commit e427c2375646789ecd0ccaef1a1e41458559ab2d upstream.
On recent kernels, Realtek codec parser tries to optimize the routing
aggressively and take the headphone output as primary at first. This
caused a regression on VAIO Z with ALC889, the silent output from the
speaker.
The problem seems that the speaker pin must be connected to the first
DAC (0x02) on this machine by some reason although the codec itself
advertises the flexible routing with any DACs.
This patch adds a fix-up for choosing the speaker pin as the primary
so that the right DAC is assigned on this device.
Reported-and-tested-by: Adam Williamson <awilliam@redhat.com>
commit 4a8f1ddde942e232387e6129ce4f4c412e43802f upstream.
Add the SMBus Device IDs for the Intel Lynx Point-LP PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit 2584f5212d97b664be250ad5700a2d0fee31a10d upstream.
Also add information on where the respective trees are.
Acked-by: Rob Landley <rob@landley.net>
commit 108cc108a3bb42fe4705df1317ff98e1e29428a6 upstream.
Also add a model/fixup string "lenovo-dock", so that other Thinkpad
users will be able to test this fixup easily, to see if it enables
dock I/O for them as well.
BugLink: https://bugs.launchpad.net/bugs/1026953
Tested-by: John McCarron <john.mccarron@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 18068bdd5f59229623b2fa518a6389e346642b0d upstream.
Veritysetup is now part of cryptsetup package.
Remove on-disk header description (which is not parsed in kernel)
and point users to cryptsetup where it the format is documented.
Mention units for block size paramaters.
Fix target line specification and dmsetup parameters.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit eb3979f64d25120d60b9e761a4c58f70b1a02f86 upstream.
Distribution kernel maintainers routinely backport fixes for users that
were deemed important but not "something critical" as defined by the
rules. To users of these kernels they are very serious and failing to fix
them reduces the value of -stable.
The problem is that the patches fixing these issues are often subtle and
prone to regressions in other ways and need greater care and attention.
To combat this, these "serious" backports should have a higher barrier
to entry.
This patch relaxes the rules to allow a distribution maintainer to merge
to -stable a backported patch or small series that fixes a "serious"
user-visible performance issue. They should include additional information on
the user-visible bug affected and a link to the bugzilla entry if available.
The same rules about the patch being already in mainline still apply.
commit 591bfc6bf9e5e25e464fd4c87d64afd5135667c4 upstream.
The HOWTO document needed updating for the new kernel versioning. The
git URI for -next was updated as well.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"For a some fix patches for v3.4, including a regression fix at DVB core"
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] gspca - sonixj: Fix a zero divide in isoc interrupt
[media] media: videobuf2-dma-contig: include header for exported symbols
[media] media: videobuf2-dma-contig: quiet sparse noise about plain integer as NULL pointer
[media] media: vb2-memops: Export vb2_get_vma symbol
[media] s5p-fimc: Correct memory allocation for VIDIOC_CREATE_BUFS
[media] s5p-fimc: Fix locking in subdev set_crop op
[media] dvb_frontend: fix a regression with DVB-S zig-zag
[media] fintek-cir: change || to &&
[media] V4L: Schedule V4L2_CID_HCENTER, V4L2_CID_VCENTER controls for removal
[media] rc: Postpone ISR registration
[media] marvell-cam: fix an ARM build error
[media] V4L: soc-camera: protect hosts during probing from overzealous user-space
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound sound fixes from Takashi Iwai:
"As good as nothing exciting here; just a few trivial fixes for various
ASoC stuff."
* tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: omap-pcm: Free dma buffers in case of error.
ASoC: s3c2412-i2s: Fix dai registration
ASoC: wm8350: Don't use locally allocated codec struct
ASoC: tlv312aic23: unbreak resume
ASoC: bf5xx-ssm2602: Set DAI format
ASoC: core: check of_property_count_strings failure
ASoC: dt: sgtl5000.txt: Add description for 'reg' field
ASoC: wm_hubs: Make sure we don't disable differential line outputs
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Updates for 3.4
Nothing terribly exciting here, a bunch of small and simple fixes
scattered around the place.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
Pull libata fixes from Jeff Garzik:
1) Fix regression that could cause a misdiagnosis, which in turn could
lead to an erroneous 3.0 Gbps -> 1.5 downshift, particularly when hotplug
and suspend/resume is involved.
2) Fix a regression that led to ata%d controller ids being numbered one
larger than in <= 3.4-rc3 (oh, the horror!). Controller ids should now be
as expected.
3) add some DT, PCI id's
4) ata/pata_arasan_cf: minor cpp fixing/cleaning
* tag 'tag/upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
ata: ahci_platform: Add synopsys ahci controller in DT's compatible list
ata/pata_arasan_cf: Move arasan_cf_pm_ops out of #ifdef, #endif macros
libata: init ata_print_id to 0
ahci: Detect Marvell 88SE9172 SATA controller
libata: skip old error history when counting probe trials
Pull networking fixes from David Miller:
1) Transfer padding was wrong for full-speed USB in ASIX driver, fix
from Ingo van Lil.
2) Propagate the negative packet offset fix into the PowerPC BPF JIT.
From Jan Seiffert.
3) dl2k driver's private ioctls were letting unprivileged tasks make
MII writes and other ugly bits like that. Fix from Jeff Mahoney.
4) Fix TX VLAN and RX packet drops in ucc_geth, from Joakim Tjernlund.
5) OOPS and network namespace fixes in IPVS from Hans Schillstrom and
Julian Anastasov.
6) Fix races and sleeping in locked context bugs in drop_monitor, from
Neil Horman.
7) Fix link status indication in smsc95xx driver, from Paolo Pisati.
8) Fix bridge netfilter OOPS, from Peter Huang.
9) L2TP sendmsg can return on error conditions with the socket lock
held, oops. Fix from Sasha Levin.
10) udp_diag should return meaningful values for socket memory usage,
from Shan Wei.
11) Eric Dumazet is so awesome he gets his own section:
Socket memory cgroup code (I never should have applied those
patches, grumble...) made erroneous changes to
sk_sockets_allocated_read_positive(). It was changed to
use percpu_counter_sum_positive (which requires BH disabling)
instead of percpu_counter_read_positive (which does not).
Revert back to avoid crashes and lockdep warnings.
Adjust the default tcp_adv_win_scale and tcp_rmem[2] values
to fix throughput regressions. This is necessary as a result
of our more precise skb->truesize tracking.
Fix SKB leak in netem packet scheduler.
12) New device IDs for various bluetooth devices, from Manoj Iyer,
AceLan Kao, and Steven Harms.
13) Fix command completion race in ipw2200, from Stanislav Yakovlev.
14) Fix rtlwifi oops on unload, from Larry Finger.
15) Fix hard_mtu when adjusting hard_header_len in smsc95xx driver.
From Stephane Fillod.
16) ehea driver registers it's IRQ before all the necessary state is
setup, resulting in crashes. Fix from Thadeu Lima de Souza
Cascardo.
17) Fix PHY connection failures in davinci_emac driver, from Anatolij
Gustschin.
18) Missing break; in switch statement in bluetooth's
hci_cmd_complete_evt(). Fix from Szymon Janc.
19) Fix queue programming in iwlwifi, from Johannes Berg.
20) Interrupt throttling defaults not being actually programmed into the
hardware, fix from Jeff Kirsher and Ying Cai.
21) TLAN driver SKB encoding in descriptor busted on 64-bit, fix from
Benjamin Poirier.
22) Fix blind status block RX producer pointer deref in TG3 driver, from
Matt Carlson.
23) Promisc and multicast are busted on ehea, fixes from Thadeu Lima de
Souza Cascardo.
24) Fix crashes in 6lowpan, from Alexander Smirnov.
25) tcp_complete_cwr() needs to be careful to not rewind the CWND to
ssthresh if ssthresh has the "infinite" value. Fix from Yuchung
Cheng.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (81 commits)
sungem: Fix WakeOnLan
tcp: change tcp_adv_win_scale and tcp_rmem[2]
net: l2tp: unlock socket lock before returning from l2tp_ip_sendmsg
drop_monitor: prevent init path from scheduling on the wrong cpu
usbnet: fix failure handling in usbnet_probe
usbnet: fix leak of transfer buffer of dev->interrupt
ucc_geth: Add 16 bytes to max TX frame for VLANs
net: ucc_geth, increase no. of HW RX descriptors
netem: fix possible skb leak
sky2: fix receive length error in mixed non-VLAN/VLAN traffic
sky2: propogate rx hash when packet is copied
net: fix two typos in skbuff.h
cxgb3: Don't call cxgb_vlan_mode until q locks are initialized
ixgbe: fix calling skb_put on nonlinear skb assertion bug
ixgbe: Fix a memory leak in IEEE DCB
igbvf: fix the bug when initializing the igbvf
smsc75xx: enable mac to detect speed/duplex from phy
smsc75xx: declare smsc75xx's MII as GMII capable
smsc75xx: fix phy interrupt acknowledge
smsc75xx: fix phy init reset loop
SPEAr13xx series of SoCs contain Synopsys AHCI SATA Controller which shares
ahci_platform driver with other controller versions.
This patch updates DT compatible list for ahci_platform. It also updates and
renames binding documentation to more generic name.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Cc: Rob Herring <rob.herring@calxeda.com>
tcp_adv_win_scale default value is 2, meaning we expect a good citizen
skb to have skb->len / skb->truesize ratio of 75% (3/4)
In 2.6 kernels we (mis)accounted for typical MSS=1460 frame :
1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392.
So these skbs were considered as not bloated.
With recent truesize fixes, a typical MSS=1460 frame truesize is now the
more precise :
2048 + 256 = 2304. But 2304 * 3/4 = 1728.
So these skb are not good citizen anymore, because 1460 < 1728
(GRO can escape this problem because it build skbs with a too low
truesize.)
This also means tcp advertises a too optimistic window for a given
allocated rcvspace : When receiving frames, sk_rmem_alloc can hit
sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often,
especially when application is slow to drain its receive queue or in
case of losses (netperf is fast, scp is slow). This is a major latency
source.
We should adjust the len/truesize ratio to 50% instead of 75%
This patch :
1) changes tcp_adv_win_scale default to 1 instead of 2
2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account
better truesize tracking and to allow autotuning tcp receive window to
reach same value than before. Note that same amount of kernel memory is
consumed compared to 2.6 kernels.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Pull power management fixes from Rafael J. Wysocki:
"Fix for an issue causing hibernation to hang on systems with highmem
(that practically means i386) due to broken memory management (bug
introduced in 3.2, so -stable material) and PM documentation update
making the freezer documentation follow the code again after some
recent updates."
* tag 'pm-for-3.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / Freezer / Docs: Update documentation about freezing of tasks
PM / Hibernate: fix the number of pages used for hibernate/thaw buffering
The file Documentation/power/freezing-of-tasks.txt was still referencing
the TIF_FREEZE flag, that was removed by the commit
d88e4cb67197d007fb778d62fe17360e970d5bfa(freezer: remove now unused
TIF_FREEZE).
This patch removes all the references of TIF_FREEZE that were left
behind.
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
These controls have been marked for long time as V4L2_CID_HCENTER_DEPRECATED,
V4L2_CID_VCENTER_DEPRECATED in the DocBook and are going to be removed
from include/linux/videodev2.h.
Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Add description for 'reg' field.
Adds sysfs HSI framework documentation
Signed-off-by: Carlos Chinea <carlos.chinea@nokia.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
- Fixes a regression at DVB core when switching from DVB-S2 to DVB-S on
Kaffeine (Fedora 16 Bugzilla #812895);
- Fixes a mutex unlock at an error condition at drx-k;
- Fix winbond-cir set mode;
- mt9m032: Fix a compilation breakage with some random Kconfig;
- mt9m032: fix two dead locks;
- xc5000: don't require an special firmware (that won't be provided by
the vendor) just because the xtal frequency is different;
- V4L DocBook: fix some typos at multi-plane formats description.
[media] xc5000: support 32MHz & 31.875MHz xtal using the 41.024.5 firmware
[media] V4L: mt9m032: fix compilation breakage
[media] V4L: DocBook: Fix typos in the multi-plane formats description
[media] V4L: mt9m032: fix two dead-locks
[media] rc-core: set mode for winbond-cir
[media] drxk: Does not unlock mutex if sanity check failed in scu_command()
[media] dvb_frontend: Fix a regression when switching back to DVB-S
Pull another round of sound fixes from Takashi Iwai:
"A few regression fixes for Realtek HD-audio codecs, mainly specific to
some laptop models."
ALSA: hda/realtek - Fix mem leak (and rid us of trailing whitespace).
ALSA: hda/realtek - Add quirk for Mac Pro 5,1 machines
ALSA: hda/realtek - Add a fixup entry for Acer Aspire 8940G
ALSA: hda/realtek - Fix GPIO1 setup for Acer Aspire 4930 & co
ALSA: hda/realtek - Add a few ALC882 model strings back
Pull block driver bits from Jens Axboe:
- A series of fixes for mtip32xx. Most from Asai at Micron, but also
one from Greg, getting rid of the dependency on PCIE_HOTPLUG.
- A few bug fixes for xen-blkfront, and blkback.
- A virtio-blk fix for Vivek, making resize actually work.
- Two fixes from Stephen, making larger transfers possible on cciss.
This is needed for tape drive support.
* 'for-3.4/drivers' of git://git.kernel.dk/linux-block:
block: mtip32xx: remove HOTPLUG_PCI_PCIE dependancy
mtip32xx: dump tagmap on failure
mtip32xx: fix handling of commands in various scenarios
mtip32xx: Shorten macro names
mtip32xx: misc changes
mtip32xx: Add new sysfs entry 'status'
mtip32xx: make setting comp_time as common
mtip32xx: Add new bitwise flag 'dd_flag'
mtip32xx: fix error handling in mtip_init()
virtio-blk: Call revalidate_disk() upon online disk resize
xen/blkback: Make optional features be really optional.
xen/blkback: Squash the discard support for 'file' and 'phy' type.
mtip32xx: fix incorrect value set for drv_cleanup_done, and re-initialize and start port in mtip_restart_port()
cciss: Fix scsi tape io with more than 255 scatter gather elements
cciss: Initialize scsi host max_sectors for tape drive support
xen-blkfront: make blkif_io_lock spinlock per-device
xen/blkfront: don't put bdev right after getting it
xen-blkfront: use bitmap_set() and bitmap_clear()
xen/blkback: Enable blkback on HVM guests
xen/blkback: use grant-table.c hypercall wrappers
Pull block core bits from Jens Axboe:
"It's a nice and quiet round this time, since most of the tricky stuff
has been pushed to 3.5 to give it more time to mature. After a few
hectic block IO core changes for 3.3 and 3.2, I'm quite happy with a
slow round.
Really minor stuff in here, the only real functional change is making
the auto-unplug threshold a per-queue entity. The threshold is set so
that it's low enough that we don't hold off IO for too long, but still
big enough to get a nice benefit from the batched insert (and hence
queue lock cost reduction). For raid configurations, this currently
breaks down."
* 'for-3.4/core' of git://git.kernel.dk/linux-block:
block: make auto block plug flush threshold per-disk based
Documentation: Add sysfs ABI change for cfq's target latency.
block: Make cfq_target_latency tunable through sysfs.
block: use lockdep_assert_held for queue locking
block: blk_alloc_queue_node(): use caller's GFP flags instead of GFP_KERNEL
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of fixes for the USB core and drivers for 3.4-rc2
Lots of tiny xhci fixes here, a few usb-serial driver fixes and new
device ids, and a smattering of other minor fixes in different USB
drivers.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (30 commits)
USB: update usbtmc api documentation
xHCI: Correct the #define XHCI_LEGACY_DISABLE_SMI
xHCI: use gfp flags from caller instead of GFP_ATOMIC
xHCI: add XHCI_RESET_ON_RESUME quirk for VIA xHCI host
USB: fix bug of device descriptor got from superspeed device
xhci: Fix register save/restore order.
xhci: Restore event ring dequeue pointer on resume.
xhci: Don't write zeroed pointers to xHC registers.
xhci: Warn when hosts don't halt.
xhci: don't re-enable IE constantly
usb: xhci: fix section mismatch in linux-next
xHCI: correct to print the true HSEE of USBCMD
USB: serial: fix race between probe and open
UHCI: hub_status_data should indicate if ports are resuming
EHCI: keep track of ports being resumed and indicate in hub_status_data
USB: fix race between root-hub suspend and remote wakeup
USB: sierra: add support for Sierra Wireless MC7710
USB: ftdi_sio: fix race condition in TIOCMIWAIT, and abort of TIOCMIWAIT when the device is removed
USB: ftdi_sio: fix status line change handling for TIOCMIWAIT and TIOCGICOUNT
USB: don't ignore suspend errors for root hubs
Pull timer fixes from Thomas Gleixner:
"The itimer removal one is not strictly a fix, but I really wanted to
avoid a rebase of the urgent ones."
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "clocksource: Load the ACPI PM clocksource asynchronously"
clockevents: tTack broadcast device mode change in tick_broadcast_switch_to_oneshot()
itimer: Use printk_once instead of WARN_ONCE
nohz: Fix stale jiffies update in tick_nohz_restart()
tick: Document TICK_ONESHOT config option
proc: stats: Use arch_idle_time for idle and iowait times if available
itimer: Schedule silent NULL pointer fixup in setitimer() for removal
Merge fixes from Andrew Morton.
* emailed from Andrew Morton <akpm@linux-foundation.org>: (14 patches)
panic: fix stack dump print on direct call to panic()
drivers/rtc/rtc-pl031.c: enable clock on all ST variants
Revert "mm: vmscan: fix misused nr_reclaimed in shrink_mem_cgroup_zone()"
hugetlb: fix race condition in hugetlb_fault()
drivers/rtc/rtc-twl.c: use static register while reading time
drivers/rtc/rtc-s3c.c: add placeholder for driver private data
drivers/rtc/rtc-s3c.c: fix compilation error
MAINTAINERS: add PCDP console maintainer
memcg: do not open code accesses to res_counter members
drivers/rtc/rtc-efi.c: fix section mismatch warning
drivers/rtc/rtc-r9701.c: reset registers if invalid values are detected
drivers/char/random.c: fix boot id uniqueness race
memcg: fix broken boolen expression
memcg: fix up documentation on global LRU
In v3.3-rc1, the global LRU was removed in commit 925b7673cce3 ("mm:
make per-memcg LRU lists exclusive"). The patch fixes up the memcg
docs.
I left the swap session to someone who has better understanding of
'memory+swap'.
Signed-off-by: Ying Han <yinghan@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Correct path names in API documentation for usbtmc
Signed-off-by: Stephen Lewis <lewis@sdf.lonestar.org>
Since there are still many Acer models that might not be covered by
the current fixup table, let's add back a few typical model names so
that user can test the fixup without recompiling.
* Add support for detecting the following device status
- write protect
- over temp (thermal shutdown)
* Add new sysfs entry 'status', possible values - online, write_protect, thermal_shutdown
* Add new file 'sysfs-block-rssd' to document ABI (Reported-by: Greg Kroah-Hartman)
Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com>
This is needed to catch the resume bug that was bothering lots of us from
testing some XHCI bug fixes in the suspend/resume path.
This patch (as1534c) updates the documentation for usb_unlink_urb and
related functions. It explains that the caller must prevent the URB
being unlinked from getting deallocated while the unlink is taking
place.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Ming Lei <tom.leiming@gmail.com>
The doc says that the data
| 55534243 5e000000 00000000 00000600 00000000 00000000 00000000 000000
is the SCSI command 0x5e. According to the usbmon source, it dumps one
byte after the other. The first 4 bytes are US_BULK_CB_SIGN which is
correct. After that we see the TAG which is 0x5e. The cdb is 0x00 in
this example.
In order to correct this, I change the example to a READ_10 command
which is 0x28 so it is not just a zero somewhere in the stream.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Pull networking updates from David Miller:
1) Fix inaccuracies in network driver interface documentation, from Ben
Hutchings.
2) Fix handling of negative offsets in BPF JITs, from Jan Seiffert.
3) Compile warning, locking, and refcounting fixes in netfilter's
xt_CT, from Pablo Neira Ayuso.
4) phonet sendmsg needs to validate user length just like any other
datagram protocol, fix from Sasha Levin.
5) Ipv6 multicast code uses wrong loop index, from RongQing Li.
6) Link handling and firmware fixes in bnx2x driver from Yaniv Rosner
and Yuval Mintz.
7) mlx4 erroneously allocates 4 pages at a time, regardless of page
size, fix from Thadeu Lima de Souza Cascardo.
8) SCTP socket option wasn't extended in a backwards compatible way,
fix from Thomas Graf.
9) Add missing address change event emissions to bonding, from Shlomo
Pongratz.
10) /proc/net/dev regressed because it uses a private offset to track
where we are in the hash table, but this doesn't track the offset
pullback that the seq_file code does resulting in some entries being
missed in large dumps.
Fix from Eric Dumazet.
11) do_tcp_sendpage() unloads the send queue way too fast, because it
invokes tcp_push() when it shouldn't. Let the natural sequence
generated by the splice paths, and the assosciated MSG_MORE
settings, guide the tcp_push() calls.
Otherwise what goes out of TCP is spaghetti and doesn't batch
effectively into GSO/TSO clusters.
From Eric Dumazet.
12) Once we put a SKB into either the netlink receiver's queue or a
socket error queue, it can be consumed and freed up, therefore we
cannot touch it after queueing it like that.
Fixes from Eric Dumazet.
13) PPP has this annoying behavior in that for every transmit call it
immediately stops the TX queue, then calls down into the next layer
to transmit the PPP frame.
But if that next layer can take it immediately, it just un-stops the
TX queue right before returning from the transmit method.
Besides being useless work, it makes several facilities unusable, in
particular things like the equalizers. Well behaved devices should
only stop the TX queue when they really are full, and in PPP's case
when it gets backlogged to the downstream device.
David Woodhouse therefore fixed PPP to not stop the TX queue until
it's downstream can't take data any more.
14) IFF_UNICAST_FLT got accidently lost in some recent stmmac driver
changes, re-add. From Marc Kleine-Budde.
15) Fix link flaps in ixgbe, from Eric W. Multanen.
16) Descriptor writeback fixes in e1000e from Matthew Vick.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits)
net: fix a race in sock_queue_err_skb()
netlink: fix races after skb queueing
doc, net: Update ndo_start_xmit return type and values
doc, net: Remove instruction to set net_device::trans_start
doc, net: Update netdev operation names
doc, net: Update documentation of synchronisation for TX multiqueue
doc, net: Remove obsolete reference to dev->poll
ethtool: Remove exception to the requirement of holding RTNL lock
MAINTAINERS: update for Marvell Ethernet drivers
bonding: properly unset current_arp_slave on slave link up
phonet: Check input from user before allocating
tcp: tcp_sendpages() should call tcp_push() once
ipv6: fix array index in ip6_mc_add_src()
mlx4: allocate just enough pages instead of always 4 pages
stmmac: re-add IFF_UNICAST_FLT for dwmac1000
bnx2x: Clear MDC/MDIO warning message
bnx2x: Fix BCM57711+BCM84823 link issue
bnx2x: Clear BCM84833 LED after fan failure
bnx2x: Fix BCM84833 PHY FW version presentation
bnx2x: Fix link issue for BCM8727 boards.
Commit dc1f8bf68b311b1537cb65893430b6796118498a ('netdev: change
transmit to limited range type') changed the required return type and
9a1654ba0b50402a6bd03c7b0fe9b0200a5ea7b1 ('net: Optimize
hard_start_xmit() return checking') changed the valid numerical
return values.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Commit 08baf561083bc27a953aa087dd8a664bb2b88e8e ('net:
txq_trans_update() helper') made it unnecessary for most drivers to
set net_device::trans_start (or netdev_queue::trans_start).
Commits d314774cf2cd5dfeb39a00d37deee65d4c627927 ('netdev: network
device operations infrastructure') and
008298231abbeb91bc7be9e8b078607b816d1a4a ('netdev: add more functions
to netdevice ops') moved and renamed net device operation pointers.
Commits e308a5d806c852f56590ffdd3834d0df0cbed8d7 ('netdev: Add
netdev->addr_list_lock protection.') and
e8a0464cc950972824e2e128028ae3db666ec1ed ('netdev: Allocate multiple
queues for TX.') introduced more fine-grained locks.
Commit bea3348eef27e6044b6161fd04c3152215f96411 ('[NET]: Make NAPI
polling independent of struct net_device objects.') removed the
automatic disabling of NAPI polling by dev_close(), and drivers
must now do this themselves.
Pull "ARM: SoC fixes: from Olof Johansson:
"A bunch of fixes for regressions (and a few other problems) in
3.4-rc1:
- Fix for regression of mach/io.h cleanup on platforms with PCI or
PCMCIA (adding back the include file on those for now)
- AT91 fixes for usb and spi
- smsc911x ethernet fixes for i.MX
- smsc911x fixes for OMAP
- gpio fixes for Tegra
- A handful of build error and warning fixes for various platforms
- cpufreq kconfig dependencies, build and lowlevel debug fixes for
Samsung platforms
In other words, more or less the regular collection of -rc1/2 type
material. A few of them, in particular the smsc911x for OMAP series,
aren't technically regressions for 3.4, but they're valid fixes and
we're still relatively early in the rc cycle so it seems appropriate
to include them."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits)
ARM: fix __io macro for PCMCIA
ARM: EXYNOS: Fix compiler warning in dma.c file
ARM: EXYNOS: fix ISO C90 warning
ARM: OMAP2+: hwmod: Fix wrong SYSC_TYPE1_XXX_MASK bit definitions
ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status
ARM: OMAP2+: hwmod: Restore sysc after a reset
ARM: OMAP2+: omap_hwmod: Allow io_ring wakeup configuration for all modules
ARM: OMAP3: clock data: fill in some missing clockdomains
ARM: OMAP4: clock data: Force a DPLL clkdm/pwrdm ON before a relock
ARM: OMAP4: clock data: fix mult and div mask for USB_DPLL
ARM: OMAP2+: powerdomain: Wait for powerdomain transition in pwrdm_state_switch()
gpio: tegra: Iterate over the correct number of banks
gpio: tegra: fix register address calculations for Tegra30
EXYNOS: fix dependency for EXYNOS_CPUFREQ
ARM: at91: dt: remove unit-address part for memory nodes
ARM: at91: fix check of valid GPIO for SPI and USB
USB: ehci-atmel: add needed of.h header file
ARM: at91/NAND DT bindings: add comments
ARM: at91/at91sam9x5.dtsi: fix NAND ale/cle in DT file
USB: ohci-at91: trivial return code name change
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA mapping branch from Marek Szyprowski:
"Short summary for the whole series:
A few limitations have been identified in the current dma-mapping
design and its implementations for various architectures. There exist
more than one function for allocating and freeing the buffers:
currently these 3 are used dma_{alloc, free}_coherent,
dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent.
For most of the systems these calls are almost equivalent and can be
interchanged. For others, especially the truly non-coherent ones
(like ARM), the difference can be easily noticed in overall driver
performance. Sadly not all architectures provide implementations for
all of them, so the drivers might need to be adapted and cannot be
easily shared between different architectures. The provided patches
unify all these functions and hide the differences under the already
existing dma attributes concept. The thread with more references is
available here:
http://www.spinics.net/lists/linux-sh/msg09777.html
These patches are also a prerequisite for unifying DMA-mapping
implementation on ARM architecture with the common one provided by
dma_map_ops structure and extending it with IOMMU support. More
information is available in the following thread:
http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819
More works on dma-mapping framework are planned, especially in the
area of buffer sharing and managing the shared mappings (together with
the recently introduced dma_buf interface: commit d15bd7ee445d
"dma-buf: Introduce dma buffer sharing mechanism").
The patches in the current set introduce a new alloc/free methods
(with support for memory attributes) in dma_map_ops structure, which
will later replace dma_alloc_coherent and dma_alloc_writecombine
functions."
People finally started piping up with support for merging this, so I'm
merging it as the last of the pending stuff from the merge window.
Looks like pohmelfs is going to wait for 3.5 and more external support
for merging.
* 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
common: DMA-mapping: add NON-CONSISTENT attribute
common: DMA-mapping: add WRITE_COMBINE attribute
common: dma-mapping: introduce mmap method
common: dma-mapping: remove old alloc_coherent and free_coherent methods
Hexagon: adapt for dma_map_ops changes
Unicore32: adapt for dma_map_ops changes
Microblaze: adapt for dma_map_ops changes
SH: adapt for dma_map_ops changes
Alpha: adapt for dma_map_ops changes
SPARC: adapt for dma_map_ops changes
PowerPC: adapt for dma_map_ops changes
MIPS: adapt for dma_map_ops changes
X86 & IA64: adapt for dma_map_ops changes
common: dma-mapping: introduce generic alloc() and free() methods
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A bunch of smallish fixes that came up during the merge window as
things got more testing - even more fixes from Axel, a fix for error
handling in more complex systems using -EPROBE_DEFER and a couple of
small fixes for the new dummy regulators."
* tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: Remove non-existent parameter from fixed-helper.c kernel doc
regulator: Fix setting new voltage in s5m8767_set_voltage
regulator: fix sysfs name collision between dummy and fixed dummy regulator
regulator: Fix deadlock on removal of regulators with supplies
regulator: Fix comments in include/linux/regulator/machine.h
regulator: Only update [LDOx|DCx]_HIB_MODE bits in wm8350_[ldo|dcdc]_set_suspend_disable
regulator: Fix setting low power mode for wm831x aldo
regulator: Return microamps in wm8350_isink_get_current
regulator: wm8350: Fix the logic to choose best current limit setting
regulator: wm831x-isink: Fix the logic to choose best current limit setting
regulator: wm831x-dcdc: Fix the logic to choose best current limit setting
regulator: anatop: patching to device-tree property "reg".
regulator: Do proper shift to set correct bit for DC[2|5]_HIB_MODE setting
regulator: Fix restoring pmic.dcdcx_hib_mode settings in wm8350_dcdc_set_suspend_enable
regulator: Fix unbalanced lock/unlock in mc13892_regulator_probe error path
regulator: Fix set and get current limit for wm831x_buckv
regulator: tps6586x: Fix list minimal voltage setting for LDO0
Pull x86 fixes from Ingo Molnar.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, kvm: Call restore_sched_clock_state() only after %gs is initialized
x86: Use -mno-avx when available
x86: Remove the ancient and deprecated disable_hlt() and enable_hlt() facility
x86: Preserve lazy irq disable semantics in fixup_irqs()
Add comments to NAND "gpios" property to make it clearer.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon patches from Guenter Roeck:
- Fix crash in ad7314 driver
- Add support for AMD Trinity CPUs to k10temp driver
- Fix __initdata/__initconst mixup in w83627ehf driver
- Fix runtime warnings in acpi_power_meter and max6639 drivers
- Fix build warnings in adm1031, f75375s, sht15, and gpio-fan drivers
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (ad7314) Adds missing spi_dev initialization
hwmon: (k10temp) Add support for AMD Trinity CPUs
hwmon: (w83627ehf) mark const init data with __initconst instead of __initdata
hwmon: (acpi_power_meter) fix lockdep spew due to non-static lock class
hwmon: (adm1031) Fix compiler warning
hwmon: (f75375s) Fix warning message seen in some configurations
hwmon: (max6639) Convert to dev_pm_ops
hwmon: (sht15) Fix Kconfig dependencies
hwmon: (gpio-fan) Fix Kconfig dependencies
The explanation of ip_local_port_range in
Documentation/networking/ip-sysctl.txt contains several factual
errors:
- The default value of ip_local_port_range does not depend on the
amount of memory available in the system.
- tcp_tw_recycle is not enabled by default.
- 1024-4999 is not the default value.
- Etc.
Clean up the mess.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Pull HSI (High Speed Synchronous Serial Interface) framework from Carlos Chinea:
"The High Speed Synchronous Serial Interface (HSI) is a serial
interface mainly used for connecting application engines (APE) with
cellular modem engines (CMT) in cellular handsets.
The framework is currently being used for some people and we would
like to see it integrated into the kernel for 3.3. There is no HW
controller drivers in this pull, but some people have already some of
them pending which they would like to push as soon as this integrated.
I am also working on the acceptance for an TI OMAP one, based on a
compatible legacy version of the interface called SSI."
Ok, so it didn't get into 3.3, but here it is pulled into 3.4.
Several people piped up to say "yeah, we want this".
* 'for-next' of git://gitorious.org/kernel-hsi/kernel-hsi:
HSI: hsi_char: Update ioctl-number.txt
HSI: Add HSI API documentation
HSI: hsi_char: Add HSI char device kernel configuration
HSI: hsi_char: Add HSI char device driver
HSI: hsi: Introducing HSI framework
