path: root/Documentation
2012-02-06Documentation: add missing tainted bits to Documentation/sysctl/kernel.txtLarry Finger
Two of the bits in the tainted flag are not documented. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - add Lenovo Ideapad U455 to 'reset' blacklist Input: serio_raw - return proper result when serio_raw_read fails Input: document device properties Input: twl4030_keypad - fix comment (trivial) Input: gpio_keys - fix struct device declared inside parameter list Input: evdev - fix variable initialisation
2012-02-01docbook: fix fatal errors in device-drivers docbook and add DMA Management ↵Randy Dunlap
section Fix 2 fatal errors in the device-drivers docbook. Also add some missing files from drivers/base/; since several of these are DMA-related, add a section for DMA Management. docproc: drivers/base/sys.c: No such file or directory docproc: drivers/tty/serial/8250.c: No such file or directory Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-01Input: document device propertiesHenrik Rydberg
Add a section which defines the input device properties and provides guidelines on how to use them. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Reviewed-by: Chase Douglas <chase.douglas@canonical.com> Reviewed-by: Jussi Pakkanen <jussi.pakkanen@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2012-01-30Merge branch 'for-torvalds' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Here are some fixes to the pin control system that has accumulated since -rc1. Mainly Tony Lindgren fixed the module load/unload logic and the rest are minor fixes and documentation. * 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: add checks for empty function names pinctrl: fix pinmux_hog_maps when ctrl_dev_name is not set pinctrl: fix some pinmux typos pinctrl: free debugfs entries when unloading a pinmux driver pinctrl: unbreak error messages Documentation/pinctrl: fix a few syntax errors in code examples pinctrl: fix pinconf_pins_show iteration
2012-01-28Merge tag 'driver-core-3.3-rc1-bugfixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Here are some patches for the 3.3-rc1 tree. It contains the removal of the sysdev code, now that all users of it are gone, as well as some sysfs bugfixes that have been reported by users. There are also some documentation updates here as well. * tag 'driver-core-3.3-rc1-bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: sysfs: Complain bitterly about attempts to remove files from nonexistent directories. stable: update documentation to ask for kernel version base/core.c:fix typo in comment in function device_add Documentation: devres: add allocation functions to list of supported calls Documentation update for the driver model core kernel-doc: fix new warnings in driver-core kernel-doc: fix new warnings in debugfs kernel-doc: fix new warnings in device.h driver core: remove drivers/base/sys.c and include/linux/sysdev.h
2012-01-28Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
* tag 'for-linus' of git://github.com/rustyrussell/linux: lguest: remove reference from Documentation/virtual/00-INDEX virtio: correct the memory barrier in virtqueue_kick_prepare() virtio: fix typos of memory barriers
2012-01-28Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc arm-soc fixes for 3.3-rc: AT91 needed reset fixes which resulted in some minor code refactoring, it also adds a feature-removal for one of their platforms for 3.4. The USB patches have been acked by Greg K-H. i.MX and ux500 both have some minor fixes, nothing controversial. * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arch/arm/mach-imx/mach-mx53_ard.c: add missing iounmap ARM: imx: iomux-v1.h: Fix build error due to __init annotation ARM: at91: Fix at91sam9g45 and at91cap9 reset ARM: at91: make rstc soc independent ARM: at91: introduce AT91_SAM9_ALT_RESET to select the at91sam9 alternative reset ARM: at91: merge at91cap9_ddrsdr.h in at91sam9_ddrsdr.h ARM: at91: fix cap9 ddrsdr register ARM/USB: at91/ohci-at91: rename vbus_pin_inverted to vbus_pin_active_low USB: at91: fix clk_get error handling ARM: at91: removal of CAP9 SoC family ARM: at91: fix at91rm9200 soc subtype handling mach-ux500: no MMC_CAP_SD_HIGHSPEED on Snowball mach-ux500: enable ARM errata 764369 mach-ux500: do not override outer.inv_all mach-ux500: musb: now musb is always in OTG mode ARM: imx6: add missing twd_clk for imx6q clock
2012-01-28lguest: remove reference from Documentation/virtual/00-INDEXRusty Russell
We're in tools/lguest now. Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-26pinctrl: fix some pinmux typosTony Lindgren
Fix some pinmux typos so implementing pinmux drivers is a bit easier. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-24Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Quoth Len: "This fixes a merge-window regression due to a conflict between error injection and preparation to remove atomicio.c Here we fix that regression and complete the removal of atomicio.c. This also re-orders some idle initialization code to complete the merge window series that allows cpuidle to cope with bringing processors on-line after boot." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: Use acpi_os_map_memory() instead of ioremap() in einj driver ACPI, APEI, EINJ, cleanup 0 vs NULL confusion ACPI, APEI, EINJ Allow empty Trigger Error Action Table thermal: Rename generate_netlink_event ACPI / PM: Add Sony Vaio VPCCW29FX to nonvs blacklist. ACPI: Remove ./drivers/acpi/atomicio.[ch] ACPI, APEI: Add RAM mapping support to ACPI ACPI, APEI: Add 64-bit read/write support for APEI on i386 ACPI processor hotplug: Delay acpi_processor_start() call for hotplugged cores ACPI processor hotplug: Split up acpi_processor_add
2012-01-24Documentation/pinctrl: fix a few syntax errors in code examplesUwe Kleine-König
Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-24stable: update documentation to ask for kernel versionGreg Kroah-Hartman
It would save me an email round-trip asking which stable tree(s) that a patch should be applied to, so document that the tree number should be specified in the email request. Reported-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24Documentation: devres: add allocation functions to list of supported callsWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Tejun Heo <tj@kernel.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-23Merge tag 'pm-fixes-for-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Power management fixes for 3.3 Two fixes for regressions introduced during the merge window, one fix for a long-standing obscure issue in the computation of hibernate image size and two small PM documentation fixes. * tag 'pm-fixes-for-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Sleep: Fix read_unlock_usermodehelper() call. PM / Hibernate: Rewrite unlock_system_sleep() to fix s2disk regression PM / Hibernate: Correct additional pages number calculation PM / Documentation: Fix minor issue in freezing_of_tasks.txt PM / Documentation: Fix spelling mistake in basic-pm-debugging.txt
2012-01-23docbook: fix sched source file names in device-drivers bookRandy Dunlap
Fix warning since kernel scheduler functions and kernel-doc notation were moved to other files. docproc: lnx-33-rc1/kernel/sched.c: No such file or directory Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23docbook: change iomap source filename in deviceiobookRandy Dunlap
Fix warning since kernel-doc comments were moved to another source file. Warning(lib/iomap.c): no structured comments found Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23docbook: don't use serial_core.h in device-drivers bookRandy Dunlap
Fix new kernel-doc warning. This file no longer contains kernel-doc comments. Warning(include/linux/serial_core.h): no structured comments found Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23thermal: Rename generate_netlink_eventJean Delvare
It doesn't seem right for the thermal subsystem to export a symbol named generate_netlink_event. This function is thermal-specific and its name should reflect that fact. Rename it to thermal_generate_netlink_event. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: R.Durgadoss <durgadoss.r@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-20ARM: at91: removal of CAP9 SoC familyNicolas Ferre
Atmel CAP9 family is not maintained well and products may be difficult to find now. It will allow to save workforce and remove LOC during current cleanup process. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-01-19PM / Documentation: Fix minor issue in freezing_of_tasks.txtViresh Kumar
In a paragraph, "kernel thread" is mistakenly written as "kernel". Fix this by adding thread after word "kernel". Changes are shown in multiple lines, as they are realigned to 80 col width. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-01-19PM / Documentation: Fix spelling mistake in basic-pm-debugging.txtViresh Kumar
Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-01-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (26 commits) target: Set additional sense length field in sense data target: Remove legacy device status check from transport_execute_tasks target: Remove __transport_execute_tasks() for each processing context target: Remove extra se_device->execute_task_lock access in fast path target: Drop se_device TCQ queue_depth usage from I/O path target: Fix possible NULL pointer with __transport_execute_tasks target: Remove TFO->check_release_cmd() fabric API caller tcm_fc: Convert ft_send_work to use target_submit_cmd target: Add target_submit_cmd() for process context fabric submission target: Make target_put_sess_cmd use target_release_cmd_kref target: Set response format in INQUIRY response target: tcm_mod_builder: small fixups Documentation/target: Fix tcm_mod_builder.py build breakage target: remove overagressive ____cacheline_aligned annoations tcm_loop: bump max_sectors target/configs: remove trailing newline from udev_path and alias iscsi-target: fix chap identifier simple_strtoul usage target: remove useless casts target: simplify target_check_cdb_and_preempt target: Move core_scsi3_check_cdb_abort_and_preempt ...
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-18Merge branch 'for-linus/i2c-33' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c-33' of git://git.fluff.org/bjdooks/linux: i2c-eg20t: Change-company-name-OKI-SEMICONDUCTOR to LAPIS Semiconductor i2c-eg20t: Support new device LAPIS Semiconductor ML7831 IOH i2c-eg20t: modified the setting of transfer rate. i2c-eg20t: use i2c_add_numbered_adapter to get a fixed bus number i2c: OMAP: Add DT support for i2c controller I2C: OMAP: NACK without STP I2C: OMAP: correct SYSC register offset for OMAP4
2012-01-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (57 commits) [media] as3645a: Fix compilation by including slab.h [media] s5p-fimc: Remove linux/version.h include from fimc-mdevice.c [media] s5p-mfc: Remove linux/version.h include from s5p_mfc.c [media] ds3000: using logical && instead of bitwise & [media] v4l2-ctrls: make control names consistent [media] DVB: dib0700, add support for Nova-TD LEDs [media] DVB: dib0700, add corrected Nova-TD frontend_attach [media] DVB: dib0700, separate stk7070pd initialization [media] DVB: dib0700, move Nova-TD Stick to a separate set [media] : add MODULE_FIRMWARE to dib0700 [media] DVB-CORE: remove superfluous DTV_CMDs [media] s5p-jpeg: adapt to recent videobuf2 changes [media] s5p-g2d: fixed a bug in controls setting function [media] s5p-mfc: Fix volatile controls setup [media] drivers/media/video/s5p-mfc/s5p_mfc.c: adjust double test [media] drivers/media/video/s5p-fimc/fimc-capture.c: adjust double test [media] s5p-fimc: Fix incorrect control ID assignment [media] dvb_frontend: Don't call get_frontend() if idle [media] DocBook/dvbproperty.xml: Remove DTV_MODULATION from ISDB-T [media] DocBook/dvbproperty.xml: Fix ISDB-T delivery system parameters ...
2012-01-18Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 SCSI updates on 20120118 * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (49 commits) [SCSI] libfc: remove redundant timer init for fcp [SCSI] fcoe: Move fcoe_debug_logging from fcoe.h to fcoe.c [SCSI] libfc: Declare local functions static [SCSI] fcoe: fix regression on offload em matching function for initiator/target [SCSI] qla4xxx: Update driver version to 5.02.00-k12 [SCSI] qla4xxx: Cleanup modinfo display [SCSI] qla4xxx: Update license [SCSI] qla4xxx: Clear the RISC interrupt bit during FW init [SCSI] qla4xxx: Added error logging for firmware abort [SCSI] qla4xxx: Disable generating pause frames in case of FW hung [SCSI] qla4xxx: Temperature monitoring for ISP82XX core. [SCSI] megaraid: fix sparse warnings [SCSI] sg: convert to kstrtoul_from_user() [SCSI] don't change sdev starvation list order without request dispatched [SCSI] isci: fix, prevent port from getting stuck in the 'configuring' state [SCSI] isci: fix start OOB [SCSI] isci: fix io failures while wide port links are coming up [SCSI] isci: allow more time for wide port targets [SCSI] isci: enable wide port targets [SCSI] isci: Fix IO fails when pull cable from phy in x4 wideport in MPC mode. ...
2012-01-18Merge git://git.infradead.org/users/willy/linux-nvmeLinus Torvalds
* git://git.infradead.org/users/willy/linux-nvme: (105 commits) NVMe: Set number of queues correctly NVMe: Version 0.8 NVMe: Set queue flags correctly NVMe: Simplify nvme_unmap_user_pages NVMe: Mark the end of the sg list NVMe: Fix DMA mapping for admin commands NVMe: Rename IO_TIMEOUT to NVME_IO_TIMEOUT NVMe: Merge the nvme_bio and nvme_prp data structures NVMe: Change nvme_completion_fn to take a dev NVMe: Change get_nvmeq to take a dev instead of a namespace NVMe: Simplify completion handling NVMe: Update Identify Controller data structure NVMe: Implement doorbell stride capability NVMe: Version 0.7 NVMe: Don't probe namespace 0 Fix calculation of number of pages in a PRP List NVMe: Create nvme_identify and nvme_get_features functions NVMe: Fix memory leak in nvme_dev_add() NVMe: Fix calls to dma_unmap_sg NVMe: Correct sg list setup in nvme_map_user_pages ...
2012-01-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) tg3: Fix single-vector MSI-X code openvswitch: Fix multipart datapath dumps. ipv6: fix per device IP snmp counters inetpeer: initialize ->redirect_genid in inet_getpeer() net: fix NULL-deref in WARN() in skb_gso_segment() net: WARN if skb_checksum_help() is called on skb requiring segmentation caif: Remove bad WARN_ON in caif_dev caif: Fix typo in Vendor/Product-ID for CAIF modems bnx2x: Disable AN KR work-around for BCM57810 bnx2x: Remove AutoGrEEEn for BCM84833 bnx2x: Remove 100Mb force speed for BCM84833 bnx2x: Fix PFC setting on BCM57840 bnx2x: Fix Super-Isolate mode for BCM84833 net: fix some sparse errors net: kill duplicate included header net: sh-eth: Fix build error by the value which is not defined net: Use device model to get driver name in skb_gso_segment() bridge: BH already disabled in br_fdb_cleanup() net: move sock_update_memcg outside of CONFIG_INET mwl8k: Fixing Sparse ENDIAN CHECK warning ...
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-18acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi specTony Luck
ACPI 5.0 provides extensions to the EINJ mechanism to specify the target for the error injection - by APICID for cpu related errors, by address for memory related errors, and by segment/bus/device/function for PCIe related errors. Also extensions for vendor specific error injections. Tested-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2012-01-17Merge branches 'for-33/i2c/eg20t' and 'for-33/i2c/omap' into for-linus/i2c-33Ben Dooks
2012-01-17i2c: OMAP: Add DT support for i2c controllerBenoit Cousson
Add initial DT support to retrieve the frequency using a DT attribute instead of the pdata pointer if of_node exist. Add documentation for omap i2c controller binding. Based on original patches from Manju and Grant. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Ben Dooks <ben-linux@fluff.org> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-01-17ACPI: kernel-parameters.txt : Add intel_idle.max_cstateMasanari Iida
Add missing intel_idle.max_cstate in kernel-parameters.txt Signed-off-by Masanari Iida <standby24x7@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17[media] DocBook/dvbproperty.xml: Remove DTV_MODULATION from ISDB-TMauro Carvalho Chehab
On ISDB-T, each layer can have its own independent modulation, applied to the carriers that belong to the segments associated with them. So, there's no sense to define a global modulation parameter. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] DocBook/dvbproperty.xml: Fix ISDB-T delivery system parametersMauro Carvalho Chehab
The ISDB-T differs on its way to implement the hierarchical transmissions: instead of using a low-priority/high-priority FEC codes, it does that by using different layers, each layer with their groups of segments. So, those parameters don't make sense for ISDB-T. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] DocBook/dvbproperty.xml: Fix the units for DTV_FREQUENCYMauro Carvalho Chehab
The units for DTV_FREQUENCY are kHz for satellital delivery systems (DVB-S/DVB-S2/DVB-TURBO/ISDB-S). Fix it at the API spec. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-16Merge branch 'x86-syscall-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move <asm/asm-offsets.h> from trace_syscalls.c to asm/syscall.h x86, um: Fix typo in 32-bit system call modifications um: Use $(srctree) not $(KBUILD_SRC) x86, um: Mark system call tables readonly x86, um: Use the same style generated syscall tables as native um: Generate headers before generating user-offsets.s um: Run host archheaders, allow use of host generated headers kbuild, headers.sh: Don't make archheaders explicitly x86, syscall: Allow syscall offset to be symbolic x86, syscall: Re-fix typo in comment x86: Simplify syscallhdr.sh x86: Generate system call tables and unistd_*.h from tables checksyscalls: Use arch/x86/syscalls/syscall_32.tbl as source x86: Machine-readable syscall tables and scripts to process them trace: Include <asm/asm-offsets.h> in trace_syscalls.c x86-64, ia32: Move compat_ni_syscall into C and its own file x86-64, syscall: Adjust comment spacing and remove typo kbuild: Add support for an "archheaders" target kbuild: Add support for installing generated asm headers
2012-01-16Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (sysfs-interface) Update tempX_type attribute to be more generic hwmon: (adm1031) Fix coding style issues hwmon: (it87) Add IT8728F support hwmon: (coretemp) Add missing section annotations hwmon: (lm90) Add range check to set_update_interval hwmon: (lm63) Support extended lookup table of LM96163 hwmon: (lm63) Expose automatic fan speed control lookup table hwmon: (lm63) Fix incorrect comment about I2C address hwmon: (lm63) LM64 has a dedicated pin for tachometer hwmon: (lm63) Add sensor type attribute for external sensor on LM96163 hwmon: (lm63) Add support for update_interval sysfs attribute hwmon: (lm63) Add support for writing the external critical temperature hwmon: (lm63) Add support for unsigned upper temperature limits hwmon: (lm63) Add support for LM96163 hwmon: (lm63) Add support for external temperature offset register hwmon: (lm63) Fix checkpatch errors hwmon: (max1111) Change sysfs interface to in[0-3]_input in millivolts
2012-01-16Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle: improve the coverage of some semantic patches coccinelle: semantic patches related to devm_ functions (part 2) coccinelle: semantic patches related to devm_ functions (part 1) coccinelle.txt: update documentation to include M= option coccicheck: add M= option to control which dir is processed ctags: remove struct forward declarations scripts/tags.sh: Add Page flag function magic
2012-01-16hwmon: (sysfs-interface) Update tempX_type attribute to be more genericGuenter Roeck
The temp[1-*]_type attribute reports the temperature sensor type. Sensor type 1 is described as "PII/Celeron Diode", which is quite restrictive; other CPUs may also have an embedded temperature sensor diode with similar characteristics. Change description to "CPU embedded diode" to be more generic. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-16hwmon: (it87) Add IT8728F supportJean Delvare
Until we get a datasheet for the IT8728F, treat it as fully compatible with the IT8721F, as it seems to work reasonably well. This closes kernel bug #27262. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-16hwmon: (lm63) Expose automatic fan speed control lookup tableJean Delvare
The LM63 and compatible devices have a lookup table to control the fan speed automatically. Expose it in sysfs. Values are cached for 5 seconds, independently of the other register values to avoid slowing down "sensors". We might make the table values writable in the future. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-16hwmon: (lm63) LM64 has a dedicated pin for tachometerJean Delvare
On the LM64, the tachometer function has a dedicated pin and fan speed monitoring is always enabled. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-16hwmon: (lm63) Add sensor type attribute for external sensor on LM96163Guenter Roeck
On LM96163, the external temperature sensor type is configurable to either a thermal diode or a 3904 transistor. The chip reports a wrong temperature if misconfigured. Add writable attribute to support it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-16hwmon: (lm63) Add support for update_interval sysfs attributeGuenter Roeck
The update interval is configurable on LM63 and compatibles. Add support for it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-16hwmon: (lm63) Add support for LM96163Guenter Roeck
LM96163 is an enhanced version of LM63 with improved PWM resolution. Add chip detection code as well as support for improved PWM resolution if the chip is configured to use it. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-16[media] v4l2-ioctl: make tuner 'type' check more strict for S_FREQUENCYHans Verkuil
As per the feature removal document, make the tuner type check more strict so that it is no longer possible to set the radio frequency through a video node or the TV frequency through a radio node. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-16[media] V4L2 Spec: improve the G/S_INPUT/OUTPUT documentationHans Verkuil
As Rupert pointed out, the phrase "It is good practice" should be replaced with "You must". Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Rupert Eibauer <Rupert.Eibauer@ces.ch> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
