command-line handling in new generic idle
kthread: Document ways of reducing OS jitter due to per-CPU kthreads
There is no point. We would just squeeze the guest to put more and
more pages in the swap disk without any purpose.
The only time it makes sense to use the selfballooning and shrinking
is when frontswap is being utilized.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
If tmem is built-in or a module, the user has the option on
the command line to influence it by doing: tmem.<some option>
instead of having a variety of "nocleancache", and
"nofrontswap". The others: "noselfballooning" and "selfballooning";
and "noselfshrink" are in a different driver xen-selfballoon.c
and the patches:
xen/tmem: Remove the usage of 'noselfballoon','selfballoon' and use 'tmem.selfballon' bool instead.
remove them.
Also add documentation.
git://evilpiepirate.org/~kent/linux-bcache into for-linus
Kent writes:
Jens - couple more bcache patches. Bug fixes and a doc update.
Don't describe bcache_available_percent as free space but as
non-writeback space. Describe priority_stats in more detail
and point to that for total bcache occupation.
Signed-off-by: Gabriel de Perthuis <g2p.code+bcache@gmail.com>
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Correct the meaning of PM_HIBERNATION_PREPARE in the docs.
References: http://lkml.kernel.org/r/20130512162717.GA6305@pd.tnic
statement
The lantency of the transition from suspend and hibernate is
platform-dependent. Thus we should not refer the lantency in the
documentation.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Pull MIPS updates from Ralf Baechle:
- More work on DT support for various platforms
- Various fixes that were to late to make it straight into 3.9
- Improved platform support, in particular the Netlogic XLR and
BCM63xx, and the SEAD3 and Malta eval boards.
- Support for several Ralink SOC families.
- Complete support for the microMIPS ASE which basically reencodes the
existing MIPS32/MIPS64 ISA to use non-constant size instructions.
- Some fallout from LTO work which remove old cruft and will generally
make the MIPS kernel easier to maintain and resistant to compiler
optimization, even in absence of LTO.
- KVM support. While MIPS has announced hardware virtualization
extensions this KVM extension uses trap and emulate mode for
virtualization of MIPS32. More KVM work to add support for VZ
hardware virtualizaiton extensions and MIPS64 will probably already
be merged for 3.11.
Most of this has been sitting in -next for a long time. All defconfigs
have been build or run time tested except three for which fixes are being
sent by other maintainers.
Semantic conflict with kvm updates done as per Ralf
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits)
MIPS: Add new GIC clockevent driver.
MIPS: Formatting clean-ups for clocksources.
MIPS: Refactor GIC clocksource code.
MIPS: Move 'gic_frequency' to common location.
MIPS: Move 'gic_present' to common location.
MIPS: MIPS16e: Add unaligned access support.
MIPS: MIPS16e: Support handling of delay slots.
MIPS: MIPS16e: Add instruction formats.
MIPS: microMIPS: Optimise 'strnlen' core library function.
MIPS: microMIPS: Optimise 'strlen' core library function.
MIPS: microMIPS: Optimise 'strncpy' core library function.
MIPS: microMIPS: Optimise 'memset' core library function.
MIPS: microMIPS: Add configuration option for microMIPS kernel.
MIPS: microMIPS: Disable LL/SC and fix linker bug.
MIPS: microMIPS: Add vdso support.
MIPS: microMIPS: Add unaligned access support.
MIPS: microMIPS: Support handling of delay slots.
MIPS: microMIPS: Add support for exception handling.
MIPS: microMIPS: Floating point support.
MIPS: microMIPS: Fix macro naming in micro-assembler.
Pull ARM SoC fixes and straggler patches from Olof Johansson:
"A collection of fixes for fall out from 3.10 merge window, some build
fixes and warning cleanups and a small handful of patches that were
small and contained and made sense to still include in 3.10 (some of
these have also been in -next since the merge window opened).
Largest continous series is for OMAP, but there's a handful for other
platforms.
For i.MX, one of the patches are framebuffer fixups due to fallout
during the merge window, and the other removes some stale and broken
code."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (34 commits)
ARM: exynos: dts: Fixed vbus-gpios
ARM: EXYNOS5: Fix kernel dump in AFTR idle mode
ARM: ux500: Rid ignored return value of regulator_enable() compiler warning
ARM: ux500: read the correct soc_id number
ARM: exynos: dts: cros5250: add cyapa trackpad
video: mxsfb: Adapt to new videomode API
ARM: imx: Select GENERIC_ALLOCATOR
ARM: imx: compile fix for hotplug.c
ARM: dts: don't assume boards are using twl4030 for omap3
ARM: OMAP2+: Remove bogus IS_ERR_OR_NULL checking from id.c
ARM: dts: Configure and fix the McSPI pins for 4430sdp
ARM: dts: AM33XX: Add GPMC node
ARM: dts: OMAP4460: Fix CPU OPP voltages
ARM: dts: OMAP36xx: Fix CPU OPP voltages
ARM: OMAP4+: omap2plus_defconfig: Enable audio via TWL6040 as module
ARM: OMAP2: AM33XX: id: Add support for new AM335x PG2.1 Si
omap: mux: add AM/DM37x gpios
ARM: OMAP1: DMA: fix error handling in omap1_system_dma_init()
ARM: OMAP2+: omap_device: use late_initcall_sync
ARM: OMAP: RX-51: change probe order of touchscreen and panel SPI devices
Pull xtensa updates from Chris Zankel:
"Support for the latest MMU architecture that allows for a larger
accessible memory region, and various bug-fixes"
* tag 'xtensa-next-20130508' of git://github.com/czankel/xtensa-linux:
xtensa: Switch to asm-generic/linkage.h
xtensa: fix redboot load address
xtensa: ISS: fix timer_lock usage in rs_open
xtensa: disable IRQs while IRQ handler is running
xtensa: enable lockdep support
xtensa: fix arch_irqs_disabled_flags implementation
xtensa: add irq flags trace support
xtensa: provide custom CALLER_ADDR* implementations
xtensa: add stacktrace support
xtensa: clean up stpill_registers
xtensa: don't use a7 in simcalls
xtensa: don't attempt to use unconfigured timers
xtensa: provide default platform_pcibios_init implementation
xtensa: remove KCORE_ELF again
xtensa: document MMUv3 setup sequence
xtensa: add MMU v3 support
xtensa: fix ibreakenable register update
xtensa: fix oprofile building as module
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
Omap fixes for things that were discovered during the merge window:
- Few GPMC fixes and binding doc updates noted after sending
pull requests for the GPMC branch.
- Board fixes for beagle usb host and rx51 spi probe order
- SoC fixes dt earlyprintk, omap1 dma and omap2+ id.c error
handling fixes
Then few minor things that are not strictly fixes but are good
to get out of the way:
- Add missing legacy mux registers for am/dm73x gpio
- Add detection for am33xx pg2.1 silicon
- Enable twl4030 audio modules in defconfig
* tag 'omap-for-v3.10/fixes-for-merge-window-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP3: Beagle: Fix USB Host on beagle xM Ax/Bx
ARM: OMAP2+: only WARN if a GPMC child probe function fail
ARM: OMAP2+: only search for GPMC DT child nodes on probe
Documentation: dt: update properties in TI GPMC NAND example
Documentation: dt: update TI GPMC ethernet binding properties
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs update from Chris Mason:
"These are mostly fixes. The biggest exceptions are Josef's skinny
extents and Jan Schmidt's code to rebuild our quota indexes if they
get out of sync (or you enable quotas on an existing filesystem).
The skinny extents are off by default because they are a new variation
on the extent allocation tree format. btrfstune -x enables them, and
the new format makes the extent allocation tree about 30% smaller.
I rebased this a few days ago to rework Dave Sterba's crc checks on
the super block, but almost all of these go back to rc6, since I
though 3.9 was due any minute.
The biggest missing fix is the tracepoint bug that was hit late in
3.9. I ran into problems with that in overnight testing and I'm still
tracking it down. I'll definitely have that fixed for rc2."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (101 commits)
Btrfs: allow superblock mismatch from older mkfs
btrfs: enhance superblock checks
btrfs: fix misleading variable name for flags
btrfs: use unsigned long type for extent state bits
Btrfs: improve the loop of scrub_stripe
btrfs: read entire device info under lock
btrfs: remove unused gfp mask parameter from release_extent_buffer callchain
btrfs: handle errors returned from get_tree_block_key
btrfs: make static code static & remove dead code
Btrfs: deal with errors in write_dev_supers
Btrfs: remove almost all of the BUG()'s from tree-log.c
Btrfs: deal with free space cache errors while replaying log
Btrfs: automatic rescan after "quota enable" command
Btrfs: rescan for qgroups
Btrfs: split btrfs_qgroup_account_ref into four functions
Btrfs: allocate new chunks if the space is not enough for global rsv
Btrfs: separate sequence numbers for delayed ref tracking and tree mod log
btrfs: move leak debug code to functions
Btrfs: return free space in cow error path
Btrfs: set UUID in root_item for created trees
Pull MTD update from David Woodhouse:
- Lots of cleanups from Artem, including deletion of some obsolete
drivers
- Support partitions larger than 4GiB in device tree
- Support for new SPI chips
* tag 'for-linus-20130509' of git://git.infradead.org/linux-mtd: (83 commits)
mtd: omap2: Use module_platform_driver()
mtd: bf5xx_nand: Use module_platform_driver()
mtd: denali_dt: Remove redundant use of of_match_ptr
mtd: denali_dt: Change return value to fix smatch warning
mtd: denali_dt: Use module_platform_driver()
mtd: denali_dt: Fix incorrect error check
mtd: nand: subpage write support for hardware based ECC schemes
mtd: omap2: use msecs_to_jiffies()
mtd: nand_ids: use size macros
mtd: nand_ids: improve LEGACY_ID_NAND macro a bit
mtd: add 4 Toshiba nand chips for the full-id case
mtd: add the support to parse out the full-id nand type
mtd: add new fields to nand_flash_dev{}
mtd: sh_flctl: Use of_match_ptr() macro
mtd: gpio: Use of_match_ptr() macro
mtd: gpio: Use devm_kzalloc()
mtd: davinci_nand: Use of_match_ptr()
mtd: dataflash: Use of_match_ptr() macro
mtd: remove h720x flash support
mtd: onenand: remove OneNAND simulator
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Pull slave-dmaengine updates from Vinod Koul:
"This time we have dmatest improvements from Andy along with dw_dmac
fixes. He has also done support for acpi for dmanegine.
Also we have bunch of fixes going in DT support for dmanegine for
various folks. Then Haswell and other ioat changes from Dave and
SUDMAC support from Shimoda."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits)
dma: tegra: implement suspend/resume callbacks
dma:of: Use a mutex to protect the of_dma_list
dma: of: Fix of_node reference leak
dmaengine: sirf: move driver init from module_init to subsys_initcall
sudmac: add support for SUDMAC
dma: sh: add Kconfig
at_hdmac: move to generic DMA binding
ioatdma: ioat3_alloc_sed can be static
ioatdma: Adding write back descriptor error status support for ioatdma 3.3
ioatdma: S1200 platforms ioatdma channel 2 and 3 falsely advertise RAID cap
ioatdma: Adding support for 16 src PQ ops and super extended descriptors
ioatdma: Removing hw bug workaround for CB3.x .2 and earlier
dw_dmac: add ACPI support
dmaengine: call acpi_dma_request_slave_channel as well
dma: acpi-dma: introduce ACPI DMA helpers
dma: of: Remove unnecessary list_empty check
DMA: OF: Check properties value before running be32_to_cpup() on it
DMA: of: Constant names
ioatdma: skip silicon bug workaround for pq_align for cb3.3
ioatdma: Removing PQ val disable for cb3.3
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management update from Zhang Rui:
"The most important one is to build thermal core and governor and cpu
cooling code into one module. This fixes a regression that thermal
core does not work if it is built as module, since 3.7. I'll backport
them to stable kernel once those changes are in upstream.
The largest batch is the thermal kernel-doc & coding style
updates/cleanups from Eduardo.
Highlights:
- build all thermal framework code into one module to fix a
regression that thermal does not work if it is built as module.
- Marvell Armada 370/XP thermal sensor driver
- thermal core/cpu cooling kernel-doc & coding style updates and
cleanups.
- Add Eduardo Valentin as thermal sub-maintainer, both in mailing
list and patchwork. He will help me on arm thermal drivers."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (68 commits)
thermal: db8500_cpufreq_cooling: remove usage of IS_ERR_OR_NULL()
thermal: thermal_core: remove usage of IS_ERR_OR_NULL
thermal: cpu_cooling: improve line breaking
thermal: cpu_cooling: alignment improvements
thermal: cpu_cooling: remove checkpatch.pl warning
thermal: cpu_cooling: remove trailing blank line
thermal: cpu_cooling: align on open parenthesis
thermal: cpu_cooling: standardize comment style
thermal: cpu_cooling: standardize end of function
thermal: cpu_cooling: remove trailing white spaces
Thermal: update documentation for thermal_zone_device_register
thermal: update kernel-doc for thermal_zone_device_register
thermal: update kernel-doc for create_trip_attrs
thermal: update kernel-doc for thermal_cooling_device_register
thermal: update kernel-doc for thermal_zone_unbind_cooling_device
thermal: update kernel-doc for thermal_zone_bind_cooling_device
thermal: use EXPORT_SYMBOL_GPL
thermal: rename notify_thermal_framework to thermal_notify_framework
thermal: update driver license
thermal: use strlcpy instead of strcpy
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Chris Zankel <chris@zankel.net>
into fixes
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"This patch-set includes the following major enhancement patches.
- introduce a new gloabl lock scheme
- add tracepoints on several major functions
- fix the overall cleaning process focused on victim selection
- apply the block plugging to merge IOs as much as possible
- enhance management of free nids and its list
- enhance the readahead mode for node pages
- address several cretical deadlock conditions
- reduce lock_page calls
The other minor bug fixes and enhancements are as follows.
- calculation mistakes: overflow
- bio types: READ, READA, and READ_SYNC
- fix the recovery flow, data races, and null pointer errors"
* tag 'f2fs-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (68 commits)
f2fs: cover free_nid management with spin_lock
f2fs: optimize scan_nat_page()
f2fs: code cleanup for scan_nat_page() and build_free_nids()
f2fs: bugfix for alloc_nid_failed()
f2fs: recover when journal contains deleted files
f2fs: continue to mount after failing recovery
f2fs: avoid deadlock during evict after f2fs_gc
f2fs: modify the number of issued pages to merge IOs
f2fs: remove useless #include <linux/proc_fs.h> as we're now using sysfs as debug entry.
f2fs: fix inconsistent using of NM_WOUT_THRESHOLD
f2fs: check truncation of mapping after lock_page
f2fs: enhance alloc_nid and build_free_nids flows
f2fs: add a tracepoint on f2fs_new_inode
f2fs: check nid == 0 in add_free_nid
f2fs: add REQ_META about metadata requests for submit
f2fs: give a chance to merge IOs by IO scheduler
f2fs: avoid frequent background GC
f2fs: add tracepoints to debug checkpoint request
f2fs: add tracepoints for write page operations
f2fs: add tracepoints to debug the block allocation
Pull block driver updates from Jens Axboe:
"It might look big in volume, but when categorized, not a lot of
drivers are touched. The pull request contains:
- mtip32xx fixes from Micron.
- A slew of drbd updates, this time in a nicer series.
- bcache, a flash/ssd caching framework from Kent.
- Fixes for cciss"
* 'for-3.10/drivers' of git://git.kernel.dk/linux-block: (66 commits)
bcache: Use bd_link_disk_holder()
bcache: Allocator cleanup/fixes
cciss: bug fix to prevent cciss from loading in kdump crash kernel
cciss: add cciss_allow_hpsa module parameter
drivers/block/mg_disk.c: add CONFIG_PM_SLEEP to suspend/resume functions
mtip32xx: Workaround for unaligned writes
bcache: Make sure blocksize isn't smaller than device blocksize
bcache: Fix merge_bvec_fn usage for when it modifies the bvm
bcache: Correctly check against BIO_MAX_PAGES
bcache: Hack around stuff that clones up to bi_max_vecs
bcache: Set ra_pages based on backing device's ra_pages
bcache: Take data offset from the bdev superblock.
mtip32xx: mtip32xx: Disable TRIM support
mtip32xx: fix a smatch warning
bcache: Disable broken btree fuzz tester
bcache: Fix a format string overflow
bcache: Fix a minor memory leak on device teardown
bcache: Documentation updates
bcache: Use WARN_ONCE() instead of __WARN()
bcache: Add missing #include <linux/prefetch.h>
Pull block core updates from Jens Axboe:
- Major bit is Kents prep work for immutable bio vecs.
- Stable candidate fix for a scheduling-while-atomic in the queue
bypass operation.
- Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging
discard bios.
- Tejuns changes to convert the writeback thread pool to the generic
workqueue mechanism.
- Runtime PM framework, SCSI patches exists on top of these in James'
tree.
- A few random fixes.
* 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits)
relay: move remove_buf_file inside relay_close_buf
partitions/efi.c: replace useless kzalloc's by kmalloc's
fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read()
block: fix max discard sectors limit
blkcg: fix "scheduling while atomic" in blk_queue_bypass_start
Documentation: cfq-iosched: update documentation help for cfq tunables
writeback: expose the bdi_wq workqueue
writeback: replace custom worker pool implementation with unbound workqueue
writeback: remove unused bdi_pending_list
aoe: Fix unitialized var usage
bio-integrity: Add explicit field for owner of bip_buf
block: Add an explicit bio flag for bios that own their bvec
block: Add bio_alloc_pages()
block: Convert some code to bio_for_each_segment_all()
block: Add bio_for_each_segment_all()
bounce: Refactor __blk_queue_bounce to not use bi_io_vec
raid1: use bio_copy_data()
pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage
pktcdvd: use bio_copy_data()
block: Add bio_copy_data()
Merge more incoming from Andrew Morton:
- Various fixes which were stalled or which I picked up recently
- A large rotorooting of the AIO code. Allegedly to improve
performance but I don't really have good performance numbers (I might
have lost the email) and I can't raise Kent today. I held this out
of 3.9 and we could give it another cycle if it's all too late/scary.
I ended up taking only the first two thirds of the AIO rotorooting. I
left the percpu parts and the batch completion for later. - Linus
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (33 commits)
aio: don't include aio.h in sched.h
aio: kill ki_retry
aio: kill ki_key
aio: give shared kioctx fields their own cachelines
aio: kill struct aio_ring_info
aio: kill batch allocation
aio: change reqs_active to include unreaped completions
aio: use cancellation list lazily
aio: use flush_dcache_page()
aio: make aio_read_evt() more efficient, convert to hrtimers
wait: add wait_event_hrtimeout()
aio: refcounting cleanup
aio: make aio_put_req() lockless
aio: do fget() after aio_get_req()
aio: dprintk() -> pr_debug()
aio: move private stuff out of aio.h
aio: add kiocb_cancel()
aio: kill return value of aio_complete()
char: add aio_{read,write} to /dev/{null,zero}
aio: remove retry-based AIO
This exports the amount of anonymous transparent hugepages for each
memcg via the new "rss_huge" stat in memory.stat. The units are in
bytes.
This is helpful to determine the hugepage utilization for individual
jobs on the system in comparison to rss and opportunities where
MADV_HUGEPAGE may be helpful.
The amount of anonymous transparent hugepages is also included in "rss"
for backwards compatibility.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
