path: root/Documentation
2014-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "overlayfs merge + leak fix for d_splice_alias() failure exits" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: overlayfs: embed middle into overlay_readdir_data overlayfs: embed root into overlay_readdir_data overlayfs: make ovl_cache_entry->name an array instead of pointer overlayfs: don't hold ->i_mutex over opening the real directory fix inode leaks on d_splice_alias() failure exits fs: limit filesystem stacking depth overlay: overlay filesystem documentation overlayfs: implement show_options overlayfs: add statfs support overlay filesystem shmem: support RENAME_WHITEOUT ext4: support RENAME_WHITEOUT vfs: add RENAME_WHITEOUT vfs: add whiteout support vfs: export check_sticky() vfs: introduce clone_private_mount() vfs: export __inode_permission() to modules vfs: export do_splice_direct() to modules vfs: add i_op->dentry_open()
2014-10-24Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - enable 48-bit VA space now that KVM has been fixed, together with a couple of fixes for pgd allocation alignment and initial memblock current_limit. There is still a dependency on !ARM_SMMU which needs to be updated as it uses the page table manipulation macros of the host kernel - eBPF fixes following changes/conflicts during the merging window - Compat types affecting compat_elf_prpsinfo - Compilation error on UP builds - ASLR fix when /proc/sys/kernel/randomize_va_space == 0 - DT definitions for CLCD support on ARMv8 model platform * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: Fix memblock current_limit with 64K pages and 48-bit VA arm64: ASLR: Don't randomise text when randomise_va_space == 0 arm64: vexpress: Add CLCD support to the ARMv8 model platform arm64: Fix compilation error on UP builds Documentation/arm64/memory.txt: fix typo net: bpf: arm64: minor fix of type in jited arm64: bpf: add 'load 64-bit immediate' instruction arm64: bpf: add 'shift by register' instructions net: bpf: arm64: address randomize and write protect JIT code arm64: mm: Correct fixmap pagetable types arm64: compat: fix compat types affecting struct compat_elf_prpsinfo arm64: Align less than PAGE_SIZE pgds naturally arm64: Allow 48-bits VA space without ARM_SMMU
2014-10-24Merge tag 'pm+acpi-3.18-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This is material that didn't make it to my 3.18-rc1 pull request for various reasons, mostly related to timing and travel (LinuxCon EU / LPC) plus a couple of fixes for recent bugs. The only really new thing here is the PM QoS class for memory bandwidth, but it is simple enough and users of it will be added in the next cycle. One major change in behavior is that platform devices enumerated by ACPI will use 32-bit DMA mask by default. Also included is an ACPICA update to a new upstream release, but that's mostly cleanups, changes in tools and similar. The rest is fixes and cleanups mostly. Specifics: - Fix for a recent PCI power management change that overlooked the fact that some IRQ chips might not be able to configure PCIe PME for system wakeup from Lucas Stach. - Fix for a bug introduced in 3.17 where acpi_device_wakeup() is called with a wrong ordering of arguments from Zhang Rui. - A bunch of intel_pstate driver fixes (all -stable candidates) from Dirk Brandewie, Gabriele Mazzotta and Pali Rohár. - Fixes for a rather long-standing problem with the OOM killer and the freezer that frozen processes killed by the OOM do not actually release any memory until they are thawed, so OOM-killing them is rather pointless, with a couple of cleanups on top (Michal Hocko, Cong Wang, Rafael J Wysocki). - ACPICA update to upstream release 20140926, inlcuding mostly cleanups reducing differences between the upstream ACPICA and the kernel code, tools changes (acpidump, acpiexec) and support for the _DDN object (Bob Moore, Lv Zheng). - New PM QoS class for memory bandwidth from Tomeu Vizoso. - Default 32-bit DMA mask for platform devices enumerated by ACPI (this change is mostly needed for some drivers development in progress targeted at 3.19) from Heikki Krogerus. - ACPI EC driver cleanups, mostly related to debugging, from Lv Zheng. - cpufreq-dt driver updates from Thomas Petazzoni. - powernv cpuidle driver update from Preeti U Murthy" * tag 'pm+acpi-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (34 commits) intel_pstate: Correct BYT VID values. intel_pstate: Fix BYT frequency reporting intel_pstate: Don't lose sysfs settings during cpu offline cpufreq: intel_pstate: Reflect current no_turbo state correctly cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy PCI / PM: handle failure to enable wakeup on PCIe PME ACPI: invoke acpi_device_wakeup() with correct parameters PM / freezer: Clean up code after recent fixes PM: convert do_each_thread to for_each_process_thread OOM, PM: OOM killed task shouldn't escape PM suspend freezer: remove obsolete comments in __thaw_task() freezer: Do not freeze tasks killed by OOM killer ACPI / platform: provide default DMA mask cpuidle: powernv: Populate cpuidle state details by querying the device-tree cpufreq: cpufreq-dt: adjust message related to regulators cpufreq: cpufreq-dt: extend with platform_data cpufreq: allow driver-specific data ACPI / EC: Cleanup coding style. ACPI / EC: Refine event/query debugging messages. ...
2014-10-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "Sorry that I missed the merge window as there is a bug found in the last minute, and I have to fix it and wait for the code to be tested in linux-next tree for a few days. Now the buggy patch has been dropped entirely from my next branch. Thus I hope those changes can still be merged in 3.18-rc2 as most of them are platform thermal driver changes. Specifics: - introduce ACPI INT340X thermal drivers. Newer laptops and tablets may have thermal sensors and other devices with thermal control capabilities that are exposed for the OS to use via the ACPI INT340x device objects. Several drivers are introduced to expose the temperature information and cooling ability from these objects to user-space via the normal thermal framework. From: Lu Aaron, Lan Tianyu, Jacob Pan and Zhang Rui. - introduce a new thermal governor, which just uses a hysteresis to switch abruptly on/off a cooling device. This governor can be used to control certain fan devices that can not be throttled but just switched on or off. From: Peter Feuerer. - introduce support for some new thermal interrupt functions on i.MX6SX, in IMX thermal driver. From: Anson, Huang. - introduce tracing support on thermal framework. From: Punit Agrawal. - small fixes in OF thermal and thermal step_wise governor" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (25 commits) Thermal: int340x thermal: select ACPI fan driver Thermal: int3400_thermal: use acpi_thermal_rel parsing APIs Thermal: int340x_thermal: expose acpi thermal relationship tables Thermal: introduce int3403 thermal driver Thermal: introduce INT3402 thermal driver Thermal: move the KELVIN_TO_MILLICELSIUS macro to thermal.h ACPI / Fan: support INT3404 thermal device ACPI / Fan: add ACPI 4.0 style fan support ACPI / fan: convert to platform driver ACPI / fan: use acpi_device_xxx_power instead of acpi_bus equivelant ACPI / fan: remove no need check for device pointer ACPI / fan: remove unused macro Thermal: int3400 thermal: register to thermal framework Thermal: int3400 thermal: add capability to detect supporting UUIDs Thermal: introduce int3400 thermal driver ACPI: add ACPI_TYPE_LOCAL_REFERENCE support to acpi_extract_package() ACPI: make acpi_create_platform_device() an external API thermal: step_wise: fix: Prevent from binary overflow when trend is dropping ACPI: introduce ACPI int340x thermal scan handler thermal: Added Bang-bang thermal governor ...
2014-10-24overlay: overlay filesystem documentationNeil Brown
Document the overlay filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: add i_op->dentry_open()Miklos Szeredi
Add a new inode operation i_op->dentry_open(). This is for stacked filesystems that want to return a struct file from a different filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-23Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI updates from Peter Anvin: "This patchset falls under the "maintainers that grovel" clause in the v3.18-rc1 announcement. We had intended to push it late in the merge window since we got it into the -tip tree relatively late. Many of these are relatively simple things, but there are a couple of key bits, especially Ard's and Matt's patches" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) rtc: Disable EFI rtc for x86 efi: rtc-efi: Export platform:rtc-efi as module alias efi: Delete the in_nmi() conditional runtime locking efi: Provide a non-blocking SetVariable() operation x86/efi: Adding efi_printks on memory allocationa and pci.reads x86/efi: Mark initialization code as such x86/efi: Update comment regarding required phys mapped EFI services x86/efi: Unexport add_efi_memmap variable x86/efi: Remove unused efi_call* macros efi: Resolve some shadow warnings arm64: efi: Format EFI memory type & attrs with efi_md_typeattr_format() ia64: efi: Format EFI memory type & attrs with efi_md_typeattr_format() x86: efi: Format EFI memory type & attrs with efi_md_typeattr_format() efi: Introduce efi_md_typeattr_format() efi: Add macro for EFI_MEMORY_UCE memory attribute x86/efi: Clear EFI_RUNTIME_SERVICES if failing to enter virtual mode arm64/efi: Do not enter virtual mode if booting with efi=noruntime or noefi arm64/efi: uefi_init error handling fix efi: Add kernel param efi=noruntime lib: Add a generic cmdline parse function parse_option_str ...
2014-10-23Merge branch 'pm-qos'Rafael J. Wysocki
* pm-qos: PM / QoS: Add PM_QOS_MEMORY_BANDWIDTH class
2014-10-21Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Here are the target updates for v3.18-rc2 code. These where originally destined for -rc1, but due to the combination of travel last week for KVM Forum and my mistake of taking the three week merge window literally, the pull request slipped.. Apologies for that. Things where reasonably quiet this round. The highlights include: - New userspace backend driver (target_core_user.ko) by Shaohua Li and Andy Grover - A number of cleanups in target, iscsi-taret and qla_target code from Joern Engel - Fix an OOPs related to queue full handling with CHECK_CONDITION status from Quinn Tran - Fix to disable TX completion interrupt coalescing in iser-target, that was causing problems on some hardware - Fix for PR APTPL metadata handling with demo-mode ACLs I'm most excited about the new backend driver that uses UIO + shared memory ring to dispatch I/O and control commands into user-space. This was probably the most requested feature by users over the last couple of years, and opens up a new area of development + porting of existing user-space storage applications to LIO. Thanks to Shaohua + Andy for making this happen. Also another honorable mention, a new Xen PV SCSI driver was merged via the xen/tip.git tree recently, which puts us now at 10 target drivers in upstream! Thanks to David Vrabel + Juergen Gross for their work to get this code merged" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (40 commits) target/file: fix inclusive vfs_fsync_range() end iser-target: Disable TX completion interrupt coalescing target: Add force_pr_aptpl device attribute target: Fix APTPL metadata handling for dynamic MappedLUNs qla_target: don't delete changed nacls target/user: Recalculate pad size inside is_ring_space_avail() tcm_loop: Fixup tag handling iser-target: Fix smatch warning target/user: Fix up smatch warnings in tcmu_netlink_event target: Add a user-passthrough backstore target: Add documentation on the target userspace pass-through driver uio: Export definition of struct uio_device target: Remove unneeded check in sbc_parse_cdb target: Fix queue full status NULL pointer for SCF_TRANSPORT_TASK_SENSE qla_target: rearrange struct qla_tgt_prm qla_target: improve qlt_unmap_sg() qla_target: make some global functions static qla_target: remove unused parameter target: simplify core_tmr_abort_task target: encapsulate smp_mb__after_atomic() ...
2014-10-21Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull email address change from Boaz Harrosh. * 'for-linus' of git://git.open-osd.org/linux-open-osd: Boaz Harrosh - fix email in Documentation Boaz Harrosh - Fix broken email address MAINTAINERS: Change Boaz Harrosh's email
2014-10-21Merge branch 'mailbox-for-linus' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox framework from Jassi Brar: "A framework for Mailbox controllers and clients have been cooking for more than a year now. Everybody in the CC list had been copied on patchset revisions and most of them have made sounds of approval, though just one concrete Reviewed-by. The patchset has also been in linux-next for a couple of weeks now and no conflict has been reported. The framework has the backing of at least 5 platforms, though I can't say if/when they upstream their drivers (some businesses have 'changed')" (Further acked-by by Arnd Bergmann and Suman Anna in the pull request thread) * 'mailbox-for-linus' of git://git.linaro.org/landing-teams/working/fujitsu/integration: dt: mailbox: add generic bindings doc: add documentation for mailbox framework mailbox: Introduce framework for mailbox mailbox: rename pl320-ipc specific mailbox.h
2014-10-21Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - new Cadence WDT driver - new Ricoh RN5T618 watchdog - new DA9063 PMIC watchdog driver - new Meson WDT driver - add restart handling code - fixes and improvements * git://www.linux-watchdog.org/linux-watchdog: (25 commits) watchdog: meson: remove magic value for reboot watchdog: Let XILINX_WATCHDOG and TEGRA_WATCHDOG depend on HAS_IOMEM watchdog: sunxi: Add A31 watchdog support watchdog: sunxi: support parameterized compatible strings watchdog: imx2_wdt: add restart handler support watchdog: qcom: register a restart notifier watchdog: s3c2410: add restart handler watchdog: dw_wdt: add restart handler support ARM: defconfig: update multi_v7_defconfig ARM: meson: add watchdog driver ARM: docs: add documentation binding for meson watchdog stmp3xxx_rtc_wdt: Add suspend/resume PM support watchdog: Add DA9063 PMIC watchdog driver. watchdog: add driver for Ricoh RN5T618 watchdog watchdog: s3c2410_wdt: Add support for Watchdog device on Exynos7 watchdog: qcom: document device tree bindings watchdog: qcom: add support for KPSS WDT watchdog: dw_wdt: initialise TOP_INIT in dw_wdt_set_top() devicetree: Add Cadence WDT devicetree bindings documentation watchdog: Add Cadence WDT driver ...
2014-10-21Merge tag 'pwm/for-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "There are no new drivers here, only a couple of fixes all over the place" * tag 'pwm/for-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: Let PWM_CLPS711X depend on HAS_IOMEM pwm: atmel: Fix calculation of prescale value pwm: Fix uninitialized warnings in pwm_get() pwm: rockchip: Allow polarity invert on rk3288 pwm: imx: Avoid sample FIFO overflow for i.MX PWM version2 pwm: imx: Cleanup indentation for register definitions pwm: imx: Fix the macro MX3_PWMCR_PRESCALER(x) definition pwm: Fix possible ZERO_SIZE_PTR pointer dereferencing error. pwm: lpss: make it buildable only on X86 pwm: lpss: use c99 initializers in structures pwm: lpss: Fix build failure on PowerPC pwm: lpss: pci: Move to use pcim_enable_device() pwm: lpss: Properly split driver to parts pwm: lpss: Add ACPI and PCI IDs for Intel Braswell pwm: fsl-ftm: Select REGMAP_MMIO pwm: fsl-ftm: Document 'big-endian' property pwm: fsl-ftm: Convert to direct regmap API usage pwm: fsl-ftm: Clean up the code
2014-10-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull more powerpc updates from Michael Ellerman: "Here's some more updates for powerpc for 3.18. They are a bit late I know, though must are actually bug fixes. In my defence I nearly cut the top of my finger off last weekend in a gruesome bike maintenance accident, so I spent a good part of the week waiting around for doctors. True story, I can send photos if you like :) Probably the most interesting fix is the sys_call_table one, which enables syscall tracing for powerpc. There's a fix for HMI handling for old firmware, more endian fixes for firmware interfaces, more EEH fixes, Anton fixed our routine that gets the current stack pointer, and a few other misc bits" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (22 commits) powerpc: Only do dynamic DMA zone limits on platforms that need it powerpc: sync pseries_le_defconfig with pseries_defconfig powerpc: Add printk levels to setup_system output powerpc/vphn: NUMA node code expects big-endian powerpc/msi: Use WARN_ON() in msi bitmap selftests powerpc/msi: Fix the msi bitmap alignment tests powerpc/eeh: Block CFG upon frozen Shiner adapter powerpc/eeh: Don't collect logs on PE with blocked config space powerpc/eeh: Block PCI config access upon frozen PE powerpc/pseries: Drop config requests in EEH accessors powerpc/powernv: Drop config requests in EEH accessors powerpc/eeh: Rename flag EEH_PE_RESET to EEH_PE_CFG_BLOCKED powerpc/eeh: Fix condition for isolated state powerpc/pseries: Make CPU hotplug path endian safe powerpc/pseries: Use dump_stack instead of show_stack powerpc: Rename __get_SP() to current_stack_pointer() powerpc: Reimplement __get_SP() as a function not a define powerpc/numa: Add ability to disable and debug topology updates powerpc/numa: check error return from proc_create powerpc/powernv: Fallback to old HMI handling behavior for old firmware ...
2014-10-20ARM: docs: add documentation binding for meson watchdogCarlo Caione
Signed-off-by: Carlo Caione <carlo@caione.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-10-20watchdog: s3c2410_wdt: Add support for Watchdog device on Exynos7Naveen Krishna Chatradhi
Exynos7 SoC has a Watchdog for Atlas (A57) cores This patch adds support for the Atlas watchdog. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-10-20watchdog: qcom: document device tree bindingsJosh Cartwright
The Qualcomm Krait Processor Sub-system (KPSS) contains one or more instances of the WDT. Provide documentation on how to describe these in the device tree. Signed-off-by: Josh Cartwright <joshc@codeaurora.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-10-20devicetree: Add Cadence WDT devicetree bindings documentationHarini Katakam
Add cadence-wdt bindings documentation. Signed-off-by: Harini Katakam <harinik@xilinx.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-10-20watchdog: imx2_wdt: Convert to use regmap framework's endianness method.Xiubo Li
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-10-20Documentation/arm64/memory.txt: fix typoAlex Bennée
There is no swapper_pgd_dir, it meant swapper_pg_dir. Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-10-19Merge tag 'arm-soc-fixes-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A batch of fixes that have come in during the merge window. Some of them are defconfig updates for things that have now landed, some errata additions and a few general scattered fixes. There's also a qcom DT update that adds support for SATA on AP148, and basic support for Sony Xperia Z1 and CM-QS600 platforms that seemed isolated enough that we could merge it even if it's late" * tag 'arm-soc-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: corrected bcm2835 search ARM: dts: Explicitly set dr_mode on exynos5420-arndale-octa ARM: dts: Explicitly set dr_mode on exynos Peach boards ARM: dts: qcom: add CM-QS600 board ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phone ARM: dts: qcom: Add SATA support on IPQ8064/AP148 MAINTAINERS: Update Santosh Shilimkar's email id ARM: sunxi_defconfig: enable CONFIG_REGULATOR ARM: dts: Disable smc91x on n900 until bootloader dependency is removed ARM: omap2plus_defconfig: Enable ARM erratum 430973 for omap3 ARM: exynos_defconfig: enable USB gadget support ARM: exynos_defconfig: Enable Maxim 77693 and I2C GPIO drivers ARM: mm: Fix ifdef around cpu_*_do_[suspend, resume] ops ARM: EXYNOS: Fix build with PM_SLEEP=n and ARM_EXYNOS_CPUIDLE=n ARM: SAMSUNG: Restore Samsung PM Debug functionality ARM: dts: Fix pull setting in sd4_width8 pin group for exynos4x12 ARM: exynos_defconfig: Enable SBS battery support ARM: exynos_defconfig: Enable Control Groups support ARM: exynos_defconfig: Enable Atmel maXTouch support ARM: exynos_defconfig: Enable MAX77802
2014-10-19Merge tag 'qcom-dt-for-3.18-3' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom into fixes Merge "qcom DT changes for v3.18-3" from Kumar Gala: Qualcomm ARM Based Device Tree Updates for v3.18-3 * Added Board support for CM-QS600 and Sony Xperia Z1 phone * Added SATA support on IPQ8064/AP148 * tag 'qcom-dt-for-3.18-3' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom: ARM: dts: qcom: add CM-QS600 board ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phone ARM: dts: qcom: Add SATA support on IPQ8064/AP148
2014-10-19Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Highlights from the I2C subsystem for 3.18: - new drivers for Axxia AM55xx, and Hisilicon hix5hd2 SoC. - designware driver gained AMD support, exynos gained exynos7 support The rest is usual driver stuff. Hopefully no lowlights this time" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: i801: Add Device IDs for Intel Sunrise Point PCH i2c: hix5hd2: add i2c controller driver i2c-imx: Disable the clock on probe failure i2c: designware: Add support for AMD I2C controller i2c: designware: Rework probe() to get clock a bit later i2c: designware: Default to fast mode in case of ACPI i2c: axxia: Add I2C driver for AXM55xx i2c: exynos: add support for HSI2C module on Exynos7 i2c: mxs: detect No Slave Ack on SELECT in PIO mode i2c: cros_ec: Remove EC_I2C_FLAG_10BIT i2c: cros-ec-tunnel: Add of match table i2c: rcar: remove sign-compare flaw i2c: ismt: Use minimum descriptor size i2c: imx: Add arbitration lost check i2c: rk3x: Remove unlikely() annotations i2c: rcar: check for no IRQ in rcar_i2c_irq() i2c: rcar: make rcar_i2c_prepare_msg() *void* i2c: rcar: simplify check for last message i2c: designware: add support of platform data to set I2C mode i2c: designware: add support of I2C standard mode
2014-10-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull second round of input updates from Dmitry Torokhov: "Mostly simple bug fixes, although we do have one brand new driver for Microchip AR1021 i2c touchscreen. Also there is the change to stop trying to use i8042 active multiplexing by default (it is still possible to activate it via i8042.nomux=0 on boxes that implement it)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - add Thrustmaster as Xbox 360 controller vendor Input: xpad - add USB ID for Thrustmaster Ferrari 458 Racing Wheel Input: max77693-haptic - fix state check in imax77693_haptic_disable() Input: xen-kbdfront - free grant table entry in xenkbd_disconnect_backend Input: alps - fix v4 button press recognition Input: i8042 - disable active multiplexing by default Input: i8042 - add noloop quirk for Asus X750LN Input: synaptics - gate forcepad support by DMI check Input: Add Microchip AR1021 i2c touchscreen Input: cros_ec_keyb - add of match table Input: serio - avoid negative serio device numbers Input: avoid negative input device numbers Input: automatically set EV_ABS bit in input_set_abs_params Input: adp5588-keys - cancel workqueue in failure path Input: opencores-kbd - switch to using managed resources Input: evdev - fix EVIOCG{type} ioctl
2014-10-19Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second (and last) round of late coming fixes and changes, almost all of them in perf tooling: User visible tooling changes: - Add period data column and make it default in 'perf script' (Jiri Olsa) - Add a visual cue for toggle zeroing of samples in 'perf top' (Taeung Song) - Improve callchains when using libunwind (Namhyung Kim) Tooling fixes and infrastructure changes: - Fix for double free in 'perf stat' when using some specific invalid command line combo (Yasser Shalabi) - Fix off-by-one bugs in map->end handling (Stephane Eranian) - Fix off-by-one bug in maps__find(), also related to map->end handling (Namhyung Kim) - Make struct symbol->end be the first addr after the symbol range, to make it match the convention used for struct map->end. (Arnaldo Carvalho de Melo) - Fix perf_evlist__add_pollfd() error handling in 'perf kvm stat live' (Jiri Olsa) - Fix python test build by moving callchain_param to an object linked into the python binding (Jiri Olsa) - Document sysfs events/ interfaces (Cody P Schafer) - Fix typos in perf/Documentation (Masanari Iida) - Add missing 'struct option' forward declaration (Arnaldo Carvalho de Melo) - Add option to copy events when queuing for sorting across cpu buffers and enable it for 'perf kvm stat live', to avoid having events left in the queue pointing to the ring buffer be rewritten in high volume sessions. (Alexander Yarygin, improving work done by David Ahern): - Do not include a struct hists per perf_evsel, untangling the histogram code from perf_evsel, to pave the way for exporting a minimalistic tools/lib/api/perf/ library usable by tools/perf and initially by the rasd daemon being developed by Borislav Petkov, Robert Richter and Jean Pihet. (Arnaldo Carvalho de Melo) - Make perf_evlist__open(evlist, NULL, NULL), i.e. without cpu and thread maps mean syswide monitoring, reducing the boilerplate for tools that only want system wide mode. (Arnaldo Carvalho de Melo) - Move exit stuff from perf_evsel__delete to perf_evsel__exit, delete should be just a front end for exit + free (Arnaldo Carvalho de Melo) - Add support to new style format of kernel PMU event. (Kan Liang) and other misc fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) perf script: Add period as a default output column perf script: Add period data column perf evsel: No need to drag util/cgroup.h perf evlist: Add missing 'struct option' forward declaration perf evsel: Move exit stuff from __delete to __exit kprobes/x86: Remove stale ARCH_SUPPORTS_KPROBES_ON_FTRACE define perf kvm stat live: Enable events copying perf session: Add option to copy events when queueing perf Documentation: Fix typos in perf/Documentation perf trace: Use thread_{,_set}_priv helpers perf kvm: Use thread_{,_set}_priv helpers perf callchain: Create an address space per thread perf report: Set callchain_param.record_mode for future use perf evlist: Fix for double free in tools/perf stat perf test: Add test case for pmu event new style format perf tools: Add support to new style format of kernel PMU event perf tools: Parse the pmu event prefix and suffix Revert "perf tools: Default to cpu// for events v5" perf Documentation: Remove Ruplicated docs for powerpc cpu specific events perf Documentation: sysfs events/ interfaces ...
2014-10-19Boaz Harrosh - fix email in DocumentationBoaz Harrosh
I forgot to update Documentation/*.txt Signed-off-by: Boaz Harrosh <ooo@electrozaur.com>
2014-10-18Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "For dmaengine contributions we have: - designware cleanup by Andy - my series moving device_control users to dmanegine_xxx APIs for later removal of device_control API - minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma etc" * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits) serial: atmel: add missing dmaengine header dmaengine: remove FSLDMA_EXTERNAL_START dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method carma-fpga: move to fsl_dma_external_start() carma-fpga: use dmaengine_xxx() API dmaengine: freescale: add and export fsl_dma_external_start() dmaengine: add dmaengine_prep_dma_sg() helper video: mx3fb: use dmaengine_terminate_all() API serial: sh-sci: use dmaengine_terminate_all() API net: ks8842: use dmaengine_terminate_all() API mtd: sh_flctl: use dmaengine_terminate_all() API mtd: fsmc_nand: use dmaengine_terminate_all() API V4L2: mx3_camer: use dmaengine_pause() API dmaengine: coh901318: use dmaengine_terminate_all() API pata_arasan_cf: use dmaengine_terminate_all() API dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause() dmaengine: dw: export probe()/remove() and Co to users dmaengine: dw: enable and disable controller when needed dmaengine: dw: always export dw_dma_{en,dis}able dmaengine: dw: introduce dw_dma_on() helper ...
2014-10-18Merge tag 'fbdev-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: - new 6x10 font - various small fixes and cleanups * tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits) fonts: Add 6x10 font videomode: provide dummy inline functions for !CONFIG_OF video/atmel_lcdfb: Introduce regulator support fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume framebuffer: fix screen corruption when copying framebuffer: fix border color arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy video: valkyriefb: Fix unused variable warning in set_valkyrie_clock() video: fbdev: use %*ph specifier to dump small buffers video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT video: fbdev: au1200fb: delete double assignment video: fbdev: sis: delete double assignment ...
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfsLinus Torvalds
Pull NTFS update from Anton Altaparmakov: "Here is a small NTFS update notably implementing FIBMAP ioctl for NTFS by adding the bmap address space operation. People seem to still want FIBMAP" * git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfs: NTFS: Bump version to 2.1.31. NTFS: Add bmap address space operation needed for FIBMAP ioctl. NTFS: Remove changelog from Documentation/filesystems/ntfs.txt. NTFS: Split ntfs_aops into ntfs_normal_aops and ntfs_compressed_aops in preparation for them diverging.
2014-10-18Merge branch 'for-3.18/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block layer changes from Jens Axboe: "This is the core block IO pull request for 3.18. Apart from the new and improved flush machinery for blk-mq, this is all mostly bug fixes and cleanups. - blk-mq timeout updates and fixes from Christoph. - Removal of REQ_END, also from Christoph. We pass it through the ->queue_rq() hook for blk-mq instead, freeing up one of the request bits. The space was overly tight on 32-bit, so Martin also killed REQ_KERNEL since it's no longer used. - blk integrity updates and fixes from Martin and Gu Zheng. - Update to the flush machinery for blk-mq from Ming Lei. Now we have a per hardware context flush request, which both cleans up the code should scale better for flush intensive workloads on blk-mq. - Improve the error printing, from Rob Elliott. - Backing device improvements and cleanups from Tejun. - Fixup of a misplaced rq_complete() tracepoint from Hannes. - Make blk_get_request() return error pointers, fixing up issues where we NULL deref when a device goes bad or missing. From Joe Lawrence. - Prep work for drastically reducing the memory consumption of dm devices from Junichi Nomura. This allows creating clone bio sets without preallocating a lot of memory. - Fix a blk-mq hang on certain combinations of queue depths and hardware queues from me. - Limit memory consumption for blk-mq devices for crash dump scenarios and drivers that use crazy high depths (certain SCSI shared tag setups). We now just use a single queue and limited depth for that" * 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits) block: Remove REQ_KERNEL blk-mq: allocate cpumask on the home node bio-integrity: remove the needless fail handle of bip_slab creating block: include func name in __get_request prints block: make blk_update_request print prefix match ratelimited prefix blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio block: fix alignment_offset math that assumes io_min is a power-of-2 blk-mq: Make bt_clear_tag() easier to read blk-mq: fix potential hang if rolling wakeup depth is too high block: add bioset_create_nobvec() block: use bio_clone_fast() in blk_rq_prep_clone() block: misplaced rq_complete tracepoint sd: Honor block layer integrity handling flags block: Replace strnicmp with strncasecmp block: Add T10 Protection Information functions block: Don't merge requests if integrity flags differ block: Integrity checksum flag block: Relocate bio integrity flags block: Add a disk flag to block integrity profile block: Add prefix to block integrity profile flags ...
2014-10-18Merge tag 'for-linus-20141015' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from Brian Norris: "Sorry for delaying this a bit later than usual. There's one mild regression from 3.16 that was noticed during the 3.17 cycle, and I meant to send a fix for it along with this pull request. I'll probably try to queue it up for a later pull request once I've had a better look at it, hopefully by -rc2 at the latest. Summary for this pull: NAND - Cleanup for Denali driver - Atmel: add support for new page sizes - Atmel: fix up 'raw' mode support - Atmel: miscellaneous cleanups - New timing mode helpers for non-ONFI NAND - OMAP: allow driver to be (properly) built as a module - bcm47xx: RESET support and other cleanups SPI NOR - Miscellaneous cleanups, to prepare framework for wider use (some further work still pending) - Compile-time configuration to select 4K vs. 64K support for flash that support both (necessary for using UBIFS on some SPI NOR) A few scattered code quality fixes, detected by Coverity See the changesets for more" * tag 'for-linus-20141015' of git://git.infradead.org/linux-mtd: (59 commits) mtd: nand: omap: Correct CONFIG_MTD_NAND_OMAP_BCH help message mtd: nand: Force omap_elm to be built as a module if omap2_nand is a module mtd: move support for struct flash_platform_data into m25p80 mtd: spi-nor: add Kconfig option to disable 4K sectors mtd: nand: Move ELM driver and rename as omap_elm nand: omap2: Replace pr_err with dev_err nand: omap2: Remove horrible ifdefs to fix module probe mtd: nand: add Hynix's H27UCG8T2ATR-BC to nand_ids table mtd: nand: support ONFI timing mode retrieval for non-ONFI NANDs mtd: physmap_of: Add non-obsolete map_rom probe mtd: physmap_of: Fix ROM support via OF MAINTAINERS: add l2-mtd.git, 'next' tree for MTD mtd: denali: fix indents and other trivial things mtd: denali: remove unnecessary parentheses mtd: denali: remove another set-but-unused variable mtd: denali: fix include guard and license block of denali.h mtd: nand: don't break long print messages mtd: bcm47xxnflash: replace some magic numbers mtd: bcm47xxnflash: NAND_CMD_RESET support mtd: bcm47xxnflash: add cmd_ctrl handler ...
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Include fixes for netrom and dsa (Fabian Frederick and Florian Fainelli) 2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO. 3) Several SKB use after free fixes (vxlan, openvswitch, vxlan, ip_tunnel, fou), from Li ROngQing. 4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy. 5) Use after free in virtio_net, from Michael S Tsirkin. 6) Fix flow mask handling for megaflows in openvswitch, from Pravin B Shelar. 7) ISDN gigaset and capi bug fixes from Tilman Schmidt. 8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin. 9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov. 10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong Wang and Eric Dumazet. 11) Don't overwrite end of SKB when parsing malformed sctp ASCONF chunks, from Daniel Borkmann. 12) Don't call sock_kfree_s() with NULL pointers, this function also has the side effect of adjusting the socket memory usage. From Cong Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits) bna: fix skb->truesize underestimation net: dsa: add includes for ethtool and phy_fixed definitions openvswitch: Set flow-key members. netrom: use linux/uaccess.h dsa: Fix conversion from host device to mii bus tipc: fix bug in bundled buffer reception ipv6: introduce tcp_v6_iif() sfc: add support for skb->xmit_more r8152: return -EBUSY for runtime suspend ipv4: fix a potential use after free in fou.c ipv4: fix a potential use after free in ip_tunnel_core.c hyperv: Add handling of IP header with option field in netvsc_set_hash() openvswitch: Create right mask with disabled megaflows vxlan: fix a free after use openvswitch: fix a use after free ipv4: dst_entry leak in ip_send_unicast_reply() ipv4: clean up cookie_v4_check() ipv4: share tcp_v4_save_options() with cookie_v4_check() ipv4: call __ip_options_echo() in cookie_v4_check() atm: simplify lanai.c by using module_pci_driver ...
2014-10-16NTFS: Remove changelog from Documentation/filesystems/ntfs.txt.Anton Altaparmakov
Changelog is in git history, no need to have a copy in the documentation. Signed-off-by: Anton Altaparmakov <anton@tuxera.com>
2014-10-16ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phoneTim Bird
This DTS has support for the Sony Xperia Z1 phone (codenamed Honami). This first version of the DTS supports just a serial console. Signed-off-by: Tim Bird <tim.bird@sonymobile.com> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-10-16i2c: i801: Add Device IDs for Intel Sunrise Point PCHjames.d.ralston@intel.com
This patch adds the I2C/SMBus Device IDs for the Intel Sunrise Point PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-16i2c: hix5hd2: add i2c controller driverWei Yan
I2C drivers for hix5hd2 soc series, including following chipset Hi3716CV200, Hi3719CV100, Hi3718CV100, Hi3719MV100, Hi3718MV100. Signed-off-by: Wei Yan <sledge.yanwei@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> [wsa: folded dt docs into this patch] Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-15perf Documentation: Remove Ruplicated docs for powerpc cpu specific eventsCody P Schafer
Listing specific events doesn't actually help us at all here because: - these events actually vary between different ppc processors, they aren't garunteed to be present. - the documentation of the (generic) file contents is now superceded by the docs for arbitrary event file contents. Signed-off-by: Cody P Schafer <dev@codyps.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Haren Myneni <hbabu@us.ibm.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1412143402-26061-5-git-send-email-sukadev@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf Documentation: sysfs events/ interfacesCody P Schafer
Add documentation for the <event>, <event>.scale, and <event>.unit files in sysfs. <event>.scale and <event>.unit were undocumented. <event> was previously documented only for specific powerpc pmu events. Signed-off-by: Cody P Schafer <dev@codyps.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Cody P Schafer <dev@codyps.com> Cc: Haren Myneni <hbabu@us.ibm.com> Cc: Haren Myneni <hbabu@us.ibm.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1412143402-26061-4-git-send-email-sukadev@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15Merge tag 'iommu-updates-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "This pull-request includes: - change in the IOMMU-API to convert the former iommu_domain_capable function to just iommu_capable - various fixes in handling RMRR ranges for the VT-d driver (one fix requires a device driver core change which was acked by Greg KH) - the AMD IOMMU driver now assigns and deassigns complete alias groups to fix issues with devices using the wrong PCI request-id - MMU-401 support for the ARM SMMU driver - multi-master IOMMU group support for the ARM SMMU driver - various other small fixes all over the place" * tag 'iommu-updates-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (41 commits) iommu/vt-d: Work around broken RMRR firmware entries iommu/vt-d: Store bus information in RMRR PCI device path iommu/vt-d: Only remove domain when device is removed driver core: Add BUS_NOTIFY_REMOVED_DEVICE event iommu/amd: Fix devid mapping for ivrs_ioapic override iommu/irq_remapping: Fix the regression of hpet irq remapping iommu: Fix bus notifier breakage iommu/amd: Split init_iommu_group() from iommu_init_device() iommu: Rework iommu_group_get_for_pci_dev() iommu: Make of_device_id array const amd_iommu: do not dereference a NULL pointer address. iommu/omap: Remove omap_iommu unused owner field iommu: Remove iommu_domain_has_cap() API function IB/usnic: Convert to use new iommu_capable() API function vfio: Convert to use new iommu_capable() API function kvm: iommu: Convert to use new iommu_capable() API function iommu/tegra: Convert to iommu_capable() API function iommu/msm: Convert to iommu_capable() API function iommu/vt-d: Convert to iommu_capable() API function iommu/fsl: Convert to iommu_capable() API function ...
2014-10-15Merge tag 'clk-for-linus-3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock tree updates from Mike Turquette: "The clk tree changes for 3.18 are dominated by clock drivers. Mostly fixes and enhancements to existing drivers as well as new drivers. This tag contains a bit more arch code than I usually take due to some OMAP2+ changes. Additionally it contains the restart notifier handlers which are merged as a dependency into several trees. The PXA changes are the only messy part. Due to having a stable tree I had to revert one patch and follow up with one more fix near the tip of this tag. Some dead code is introduced but it will soon become live code after 3.18-rc1 is released as the rest of the PXA family is converted over to the common clock framework. Another trend in this tag is that multiple vendors have started to push the complexity of changing their CPU frequency into the clock driver, whereas this used to be done in CPUfreq drivers. Changes to the clk core include a generic gpio-clock type and a clk_set_phase() function added to the top-level clk.h api. Due to some confusion on the fbdev mailing list the kernel boot parameters documentation was updated to further explain the clk_ignore_unused parameter, which is often required by users of the simplefb driver. Finally some fixes to the locking around the clock debugfs stuff was done to prevent deadlocks when interacting with other subsystems." * tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits) clk: pxa clocks build system fix Revert "arm: pxa: Transition pxa27x to clk framework" clk: samsung: register restart handlers for s3c2412 and s3c2443 clk: rockchip: add restart handler clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate doc/kernel-parameters.txt: clarify clk_ignore_unused arm: pxa: Transition pxa27x to clk framework dts: add devicetree bindings for pxa27x clocks clk: add pxa27x clock drivers arm: pxa: add clock pll selection bits clk: dts: document pxa clock binding clk: add pxa clocks infrastructure clk: gpio-gate: Ensure gpiod_ APIs are prototyped clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe clk: ti: LLVMLinux: Move __init outside of type definition clk: ti: consider the fact that of_clk_get() might return an error clk: ti: dra7-atl-clock: fix a memory leak clk: ti: change clock init to use generic of_clk_init clk: hix5hd2: add I2C clocks clk: hix5hd2: add watchdog0 clocks ...
2014-10-15Merge tag 'mfd-for-linus-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030 - Export symbols for use in modules in max14577 - Plenty of static code analysis/Coccinelle fixes throughout the SS - Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808 - Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona - Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr - IRQ fixups in arizona, stmpe, max14577 - Regulator related changes in axp20x - Pass DMA coherency information from parent => child in MFD core - Rename DT document files for consistency - Add ACPI support to the MFD core - Add Andreas Werner to MAINTAINERS for MEN F21BMC New drivers/supported devices: - New driver for MEN 14F021P00 Board Management Controller - New driver for Ricoh RN5T618 PMIC - New driver for Rockchip RK808 - New driver for HiSilicon Hi6421 PMIC - New driver for Qualcomm SPMI PMICs - Add support for Intel Braswell in lpc_ich - Add support for Intel 9 Series PCH in lpc_ich - Add support for Intel Quark ILB in lpc_sch" [ Delayed to after the poweer/reset pull due to Kconfig problems with recursive Kconfig select/depends-on chains. - Linus ] * tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits) mfd: cros_ec: wait for completion of commands that return IN_PROGRESS i2c: i2c-cros-ec-tunnel: Set retries to 3 mfd: cros_ec: move locking into cros_ec_cmd_xfer mfd: cros_ec: stop calling ->cmd_xfer() directly mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC mfd: arizona: Correct mask to allow setting micbias external cap mfd: Add ACPI support Revert "mfd: wm5102: Manually apply register patch" mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention mfd: Inherit coherent_dma_mask from parent device mfd: Document DT bindings for Qualcomm SPMI PMICs mfd: Add support for Qualcomm SPMI PMICs mfd: dt-bindings: pm8xxx: Add new compatible string mfd: axp209x: Drop the parent supplies field mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off mfd: dt-bindings: twl4030-power: Use the standard property to mark power control mfd: syscon: Add Atmel GPBR DT bindings documention ...
2014-10-15Merge tag 'for-v3.18' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply and reset updates from Sebastian Reichel: - Initial support for the following chips * max77836 (charger) * max14577 (charger) * bq27742 (battery gauge) * ltc2952 (poweroff) * stih416 (restart) * syscon-reboot (restart) * gpio-restart (restart) - cleanup of power supply core - misc fixes in power supply and reset drivers * tag 'for-v3.18' of git://git.infradead.org/battery-2.6: (48 commits) power: ab8500_fg: Fix build warning Documentation: charger: max14577: Update the date of introducing ABI power: reset: corrections for simple syscon reboot driver Documentation: power: reset: Add documentation for generic SYSCON reboot driver power: reset: Add generic SYSCON register mapped reset bq27x00_battery: Fix flag reading for bq27742 power: reset: use restart_notifier mechanism for msm-poweroff power: Add simple gpio-restart driver power: reset: st: Provide DT bindings for ST's Power Reset driver power: reset: Add restart functionality for STiH41x platforms power: charger-manager: Fix NULL pointer exception with missing cm-fuel-gauge power: max14577: Fix circular config SYSFS dependency power: gpio-charger: do not use gpio value directly power: max8925: Use of_get_child_by_name power: max8925: Fix NULL ptr dereference on memory allocation failure bq27x00_battery: Add support to bq27742 Documentation: charger: max14577: Document exported sysfs entry devicetree: mfd: max14577: Add device tree bindings document power: max17040: Add ID for MAX77836 Fuel Gauge block charger: max14577: Configure battery-dependent settings from DTS and sysfs ... Conflicts: drivers/power/reset/Kconfig drivers/power/reset/Makefile
2014-10-14stmmac: dwmac-sti: review the glue-logic for STi4xx and STiD127 SoCsGiuseppe CAVALLARO
This patch is to review the whole glue logic adopted on STi SoCs that was bugged. In the old glue-logic there was a lot of confusion when setup the retiming especially for STiD127 where, for example, the bits 6 and 7 (in the GMAC control register) have a different meaning of what is used for STiH4xx SoCs. So we cannot adopt the same glue for all these SoCs. Moreover, GiGa on STiD127 didn't work and, for all the SoCs, the RGMII couldn't run when the speed was 10Mbps (because the clock was not properly managed). Note that the phy clock needs to be provided by the platform as well as documented in the related binding file (updated as consequence). The old code supported too many configurations never adopted and validated. This made the code very complex to maintain and debug in case of issues. The patch simplifies all the configurations as commented in the tables inside the file and obviously it has been tested on all the boards based on the SoCs mentioned. With this patch, the dwmac-sti is also ready to support new configurations that will be available on next SoC generations. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14stmmac: make the STi Layer compatible to STiH407Giuseppe CAVALLARO
This adds the missing compatibility to the STiH407 SoC. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main git pull for the drm, I pretty much froze major pulls at -rc5/6 time, and haven't had much fallout, so will probably continue doing that. Lots of changes all over, big internal header cleanup to make it clear drm features are legacy things and what are things that modern KMS drivers should be using. Also big move to use the new generic fences in all the TTM drivers. core: atomic prep work, vblank rework changes, allows immediate vblank disables major header reworking and cleanups to better delinate legacy interfaces from what KMS drivers should be using. cursor planes locking fixes ttm: move to generic fences (affects all TTM drivers) ppc64 caching fixes radeon: userptr support, uvd for old asics, reset rework for fence changes better buffer placement changes, dpm feature enablement hdmi audio support fixes intel: Cherryview work, 180 degree rotation, skylake prep work, execlist command submission full ppgtt prep work cursor improvements edid caching, vdd handling improvements nouveau: fence reworking kepler memory clock work gt21x clock work fan control improvements hdmi infoframe fixes DP audio ast: ppc64 fixes caching fix rcar: rcar-du DT support ipuv3: prep work for capture support msm: LVDS support for mdp4, new panel, gpu refactoring exynos: exynos3250 SoC support, drop bad mmap interface, mipi dsi changes, and component match support" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (640 commits) drm/mst: rework payload table allocation to conform better. drm/ast: Fix HW cursor image drm/radeon/kv: add uvd/vce info to dpm debugfs output drm/radeon/ci: add uvd/vce info to dpm debugfs output drm/radeon: export reservation_object from dmabuf to ttm drm/radeon: cope with foreign fences inside the reservation object drm/radeon: cope with foreign fences inside display drm/core: use helper to check driver features drm/radeon/cik: write gfx ucode version to ucode addr reg drm/radeon/si: print full CS when we hit a packet 0 drm/radeon: remove unecessary includes drm/radeon/combios: declare legacy_connector_convert as static drm/radeon/atombios: declare connector convert tables as static drm/radeon: drop btc_get_max_clock_from_voltage_dependency_table drm/radeon/dpm: drop clk/voltage dependency filters for BTC drm/radeon/dpm: drop clk/voltage dependency filters for CI drm/radeon/dpm: drop clk/voltage dependency filters for SI drm/radeon/dpm: drop clk/voltage dependency filters for NI drm/radeon: disable audio when we disable hdmi (v2) drm/radeon: split audio enable between eg and r600 (v2) ...
2014-10-14Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "This is the less critical kbuild stuff for v3.18-rc1: - make deb-pkg debuginfo fix, ppc64el support and warning fix for recent dpkg tools - make TAGS fixes - new coccinelle patch - kbuild documentation improvements" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: deb-pkg: remove obsolete -isp option to dpkg-gencontrol coccinelle: misc: semantic patch to delete overly complex return code processing deb-pkg: Add support for powerpc little endian builddeb: put the dbg files into the correct directory scripts/tags.sh: fix DEFINE_HASHTABLE in emacs case scripts/tags.sh: remove *PCGFLAGS regular expressions scripts/tags.sh: Don't specify kind-spec for emacs' ctags/etags Documentation: kbuild: Improve grammar Documentation: kbuild: Remove obsolete dtc_cpp section Documentation: kbuild: Improve if_changed documentation Documentation: kbuild: Remove obsolete include/asm symlink step
2014-10-14Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - a few hotfixes - drivers/dma updates - MAINTAINERS updates - Quite a lot of lib/ updates - checkpatch updates - binfmt updates - autofs4 - drivers/rtc/ - various small tweaks to less used filesystems - ipc/ updates - kernel/watchdog.c changes * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (135 commits) mm: softdirty: enable write notifications on VMAs after VM_SOFTDIRTY cleared kernel/param: consolidate __{start,stop}___param[] in <linux/moduleparam.h> ia64: remove duplicate declarations of __per_cpu_start[] and __per_cpu_end[] frv: remove unused declarations of __start___ex_table and __stop___ex_table kvm: ensure hard lockup detection is disabled by default kernel/watchdog.c: control hard lockup detection default staging: rtl8192u: use %*pEn to escape buffer staging: rtl8192e: use %*pEn to escape buffer staging: wlan-ng: use %*pEhp to print SN lib80211: remove unused print_ssid() wireless: hostap: proc: print properly escaped SSID wireless: ipw2x00: print SSID via %*pE wireless: libertas: print esaped string via %*pE lib/vsprintf: add %*pE[achnops] format specifier lib / string_helpers: introduce string_escape_mem() lib / string_helpers: refactoring the test suite lib / string_helpers: move documentation to c-file include/linux: remove strict_strto* definitions arch/x86/mm/numa.c: fix boot failure when all nodes are hotpluggable fs: check bh blocknr earlier when searching lru ...
2014-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "This patch set contains the main portion of the changes for 3.18 in regard to the s390 architecture. It is a bit bigger than usual, mainly because of a new driver and the vector extension patches. The interesting bits are: - Quite a bit of work on the tracing front. Uprobes is enabled and the ftrace code is reworked to get some of the lost performance back if CONFIG_FTRACE is enabled. - To improve boot time with CONFIG_DEBIG_PAGEALLOC, support for the IPTE range facility is added. - The rwlock code is re-factored to improve writer fairness and to be able to use the interlocked-access instructions. - The kernel part for the support of the vector extension is added. - The device driver to access the CD/DVD on the HMC is added, this will hopefully come in handy to improve the installation process. - Add support for control-unit initiated reconfiguration. - The crypto device driver is enhanced to enable the additional AP domains and to allow the new crypto hardware to be used. - Bug fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (39 commits) s390/ftrace: simplify enabling/disabling of ftrace_graph_caller s390/ftrace: remove 31 bit ftrace support s390/kdump: add support for vector extension s390/disassembler: add vector instructions s390: add support for vector extension s390/zcrypt: Toleration of new crypto hardware s390/idle: consolidate idle functions and definitions s390/nohz: use a per-cpu flag for arch_needs_cpu s390/vtime: do not reset idle data on CPU hotplug s390/dasd: add support for control unit initiated reconfiguration s390/dasd: fix infinite loop during format s390/mm: make use of ipte range facility s390/setup: correct 4-level kernel page table detection s390/topology: call set_sched_topology early s390/uprobes: architecture backend for uprobes s390/uprobes: common library for kprobes and uprobes s390/rwlock: use the interlocked-access facility 1 instructions s390/rwlock: improve writer fairness s390/rwlock: remove interrupt-enabling rwlock variant. s390/mm: remove change bit override support ...
2014-10-14Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "This tree includes the following changes: - fix memory hotplug - fix hibernation bootup memory layout assumptions - fix hyperv numa guest kernel messages - remove dead code - update documentation" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Update memory map description to list hypervisor-reserved area x86/mm, hibernate: Do not assume the first e820 area to be RAM x86/mm/numa: Drop dead code and rename setup_node_data() to setup_alloc_data() x86/mm/hotplug: Modify PGD entry when removing memory x86/mm/hotplug: Pass sync_global_pgds() a correct argument in remove_pagetable() x86: Remove set_pmd_pfn
2014-10-14lib/vsprintf: add %*pE[achnops] format specifierAndy Shevchenko
This allows user to print a given buffer as an escaped string. The rules are applied according to an optional mix of flags provided by additional format letters. For example, if the given buffer is: 1b 62 20 5c 43 07 22 90 0d 5d The result strings would be: %*pE "\eb \C\a"\220\r]" %*pEhp "\x1bb \C\x07"\x90\x0d]" %*pEa "\e\142\040\\\103\a\042\220\r\135" Please, read Documentation/printk-formats.txt and lib/string_helpers.c kernel documentation to get further information. [akpm@linux-foundation.org: tidy up comment layout, per Joe] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Suggested-by: Joe Perches <joe@perches.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
