path: root/Documentation
2014-06-15Merge tag 'clk-for-linus-3.16-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework updates from Mike Turquette: "This contains the second half the of the clk changes for 3.16. They are simply fixes and code refactoring for the OMAP clock drivers. The sunxi clock driver changes include splitting out the one mega-driver into several smaller pieces and adding support for the A31 SoC clocks" * tag 'clk-for-linus-3.16-part2' of git://git.linaro.org/people/mike.turquette/linux: (25 commits) clk: sunxi: document PRCM clock compatible strings clk: sunxi: add PRCM (Power/Reset/Clock Management) clks support clk: sun6i: Protect SDRAM gating bit clk: sun6i: Protect CPU clock clk: sunxi: Rework clock protection code clk: sunxi: Move the GMAC clock to a file of its own clk: sunxi: Move the 24M oscillator to a file of its own clk: sunxi: Remove calls to clk_put clk: sunxi: document new A31 USB clock compatible clk: sunxi: Implement A31 USB clock ARM: dts: OMAP5/DRA7: use omap5-mpu-dpll-clock capable of dealing with higher frequencies CLK: TI: dpll: support OMAP5 MPU DPLL that need special handling for higher frequencies ARM: OMAP5+: dpll: support Duty Cycle Correction(DCC) CLK: TI: clk-54xx: Set the rate for dpll_abe_m2x2_ck CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic) dt:/bindings: DRA7 ATL (Audio Tracking Logic) clock bindings ARM: dts: dra7xx-clocks: Correct name for atl clkin3 clock CLK: TI: gate: add composite interface clock to OMAP2 only build ARM: OMAP2: clock: add DT boot support for cpufreq_ck CLK: TI: OMAP2: add clock init support ...
2014-06-14Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 vdso fixes from Peter Anvin: "Fixes for x86/vdso. One is a simple build fix for bigendian hosts, one is to make "make vdso_install" work again, and the rest is about working around a bug in Google's Go language -- two are documentation patches that improves the sample code that the Go coders took, modified, and broke; the other two implements a workaround that keeps existing Go binaries from segfaulting at least" * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vdso: Fix vdso_install x86/vdso: Hack to keep 64-bit Go programs working x86/vdso: Add PUT_LE to store little-endian values x86/vdso/doc: Make vDSO examples more portable x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.c x86, vdso: Remove one final use of htole16()
2014-06-14Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: - new driver for Sensirion SHTC1 humidity / temperature sensor - convert ltc4151 and vexpress drivers to use devm functions - drop generic chip detection from lm85 driver - avoid forward declarations in atxp1 driver - fix sign extensions in ina2xx driver * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: vexpress: Use devm helper for hwmon device registration hwmon: (atxp1) Avoid forward declaration hwmon: add support for Sensirion SHTC1 sensor hwmon: (ltc4151) Convert to devm_hwmon_device_register_with_groups hwmon: (lm85) Drop generic detection hwmon: (ina2xx) Cast to s16 on shunt and current regs
2014-06-12Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild misc updates from Michal Marek: "This is the non-critical part of kbuild for v3.16-rc1: - make deb-pkg can do s390x and arm64 - new patterns in scripts/tags.sh - scripts/tags.sh skips userspace tools' sources (which sometimes have copies of kernel structures) and symlinks - improvements to the objdiff tool - two new coccinelle patches - other minor fixes" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts: objdiff: support directories for the augument of record command scripts: objdiff: fix a comment scripts: objdiff: change the extension of disassembly from .o to .dis scripts: objdiff: improve path flexibility for record command scripts: objdiff: remove unnecessary code scripts: objdiff: direct error messages to stderr scripts: objdiff: get the path to .tmp_objdiff more simply deb-pkg: Add automatic support for s390x architecture coccicheck: Add unneeded return variable test kbuild: Fix a typo in documentation kbuild: trivial - use tabs for code indent where possible kbuild: trivial - remove trailing empty lines coccinelle: Check for missing NULL terminators in of_device_id tables scripts/tags.sh: ignore symlink'ed source files scripts/tags.sh: add regular expression replacement pattern for memcg builddeb: add arm64 in the supported architectures builddeb: use $OBJCOPY variable instead of objcopy scripts/tags.sh: ignore code of user space tools scripts/tags.sh: add pattern for DEFINE_HASHTABLE .gitignore: ignore Module.symvers in all directories
2014-06-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second round of perf updates: - wide reaching kprobes sanitization and robustization, with the hope of fixing all 'probe this function crashes the kernel' bugs, by Masami Hiramatsu. - uprobes updates from Oleg Nesterov: tmpfs support, corner case fixes and robustization work. - perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo et al: * Add support to accumulate hist periods (Namhyung Kim) * various fixes, refactorings and enhancements" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits) perf: Differentiate exec() and non-exec() comm events perf: Fix perf_event_comm() vs. exec() assumption uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates perf/documentation: Add description for conditional branch filter perf/x86: Add conditional branch filtering support perf/tool: Add conditional branch filter 'cond' to perf record perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND' uprobes: Teach copy_insn() to support tmpfs uprobes: Shift ->readpage check from __copy_insn() to uprobe_register() perf/x86: Use common PMU interrupt disabled code perf/ARM: Use common PMU interrupt disabled code perf: Disable sampled events if no PMU interrupt perf: Fix use after free in perf_remove_from_context() perf tools: Fix 'make help' message error perf record: Fix poll return value propagation perf tools: Move elide bool into perf_hpp_fmt struct perf tools: Remove elide setup for SORT_MODE__MEMORY mode perf tools: Fix "==" into "=" in ui_browser__warning assignment perf tools: Allow overriding sysfs and proc finding with env var perf tools: Consider header files outside perf directory in tags target ...
2014-06-12x86/vdso/doc: Make vDSO examples more portableAndy Lutomirski
This adds a new vdso_test.c that's written entirely in C. It also makes all of the vDSO examples work on 32-bit x86. Cc: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/62b701fc44b79f118ac2b2d64d19965fc5c291fb.1402620737.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-06-12x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.cAndy Lutomirski
This thing is hopelessly x86_64-specific: it's an example of how to access the vDSO without any runtime support at all. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/3efc170e0e166e15f0150c9fdb37d52488b9c0a4.1402620737.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-06-12Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more locking changes from Ingo Molnar: "This is the second round of locking tree updates for v3.16, offering large system scalability improvements: - optimistic spinning for rwsems, from Davidlohr Bueso. - 'qrwlocks' core code and x86 enablement, from Waiman Long and PeterZ" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, locking/rwlocks: Enable qrwlocks on x86 locking/rwlocks: Introduce 'qrwlocks' - fair, queued rwlocks locking/mutexes: Documentation update/rewrite locking/rwsem: Fix checkpatch.pl warnings locking/rwsem: Fix warnings for CONFIG_RWSEM_GENERIC_SPINLOCK locking/rwsem: Support optimistic spinning
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-12Merge tag 'pci-v3.16-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull more PCI updates from Bjorn Helgaas: "Here are some more things I'd like to see in v3.16-rc1: - DMA alias iterator, part of some work to fix IOMMU issues - MVEBU, Tegra, DesignWare changes that I forgot to include before - Some whitespace code cleanup Details: IOMMU - Add DMA alias iterator (Alex Williamson) - Add DMA alias quirks for ASMedia, ITE, Tundra bridges (Alex Williamson) - Add DMA alias quirks for Marvell, Ricoh devices (Alex Williamson) - Add DMA alias quirk for HighPoint devices (Jérôme Carretero) MSI - Fix leak in free_msi_irqs() (Alexei Starovoitov) Marvell MVEBU - Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray) - Avoid setting an undefined window size (Jason Gunthorpe) - Allow several windows with the same target/attribute (Thomas Petazzoni) - Split PCIe BARs into multiple MBus windows when needed (Thomas Petazzoni) - Fix off-by-one in the computed size of the mbus windows (Willy Tarreau) NVIDIA Tegra - Use new OF interrupt mapping when possible (Lucas Stach) Synopsys DesignWare - Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray) - Use new OF interrupt mapping when possible (Lucas Stach) - Split Exynos and i.MX bindings (Lucas Stach) - Fix comment for setting number of lanes (Mohit Kumar) - Fix iATU programming for cfg1, io and mem viewport (Mohit Kumar) Miscellaneous - EXPORT_SYMBOL cleanup (Ryan Desfosses) - Whitespace cleanup (Ryan Desfosses) - Merge multi-line quoted strings (Ryan Desfosses)" * tag 'pci-v3.16-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (21 commits) PCI: Add function 1 DMA alias quirk for HighPoint RocketRaid 642L PCI/MSI: Fix memory leak in free_msi_irqs() PCI: Merge multi-line quoted strings PCI: Whitespace cleanup PCI: Move EXPORT_SYMBOL so it immediately follows function/variable PCI: Add bridge DMA alias quirk for ITE bridge PCI: designware: Split Exynos and i.MX bindings PCI: Add bridge DMA alias quirk for ASMedia and Tundra bridges PCI: Add support for PCIe-to-PCI bridge DMA alias quirks PCI: Add function 1 DMA alias quirk for Marvell devices PCI: Add function 0 DMA alias quirk for Ricoh devices PCI: Add support for DMA alias quirks PCI: Convert pci_dev_flags definitions to bit shifts PCI: Add DMA alias iterator PCI: mvebu: Use '%pa' for printing 'phys_addr_t' type PCI: mvebu: Remove unnecessary use of 'conf_lock' spinlock PCI: designware: Remove unnecessary use of 'conf_lock' spinlock PCI: designware: Use new OF interrupt mapping when possible PCI: designware: Fix iATU programming for cfg1, io and mem viewport PCI: designware: Fix comment for setting number of lanes ...
2014-06-12Merge tag 'pm+acpi-3.16-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are fixups on top of the previous PM+ACPI pull request, regression fixes (ACPI hotplug, cpufreq ppc-corenet), other bug fixes (ACPI reset, cpufreq), new PM trace points for system suspend profiling and a copyright notice update. Specifics: - I didn't remember correctly that the Hans de Goede's ACPI video patches actually didn't flip the video.use_native_backlight default, although we had discussed that and decided to do that. Since I said we would do that in the previous PM+ACPI pull request, make that change for real now. - ACPI bus check notifications for PCI host bridges don't cause the bus below the host bridge to be checked for changes as they should because of a mistake in the ACPI-based PCI hotplug (ACPIPHP) subsystem that forgets to add hotplug contexts to PCI host bridge ACPI device objects. Create hotplug contexts for PCI host bridges too as appropriate. - Revert recent cpufreq commit related to the big.LITTLE cpufreq driver that breaks arm64 builds. - Fix for a regression in the ppc-corenet cpufreq driver introduced during the 3.15 cycle and causing the driver to use the remainder from do_div instead of the quotient. From Ed Swarthout. - Resets triggered by panic activate a BUG_ON() in vmalloc.c on systems where the ACPI reset register is located in memory address space. Fix from Randy Wright. - Fix for a problem with cpufreq governors that decisions made by them may be suboptimal due to the fact that deferrable timers are used by them for CPU load sampling. From Srivatsa S Bhat. - Fix for a problem with the Tegra cpufreq driver where the CPU frequency is temporarily switched to a "stable" level that is different from both the initial and target frequencies during transitions which causes udelay() to expire earlier than it should sometimes. From Viresh Kumar. - New trace points and rework of some existing trace points for system suspend/resume profiling from Todd Brandt. - Assorted cpufreq fixes and cleanups from Stratos Karafotis and Viresh Kumar. - Copyright notice update for suspend-and-cpuhotplug.txt from Srivatsa S Bhat" * tag 'pm+acpi-3.16-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / hotplug / PCI: Add hotplug contexts to PCI host bridges PM / sleep: trace events for device PM callbacks cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR cpufreq: tegra: update comment for clarity cpufreq: intel_pstate: Remove duplicate CPU ID check cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag PM / Documentation: Update copyright in suspend-and-cpuhotplug.txt cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info' cpufreq: governor: Be friendly towards latency-sensitive bursty workloads PM / sleep: trace events for suspend/resume cpufreq: ppc-corenet-cpu-freq: do_div use quotient Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64" cpufreq: Tegra: implement intermediate frequency callbacks cpufreq: add support for intermediate (stable) frequencies ACPI / video: Change the default for video.use_native_backlight to 1 ACPI: Fix bug when ACPI reset register is implemented in system memory
2014-06-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED updates from Bryan Wu: "I just found merge window is open and I'm quite busy and almost forget to send out this pull request. Thanks Russell and Alexandre ping me about this. So basically we got some clean up and leds-pwm fixing patches from Russell" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: Remove duplicated OOM message for individual driver drivers/leds: Replace __get_cpu_var use through this_cpu_ptr leds: lp55xx: add DT bindings for LP55231 leds: 88pm860x: Fix missing refcount decrement for parent of_node leds: 88pm860x: Use of_get_child_by_name leds: leds-pwm: add DT support for LEDs wired to supply leds: leds-pwm: implement PWM inversion leds: leds-pwm: convert OF parsing code to use led_pwm_add() leds: leds-pwm: provide a common function to setup a single led-pwm device leds: pca9685: Remove leds-pca9685 driver dell-led: add mic mute led interface
2014-06-12Merge tag 'mfd-for-linus-3.16-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull more MFD updates from Lee Jones: "I missed collecting these patches due to a branch/tag naming ambiguity. Completely my own fault, as I mindlessly named a branch and tag identically. Sorry for the fuss. This pull-request contains some misplaced patches from Tony Lindgren that should have been part of the initial one" * tag 'mfd-for-linus-3.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle mfd: twl4030-power: Add support for board specific configuration mfd: twl4030-power: Add recommended idle configuration mfd: twl4030-power: Add generic reset configuration mfd: twl4030-power: Fix some defines for SW_EVENTS mfd: twl4030-power: Fix hang on reboot if sleep configuration was loaded earlier
2014-06-12Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm merge window pull request, changes all over the place, mostly normal levels of churn. Highlights: Core drm: More cleanups, fix race on connector/encoder naming, docs updates, object locking rework in prep for atomic modeset i915: mipi DSI support, valleyview power fixes, cursor size fixes, execlist refactoring, vblank improvements, userptr support, OOM handling improvements radeon: GPUVM tuning and large page size support, gart fixes, deep color HDMI support, HDMI audio cleanups nouveau: - displayport rework should fix lots of issues - initial gk20a support - gk110b support - gk208 fixes exynos: probe order fixes, HDMI changes, IPP consolidation msm: debugfs updates, misc fixes ast: ast2400 support, sync with UMS driver tegra: cleanups, hdmi + hw cursor for Tegra 124. panel: fixes existing panels add some new ones. ipuv3: moved from staging to drivers/gpu" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits) drm/nouveau/disp/dp: fix tmds passthrough on dp connector drm/nouveau/dp: probe dpcd to determine connectedness drm/nv50-: trigger update after all connectors disabled drm/nv50-: prepare for attaching a SOR to multiple heads drm/gf119-/disp: fix debug output on update failure drm/nouveau/disp/dp: make use of postcursor when its available drm/g94-/disp/dp: take max pullup value across all lanes drm/nouveau/bios/dp: parse lane postcursor data drm/nouveau/dp: fix support for dpms drm/nouveau: register a drm_dp_aux channel for each dp connector drm/g94-/disp: add method to power-off dp lanes drm/nouveau/disp/dp: maintain link in response to hpd signal drm/g94-/disp: bash and wait for something after changing lane power regs drm/nouveau/disp/dp: split link config/power into two steps drm/nv50/disp: train PIOR-attached DP from second supervisor drm/nouveau/disp/dp: make use of existing output data for link training drm/gf119/disp: start removing direct vbios parsing from supervisor drm/nv50/disp: start removing direct vbios parsing from supervisor drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal drm/nouveau/disp/dp: create subclass for dp outputs ...
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-12hwmon: add support for Sensirion SHTC1 sensorTomas Pop
Add support for Sensirion SHTC1 and compatible temperature and humidity sensors. Signed-off-by: Tomas Pop <tomas.pop@sensirion.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-12Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR cpufreq: tegra: update comment for clarity cpufreq: intel_pstate: Remove duplicate CPU ID check cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info' cpufreq: governor: Be friendly towards latency-sensitive bursty workloads cpufreq: ppc-corenet-cpu-freq: do_div use quotient Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64" cpufreq: Tegra: implement intermediate frequency callbacks cpufreq: add support for intermediate (stable) frequencies
2014-06-12Merge commit '9f12600fe425bc28f0ccba034a77783c09c15af4' into for-linusAl Viro
Backmerge of dcache.c changes from mainline. It's that, or complete rebase... Conflicts: fs/splice.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-06-11Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Most of this is cleaning up various driver sysfs permissions so we can re-add the perm check (we unified the module param and sysfs checks, but the module ones were stronger so we weakened them temporarily). Param parsing gets documented, and also "--" now forces args to be handed to init (and ignored by the kernel). Module NX/RO protections get tightened: we now set them before calling parse_args()" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: set nx before marking module MODULE_STATE_COMING. samples/kobject/: avoid world-writable sysfs files. drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files. drivers/staging/speakup/: avoid world-writable sysfs files. drivers/regulator/virtual: avoid world-writable sysfs files. drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files. drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files. drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files. drivers/mtd/devices/docg3.c: avoid world-writable sysfs files. speakup: fix incorrect perms on speakup_acntsa.c cpumask.h: silence warning with -Wsign-compare Documentation: Update kernel-parameters.tx param: hand arguments after -- straight to init modpost: Fix resource leak in read_dump()
2014-06-11net: filter: document internal instruction encodingAlexei Starovoitov
This patch adds a description of eBPFs instruction encoding in order to bring the documentation in line with the implementation. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-11net: filter: mention eBPF terminology as wellAlexei Starovoitov
Since the term eBPF is used anyway on mailing list discussions, lets also document that in the main BPF documentation file and replace a couple of occurrences with eBPF terminology to be more clear. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management update from Zhang Rui: "Specifics: - fix a bug in Exynos thermal driver, which overwrites the hardware trip point threshold when updating software trigger levels and results in emergency shutdown. From: Tushar Behera. - add thermal sensor support for Armada 375 and 38x SoCs. From Ezequiel Garcia. - add TMU (Thermal Management Unit) support for Exynos5260 and Exynos5420 SoCs. From Naveen Krishna Chatradhi. - add support for the additional digital temperature sensors in the Intel SoCs like Bay Trail. From: Srinivas Pandruvada. - a couple of cleanups and small fixes from Jingoo Han, Bartlomiej Zolnierkiewicz, Geert Uytterhoeven, Jacob Pan, Paul Walmsley and Lan,Tianyu" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (21 commits) thermal: spear: remove unnecessary OOM messages thermal: exynos: remove unnecessary OOM messages thermal: rcar: remove unnecessary OOM messages thermal: armada: Support Armada 380 SoC thermal: armada: Support Armada 375 SoC thermal: armada: Allow to specify an 'inverted readout' sensor thermal: armada: Pass the platform_device to init_sensor() thermal: armada: Add generic infrastructure to handle the sensor thermal: armada: Add infrastructure to support generic formulas thermal: armada: Rename armada_thermal_ops struct thermal/intel_powerclamp: add newer cpu ids thermal: rcar: Use pm_runtime_put() i.s.o. pm_runtime_put_sync() thermal: samsung: Only update available threshold limits Thermal/int3403: Fix thermal hysteresis unit conversion thermal: Intel SoC DTS thermal thermal: samsung: Add TMU support for Exynos5260 SoCs thermal: samsung: Add TMU support for Exynos5420 SoCs thermal: samsung: change base_common to more meaningful base_second thermal: samsung: replace inten_ bit fields with intclr_ thermal: offer Samsung thermal support only when ARCH_EXYNOS is defined ...
2014-06-11Merge tag 'pwm/for-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "The majority of these changes are cleanups and fixes across all drivers. Redundant error messages are removed and more PWM controllers set the .can_sleep flag to signal that they can't be used in atomic context. Support is added for the Broadcom Kona family of SoCs and the Intel LPSS driver can now probe PCI devices in addition to ACPI devices. Upon shutdown, the pwm-backlight driver will now power off the backlight. It also uses the new descriptor-based GPIO API for more concise GPIO handling. A large chunk of these changes also converts platforms to use the lookup mechanism rather than relying on the global number space to reference PWM devices. This is largely in preparation for more unification and cleanups in future patches. Eventually it will allow the legacy PWM API to be removed" * tag 'pwm/for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (38 commits) pwm: fsl-ftm: set pwm_chip can_sleep flag pwm: ab8500: Fix wrong value shift for disable/enable PWM pwm: samsung: do not set manual update bit in pwm_samsung_config pwm: lp3943: Set pwm_chip can_sleep flag pwm: atmel: set pwm_chip can_sleep flag pwm: mxs: set pwm_chip can_sleep flag pwm: tiehrpwm: inline accessor functions pwm: tiehrpwm: don't build PM related functions when not needed pwm-backlight: retrieve configured PWM period leds: leds-pwm: retrieve configured PWM period ARM: pxa: hx4700: use PWM_LOOKUP to initialize struct pwm_lookup ARM: shmobile: armadillo: use PWM_LOOKUP to initialize struct pwm_lookup ARM: OMAP3: Beagle: use PWM_LOOKUP to initialize struct pwm_lookup pwm: modify PWM_LOOKUP to initialize all struct pwm_lookup members ARM: pxa: hx4700: initialize all the struct pwm_lookup members ARM: OMAP3: Beagle: initialize all the struct pwm_lookup members pwm: renesas-tpu: remove unused struct tpu_pwm_platform_data ARM: shmobile: armadillo: initialize all struct pwm_lookup members pwm: add period and polarity to struct pwm_lookup pwm: twl: Really disable twl6030 PWMs ...
2014-06-11Merge tag 'for-linus-20140610' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: - refactor m25p80.c driver for use as a general SPI NOR framework for other drivers which may speak to SPI NOR flash without providing full SPI support (i.e., not part of drivers/spi/) - new Freescale QuadSPI driver (utilizing new SPI NOR framework) - updates for the STMicro "FSM" SPI NOR driver - fix sync/flush behavior on mtd_blkdevs - fixup subpage write support on a few NAND drivers - correct the MTD OOB test for odd-sized OOB areas - add BCH-16 support for OMAP NAND - fix warnings and trivial refactoring - utilize new ECC DT bindings in pxa3xx NAND driver - new LPDDR NVM driver - address a few assorted bugs caught by Coverity - add new imx6sx support for GPMI NAND - use a bounce buffer for NAND when non-DMA-able buffers are used * tag 'for-linus-20140610' of git://git.infradead.org/linux-mtd: (77 commits) mtd: gpmi: add gpmi support for imx6sx mtd: maps: remove check for CONFIG_MTD_SUPERH_RESERVE mtd: bf5xx_nand: use the managed version of kzalloc mtd: pxa3xx_nand: make the driver work on big-endian systems mtd: nand: omap: fix omap_calculate_ecc_bch() for-loop error mtd: nand: r852: correct write_buf loop bounds mtd: nand_bbt: handle error case for nand_create_badblock_pattern() mtd: nand_bbt: remove unused variable mtd: maps: sc520cdp: fix warnings mtd: slram: fix unused variable warning mtd: pfow: remove unused variable mtd: lpddr: fix Kconfig dependency, for I/O accessors mtd: nand: pxa3xx: Add supported ECC strength and step size to the DT binding mtd: nand: pxa3xx: Use ECC strength and step size devicetree binding mtd: nand: pxa3xx: Clean pxa_ecc_init() error handling mtd: nand: Warn the user if the selected ECC strength is too weak mtd: nand: omap: Documentation: How to select correct ECC scheme for your device ? mtd: nand: omap: add support for BCH16_ECC - NAND driver updates mtd: nand: omap: add support for BCH16_ECC - ELM driver updates mtd: nand: omap: add support for BCH16_ECC - GPMC driver updates ...
2014-06-11clk: sunxi: document PRCM clock compatible stringsBoris BREZILLON
Document new compatible strings for clock provided by the PRCM (Power/Reset/Clock Management) unit. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Emilio López <emilio@elopez.com.ar>
2014-06-11clk: sunxi: document new A31 USB clock compatibleEmilio López
Support for the USB gates and resets on A31 has been recently added using a new compatible, so let's document it here. Signed-off-by: Emilio López <emilio@elopez.com.ar>
2014-06-11net: filter: cleanup A/X name usageAlexei Starovoitov
The macro 'A' used in internal BPF interpreter: #define A regs[insn->a_reg] was easily confused with the name of classic BPF register 'A', since 'A' would mean two different things depending on context. This patch is trying to clean up the naming and clarify its usage in the following way: - A and X are names of two classic BPF registers - BPF_REG_A denotes internal BPF register R0 used to map classic register A in internal BPF programs generated from classic - BPF_REG_X denotes internal BPF register R7 used to map classic register X in internal BPF programs generated from classic - internal BPF instruction format: struct sock_filter_int { __u8 code; /* opcode */ __u8 dst_reg:4; /* dest register */ __u8 src_reg:4; /* source register */ __s16 off; /* signed offset */ __s32 imm; /* signed immediate constant */ }; - BPF_X/BPF_K is 1 bit used to encode source operand of instruction In classic: BPF_X - means use register X as source operand BPF_K - means use 32-bit immediate as source operand In internal: BPF_X - means use 'src_reg' register as source operand BPF_K - means use 32-bit immediate as source operand Suggested-by: Chema Gonzalez <chema@google.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Chema Gonzalez <chema@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-10Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - addition of the Intel MID watchdog - removal of W83697HF and W83697UG drivers (code was merged into w83627hf_wdt driver) - addition of Armada 375/380 SoC support - conversion of imx2_wdt to regmap API and to watchdog core API - lots of other small improvements and fixes" [ Wim was also tagged by gmail as a spammer, but not delayed by days unlike Ben ] * git://www.linux-watchdog.org/linux-watchdog: (25 commits) x86: intel-mid: add watchdog platform code for Merrifield watchdog: add Intel MID watchdog driver support watchdog: sp805: Set watchdog_device->timeout from ->set_timeout() booke/watchdog: refine and clean up the codes watchdog: iop_wdt only builds for mach-iop13xx watchdog: Remove drivers for W83697HF and W83697UG watchdog: w83627hf_wdt: Add early_disable module parameter ARM: mvebu: Add A375/A380 watchdog binding documentation watchdog: orion: Add Armada 375/380 SoC support watchdog: orion: Introduce per-SoC enabled() function watchdog: orion: Introduce per-SoC stop() function watchdog: orion: Remove unneeded atomic access watchdog: orion: Introduce a SoC-specific RSTOUT mapping watchdog: orion: Move the register ioremap'ing to its own function watchdog: xilinx: Make of_device_id array const watchdog: imx2_wdt: convert to watchdog core api watchdog: imx2_wdt: convert to use regmap API. watchdog: imx2_wdt: Sort the header files alphabetically watchdog: ath79_wdt: switch to clk_prepare/clk_disable watchdog: ath79_wdt: avoid spurious restarts on AR934x ...
2014-06-10Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "Here is the bulk of the powerpc changes for this merge window. It got a bit delayed in part because I wasn't paying attention, and in part because I discovered I had a core PCI change without a PCI maintainer ack in it. Bjorn eventually agreed it was ok to merge it though we'll probably improve it later and I didn't want to rebase to add his ack. There is going to be a bit more next week, essentially fixes that I still want to sort through and test. The biggest item this time is the support to build the ppc64 LE kernel with our new v2 ABI. We previously supported v2 userspace but the kernel itself was a tougher nut to crack. This is now sorted mostly thanks to Anton and Rusty. We also have a fairly big series from Cedric that add support for 64-bit LE zImage boot wrapper. This was made harder by the fact that traditionally our zImage wrapper was always 32-bit, but our new LE toolchains don't really support 32-bit anymore (it's somewhat there but not really "supported") so we didn't want to rely on it. This meant more churn that just endian fixes. This brings some more LE bits as well, such as the ability to run in LE mode without a hypervisor (ie. under OPAL firmware) by doing the right OPAL call to reinitialize the CPU to take HV interrupts in the right mode and the usual pile of endian fixes. There's another series from Gavin adding EEH improvements (one day we *will* have a release with less than 20 EEH patches, I promise!). Another highlight is the support for the "Split core" functionality on P8 by Michael. This allows a P8 core to be split into "sub cores" of 4 threads which allows the subcores to run different guests under KVM (the HW still doesn't support a partition per thread). And then the usual misc bits and fixes ..." [ Further delayed by gmail deciding that BenH is a dirty spammer. Google knows. ] * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (155 commits) powerpc/powernv: Add missing include to LPC code selftests/powerpc: Test the THP bug we fixed in the previous commit powerpc/mm: Check paca psize is up to date for huge mappings powerpc/powernv: Pass buffer size to OPAL validate flash call powerpc/pseries: hcall functions are exported to modules, need _GLOBAL_TOC() powerpc: Exported functions __clear_user and copy_page use r2 so need _GLOBAL_TOC() powerpc/powernv: Set memory_block_size_bytes to 256MB powerpc: Allow ppc_md platform hook to override memory_block_size_bytes powerpc/powernv: Fix endian issues in memory error handling code powerpc/eeh: Skip eeh sysfs when eeh is disabled powerpc: 64bit sendfile is capped at 2GB powerpc/powernv: Provide debugfs access to the LPC bus via OPAL powerpc/serial: Use saner flags when creating legacy ports powerpc: Add cpu family documentation powerpc/xmon: Fix up xmon format strings powerpc/powernv: Add calls to support little endian host powerpc: Document sysfs DSCR interface powerpc: Fix regression of per-CPU DSCR setting powerpc: Split __SYSFS_SPRSETUP macro arch: powerpc/fadump: Cleaning up inconsistent NULL checks ...
2014-06-10Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Very little of excitement here - the most significant is a new driver for detecting device freefall on Dells, other than that it's pretty much entirely minor fixes for specific machines" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: hp-wmi: Enable hotkeys on some systems thinkpad_acpi: Add mappings for F9 - F12 hotkeys on X240 / T440 / T540 platform: x86: dell-smo8800: Dell Latitude freefall driver (ACPI SMO8800/SMO8810) ideapad_laptop: Introduce the use of the managed version of kzalloc platform/x86: Fix run-time dependencies of OLPC drivers platform: x86: asus-wmi.c: Cleaning up uninitialized variables ix86/mid/thermal: Introduce the use of the managed version of kzalloc platform x86 Kconfig: Refer to the laptop list in the Compal driver help Documentation: Add list of laptop models supported by the Compal driver ideapad-laptop: Blacklist rfkill control on the Lenovo Yoga 2 11 asus-wmi: Set WAPF to 4 for Asus X550CA alienware-wmi: For WMAX HDMI method, introduce a way to query HDMI cable status alienware-wmi: Update WMAX brightness method limit to 15 pvpanic: Set high notifier priority platform/x86: samsung-laptop: Add support for Samsung's NP7[34]0U3E models. toshiba_acpi: Add alternative keymap support for Satellite M840 platform-drivers-x86: intel_pmic_gpio: Fix off-by-one valid offset range check
2014-06-10Merge branch 'for-v3.16/ti-clk-drv' of github.com:t-kristo/linux-pm into ↵Mike Turquette
clk-next
2014-06-10Documentation: Add list of laptop models supported by the Compal driverIsmael Luceno
Signed-off-by: Ismael Luceno <ismael.luceno@gmail.com> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
2014-06-10Merge tag 'mmc-updates-for-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC update from Chris Ball: "MMC highlights for 3.16: Core: - support HS400 mode of eMMC 5.0, via DT bindings mmc-hs400-1_{2,8}v - if card init at 3.3v doesn't work, try 1.8v and 1.2v too Drivers: - moxart: New driver for MOXA ART SoCs - rtsx_usb_sdmmc: New driver for Realtek USB card readers - sdhci: Large rework around IRQ/regulator handling, remove card_tasklet - sdhci-pci-o2micro: Add SeaBird SeaEagle SD3 support - sunxi: New driver for Allwinner sunxi SoCs - usdhi6rol0: New driver for Renesas SD/SDIO controller" * tag 'mmc-updates-for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (95 commits) mmc: sdhci-s3c: use mmc_of_parse and remove the card_tasklet mmc: add a driver for the Renesas usdhi6rol0 SD/SDIO host controller mmc: sdhci-of-esdhc: Fixup compile error mmc: tegra: fix reporting of base clock frequency mmc: tegra: disable UHS modes mmc: sdhci-dove: use mmc_of_parse() and remove card_tasklet CD handler MAINTAINERS: mmc: Add path to git tree mmc: dove: fix missing MACH_DOVE dependency mmc: sdhci: SD tuning is broken for some controllers mmc: sdhci-esdhc-imx: fix mmc ddr mode regression issue mmc: sdhci-pci-o2micro: Add SeaBird SeaEagle SD3 support mmc: omap_hsmmc: split omap-dma header file mmc: omap_hsmmc: fix cmd23 multiblock read/write mmc: omap_hsmmc: use devm_ioremap_resource mmc: omap_hsmmc: use devm_request_threaded_irq mmc: omap_hsmmc: use devm_request_irq mmc: omap_hsmmc: use devm_clk_get mmc: sunxi: Add driver for SD/MMC hosts found on Allwinner sunxi SoCs mmc: wmt-sdmmc: Use GFP_KERNEL instead of hard-coded value mmc: omap: Use DIV_ROUND_UP instead of open coded ...
2014-06-10ARM: mvebu: Add A375/A380 watchdog binding documentationEzequiel Garcia
This commit documents the new support for "marvell,armada-{375,380}-wdt" compatible strings and the extra 'reg' entry requirement. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-06-10Merge branch 'for-3.16' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "The largest piece is a long-overdue rewrite of the xdr code to remove some annoying limitations: for example, there was no way to return ACLs larger than 4K, and readdir results were returned only in 4k chunks, limiting performance on large directories. Also: - part of Neil Brown's work to make NFS work reliably over the loopback interface (so client and server can run on the same machine without deadlocks). The rest of it is coming through other trees. - cleanup and bugfixes for some of the server RDMA code, from Steve Wise. - Various cleanup of NFSv4 state code in preparation for an overhaul of the locking, from Jeff, Trond, and Benny. - smaller bugfixes and cleanup from Christoph Hellwig and Kinglong Mee. Thanks to everyone! This summer looks likely to be busier than usual for knfsd. Hopefully we won't break it too badly; testing definitely welcomed" * 'for-3.16' of git://linux-nfs.org/~bfields/linux: (100 commits) nfsd4: fix FREE_STATEID lockowner leak svcrdma: Fence LOCAL_INV work requests svcrdma: refactor marshalling logic nfsd: don't halt scanning the DRC LRU list when there's an RC_INPROG entry nfs4: remove unused CHANGE_SECURITY_LABEL nfsd4: kill READ64 nfsd4: kill READ32 nfsd4: simplify server xdr->next_page use nfsd4: hash deleg stateid only on successful nfs4_set_delegation nfsd4: rename recall_lock to state_lock nfsd: remove unneeded zeroing of fields in nfsd4_proc_compound nfsd: fix setting of NFS4_OO_CONFIRMED in nfsd4_open nfsd4: use recall_lock for delegation hashing nfsd: fix laundromat next-run-time calculation nfsd: make nfsd4_encode_fattr static SUNRPC/NFSD: Remove using of dprintk with KERN_WARNING nfsd: remove unused function nfsd_read_file nfsd: getattr for FATTR4_WORD0_FILES_AVAIL needs the statfs buffer NFSD: Error out when getting more than one fsloc/secinfo/uuid NFSD: Using type of uint32_t for ex_nflavors instead of int ...
2014-06-10Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: - new Xilixn VDMA driver from Srikanth - bunch of updates for edma driver by Thomas, Joel and Peter - fixes and updates on dw, ste_dma, freescale, mpc512x, sudmac etc * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (45 commits) dmaengine: sh: don't use dynamic static allocation dmaengine: sh: fix print specifier warnings dmaengine: sh: make shdma_prep_dma_cyclic static dmaengine: Kconfig: Update MXS_DMA help text to include MX6Q/MX6DL of: dma: Grammar s/requests/request/, s/used required/required/ dmaengine: shdma: Enable driver compilation with COMPILE_TEST dmaengine: rcar-hpbdma: Include linux/err.h dmaengine: sudmac: Include linux/err.h dmaengine: sudmac: Keep #include sorted alphabetically dmaengine: shdmac: Include linux/err.h dmaengine: shdmac: Keep #include sorted alphabetically dmaengine: s3c24xx-dma: Add cyclic transfer support dmaengine: s3c24xx-dma: Process whole SG chain dmaengine: imx: correct sdmac->status for cyclic dma tx dmaengine: pch: fix compilation for alpha target dmaengine: dw: check return code of dma_async_device_register() dmaengine: dw: fix regression in dw_probe() function dmaengine: dw: enable clock before access dma: pch_dma: Fix Kconfig dependencies dmaengine: mpc512x: add support for peripheral transfers ...
2014-06-10Merge branch 'serge-next-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security Pull security layer updates from Serge Hallyn: "This is a merge of James Morris' security-next tree from 3.14 to yesterday's master, plus four patches from Paul Moore which are in linux-next, plus one patch from Mimi" * 'serge-next-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security: ima: audit log files opened with O_DIRECT flag selinux: conditionally reschedule in hashtab_insert while loading selinux policy selinux: conditionally reschedule in mls_convert_context while loading selinux policy selinux: reject setexeccon() on MNT_NOSUID applications with -EACCES selinux: Report permissive mode in avc: denied messages. Warning in scanf string typing Smack: Label cgroup files for systemd Smack: Verify read access on file open - v3 security: Convert use of typedef ctl_table to struct ctl_table Smack: bidirectional UDS connect check Smack: Correctly remove SMACK64TRANSMUTE attribute SMACK: Fix handling value==NULL in post setxattr bugfix patch for SMACK Smack: adds smackfs/ptrace interface Smack: unify all ptrace accesses in the smack Smack: fix the subject/object order in smack_ptrace_traceme() Minor improvement of 'smack_sb_kern_mount' smack: fix key permission verification KEYS: Move the flags representing required permission to linux/key.h
2014-06-10kbuild: Fix a typo in documentationWarren Turkal
Signed-off-by: Warren Turkal <wt@penguintechs.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-09Merge tag 'for-f2fs-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "In this round, there is no special interesting feature, but we've investigated a couple of tuning points with respect to the I/O flow. Several major bug fixes and a bunch of clean-ups also have been made. This patch-set includes the following major enhancement patches: - enhance wait_on_page_writeback - support SEEK_DATA and SEEK_HOLE - enhance readahead flows - enhance IO flushes - support fiemap - add some tracepoints The other bug fixes are as follows: - fix to support a large volume > 2TB correctly - recovery bug fix wrt fallocated space - fix recursive lock on xattr operations - fix some cases on the remount flow And, there are a bunch of cleanups" * tag 'for-f2fs-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (52 commits) f2fs: support f2fs_fiemap f2fs: avoid not to call remove_dirty_inode f2fs: recover fallocated space f2fs: fix to recover data written by dio f2fs: large volume support f2fs: avoid crash when trace f2fs_submit_page_mbio event in ra_sum_pages f2fs: avoid overflow when large directory feathure is enabled f2fs: fix recursive lock by f2fs_setxattr MAINTAINERS: add a co-maintainer from samsung for F2FS MAINTAINERS: change the email address for f2fs f2fs: use inode_init_owner() to simplify codes f2fs: avoid to use slab memory in f2fs_issue_flush for efficiency f2fs: add a tracepoint for f2fs_read_data_page f2fs: add a tracepoint for f2fs_write_{meta,node,data}_pages f2fs: add a tracepoint for f2fs_write_{meta,node,data}_page f2fs: add a tracepoint for f2fs_write_end f2fs: add a tracepoint for f2fs_write_begin f2fs: fix checkpatch warning f2fs: deactivate inode page if the inode is evicted f2fs: decrease the lock granularity during write_begin ...
2014-06-09Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI updates from James Bottomley: "This patch consists of the usual driver updates (qla2xxx, qla4xxx, lpfc, be2iscsi, fnic, ufs, NCR5380) The NCR5380 is the addition to maintained status of a long neglected driver for older hardware. In addition there are a lot of minor fixes and cleanups and some more updates to make scsi mq ready" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (130 commits) include/scsi/osd_protocol.h: remove unnecessary __constant mvsas: Recognise device/subsystem 9485/9485 as 88SE9485 Revert "be2iscsi: Fix processing cqe for cxn whose endpoint is freed" mptfusion: fix msgContext in mptctl_hp_hostinfo acornscsi: remove linked command support scsi/NCR5380: dprintk macro fusion: Remove use of DEF_SCSI_QCMD fusion: Add free msg frames to the head, not tail of list mpt2sas: Add free smids to the head, not tail of list mpt2sas: Remove use of DEF_SCSI_QCMD mpt2sas: Remove uses of serial_number mpt3sas: Remove use of DEF_SCSI_QCMD mpt3sas: Remove uses of serial_number qla2xxx: Use kmemdup instead of kmalloc + memcpy qla4xxx: Use kmemdup instead of kmalloc + memcpy qla2xxx: fix incorrect debug printk be2iscsi: Bump the driver version be2iscsi: Fix processing cqe for cxn whose endpoint is freed be2iscsi: Fix destroy MCC-CQ before MCC-EQ is destroyed be2iscsi: Fix memory corruption in MBX path ...
2014-06-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A big update to the Atmel touchscreen driver, devm support for polled input devices, several drivers have been converted to using managed resources, and assorted driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (87 commits) Input: synaptics - fix resolution for manually provided min/max Input: atmel_mxt_ts - fix invalid return from mxt_get_bootloader_version Input: max8997_haptic - add error handling for regulator and pwm Input: elantech - don't set bit 1 of reg_10 when the no_hw_res quirk is set Input: elantech - deal with clickpads reporting right button events Input: edt-ft5x06 - fix an i2c write for M09 support Input: omap-keypad - remove platform data support ARM: OMAP2+: remove unused omap4-keypad file and code Input: ab8500-ponkey - switch to using managed resources Input: max8925_onkey - switch to using managed resources Input: 88pm860x-ts - switch to using managed resources Input: 88pm860x_onkey - switch to using managed resources Input: intel-mid-touch - switch to using managed resources Input: wacom - process outbound for newer Cintiqs Input: wacom - set stylus_in_proximity when pen is in range DTS: ARM: OMAP3-N900: Add tsc2005 support Input: tsc2005 - add DT support Input: add common DT binding for touchscreens Input: jornada680_kbd - switch top using managed resources Input: adp5520-keys - switch to using managed resources ...
2014-06-09Merge tag 'trace-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "Lots of tweaks, small fixes, optimizations, and some helper functions to help out the rest of the kernel to ease their use of trace events. The big change for this release is the allowing of other tracers, such as the latency tracers, to be used in the trace instances and allow for function or function graph tracing to be in the top level simultaneously" * tag 'trace-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (44 commits) tracing: Fix memory leak on instance deletion tracing: Fix leak of ring buffer data when new instances creation fails tracing/kprobes: Avoid self tests if tracing is disabled on boot up tracing: Return error if ftrace_trace_arrays list is empty tracing: Only calculate stats of tracepoint benchmarks for 2^32 times tracing: Convert stddev into u64 in tracepoint benchmark tracing: Introduce saved_cmdlines_size file tracing: Add __get_dynamic_array_len() macro for trace events tracing: Remove unused variable in trace_benchmark tracing: Eliminate double free on failure of allocation on boot up ftrace/x86: Call text_ip_addr() instead of the duplicated code tracing: Print max callstack on stacktrace bug tracing: Move locking of trace_cmdline_lock into start/stop seq calls tracing: Try again for saved cmdline if failed due to locking tracing: Have saved_cmdlines use the seq_read infrastructure tracing: Add tracepoint benchmark tracepoint tracing: Print nasty banner when trace_printk() is in use tracing: Add funcgraph_tail option to print function name after closing braces tracing: Eliminate duplicate TRACE_GRAPH_PRINT_xx defines tracing: Add __bitmask() macro to trace events to cpumasks and other bitmasks ...
2014-06-10drm/doc: Add the "type" plane property to the list of propertiesDamien Lespiau
Matt aded this plane property before we had a table giving a summary of the properties. Add it there. Cc: Matt Roper <matthew.d.roper@intel.com> Signed-off-by: Damien Lespiau <damien.lespiau@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-10drm/doc: Fix nouveau typoDamien Lespiau
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-10Merge tag 'drm/panel/for-3.16-rc1' of ↵Dave Airlie
git://anongit.freedesktop.org/tegra/linux into drm-next drm/panel: Changes for v3.16-rc1 This set of commits contains a couple of fixes to existing panel drivers and support for some new panels. One commit touches the DRM core in that in modifies the MIPI DSI support to hook up the shutdown function so that drivers can provide code that's run on shutdown. This is used by a subsequent commit to make the simple panel driver power off the backlight on shutdown. * tag 'drm/panel/for-3.16-rc1' of git://anongit.freedesktop.org/tegra/linux: drm/panel: simple - Add AUO B133XTN01 panel support drm/panel: simple - Disable panel on shutdown drm/panel: add support for EDT ET057090DHU panel drm/panel: Add support for EDT ETM0700G0DH6 and ET070080DH6 panels drm/panel: ld9040: add power control sequence drm/panel: s6e8aa0: silence array overflow warning drm/dsi: Support device shutdown
2014-06-10Merge tag 'drm/tegra/for-3.16-rc1' of ↵Dave Airlie
git://anongit.freedesktop.org/tegra/linux into drm-next drm/tegra: Changes for v3.16-rc1 The majority of these changes are a slew of cleanups across the board. A more noteworthy change is the addition of drm_dev_set_unique() and the conversion of the Tegra DRM driver to use it. This allows us to get rid of the host1x drm_bus implementation. Other USB and platform drivers can be changed in a similar way. Unfortunately for most PCI devices there is some userspace that relies on the old functionality and cannot be as easily converted. HDMI and hardware cursor support is added for Tegra124. The SOR output gains support for exposing CRCs via debugfs, which can be used for automated testing. Many values that were hardcoded in the SOR/eDP code are now computed at runtime to increase compatibility with more devices. * tag 'drm/tegra/for-3.16-rc1' of git://anongit.freedesktop.org/tegra/linux: (47 commits) drm/tegra: sor - Remove obsolete comment drm/tegra: sor - Enable only the necessary number of lanes drm/tegra: sor - Power on only the necessary lanes drm/tegra: sor - Do not program interlaced mode registers drm/tegra: sor - Do not hardcode link speed drm/tegra: sor - Do not hardcode number of blank symbols drm/tegra: sor - Don't hardcode link parameters drm/tegra: sor - Change power down ordering drm/tegra: sor - Fix copy/paste error drm/tegra: sor - Remove pixel clock rounding drm/tegra: sor - Make debugfs setup consistent drm/tegra: sor - Recursively remove debugfs tree drm/tegra: dp - Mark the connector as hotplug capable drm/tegra: dp - Implement hotplug detection in work queue drm/tegra: Add hardware cursor support drm/tegra: Remove host1x drm_bus implementation drm: Document how to register devices without struct drm_bus drm: Add device registration documentation drm: Introduce drm_dev_set_unique() gpu: host1x: Rename internal functions for clarity ...
2014-06-09Merge branch 'for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on cgroup side. Heavy restructuring including locking simplification took place to improve the code base and enable implementation of the unified hierarchy, which currently exists behind a __DEVEL__ mount option. The core support is mostly complete but individual controllers need further work. To explain the design and rationales of the the unified hierarchy Documentation/cgroups/unified-hierarchy.txt is added. Another notable change is css (cgroup_subsys_state - what each controller uses to identify and interact with a cgroup) iteration update. This is part of continuing updates on css object lifetime and visibility. cgroup started with reference count draining on removal way back and is now reaching a point where csses behave and are iterated like normal refcnted objects albeit with some complexities to allow distinguishing the state where they're being deleted. The css iteration update isn't taken advantage of yet but is planned to be used to simplify memcg significantly" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (77 commits) cgroup: disallow disabled controllers on the default hierarchy cgroup: don't destroy the default root cgroup: disallow debug controller on the default hierarchy cgroup: clean up MAINTAINERS entries cgroup: implement css_tryget() device_cgroup: use css_has_online_children() instead of has_children() cgroup: convert cgroup_has_live_children() into css_has_online_children() cgroup: use CSS_ONLINE instead of CGRP_DEAD cgroup: iterate cgroup_subsys_states directly cgroup: introduce CSS_RELEASED and reduce css iteration fallback window cgroup: move cgroup->serial_nr into cgroup_subsys_state cgroup: link all cgroup_subsys_states in their sibling lists cgroup: move cgroup->sibling and ->children into cgroup_subsys_state cgroup: remove cgroup->parent device_cgroup: remove direct access to cgroup->children memcg: update memcg_has_children() to use css_next_child() memcg: remove tasks/children test from mem_cgroup_force_empty() cgroup: remove css_parent() cgroup: skip refcnting on normal root csses and cgrp_dfl_root self css cgroup: use cgroup->self.refcnt for cgroup refcnting ...
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Nothing too interesting - another ahci platform driver variant, additional controller support, minor fixes and cleanups" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: Add Device ID for HighPoint RocketRaid 642L ata: ep93xx: use dmaengine_prep_slave_sg api instead of internal callback ahci: add PCI ID for Marvell 88SE91A0 SATA Controller sata_fsl: remove check for CONFIG_MPC8315_DS ahci: add support for Hisilicon sata libahci_platform: add host_flags parameter in ahci_platform_init_host() ata: ahci: append new hflag AHCI_HFLAG_NO_FBS ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host drivers ata: ahci_mvebu: new driver for Marvell Armada 380 AHCI interfaces Documentation: dt-bindings: reformat and order list of ahci-platform compatibles libata-sff: remove dead code ata: SATL compliance for Inquiry Product Revision pata_octeon_cf: use devm_kzalloc() to allocate cf_port
2014-06-09PM / Documentation: Update copyright in suspend-and-cpuhotplug.txtSrivatsa S. Bhat
Extend the year to 2014 in the copyright. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-09Merge branch 'topic/xilinx' into for-linusVinod Koul
