path: root/Documentation
2015-10-27Doc: ABI: testing: configfs-usb-gadget-sourcesinkPeter Chen
[ Upstream commit 4bc58eb16bb2352854b9c664cc36c1c68d2bfbb7 ] Fix the name of attribute Cc: <stable@vger.kernel.org> Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27Doc: ABI: testing: configfs-usb-gadget-loopbackPeter Chen
[ Upstream commit 8cd50626823c00ca7472b2f61cb8c0eb9798ddc0 ] Fix the name of attribute Cc: <stable@vger.kernel.org> Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27docs: update HOWTO for 3.x -> 4.x versioningMario Carrillo
[ Upstream commit e4144fe5d47c91c92d36cdbd5f31ed8d6e3a57ab ] The HOWTO document needed updating for the new kernel versioning. Signed-off-by: Mario Carrillo <mario.alfredo.c.arevalo@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27of_mdio: add new DT property 'managed' to specify the PHY management typeStas Sergeev
[ Upstream commit 4cba5c2103657d43d0886e4cff8004d95a3d0def ] Currently the PHY management type is selected by the MAC driver arbitrary. The decision is based on the presence of the "fixed-link" node and on a will of the driver's authors. This caused a regression recently, when mvneta driver suddenly started to use the in-band status for auto-negotiation on fixed links. It appears the auto-negotiation may not work when expected by the MAC driver. Sebastien Rannou explains: << Yes, I confirm that my HW does not generate an in-band status. AFAIK, it's a PHY that aggregates 4xSGMIIs to 1xQSGMII ; the MAC side of the PHY (with inband status) is connected to the switch through QSGMII, and in this context we are on the media side of the PHY. >> https://lkml.org/lkml/2015/7/10/206 This patch introduces the new string property 'managed' that allows the user to set the management type explicitly. The supported values are: "auto" - default. Uses either MDIO or nothing, depending on the presence of the fixed-link node "in-band-status" - use in-band status Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net> CC: Rob Herring <robh+dt@kernel.org> CC: Pawel Moll <pawel.moll@arm.com> CC: Mark Rutland <mark.rutland@arm.com> CC: Ian Campbell <ijc+devicetree@hellion.org.uk> CC: Kumar Gala <galak@codeaurora.org> CC: Florian Fainelli <f.fainelli@gmail.com> CC: Grant Likely <grant.likely@linaro.org> CC: devicetree@vger.kernel.org CC: linux-kernel@vger.kernel.org CC: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-08-27libata: Expose TRIM capability in sysfsMartin K. Petersen
[ Upstream commit f303074160d3401970ccae082014e1ee5a9a52c5 ] Create a sysfs "trim" attribute for each ata_device that displays whether DSM TRIM is "unsupported", "unqueued", "forced_unqueued" (blacklisted) or "queued". Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-08-27i2c: i801: Add DeviceIDs for SunrisePoint LPDevin Ryles
[ Upstream commit 3eee1799aed90e990e02a73a89bfcff1982c74dd ] Signed-off-by: Devin Ryles <devin.ryles@intel.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-08-27ima: extend "mask" policy matching supportMimi Zohar
[ Upstream commit 747cadeb108665b0474624a374aa9e13f12c9274 ] commit 4351c294b8c1028077280f761e158d167b592974 upstream. The current "mask" policy option matches files opened as MAY_READ, MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask" option to match files opened containing one of these modes. For example, "mask=^MAY_READ" would match files opened read-write. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-08-27ima: add support for new "euid" policy conditionMimi Zohar
[ Upstream commit 139069eff7388407f19794384c42a534d618ccd7 ] The new "euid" policy condition measures files with the specified effective uid (euid). In addition, for CAP_SETUID files it measures files with the specified uid or suid. Changelog: - fixed checkpatch.pl warnings - fixed avc denied {setuid} messages - based on Roberto's feedback Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-08-22clk: keystone: add support for post divider register for main pllMurali Karicheri
[ Upstream commit 02fdfd708fd252a778709beb6c65d5e7360341ac ] Main PLL controller has post divider bits in a separate register in pll controller. Use the value from this register instead of fixed divider when available. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Michael Turquette <mturquette@baylibre.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-08-04spi: pl022: Specify 'num-cs' property as required in devicetree bindingEzequiel Garcia
[ Upstream commit ea6055c46eda1e19e02209814955e13f334bbe1b ] Since commit 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data") the 'num-cs' parameter cannot be passed through platform data when probing with devicetree. Instead, it's a required devicetree property. Fix the binding documentation so the property is properly specified. Fixes: 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data") Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-05net: mvneta: introduce compatible string "marvell, armada-xp-neta"Simon Guinot
[ Upstream commit f522a975a8101895a85354b9c143f41b8248e71a ] The mvneta driver supports the Ethernet IP found in the Armada 370, XP, 380 and 385 SoCs. Since at least one more hardware feature is available for the Armada XP SoCs then a way to identify them is needed. This patch introduces a new compatible string "marvell,armada-xp-neta". Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit") Cc: <stable@vger.kernel.org> # v3.8+ Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03pinctrl: mvebu: armada-xp: fix functions of MPP48Thomas Petazzoni
[ Upstream commit ea78b9511a54d0de026e04b5da86b30515072f31 ] There was a mistake in the definition of the functions for MPP48 on Marvell Armada XP. The second function is dev(clkout), and not tclk. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.7+ Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03pinctrl: mvebu: armada-xp: remove non-existing VDD cpu_pd functionsThomas Petazzoni
[ Upstream commit 80b3d04feab5e69d51cb2375eb989a7165e43e3b ] The latest version of the Armada XP datasheet no longer documents the VDD cpu_pd functions, which might indicate they are not working and/or not supported. This commit ensures the pinctrl driver matches the datasheet. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.7+ Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03pinctrl: mvebu: armada-xp: remove non-existing NAND pinsThomas Petazzoni
[ Upstream commit bc99357f3690c11817756adfee0ece811a3db2e7 ] After updating to a more recent version of the Armada XP datasheet, we realized that some of the pins documented as having a NAND-related functionality in fact did not have such functionality. This commit updates the pinctrl driver accordingly. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.7+ Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03pinctrl: mvebu: armada-375: remove non-existing NAND re/we pinsThomas Petazzoni
[ Upstream commit e5447d26092c72ef3346615ee558c9112ef8063f ] After updating to a more recent version of the Armada 375, we realized that some of the pins documented as having a NAND-related functionality in fact did not have such functionality. This commit updates the pinctrl driver accordingly. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.15+ Fixes: ce3ed59dcddd ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 375") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03pinctrl: mvebu: armada-370: fix spi0 pin descriptionThomas Petazzoni
[ Upstream commit 438881dfddb9107ef0eb30b49368e91e092f0b3e ] Due to a mistake, the CS0 and CS1 SPI0 functions were incorrectly named "spi0-1" instead of just "spi0". This commit fixes that. This DT binding change does not affect any of the in-tree users. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.7+ Fixes: 5f597bb2be57 ("pinctrl: mvebu: add pinctrl driver for Armada 370") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03pinctrl: mvebu: armada-38x: fix PCIe functionsThomas Petazzoni
[ Upstream commit 331642fbf24a1c16b2669ca0a6479b5fcd6dd5b2 ] A new revision of the Marvell Armada 38x hardware datasheet unveiled that the definition of some of the PCIe functions were not correct. This commit fixes the pinctrl driver accordingly. Some PCIe functions simply do not exist, some of the PCIe functions in fact were corresponding to other functions, and some PCIe functions have been added. Note: the seemingly unrelated removal of spi(cs2) on MPP47 is related: this function is in fact implemented on MPP43, instead of a PCIe function. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.15+ Fixes: ca6d9a084b56f ("pinctrl: mvebu: add pin-muxing driver for the Marvell Armada 380/385") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03stable: Update documentation to clarify preferred procedureChristoffer Dall
[ Upstream commit bde1b29420d71a17d87332db8e20229f251d6c14 ] Clearly specify that "Cc: stable@vger.kernel.org" is strongly preferred so that developers understand that the other options should only be used when absolutely required. Also specify how upstream commit ids should be referenced in patches submitted directly to stable (I gathered this from looking at the stable archives), and specify that any modified patches for stable should be clearly documented in the patch description. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-28RDS: Documentation: Document AF_RDS, PF_RDS and SOL_RDS correctly.Sowmini Varadhan
[ Upstream commit ebe96e641dee2cbd135ee802ae7e40c361640088 ] AF_RDS, PF_RDS and SOL_RDS are available in header files, and there is no need to get their values from /proc. Document this correctly. Fixes: 0c5f9b8830aa ("RDS: Documentation") Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-28stable_kernel_rules: Add clause about specification of kernel versions to patch.David Daney
[ Upstream commit fdc81b7910ad5153bf257e5f7861be71f75a02ef ] Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-28pinctrl: fix example .get_group_pins implementation signatureBaruch Siach
[ Upstream commit 838d030bda9e2da5f9dcf7251f4e117c6258cb2f ] The callback function signature has changed in commit a5818a8bd0 (pinctrl: get_group_pins() const fixes) Fixes: a5818a8bd0 ('pinctrl: get_group_pins() const fixes') Cc: Stephen Warren <swarren@nvidia.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-28pinctrl: remove doc mention of the enable/disable APIBaruch Siach
[ Upstream commit b18104c00089c73f2b70790765d40424a4f9b65f ] This API has changed in commit 6e5e959dde0 (pinctrl: API changes to support multiple states per device). Fixes: 6e5e959dde0 ('pinctrl: API changes to support multiple states per device') Cc: Stephen Warren <swarren@nvidia.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-28pinctrl: remove enable/disable callbacks from documentationBaruch Siach
[ Upstream commit 260463d4921468b9c0c018695ab09b3c2d15345b ] Commit 03e9f0cac5d (pinctrl: clean up after enable refactoring) updated the documentation to remove mention of disable(), and rename enable() to set_mux(). One in-text mention was forgotten. Fix this. Fixes: 03e9f0cac5d ('pinctrl: clean up after enable refactoring') Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-28pinctrl: remove maxpin from documentationBaruch Siach
[ Upstream commit 939417bd8b909ae34a3b2106531594f5115eaea5 ] struct pinctrl_desc does not contain the maxpin member since commit 0d2006bbf0 (pinctrl: remove unnecessary max pin number). Fixes: 0d2006bbf0 ('pinctrl: remove unnecessary max pin number') Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-09KVM: MMU: fix SMAP virtualizationXiao Guangrong
[ Upstream commit 0be0226f07d14b153a5eedf2bb86e1eb7dcefab5 ] KVM may turn a user page to a kernel page when kernel writes a readonly user page if CR0.WP = 1. This shadow page entry will be reused after SMAP is enabled so that kernel is allowed to access this user page Fix it by setting SMAP && !CR0.WP into shadow page's role and reset mmu once CR4.SMAP is updated Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-09ARM: dts: imx28: Fix AUART4 TX-DMA interrupt nameMarek Vasut
[ Upstream commit 4ada77e37a773168fea484899201e272ab44ba8b ] Fix a typo in the TX DMA interrupt name for AUART4. This patch makes AUART4 operational again. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma") Cc: stable@vger.kernel.org Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17uas: Add US_FL_MAX_SECTORS_240 flagHans de Goede
[ Upstream commit ee136af4a064c2f61e2025873584d2c7ec93f4ae ] The usb-storage driver sets max_sectors = 240 in its scsi-host template, for uas we do not want to do that for all devices, but testing has shown that some devices need it. This commit adds a US_FL_MAX_SECTORS_240 flag for such devices, and implements support for it in uas.c, while at it it also adds support for US_FL_MAX_SECTORS_64 to uas.c. Cc: stable@vger.kernel.org # 3.16 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17KVM: s390: fix get_all_floating_irqsJens Freimann
[ Upstream commit 94aa033efcac47b09db22cb561e135baf37b7887 ] This fixes a bug introduced with commit c05c4186bbe4 ("KVM: s390: add floating irq controller"). get_all_floating_irqs() does copy_to_user() while holding a spin lock. Let's fix this by filling a temporary buffer first and copy it to userspace after giving up the lock. Cc: <stable@vger.kernel.org> # 3.18+: 69a8d4562638 KVM: s390: no need to hold... Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: Turn off vcpus on PSCI shutdown/rebootChristoffer Dall
commit cf5d318865e25f887d49a0c6083bbc6dcd1905b1 upstream. When a vcpu calls SYSTEM_OFF or SYSTEM_RESET with PSCI v0.2, the vcpus should really be turned off for the VM adhering to the suggestions in the PSCI spec, and it's the sane thing to do. Also, clarify the behavior and expectations for exits to user space with the KVM_EXIT_SYSTEM_EVENT case. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: Correct KVM_ARM_VCPU_INIT power off optionChristoffer Dall
commit 3ad8b3de526a76fbe9466b366059e4958957b88f upstream. The implementation of KVM_ARM_VCPU_INIT is currently not doing what userspace expects, namely making sure that a vcpu which may have been turned off using PSCI is returned to its initial state, which would be powered on if userspace does not set the KVM_ARM_VCPU_POWER_OFF flag. Implement the expected functionality and clarify the ABI. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-23stable_kernel_rules: reorganize and update submission optionsBrian Norris
commit 5de61e7aa1ba9ac3c7edbea375da2bc8eb1a89ae upstream. The current organization of Documentation/stable_kernel_rules.txt doesn't clearly differentiate the mutually exclusive options for submission to the -stable review process. As I understand it, patches are not actually required to be mailed directly to stable@vger.kernel.org, but the instructions do not make this clear. Also, there are some established processes that are not listed -- specifically, what I call Option 2 below. This patch updates and reorganizes a bit, to make things clearer. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-27Input: i8042 - reset keyboard to fix Elantech touchpad detectionSrihari Vijayaraghavan
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream. On some laptops, keyboard needs to be reset in order to successfully detect touchpad (e.g., some Gigabyte laptop models with Elantech touchpads). Without resettin keyboard touchpad pretends to be completely dead. Based on the original patch by Mateusz Jończyk this version has been expanded to include DMI based detection & application of the fix automatically on the affected models of laptops. This has been confirmed to fix problem by three users already on three different models of laptops. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331 Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com> Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl> Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com> Tested by: Zakariya Dehlawi <zdehlawi@gmail.com> Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16i2c: designware: Fix falling time bindings docDoug Anderson
commit 8e2596e81a9dd8f9efcf78476f3990f211e25edb upstream. In (6468276 i2c: designware: make SCL and SDA falling time configurable) new device tree properties were added for setting the falling time of SDA and SCL. The device tree bindings doc had a typo in it: it forgot the "-ns" suffix for both properies in the prose of the bindings. I assume this is a typo because: * The source code includes the "-ns" * The example in the bindings includes the "-ns". Fix the typo. Signed-off-by: Doug Anderson <dianders@chromium.org> Fixes: 6468276b2206 ("i2c: designware: make SCL and SDA falling time configurable") Acked-by: Romain Baeriswyl <romain.baeriswyl@alitech.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16pstore-ram: Allow optional mapping with pgprot_noncachedTony Lindgren
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream. On some ARMs the memory can be mapped pgprot_noncached() and still be working for atomic operations. As pointed out by Colin Cross <ccross@android.com>, in some cases you do want to use pgprot_noncached() if the SoC supports it to see a debug printk just before a write hanging the system. On ARMs, the atomic operations on strongly ordered memory are implementation defined. So let's provide an optional kernel parameter for configuring pgprot_noncached(), and use pgprot_writecombine() by default. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rob Herring <robherring2@gmail.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several small fixes here: 1) Don't crash in tg3 driver when the number of tx queues has been configured to be different from the number of rx queues. From Thadeu Lima de Souza Cascardo. 2) VLAN filter not disabled properly in promisc mode in ixgbe driver, from Vlad Yasevich. 3) Fix OOPS on dellink op in VTI tunnel driver, from Xin Long. 4) IPV6 GRE driver WCCP code checks skb->protocol for ETH_P_IP instead of ETH_P_IPV6, whoops. From Yuri Chislov. 5) Socket matching in ping driver is buggy when packet AF does not match socket's AF. Fix from Jane Zhou. 6) Fix checksum calculation errors in VXLAN due to where the udp_tunnel6_xmit_skb() helper gets it's saddr/daddr from. From Alexander Duyck. 7) Fix 5G detection problem in rtlwifi driver, from Larry Finger. 8) Fix NULL deref in tcp_v{4,6}_send_reset, from Eric Dumazet. 9) Various missing netlink attribute verifications in bridging code, from Thomas Graf. 10) tcp_recvmsg() unconditionally calls ipv4 ip_recv_error even for ipv6 sockets, whoops. Fix from Willem de Bruijn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits) net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socks bridge: Sanitize IFLA_EXT_MASK for AF_BRIDGE:RTM_GETLINK bridge: Add missing policy entry for IFLA_BRPORT_FAST_LEAVE net: Check for presence of IFLA_AF_SPEC net: Validate IFLA_BRIDGE_MODE attribute length bridge: Validate IFLA_BRIDGE_FLAGS attribute length stmmac: platform: fix default values of the filter bins setting net/mlx4_core: Limit count field to 24 bits in qp_alloc_res net: dsa: bcm_sf2: reset switch prior to initialization net: dsa: bcm_sf2: fix unmapping registers in case of errors tg3: fix ring init when there are more TX than RX channels tcp: fix possible NULL dereference in tcp_vX_send_reset() rtlwifi: Change order in device startup rtlwifi: rtl8821ae: Fix 5G detection problem Revert "netfilter: conntrack: fix race in __nf_conntrack_confirm against get_next_corpse" vxlan: Fix boolean flip in VXLAN_F_UDP_ZERO_CSUM6_[TX|RX] ip6_udp_tunnel: Fix checksum calculation net-timestamp: Fix a documentation typo net/ping: handle protocol mismatching scenario af_packet: fix sparse warning ...
2014-11-25net-timestamp: Fix a documentation typoAndrew Lutomirski
SOF_TIMESTAMPING_OPT_ID puts the id in ee_data, not ee_info. Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Assorted fixes, most in overlayfs land" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ovl: ovl_dir_fsync() cleanup ovl: update MAINTAINERS ovl: pass dentry into ovl_dir_read_merged() ovl: use lockless_dereference() for upperdentry ovl: allow filenames with comma ovl: fix race in private xattr checks ovl: fix remove/copy-up race ovl: rename filesystem type to "overlay" isofs: avoid unused function warning vfs: fix reference leak in d_prune_aliases()
2014-11-21Merge tag 'devicetree-fixes-for-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree fixes from Rob Herring: "DeviceTree fixes for 3.18: - two fixes for OF selftest code - fix for PowerPC address parsing to disable work-around except on old PowerMACs - fix a crash when earlycon is enabled, but no device is found - DT documentation fixes and missing vendor prefixes All but the doc updates are also for stable" * tag 'devicetree-fixes-for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: of/selftest: Fix testing when /aliases is missing of/selftest: Fix off-by-one error in removal path documentation: pinctrl bindings: Fix trivial typo 'abitrary' devicetree: bindings: Add vendor prefix for Micron Technology, Inc. of: Add vendor prefix for Chips&Media, Inc. of/base: Fix PowerPC address parsing hack devicetree: vendor-prefixes.txt: fix whitespace of: Fix crash if an earlycon driver is not found of/irq: Drop obsolete 'interrupts' vs 'interrupts-extended' text of: Spelling s/stucture/structure/ devicetree: bindings: add sandisk to the vendor prefixes
2014-11-21Merge tag 'pci-v3.18-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These are fixes for an issue with 64-bit PCI bus addresses on 32-bit PAE kernels, an APM X-Gene problem (it depended on a generic change we removed before merging), a fix for my hotplug device configuration changes, and a devicetree documentation update. Resource management: - Support 64-bit bridge windows if we have 64-bit dma_addr_t (Yinghai Lu) PCI device hotplug: - Apply _HPX Link Control settings to all devices with a link (Yinghai Lu) Generic host bridge driver: - Add DT binding for "linux,pci-domain" property (Lucas Stach) APM X-Gene: - Assign resources to bus before adding new devices (Duc Dang)" * tag 'pci-v3.18-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Support 64-bit bridge windows if we have 64-bit dma_addr_t PCI: Apply _HPX Link Control settings to all devices with a link PCI: Add missing DT binding for "linux,pci-domain" property PCI: xgene: Assign resources to bus before adding new devices
2014-11-20ovl: rename filesystem type to "overlay"Miklos Szeredi
Some distributions carry an "old" format of overlayfs while mainline has a "new" format. The distros will possibly want to keep the old overlayfs alongside the new for compatibility reasons. To make it possible to differentiate the two versions change the name of the new one from "overlayfs" to "overlay". Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Andy Whitcroft <apw@canonical.com>
2014-11-18documentation: pinctrl bindings: Fix trivial typo 'abitrary'Soren Brinkmann
A misspelled 'arbitrary' propagated to quite a few locations in the DT binding documentation for pin-controllers. Fixing by: git grep abitrary | cut -f1 -d: | xargs sed -i 's/abitrary/arbitrary/' Reported-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Rob Herring <robh@kernel.org>
2014-11-18devicetree: bindings: Add vendor prefix for Micron Technology, Inc.bpqw
This patch is used to add vendor prefix for Micron Technology, Inc. in the vendor-prefixes.txt file. Micron Technology, Inc. is an American multinational corporation based in Boise, Idaho, best known for producing many forms of semiconductor devices. This includes DRAM, SDRAM, flash memory, eMMC and SSDs. Signed-off-by: Bean Huo <bpqw@micron.com> [robh: cleanup commit msg formatting and company name] Signed-off-by: Rob Herring <robh@kernel.org>
2014-11-18of: Add vendor prefix for Chips&Media, Inc.Philipp Zabel
Chips&Media is a developer of Video Codec IP cores. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> [robh: fix-up alphabetical ordering] Signed-off-by: Rob Herring <robh@kernel.org>
2014-11-18devicetree: vendor-prefixes.txt: fix whitespaceAntony Pavlov
Signed-off-by: Antony Pavlov <antonynpavlov@gmail.com> Signed-off-by: Rob Herring <robh@kernel.org>
2014-11-18of/irq: Drop obsolete 'interrupts' vs 'interrupts-extended' textBjorn Helgaas
a9ecdc0fdc54 ("of/irq: Fix lookup to use 'interrupts-extended' property first") updated the description to say that: - Both 'interrupts' and 'interrupts-extended' may be present - Software should prefer 'interrupts-extended' - Software that doesn't comprehend 'interrupts-extended' may use 'interrupts' But there is still a paragraph at the end that prohibits having both and says 'interrupts' should be preferred. Remove the contradictory text. Fixes: a9ecdc0fdc54 ("of/irq: Fix lookup to use 'interrupts-extended' property first") Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.13+ Acked-by: Brian Norris <computersforpeace@gmail.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Rob Herring <robh@kernel.org>
2014-11-18devicetree: bindings: add sandisk to the vendor prefixesRobert Jarzmik
Add sandisk to the list of vendors. This prefix should be used also for companies absorbed by Sandisk, like M-Systems. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Rob Herring <robh@kernel.org>
2014-11-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "Mostly small fixups to PS/2 tochpad drivers (ALPS, Elantech, Synaptics) to better deal with specific hardware" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elantech - update the documentation Input: elantech - provide a sysfs knob for crc_enabled Input: elantech - report the middle button of the touchpad Input: alps - ignore bad data on Dell Latitudes E6440 and E7440 Input: alps - allow up to 2 invalid packets without resetting device Input: alps - ignore potential bare packets when device is out of sync Input: elantech - fix crc_enabled for Fujitsu H730 Input: elantech - use elantech_report_trackpoint for hardware v4 too Input: twl4030-pwrbutton - ensure a wakeup event is recorded. Input: synaptics - add min/max quirk for Lenovo T440s
2014-11-14Merge branch 'for-3.18-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "The most notable is the revert of lock splitting optimization in ahci. This also made the IRQ handling threaded even when there's only one IRQ in use. The conversion missed IRFQ_SHARED leading to screaming IRQs problem in some cases and the threaded IRQ handling showed performance regression in some LKP test cases. The changes are reverted for now. It'll probably be retried once threaded IRQ handling is removed from ahci. Other than that, there's one fix for ahci and several patches adding device IDs" * 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: fix AHCI parameters not taken into account ata: sata_rcar: Add r8a7793 device support ahci: Add Device IDs for Intel Sunrise Point PCH ahci: disable MSI instead of NCQ on Samsung pci-e SSDs on macbooks Revert "AHCI: Optimize single IRQ interrupt processing" Revert "AHCI: Do not acquire ata_host::lock from single IRQ handler" ata: sata_rcar: Disable DIPM mode for r8a7790 ES1
2014-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) sunhme driver lacks DMA mapping error checks, based upon a report by Meelis Roos. 2) Fix memory leak in mvpp2 driver, from Sudip Mukherjee. 3) DMA memory allocation sizes are wrong in systemport ethernet driver, fix from Florian Fainelli. 4) Fix use after free in mac80211 defragmentation code, from Johannes Berg. 5) Some networking uapi headers missing from Kbuild file, from Stephen Hemminger. 6) TUN driver gets csum_start offset wrong when VLAN accel is enabled, and macvtap has a similar bug, from Herbert Xu. 7) Adjust several tunneling drivers to set dev->iflink after registry, because registry sets that to -1 overwriting whatever we did. From Steffen Klassert. 8) Geneve forgets to set inner tunneling type, causing GSO segmentation to fail on some NICs. From Jesse Gross. 9) Fix several locking bugs in stmmac driver, from Fabrice Gasnier and Giuseppe CAVALLARO. 10) Fix spurious timeouts with NewReno on low traffic connections, from Marcelo Leitner. 11) Fix descriptor updates in enic driver, from Govindarajulu Varadarajan. 12) PPP calls bpf_prog_create() with locks held, which isn't kosher. Fix from Takashi Iwai. 13) Fix NULL deref in SCTP with malformed INIT packets, from Daniel Borkmann. 14) psock_fanout selftest accesses past the end of the mmap ring, fix from Shuah Khan. 15) Fix PTP timestamping for VLAN packets, from Richard Cochran. 16) netlink_unbind() calls in netlink pass wrong initial argument, from Hiroaki SHIMODA. 17) vxlan socket reuse accidently reuses a socket when the address family is different, so we have to explicitly check this, from Marcelo Lietner. 18) Fix missing include in nft_reject_bridge.c breaking the build on ppc and other architectures, from Guenter Roeck. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) vxlan: Do not reuse sockets for a different address family smsc911x: power-up phydev before doing a software reset. lib: rhashtable - Remove weird non-ASCII characters from comments net/smsc911x: Fix delays in the PHY enable/disable routines net/smsc911x: Fix rare soft reset timeout issue due to PHY power-down mode netlink: Properly unbind in error conditions. net: ptp: fix time stamp matching logic for VLAN packets. cxgb4 : dcb open-lldp interop fixes selftests/net: psock_fanout seg faults in sock_fanout_read_ring() net: bcmgenet: apply MII configuration in bcmgenet_open() net: bcmgenet: connect and disconnect from the PHY state machine net: qualcomm: Fix dependency ixgbe: phy: fix uninitialized status in ixgbe_setup_phy_link_tnx net: phy: Correctly handle MII ioctl which changes autonegotiation. ipv6: fix IPV6_PKTINFO with v4 mapped net: sctp: fix memory leak in auth key management net: sctp: fix NULL pointer dereference in af->from_addr_param on malformed packet net: ppp: Don't call bpf_prog_create() in ppp_lock net/mlx4_en: Advertize encapsulation offloads features only when VXLAN tunnel is set cxgb4 : Fix bug in DCB app deletion ...
2014-11-13Input: elantech - update the documentationUlrik De Bie
A chapter is added to describe the trackpoint packets. A section is added to describe the behaviour of the knob crc_enabled in sysfs. The introduction of the documentation only mentioned v1/v2, but in the last part it already contains explanation of v3 and v4. The introduction is updated. Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
