commit ea78b9511a54d0de026e04b5da86b30515072f31 upstream.
There was a mistake in the definition of the functions for MPP48 on
Marvell Armada XP. The second function is dev(clkout), and not tclk.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fixes: 463e270f766a ("pinctrl: mvebu: add pinctrl driver for Armada XP")
commit 80b3d04feab5e69d51cb2375eb989a7165e43e3b upstream.
The latest version of the Armada XP datasheet no longer documents the
VDD cpu_pd functions, which might indicate they are not working and/or
not supported. This commit ensures the pinctrl driver matches the
datasheet.
commit bc99357f3690c11817756adfee0ece811a3db2e7 upstream.
After updating to a more recent version of the Armada XP datasheet, we
realized that some of the pins documented as having a NAND-related
functionality in fact did not have such functionality. This commit
updates the pinctrl driver accordingly.
commit 438881dfddb9107ef0eb30b49368e91e092f0b3e upstream.
Due to a mistake, the CS0 and CS1 SPI0 functions were incorrectly
named "spi0-1" instead of just "spi0". This commit fixes that.
This DT binding change does not affect any of the in-tree users.
Fixes: 5f597bb2be57 ("pinctrl: mvebu: add pinctrl driver for Armada 370")
commit ea6055c46eda1e19e02209814955e13f334bbe1b upstream.
Since commit 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data")
the 'num-cs' parameter cannot be passed through platform data when probing
with devicetree. Instead, it's a required devicetree property.
Fix the binding documentation so the property is properly specified.
Fixes: 39a6ac11df65 ("spi/pl022: Devicetree support w/o platform data")
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 3ad8b3de526a76fbe9466b366059e4958957b88f upstream.
The implementation of KVM_ARM_VCPU_INIT is currently not doing what
userspace expects, namely making sure that a vcpu which may have been
turned off using PSCI is returned to its initial state, which would be
powered on if userspace does not set the KVM_ARM_VCPU_POWER_OFF flag.
Implement the expected functionality and clarify the ABI.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
commit 4ada77e37a773168fea484899201e272ab44ba8b upstream.
Fix a typo in the TX DMA interrupt name for AUART4.
This patch makes AUART4 operational again.
Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma")
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream.
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit 66865de4314caca30598244b86817e774c188afa upstream.
a9ecdc0fdc54 ("of/irq: Fix lookup to use 'interrupts-extended' property
first") updated the description to say that:
- Both 'interrupts' and 'interrupts-extended' may be present
- Software should prefer 'interrupts-extended'
- Software that doesn't comprehend 'interrupts-extended' may use
'interrupts'
But there is still a paragraph at the end that prohibits having both and
says 'interrupts' should be preferred.
Remove the contradictory text.
Fixes: a9ecdc0fdc54 ("of/irq: Fix lookup to use 'interrupts-extended' property first")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Brian Norris <computersforpeace@gmail.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Rob Herring <robh@kernel.org>
commit aa1cf25887099bba68f1f3879c0d394e08b8779f upstream.
Unlike other SATA R-Car r8a7790 controllers the r8a7790 ES1 SATA R-Car
controller needs to be run with DIPM disabled.
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit d98a0526434d27e261f622cf9d2e0028b5ff1a00 upstream.
Add a complete description of the LZO format as processed by the
decompressor. I have not found a public specification of this format
hence this analysis, which will be used to better understand the code.
Cc: Willem Pinckaers <willem@lekkertech.net>
Cc: "Don A. Bailey" <donb@securitymouse.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit ee3d1570b58677885b4552bce8217fda7b226a68 upstream.
vcpu exits and memslot mutations can run concurrently as long as the
vcpu does not aquire the slots mutex. Thus it is theoretically possible
for memslots to change underneath a vcpu that is handling an exit.
If we increment the memslot generation number again after
synchronize_srcu_expedited(), vcpus can safely cache memslot generation
without maintaining a single rcu_dereference through an entire vm exit.
And much of the x86/kvm code does not maintain a single rcu_dereference
of the current memslots during each exit.
We can prevent the following case:
vcpu (CPU 0) | thread (CPU 1)
1 vm exit |
2 srcu_read_unlock(&kvm->srcu) |
3 decide to cache something based on |
old memslots |
4 | change memslots
| (increments generation)
5 | synchronize_srcu(&kvm->srcu);
6 retrieve generation # from new memslots |
7 tag cache with new memslot generation |
8 srcu_read_unlock(&kvm->srcu) |
<action based on cache occurs even |
though the caching decision was based |
on the old memslots> |
<action *continues* to occur until next |
memslot generation change, which may |
be never> |
By incrementing the generation after synchronizing with kvm->srcu readers,
we ensure that the generation retrieved in (6) will become invalid soon
after (8).
Keeping the existing increment is not strictly necessary, but we
do keep it and just move it for consistency from update_memslots to
install_new_memslots. It invalidates old cached MMIOs immediately,
instead of having to wait for the end of synchronize_srcu_expedited,
which makes the code more clearly correct in case CPU 1 is preempted
right after synchronize_srcu() returns.
To avoid halving the generation space in SPTEs, always presume that the
low bit of the generation is zero when reconstructing a generation number
out of an SPTE. This effectively disables MMIO caching in SPTEs during
the call to synchronize_srcu_expedited. Using the low bit this way is
somewhat like a seqcount---where the protected thing is a cache, and
instead of retrying we can simply punt if we observe the low bit to be 1.
Signed-off-by: David Matlack <dmatlack@google.com>
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Reviewed-by: David Matlack <dmatlack@google.com>
commit a9ecdc0fdc54aa499604dbd43132988effcac9b4 upstream.
In case the Device Tree blob passed by the boot agent supplies both an
'interrupts-extended' and an 'interrupts' property in order to allow for
older kernels to be usable, prefer the new-style 'interrupts-extended'
property which conveys a lot more information.
This allows us to have bootloaders willingly maintaining backwards
compatibility with older kernels without entirely deprecating the
'interrupts' property.
Update the bindings documentation to describe a situation where both the
'interrupts-extended' and the 'interrupts' property are present, and
which one takes precedence over the other.
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit d1555c407a65db42126b295425379acb393ba83a upstream.
The specification requires compatible = "adi,axi-spdif-1.00.a" but
driver and example and file name indicate "adi,axi-spdif-tx-1.00.a".
Change the specification to match the implementation.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
Fixes: d7b528eff927 ("dt: Add bindings documentation for the ADI AXI-SPDIF audio controller")
Signed-off-by: Andreas Färber <afaerber@suse.de>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit f42bb22243d2ae264d721b055f836059fe35321f upstream.
Just add the PCI ID for the STX II. It appears to work the same as the
STX, except for the addition of the not-yet-supported daughterboard.
Tested-by: Mario <fugazzi99@gmail.com>
Tested-by: corubba <corubba@gmx.de>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit b76fc285337b6b256e9ba20a40cfd043f70c27af upstream.
Stable_kernel_rules should point submitters of network stable patches to the
netdev_FAQ.txt as requests for stable network patches should go to netdev
first.
Signed-off-by: Dave Chiluk <chiluk@canonical.com>
commit 3891a04aafd668686239349ea58f3314ea2af86b upstream.
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. This
causes some 16-bit software to break, but it also leaks kernel state
to user space. We have a software workaround for that ("espfix") for
the 32-bit kernel, but it relies on a nonzero stack segment base which
is not available in 64-bit mode.
In checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
we "solved" this by forbidding 16-bit segments on 64-bit kernels, with
the logic that 16-bit support is crippled on 64-bit kernels anyway (no
V86 support), but it turns out that people are doing stuff like
running old Win16 binaries under Wine and expect it to work.
This works around this by creating percpu "ministacks", each of which
is mapped 2^16 times 64K apart. When we detect that the return SS is
on the LDT, we copy the IRET frame to the ministack and use the
relevant alias to return to userspace. The ministacks are mapped
readonly, so if IRET faults we promote #GP to #DF which is an IST
vector and thus has its own stack; we then do the fixup in the #DF
handler.
(Making #GP an IST exception would make the msr_safe functions unsafe
in NMI/MC context, and quite possibly have other effects.)
Special thanks to:
- Andy Lutomirski, for the suggestion of using very small stack slots
and copy (as opposed to map) the IRET frame there, and for the
suggestion to mark them readonly and let the fault promote to #DF.
- Konrad Wilk for paravirt fixup and testing.
- Borislav Petkov for testing help and useful comments.
Reported-by: Brian Gerst <brgerst@gmail.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Andrew Lutomriski <amluto@gmail.com>
Cc: Dirk Hohndel <dirk@hohndel.org>
Cc: Arjan van de Ven <arjan.van.de.ven@intel.com>
Cc: comex <comexk@gmail.com>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: <stable@vger.kernel.org> # consider after upstream merge
commit 41629a8233470325bfbb60377f555f9e8acc879f upstream.
Update documentation to make the interpretation of the values clearer
Link: https://bugzilla.kernel.org/show_bug.cgi?id=64251
Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com>
commit 7cd2b0a34ab8e4db971920eef8982f985441adfb upstream.
Oleg reports a division by zero error on zero-length write() to the
percpu_pagelist_fraction sysctl:
divide error: 0000 [#1] SMP DEBUG_PAGEALLOC
CPU: 1 PID: 9142 Comm: badarea_io Not tainted 3.15.0-rc2-vm-nfs+ #19
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff8800d5aeb6e0 ti: ffff8800d87a2000 task.ti: ffff8800d87a2000
RIP: 0010: percpu_pagelist_fraction_sysctl_handler+0x84/0x120
RSP: 0018:ffff8800d87a3e78 EFLAGS: 00010246
RAX: 0000000000000f89 RBX: ffff88011f7fd000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000010
RBP: ffff8800d87a3e98 R08: ffffffff81d002c8 R09: ffff8800d87a3f50
R10: 000000000000000b R11: 0000000000000246 R12: 0000000000000060
R13: ffffffff81c3c3e0 R14: ffffffff81cfddf8 R15: ffff8801193b0800
FS: 00007f614f1e9740(0000) GS:ffff88011f440000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f614f1fa000 CR3: 00000000d9291000 CR4: 00000000000006e0
Call Trace:
proc_sys_call_handler+0xb3/0xc0
proc_sys_write+0x14/0x20
vfs_write+0xba/0x1e0
SyS_write+0x46/0xb0
tracesys+0xe1/0xe6
However, if the percpu_pagelist_fraction sysctl is set by the user, it
is also impossible to restore it to the kernel default since the user
cannot write 0 to the sysctl.
This patch allows the user to write 0 to restore the default behavior.
It still requires a fraction equal to or larger than 8, however, as
stated by the documentation for sanity. If a value in the range [1, 7]
is written, the sysctl will return EINVAL.
This successfully solves the divide by zero issue at the same time.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Oleg Drokin <green@linuxhacker.ru>
commit 8401aa1f59975c03eeebd3ac6d264cbdfe9af5de upstream.
Update the SubmittingPatches process to include howto about the new
'Fixes:' tag to be used when a patch fixes an issue in a previous commit
(found by git-bisect for example).
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
SIGBUS(BUS_MCEERR_AO)
commit 3ba08129e38437561df44c36b7ea9081185d5333 upstream.
Currently memory error handler handles action optional errors in the
deferred manner by default. And if a recovery aware application wants
to handle it immediately, it can do it by setting PF_MCE_EARLY flag.
However, such signal can be sent only to the main thread, so it's
problematic if the application wants to have a dedicated thread to
handler such signals.
So this patch adds dedicated thread support to memory error handler. We
have PF_MCE_EARLY flags for each thread separately, so with this patch
AO signal is sent to the thread with PF_MCE_EARLY flag set, not the main
thread. If you want to implement a dedicated thread, you call prctl()
to set PF_MCE_EARLY on the thread.
Memory error handler collects processes to be killed, so this patch lets
it check PF_MCE_EARLY flag on each thread in the collecting routines.
No behavioral change for all non-early kill cases.
Tony said:
: The old behavior was crazy - someone with a multithreaded process might
: well expect that if they call prctl(PF_MCE_EARLY) in just one thread, then
: that thread would see the SIGBUS with si_code = BUS_MCEERR_A0 - even if
: that thread wasn't the main thread for the process.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Tony Luck <tony.luck@intel.com>
Cc: Kamil Iskra <iskra@mcs.anl.gov>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chen Gong <gong.chen@linux.jf.intel.com>
commit f9b2a735bdddf836214b5dca74f6ca7712e5a08c upstream.
Files are measured or appraised based on the IMA policy. When a
file, in policy, is opened with the O_DIRECT flag, a deadlock
occurs.
The first attempt at resolving this lockdep temporarily removed the
O_DIRECT flag and restored it, after calculating the hash. The
second attempt introduced the O_DIRECT_HAVELOCK flag. Based on this
flag, do_blockdev_direct_IO() would skip taking the i_mutex a second
time. The third attempt, by Dmitry Kasatkin, resolves the i_mutex
locking issue, by re-introducing the IMA mutex, but uncovered
another problem. Reading a file with O_DIRECT flag set, writes
directly to userspace pages. A second patch allocates a user-space
like memory. This works for all IMA hooks, except ima_file_free(),
which is called on __fput() to recalculate the file hash.
Until this last issue is addressed, do not 'collect' the
measurement for measuring, appraising, or auditing files opened
with the O_DIRECT flag set. Based on policy, permit or deny file
access. This patch defines a new IMA policy rule option named
'permit_directio'. Policy rules could be defined, based on LSM
or other criteria, to permit specific applications to open files
Changelog v1:
- permit or deny file access based IMA policy rules
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Acked-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
commit 80c578930ce77ba8bcfb226a184b482020bdda7b upstream.
Commit 85ad643b ("dm thin: add timeout to stop out-of-data-space mode
holding IO forever") introduced a fixed 60 second timeout. Users may
want to either disable or modify this timeout.
Allow the out-of-data-space timeout to be configured using the
'no_space_timeout' dm-thin-pool module param. Setting it to 0 will
disable the timeout, resulting in IO being queued until more data space
is added to the thin-pool.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 2fe2023adf695d08af5b598b2be3b288a95d563c upstream.
Undo a feature introduced in v3.14 by commit fcd46b34425d
"firewire: Enable remote DMA above 4 GB". That change raised the
minimum address at which protocol drivers and user programs can register
for request reception from 0x0001'0000'0000 to 0x8000'0000'0000.
It turned out that at least one vendor-specific protocol exists which
uses lower addresses: https://bugzilla.kernel.org/show_bug.cgi?id=76921
For the time being, revert most of commit fcd46b34425d so that affected
protocols work like with kernel v3.13 and before. Just keep the valid
documentation parts from the regressing commit, and the ability to
identify controllers which could be programmed to accept >32 bit
physical DMA addresses. The rest of fcd46b34425d should probably be
brought back as an optional instead of default feature.
Reported-by: Fabien Spindler <fabien.spindler@inria.fr>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit e60cbeedc48d80689c249ab5dcc3c31ad0452dea upstream.
Prior to commit 4266129964b8 ("[media] DocBook: Move all media docbook
stuff into its own directory") it was possible to build only a single
(or more) book(s) by calling, for example
make htmldocs DOCBOOKS=80211.xml
This now fails:
cp: target `.../Documentation/DocBook//media_api' is not a directory
Ignore errors from that copy to make this possible again.
Fixes: 4266129964b8 ("[media] DocBook: Move all media docbook stuff into its own directory")
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
commit 36189cc3cd57ab0f1cd75241f93fe01de928ac06 upstream.
The hw_version 3 Elantech touchpad on the Gigabyte U2442 does not accept
0x0b as initialization value for r10, this stand-alone version of the
driver: http://planet76.com/drivers/elantech/psmouse-elantech-v6.tar.bz2
Uses 0x03 which does work, so this means not setting bit 3 of r10 which
sets: "Enable Real H/W Resolution In Absolute mode"
Which will result in half the x and y resolution we get with that bit set,
so simply not setting it everywhere is not a solution. We've been unable to
find a way to identify touchpads where setting the bit will fail, so this
patch uses a dmi based blacklist for this.
https://bugzilla.kernel.org/show_bug.cgi?id=61151
Reported-by: Philipp Wolfer <ph.wolfer@gmail.com>
Tested-by: Philipp Wolfer <ph.wolfer@gmail.com>
commit 1b31e9b76ef8c62291e698dfdb973499986a7f68 upstream.
Add Device ID of Intel BayTrail SMBus Controller.
Signed-off-by: Chew, Kean ho <kean.ho.chew@intel.com>
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: "Chang, Rebecca Swee Fun" <rebecca.swee.fun.chang@intel.com>
commit 98b0f811aade1b7c6e7806c86aa0befd5919d65f upstream.
The English and Korean translations were updated, the Chinese and Japanese
weren't.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit cf7eb979116c2568e8bc3b6a7269c7a359864ace upstream.
This is another great example of trainwreck engineering:
commit 2646a0e529 (ARM: edma: Add EDMA crossbar event mux support)
added support for using EDMA on peripherals which have no direct EDMA
event mapping.
The code compiles and does not explode in your face, but that's it.
1) Reading an u16 array from an u32 device tree array simply does not
work. Even if the function is named "edma_of_read_u32_to_s16_array".
It merily calls of_property_read_u16_array. So the resulting 16bit
array will have every other entry = 0.
2) The DT entry for the xbar registers related to xbar has length 0x10
instead of the real length: 0xfd0 - 0xf90 = 0x40.
Not a real problem as it does not cross a page boundary, but
wrong nevertheless.
3) But none of this matters as the mapping never happens:
After reading nonsense edma_of_read_u32_to_s16_array() invalidates
the first array entry pair, so nobody can ever notice the
braindamage by immediate explosion.
Seems the QA criteria for this code was solely not to explode when
someone adds edma-xbar-event-map entries to the DT. Goal achieved,
congratulations!
Not really helpful if someone wants to use edma on a device which
requires a xbar mapping.
Fix the issues by:
- annotating the device tree entry with "/bits/ 16" as documented in
the of_property_read_u16_array kernel doc
- make the size of the xbar register mapping correct
- invalidating the end of the array and not the start
This convoluted mess wants to be completely rewritten as there is no
point to keep the xbar_chan array memory and the iomapping of the xbar
regs around forever. Marking the xbar mapped channels as used should
be done right there.
But that's a different issue and this patch is small enough to make it
work and allows a simple backport for stable.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit 80df28476505ed4e6701c3448c63c9229a50c655 upstream.
As sysctl_hung_task_timeout_sec is unsigned long, when this value is
larger then LONG_MAX/HZ, the function schedule_timeout_interruptible in
watchdog will return immediately without sleep and with print :
schedule_timeout: wrong timeout value ffffffffffffff83
and then the funtion watchdog will call schedule_timeout_interruptible
again and again. The screen will be filled with
"schedule_timeout: wrong timeout value ffffffffffffff83"
This patch does some check and correction in sysctl, to let the function
schedule_timeout_interruptible allways get the valid parameter.
Signed-off-by: Liu Hua <sdu.liu@huawei.com>
Tested-by: Satoru Takeuchi <satoru.takeuchi@gmail.com>
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream.
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit 12f6dd860cf8bf036c0bec38c00a53da71bcd43a upstream.
Wolfram Sang pointed out that "efm32,$device" is non-standard. So use the
common scheme and prefix device with "efm32-". The old compatible string
is left in place until arch/arm/boot/dts/efm32* is fixed.
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Few platforms use external regulator to keep the ethernet MAC supplied.
So, request and enable the regulator for driver functionality.
Fixes: 66fda75f47dc (regulator: core: Replace direct ops->disable usage)
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Suggested-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Nishanth Menon <nm@ti.com>
The documentation for how to use netlink mmap interface is incorrect.
The calls to setsockopt() require an additional argument.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Pull networking fixes from David Miller:
"I know this is a bit more than you want to see, and I've told the
wireless folks under no uncertain terms that they must severely scale
back the extent of the fixes they are submitting this late in the
game.
Anyways:
1) vmxnet3's netpoll doesn't perform the equivalent of an ISR, which
is the correct implementation, like it should. Instead it does
something like a NAPI poll operation. This leads to crashes.
From Neil Horman and Arnd Bergmann.
2) Segmentation of SKBs requires proper socket orphaning of the
fragments, otherwise we might access stale state released by the
release callbacks.
This is a 5 patch fix, but the initial patches are giving
variables and such significantly clearer names such that the
actual fix itself at the end looks trivial.
From Michael S. Tsirkin.
3) TCP control block release can deadlock if invoked from a timer on
an already "owned" socket. Fix from Eric Dumazet.
4) In the bridge multicast code, we must validate that the
destination address of general queries is the link local all-nodes
multicast address. From Linus Lüssing.
5) The x86 BPF JIT support for negative offsets puts the parameter
for the helper function call in the wrong register. Fix from
Alexei Starovoitov.
6) The descriptor type used for RTL_GIGA_MAC_VER_17 chips in the
r8169 driver is incorrect. Fix from Hayes Wang.
7) The xen-netback driver tests skb_shinfo(skb)->gso_type bits to see
if a packet is a GSO frame, but that's not the correct test. It
should use skb_is_gso(skb) instead. Fix from Wei Liu.
8) Negative msg->msg_namelen values should generate an error, from
Matthew Leach.
9) at86rf230 can deadlock because it takes the same lock from it's
ISR and it's hard_start_xmit method, without disabling interrupts
in the latter. Fix from Alexander Aring.
10) The FEC driver's restart doesn't perform operations in the correct
order, so promiscuous settings can get lost. Fix from Stefan
Wahren.
11) Fix SKB leak in SCTP cookie handling, from Daniel Borkmann.
12) Reference count and memory leak fixes in TIPC from Ying Xue and
Erik Hugne.
13) Forced eviction in inet_frag_evictor() must strictly make sure all
frags are deleted, otherwise module unload (f.e. 6lowpan) can
crash. Fix from Florian Westphal.
14) Remove assumptions in AF_UNIX's use of csum_partial() (which it
uses as a hash function), which breaks on PowerPC. From Anton
Blanchard.
The main gist of the issue is that csum_partial() is defined only
as a value that, once folded (f.e. via csum_fold()) produces a
correct 16-bit checksum. It is legitimate, therefore, for
csum_partial() to produce two different 32-bit values over the
same data if their respective alignments are different.
15) Fix endiannes bug in MAC address handling of ibmveth driver, also
from Anton Blanchard.
16) Error checks for ipv6 exthdrs offload registration are reversed,
from Anton Nayshtut.
17) Externally triggered ipv6 addrconf routes should count against the
garbage collection threshold. Fix from Sabrina Dubroca.
18) The PCI shutdown handler added to the bnx2 driver can wedge the
chip if it was not brought up earlier already, which in particular
causes the firmware to shut down the PHY. Fix from Michael Chan.
19) Adjust the sanity WARN_ON_ONCE() in qdisc_list_add() because as
currently coded it can and does trigger in legitimate situations.
From Eric Dumazet.
20) BNA driver fails to build on ARM because of a too large udelay()
call, fix from Ben Hutchings.
21) Fair-Queue qdisc holds locks during GFP_KERNEL allocations, fix
from Eric Dumazet.
22) The vlan passthrough ops added in the previous release causes a
regression in source MAC address setting of outgoing headers in
some circumstances. Fix from Peter Boström"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (70 commits)
ipv6: Avoid unnecessary temporary addresses being generated
eth: fec: Fix lost promiscuous mode after reconnecting cable
bonding: set correct vlan id for alb xmit path
at86rf230: fix lockdep splats
net/mlx4_en: Deregister multicast vxlan steering rules when going down
vmxnet3: fix building without CONFIG_PCI_MSI
MAINTAINERS: add networking selftests to NETWORKING
net: socket: error on a negative msg_namelen
MAINTAINERS: Add tools/net to NETWORKING [GENERAL]
packet: doc: Spelling s/than/that/
net/mlx4_core: Load the IB driver when the device supports IBoE
net/mlx4_en: Handle vxlan steering rules for mac address changes
net/mlx4_core: Fix wrong dump of the vxlan offloads device capability
xen-netback: use skb_is_gso in xenvif_start_xmit
r8169: fix the incorrect tx descriptor version
tools/net/Makefile: Define PACKAGE to fix build problems
x86: bpf_jit: support negative offsets
bridge: multicast: enable snooping on general queries only
bridge: multicast: add sanity check for general query destination
tcp: tcp_release_cb() should release socket ownership
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Cc: netdev@vger.kernel.org
Pull ARM SoC fixes from from Olof Johansson:
"A collection of fixes for ARM platforms. A little large due to us
missing to do one last week, but there's nothing in particular here
that is in itself large and scary.
Mostly a handful of smaller fixes all over the place. The majority is
made up of fixes for OMAP, but there are a few for others as well. In
particular, there was a decision to rename a binding for the Broadcom
pinctrl block that we need to go in before the final release since we
then treat it as ABI"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: omap3-gta04: Add ti,omap36xx to compatible property to avoid problems with booting
ARM: tegra: add LED options back into tegra_defconfig
ARM: dts: omap3-igep: fix boot fail due wrong compatible match
ARM: OMAP3: Fix pinctrl interrupts for core2
pinctrl: Rename Broadcom Capri pinctrl binding
pinctrl: refer to updated dt binding string.
Update dtsi with new pinctrl compatible string
ARM: OMAP: Kill warning in CPUIDLE code with !CONFIG_SMP
ARM: OMAP2+: Add support for thumb mode on DT booted N900
ARM: OMAP2+: clock: fix clkoutx2 with CLK_SET_RATE_PARENT
ARM: OMAP4: hwmod: Fix SOFTRESET logic for OMAP4
ARM: DRA7: hwmod data: correct the sysc data for spinlock
ARM: OMAP5: PRM: Fix reboot handling
ARM: sunxi: dt: Change the touchscreen compatibles
ARM: sun7i: dt: Fix interrupt trigger types
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
- dm-cache memory allocation failure fix
- fix DM's Kconfig identation
- dm-snapshot metadata corruption fix for bug introduced in 3.14-rc1
- important refcount < 0 fix for the DM persistent data library's space
map metadata interface which fixes corruption reported by a few
dm-thinp users
and last but not least:
- more extensive fixes than ideal for dm-thinp's data resize capability
(which has had growing pain much like we've seen from -ENOSPC
handling of filesystems that mature).
The end result is dm-thinp now handles metadata operation failure and
no data space error conditions much better than before.
* tag 'dm-3.14-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm space map metadata: fix refcount decrement below 0 which caused corruption
dm thin: fix Documentation for held metadata root feature
dm thin: fix noflush suspend IO queueing
dm thin: fix deadlock in __requeue_bio_list
dm thin: fix out of data space handling
dm thin: ensure user takes action to validate data and metadata consistency
dm thin: synchronize the pool mode during suspend
dm snapshot: fix metadata corruption
dm: fix Kconfig indentation
dm cache mq: fix memory allocation failure for large cache devices
The original documentation was very unclear.
The code fix is presumably related to the formerly unclear
documentation: SOCK_TIMESTAMPING_RX_SOFTWARE has no effect on
__sock_recv_timestamp's behavior, so calling __sock_recv_ts_and_drops
from sock_recv_ts_and_drops if only SOCK_TIMESTAMPING_RX_SOFTWARE is
set is pointless. This should have no user-observable effect.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Cochran <richardcochran@gmail.com>
The Documentation for the thin provisioning target's held metadata root
feature was incorrect. It is now available and the value for the held
metadata root is in block units (not 512b sectors).
If a thin metadata operation fails the current transaction will abort,
whereby causing potential for IO layers up the stack (e.g. filesystems)
to have data loss. As such, set THIN_METADATA_NEEDS_CHECK_FLAG in the
thin metadata's superblock which:
1) requires the user verify the thin metadata is consistent (e.g. use
thin_check, etc)
2) suggests the user verify the thin data is consistent (e.g. use fsck)
The only way to clear the superblock's THIN_METADATA_NEEDS_CHECK_FLAG is
to run thin_repair.
On metadata operation failure: abort current metadata transaction, set
pool in read-only mode, and now set the needs_check flag.
As part of this change, constraints are introduced or relaxed:
* don't allow a pool to transition to write mode if needs_check is set
* don't allow data or metadata space to be resized if needs_check is set
* if a thin pool's metadata space is exhausted: the kernel will now
force the user to take the pool offline for repair before the kernel
will allow the metadata space to be extended.
Also, update Documentation to include information about when the thin
provisioning target commits metadata, how it handles metadata failures
and running out of space.
Signed-off-by: Joe Thornber <ejt@redhat.com>
1) Fix memory leak in ieee80211_prep_connection(), sta_info leaked on
error. From Eytan Lifshitz.
2) Unintentional switch case fallthrough in nft_reject_inet_eval(),
from Patrick McHardy.
3) Must check if payload lenth is a power of 2 in
nft_payload_select_ops(), from Nikolay Aleksandrov.
4) Fix mis-checksumming in xen-netfront driver, ip_hdr() is not in the
correct place when we invoke skb_checksum_setup(). From Wei Liu.
5) TUN driver should not advertise HW vlan offload features in
vlan_features. Fix from Fernando Luis Vazquez Cao.
6) IPV6_VTI needs to select NET_IPV_TUNNEL to avoid build errors, fix
from Steffen Klassert.
7) Add missing locking in xfrm_migrade_state_find(), we must hold the
per-namespace xfrm_state_lock while traversing the lists. Fix from
Steffen Klassert.
8) Missing locking in ath9k driver, access to tid->sched must be done
under ath_txq_lock(). Fix from Stanislaw Gruszka.
9) Fix two bugs in TCP fastopen. First respect the size argument given
to tcp_sendmsg() in the fastopen path, and secondly prevent
tcp_send_syn_data() from potentially using order-5 allocations.
From Eric Dumazet.
10) Fix handling of default neigh garbage collection params, from Jiri
Pirko.
11) Fix cwnd bloat and over-inflation of RTT when transmit segmentation
is in use. From Eric Dumazet.
12) Missing initialization of Realtek r8169 driver's statistics
seqlocks. Fix from Kyle McMartin.
13) Fix RTNL assertion failures in 802.3ad and AB ARP monitor of bonding
driver, from Ding Tianhong.
14) Bonding slave release race can cause divide by zero, fix from
15) Overzealous return from neigh_periodic_work() causes reachability
time to not be computed. Fix from Duain Jiong.
16) Fix regression in ipv6_find_hdr(), it should not return -ENOENT when
a specific target is specified and found. From Hans Schillstrom.
17) Fix VLAN tag stripping regression in BNA driver, from Ivan Vecera.
18) Tail loss probe can calculate bogus RTTs due to missing packet
marking on retransmit. Fix from Yuchung Cheng.
19) We cannot do skb_dst_drop() in iptunnel_pull_header() because
multicast loopback detection in later code paths need access to
skb_rtable(). Fix from Xin Long.
20) The macvlan driver regresses in that it propagates lower device
offload support disables into itself, causing severe slowdowns when
running over a bridge. Provide the software offloads always on
macvlan devices to deal with this and the regression is gone. From
Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits)
macvlan: Add support for 'always_on' offload features
net: sctp: fix sctp_sf_do_5_1D_ce to verify if we/peer is AUTH capable
ip_tunnel:multicast process cause panic due to skb->_skb_refdst NULL pointer
net: cpsw: fix cpdma rx descriptor leak on down interface
be2net: isolate TX workarounds not applicable to Skyhawk-R
be2net: Fix skb double free in be_xmit_wrokarounds() failure path
be2net: clear promiscuous bits in adapter->flags while disabling promiscuous mode
be2net: Fix to reset transparent vlan tagging
qlcnic: dcb: a couple off by one bugs
tcp: fix bogus RTT on special retransmission
hsr: off by one sanity check in hsr_register_frame_in()
can: remove CAN FD compatibility for CAN 2.0 sockets
can: flexcan: factor out soft reset into seperate funtion
can: flexcan: flexcan_remove(): add missing netif_napi_del()
can: flexcan: fix transition from and to freeze mode in chip_{,un}freeze
can: flexcan: factor out transceiver {en,dis}able into seperate functions
can: flexcan: fix transition from and to low power mode in chip_{en,dis}able
can: flexcan: flexcan_open(): fix error path if flexcan_chip_start() fails
can: flexcan: fix shutdown: first disable chip, then all interrupts
USB AX88179/178A: Support D-Link DUB-1312
git://git.linaro.org/people/mike.turquette/linux
Pull clk framework fixes from Mike Turquette:
"Clock framework and driver fixes, all of which fix user-visible
regressions.
There is a single framework fix that prevents dereferencing a NULL
pointer when calling clk_get. The range of fixes for clock driver
regressions spans memory leak fixes, touching the wrong registers that
cause things to explode, misconfigured clock rates that result in
non-responsive devices and even some boot failures. The most benign
fix is DT binding doc typo. It is a stable ABI exposed from the
kernel that was introduced in -rc1, so best to fix it now"
* tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux: (25 commits)
clk:at91: Fix memory leak in of_at91_clk_master_setup()
clk: nomadik: fix multiplatform problem
clk: Correct handling of NULL clk in __clk_{get, put}
clk: shmobile: Fix typo in MSTP clock DT bindings
clk: shmobile: rcar-gen2: Fix qspi divisor
clk: shmobile: rcar-gen2: Fix clock parent for all non-PLL clocks
clk: tegra124: remove gr2d and gr3d clocks
clk: tegra: Fix vic03 mux index
clk: shmobile: rcar-gen2: Fix clock parent all non-PLL clocks
clk: tegra: use max divider if divider overflows
clk: tegra: cclk_lp has a pllx/2 divider
clk: tegra: fix sdmmc clks on Tegra1x4
clk: tegra: fix host1x clock on Tegra124
clk: tegra: PLLD2 fixes for hdmi
clk: tegra: Fix PLLD mnp table
clk: tegra: Fix PLLP rate table
clk: tegra: Correct clock number for UARTE
clk: tegra: Add missing Tegra20 fuse clks
ARM: keystone: dts: fix clkvcp3 control register address
In commit e2d265d3b587 (canfd: add support for CAN FD in CAN_RAW sockets)
CAN FD frames with a payload length up to 8 byte are passed to legacy
sockets where the CAN FD support was not enabled by the application.
After some discussions with developers at a fair this well meant feature
leads to confusion as no clean switch for CAN / CAN FD is provided to the
application programmer. Additionally a compatibility like this for legacy
CAN_RAW sockets requires some compatibility handling for the sending, e.g.
make CAN2.0 frames a CAN FD frame with BRS at transmission time (?!?).
This will become a mess when people start to develop applications with
real CAN FD hardware. This patch reverts the bad compatibility code
together with the documentation describing the removed feature.
Acked-by: Stephane Grosjean <s.grosjean@peak-system.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Pull slave-dma fixes from Vinod Koul:
"This request brings you two small fixes. First one for fixing
dereference of freed descriptor and second for fixing sdma bindings
for it to work for imx25.
I was planning to send this about 10days ago but then I had to proceed
on my paternity leave and didnt get chance to send this. Now got a
bit of time from dady duties :)"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dma: sdma: Add imx25 compatible
dma: ste_dma40: don't dereference free:d descriptor
The compatible string of the Broadcom Capri pinctrl driver is renamed to
"brcm,bcm11351-pinctrl" to match the machine binding here:
Documentation/devicetree/bindings/arm/bcm/bcm11351.txt
Signed-off-by: Sherman Yin <syin@broadcom.com>
Reviewed-by: Matt Porter <mporter@linaro.org>
Signed-off-by: Christian Daudt <bcm@fixthebug.org>
The DT bindings document a renesas,indices property, while the code, the
DT example and the DT sources all use renesas,clock-indices. Fix the
documentation.
The shmobile mstp DT bindings have been merged in v3.14-rc1 with a bug
in the DT ABI, a fix during the -rc series is appropriate.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Simon Horman <horms@verge.net.au>
Pull ARM SoC fixes from Olof Johansson:
"A collection of fixes for ARM platforms. Most are fixes for DTS
files, mostly from DT conversion on OMAP which is still finding a few
issues here and there.
There's a couple of small stale code removal patches that we usually
queue for the next release instead, but they seemed harmless enough to
bring in now.
Also, a fix for backlight on some PXA platforms, and a cache
configuration fix for Tegra, etc"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits)
MAINTAINERS: add additional ARM BCM281xx/BCM11xxx maintainer
ARM: tegra: only run PL310 init on systems with one
ARM: tegra: Add head numbers to display controllers
ARM: imx6: build pm-imx6q.c independently of CONFIG_PM
ARM: tegra: fix RTC0 alias for Cardhu
ARM: dove: dt: revert PMU interrupt controller node
Documentation: dt: OMAP: Update Overo/Tobi
ARM: dts: Add support for both OMAP35xx and OMAP36xx Overo/Tobi
ARM: dts: omap3-tobi: Use the correct vendor prefix
ARM: dts: omap3-tobi: Fix boot with OMAP36xx-based Overo
ARM: OMAP2+: Remove legacy macros for zoom platforms
ARM: OMAP2+: Remove MACH_NOKIA_N800
ARM: dts: N900: add missing compatible property
ARM: dts: N9/N950: fix boot hang with 3.14-rc1
ARM: OMAP1: nokia770: enable tahvo-usb
ARM: OMAP2+: gpmc: fix: DT ONENAND child nodes not probed when MTD_ONENAND is built as module
ARM: OMAP2+: gpmc: fix: DT NAND child nodes not probed when MTD_NAND is built as module
ARM: dts: omap3-gta04: Fix mmc1 properties.
ARM: dts: omap3-gta04: Fix 'aux' gpio key flags.
ARM: OMAP2+: add missing ARCH_HAS_OPP
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull TTY revert from Greg KH:
"Here is a single commit, a revert of a sysfs file change that ended up
breaking a userspace tool"
* tag 'tty-3.14-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
Revert "tty: Set correct tty name in 'active' sysfs attribute"
