path: root/Documentation
2014-07-19Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU fixes from Thomas Gleixner: "Two RCU patches: - Address a serious performance regression on open/close caused by commit ac1bea85781e ("Make cond_resched() report RCU quiescent states") - Export RCU debug functions. Not a regression, but enablement to address a serious recursion bug in the sl*b allocators in 3.17" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Reduce overhead of cond_resched() checks for RCU rcu: Export debug_init_rcu_head() and and debug_init_rcu_head()
2014-07-18Merge branches 'pm-sleep' and 'pm-cpufreq'Rafael J. Wysocki
* pm-sleep: PM / sleep: fix freeze_ops NULL pointer dereferences PM / sleep: Fix request_firmware() error at resume * pm-cpufreq: cpufreq: make table sentinel macros unsigned to match use cpufreq: move policy kobj to policy->cpu at resume cpufreq: cpu0: OPPs can be populated at runtime cpufreq: kirkwood: Reinstate cpufreq driver for ARCH_KIRKWOOD cpufreq: imx6q: Select PM_OPP cpufreq: sa1110: set memory type for h3600
2014-07-18Merge branches 'acpi-scan' and 'acpi-video'Rafael J. Wysocki
* acpi-scan: ACPI / documentation: Remove reference to acpi_platform_device_ids from enumeration.txt * acpi-video: ACPI / video: Add use_native_backlight quirk for HP ProBook 4540s Revert "ACPI / video: change acpi-video brightness_switch_enabled default to 0"
2014-07-16cpufreq: cpu0: OPPs can be populated at runtimeViresh Kumar
OPPs can be populated statically, via DT, or added at run time with dev_pm_opp_add(). While this driver handles the first case correctly, it would fail to populate OPPs added at runtime. Because call to of_init_opp_table() would fail as there are no OPPs in DT and probe will return early. To fix this, remove error checking and call dev_pm_opp_init_cpufreq_table() unconditionally. Update bindings as well. Suggested-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-14Revert "ACPI / video: change acpi-video brightness_switch_enabled default to 0"Rafael J. Wysocki
This reverts commit 886129a8eebeb (ACPI / video: change acpi-video brightness_switch_enabled default to 0) as it is reported to cause problems to happen. Fixes: 886129a8eebeb (ACPI / video: change acpi-video brightness_switch_enabled default to 0) Link: http://marc.info/?l=linux-acpi&m=140534286826819&w=2 Reported by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-13Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "This week's arm-soc fixes: - Another set of OMAP fixes * Clock fixes * Restart handling * PHY regulators * SATA hwmod data for DRA7 + Some trivial fixes and removal of a bit of dead code - Exynos fixes * A bunch of clock fixes * Some SMP fixes * Exynos multi-core timer: register as clocksource and fix ftrace. + a few other minor fixes There's also a couple more patches, and at91 fix for USB caused by common clock conversion, and more MAINTAINERS entries for shmobile. We're definitely switching to only regression fixes from here on out, we've been a little less strict than usual up until now" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (26 commits) ARM: at91: at91sam9x5: add clocks for usb device ARM: EXYNOS: Register cpuidle device only on exynos4210 and 5250 ARM: dts: Add clock property for mfc_pd in exynos5420 clk: exynos5420: Add IDs for clocks used in PD mfc ARM: EXYNOS: Add support for clock handling in power domain ARM: OMAP2+: Remove non working OMAP HDMI audio initialization ARM: imx: fix shared gate clock ARM: dts: Update the parent for Audss clocks in Exynos5420 ARM: EXYNOS: Update secondary boot addr for secure mode ARM: dts: Fix TI CPSW Phy mode selection on IGEP COM AQUILA. ARM: dts: am335x-evmsk: Enable the McASP FIFO for audio ARM: dts: am335x-evm: Enable the McASP FIFO for audio ARM: OMAP2+: Make GPMC skip disabled devices ARM: OMAP2+: create dsp device only on OMAP3 SoCs ARM: dts: dra7-evm: Make VDDA_1V8_PHY supply always on ARM: DRA7/AM43XX: fix header definition for omap44xx_restart ARM: OMAP2+: clock/dpll: fix _dpll_test_fint arithmetics overflow ARM: DRA7: hwmod: Add SYSCONFIG for usb_otg_ss ARM: DRA7: hwmod: Fixup SATA hwmod ARM: OMAP3: PRM/CM: Add back macros used by TI DSP/Bridge driver ...
2014-07-12Merge tag 'tty-3.16-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are some small serial fixes that resolve some reported problems that started in 3.15 with some serial drivers. And there's a new dt binding for a serial driver, which was all that was needed for the renesas serial driver" * tag 'tty-3.16-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: serial: sh-sci: Add device tree support for r8a7{778,740,3a4} and sh73a0 serial: imx: Fix build breakage serial: arc_uart: Use uart_circ_empty() for open-coded comparison serial: Test for no tx data on tx restart
2014-07-12Documenation/laptops: rename and update hpfall.cPali Rohár
Dell kernel driver dell-smo8800 provides same freefall interface as hp_accel so program hpfall.c works also on Dell laptops. So rename it to freefall.c. Dell driver does not provide hp::hddprotect led so make sure that freefall.c works also if hp::hddprotect does not exist in sysfs. Additionally write info to syslog. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Sonal Santan <sonal.santan@gmail.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-12DocBook: fix various typosMasanari Iida
This patch fixed spelling typo in various template files within Documentation/Docbook. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-12DocBook: fix mtdnand typosMasanari Iida
This patch fixed spelling typo found in DocBook/mtdnand.tmpl. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-12Documentation/Changes: clean up mcelog paragraphPaul Bolle
The paragraph on mcelog currently describes kernel v2.6.31. In that kernel the mce code (for i386, that is) was in transition. Ever since v2.6.32 the situation is much simpler (eg, mcelog is now needed to process events on almost all x86 machines, i386 and x86-64). Since this "document is designed to provide a list of the minimum levels of software necessary to run the 3.0 kernels" let's just describe that situation. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-11serial: sh-sci: Add device tree support for r8a7{778,740,3a4} and sh73a0Simon Horman
Simply document new compat strings. There appears to be no need for a driver updates. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-12ACPI / documentation: Remove reference to acpi_platform_device_ids from ↵Darren Hart
enumeration.txt As of: 4845934 ACPI / scan: use platform bus type by default for _HID enumeration ACPI uses the platform bus by default, changing the opt-in to an opt-out policy, eliminating the acpi_platform_device_ids table and replacing it with forbidden_id_list[]. Remove the qualifying paragraph from the acpi/enumeration documentation as it no longer applies. Reported-by: Max Eliaser <max@meliaserlow.dyndns.tv> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-11ARM: EXYNOS: Add support for clock handling in power domainPrathyush K
While powering on/off a local powerdomain in exynos5 chipsets, the input clocks to each device gets modified. This behaviour is based on the SYSCLK_SYS_PWR_REG registers. E.g. SYSCLK_MFC_SYS_PWR_REG = 0x0, the parent of input clock to MFC (aclk333) gets modified to oscclk = 0x1, no change in clocks. The recommended value of SYSCLK_SYS_PWR_REG before power gating any domain is 0x0. So we must also restore the clocks while powering on a domain everytime. This patch adds the framework for getting the required mux and parent clocks through a power domain device node. With this patch, while powering off a domain, parent is set to oscclk and while powering back on, its re-set to the correct parent which is as per the recommended pd on/off sequence. Signed-off-by: Prathyush K <prathyush.k@samsung.com> Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Arun Kumar K <arun.kk@samsung.com> Signed-off-by: Shaik Ameer Basha <shaik.ameer@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-10Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: cpufreq: Makefile: fix compilation for davinci platform intel_pstate: Set CPU number before accessing MSRs intel_pstate: Update documentation of {max,min}_perf_pct sysfs files intel_pstate: don't touch turbo bit if turbo disabled or unavailable. intel_pstate: Fix setting VID
2014-07-07intel_pstate: Update documentation of {max,min}_perf_pct sysfs filesDirk Brandewie
Update documentation to make the interpretation of the values clearer Link: https://bugzilla.kernel.org/show_bug.cgi?id=64251 Cc: 3.13+ <stable@vger.kernel.org> # 3.13+ Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-03mm:vmscan: update the trace-vmscan-postprocess.pl for event ↵Chen Yucong
vmscan/mm_vmscan_lru_isolate When using trace-vmscan-postprocess.pl for checking the file/anon rate of scanning, we can find that it can not be performed. At the same time, the following message will be reported: WARNING: Format not as expected for event vmscan/mm_vmscan_lru_isolate 'file' != 'contig_taken' Fewer fields than expected in format at ./trace-vmscan-postprocess.pl line 171, <FORMAT> line 76. In trace-vmscan-postprocess.pl, (contig_taken, contig_dirty, and contig_failed) are be associated respectively to (nr_lumpy_taken, nr_lumpy_dirty, and nr_lumpy_failed) for lumpy reclaim. Via commit c53919adc045 ("mm: vmscan: remove lumpy reclaim"), lumpy reclaim had already been removed by Mel, but the update for trace-vmscan-postprocess.pl was missed. Signed-off-by: Chen Yucong <slaoub@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-29Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another round of ARM fixes. The largest change here is the L2 changes to work around problems for the Armada 37x/380 devices, where most of the size comes down to comments rather than code. The other significant fix here is for the ptrace code, to ensure that rewritten syscalls work as intended. This was pointed out by Kees Cook, but Will Deacon reworked the patch to be more elegant. The remainder are fairly trivial changes" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8087/1: ptrace: reload syscall number after secure_computing() check ARM: 8086/1: Set memblock limit for nommu ARM: 8085/1: sa1100: collie: add top boot mtd partition ARM: 8084/1: sa1100: collie: revert back to cfi_probe ARM: 8080/1: mcpm.h: remove unused variable declaration ARM: 8076/1: mm: add support for HW coherent systems in PL310 cache
2014-06-29Documentation: add section about git to email-clients.txtDan Carpenter
These days most people use git to send patches so I have added a section about that. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-29ARM: 8076/1: mm: add support for HW coherent systems in PL310 cacheThomas Petazzoni
When a PL310 cache is used on a system that provides hardware coherency, the outer cache sync operation is useless, and can be skipped. Moreover, on some systems, it is harmful as it causes deadlocks between the Marvell coherency mechanism, the Marvell PCIe controller and the Cortex-A9. To avoid this, this commit introduces a new Device Tree property 'arm,io-coherent' for the L2 cache controller node, valid only for the PL310 cache. It identifies the usage of the PL310 cache in an I/O coherent configuration. Internally, it makes the driver disable the outer cache sync operation. Note that technically speaking, a fully coherent system wouldn't require any of the other .outer_cache operations. However, in practice, when booting secondary CPUs, these are not yet coherent, and therefore a set of cache maintenance operations are necessary at this point. This explains why we keep the other .outer_cache operations and only ->sync is disabled. While in theory any write to a PL310 register could cause the deadlock, in practice, disabling ->sync is sufficient to workaround the deadlock, since the other cache maintenance operations are only used in very specific situations. Contrary to previous versions of this patch, this new version does not simply NULL-ify the ->sync member, because the l2c_init_data structures are now 'const' and therefore cannot be modified, which is a good thing. Therefore, this patch introduces a separate l2c_init_data instance, called of_l2c310_coherent_data. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-28Merge tag 'spi-v3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi fixes from Mark Brown: "A few driver specific fixes, the biggest one being a fix for the newly added Qualcomm SPI controller driver to make it not use its internal chip select due to hardware bugs, replacing it with GPIOs" * tag 'spi-v3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: spi: qup: Remove chip select function spi: qup: Fix order of spi_register_master spi: sh-sci: fix use-after-free in sh_sci_spi_remove() spi/pxa2xx: fix incorrect SW mode chipselect setting for BayTrail LPSS SPI
2014-06-28Merge remote-tracking branches 'spi/fix/pxa2xx', 'spi/fix/qup' and ↵Mark Brown
'spi/fix/sh-sci' into spi-linus
2014-06-27Merge tag 'sound-3.16-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here includes a few patchset for fixing mostly HD-audio issues in addition to a patch assuring the compress API bytes alignment and a fix for the die-hard existing race condition at USB-audio disconnection. The volume looks big in Realtek HD-audio code, but it's just a translation of the fixup tables, and the actual changes are rather trivial" * tag 'sound-3.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - restore BCLK M/N values when resuming HSW/BDW display controller ALSA: usb-audio: Fix races at disconnection and PCM closing ALSA: hda - Adjust speaker HPF and add LED support for HP Spectre 13 ALSA: hda - Make the pin quirk tables use the SND_HDA_PIN_QUIRK macro ALSA: hda - Make a SND_HDA_PIN_QUIRK macro ALSA: hda - Add pin quirk for Dell XPS 15 ALSA: hda - hdmi: call overridden init on resume ALSA: hda - Fix usage of "model" module parameter ALSA: compress: fix the struct alignment to 4 bytes
2014-06-25Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "Various minor fixes" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (gpio-fan) Change name used in hwmon_device_register_with_groups hwmon: (emc1403) Fix missing 'select REGMAP_I2C' in Kconfig hwmon: (ntc_thermistor) Use the manufacturer name properly devicetree: bindings: Document murata vendor prefix hwmon: (w83l786ng) Report correct minimum fan speed
2014-06-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix crash in ipvs tot_stats estimator, from Julian Anastasov. 2) Fix OOPS in nf_nat on netns removal, from Florian Westphal. 3) Really really really fix locking issues in slip and slcan tty write wakeups, from Tyler Hall. 4) Fix checksum offloading in fec driver, from Fugang Duan. 5) Off by one in BPF instruction limit test, from Kees Cook. 6) Need to clear all TSO capability flags when doing software TSO in tg3 driver, from Prashant Sreedharan. 7) Fix memory leak in vlan_reorder_header() error path, from Li RongQing. 8) Fix various bugs in xen-netfront and xen-netback multiqueue support, from David Vrabel and Wei Liu. 9) Fix deadlock in cxgb4 driver, from Li RongQing. 10) Prevent double free of no-cache DST entries, from Eric Dumazet. 11) Bad csum_start handling in skb_segment() leads to crashes when forwarding, from Tom Herbert. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (76 commits) net: fix setting csum_start in skb_segment() ipv4: fix dst race in sk_dst_get() net: filter: Use kcalloc/kmalloc_array to allocate arrays trivial: net: filter: Change kerneldoc parameter order trivial: net: filter: Fix typo in comment net: allwinner: emac: Add missing free_irq cxgb4: use dev_port to identify ports xen-netback: bookkeep number of active queues in our own module tg3: Change nvram command timeout value to 50ms cxgb4: Not need to hold the adap_rcu_lock lock when read adap_rcu_list be2net: fix qnq mode detection on VFs of: mdio: fixup of_phy_register_fixed_link parsing of new bindings at86rf230: fix irq setup net: phy: at803x: fix coccinelle warnings net/mlx4_core: Fix the error flow when probing with invalid VF configuration tulip: Poll link status more frequently for Comet chips net: huawei_cdc_ncm: increase command buffer size drivers: net: cpsw: fix dual EMAC stall when connected to same switch xen-netfront: recreate queues correctly when reconnecting xen-netfront: fix oops when disconnected from backend ...
2014-06-25Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A new set of bug fixes for 3.16, containing patches for seven platforms: at91: - drivers/misc fix for Kconfig PWM symbol - correction of several values in DT after conversion to CCF - fix at91sam9261/at91sam9261ek mistake in slow crystal vs. slow RC osc imx: - Use GPIO for card CD/WP on imx51-babbage and eukrea-mbimxsd51, because controller base CD/WP is not working in esdhc driver due to runtime PM support - A couple of random ventana gw5xxx board fixes - Add IMX_IPUV3_CORE back to defconfig, which gets lost when moving IPUv3 driver out of staging tree - Fix enet/fec clock selection on imx6sl - Fix display node on imx53-m53evk board - A couple of Cubox-i updates from Russell, which were omitted from the merge window due to dependency integrator: - fix an OF-related regression against 3.15 mvebu: - mvebu (v7) - Fix broken SoC ID detection - Select ARM_CPU_SUSPEND for v7 - Remove armada38x compatible string (no users yet) - Enable Dove SoC in mvebu_v7_defconfig - kirkwood - Fix phy-connection-type on GuruPlug board qcom: - enable gsbi driver in defconfig - fix section mismatch warning in serial driver samsung: - use WFI macro in platform_do_lowpower because exynos cpuhotplug includes a hardcoded WFI instruction and it causes compile error in Thumb-2 mode. - fix GIC reg sizes for exynos4 SoCs - remove reset timer counter value during boot and resume for mct to fix a big jump in printk timestamps - fix pm code to check cortex-A9 for another exynos SoCs - don't rely on firmware's secondary_cpu_start for mcpm sti: - Ethernet clocks were wrongly defined for STiH415/416 platforms - STiH416 B2020 revision E DTS file name contained uppercase, change to lowercase" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (33 commits) ARM: at91/dt: sam9261: remove slow RC osc ARM: at91/dt: define sam9261ek slow crystal frequency ARM: at91/dt: sam9261: correctly define mainck ARM: at91/dt: sam9n12: correct PLLA ICPLL and OUT values ARM: at91/dt: sam9x5: correct PLLA ICPLL and OUT values misc: atmel_pwm: fix Kconfig symbols ARM: integrator: fix OF-related regression ARM: mvebu: Fix the improper use of the compatible string armada38x using a wildcard ARM: dts: kirkwood: fix phy-connection-type for Guruplug ARM: EXYNOS: Don't rely on firmware's secondary_cpu_start for mcpm ARM: dts: imx51-eukrea-mbimxsd51-baseboard: unbreak esdhc. ARM: dts: imx51-babbage: Fix esdhc setup ARM: dts: mx5: Move the display out of soc {} node ARM: dts: mx5: Fix IPU port node placement ARM: mvebu: select ARM_CPU_SUSPEND for Marvell EBU v7 platforms ARM: mvebu: Fix broken SoC ID detection ARM: imx_v6_v7_defconfig: Enable CONFIG_IMX_IPUV3_CORE ARM: multi_v7_defconfig: Add QCOM GSBI driver ARM: stih41x: Rename stih416-b2020-revE.dts to stih416-b2020e.dts tty: serial: msm: Fix section mismatch warning ...
2014-06-25ALSA: hda - Adjust speaker HPF and add LED support for HP Spectre 13Takashi Iwai
HP Spectre 13 has the IDT 92HD95 codec, and BIOS seems to set the default high-pass filter in some "safer" range, which results in the very soft tone from the built-in speakers in contrast to Windows. Also, the mute LED control is missing, since 92HD95 codec still has no HP-specific fixups for GPIO setups. This patch adds these missing features: the HPF is adjusted by the vendor-specific verb, and the LED is set up from a DMI string (but with the default polarity = 0 assumption due to the incomplete BIOS on the given machine). Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=74841 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-25hwmon: (ntc_thermistor) Use the manufacturer name properlyNaveen Krishna Chatradhi
Murata Manufacturing Co., Ltd is the vendor for NTC (Negative Temperature coefficient) based Thermistors. But, the driver extensively uses "NTC" as the vendor name. This patch corrects the vendor name also updates the compatibility strings according to the vendor-prefix.txt Note: Drivers continue to support the previous compatible strings but further addition of these compatible strings in device tree is deprecated. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-25devicetree: bindings: Document murata vendor prefixNaveen Krishna Chatradhi
Add Murata Manufacturing Co., Ltd. to the list of device tree vendor prefixes. Murata manufactures NTC (Negative Temperature Coefficient) based Thermistors for small scale applications like Mobiles and PDAs. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-25Merge branch 'urgent.2014.06.23a' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent Pull RCU fixes from Paul E. McKenney: " This series includes the following: 1. Export a pair of debug-object interfaces for RCU that will allow the slab allocators to avoid a recursion bug located by Sasha Levin. Strictly speaking, this is not a regression, but it would be good to enable the fix. 2. Address a serious performance regression on an open/close micro-benchmark located by Dave Hansen. The offending commit is ac1bea85781e (Make cond_resched() report RCU quiescent states). " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-24ARM: mvebu: Fix the improper use of the compatible string armada38x using a ↵Gregory CLEMENT
wildcard Wildcards in compatible strings should be avoid. "marvell,armada38x" was recently introduced but was not yet used. The armada 385 SoC is a superset of the armada 380 SoC (with more CPUs and more PCIe slots). So this patch replaces the use of "marvell,armada38x" by the "marvell,armada380" string. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1403533011-21339-1-git-send-email-gregory.clement@free-electrons.com Acked-by: Andrew Lunn <andrew@lunn.ch> Cc: <stable@vger.kernel.org> # v3.15+ Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-23kernel/watchdog.c: print traces for all cpus on lockup detectionAaron Tomlin
A 'softlockup' is defined as a bug that causes the kernel to loop in kernel mode for more than a predefined period to time, without giving other tasks a chance to run. Currently, upon detection of this condition by the per-cpu watchdog task, debug information (including a stack trace) is sent to the system log. On some occasions, we have observed that the "victim" rather than the actual "culprit" (i.e. the owner/holder of the contended resource) is reported to the user. Often this information has proven to be insufficient to assist debugging efforts. To avoid loss of useful debug information, for architectures which support NMI, this patch makes it possible to improve soft lockup reporting. This is accomplished by issuing an NMI to each cpu to obtain a stack trace. If NMI is not supported we just revert back to the old method. A sysctl and boot-time parameter is available to toggle this feature. [dzickus@redhat.com: add CONFIG_SMP in certain areas] [akpm@linux-foundation.org: additional CONFIG_SMP=n optimisations] [mq@suse.cz: fix warning] Signed-off-by: Aaron Tomlin <atomlin@redhat.com> Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Mateusz Guzik <mguzik@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Jan Moskyto Matejka <mq@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23Documentation/accounting/getdelays.c: add missing null-terminate after ↵Rickard Strandqvist
strncpy call Added a guaranteed null-terminate after call to strncpy. This was partly found using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm, pcp: allow restoring percpu_pagelist_fraction defaultDavid Rientjes
Oleg reports a division by zero error on zero-length write() to the percpu_pagelist_fraction sysctl: divide error: 0000 [#1] SMP DEBUG_PAGEALLOC CPU: 1 PID: 9142 Comm: badarea_io Not tainted 3.15.0-rc2-vm-nfs+ #19 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8800d5aeb6e0 ti: ffff8800d87a2000 task.ti: ffff8800d87a2000 RIP: 0010: percpu_pagelist_fraction_sysctl_handler+0x84/0x120 RSP: 0018:ffff8800d87a3e78 EFLAGS: 00010246 RAX: 0000000000000f89 RBX: ffff88011f7fd000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000010 RBP: ffff8800d87a3e98 R08: ffffffff81d002c8 R09: ffff8800d87a3f50 R10: 000000000000000b R11: 0000000000000246 R12: 0000000000000060 R13: ffffffff81c3c3e0 R14: ffffffff81cfddf8 R15: ffff8801193b0800 FS: 00007f614f1e9740(0000) GS:ffff88011f440000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f614f1fa000 CR3: 00000000d9291000 CR4: 00000000000006e0 Call Trace: proc_sys_call_handler+0xb3/0xc0 proc_sys_write+0x14/0x20 vfs_write+0xba/0x1e0 SyS_write+0x46/0xb0 tracesys+0xe1/0xe6 However, if the percpu_pagelist_fraction sysctl is set by the user, it is also impossible to restore it to the kernel default since the user cannot write 0 to the sysctl. This patch allows the user to write 0 to restore the default behavior. It still requires a fraction equal to or larger than 8, however, as stated by the documentation for sanity. If a value in the range [1, 7] is written, the sysctl will return EINVAL. This successfully solves the divide by zero issue at the same time. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Oleg Drokin <green@linuxhacker.ru> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm, hotplug: probe interface is available on several platformsDavid Rientjes
Documentation/memory-hotplug.txt incorrectly states that the memory driver "probe" interface is only supported on powerpc and is vague about its application on x86. Clarify the platforms that make this interface available if memory hotplug is enabled. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23rcu: Reduce overhead of cond_resched() checks for RCUPaul E. McKenney
Commit ac1bea85781e (Make cond_resched() report RCU quiescent states) fixed a problem where a CPU looping in the kernel with but one runnable task would give RCU CPU stall warnings, even if the in-kernel loop contained cond_resched() calls. Unfortunately, in so doing, it introduced performance regressions in Anton Blanchard's will-it-scale "open1" test. The problem appears to be not so much the increased cond_resched() path length as an increase in the rate at which grace periods complete, which increased per-update grace-period overhead. This commit takes a different approach to fixing this bug, mainly by moving the RCU-visible quiescent state from cond_resched() to rcu_note_context_switch(), and by further reducing the check to a simple non-zero test of a single per-CPU variable. However, this approach requires that the force-quiescent-state processing send resched IPIs to the offending CPUs. These will be sent only once the grace period has reached an age specified by the boot/sysfs parameter rcutree.jiffies_till_sched_qs, or once the grace period reaches an age halfway to the point at which RCU CPU stall warnings will be emitted, whichever comes first. Reported-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Lameter <cl@gentwo.org> Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> [ paulmck: Made rcu_momentary_dyntick_idle() as suggested by the ktest build robot. Also fixed smp_mb() comment as noted by Oleg Nesterov. ] Merge with e552592e (Reduce overhead of cond_resched() checks for RCU) Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2014-06-22spi: qup: Remove chip select functionAndy Gross
This patch removes the chip select function. Chip select should instead be supported using GPIOs, defining the DT entry "cs-gpios", and letting the SPI core assert/deassert the chip select as it sees fit. The chip select control inside the controller is buggy. It is supposed to automatically assert the chip select based on the activity in the controller, but it is buggy and doesn't work at all. So instead we elect to use GPIOs. Signed-off-by: Andy Gross <agross@codeaurora.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-21Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c new drivers from Wolfram Sang: "Here is a pull request from i2c hoping for the "new driver" rule. Originally, I wanted to send this request during the merge window, but code checkers with very recent additions complained, so a few fixups were needed. So, some more time went by and I merged rc1 to get a stable base" So the "new driver" rule is really about drivers that people absolutely need for the kernel to work on new hardware, which is not so much the case for i2c. So I considered not pulling this, but eventually relented. Just for FYI: the whole (and only) point of "new drivers" is not that new drivers cannot regress things (they can, and they have - by triggering badly tested code on machines that never triggered that code before), but because they can bring to life machines that otherwise wouldn't be useful at all without the drivers. So the new driver rule is for essential things that actual consumers would care about, ie devices like networking or disk drivers that matter to normal people (not server people - they run old kernels anyway, so mainlining new drivers is irrelevant for them). * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: sun6-p2wi: fix call to snprintf i2c: rk3x: add NULL entry to the end of_device_id array i2c: sun6i-p2wi: use proper return value in probe i2c: sunxi: add P2WI (Push/Pull 2 Wire Interface) controller support i2c: sunxi: add P2WI DT bindings documentation i2c: rk3x: add driver for Rockchip RK3xxx SoC I2C adapter
2014-06-21Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "There are three fixes for regressions caused by the relative paths series: deb-pkg, tar-pkg and *docs did not work with O=. Plus, there is a fix for the linux-headers deb package and a fixed typo. These are not regression fixes but are safe enough" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: fix a typo in a kbuild document builddeb: fix missing headers in linux-headers package Documentation: Fix DocBook build with relative $(srctree) kbuild: Fix tar-pkg with relative $(objtree) deb-pkg: Fix for relative paths
2014-06-19Merge tag 'pm+acpi-3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are fixes mostly (ia64 regression related to the ACPI enumeration of devices, cpufreq regressions, fix for I2C controllers included in Intel SoCs, mvebu cpuidle driver fix related to sysfs) plus additional kernel command line arguments from Kees to make it possible to build kernel images with hibernation and the kernel address space randomization included simultaneously, a new ACPI battery driver quirk for a system with a broken BIOS and a couple of ACPI core cleanups. Specifics: - Fix for an ia64 regression introduced during the 3.11 cycle by a commit that modified the hardware initialization ordering and made device discovery fail on some systems. - Fix for a build problem on systems where the cpufreq-cpu0 driver is built-in and the cpu-thermal driver is modular from Arnd Bergmann. - Fix for a recently introduced computational mistake in the intel_pstate driver that leads to excessive rounding errors from Doug Smythies. - Fix for a failure code path in cpufreq_update_policy() that fails to unlock the locks acquired previously from Aaron Plattner. - Fix for the cpuidle mvebu driver to use shorter state names which will prevent the sysfs interface from returning mangled strings. From Gregory Clement. - ACPI LPSS driver fix to make sure that the I2C controllers included in BayTrail SoCs are not held in the reset state while they are being probed from Mika Westerberg. - New kernel command line arguments making it possible to build kernel images with hibernation and kASLR included at the same time and to select which of them will be used via the command line (they are still functionally mutually exclusive, though). From Kees Cook. - ACPI battery driver quirk for Acer Aspire V5-573G that fails to send battery status change notifications timely from Alexander Mezin. - Two ACPI core cleanups from Christoph Jaeger and Fabian Frederick" * tag 'pm+acpi-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpuidle: mvebu: Fix the name of the states cpufreq: unlock when failing cpufreq_update_policy() intel_pstate: Correct rounding in busy calculation ACPI: use kstrto*() instead of simple_strto*() ACPI / processor replace __attribute__((packed)) by __packed ACPI / battery: add quirk for Acer Aspire V5-573G ACPI / battery: use callback for setting up quirks ACPI / LPSS: Take I2C host controllers out of reset x86, kaslr: boot-time selectable with hibernation PM / hibernate: introduce "nohibernate" boot parameter cpufreq: cpufreq-cpu0: fix CPU_THERMAL dependency ACPI / ia64 / sba_iommu: Restore the working initialization ordering
2014-06-18kbuild: fix a typo in a kbuild documentMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-18Documentation: Fix DocBook build with relative $(srctree)Michal Marek
After commits 890676c6 (kbuild: Use relative path when building in the source tree) and 9da0763b (kbuild: Use relative path when building in a subdir of the source tree), the $(srctree) variable can be a relative path. This breaks Documentation/DocBook/media/Makefile, because it tries to create symlinks from a subdirectory of the object tree to the source tree. Fix this by using a full path in this case. Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Tested-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-17Merge tag 'v3.16-rc1' into i2c/for-nextWolfram Sang
Merge a stable base (Linux 3.16-rc1) Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-17Merge branch 'drm-nouveau-next' of ↵Dave Airlie
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-next This is bigger because it regenerates the internal firmwares after a fix. * 'drm-nouveau-next' of git://anongit.freedesktop.org/git/nouveau/linux-2.6: drm/nouveau/doc: update the thermal documentation drm/nouveau/pwr: fix typo in fifo wrap handling drm/nv50/disp: fix a potential oops in supervisor handling drm/nouveau/disp/dp: don't touch link config after success drm/nouveau/kms: reference vblank for crtc during pageflip. drm/gk104/fb/ram: fixups from an earlier search+replace drm/nv50/gr: remove an unneeded write while initialising PGRAPH drm/nv50/gr: fix overlap while zeroing zcull regions drm/gf100-/gr: report class data to host on fwmthd failure drm/gk104/ibus: increase various random timeouts drm/gk104/clk: only touch divider for mode we'll be using
2014-06-17drm/nouveau/doc: update the thermal documentationMartin Peres
Changes: - Change the maintainer's address (the labri address will expire soon); - Drop the note about not all families supporting all fan modes; - Add a note about the reported RPM not being accurate when driven outside the vbios-defined PWM range. Signed-off-by: Martin Peres <martin.peres@free.fr> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-06-16ptp: In the testptp utility, use clock_adjtime from glibc when availableChristian Riesch
clock_adjtime was included in glibc 2.14. _GNU_SOURCE must be defined to make it available. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Richard Cochran <richardcochran@gmail.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-16x86, kaslr: boot-time selectable with hibernationKees Cook
Changes kASLR from being compile-time selectable (blocked by CONFIG_HIBERNATION), to being boot-time selectable (with hibernation available by default) via the "kaslr" kernel command line. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-16PM / hibernate: introduce "nohibernate" boot parameterKees Cook
To support using kernel features that are not compatible with hibernation, this creates the "nohibernate" kernel boot parameter to disable both hibernation and resume. This allows hibernation support to be a boot-time choice instead of only a compile-time choice. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-15Merge tag 'clk-for-linus-3.16-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework updates from Mike Turquette: "This contains the second half the of the clk changes for 3.16. They are simply fixes and code refactoring for the OMAP clock drivers. The sunxi clock driver changes include splitting out the one mega-driver into several smaller pieces and adding support for the A31 SoC clocks" * tag 'clk-for-linus-3.16-part2' of git://git.linaro.org/people/mike.turquette/linux: (25 commits) clk: sunxi: document PRCM clock compatible strings clk: sunxi: add PRCM (Power/Reset/Clock Management) clks support clk: sun6i: Protect SDRAM gating bit clk: sun6i: Protect CPU clock clk: sunxi: Rework clock protection code clk: sunxi: Move the GMAC clock to a file of its own clk: sunxi: Move the 24M oscillator to a file of its own clk: sunxi: Remove calls to clk_put clk: sunxi: document new A31 USB clock compatible clk: sunxi: Implement A31 USB clock ARM: dts: OMAP5/DRA7: use omap5-mpu-dpll-clock capable of dealing with higher frequencies CLK: TI: dpll: support OMAP5 MPU DPLL that need special handling for higher frequencies ARM: OMAP5+: dpll: support Duty Cycle Correction(DCC) CLK: TI: clk-54xx: Set the rate for dpll_abe_m2x2_ck CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic) dt:/bindings: DRA7 ATL (Audio Tracking Logic) clock bindings ARM: dts: dra7xx-clocks: Correct name for atl clkin3 clock CLK: TI: gate: add composite interface clock to OMAP2 only build ARM: OMAP2: clock: add DT boot support for cpufreq_ck CLK: TI: OMAP2: add clock init support ...
2014-06-14Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 vdso fixes from Peter Anvin: "Fixes for x86/vdso. One is a simple build fix for bigendian hosts, one is to make "make vdso_install" work again, and the rest is about working around a bug in Google's Go language -- two are documentation patches that improves the sample code that the Go coders took, modified, and broke; the other two implements a workaround that keeps existing Go binaries from segfaulting at least" * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vdso: Fix vdso_install x86/vdso: Hack to keep 64-bit Go programs working x86/vdso: Add PUT_LE to store little-endian values x86/vdso/doc: Make vDSO examples more portable x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.c x86, vdso: Remove one final use of htole16()
