path: root/Documentation
2011-03-28Platform: add Samsung Laptop platform driverGreg Kroah-Hartman
This adds the samsung-laptop driver to the kernel. It now supports all known Samsung laptops that use the SABI interface. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-03-28eeepc-wmi: asus generic asus-wmi.ko moduleCorentin Chary
New Asus notebooks are using a WMI device similar to the one used in Eee PCs. Since we don't want to load eeepc-wmi module on Asus notebooks, and we want to keep the eeepc-wmi module for backward compatibility, this patch introduce a new module, named asus-wmi, that will be used by eeepc-wmi and the new Asus Notebook WMI Driver. eeepc-wmi's input device strings (device name and phys) are kept, but rfkill and led names are changed (s/eeepc/asus/). This should not break anything since rfkill are used by type or index, not by name, and the eeepc::touchpad led wasn't working correctly before 2.6.39 anyway. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-03-28sony-laptop: documentation updatesMattia Dongili
Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-03-28eeepc-wmi: add touchpad sysfs fileCorentin Chary
2011-03-28eeepc-wmi: add camera and card reader supportCorentin Chary
2011-03-27Merge branch 'for-2.6.39/drivers' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/drivers' of git://git.kernel.dk/linux-2.6-block: (122 commits) cciss: fix lost command issue drbd: need include for bitops functions declarations Revert "cciss: Add missing allocation in scsi_cmd_stack_setup and corresponding deallocation" cciss: fix missed command status value CMD_UNABORTABLE cciss: remove unnecessary casts cciss: Mask off error bits of c->busaddr in cmd_special_free when calling pci_free_consistent cciss: Inform controller we are using 32-bit tags. cciss: hoist tag masking out of loop cciss: Add missing allocation in scsi_cmd_stack_setup and corresponding deallocation cciss: export resettable host attribute drbd: drop code present under #ifdef which is relevant to 2.6.28 and below drbd: Fixed handling of read errors on a 'VerifyS' node drbd: Fixed handling of read errors on a 'VerifyT' node drbd: Implemented real timeout checking for request processing time drbd: Remove unused function atodb_endio() drbd: improve log message if received sector offset exceeds local capacity drbd: kill dead code drbd: don't BUG_ON, if bio_add_page of a single page to an empty bio fails drbd: Removed left over, now wrong comments drbd: serialize admin requests for new verify run with pending bitmap io ...
2011-03-27Merge branch 'docs-next' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs-next' of git://git.lwn.net/linux-2.6: docs: update the development process document docs: fix dev_debug() braino in dynamic-debug-howto.txt
2011-03-27Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (f71882fg) Add support for the F71889A hwmon: (f71882fg) Add support for the F81865F hwmon: (f71882fg) Document all supported devices hwmon: (f71882fg) Per-chip fan/temperature input count tables hwmon: (f71882fg) Secure chip property definition arrays
2011-03-27docbook: fix rapidio warningRandy Dunlap
Fix fsl_rio.c kernel-doc warning: no exported symbols as requested by !E are found: Warning(arch/powerpc/sysdev/fsl_rio.c): no structured comments found Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-27docbook: fix broken media buildRandy Dunlap
DocBook/v4l/ no longer has any *.png files, so the 'cp' command fails, breaking the build. Drop the *.png cp. cp: cannot stat `linux-2.6.38-git18/Documentation/DocBook/v4l/*.png': No such file or directory Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-26hwmon: (f71882fg) Add support for the F71889AHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-26hwmon: (f71882fg) Add support for the F81865FJean Delvare
Add support for the Fintek F81865F. It's essentially compatible with the F71882FG, but has fewer inputs: 7 voltage, 2 temperature and 2 fan inputs only. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-26hwmon: (f71882fg) Document all supported devicesJean Delvare
The list of supported devices was not always well documented in all places. Clarify and list all devices in documentation, Kconfig and the driver itself. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (55 commits) [SCSI] tcm_loop: Add multi-fabric Linux/SCSI LLD fabric module [SCSI] qla4xxx: Use polling mode for disable interrupt mailbox completion [SCSI] Revert "[SCSI] Retrieve the Caching mode page" [SCSI] bnx2fc: IO completion not processed due to missed wakeup [SCSI] qla4xxx: Update driver version to 5.02.00-k6 [SCSI] qla4xxx: masking required bits of add_fw_options during initialization [SCSI] qla4xxx: added new function qla4xxx_relogin_all_devices [SCSI] qla4xxx: add support for ql4xsess_recovery_tmo cmd line param [SCSI] qla4xxx: Add support for ql4xmaxqdepth command line parameter [SCSI] qla4xxx: cleanup function qla4xxx_process_ddb_changed [SCSI] qla4xxx: Prevent other port reinitialization during remove_adapter [SCSI] qla4xxx: remove unused ddb flag DF_NO_RELOGIN [SCSI] qla4xxx: cleanup DDB relogin logic during initialization [SCSI] qla4xxx: Do not retry ISP82XX initialization if H/W state is failed [SCSI] qla4xxx: Do not send mbox command if FW is in failed state [SCSI] qla4xxx: cleanup qla4xxx_initialize_ddb_list() [SCSI] ses: add subenclosure support [SCSI] bnx2fc: Bump version to 1.0.1 [SCSI] bnx2fc: Remove unnecessary module state checks [SCSI] bnx2fc: Fix MTU issue by using static MTU ...
2011-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: dm stripe: implement merge method dm mpath: allow table load with no priority groups dm mpath: fail message ioctl if specified path is not valid dm ioctl: add flag to wipe buffers for secure data dm ioctl: prepare for crypt key wiping dm crypt: wipe keys string immediately after key is set dm: add flakey target dm: fix opening log and cow devices for read only tables
2011-03-25Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, doc: Update sched-design-CFS.txt sched: Remove unused 'rq' variable and cpu_rq() call from alloc_fair_sched_group() sched.h: Fix a typo ("its") sched: Fix yield_to kernel-doc
2011-03-25docs: update the development process documentJonathan Corbet
Here's a set of changes updating Documentation/development-process. I have update kernel releases and relevant statistics, added information for a couple of tools, zapped some trailing white space, and generally tried to make it more closely match the current state of affairs. [Typo fixes from Joe Perches and Nicolas Kaiser incorporated] Signed-off-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Greg KH <greg@kroah.com> Cc: Randy Dunlap <rdunlap@xenotime.net>
2011-03-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (43 commits) ext4: fix a BUG in mb_mark_used during trim. ext4: unused variables cleanup in fs/ext4/extents.c ext4: remove redundant set_buffer_mapped() in ext4_da_get_block_prep() ext4: add more tracepoints and use dev_t in the trace buffer ext4: don't kfree uninitialized s_group_info members ext4: add missing space in printk's in __ext4_grp_locked_error() ext4: add FITRIM to compat_ioctl. ext4: handle errors in ext4_clear_blocks() ext4: unify the ext4_handle_release_buffer() api ext4: handle errors in ext4_rename jbd2: add COW fields to struct jbd2_journal_handle jbd2: add the b_cow_tid field to journal_head struct ext4: Initialize fsync transaction ids in ext4_new_inode() ext4: Use single thread to perform DIO unwritten convertion ext4: optimize ext4_bio_write_page() when no extent conversion is needed ext4: skip orphan cleanup if fs has unknown ROCOMPAT features ext4: use the nblocks arg to ext4_truncate_restart_trans() ext4: fix missing iput of root inode for some mount error paths ext4: make FIEMAP and delayed allocation play well together ext4: suppress verbose debugging information if malloc-debug is off ... Fi up conflicts in fs/ext4/super.c due to workqueue changes
2011-03-25docs: fix dev_debug() braino in dynamic-debug-howto.txtJonathan Corbet
While looking at dynamic-debug-howto.txt, I noticed that it references dev_debug() (which doesn't exist) instead of dev_dbg() (which does exist). I'm lazy, so I choose to fix the document rather than changing every dev_dbg() call. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
2011-03-24fs: remove inode_lock from iput_final and prune_icacheDave Chinner
Now that inode state changes are protected by the inode->i_lock and the inode LRU manipulations by the inode_lru_lock, we can remove the inode_lock from prune_icache and the initial part of iput_final(). instead of using the inode_lock to protect the inode during iput_final, use the inode->i_lock instead. This protects the inode against new references being taken while we change the inode state to I_FREEING, as well as preventing prune_icache from grabbing the inode while we are manipulating it. Hence we no longer need the inode_lock in iput_final prior to setting I_FREEING on the inode. For prune_icache, we no longer need the inode_lock to protect the LRU list, and the inodes themselves are protected against freeing races by the inode->i_lock. Hence we can lift the inode_lock from prune_icache as well. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits) [media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t [media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly [media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE [media] v4l: soc-camera: Store negotiated buffer settings [media] rc: interim support for 32-bit NEC-ish scancodes [media] mceusb: topseed 0x0011 needs gen3 init for tx to work [media] lirc_zilog: error out if buffer read bytes != chunk size [media] lirc: silence some compile warnings [media] hdpvr: use same polling interval as other OS [media] ir-kbd-i2c: pass device code w/key in hauppauge case [media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap [media] remove the old RC_MAP_HAUPPAUGE_NEW RC map [media] rc/keymaps: Rename Hauppauge table as rc-hauppauge [media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping [media] rc-rc5-hauppauge-new: Add support for the old Black RC [media] rc-rc5-hauppauge-new: Add the old control to the table [media] rc-winfast: Fix the keycode tables [media] a800: Fix a few wrong IR key assignments [media] opera1: Use multimedia keys instead of an app-specific mapping [media] dw2102: Use multimedia keys instead of an app-specific mapping ... Fix up trivial conflicts (remove/modify and some real conflicts) in: arch/arm/mach-omap2/devices.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/dabusb/dabusb.c drivers/staging/dabusb/dabusb.h drivers/staging/easycap/easycap_ioctl.c drivers/staging/usbvideo/usbvideo.c drivers/staging/usbvideo/vicam.c
2011-03-24Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (42 commits) ACPI: minor printk format change in acpi_pad ACPI: make acpi_pad /sys output more readable ACPICA: Update version to 20110316 ACPICA: Header support for SLIC table ACPI: Make sure the FADT is at least rev 2 before using the reset register ACPI: Bug compatibility for Windows on the ACPI reboot vector ACPICA: Fix access width for reset vector ACPI battery: fribble sysfs files from a resume notifier ACPI button: remove unused procfs I/F ACPI, APEI, Add PCIe AER error information printing support PCIe, AER, use pre-generated prefix in error information printing ACPI, APEI, Add ERST record ID cache ACPI: Use syscore_ops instead of sysdev class and sysdev ACPI: Remove the unused EC sysdev class ACPI: use __cpuinit for the acpi_processor_set_pdc() call tree ACPI: use __init where possible in processor driver Thermal_Framework-Fix_crash_during_hwmon_unregister ACPICA: Update version to 20110211. ACPICA: Add mechanism to defer _REG methods for some installed handlers ACPICA: Add support for FunctionalFixedHW in acpi_ut_get_region_name ...
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: Use vmalloc rather than kmalloc for zlib workspace Squashfs: handle corruption of directory structure Squashfs: wrap squashfs_mount() definition Squashfs: xz_wrapper doesn't need to include squashfs_fs_i.h anymore Squashfs: Update documentation to include compression options Squashfs: Update Kconfig help text to include xz compression Squashfs: add compression options support to xz decompressor Squashfs: extend decompressor framework to handle compression options
2011-03-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (90 commits) mfd: Push byte swaps out of wm8994 bulk read path mfd: Rename ab8500 gpadc header mfd: Constify WM8994 write path mfd: Push byte swap out of WM8994 bulk I/O mfd: Avoid copying data in WM8994 I2C write mfd: Remove copy from WM831x I2C write function mfd: Staticise WM8994 PM ops regulator: Add a subdriver for TI TPS6105x regulator portions v2 mfd: Add a core driver for TI TPS61050/TPS61052 chips v2 gpio: Add Tunnel Creek support to sch_gpio mfd: Add Tunnel Creek support to lpc_sch pci_ids: Add Intel Tunnel Creek LPC Bridge device ID. regulator: MAX8997/8966 support mfd: Add WM8994 bulk register write operation mfd: Append additional read write on 88pm860x mfd: Adopt mfd_data in 88pm860x input driver mfd: Adopt mfd_data in 88pm860x regulator mfd: Adopt mfd_data in 88pm860x led mfd: Adopt mfd_data in 88pm860x backlight mfd: Fix MAX8997 Kconfig entry typos ...
2011-03-24Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: deprecate the commands pending counter exofs: Write sbi->s_nextid as part of the Create command exofs: Add option to mount by osdname exofs: Override read-ahead to align on stripe_size exofs: simple fsync race fix exofs: Optimize read_4_write exofs: Trivial: fix some indentation and debug prints exofs: Remove redundant unlikely()
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: (140 commits) MAINTAINERS: de-orphan fbdev. MAINTAINERS: Add file pattern for fb dt bindings. video: Move sm501fb devicetree binding documentation to a better place. fbcon: fix situation where fbcon gets deinitialised and can't reinit. video, sm501: add OF binding to support SM501 video, sm501: add edid and commandline support video, sm501: add I/O functions for use on powerpc video: Fix EDID macros H_SYNC_WIDTH and H_SYNC_OFFSET fbcon: Bugfix soft cursor detection in Tile Blitting video: add missing framebuffer_release in error path video: metronomefb: add __devexit_p around reference to metronomefb_remove video: hecubafb: add __devexit_p around reference to hecubafb_remove drivers:video:aty:radeon_base Fix typo occationally to occasionally atmel_lcdfb: add fb_blank function atmel_lcdfb: implement inverted contrast pwm video: s3c-fb: return proper error if clk_get fails uvesafb,vesafb: create WC or WB PAT-entries video: ffb: fix ffb_probe error path radeonfb: Let hwmon driver probe the "monid" I2C bus fbdev: sh_mobile_lcdc: checking NULL instead of IS_ERR() ...
2011-03-24dm: add flakey targetJosef Bacik
This target is the same as the linear target except that it returns I/O errors periodically. It's been found useful in simulating failing devices for testing purposes. I needed a dm target to do some failure testing on btrfs's raid code, and Mike pointed me at this. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-03-23rapidio: add RapidIO documentationAlexandre Bounine
Add RapidIO documentation files as it was discussed earlier (see thread http://marc.info/?l=linux-kernel&m=129202338918062&w=2) Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Documentation/iostats.txt: bit-size reference etc.Randy Dunlap
- correction that disk stats values are native-word-sized 32-bit or 64-bit values, not always 32-bi values - drop "Last modified" entry; use git for that - fix a few typos - change "cpu" to "CPU" Reported-by: Linda Walsh <lkml@tlinx.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-23[SCSI] tcm_mod_builder.py: Fix generated *_drop_nodeacl() handlerFubo Chen
This patch adds the missing core_tpg_del_initiator_node_acl() call required by fabric modules for struct se_node_acl->acl_group context shutdown via target_core_fabric_configfs.c:target_fabric_nacl_base_release() -> struct target_core_fabric_ops->fabric_drop_nodeacl() for tcm_mod_builder.py generated $FABRIC_MOD_configfs.c skeleton code. Signed-off-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: tcm_mod_builder.py generated Makefile cleanupsNicholas Bellinger
This patch converts the tcm_mod_builder.py generation script to create a new drivers/target/$TCM_FABRIC_MOD/Makefile and update drivers/target/Makefile, instead of creating+updating a 'Kbuild' filename. It also removes the remaining EXTRA_CFLAGS includes from tcm_mod_build_kbuild(), and converts fabric module generated .c code to us ""-style includes for $FABRIC_MOD_[base,fabric].h Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23sched, doc: Update sched-design-CFS.txtBorislav Petkov
Correct ->dequeue_tree() thinko into sched_class->dequeue_task and drop all references to ->task_new() since it is obviously gone. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <1300815978-16618-1-git-send-email-bp@amd64.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23hwmon: twl4030: Hwmon Driver for TWL4030 MADCKeerthy
This driver exposes the sysfs nodes of the TWL4030 MADC module. All the voltage channel values are expressed in terms of mV. Channel 13 and channel 14 are reserved. There are channels which represent temperature and current the output is represented by celcius and mA respectively. Signed-off-by: Keerthy <j-keerthy@ti.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-23Merge commit 'v2.6.38' into releaseLen Brown
2011-03-22Merge branch 'button-cleanup' into releaseLen Brown
2011-03-22ACPI button: remove unused procfs I/FZhang Rui
Remove unused ACPI button procfs interface. Only /proc/acpi/button/lid/LID/state remains. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-22adfs: add hexadecimal filetype suffix optionStuart Swales
ADFS (FileCore) storage complies with the RISC OS filetype specification (12 bits of file type information is stored in the file load address, rather than using a file extension). The existing driver largely ignores this information and does not present it to the end user. It is desirable that stored filetypes be made visible to the end user to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu) or to a network share which can be accessed by real Acorn systems. This patch implements a per-mount filetype suffix option (use -o ftsuffix=1) to present any filetype as a ,xyz hexadecimal suffix on each file. This type suffix is compatible with that used by RISC OS systems that access network servers using NFS client software and by RPCemu's host filing system. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/vm/page-types.c: auto debugfs mount for hwpoison operationChen Gong
page-types.c doesn't supply a way to specify the debugfs path and the original debugfs path is not usual on most machines. This patch supplies a way to auto mount debugfs if needed. This patch is heavily inspired by tools/perf/utils/debugfs.c [akpm@linux-foundation.org: make functions static] [akpm@linux-foundation.org: fix debugfs_mount() signature] Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/Changes: minor correctionsChristian Kujau
I noticed the 'mcelog' program had no comment and then ended up "fixing" a few more things: * reiserfsck -V does not print "reiserfsprogs" (any more?) * is "udevinfo" still shipped? udevd certainly is * grub2 doesn't have a 'grub' binary * add a "# how to get the mcelog version" comment Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/CodingStyle: flesh out if-else examplesHarry Wei
There is a missing case for "Chapter 3: Placing Braces and Spaces". We often know we should not use braces where a single statement. The first case is: if (condition) action(); Another case is: if (condition) do_this(); else do_that(); However, I can not find a description of the second case. Signed-off-by: Harry Wei <harryxiyou@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22console: allow to retain boot console via boot option keep_bootconFabio M. Di Nitto
On some architectures, the boot process involves de-registering the boot console (early boot), initialize drivers and then re-register the console. This mechanism introduces a window in which no printk can happen on the console and messages are buffered and then printed once the new console is available. If a kernel crashes during this window, all it's left on the boot console is "console [foo] enabled, bootconsole disabled" making debug of the crash rather 'interesting'. By adding "keep_bootcon" option, do not unregister the boot console, that will allow to printk everything that is happening up to the crash. The option is clearly meant only for debugging purposes as it introduces lots of duplicated info printed on console, but will make bug report from users easier as it doesn't require a kernel build just to figure out where we crash. Signed-off-by: Fabio M. Di Nitto <fabbione@fabbione.net> Acked-by: David S. Miller <davem@davemloft.net> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kernel/watchdog.c: allow hardlockup to panic by defaultDon Zickus
When a cpu is considered stuck, instead of limping along and just printing a warning, it is sometimes preferred to just panic, let kdump capture the vmcore and reboot. This gets the machine back into a stable state quickly while saving the info that got it into a stuck state to begin with. Add a Kconfig option to allow users to set the hardlockup to panic by default. Also add in a 'nmi_watchdog=nopanic' to override this. [akpm@linux-foundation.org: fix strncmp length] Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22move x86 specific oops=panic to generic codeOlaf Hering
The oops=panic cmdline option is not x86 specific, move it to generic code. Update documentation. Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22ST SPEAr: PCIE gadget suppportPratyush Anand
This is a configurable gadget. can be configured by configfs interface. Any IP available at PCIE bus can be programmed to be used by host controller.It supoorts both INTX and MSI. By default, the gadget is configured for INTX and SYSRAM1 is mapped to BAR0 with size 0x1000 Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Viresh Kumar <viresh.kumar@st.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22backlight: add backlight typeMatthew Garrett
There may be multiple ways of controlling the backlight on a given machine. Allow drivers to expose the type of interface they are providing, making it possible for userspace to make appropriate policy decisions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-clientLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: use watch/notify for changes in rbd header libceph: add lingering request and watch/notify event framework rbd: update email address in Documentation ceph: rename dentry_release -> d_release, fix comment ceph: add request to the tail of unsafe write list ceph: remove request from unsafe list if it is canceled/timed out ceph: move readahead default to fs/ceph from libceph ceph: add ino32 mount option ceph: update common header files ceph: remove debugfs debug cruft libceph: fix osd request queuing on osdmap updates ceph: preserve I_COMPLETE across rename libceph: Fix base64-decoding when input ends in newline.
2011-03-23video: Move sm501fb devicetree binding documentation to a better place.Paul Mundt
Now that there is a Documentation/devicetree hierarchy, and the driver in question has no specific platform dependency, move the binding information to a more appropriate place. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
