path: root/Documentation
2012-07-16Merge tag 'fixes-for-v3.5-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull late pinctrl fixes from Linus Walleij: - Two fixes to the i.MX driver * tag 'fixes-for-v3.5-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: pinctrl-imx6q: add missed mux function for USBOTG_ID pinctrl: pinctrl-imx: only print debug message when DEBUG is defined
2012-07-14pinctrl: pinctrl-imx6q: add missed mux function for USBOTG_IDDong Aisheng
The original pin registers table is derived from u-boot mainline, but somehow it was found missing some mux functions for USBOTG_ID. We added it at the bottom by following the exist pin function ids, then it will not break the exist using of pin function id in dts file. Reported-by: Richard Zhao <richard.zhao@freescale.com> Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-07-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: - Some regression fixes at the audio part for devices with cx23885/cx25840 - A DMA corruption fix at cx231xx - two fixes at the winbond IR driver - Several fixes for the EXYNOS media driver (s5p) - two fixes at the OMAP3 preview driver - one fix at the dvb core failure path - an include missing (slab.h) at smiapp-core causing compilation breakage - em28xx was not loading the IR driver driver anymore. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (31 commits) [media] Revert "[media] V4L: JPEG class documentation corrections" [media] s5p-fimc: Add missing FIMC-LITE file operations locking [media] omap3isp: preview: Fix contrast and brightness handling [media] omap3isp: preview: Fix output size computation depending on input format [media] winbond-cir: Initialise timeout, driver_type and allowed_protos [media] winbond-cir: Fix txandrx module info [media] cx23885: Silence unknown command warnings [media] cx23885: add support for HVR-1255 analog (cx23888 variant) [media] cx23885: make analog support work for HVR_1250 (cx23885 variant) [media] cx25840: fix vsrc/hsrc usage on cx23888 designs [media] cx25840: fix regression in HVR-1800 analog audio [media] cx25840: fix regression in analog support hue/saturation controls [media] cx25840: fix regression in HVR-1800 analog support [media] s5p-mfc: Fixed setup of custom controls in decoder and encoder [media] cx231xx: don't DMA to random addresses [media] em28xx: fix em28xx-rc load [media] dvb-core: Release semaphore on error path dvb_register_device() [media] s5p-fimc: Stop media entity pipeline if fimc_pipeline_validate fails [media] s5p-fimc: Fix compiler warning in fimc-lite.c [media] s5p-fimc: media_entity_pipeline_start() may fail ...
2012-07-13Merge tag 'for-linus-20120712' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull late MTD fixes from David Woodhouse: - fix 'sparse warning fix' regression which totally breaks MXC NAND - fix GPMI NAND regression when used with UBI - update/correct sysfs documentation for new 'bitflip_threshold' field - fix nandsim build failure * tag 'for-linus-20120712' of git://git.infradead.org/linux-mtd: mtd: nandsim: don't open code a do_div helper mtd: ABI documentation: clarification of bitflip_threshold mtd: gpmi-nand: fix read page when reading to vmalloced area mtd: mxc_nand: use 32bit copy functions
2012-07-08security: Minor improvements to no_new_privs documentationAndy Lutomirski
The documentation didn't actually mention how to enable no_new_privs. This also adds a note about possible interactions between no_new_privs and LSMs (i.e. why teaching systemd to set no_new_privs is not necessarily a good idea), and it references the new docs from include/linux/prctl.h. Suggested-by: Rob Landley <rob@landley.net> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-07[media] Revert "[media] V4L: JPEG class documentation corrections"Sylwester Nawrocki
This reverts commit feed0258e11e04b7e0, as the same issues are already covered in another version of that patch that was also applied (579e92ffac65c717c9c8a50feb755a). Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-06mtd: ABI documentation: clarification of bitflip_thresholdMike Dunn
The -EUCLEAN return value applies to mtd_read_oob() as well as mtd_read(), but only mtd_read() was mentioned in the blurd on bitflip_threshold in the ABI documentation. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-07-05Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fix from Marcelo Tosatti: "Memory leak and oops on the x86 mmu code, and sanitization of the KVM_IRQFD ioctl." * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: MMU: fix shrinking page from the empty mmu KVM: fix fault page leak KVM: Sanitize KVM_IRQFD flags KVM: Add missing KVM_IRQFD API documentation KVM: Pass kvm_irqfd to functions
2012-07-05Merge branch 'fixes-for-grant' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
Pull DT fixes from Rob Herring: "Mainly some documentation updates and 2 fixes: - An export symbol fix for of_platform_populate from Stephen W. - A fix for the order compatible entries are matched to ensure the first compatible string is matched when there are multiple matches." Normally these would go through Grant Likely (thus the "fixes-for-grant" branch name), but Grant is in the middle of moving to Scotland, and is practically offline until sometime in August. So pull directly from Rob. * 'fixes-for-grant' of git://sources.calxeda.com/kernel/linux: of: match by compatible property first dt: mc13xxx.txt: Fix gpio number assignment dt: fsl-fec.txt: Fix gpio number assignment dt: fsl-mma8450.txt: Add missing 'reg' description dt: fsl-imx-esdhc.txt: Fix gpio number assignment dt: fsl-imx-cspi.txt: Fix comment about GPIOs used for chip selects of: Add Avionic Design vendor prefix of: export of_platform_populate()
2012-07-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block bits from Jens Axboe: "As vacation is coming up, thought I'd better get rid of my pending changes in my for-linus branch for this iteration. It contains: - Two patches for mtip32xx. Killing a non-compliant sysfs interface and moving it to debugfs, where it belongs. - A few patches from Asias. Two legit bug fixes, and one killing an interface that is no longer in use. - A patch from Jan, making the annoying partition ioctl warning a bit less annoying, by restricting it to !CAP_SYS_RAWIO only. - Three bug fixes for drbd from Lars Ellenberg. - A fix for an old regression for umem, it hasn't really worked since the plugging scheme was changed in 3.0. - A few fixes from Tejun. - A splice fix from Eric Dumazet, fixing an issue with pipe resizing." * 'for-linus' of git://git.kernel.dk/linux-block: scsi: Silence unnecessary warnings about ioctl to partition block: Drop dead function blk_abort_queue() block: Mitigate lock unbalance caused by lock switching block: Avoid missed wakeup in request waitqueue umem: fix up unplugging splice: fix racy pipe->buffers uses drbd: fix null pointer dereference with on-congestion policy when diskless drbd: fix list corruption by failing but already aborted reads drbd: fix access of unallocated pages and kernel panic xen/blkfront: Add WARN to deal with misbehaving backends. blkcg: drop local variable @q from blkg_destroy() mtip32xx: Create debugfs entries for troubleshooting mtip32xx: Remove 'registers' and 'flags' from sysfs blkcg: fix blkg_alloc() failure path block: blkcg_policy_cfq shouldn't be used if !CONFIG_CFQ_GROUP_IOSCHED block: fix return value on cfq_init() failure mtip32xx: Remove version.h header file inclusion xen/blkback: Copy id field when doing BLKIF_DISCARD.
2012-07-03Merge tag 'dm-3.5-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper fixes from Alasdair G Kergon: "Four minor thin provisioning fixes and correct and update dm-verity documentation." * tag 'dm-3.5-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: dm: verity fix documentation dm persistent data: fix allocation failure in space map checker init dm persistent data: handle space map checker creation failure dm persistent data: fix shadow_info_leak on dm_tm_destroy dm thin: commit metadata before creating metadata snapshot
2012-07-03dm: verity fix documentationMilan Broz
Veritysetup is now part of cryptsetup package. Remove on-disk header description (which is not parsed in kernel) and point users to cryptsetup where it the format is documented. Mention units for block size paramaters. Fix target line specification and dmsetup parameters. Signed-off-by: Milan Broz <mbroz@redhat.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-03security: document no_new_privsAndy Lutomirski
Document no_new_privs. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-02KVM: Add missing KVM_IRQFD API documentationAlex Williamson
Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-06-30Merge tag 'driver-core-3.5-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver Core fixes from Greg Kroah-Hartman: "Here is a number of printk() fixes, specifically a few reported by the crazy blog program that ships in SUSE releases (that's "boot log" and not "web log", it predates the general "blog" terminology by many years), and the restoration of the continuation line functionality reported by Stephen and others. Yes, the changes seem a bit big this late in the cycle, but I've been beating on them for a while now, and Stephen has even optimized it a bit, so all looks good to me. The other change in here is a Documentation update for the stable kernel rules describing how some distro patches should be backported, to hopefully drive a bit more response from the distros to the stable kernel releases. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.5-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: printk: Optimize if statement logic where newline exists printk: flush continuation lines immediately to console syslog: fill buffer with more than a single message for SYSLOG_ACTION_READ Revert "printk: return -EINVAL if the message len is bigger than the buf size" printk: fix regression in SYSLOG_ACTION_CLEAR stable: Allow merging of backports for serious user-visible performance issues
2012-06-25Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab. Trivial conflict due to new USB HID ID's being added next to each other (Baanto vs Axentia). * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (44 commits) [media] smia: Fix compile failures [media] Fix VIDIOC_DQEVENT docbook entry [media] s5p-fimc: Fix control creation function [media] s5p-mfc: Fix checkpatch error in s5p_mfc_shm.h file [media] s5p-mfc: Fix setting controls [media] v4l/s5p-mfc: added image size align in VIDIOC_TRY_FMT [media] v4l/s5p-mfc: corrected encoder v4l control definitions [media] v4l: mem2mem_testdev: Fix race conditions in driver [media] s5p-mfc: Bug fix of timestamp/timecode copy mechanism [media] cxd2820r: Fix an incorrect modulation type bitmask [media] em28xx: Show a warning if the board does not support remote controls [media] em28xx: Add remote control support for Terratec's Cinergy HTC Stick HD [media] USB: Staging: media: lirc: initialize spinlocks before usage [media] Revert "[media] media: mx2_camera: Fix mbus format handling" [media] bw-qcam: driver and pixfmt documentation fixes [media] cx88: fix firmware load on big-endian systems [media] cx18: support big-endian systems [media] ivtv: fix support for big-endian systems [media] tuner-core: return the frequency range of the correct tuner [media] v4l2-dev.c: fix g_parm regression in determine_valid_ioctls() ...
2012-06-25stable: Allow merging of backports for serious user-visible performance issuesMel Gorman
Distribution kernel maintainers routinely backport fixes for users that were deemed important but not "something critical" as defined by the rules. To users of these kernels they are very serious and failing to fix them reduces the value of -stable. The problem is that the patches fixing these issues are often subtle and prone to regressions in other ways and need greater care and attention. To combat this, these "serious" backports should have a higher barrier to entry. This patch relaxes the rules to allow a distribution maintainer to merge to -stable a backported patch or small series that fixes a "serious" user-visible performance issue. They should include additional information on the user-visible bug affected and a link to the bugzilla entry if available. The same rules about the patch being already in mainline still apply. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20Merge tag 'staging-3.5-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree fixes from Greg Kroah-Hartman: "Here are a number of small fixes for the drivers/staging tree, as well as iio and pstore drivers (which came from the staging tree in the 3.5-rc1 merge). All of these are tiny, but resolve issues that people have been reporting. There's also a documentation update to reflect what the iio drivers really are doing, which is good to get straightened out. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'staging-3.5-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8712u: Add new USB IDs staging: gdm72xx: Release netlink socket properly iio: drop wrong reference from Kconfig pstore/inode: Make pstore_fill_super() static pstore/ram: Should zap persistent zone on unlink pstore/ram_core: Factor persistent_ram_zap() out of post_init() pstore/ram_core: Do not reset restored zone's position and size pstore/ram: Should update old dmesg buffer before reading staging:iio:ad7298: Fix linker error due to missing IIO kfifo buffer Revert "staging: usbip: bugfix for stack corruption on 64-bit architectures" staging: usbip: bugfix for stack corruption on 64-bit architectures staging/comedi: fix build for USB not enabled staging: omapdrm: fix crash when freeing bad fb staging:iio:ad7606: Re-add missing scale attribute iio: Fix potential use after free staging:iio: remove num_interrupt_lines from documentation iio: documentation: Add out_altvoltage and friends
2012-06-20Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
* emailed from Andrew Morton <akpm@linux-foundation.org>: (21 patches) mm/memblock: fix overlapping allocation when doubling reserved array c/r: prctl: Move PR_GET_TID_ADDRESS to a proper place pidns: find_new_reaper() can no longer switch to init_pid_ns.child_reaper pidns: guarantee that the pidns init will be the last pidns process reaped fault-inject: avoid call to random32() if fault injection is disabled Viresh has moved get_maintainer: Fix --help warning mm/memory.c: fix kernel-doc warnings mm: fix kernel-doc warnings mm: correctly synchronize rss-counters at exit/exec mm, thp: print useful information when mmap_sem is unlocked in zap_pmd_range h8300: use the declarations provided by <asm/sections.h> h8300: fix use of extinct _sbss and _ebss xtensa: use the declarations provided by <asm/sections.h> xtensa: use "test -e" instead of bashism "test -a" xtensa: replace xtensa-specific _f{data,text} by _s{data,text} memcg: fix use_hierarchy css_is_ancestor oops regression mm, oom: fix and cleanup oom score calculations nilfs2: ensure proper cache clearing for gc-inodes thp: avoid atomic64_read in pmd_read_atomic for 32bit PAE ...
2012-06-20Viresh has movedViresh Kumar
viresh.kumar@st.com email-id doesn't exist anymore as I have left the company. Replace ST's id with viresh.linux@gmail.com. It also updates .mailmap file to fix address for 'git shortlog' Signed-off-by: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-18[media] Fix VIDIOC_DQEVENT docbook entryHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-17hwmon: (coretemp) Document TjMax for 3rd generation i5/i7 processorsGuenter Roeck
Tjmax values from Intel datasheets. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-06-17hwmon: (coretemp) Add support for Atom D2000 and N2000 series CPU modelsGuenter Roeck
Document the Atom series D2000 and N2000 (Cedar Trail) as being supported. List and set TjMax for those series. Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "R, Durgadoss" <durgadoss.r@intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-06-17hwmon: (coretemp) Improve support of recent Atom CPU modelsJean Delvare
Document the new Atom series (Tunnel Creek and Medfield) as being supported, and list TjMax for the Atom E600 series. Also enable the Atom tjmax heuristic for these Atom CPU models. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Alexander Stein <alexander.stein@systec-electronic.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "R, Durgadoss" <durgadoss.r@intel.com>
2012-06-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David S. Miller: This has the fix for the wireless issues I ran into the other week as well as: 1) Fix CAN c_can driver transmit handling resulting in BUG check triggers, from AnilKumar Ch. 2) Fix packet drop monitor sleeping in atomic context, from Eric Dumazet. 3) Fix mv643xx_eth driver build regression, from Andrew Lunn. 4) Inetpeer freeing needs an RCU grace period in order to avoid races during tree invalidation. From Eric Dumazet. 5) Fix endianness bugs in xt_HMARK netfilter module, from Hans Schillstrom. 6) Add proper module refcounting to l2tp_eth to avoid crash on module unload, from Eric Dumazet. 7) Fix truncation of neighbour entry dumps due to logic errors in neigh_dump_info() and friends, from Eric Dumazet. 8) The conversion of fib6_age() to dst_neigh_lookup() accidently reversed the logic of a flags test, fix from Thomas Graf. 9) Fix checksum configuration in newer sky2 chips, from Stephen Hemminger. 10) Revert BQL support in NIU driver, doesn't work. 11) l2tp_ip_sendmsg() illegally uses a route without a proper reference. From Eric Dumazet. 12) be2net driver references an SKB after it's potentially been freed, also from Eric Dumazet. 13) Fix RCU stalls in dummy net driver init. Also from Eric Dumazet. 14) lpc_eth has several bugs in it's transmit engine leading to packet leaks and improper queue wakes, from Eric Dumazet. 15) Apply short DMA workaround to more tg3 chips, from Matt Carlson. 16) Add tilegx network driver. 17) Bonding queue mapping for a packet can get corrupted, fix from Eric Dumazet. 18) Fix bug in netpoll_send_udp() SKB management that can leave garbage in the payload in certain situations. From Eric Dumazet. 19) bnx2x driver interprets chip RX checksum offload incorrectly in encapsulation situations. Fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) bnx2x: fix checksum validation netpoll: fix netpoll_send_udp() bugs bonding: Fix corrupted queue_mapping bonding:record primary when modify it via sysfs tilegx network driver: initial support tg3: Apply short DMA frag workaround to 5906 net: stmmac: Fix clock en-/disable calls lpc_eth: fix tx completion lpc_eth: add missing ndo_change_mtu() dummy: fix rcu_sched self-detected stalls net: Reorder initialization in ip_route_output to fix gcc warning virtio-net: fix a race on 32bit arches r8169: avoid NAPI scheduling delay. net: Make linux/tcp.h C++ friendly (trivial) netdev: fix drivers/net/phy/ kernel-doc warnings net/core: fix kernel-doc warnings be2net: fix a race in be_xmit() l2tp: fix a race in l2tp_ip_sendmsg() mac80211: add back channel change flag NFC: Fix possible NULL ptr deref when getting the name of a socket ...
2012-06-13dt: mc13xxx.txt: Fix gpio number assignmentFabio Estevam
Fix gpio number assignment, so that it can match the number stated in the comment. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-13dt: fsl-fec.txt: Fix gpio number assignmentFabio Estevam
2012-06-13dt: fsl-mma8450.txt: Add missing 'reg' descriptionFabio Estevam
Add missing 'reg' description. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> ---- .../devicetree/bindings/input/fsl-mma8450.txt | 1 + 1 files changed, 1 insertions(+), 0 deletions(-) Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-13dt: fsl-imx-esdhc.txt: Fix gpio number assignmentFabio Estevam
Fix gpio number assignment, so that it can match the number stated in the comment. Cc: Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-13dt: fsl-imx-cspi.txt: Fix comment about GPIOs used for chip selectsFabio Estevam
The gpio numbers does not match the comment. Fix the comments for GPIOs used for chip selects. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-13of: Add Avionic Design vendor prefixThierry Reding
This commit adds a device tree vendor prefix for Avionic Design GmbH. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: devicetree-discuss@lists.ozlabs.org Cc: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-11[media] bw-qcam: driver and pixfmt documentation fixesHans Verkuil
Fix the documentation of the Y4 and Y6 formats. Fix a poll() issue, add support for enum_frmsizes, set the proper parent device and fix a few compliance issues. Tested with an actual Connectix B&W parallel port webcam, both on a little-endian and a big-endian platform. This driver has never been so good, doing 320x240 at 1 frame per second :-) I know, nobody cares, but still it is cool that linux can still support this old webcam. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] V4L2 spec fixHans Verkuil
Two small docbook fixes: - prepare-buf was not positioned in alphabetical order, moved to the right place. - the format field in create_bufs had the wrong type in the documentation Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-11[media] v4l: Correct create_bufs documentationSakari Ailus
Patch id 6016af82eafcb6e086a8f2a2197b46029a843d68 ("[media] v4l2: use __u32 rather than enums in ioctl() structs") unintentionally changes the type of the format field in struct v4l2_create_buffers from struct v4l2_format to __u32. Revert that change. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-06-06stmmac: update driver's docGiuseppe CAVALLARO
Fixed the driver's documentation that was obsolete and didn't report new platform fields (recently added). Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-05Merge branch 'i2c-embedded/for-current' of ↵Linus Torvalds
git://git.pengutronix.de/git/wsa/linux Pull embedded i2c update from Wolfram Sang: "This only contains one new driver which had multiple dependencies (pinctrl, i2c-mux-rework, new devm_* functions), so I decided to wait for rc1. Plus, it had to wait a little for the ack of a devicetree maintainer since the bindings were not trivial enough for me to pass through. So, given that, I hope there is still something like the "new driver rule", so we could have the driver in 3.5 and people can start using it. That would make merging support for some boards easier for 3.6 since the dependency on this driver is gone then." * 'i2c-embedded/for-current' of git://git.pengutronix.de/git/wsa/linux: i2c: Add generic I2C multiplexer using pinctrl API
2012-06-05mtip32xx: Remove 'registers' and 'flags' from sysfsAsai Thambi S P
This patch removes entries 'registers' and 'flags' from sysfs. Updated ABI file to reflect this change. Reported-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-06-04iio: documentation: Add out_altvoltage and friendsMichael Hennerich
Continuous frequency/clock generating devices, such as DDSs or PLLs should use out_altvoltage. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-04Merge tag 'stable/frontswap.v16-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap feature from Konrad Rzeszutek Wilk: "Frontswap provides a "transcendent memory" interface for swap pages. In some environments, dramatic performance savings may be obtained because swapped pages are saved in RAM (or a RAM-like device) instead of a swap disk. This tag provides the basic infrastructure along with some changes to the existing backends." Fix up trivial conflict in mm/Makefile due to removal of swap token code changing a line next to the new frontswap entry. This pull request came in before the merge window even opened, it got delayed to after the merge window by me just wanting to make sure it had actual users. Apparently IBM is using this on their embedded side, and Jan Beulich says that it's already made available for SLES and OpenSUSE users. Also acked by Rik van Riel, and Konrad points to other people liking it too. So in it goes. By Dan Magenheimer (4) and Konrad Rzeszutek Wilk (2) via Konrad Rzeszutek Wilk * tag 'stable/frontswap.v16-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: frontswap: s/put_page/store/g s/get_page/load MAINTAINER: Add myself for the frontswap API mm: frontswap: config and doc files mm: frontswap: core frontswap functionality mm: frontswap: core swap subsystem hooks and headers mm: frontswap: add frontswap header file
2012-06-04Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "The clocksource driver is pure hardware enablement and the skew option is default off, well tested and non dangerous." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: Move skew_tick option into the HIGH_RES_TIMER section clocksource: em_sti: Add DT support clocksource: em_sti: Emma Mobile STI driver clockevents: Make clockevents_config() a global symbol tick: Add tick skew boot option
2012-06-04i2c: Add generic I2C multiplexer using pinctrl APIStephen Warren
This is useful for SoCs whose I2C module's signals can be routed to different sets of pins at run-time, using the pinctrl API. +-----+ +-----+ | dev | | dev | +------------------------+ +-----+ +-----+ | SoC | | | | /----|------+--------+ | +---+ +------+ | child bus A, on first set of pins | |I2C|---|Pinmux| | | +---+ +------+ | child bus B, on second set of pins | \----|------+--------+--------+ | | | | | +------------------------+ +-----+ +-----+ +-----+ | dev | | dev | | dev | +-----+ +-----+ +-----+ Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-06-02Merge tag 'dm-3.5-changes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper updates from Alasdair G Kergon: "Improve multipath's retrying mechanism in some defined circumstances and provide a simple reserve/release mechanism for userspace tools to access thin provisioning metadata while the pool is in use." * tag 'dm-3.5-changes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: dm thin: provide userspace access to pool metadata dm thin: use slab mempools dm mpath: allow ioctls to trigger pg init dm mpath: delay retry of bypassed pg dm mpath: reduce size of struct multipath
2012-06-03dm thin: provide userspace access to pool metadataJoe Thornber
This patch implements two new messages that can be sent to the thin pool target allowing it to take a snapshot of the _metadata_. This, read-only snapshot can be accessed by userland, concurrently with the live target. Only one metadata snapshot can be held at a time. The pool's status line will give the block location for the current msnap. Since version 0.1.5 of the userland thin provisioning tools, the thin_dump program displays the msnap as follows: thin_dump -m <msnap root> <metadata dev> Available here: https://github.com/jthornber/thin-provisioning-tools Now that userland can access the metadata we can do various things that have traditionally been kernel side tasks: i) Incremental backups. By using metadata snapshots we can work out what blocks have changed over time. Combined with data snapshots we can ensure the data doesn't change while we back it up. A short proof of concept script can be found here: https://github.com/jthornber/thinp-test-suite/blob/master/incremental_backup_example.rb ii) Migration of thin devices from one pool to another. iii) Merging snapshots back into an external origin. iv) Asyncronous replication. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-06-02Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull straggler x86 fixes from Peter Anvin: "Three groups of patches: - EFI boot stub documentation and the ability to print error messages; - Removal for PTRACE_ARCH_PRCTL for x32 (obsolete interface which should never have been ported, and the port is broken and potentially dangerous.) - ftrace stack corruption fixes. I'm not super-happy about the technical implementation, but it is probably the least invasive in the short term. In the future I would like a single method for nesting the debug stack, however." * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, x32, ptrace: Remove PTRACE_ARCH_PRCTL for x32 x86, efi: Add EFI boot stub documentation x86, efi; Add EFI boot stub console support x86, efi: Only close open files in error path ftrace/x86: Do not change stacks in DEBUG when calling lockdep x86: Allow nesting of the debug stack IDT setting x86: Reset the debug_stack update counter ftrace: Use breakpoint method to update ftrace caller ftrace: Synchronize variable setting with breakpoints
2012-06-01Merge tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: - driver for AUO-K1900 and AUO-K1901 epaper controller - large updates for OMAP (e.g. decouple HDMI audio and video) - some updates for Exynos and SH Mobile - various other small fixes and cleanups * tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits) video: bfin_adv7393fb: Fix cleanup code video: exynos_dp: reduce delay time when configuring video setting video: exynos_dp: move sw reset prioir to enabling sw defined function video: exynos_dp: use devm_ functions fb: handle NULL pointers in framebuffer release OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request OMAPDSS: Apply VENC timings even if panel is disabled OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC OMAPDSS: DISPC: Support rotation through TILER OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n OMAPFB: remove compiler warnings when CONFIG_BUG=n OMAPDSS: remove compiler warnings when CONFIG_BUG=n OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods OMAPDSS: DISPC: Update Accumulator configuration for chroma plane drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers video: exynos mipi dsi: support reverse panel type video: exynos mipi dsi: Properly interpret the interrupt source flags video: exynos mipi dsi: Avoid races in probe() ...
2012-06-01Merge tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd update from David Woodhouse: - More robust parsing especially of xattr data in JFFS2 - Updates to mxc_nand and gpmi drivers to support new boards and device tree - Improve consistency of information about ECC strength in NAND devices - Clean up partition handling of plat_nand - Support NAND drivers without dedicated access to OOB area - BCH hardware ECC support for OMAP - Other fixes and cleanups, and a few new device IDs Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to added include files next to each other. * tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits) mtd: mxc_nand: move ecc strengh setup before nand_scan_tail mtd: block2mtd: fix recursive call of mtd_writev mtd: gpmi-nand: define ecc.strength mtd: of_parts: fix breakage in Kconfig mtd: nand: fix scan_read_raw_oob mtd: docg3 fix in-middle of blocks reads mtd: cfi_cmdset_0002: Slight cleanup of fixup messages mtd: add fixup for S29NS512P NOR flash. jffs2: allow to complete xattr integrity check on first GC scan jffs2: allow to discriminate between recoverable and non-recoverable errors mtd: nand: omap: add support for hardware BCH ecc ARM: OMAP3: gpmc: add BCH ecc api and modes mtd: nand: check the return code of 'read_oob/read_oob_raw' mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw' mtd: m25p80: Add support for Winbond W25Q80BW jffs2: get rid of jffs2_sync_super jffs2: remove unnecessary GC pass on sync jffs2: remove unnecessary GC pass on umount jffs2: remove lock_super mtd: gpmi: add gpmi support for mx6q ...
2012-06-01Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull slab updates from Pekka Enberg: "Mainly a bunch of SLUB fixes from Joonsoo Kim" * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slub: use __SetPageSlab function to set PG_slab flag slub: fix a memory leak in get_partial_node() slub: remove unused argument of init_kmem_cache_node() slub: fix a possible memory leak Documentations: Fix slabinfo.c directory in vm/slub.txt slub: fix incorrect return type of get_any_partial()
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-06-01x86, efi: Add EFI boot stub documentationMatt Fleming
Since we can't expect every user to read the EFI boot stub code it seems prudent to have a couple of paragraphs explaining what it is and how it works. The "initrd=" option in particular is tricky because it only understands absolute EFI-style paths (backslashes as directory separators), and until now this hasn't been documented anywhere. This has tripped up a couple of users. Cc: Matthew Garrett <mjg@redhat.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Link: http://lkml.kernel.org/r/1331907517-3985-4-git-send-email-matt@console-pimps.org Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-01fs: introduce inode operation ->update_timeJosef Bacik
Btrfs has to make sure we have space to allocate new blocks in order to modify the inode, so updating time can fail. We've gotten around this by having our own file_update_time but this is kind of a pain, and Christoph has indicated he would like to make xfs do something different with atime updates. So introduce ->update_time, where we will deal with i_version an a/m/c time updates and indicate which changes need to be made. The normal version just does what it has always done, updates the time and marks the inode dirty, and then filesystems can choose to do something different. I've gone through all of the users of file_update_time and made them check for errors with the exception of the fault code since it's complicated and I wasn't quite sure what to do there, also Jan is going to be pushing the file time updates into page_mkwrite for those who have it so that should satisfy btrfs and make it not a big deal to check the file_update_time() return code in the generic fault path. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
