path: root/Documentation
2015-08-03pinctrl: mvebu: armada-xp: fix functions of MPP48Thomas Petazzoni
commit ea78b9511a54d0de026e04b5da86b30515072f31 upstream. There was a mistake in the definition of the functions for MPP48 on Marvell Armada XP. The second function is dev(clkout), and not tclk. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03pinctrl: mvebu: armada-xp: remove non-existing VDD cpu_pd functionsThomas Petazzoni
commit 80b3d04feab5e69d51cb2375eb989a7165e43e3b upstream. The latest version of the Armada XP datasheet no longer documents the VDD cpu_pd functions, which might indicate they are not working and/or not supported. This commit ensures the pinctrl driver matches the datasheet. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03pinctrl: mvebu: armada-xp: remove non-existing NAND pinsThomas Petazzoni
commit bc99357f3690c11817756adfee0ece811a3db2e7 upstream. After updating to a more recent version of the Armada XP datasheet, we realized that some of the pins documented as having a NAND-related functionality in fact did not have such functionality. This commit updates the pinctrl driver accordingly. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03pinctrl: mvebu: armada-370: fix spi0 pin descriptionThomas Petazzoni
commit 438881dfddb9107ef0eb30b49368e91e092f0b3e upstream. Due to a mistake, the CS0 and CS1 SPI0 functions were incorrectly named "spi0-1" instead of just "spi0". This commit fixes that. This DT binding change does not affect any of the in-tree users. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Fixes: 5f597bb2be57 ("pinctrl: mvebu: add pinctrl driver for Armada 370") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03spi: pl022: Specify 'num-cs' property as required in devicetree bindingEzequiel Garcia
commit ea6055c46eda1e19e02209814955e13f334bbe1b upstream. Since commit 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data") the 'num-cs' parameter cannot be passed through platform data when probing with devicetree. Instead, it's a required devicetree property. Fix the binding documentation so the property is properly specified. Fixes: 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data") Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx28: Fix AUART4 TX-DMA interrupt nameMarek Vasut
commit 4ada77e37a773168fea484899201e272ab44ba8b upstream. Fix a typo in the TX DMA interrupt name for AUART4. This patch makes AUART4 operational again. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma") Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27Input: i8042 - reset keyboard to fix Elantech touchpad detectionSrihari Vijayaraghavan
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream. On some laptops, keyboard needs to be reset in order to successfully detect touchpad (e.g., some Gigabyte laptop models with Elantech touchpads). Without resettin keyboard touchpad pretends to be completely dead. Based on the original patch by Mateusz Jończyk this version has been expanded to include DMI based detection & application of the fix automatically on the affected models of laptops. This has been confirmed to fix problem by three users already on three different models of laptops. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331 Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com> Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl> Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com> Tested by: Zakariya Dehlawi <zdehlawi@gmail.com> Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16pstore-ram: Allow optional mapping with pgprot_noncachedTony Lindgren
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream. On some ARMs the memory can be mapped pgprot_noncached() and still be working for atomic operations. As pointed out by Colin Cross <ccross@android.com>, in some cases you do want to use pgprot_noncached() if the SoC supports it to see a debug printk just before a write hanging the system. On ARMs, the atomic operations on strongly ordered memory are implementation defined. So let's provide an optional kernel parameter for configuring pgprot_noncached(), and use pgprot_writecombine() by default. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robherring2@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30Documentation: lzo: document part of the encodingWilly Tarreau
commit d98a0526434d27e261f622cf9d2e0028b5ff1a00 upstream. Add a complete description of the LZO format as processed by the decompressor. I have not found a public specification of this format hence this analysis, which will be used to better understand the code. Cc: Willem Pinckaers <willem@lekkertech.net> Cc: "Don A. Bailey" <donb@securitymouse.com> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05ALSA: virtuoso: add Xonar Essence STX II supportClemens Ladisch
commit f42bb22243d2ae264d721b055f836059fe35321f upstream. Just add the PCI ID for the STX II. It appears to work the same as the STX, except for the addition of the not-yet-supported daughterboard. Tested-by: Mario <fugazzi99@gmail.com> Tested-by: corubba <corubba@gmx.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05stable_kernel_rules: Add pointer to netdev-FAQ for network patchesDave Chiluk
commit b76fc285337b6b256e9ba20a40cfd043f70c27af upstream. Stable_kernel_rules should point submitters of network stable patches to the netdev_FAQ.txt as requests for stable network patches should go to netdev first. Signed-off-by: Dave Chiluk <chiluk@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-07x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stackH. Peter Anvin
commit 3891a04aafd668686239349ea58f3314ea2af86b upstream. The IRET instruction, when returning to a 16-bit segment, only restores the bottom 16 bits of the user space stack pointer. This causes some 16-bit software to break, but it also leaks kernel state to user space. We have a software workaround for that ("espfix") for the 32-bit kernel, but it relies on a nonzero stack segment base which is not available in 64-bit mode. In checkin: b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels we "solved" this by forbidding 16-bit segments on 64-bit kernels, with the logic that 16-bit support is crippled on 64-bit kernels anyway (no V86 support), but it turns out that people are doing stuff like running old Win16 binaries under Wine and expect it to work. This works around this by creating percpu "ministacks", each of which is mapped 2^16 times 64K apart. When we detect that the return SS is on the LDT, we copy the IRET frame to the ministack and use the relevant alias to return to userspace. The ministacks are mapped readonly, so if IRET faults we promote #GP to #DF which is an IST vector and thus has its own stack; we then do the fixup in the #DF handler. (Making #GP an IST exception would make the msr_safe functions unsafe in NMI/MC context, and quite possibly have other effects.) Special thanks to: - Andy Lutomirski, for the suggestion of using very small stack slots and copy (as opposed to map) the IRET frame there, and for the suggestion to mark them readonly and let the fault promote to #DF. - Konrad Wilk for paravirt fixup and testing. - Borislav Petkov for testing help and useful comments. Reported-by: Brian Gerst <brgerst@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Andrew Lutomriski <amluto@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dirk Hohndel <dirk@hohndel.org> Cc: Arjan van de Ven <arjan.van.de.ven@intel.com> Cc: comex <comexk@gmail.com> Cc: Alexander van Heukelum <heukelum@fastmail.fm> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06Documentation/SubmittingPatches: describe the Fixes: tagJacob Keller
commit 8401aa1f59975c03eeebd3ac6d264cbdfe9af5de upstream. Update the SubmittingPatches process to include howto about the new 'Fixes:' tag to be used when a patch fixes an issue in a previous commit (found by git-bisect for example). Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11perf: Drop sample rate when sampling is too slowDave Hansen
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream. This patch keeps track of how long perf's NMI handler is taking, and also calculates how many samples perf can take a second. If the sample length times the expected max number of samples exceeds a configurable threshold, it drops the sample rate. This way, we don't have a runaway sampling process eating up the CPU. This patch can tend to drop the sample rate down to level where perf doesn't work very well. *BUT* the alternative is that my system hangs because it spends all of its time handling NMIs. I'll take a busted performance tool over an entire system that's busted and undebuggable any day. BTW, my suspicion is that there's still an underlying bug here. Using the HPET instead of the TSC is definitely a contributing factor, but I suspect there are some other things going on. But, I can't go dig down on a bug like that with my machine hanging all the time. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org Cc: acme@ghostprotocols.net Cc: Dave Hansen <dave@sr71.net> [ Prettified it a bit. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11Documentation: fix DOCBOOKS=... buildingJohannes Berg
commit e60cbeedc48d80689c249ab5dcc3c31ad0452dea upstream. Prior to commit 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory") it was possible to build only a single (or more) book(s) by calling, for example make htmldocs DOCBOOKS=80211.xml This now fails: cp: target `.../Documentation/DocBook//media_api' is not a directory Ignore errors from that copy to make this possible again. Fixes: 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07Input: elantech - fix touchpad initialization on Gigabyte U2442Hans de Goede
commit 36189cc3cd57ab0f1cd75241f93fe01de928ac06 upstream. The hw_version 3 Elantech touchpad on the Gigabyte U2442 does not accept 0x0b as initialization value for r10, this stand-alone version of the driver: http://planet76.com/drivers/elantech/psmouse-elantech-v6.tar.bz2 Uses 0x03 which does work, so this means not setting bit 3 of r10 which sets: "Enable Real H/W Resolution In Absolute mode" Which will result in half the x and y resolution we get with that bit set, so simply not setting it everywhere is not a solution. We've been unable to find a way to identify touchpads where setting the bit will fail, so this patch uses a dmi based blacklist for this. https://bugzilla.kernel.org/show_bug.cgi?id=61151 Reported-by: Philipp Wolfer <ph.wolfer@gmail.com> Tested-by: Philipp Wolfer <ph.wolfer@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07i2c: i801: enable Intel BayTrail SMBUSChew, Kean ho
commit 1b31e9b76ef8c62291e698dfdb973499986a7f68 upstream. Add Device ID of Intel BayTrail SMBus Controller. Signed-off-by: Chew, Kean ho <kean.ho.chew@intel.com> Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: "Chang, Rebecca Swee Fun" <rebecca.swee.fun.chang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCHJames Ralston
commit afc659241258b40b683998ec801d25d276529f43 upstream. This patch adds the SMBus Device IDs for the Intel Wildcat Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: "Chang, Rebecca Swee Fun" <rebecca.swee.fun.chang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07Documentation: Update stable address in Chinese and Japanese translationsGeert Uytterhoeven
commit 98b0f811aade1b7c6e7806c86aa0befd5919d65f upstream. The English and Korean translations were updated, the Chinese and Japanese weren't. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06media: media: gspca: sn9c20x: add ID for Genius Look 1320 V2Wolfram Sang
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13i2c: i801: SMBus patch for Intel Coleto Creek DeviceIDsSeth Heasley
commit f39901c1befa556bc91902516a3e2e460000b4a8 upstream. This patch adds the i801 SMBus Controller DeviceIDs for the Intel Coleto Creek PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: "Chan, Wei Sern" <wei.sern.chan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13mm, oom: base root bonus on current usageDavid Rientjes
commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream. A 3% of system memory bonus is sometimes too excessive in comparison to other processes. With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM killer tries to avoid killing privileged tasks by subtracting 3% of overall memory (system or cgroup) from their per-task consumption. But as a result, all root tasks that consume less than 3% of overall memory are considered equal, and so it only takes 33+ privileged tasks pushing the system out of memory for the OOM killer to do something stupid and kill dhclient or other root-owned processes. For example, on a 32G machine it can't tell the difference between the 1M agetty and the 10G fork bomb member. The changelog describes this 3% boost as the equivalent to the global overcommit limit being 3% higher for privileged tasks, but this is not the same as discounting 3% of overall memory from _every privileged task individually_ during OOM selection. Replace the 3% of system memory bonus with a 3% of current memory usage bonus. By giving root tasks a bonus that is proportional to their actual size, they remain comparable even when relatively small. In the example above, the OOM killer will discount the 1M agetty's 256 badness points down to 179, and the 10G fork bomb's 262144 points down to 183500 points and make the right choice, instead of discounting both to 0 and killing agetty because it's first in the task list. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06ata: sata_mv: introduce compatible string "marvell, armada-370-sata"Simon Guinot
commit b1f5c73bd5a4752efb7d7af019034044b08aafe9 upstream. The sata_mv driver supports the SATA IP found in several Marvell SoCs. As some new SATA registers have been introduced with the Armada 370/XP SoCs, a way to identify them is needed. This patch introduces a new compatible string for the SATA IP found in Armada 370/XP SoCs. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Lior Amsalem <alior@marvell.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15packet: fix send path when running with proto == 0Daniel Borkmann
[ Upstream commit 66e56cd46b93ef407c60adcac62cf33b06119d50 ] Commit e40526cb20b5 introduced a cached dev pointer, that gets hooked into register_prot_hook(), __unregister_prot_hook() to update the device used for the send path. We need to fix this up, as otherwise this will not work with sockets created with protocol = 0, plus with sll_protocol = 0 passed via sockaddr_ll when doing the bind. So instead, assign the pointer directly. The compiler can inline these helper functions automagically. While at it, also assume the cached dev fast-path as likely(), and document this variant of socket creation as it seems it is not widely used (seems not even the author of TX_RING was aware of that in his reference example [1]). Tested with reproducer from e40526cb20b5. [1] http://wiki.ipxwarzone.com/index.php5?title=Linux_packet_mmap#Example Fixes: e40526cb20b5 ("packet: fix use after free race in send path when dev is released") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Tested-by: Salam Noureddine <noureddine@aristanetworks.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libata: disable a disk via libata.force paramsRobin H. Johnson
commit b8bd6dc36186fe99afa7b73e9e2d9a98ad5c4865 upstream. A user on StackExchange had a failing SSD that's soldered directly onto the motherboard of his system. The BIOS does not give any option to disable it at all, so he can't just hide it from the OS via the BIOS. The old IDE layer had hdX=noprobe override for situations like this, but that was never ported to the libata layer. This patch implements a disable flag for libata.force. Example use: libata.force=2.0:disable [v2 of the patch, removed the nodisable flag per Tejun Heo] Signed-off-by: Robin H. Johnson <robbat2@gentoo.org> Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://unix.stackexchange.com/questions/102648/how-to-tell-linux-kernel-3-0-to-completely-ignore-a-failing-disk Link: http://askubuntu.com/questions/352836/how-can-i-tell-linux-kernel-to-completely-ignore-a-disk-as-if-it-was-not-even-co Link: http://superuser.com/questions/599333/how-to-disable-kernel-probing-for-drive Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libata: Add atapi_dmadir force flagVincent Pelletier
commit 966fbe193f47c68e70a80ec9991098e88e7959cb upstream. Some device require DMADIR to be enabled, but are not detected as such by atapi_id_dmadir. One such example is "Asus Serillel 2" SATA-host-to-PATA-device bridge: the bridge itself requires DMADIR, even if the bridged device does not. As atapi_dmadir module parameter can cause problems with some devices (as per Tejun Heo's memory), enabling it globally may not be possible depending on the hardware. This patch adds atapi_dmadir in the form of a "force" horkage value, allowing global, per-bus and per-device control. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08tcp: tsq: restore minimal amount of queueingEric Dumazet
[ Upstream commit 98e09386c0ef4dfd48af7ba60ff908f0d525cdee ] After commit c9eeec26e32e ("tcp: TSQ can use a dynamic limit"), several users reported throughput regressions, notably on mvneta and wifi adapters. 802.11 AMPDU requires a fair amount of queueing to be effective. This patch partially reverts the change done in tcp_write_xmit() so that the minimal amount is sysctl_tcp_limit_output_bytes. It also remove the use of this sysctl while building skb stored in write queue, as TSO autosizing does the right thing anyway. Users with well behaving NICS and correct qdisc (like sch_fq), can then lower the default sysctl_tcp_limit_output_bytes value from 128KB to 8KB. This new usage of sysctl_tcp_limit_output_bytes permits each driver authors to check how their driver performs when/if the value is set to a minimum of 4KB. Normally, line rate for a single TCP flow should be possible, but some drivers rely on timers to perform TX completion and too long TX completion delays prevent reaching full throughput. Fixes: c9eeec26e32e ("tcp: TSQ can use a dynamic limit") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Sujith Manoharan <sujith@msujith.org> Reported-by: Arnaud Ebalard <arno@natisbad.org> Tested-by: Sujith Manoharan <sujith@msujith.org> Cc: Felix Fietkau <nbd@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04vsprintf: check real user/group id for %pKRyan Mallon
commit 312b4e226951f707e120b95b118cbc14f3d162b2 upstream. Some setuid binaries will allow reading of files which have read permission by the real user id. This is problematic with files which use %pK because the file access permission is checked at open() time, but the kptr_restrict setting is checked at read() time. If a setuid binary opens a %pK file as an unprivileged user, and then elevates permissions before reading the file, then kernel pointer values may be leaked. This happens for example with the setuid pppd application on Ubuntu 12.04: $ head -1 /proc/kallsyms 00000000 T startup_32 $ pppd file /proc/kallsyms pppd: In file /proc/kallsyms: unrecognized option 'c1000000' This will only leak the pointer value from the first line, but other setuid binaries may leak more information. Fix this by adding a check that in addition to the current process having CAP_SYSLOG, that effective user and group ids are equal to the real ids. If a setuid binary reads the contents of a file which uses %pK then the pointer values will be printed as NULL if the real user is unprivileged. Update the sysctl documentation to reflect the changes, and also correct the documentation to state the kptr_restrict=0 is the default. This is a only temporary solution to the issue. The correct solution is to do the permission check at open() time on files, and to replace %pK with a function which checks the open() time permission. %pK uses in printk should be removed since no sane permission check can be done, and instead protected by using dmesg_restrict. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Joe Perches <joe@perches.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04tcp: TSO packets automatic sizingEric Dumazet
[ Upstream commits 6d36824e730f247b602c90e8715a792003e3c5a7, 02cf4ebd82ff0ac7254b88e466820a290ed8289a, and parts of 7eec4174ff29cd42f2acfae8112f51c228545d40 ] After hearing many people over past years complaining against TSO being bursty or even buggy, we are proud to present automatic sizing of TSO packets. One part of the problem is that tcp_tso_should_defer() uses an heuristic relying on upcoming ACKS instead of a timer, but more generally, having big TSO packets makes little sense for low rates, as it tends to create micro bursts on the network, and general consensus is to reduce the buffering amount. This patch introduces a per socket sk_pacing_rate, that approximates the current sending rate, and allows us to size the TSO packets so that we try to send one packet every ms. This field could be set by other transports. Patch has no impact for high speed flows, where having large TSO packets makes sense to reach line rate. For other flows, this helps better packet scheduling and ACK clocking. This patch increases performance of TCP flows in lossy environments. A new sysctl (tcp_min_tso_segs) is added, to specify the minimal size of a TSO packet (default being 2). A follow-up patch will provide a new packet scheduler (FQ), using sk_pacing_rate as an input to perform optional per flow pacing. This explains why we chose to set sk_pacing_rate to twice the current rate, allowing 'slow start' ramp up. sk_pacing_rate = 2 * cwnd * mss / srtt v2: Neal Cardwell reported a suspect deferring of last two segments on initial write of 10 MSS, I had to change tcp_tso_should_defer() to take into account tp->xmit_size_goal_segs Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Van Jacobson <vanj@google.com> Cc: Tom Herbert <therbert@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26media: DocBook: upgrade media_api DocBook version to 4.2Andrzej Hajda
commit 8bfd4a68ecc003c1a142f35551be846d6b13e822 upstream. Fixes the last three errors of media_api DocBook validatation: (...) media_api.xml:414: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set media_api.xml:432: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set media_api.xml:452: element imagedata: validity error : Value "SVG" for attribute format of imagedata is not among the enumerated set (...) Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07hwmon: (k10temp) Add support for Fam16h (Kabini)Wei Hu
commit 30b146d1cb5e7560192057098eb705118bd5511f upstream. The temperature reporting interface stays the same, so we just add the PCI-ID to the list. Verified on AMD Olive Hill. Signed-off-by: Wei Hu <wei@aristanetworks.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25i2c-piix4: Add AMD CZ SMBus device IDShane Huang
commit b996ac90f595dda271cbd858b136b45557fc1a57 upstream. To add AMD CZ SMBus controller device ID. [bhelgaas: drop pci_ids.h update] Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21parisc: document the shadow registersHelge Deller
commit a83f58bcb24003b9de2364de7c829a263423ead7 upstream. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Found via trinity: If you connect up an ipv6 socket to an ipv4 mapped address then an ipv6 one, sendmsg() can croak because ip6_sk_dst_check() assumes the route cached in the socket is an ipv6 one. In this case there is an ipv4 route attached, so it gets stomped on. Reported by Dave Jones and Hannes Frederic Sowa, fixed by Eric Dumazet. 2) AF_KEY notifications leak some kernel memory to userspace, fix from Mathias Krause. 3) DLCI calls __dev_get_by_name() without proper locking, and dlci_del doesn't validate that the device being deleted is actually a DLCI one. Fixes from Li Zefan. 4) Length check on bluetooth l2cap information responses is wrong, each response type has a different lenth, so we should make sure it's in a given range rather than enforce one single valid length. From Jaganath Kanakkassery. 5) Receive FIFO overflow is really easy to trigger in stress scenerios in the sh_eth driver, but the event isn't being handled properly at all. Specifically, the mask of error interrupts doesn't include the event so we never clear it, resulting in the driver becomming wedged processing an interrupt that never gets cleared. Fix from Sergei Shtylyov. 6) qlcnic sleeps while holding a spinlock, use mdelay() instead of msleep(). From Shahed Shaikh. 7) Missing curly braces causes SIP netfilter NAT module to always drop packets. Fix from Balazs Peter Odor. 8) ipt_ULOG in netfilter passes the wrong value to timer setup, causing the timer to dereference crap when it fires. Fix from Gao Feng. 9) Missing RCU protection around txq->axq_acq traversal in ath_txq_schedule(). Fix from Felix Fietkau. 10) Idle state transition test in ath9k_htc_config() is reversed, fix from Sujith Manoharan. 11) IPV6 forwarding handles unicast Router Alert packets incorrectly. It tests the wrong option state. Previously opt->ra being non-zero indicated a router alert marking in the SKB, but now it's indicated by a bit in opt->flags. Fix from YOSHIFUJI Hideaki. 12) SKB leak in GRE tunnel GSO handling, from Eric Dumazet. 13) get_user_pages_fast() error handling in TUN and MACVTAP use the same local variable for the base index and the loop iterator for page traversal, oops! Fix from Michael S Tsirkin. 14) ipv6_get_lladdr() can fail, and we must therefore check it's return value in inet6_set_iftoken(). For from Hannes Frederic Sowa. 15) If you change an interface name and meanwhile can sneak in something that looks up the name (like SO_BINDTODEVICE or SIOCGIFNAME) we can deadlock with CONFIG_PREEMPT=n. Fix this by providing a helper function that properly uses raw_seqcount_begin(). From Nicolas Schichan. 16) Chain noise calibration test is inverted in iwlwifi, fix from Nikolay Martynov. 17) Properly set TX iwlwifi descriptor flags for back requests. Fix from Emmanuel Grumbach. 18) We can't assume skb_transport_header() is set in xt_TCPOPTSTRAP module, fix from Pablo Neira Ayuso. 19) Some crummy APs don't provide the proper High Throughput info in association response frames. Add a workaround by assume we'll use whatever is in the beacon/probe. Fix from Johannes Berg. 20) mac80211 call to rate_idx_match_mask() swaps two arguments (mask and channel width). Fix from Simon Wunderlich. 21) xt_TCPMSS (like xt_TCPOPTSTRAP) must not try to handle fragmented frames. Fix from Phil Oester. 22) Fix rate control regression causing iwlwifi/iwlegacy chips to use 1Mbit/s on pre-11n networks. From Moshe Benji and Stanslaw Gruszka. 23) Disable brcmsmac power-save functions, they cause regressions. From Arend van Spriel. 24) Enforce a sane minimum MTU in l2cap_build_cmd() otherwise we can easily crash. Fix from Anderson Lizardo. 25) If a learning packet arrives during vxlan_stop() we crash, easily fixed by checking netif_running(). From Stephen Hemminger. 26) Static vxlan FDB entries should not be migrated, also from Stephen. 27) skb_clone() failures not handled in vxlan_xmit(), oops. Also from Stephen. 28) Add minimal driver for AR816x/AR817x ethernet chips, from Johannes Berg. 29) Fix regression in userspace VLAN acceleration control, added by the 802.1ad support changes. Fix from Fernando Luis Vazquez Cao. 30) Interval selection for MLD queries in the bridging code was reversed. Fix from Linus Lüssing. 31) ipv6's ndisc_send_redirect() erroneously writes to the packet we received not the packet we are building to send out. Fix from Matthias Schiffer. 32) Don't free netdev before unregistering it, in usb_8dev can driver. From Marc Kleine-Budde. 33) Fix nl80211 attribute buffer races, from Johannes Berg. 34) Although netlink_diag.h is under uapi/ it isn't present in Kbuild. From Stephen Hemminger. 35) Wrong address and family passed to MD5 key lookups in TCP, from Aydin Arik. 36) phy_type attribute created by SFC driver should not be writable. From Ben Hutchings. 37) Receive/Transmit queue allocations in pxa168_eth and mv643xx_eth should use kzalloc(). Otherwise if setup fails half-way, we'll dereference garbage when trying to teardown the rings. From Lubomir Rintel. 38) Fix double-allocation of dst (resulting in unfreeable net device) in ipv6's init_loopback(). From Gao Feng. 39) Fix fragmentation handling SKB leak in netfilter conntrack, we were freeing the wrong skb pointer. From Phil Oester. 40) Don't report "-1" (SPEED_UNKNOWN) in bond_miimon_commit(), from Nikolay Aleksandrov. 41) davinci_cpdma doesn't check for DMA mapping errors, letting the device scribble to random addresses. From Sebastian Siewior. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (69 commits) dlci: validate the net device in dlci_del() dlci: acquire rtnl_lock before calling __dev_get_by_name() af_key: fix info leaks in notify messages ipv6: ip6_sk_dst_check() must not assume ipv6 dst net: fix kernel deadlock with interface rename and netdev name retrieval. net/tg3: Avoid delay during MMIO access ipv6: check return value of ipv6_get_lladdr macvtap: fix recovery from gup errors tun: fix recovery from gup errors gre: fix a possible skb leak ipv6: Process unicast packet with Router Alert by checking flag in skb. ath9k_htc: Handle IDLE state transition properly ath9k: fix an RCU issue in calling ieee80211_get_tx_rates netfilter: ipt_ULOG: fix incorrect setting of ulog timer netfilter: ctnetlink: send event when conntrack label was modified netfilter: nf_nat_sip: fix mangling qlcnic: Do not sleep while holding spinlock drivers: net: cpsw: fix compilation error with cpsw driver tcp: doc : fix the syncookies default value sh_eth: fix misreporting of transmit abort ...
2013-06-24tcp: doc : fix the syncookies default valueShan Wei
syncookies is on for default since in commit e994b7c901 (tcp: Don't make syn cookies initial setting depend on CONFIG_SYSCTL). And fix a typo of CONFIG_SYN_COOKIES. Signed-off-by: Shan Wei <davidshan@tencent.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-18Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Only driver/device-specific small fixes that are pretty safe to apply: - USB-audio Android and Logitech webcam fixes - HD-audio MacBook Air 4,2 quirk - Complete Dell headset quirk entries that were introduced in 3.10" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Add models for Dell headset jacks ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam c310 ALSA: hda - Fix pin configurations for MacBook Air 4,2 ALSA: usb-audio: work around Android accessory firmware bug ALSA: hda - Headset mic support for three more machines
2013-06-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "Series of fixes for 3.10. There are some usual driver fixes (mostly on s5p/exynos playform drivers), plus some fixes at V4L2 core" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (40 commits) [media] soc_camera: error dev remove and v4l2 call [media] sh_veu: fix the buffer size calculation [media] sh_veu: keep power supply until the m2m context is released [media] sh_veu: invoke v4l2_m2m_job_finish() even if a job has been aborted [media] v4l2-ioctl: don't print the clips list [media] v4l2-ctrls: V4L2_CTRL_CLASS_FM_RX controls are also valid radio controls [media] cx88: fix NULL pointer dereference [media] DocBook/media/v4l: update version number [media] exynos4-is: Remove "sysreg" clock handling [media] exynos4-is: Fix reported colorspace at FIMC-IS-ISP subdev [media] exynos4-is: Ensure fimc-is clocks are not enabled until properly configured [media] exynos4-is: Prevent NULL pointer dereference when firmware isn't loaded [media] s5p-mfc: Add NULL check for allocated buffer [media] s5p-mfc: added missing end-of-lines in debug messages [media] s5p-mfc: v4l2 controls setup routine moved to initialization code [media] s5p-mfc: separate encoder parameters for h264 and mpeg4 [media] s5p-mfc: Remove special clock usage in driver [media] s5p-mfc: Remove unused s5p_mfc_get_decoded_status_v6() function [media] v4l2: mem2mem: save irq flags correctly [media] coda: v4l2-compliance fix: add VIDIOC_CREATE_BUFS support ...
2013-06-17ALSA: hda - Add models for Dell headset jacksDavid Henningsson
These headset jacks keep coming in on more and more platforms, and it's possible I don't catch them all. Make it easier to test and verify by making models. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-12Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Outside of bcache (which really isn't super big), these are all few-liners. There are a few important fixes in here: - Fix blk pm sleeping when holding the queue lock - A small collection of bcache fixes that have been done and tested since bcache was included in this merge window. - A fix for a raid5 regression introduced with the bio changes. - Two important fixes for mtip32xx, fixing an oops and potential data corruption (or hang) due to wrong bio iteration on stacked devices." * 'for-linus' of git://git.kernel.dk/linux-block: scatterlist: sg_set_buf() argument must be in linear mapping raid5: Initialize bi_vcnt pktcdvd: silence static checker warning block: remove refs to XD disks from documentation blkpm: avoid sleep when holding queue lock mtip32xx: Correctly handle bio->bi_idx != 0 conditions mtip32xx: Fix NULL pointer dereference during module unload bcache: Fix error handling in init code bcache: clarify free/available/unused space bcache: drop "select CLOSURES" bcache: Fix incompatible pointer type warning
2013-06-12rtc-at91rm9200: use shadow IMR on at91sam9x5Johan Hovold
Add support for the at91sam9x5-family which must use the shadow interrupt mask due to a hardware issue (causing RTC_IMR to always be zero). Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Cc: Robert Nelson <Robert.Nelson@digikey.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-08[media] DocBook/media/v4l: update version numberHans Verkuil
The version number was still 3.9: update to 3.10. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-06-08Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "Fix from Andy is for dmatest regression reported by Will and Rabin has fixed runtime ref counting for st_dma40" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dmatest: do not allow to interrupt ongoing tests dmaengine: ste_dma40: fix pm runtime ref counting
2013-06-08dmatest: do not allow to interrupt ongoing testsAndy Shevchenko
When user interrupts ongoing transfers the dmatest may end up with console lockup, oops, or data mismatch. This patch prevents user to abort any ongoing test. Documentation is updated accordingly. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-06-06Merge tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull more xfs updates from Ben Myers: "Here are several fixes for filesystems with CRC support turned on: fixes for quota, remote attributes, and recovery. There is also some feature work related to CRCs: the implementation of CRCs for the inode unlinked lists, disabling noattr2/attr2 options when appropriate, and bumping the maximum number of ACLs. I would have preferred to defer this last category of items to 3.11. This would require setting a feature bit for the on-disk changes, so there is some pressure to get these in 3.10. I believe this represents the end of the CRC related queue. - Rework of dquot CRCs - Fix for remote attribute invalidation of a leaf - Fix ordering of transaction replay in recovery - Implement CRCs for inode unlinked list - Disable noattr2/attr2 mount options when CRCs are enabled - Bump the limitation of ACL entries for v5 superblocks" * tag 'for-linus-v3.10-rc5' of git://oss.sgi.com/xfs/xfs: xfs: increase number of ACL entries for V5 superblocks xfs: disable noattr2/attr2 mount options for CRC enabled filesystems xfs: inode unlinked list needs to recalculate the inode CRC xfs: fix log recovery transaction item reordering xfs: fix remote attribute invalidation for a leaf xfs: rework dquot CRCs
2013-06-06xfs: disable noattr2/attr2 mount options for CRC enabled filesystemsDave Chinner
attr2 format is always enabled for v5 superblock filesystems, so the mount options to enable or disable it need to be cause mount errors. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit d3eaace84e40bf946129e516dcbd617173c1cf14)
2013-06-01powerpc/tm: Fix userspace stack corruption on signal delivery for active ↵Michael Neuling
transactions When in an active transaction that takes a signal, we need to be careful with the stack. It's possible that the stack has moved back up after the tbegin. The obvious case here is when the tbegin is called inside a function that returns before a tend. In this case, the stack is part of the checkpointed transactional memory state. If we write over this non transactionally or in suspend, we are in trouble because if we get a tm abort, the program counter and stack pointer will be back at the tbegin but our in memory stack won't be valid anymore. To avoid this, when taking a signal in an active transaction, we need to use the stack pointer from the checkpointed state, rather than the speculated state. This ensures that the signal context (written tm suspended) will be written below the stack required for the rollback. The transaction is aborted becuase of the treclaim, so any memory written between the tbegin and the signal will be rolled back anyway. For signals taken in non-TM or suspended mode, we use the normal/non-checkpointed stack pointer. Tested with 64 and 32 bit signals Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # v3.9 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-01powerpc/tm: Abort on emulation and alignment faultsMichael Neuling
If we are emulating an instruction inside an active user transaction that touches memory, the kernel can't emulate it as it operates in transactional suspend context. We need to abort these transactions and send them back to userspace for the hardware to rollback. We can service these if the user transaction is in suspend mode, since the kernel will operate in the same suspend context. This adds a check to all alignment faults and to specific instruction emulations (only string instructions for now). If the user process is in an active (non-suspended) transaction, we abort the transaction go back to userspace allowing the HW to roll back the transaction and tell the user of the failure. This also adds new tm abort cause codes to report the reason of the persistent error to the user. Crappy test case here http://neuling.org/devel/junkcode/aligntm.c Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # v3.9 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-01powerpc/tm: Update cause codes documentationMichael Neuling
Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # 3.9 only Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-24Merge branch 'akpm' (incoming from Andrew Morton)Linus Torvalds
Merge fixes from Andrew Morton: "A bunch of fixes and one simple fbdev driver which missed the merge window because people will still talking about it (to no great effect)." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits) aio: fix kioctx not being freed after cancellation at exit time mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap() random: fix accounting race condition with lockless irq entropy_count update drivers/char/random.c: fix priming of last_data mm/memory_hotplug.c: fix printk format warnings nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary drivers/block/brd.c: fix brd_lookup_page() race fbdev: FB_GOLDFISH should depend on HAS_DMA drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq() auditfilter.c: fix kernel-doc warnings aio: fix io_getevents documentation revert "selftest: add simple test for soft-dirty bit" drivers/leds/leds-ot200.c: fix error caused by shifted mask mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer linux/kernel.h: fix kernel-doc warning mm compaction: fix of improper cache flush in migration code rapidio/tsi721: fix bug in MSI interrupt handling hfs: avoid crash in hfs_bnode_create ...
2013-05-24drivers/video: implement a simple framebuffer driverStephen Warren
A simple frame-buffer describes a raw memory region that may be rendered to, with the assumption that the display hardware has already been set up to scan out from that buffer. This is useful in cases where a bootloader exists and has set up the display hardware, but a Linux driver doesn't yet exist for the display hardware. Examples use-cases include: * The built-in LCD panels on the Samsung ARM chromebook, and Tegra devices, and likely many other ARM or embedded systems. These cannot yet be supported using a full graphics driver, since the panel control should be provided by the CDF (Common Display Framework), which has been stuck in design/review for quite some time. One could support these panels using custom SoC-specific code, but there is a desire to use common infra-structure rather than having each SoC vendor invent their own code, hence the desire to wait for CDF. * Hardware for which a full graphics driver is not yet available, and the path to obtain one upstream isn't yet clear. For example, the Raspberry Pi. * Any hardware in early stages of upstreaming, before a full graphics driver has been tackled. This driver can provide a graphical boot console (even full X support) much earlier in the upstreaming process, thus making new SoC or board support more generally useful earlier. [akpm@linux-foundation.org: make simplefb_formats[] static] Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Cc: Rob Clark <robclark@gmail.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
