path: root/Documentation
2015-06-06pty: Fix input race when closingPeter Hurley
commit 1a48632ffed61352a7810ce089dc5a8bcd505a60 upstream. A read() from a pty master may mistakenly indicate EOF (errno == -EIO) after the pty slave has closed, even though input data remains to be read. For example, pty slave | input worker | pty master | | | | n_tty_read() pty_write() | | input avail? no add data | | sleep schedule worker --->| | . |---> flush_to_ldisc() | . pty_close() | fill read buffer | . wait for worker | wakeup reader --->| . | read buffer full? |---> input avail ? yes |<--- yes - exit worker | copy 4096 bytes to user TTY_OTHER_CLOSED <---| |<--- kick worker | | **** New read() before worker starts **** | | n_tty_read() | | input avail? no | | TTY_OTHER_CLOSED? yes | | return -EIO Several conditions are required to trigger this race: 1. the ldisc read buffer must become full so the input worker exits 2. the read() count parameter must be >= 4096 so the ldisc read buffer is empty 3. the subsequent read() occurs before the kicked worker has processed more input However, the underlying cause of the race is that data is pipelined, while tty state is not; ie., data already written by the pty slave end is not yet visible to the pty master end, but state changes by the pty slave end are visible to the pty master end immediately. Pipeline the TTY_OTHER_CLOSED state through input worker to the reader. 1. Introduce TTY_OTHER_DONE which is set by the input worker when TTY_OTHER_CLOSED is set and either the input buffers are flushed or input processing has completed. Readers/polls are woken when TTY_OTHER_DONE is set. 2. Reader/poll checks TTY_OTHER_DONE instead of TTY_OTHER_CLOSED. 3. A new input worker is started from pty_close() after setting TTY_OTHER_CLOSED, which ensures the TTY_OTHER_DONE state will be set if the last input worker is already finished (or just about to exit). Remove tty_flush_to_ldisc(); no in-tree callers. Fixes: 52bce7f8d4fc ("pty, n_tty: Simplify input processing on final close") Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=96311 BugLink: http://bugs.launchpad.net/bugs/1429756 Reported-by: Andy Whitcroft <apw@canonical.com> Reported-by: H.J. Lu <hjl.tools@gmail.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-06hwmon: (tmp401) Do not auto-detect chip on I2C address 0x37Guenter Roeck
commit 9aecac04d8d89e730ae362a748113b19c06a9d39 upstream. I2C address 0x37 may be used by EEPROMs, which can result in false positives. Do not attempt to detect a chip at this address. Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-06KVM: MMU: fix SMAP virtualizationXiao Guangrong
commit 0be0226f07d14b153a5eedf2bb86e1eb7dcefab5 upstream. KVM may turn a user page to a kernel page when kernel writes a readonly user page if CR0.WP = 1. This shadow page entry will be reused after SMAP is enabled so that kernel is allowed to access this user page Fix it by setting SMAP && !CR0.WP into shadow page's role and reset mmu once CR4.SMAP is updated Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17ARM: dts: imx28: Fix AUART4 TX-DMA interrupt nameMarek Vasut
commit 4ada77e37a773168fea484899201e272ab44ba8b upstream. Fix a typo in the TX DMA interrupt name for AUART4. This patch makes AUART4 operational again. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma") Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13uas: Add US_FL_MAX_SECTORS_240 flagHans de Goede
commit ee136af4a064c2f61e2025873584d2c7ec93f4ae upstream. The usb-storage driver sets max_sectors = 240 in its scsi-host template, for uas we do not want to do that for all devices, but testing has shown that some devices need it. This commit adds a US_FL_MAX_SECTORS_240 flag for such devices, and implements support for it in uas.c, while at it it also adds support for US_FL_MAX_SECTORS_64 to uas.c. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06KVM: s390: fix get_all_floating_irqsJens Freimann
commit 94aa033efcac47b09db22cb561e135baf37b7887 upstream. This fixes a bug introduced with commit c05c4186bbe4 ("KVM: s390: add floating irq controller"). get_all_floating_irqs() does copy_to_user() while holding a spin lock. Let's fix this by filling a temporary buffer first and copy it to userspace after giving up the lock. Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06net: rfs: fix crash in get_rps_cpus()Eric Dumazet
[ Upstream commit a31196b07f8034eba6a3487a1ad1bb5ec5cd58a5 ] Commit 567e4b79731c ("net: rfs: add hash collision detection") had one mistake : RPS_NO_CPU is no longer the marker for invalid cpu in set_rps_cpu() and get_rps_cpu(), as @next_cpu was the result of an AND with rps_cpu_mask This bug showed up on a host with 72 cpus : next_cpu was 0x7f, and the code was trying to access percpu data of an non existent cpu. In a follow up patch, we might get rid of compares against nr_cpu_ids, if we init the tables with 0. This is silly to test for a very unlikely condition that exists only shortly after table initialization, as we got rid of rps_reset_sock_flow() and similar functions that were writing this RPS_NO_CPU magic value at flow dismantle : When table is old enough, it never contains this value anymore. Fixes: 567e4b79731c ("net: rfs: add hash collision detection") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <tom@herbertland.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-12Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal Pull last minute thermal-SoC management fixes from Eduardo Valentin: "Specifics: - Minor fixes on ST and RCAR thermal drivers. - Avoid flooding kernel log when driver returns -EAGAIN. Note: I am sending this pull on Rui's behalf while he fixes issues in his Linux box" * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal: drivers: thermal: st: remove several sparse warnings thermal: constify of_device_id array thermal: Do not log an error if thermal_zone_get_temp returns -EAGAIN thermal: rcar: Fix typo in r8a73a4 SoC name
2015-04-07thermal: rcar: Fix typo in r8a73a4 SoC nameGeert Uytterhoeven
r8a73a4 is R-Mobile APE6, not AP6. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) In TCP, don't register an FRTO for cumulatively ACK'd data that was previously SACK'd, from Neal Cardwell. 2) Need to hold RNL mutex in ipv4 multicast code namespace cleanup, from Cong WANG. 3) Similarly we have to hold RNL mutex for fib_rules_unregister(), also from Cong WANG. 4) Revert and rework netns nsid allocation fix, from Nicolas Dichtel. 5) When we encapsulate for a tunnel device, skb->sk still points to the user socket. So this leads to cases where we retraverse the ipv4/ipv6 output path with skb->sk being of some other address family (f.e. AF_PACKET). This can cause things to crash since the ipv4 output path is dereferencing an AF_PACKET socket as if it were an ipv4 one. The short term fix for 'net' and -stable is to elide these socket checks once we've entered an encapsulation sequence by testing xmit_recursion. Longer term we have a better solution wherein we pass the tunnel's socket down through the output paths, but that is way too invasive for 'net' and -stable. From Hannes Frederic Sowa. 6) l2tp_init() failure path forgets to unregister per-net ops, from Cong WANG. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net/mlx4_core: Fix error message deprecation for ConnectX-2 cards net: dsa: fix filling routing table from OF description l2tp: unregister l2tp_net_ops on failure path mvneta: dont call mvneta_adjust_link() manually ipv6: protect skb->sk accesses from recursive dereference inside the stack netns: don't allocate an id for dead netns Revert "netns: don't clear nsid too early on removal" ip6mr: call del_timer_sync() in ip6mr_free_table() net: move fib_rules_unregister() under rtnl lock ipv4: take rtnl_lock and mark mrt table as freed on namespace cleanup tcp: fix FRTO undo on cumulative ACK of SACKed range xen-netfront: transmit fully GSO-sized packets
2015-04-06net: dsa: fix filling routing table from OF descriptionPavel Nakonechny
According to description in 'include/net/dsa.h', in cascade switches configurations where there are more than one interconnected devices, 'rtable' array in 'dsa_chip_data' structure is used to indicate which port on this switch should be used to send packets to that are destined for corresponding switch. However, dsa_of_setup_routing_table() fills 'rtable' with port numbers of the _target_ switch, but not current one. This commit removes redundant devicetree parsing and adds needed port number as a function argument. So dsa_of_setup_routing_table() now just looks for target switch number by parsing parent of 'link' device node. To remove possible misunderstandings with the way of determining target switch number, a corresponding comment was added to the source code and to the DSA device tree bindings documentation file. This was tested on a custom board with two Marvell 88E6095 switches with following corresponding routing tables: { -1, 10 } and { 8, -1 }. Signed-off-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input fixes from Dmitry Torokhov: "Updates for the input subsystem - two more tweaks for ALPS driver to work out kinks after splitting the touchpad, trackstick, and potential external PS/2 mouse into separate input devices. Changes to support ALPS SS4 devices (protocol V8) will be coming in 4.1..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: alps - document stick behavior for protocol V2 Input: alps - report V2 Dualpoint Stick events via the right evdev node Input: alps - report interleaved bare PS/2 packets via dev3
2015-04-05Input: alps - document stick behavior for protocol V2Hans de Goede
Document that protocol V2 uses standard (bare) PS/2 mouse packets for the DualPoint stick. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-By: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "A fix for ALPS driver for issue introduced in the latest update and a tweak for yet another Lenovo box in Synaptics. There will be more ALPS tweaks coming.." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: define INPUT_PROP_ACCELEROMETER behavior Input: synaptics - fix min-max quirk value for E440 Input: synaptics - add quirk for Thinkpad E440 Input: ALPS - fix max coordinates for v5 and v7 protocols Input: add MT_TOOL_PALM
2015-03-31Input: define INPUT_PROP_ACCELEROMETER behaviorPeter Hutterer
Spell out what this property means to userspace. If the property is set, all directional axes must be accelerometer axes, any other axes are left as-is. This allows an accelerometer device to e.g. have an ABS_WHEEL. It is not permitted to mix normal directional axes and accelerometer axes on the same device node. Signed-off-by: Peter Hutterer <peter.hutterer@who-t.net> Acked-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Bastien Nocera <hadess@hadess.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-03-20Input: add MT_TOOL_PALMCharlie Mooney
Currently there are only two "tools" that can be specified by a multi-touch driver: MT_TOOL_FINGER and MT_TOOL_PEN. In working with Elan (The touch vendor) and discussing their next-gen devices it seems that it will be useful to have more tools so that their devices can give the upper layers of the stack hints as to what is touching the sensor. In particular they have new experimental firmware that can better differentiate between palms vs fingertips and would like to plumb a patch so that we can use their hints in higher-level gesture soft- ware. The firmware on the device can reasonably do a better job of palm detection because it has access to all of the raw sensor readings as opposed to just the width/pressure/etc that are exposed by the driver. As such, the firmware can characterize what a palm looks like in much finer-grained detail and this change would allow such a device to share its findings with the kernel. Signed-off-by: Charlie Mooney <charliemooney@chromium.org> Acked-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-03-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "This is a rather unpleasantly large set of bug fixes for arm-soc, Most of them because of cross-tree dependencies for Exynos where we should have figured out the right path to merge things before the merge window, and then the maintainer being unable to sort things out in time during a business trip. The other changes contained here are the usual collection: MAINTAINERS file updates - Gregory Clement is now a co-maintainer for the legacy Marvell EBU platforms - A MAINTAINERS entry for the Freescale Vybrid platform that was added last year - Matt Porter no longer works as a maintainer on Broadcom SoCs Build-time issues - A compile-time error for at91 - Several minor DT fixes on at91, imx, exynos, socfpga, and omap - The new digicolor platform was not correctly enabled at all Configuration issues - Two defconfig fix for regressions using USB on versatile express and on OMAP3 - Enabling all 8 CPUs on Allwinner/SUNxi - Enabling the new STiH410 platform to be usable Bug fixes in platform code - A missing barrier for socfpga - Fixing LPDDR1 self-refresh mode on at91 - Fixing RTC interrupt numbers on Exynos3250 - Fixing a cache-coherency issues in CPU power-down on Exynos5 - Multiple small OMAP power management fixes" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (69 commits) MAINTAINERS: Add myself as co-maintainer to the legacy support of the mvebu SoCs ARM: at91: pm_slowclock: fix the compilation error ARM: at91/dt: fix USB high-speed clock to select UTMI ARM: at91/dt: fix at91 udc compatible strings ARM: at91/dt: declare matrix node as a syscon device ARM: vexpress: update CONFIG_USB_ISP1760 option ARM: digicolor: add the machine directory to Makefile ARM: STi: Add STiH410 SoC support MAINTAINERS: add Freescale Vybrid SoC MAINTAINERS: Remove self as ARM mach-bcm co-maintainer ARM: imx6sl-evk: set swbst_reg as vbus's parent reg ARM: imx6qdl-sabresd: set swbst_reg as vbus's parent reg ARM: at91/dt: at91sam9261: fix clocks and clock-names in udc definition ARM: OMAP2+: Fix wl12xx on dm3730-evm with mainline u-boot ARM: OMAP: enable TWL4030_USB in omap2plus_defconfig ARM: dts: dra7x-evm: avoid possible contention while muxing on CAN lines ARM: dts: dra7x-evm: Don't use dcan1_rx.gpio1_15 in DCAN pinctrl ARM: dts: am43xx: fix SLEWCTRL_FAST pinctrl binding ARM: dts: am33xx: fix SLEWCTRL_FAST pinctrl binding ARM: dts: OMAP5: fix polling intervals for thermal zones ...
2015-03-13Merge tag 'devicetree-fixes-for-4.0' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: - fix for stdout-path option parsing with added unittest - fix for stdout-path interaction with earlycon - several DT unittest fixes - fix Sparc allmodconfig build error on of_platform_register_reconfig_notifier - several DT overlay kconfig and build warning fixes - several DT binding documentation updates * tag 'devicetree-fixes-for-4.0' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: of/platform: Fix sparc:allmodconfig build of: unittest: Add options string testcase variants of: fix handling of '/' in options for of_find_node_by_path() of/unittest: Fix the wrong expected value in of_selftest_property_string of/unittest: remove the duplicate of_changeset_init dt: submitting-patches: clarify that DT maintainers are to be cced on bindings of: unittest: fix I2C dependency of/overlay: Remove unused variable Documentation: DT: Renamed of-serial.txt to 8250.txt of: Fix premature bootconsole disable with 'stdout-path' serial: add device tree binding documentation for ETRAX FS UART of/overlay: Directly include idr.h of: Drop superfluous dependance for OF_OVERLAY of: Add vendor prefix for Arasan of: Add prompt for OF_OVERLAY config
2015-03-11ARM: STi: Add STiH410 SoC supportFabrice GASNIER
This patch adds support to STiH410 SoC. Please note "st,stih410" is already present in device tree. The problem is that it is missing the entry in the match table, and so the L2 cache and other cpus than 0 don't get initialized. Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com> Tested-by: Maxime Coquelin <maxime.coquelin@st.com> Acked-by: Peter Griffin <peter.griffin@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-03-10dt: submitting-patches: clarify that DT maintainers are to be cced on bindingsMatt Porter
The exact steps provided for submitting binding patches can be read as requiring the bindings to be sent only to the devicetree@vger.kernel.org list. Since the DT maintainers would like to be Cced on any binding submissions, make this requirement explicit in step 2. Signed-off-by: Matt Porter <mporter@konsulko.com> Signed-off-by: Rob Herring <robh@kernel.org>
2015-03-10Documentation: DT: Renamed of-serial.txt to 8250.txtChunyan Zhang
The file of-serial.txt was only for 8250 compatible UART implementations, so renamed it to 8250.txt to avoid confusing other persons. This is suggested by Arnd, see: http://lists.infradead.org/pipermail/linux-arm-kernel/2014-September/291455.html Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Rob Herring <robh@kernel.org>
2015-03-10Merge tag 'v4.0-rc3' into HEADRob Herring
Linux 4.0-rc3 Merging in v4.0-rc3 because commit 30a22c215a00 (console: Fix console name size mismatch) is a dependency.
2015-03-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) nft_compat accidently truncates ethernet protocol to 8-bits, from Arturo Borrero. 2) Memory leak in ip_vs_proc_conn(), from Julian Anastasov. 3) Don't allow the space required for nftables rules to exceed the maximum value representable in the dlen field. From Patrick McHardy. 4) bcm63xx_enet can accidently leave interrupts permanently disabled due to errors in the NAPI polling exit logic. Fix from Nicolas Schichan. 5) Fix OOPSes triggerable by the ping protocol module, due to missing address family validations etc. From Lorenzo Colitti. 6) Don't use RCU locking in sleepable context in team driver, from Jiri Pirko. 7) xen-netback miscalculates statistic offset pointers when reporting the stats to userspace. From David Vrabel. 8) Fix a leak of up to 256 pages per VIF destroy in xen-netaback, also from David Vrabel. 9) ip_check_defrag() cannot assume that skb_network_offset(), particularly when it is used by the AF_PACKET fanout defrag code. From Alexander Drozdov. 10) gianfar driver doesn't query OF node names properly when trying to determine the number of hw queues available. Fix it to explicitly check for OF nodes named queue-group. From Tobias Waldekranz. 11) MID field in macb driver should be 12 bits, not 16. From Punnaiah Choudary Kalluri. 12) Fix unintentional regression in traceroute due to timestamp socket option changes. Empty ICMP payloads should be allowed in non-timestamp cases. From Willem de Bruijn. 13) When devices are unregistered, we have to get rid of AF_PACKET multicast list entries that point to it via ifindex. Fix from Francesco Ruggeri. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits) tipc: fix bug in link failover handling net: delete stale packet_mclist entries net: macb: constify macb configuration data MAINTAINERS: add Marc Kleine-Budde as co maintainer for CAN networking layer MAINTAINERS: linux-can moved to github can: kvaser_usb: Read all messages in a bulk-in URB buffer can: kvaser_usb: Avoid double free on URB submission failures can: peak_usb: fix missing ctrlmode_ init for every dev can: add missing initialisations in CAN related skbuffs ip: fix error queue empty skb handling bgmac: Clean warning messages tcp: align tcp_xmit_size_goal() on tcp_tso_autosize() net: fec: fix unbalanced clk disable on driver unbind net: macb: Correct the MID field length value net: gianfar: correctly determine the number of queue groups ipv4: ip_check_defrag should not assume that skb_network_offset is zero net: bcmgenet: properly disable password matching net: eth: xgene: fix booting with devicetree bnx2x: Force fundamental reset for EEH recovery xen-netback: refactor xenvif_handle_frag_list() ...
2015-03-08Merge tag 'tty-4.0-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg KH: "Here are some tty and serial driver fixes for 4.0-rc3. Along with the atime fix that you know about, here are some other serial driver bugfixes as well. Most notable is a wait_until_sent bugfix that was traced back to being around since before 2.6.12 that Johan has fixed up. All have been in linux-next successfully" * tag 'tty-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: TTY: fix tty_wait_until_sent maximum timeout TTY: fix tty_wait_until_sent on 64-bit machines USB: serial: fix infinite wait_until_sent timeout TTY: bfin_jtag_comm: remove incorrect wait_until_sent operation net: irda: fix wait_until_sent poll timeout serial: uapi: Declare all userspace-visible io types serial: core: Fix iotype userspace breakage serial: sprd: Fix missing spin_unlock in sprd_handle_irq() console: Fix console name size mismatch tty: fix up atime/mtime mess, take four serial: 8250_dw: Fix get_mctrl behaviour serial:8250:8250_pci: delete unneeded quirk entries serial:8250:8250_pci: fix redundant entry report for WCH_CH352_2S Change email address for 8250_pci serial: 8250: Revert "tty: serial: 8250_core: read only RX if there is something in the FIFO" Revert "tty/serial: of_serial: add DT alias ID handling"
2015-03-08Merge tag 'cc-4.0-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull "code of conflict" from Greg KH: "This file tries to set the rational basis for our code reviews, gives some advice on how to conduct them, and provides an excalation channel for any kernel developers if they so desire it" [ Let's see how this works ] * tag 'cc-4.0-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Code of Conflict
2015-03-07Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "A set of updates and bugfixes for the new designware-baytrail driver. And a documentation bugfix" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: imx: add required clocks property to binding i2c: designware-baytrail: baytrail_i2c_acquire() might sleep i2c: designware-baytrail: cross-check lock functions i2c: designware-baytrail: fix sparse warnings i2c: designware-baytrail: fix typo in error path i2c: designware-baytrail: describe magic numbers
2015-03-07serial: 8250_dw: Fix get_mctrl behaviourDesmond Liu
Fixed behaviour of get_mctrl() serial driver function as documented in: https://www.kernel.org/doc/Documentation/serial/driver Added device-tree properties 'dcd-override', 'dsr-override', 'cts-override', and 'ri-override' specific to the Synopsis 8250 DesignWare UART driver. Allows one to force Data Carrier Detect, Clear To Send, and Data Set Ready signals to permanently be reported as active. The Ring indicator can be forced to be reported as inactive. It is possible that if modem control signalling is enabled on a port that doesn't have these pins (e.g. - a simple two wire Tx/Rx port), the driver can hang indefinitely waiting for the state to change. The new DT properties allow the driver to ignore the state of these pins on serial ports that don't support them, as recommended in the kernel documentation. Reviewed-by: JD (Jiandong) Zheng <jdzheng@broadcom.com> Signed-off-by: Jonathan Richardson <jonathar@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07i2c: imx: add required clocks property to bindingMatt Porter
A clock specifier is required for i.MX I2C and is provided in all DTS implementations. Add this to the list of required properties in the binding. Signed-off-by: Matt Porter <mporter@konsulko.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-03-06Merge tag 'pm+acpi-4.0-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "These are fixes for recent regressions (ACPI resources management, suspend-to-idle), stable-candidate fixes (ACPI backlight), fixes related to the wakeup IRQ management changes made in v3.18, other fixes (suspend-to-idle, cpufreq ppc driver) and a couple of cleanups (suspend-to-idle, generic power domains, ACPI backlight). Specifics: - Fix ACPI resources management problems introduced by the recent rework of the code in question (Jiang Liu) and a build issue introduced by those changes (Joachim Nilsson). - Fix a recent suspend-to-idle regression on systems where entering idle states causes local timers to stop, prevent suspend-to-idle from crashing in restricted configurations (no cpuidle driver, cpuidle disabled etc.) and clean up the idle loop somewhat while at it (Rafael J Wysocki). - Fix build problem in the cpufreq ppc driver (Geert Uytterhoeven). - Allow the ACPI backlight driver module to be loaded if ACPI is disabled which helps the i915 driver in those configurations (stable-candidate) and change the code to help debug unusual use cases (Chris Wilson). - Wakeup IRQ management changes in v3.18 caused some drivers on the at91 platform to trigger a warning from the IRQ core related to an unexpected combination of interrupt action handler flags. However, on at91 a timer IRQ is shared with some other devices (including system wakeup ones) and that leads to the unusual combination of flags in question. To make it possible to avoid the warning introduce a new interrupt action handler flag (which can be used by drivers to indicate the special case to the core) and rework the problematic at91 drivers to use it and work as expected during system suspend/resume. From Boris Brezillon, Rafael J Wysocki and Mark Rutland. - Clean up the generic power domains subsystem's debugfs interface (Kevin Hilman)" * tag 'pm+acpi-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: genirq / PM: describe IRQF_COND_SUSPEND tty: serial: atmel: rework interrupt and wakeup handling watchdog: at91sam9: request the irq with IRQF_NO_SUSPEND cpuidle / sleep: Use broadcast timer for states that stop local timer clk: at91: implement suspend/resume for the PMC irqchip rtc: at91rm9200: rework wakeup and interrupt handling rtc: at91sam9: rework wakeup and interrupt handling PM / wakeup: export pm_system_wakeup symbol genirq / PM: Add flag for shared NO_SUSPEND interrupt lines ACPI / video: Propagate the error code for acpi_video_register ACPI / video: Load the module even if ACPI is disabled PM / Domains: cleanup: rename gpd -> genpd in debugfs interface cpufreq: ppc: Add missing #include <asm/smp.h> x86/PCI/ACPI: Relax ACPI resource descriptor checks to work around BIOS bugs x86/PCI/ACPI: Ignore resources consumed by host bridge itself cpuidle: Clean up fallback handling in cpuidle_idle_call() cpuidle / sleep: Do sanity checks in cpuidle_enter_freeze() too idle / sleep: Avoid excessive disabling and enabling interrupts PCI: versatile: Update for list_for_each_entry() API change genirq / PM: better describe IRQF_NO_SUSPEND semantics
2015-03-06Merge branch 'irq-pm'Rafael J. Wysocki
* irq-pm: genirq / PM: describe IRQF_COND_SUSPEND tty: serial: atmel: rework interrupt and wakeup handling watchdog: at91sam9: request the irq with IRQF_NO_SUSPEND clk: at91: implement suspend/resume for the PMC irqchip rtc: at91rm9200: rework wakeup and interrupt handling rtc: at91sam9: rework wakeup and interrupt handling PM / wakeup: export pm_system_wakeup symbol genirq / PM: Add flag for shared NO_SUSPEND interrupt lines genirq / PM: better describe IRQF_NO_SUSPEND semantics
2015-03-06genirq / PM: describe IRQF_COND_SUSPENDMark Rutland
With certain restrictions it is possible for a wakeup device to share an IRQ with an IRQF_NO_SUSPEND user, and the warnings introduced by commit cab303be91dc47942bc25de33dc1140123540800 are spurious. The new IRQF_COND_SUSPEND flag allows drivers to tell the core when these restrictions are met, allowing spurious warnings to be silenced. This patch documents how IRQF_COND_SUSPEND is expected to be used, updating some of the text now made invalid by its addition. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-03-04Documentation: dts: Update compatible field description for APM X-GeneIyappan Subramanian
Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: Keyur Chudgar <kchudgar@apm.com> Tested-by: Mark Langsdorf <mlangsdo@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-04Merge tag 'at91-fixes' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91 into fixes Merge "First fixes batch for AT91 on 4.0" from Nicolas Ferre: - PM slowclock fixes for DDR and timeouts - fix some DT entries - little defconfig updates - the removal of a harmful watchdog option + its detailed documentation * tag 'at91-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91: ARM: at91/dt: keep watchdog running in idle mode dts: Documentation: AT91 Watchdog, explain what atmel,idle-halt property really do ARM: at91/defconfig: add at91rm9200 ethernet support ARM: at91/defconfig: remove CONFIG_SYSFS_DEPRECATED ARM: at91/dt: at91sam9260: fix usart pinctrl ARM: at91/dt: sama5d4: add missing alias for i2c0 ARM: at91/dt: at91sam9263: Fixup sram1 device tree node ARM: at91: pm: fix SRAM allocation ARM: at91: pm: fix at91rm9200 standby pm: at91: Workaround DDRSDRC self-refresh bug with LPDDR1 memories. pm: at91: pm_slowclock: fix suspend/resume hang up in timeouts
2015-03-04Merge tag 'samsung-fixes-dt' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes Merge "Samsung tmu and hdmi regression fixes for v4.0" from Kukjin Kim: - The thermal management unit and HDMI (drm mixer driver) related reworks have been merged in v4.0 merge window. So if this DT changes are missed for v4.0, we regressions in v4.0 release for exynos platforms such as exynos5250, exynos5420, exynos4 SoCs. - Note since there was a dependency with driver side, this cannot be sent to upstream during preivous merge window and now it has been resolved. * tag 'samsung-fixes-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: dts: add display power domain for exynos5250 ARM: dts: add 'hdmi' clock to mixer nodes for exynos5250 and exynos5420 ARM: dts: enable hdmi support for exynos4210-universal_c210 ARM: dts: enable hdmi support for exynos4412-odroid-common ARM: dts: add dependency between TV and LCD0 power domains for exynos4 ARM: dts: add hdmi related nodes for exynos4 SoCs ARM: EXYNOS: add support for sub-power domains dt-bindings: document a note about power domain subdomains ARM: dts: Provide dt bindings identical for Exynos TMU ARM: dts: Trip points and sensor configuration data for exynos5440 ARM: dts: define default thermal-zones for exynos4 ARM: dts: default trip points definition for exynos5420 ARM: dts: add TMU default definitions for exynos4412 ARM: dts: Adding CPU cooling binding for Exynos SoCs ARM: dts: Enable TMU for exynos4412-odriod-common ARM: dts: Add LDO10 for TMU for exynos4412-odroid-common ARM: dts: Enable TMU for exynos4210-trats
2015-03-04dts: Documentation: AT91 Watchdog, explain what atmel,idle-halt property ↵Sylvain Rochet
really do atmel,idle-halt property should be used with care, it actually makes the watchdog not counting when the CPU is in idle state, therefore the watchdog reset time depends on mean CPU usage and will not reset at all of the CPU stop working while it is in idle state, which is probably not what you want. Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If an IPVS tunnel is created with a mixed-family destination address, it cannot be removed. Fix from Alexey Andriyanov. 2) Fix module refcount underflow in netfilter's nft_compat, from Pablo Neira Ayuso. 3) Generic statistics infrastructure can reference variables sitting on a released function stack, therefore use dynamic allocation always. Fix from Ignacy Gawędzki. 4) skb_copy_bits() return value test is inverted in ip_check_defrag(). 5) Fix network namespace exit in openvswitch, we have to release all of the per-net vports. From Pravin B Shelar. 6) Fix signedness bug in CAIF's cfpkt_iterate(), from Dan Carpenter. 7) Fix rhashtable grow/shrink behavior, only expand during inserts and shrink during deletes. From Daniel Borkmann. 8) Netdevice names with semicolons should never be allowed, because they serve as a separator. From Matthew Thode. 9) Use {,__}set_current_state() where appropriate, from Fabian Frederick. 10) Revert byte queue limits support in r8169 driver, it's causing regressions we can't figure out. 11) tcp_should_expand_sndbuf() erroneously uses tp->packets_out to measure packets in flight, properly use tcp_packets_in_flight() instead. From Neal Cardwell. 12) Fix accidental removal of support for bluetooth in CSR based Intel wireless cards. From Marcel Holtmann. 13) We accidently added a behavioral change between native and compat tasks, wrt testing the MSG_CMSG_COMPAT bit. Just ignore it if the user happened to set it in a native binary as that was always the behavior we had. From Catalin Marinas. 14) Check genlmsg_unicast() return valud in hwsim netlink tx frame handling, from Bob Copeland. 15) Fix stale ->radar_required setting in mac80211 that can prevent starting new scans, from Eliad Peller. 16) Fix memory leak in nl80211 monitor, from Johannes Berg. 17) Fix race in TX index handling in xen-netback, from David Vrabel. 18) Don't enable interrupts in amx-xgbe driver until all software et al. state is ready for the interrupt handler to run. From Thomas Lendacky. 19) Add missing netlink_ns_capable() checks to rtnl_newlink(), from Eric W Biederman. 20) The amount of header space needed in macvtap was not calculated properly, fix it otherwise we splat past the beginning of the packet. From Eric Dumazet. 21) Fix bcmgenet TCP TX perf regression, from Jaedon Shin. 22) Don't raw initialize or mod timers, use setup_timer() and mod_timer() instead. From Vaishali Thakkar. 23) Fix software maintained statistics in bcmgenet and systemport drivers, from Florian Fainelli. 24) DMA descriptor updates in sh_eth need proper memory barriers, from Ben Hutchings. 25) Don't do UDP Fragmentation Offload on RAW sockets, from Michal Kubecek. 26) Openvswitch's non-masked set actions aren't constructed properly into netlink messages, fix from Joe Stringer. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) openvswitch: Fix serialization of non-masked set actions. gianfar: Reduce logging noise seen due to phy polling if link is down ibmveth: Add function to enable live MAC address changes net: bridge: add compile-time assert for cb struct size udp: only allow UFO for packets from SOCK_DGRAM sockets sh_eth: Really fix padding of short frames on TX Revert "sh_eth: Enable Rx descriptor word 0 shift for r8a7790" sh_eth: Fix RX recovery on R-Car in case of RX ring underrun sh_eth: Ensure proper ordering of descriptor active bit write/read net/mlx4_en: Disbale GRO for incoming loopback/selftest packets net/mlx4_core: Fix wrong mask and error flow for the update-qp command net: systemport: fix software maintained statistics net: bcmgenet: fix software maintained statistics rxrpc: don't multiply with HZ twice rxrpc: terminate retrans loop when sending of skb fails net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR interface. net: pasemi: Use setup_timer and mod_timer net: stmmac: Use setup_timer and mod_timer net: 8390: axnet_cs: Use setup_timer and mod_timer net: 8390: pcnet_cs: Use setup_timer and mod_timer ...
2015-03-02serial: add device tree binding documentation for ETRAX FS UARTNiklas Cassel
Signed-off-by: Niklas Cassel <nks@flawful.org> Signed-off-by: Rob Herring <robh@kernel.org>
2015-03-02of: Add vendor prefix for ArasanMichal Simek
PATA(pata_arasan_cf.c) and SDHCI(sdhci-of-arasan.c) drivers are already using this prefix. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Rob Herring <robh@kernel.org>
2015-02-28mm: memcontrol: use "max" instead of "infinity" in control knobsJohannes Weiner
The memcg control knobs indicate the highest possible value using the symbolic name "infinity", which is long and awkward to type. Switch to the string "max", which is just as descriptive but shorter and sweeter. This changes a user interface, so do it before the release and before the development flag is dropped from the default hierarchy. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28ocfs2: update web page + git tree in documentationMark Fasheh
We (the Ocfs2 project) recently moved the location of our ocfs2-tools git tree and project web page. The pertinent discussion can be seen here: https://oss.oracle.com/pipermail/ocfs2-devel/2015-February/010579.html The following patch updates the Ocfs2 documentation in MAINTAINERS, ocfs2.txt, and dlmfs.txt. I added our new official web page, changed the location of our tools git tree and removed the link to Joel's ancient kernel git tree - Andrew has handled our patches for a while now. Signed-off-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-27Code of ConflictGreg Kroah-Hartman
This file provides a basic guide for how to handle conflict resolution when it comes up in the development process. Acked-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Arjan van de Ven <arjanvandeven@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Chris Ball <chris@printf.net> Acked-by: Chris Mason <clm@fb.com> Acked-by: Chris Metcalf <cmetcalf@ezchip.com> Acked-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Fabio Estevam <festevam@gmail.com> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Gerd Hoffmann <kraxel@redhat.com> Acked-by: Grant Likely <grant.likely@linaro.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Hannes Reinecke <hare@suse.de> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Jaegeuk Kim <jaegeuk@kernel.org> Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Acked-by: Jens Axboe <axboe@kernel.dk> Acked-by: Jes Sorensen <Jes.Sorensen@gmail.com> Acked-by: Johan Hedberg <johan.hedberg@intel.com> Acked-by: Johan Hovold <johan@kernel.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: John W. Linville <linville@tuxdriver.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Kevin Hilman <khilman@linaro.org> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Kristen Carlson Accardi <kristen@linux.intel.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Mark Brown <broonie@kernel.org> Acked-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: NeilBrown <neilb@suse.de> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Rafael J. Wysocki <rafael@kernel.org> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Sachin Prabhu <sprabhu@redhat.com> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Acked-by: Simon Horman <horms@verge.net.au> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Willy Tarreau <w@1wt.eu> Acked-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-27ARM: EXYNOS: add support for sub-power domainsMarek Szyprowski
This patch adds support for making one power domain a sub-domain of other domain. This is useful for modeling power dependences for devices like TV Mixer or Camera ISP, which needs to have more than one power domain enabled to be operational. Based on previous work by Amit Daniel Kachhap <amit.daniel@samsung.com>. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-02-27dt-bindings: document a note about power domain subdomainsMarek Szyprowski
This patch adds a note on defining subdomains to generic PM domain binding documentation to let power domain providers use common approach for defining power domain hierarchy. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-02-26genirq / PM: better describe IRQF_NO_SUSPEND semanticsMark Rutland
The IRQF_NO_SUSPEND flag is intended to be used for interrupts required to be enabled during the suspend-resume cycle. This mostly consists of IPIs and timer interrupts, potentially including chained irqchip interrupts if these are necessary to handle timers or IPIs. If an interrupt does not fall into one of the aforementioned categories, requesting it with IRQF_NO_SUSPEND is likely incorrect. Using IRQF_NO_SUSPEND does not guarantee that the interrupt can wake the system from a suspended state. For an interrupt to be able to trigger a wakeup, it may be necessary to program various components of the system. In these cases it is necessary to use {enable,disabled}_irq_wake. Unfortunately, several drivers assume that IRQF_NO_SUSPEND ensures that an IRQ can wake up the system, and the documentation can be read ambiguously w.r.t. this property. This patch updates the documentation regarding IRQF_NO_SUSPEND to make this caveat explicit, hopefully making future misuse rarer. Cleanup of existing misuse will occur as part of later patch series. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-25amd-xgbe-phy: PHY KX/KR mode differencesTom Lendacky
The PHY requires different settings for the Decision Feedback Analyzer (DFE) when running in KX mode vs. KR mode. Update the code to change these settings when changing modes in order to provide a more stable link. Additionally, adjust the 10GbE PQ skew default setting to a more sane value. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-22Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted stuff from this cycle. The big ones here are multilayer overlayfs from Miklos and beginning of sorting ->d_inode accesses out from David" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits) autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation procfs: fix race between symlink removals and traversals debugfs: leave freeing a symlink body until inode eviction Documentation/filesystems/Locking: ->get_sb() is long gone trylock_super(): replacement for grab_super_passive() fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry) SELinux: Use d_is_positive() rather than testing dentry->d_inode Smack: Use d_is_positive() rather than testing dentry->d_inode TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR() Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb VFS: Split DCACHE_FILE_TYPE into regular and special types VFS: Add a fallthrough flag for marking virtual dentries VFS: Add a whiteout dentry type VFS: Introduce inode-getting helpers for layered/unioned fs environments Infiniband: Fix potential NULL d_inode dereference posix_acl: fix reference leaks in posix_acl_create autofs4: Wrong format for printing dentry ...
2015-02-22Documentation/filesystems/Locking: ->get_sb() is long goneAl Viro
2015-02-21Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS: - a number of fixes that didn't make the 3.19 release. - a number of cleanups. - preliminary support for Cavium's Octeon 3 SOCs which feature up to 48 MIPS64 R3 cores with FPU and hardware virtualization. - support for MIPS R6 processors. Revision 6 of the MIPS architecture is a major revision of the MIPS architecture which does away with many of original sins of the architecture such as branch delay slots. This and other changes in R6 require major changes throughout the entire MIPS core architecture code and make up for the lion share of this pull request. - finally some preparatory work for eXtendend Physical Address support, which allows support of up to 40 bit of physical address space on 32 bit processors" [ Ahh, MIPS can't leave the PAE brain damage alone. It's like every CPU architect has to make that mistake, but pee in the snow by changing the TLA. But whether it's called PAE, LPAE or XPA, it's horrid crud - Linus ] * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (114 commits) MIPS: sead3: Corrected get_c0_perfcount_int MIPS: mm: Remove dead macro definitions MIPS: OCTEON: irq: add CIB and other fixes MIPS: OCTEON: Don't do acknowledge operations for level triggered irqs. MIPS: OCTEON: More OCTEONIII support MIPS: OCTEON: Remove setting of processor specific CVMCTL icache bits. MIPS: OCTEON: Core-15169 Workaround and general CVMSEG cleanup. MIPS: OCTEON: Update octeon-model.h code for new SoCs. MIPS: OCTEON: Implement DCache errata workaround for all CN6XXX MIPS: OCTEON: Add little-endian support to asm/octeon/octeon.h MIPS: OCTEON: Implement the core-16057 workaround MIPS: OCTEON: Delete unused COP2 saving code MIPS: OCTEON: Use correct instruction to read 64-bit COP0 register MIPS: OCTEON: Save and restore CP2 SHA3 state MIPS: OCTEON: Fix FP context save. MIPS: OCTEON: Save/Restore wider multiply registers in OCTEON III CPUs MIPS: boot: Provide more uImage options MIPS: Remove unneeded #ifdef __KERNEL__ from asm/processor.h MIPS: ip22-gio: Remove legacy suspend/resume support mips: pci: Add ifdef around pci_proc_domain ...
2015-02-21Merge tag 'dm-3.20-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull more device mapper changes from Mike Snitzer: - Significant dm-crypt CPU scalability performance improvements thanks to changes that enable effective use of an unbound workqueue across all available CPUs. A large battery of tests were performed to validate these changes, summary of results is available here: https://www.redhat.com/archives/dm-devel/2015-February/msg00106.html - A few additional stable fixes (to DM core, dm-snapshot and dm-mirror) and a small fix to the dm-space-map-disk. * tag 'dm-3.20-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm snapshot: fix a possible invalid memory access on unload dm: fix a race condition in dm_get_md dm crypt: sort writes dm crypt: add 'submit_from_crypt_cpus' option dm crypt: offload writes to thread dm crypt: remove unused io_pool and _crypt_io_pool dm crypt: avoid deadlock in mempools dm crypt: don't allocate pages for a partial request dm crypt: use unbound workqueue for request processing dm io: reject unsupported DISCARD requests with EOPNOTSUPP dm mirror: do not degrade the mirror on discard error dm space map disk: fix sm_disk_count_is_more_than_one()
2015-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull more input updates from Dmitry Torokhov: "The second round of updates for the input subsystem. Updates to ALPS an bfin_roraty drivers and a couple oother fixups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: psmouse - use IS_ENABLED instead of homegrown code Input: bfin_rotary - introduce open and close methods Input: bfin_rotary - convert to use managed resources Input: bfin_rotary - use generic IO functions Input: bfin_rotary - move pin lists into into platform data Input: bfin_rotary - move platform header to linux/platform_data Input: bfin_rotary - mark suspend and resume code as __maybe_unused Input: bfin_rotary - fix potential oops in interrupt handler Input: ALPS - move v7 packet info to Documentation and v6 packet info Input: ALPS - fix confusing comment in protocol data Input: ALPS - do not mix trackstick and external PS/2 mouse data Input: ALPS - fix trackstick detection on some Dell Latitudes Input: ALPS - consolidate setting protocol parameters Input: ALPS - split protocol data from model info Input: ALPS - make Rushmore a separate protocol Input: ALPS - renumber protocol numbers Input: adi - remove an unnecessary check Input: pxa27x_keypad - remove an unneeded NULL check Input: soc_button_array - use "Windows" key for "Home"
