path: root/Documentation
2009-04-27Bonding: fix zero address hole bug in arp_ip_target listBrian Haley
upstream commit: 5a31bec014449dc9ca994e4c1dbf2802b7ca458a Fix a zero address hole bug in the bonding arp_ip_target list that was causing the bond to ignore ARP replies (bugz 13006). Instead of just setting the array entry to zero, we now copy any additional entries down one slot, putting the zero entry at the end. With this change we can now have all the loops that walk the array stop when they hit a zero since there will be no addresses after it. Changes are based in part on code fragment provided in kernel: bugzilla 13006: http://bugzilla.kernel.org/show_bug.cgi?id=13006 by Steve Howard <steve@astutenetworks.com> Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-03-23trivial: fix orphan dates in ext2 documentationJody McIntyre
Revert the change to the orphan dates of Windows 95, DOS, compression. Add a new orphan date for OS/2. Signed-off-by: Jody McIntyre <scjody@sun.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) ucc_geth: Fix oops when using fixed-link support dm9000: locking bugfix net: update dnet.c for bus_id removal dnet: DNET should depend on HAS_IOMEM dca: add missing copyright/license headers nl80211: Check that function pointer != NULL before using it sungem: missing net_device_ops be2net: fix to restore vlan ids into BE2 during a IF DOWN->UP cycle be2net: replenish when posting to rx-queue is starved in out of mem conditions bas_gigaset: correctly allocate USB interrupt transfer buffer smsc911x: reset last known duplex and carrier on open sh_eth: Fix mistake of the address of SH7763 sh_eth: Change handling of IRQ netns: oops in ip[6]_frag_reasm incrementing stats net: kfree(napi->skb) => kfree_skb net: fix sctp breakage ipv6: fix display of local and remote sit endpoints net: Document /proc/sys/net/core/netdev_budget tulip: fix crash on iface up with shirq debug virtio_net: Make virtio_net support carrier detection ...
2009-03-18net: Document /proc/sys/net/core/netdev_budgetStanislaw Gruszka
The NAPI poll parameter netdev_budget is not documented in kernel-docs. Since it may have a substantial effect on at least some network loads, it should be. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16linux.conf.au 2009: TuzRusty Russell
Impact: help prevent extinction of species The Tasmanian Devil is a shy iconic Australian creature named for its spine-chilling screech. It is threatened with extinction due to a scientifically interesting but horrific transmissible facial cancer. This one is standing in for Tux for one release using the far less-known Devil Facial Tux Disguise. Save The Tasmanian Devil http://tassiedevil.com.au Signed-off-by: Linux.conf.au Hobart Team <contact@marchsouth.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (f75375s) Remove unnecessary and confusing initialization hwmon: (it87) Properly decode -128 degrees C temperature hwmon: (lm90) Document support for the MAX6648/6692 chips hwmon: (abituguru3) Fix I/O error handling
2009-03-12trivial: fix bad links in the ext2 and ext3 documentationJody McIntyre
Trivial patch to fix bad links in the ext2 and ext3 documentation. Signed-off-by: Jody McIntyre <scjody@sun.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12hwmon: (lm90) Document support for the MAX6648/6692 chipsDarrick J. Wong
Update documentation to prevent further confusion/duplication. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-10rcu: documentation 1Q09 updatePaul E. McKenney
Update the RCU documentation to call out the need for callers of primitives like call_rcu() and synchronize_rcu() to prevent subsequent RCU readers from hazard. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-09Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Add p4-clockmod sysfs-ui removal to feature-removal schedule. Revert "[CPUFREQ] Disable sysfs ui for p4-clockmod."
2009-03-09[CPUFREQ] Add p4-clockmod sysfs-ui removal to feature-removal schedule.Dave Jones
Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Dave Jones <davej@redhat.com>
2009-03-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) p54: fix race condition in memory management cfg80211: test before subtraction on unsigned iwlwifi: fix error flow in iwl*_pci_probe rt2x00 : more devices to rt73usb.c rt2x00 : more devices to rt2500usb.c bonding: Fix device passed into ->ndo_neigh_setup(). vlan: Fix vlan-in-vlan crashes. net: Fix missing dev->neigh_setup in register_netdevice(). tmspci: fix request_irq race pkt_sched: act_police: Fix a rate estimator test. tg3: Fix 5906 link problems SCTP: change sctp_ctl_sock_init() to try IPv4 if IPv6 fails IPv6: add "disable" module parameter support to ipv6.ko sungem: another error printed one too early aoe: error printed 1 too early net pcmcia: worklimit reaches -1 net: more timeouts that reach -1 net: fix tokenring license dm9601: new vendor/product IDs netlink: invert error code in netlink_set_err() ...
2009-03-04Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-03-05Squashfs: fix documentation typo, Cramfs filesystem limit is 256 MiBPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-03-04IPv6: add "disable" module parameter support to ipv6.koBrian Haley
Add "disable" module parameter support to ipv6.ko by specifying "disable=1" on module load. We just do the minimum of initializing inetsw6[] so calls from other modules to inet6_register_protosw() won't OOPs, then bail out. No IPv6 addresses or sockets can be created as a result, and a reboot is required to enable IPv6. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] mpt: fix disable lsi sas to use msi as default [SCSI] fix ABORTED_COMMAND looping forever problem [SCSI] sd: revive sd_index_lock [SCSI] cxgb3i: update the driver version to 1.0.1 [SCSI] cxgb3i: Fix spelling errors in documentation [SCSI] cxgb3i: added missing include in cxgb3i_ddp.h [SCSI] cxgb3i: Outgoing pdus need to observe skb's MAX_SKB_FRAGS [SCSI] cxgb3i: added per-task data to track transmit progress [SCSI] cxgb3i: transmit work-request fixes [SCSI] hptiop: Add new PCI device ID
2009-02-27Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: enable DMAR by default xen: disable interrupts early, as start_kernel expects gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_t gpu/drm, x86, PAT: Handle io_mapping_create_wc() errors in a clean way x86, Voyager: fix compile by lifting the degeneracy of phys_cpu_present_map x86, doc: fix references to Documentation/x86/i386/boot.txt
2009-02-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: V4L/DVB (10696): Remove outdated README for the flexcop-driver V4L/DVB (10695): Update Technisat card documentation V4L/DVB (10694): [PATCH] software IRQ watchdog for Flexcop B2C2 DVB PCI cards V4L/DVB (10663): soc-camera: fix S_CROP breakage on PXA and SuperH V4L/DVB (10659): em28xx: register device to soundcard for sysfs
2009-02-26V4L/DVB (10696): Remove outdated README for the flexcop-driverUwe Bugla
This patch removes an outdated README for the flexcop-driver. Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-02-26V4L/DVB (10695): Update Technisat card documentationUwe Bugla
Fixes for documentation of Technisat-based cards Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: AMD 813x B2 devices do not need boot interrupt quirk PCI: Enable PCIe AER only after checking firmware support PCI: pciehp: Handle interrupts that happen during initialization. PCI: don't enable too many HT MSI mappings PCI: add some sysfs ABI docs PCI quirk: enable MSI on 8132
2009-02-25ide: ide.c 'clear' fix, update "ide=nodma" documentationDavid Fries
Documentation/kernel-parameters.txt - ide=nodma is no longer valid. drivers/ide/Kconfig - The module is ide-core.ko not ide. drivers/ide/ide.c - It took me a while to figure out what the arguments %d.%d:%d to nodma module parameter ment, so I added a comment to each. - Added a comment to each of the sscanf lines. - There is a bug, if j is 0 it would previously clear all the other bits except the current device, changed in three different places. mask &= (1 << i) should be mask &= ~(1 << i). Signed-off-by: David Fries <david@fries.net> [bart: s/disk/device/ in ide.c, beautify patch description] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-24PCI: add some sysfs ABI docsChris Wright
Add sysfs ABI docs for driver entries bind, unbind and new_id. These entries are pretty old, from 2.6.0 onwards AFAIK, so this documents current behaviour. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2009-02-23x86, doc: fix references to Documentation/x86/i386/boot.txtKyle McMartin
Impact: Documentation fix The amazing dancing boot.txt file has jumped places again. It should never have been in Documentation/x86/i386, since it never was 32-bit-specific, but it unfortunately ended up there for a while. Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-02-22acpi/doc: add missing param valueRandy Dunlap
Add missing parameter value to list of available values for acpi=<value>. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-22docbook: split kernel-api for device-driversRandy Dunlap
The kernel-api docbook was much larger than any of the others, so processing it took longer and needed some docbook extras in some cases, so split it into kernel-api (infrastructure etc.) and device drivers/device subsystems. This allows these docbooks to be generated in parallel. (This reduced the docbook processing time on my 4-proc system with make -j4 from about 5min:16sec to about 2min:01sec.) The chapters that were moved from kernel-api to device-drivers are: Driver Basics Device drivers infrastructure Parallel Port Devices Message-based devices Sound Devices 16x50 UART Driver Frame Buffer Library Input Subsystem Serial Peripheral Interface (SPI) I2C and SMBus Subsystem Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-22PATCH [2/2] Documentation/filesystems/sysfs.txt: fix descriptions of device ↵Mike Murphy
attributes Fix descriptions of device attributes to be consistent with the actual implementations in include/linux/device.h Signed-off-by: Mike Murphy <mamurph[at]cs.clemson.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-22PATCH [1/2] Documentation/driver-model/device.txt: fix struct device_attributeMike Murphy
Fix the presented definition of struct device_attribute to match the actual definition in include/linux/device.h Signed-off-by: Mike Murphy <mamurph[at]cs.clemson.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-21[SCSI] cxgb3i: Fix spelling errors in documentationKaren Xie
Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-02-20cpuset: various documentation fixes and updatesLi Zefan
I noticed the old commit 8f5aa26c75b7722e80c0c5c5bb833d41865d7019 ("cpusets: update_cpumask documentation fix") is not a complete fix, resulting in inconsistent paragraphs. This patch fixes it and does other fixes and updates: - s/migrate_all_tasks()/migrate_live_tasks()/ - describe more cpuset control files - s/cpumask_t/struct cpumask/ - document cpu hotplug and change of 'sched_relax_domain_level' may cause domain rebuild - document various ways to query and modify cpusets - the equivalent of "mount -t cpuset" is "mount -t cgroup -o cpuset,noprefix" Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18Bernhard has movedBernhard Walle
Since I don't work for SUSE any more and the bwalle@suse.de address is invalid, correct it in the copyright headers and documentation. Signed-off-by: Bernhard Walle <bernhard.walle@gmx.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18hp accelerometer: add freefall detectionPavel Machek
This adds freefall handling to hp_accel driver. According to HP, it should just work, without us having to set the chip up by hand. hpfall.c is example .c program that parks the disk when accelerometer detects free fall. It should work; for now, it uses fixed 20seconds protection period. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Thomas Renninger <trenn@suse.de> Cc: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18cgroups: update documentation about css_set hash tableLi Zefan
The css_set hash table was introduced in 2.6.26, so update the documentation accordingly. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-17Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: doc: mmiotrace.txt, buffer size control change trace: mmiotrace to the tracer menu in Kconfig mmiotrace: count events lost due to not recording
2009-02-15doc: mmiotrace.txt, buffer size control changePekka Paalanen
Impact: prevents confusing the user when buffer size is inadequate The tracing framework offers a resizeable buffer, which mmiotrace uses to record events. If the buffer is full, the following events will be lost. Events should not be lost, so the documentation instructs the user to increase the buffer size. The buffer size is set via a debugfs file. Mmiotrace documentation was not updated the same time the debugfs file was changed. The old file was tracing/trace_entries and first contained the number of entries the buffer had space for, per cpu. Nowadays this file is replaced with the file tracing/buffer_size_kb, which tells the amount of memory reserved for the buffer, per cpu, in kilobytes. Previously, a flag had to be toggled via the debugfs file tracing/tracing_enabled when the buffer size was changed. This is no longer necessary. The mmiotrace documentation is updated to reflect the current state of the tracing framework. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-13PCI: Documentation: fix minor PCIe HOWTO thinkoAlex Chiang
Update doc to correctly refer to replacing the pci_register_driver API, and not the non-existent "pci_module_init" API. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) wimax: fix oops in wimax_dev_get_by_genl_info() when looking up non-wimax iface net: 4 bytes kernel memory disclosure in SO_BSDCOMPAT gsopt try #2 netxen: fix compile waring "label ‘set_32_bit_mask’ defined but not used" on IA64 platform bnx2: Update version to 1.9.2 and copyright. bnx2: Fix jumbo frames error handling. bnx2: Update 5709 firmware. bnx2: Update 5706/5708 firmware. 3c505: do not set pcb->data.raw beyond its size Documentation/connector/cn_test.c: don't use gfp_any() net: don't use in_atomic() in gfp_any() IRDA: cnt is off by 1 netxen: remove pcie workaround sun3: print when lance_open() fails qlge: bugfix: Add missing rx buf clean index on early exit. qlge: bugfix: Fix RX scaling values. qlge: bugfix: Fix TSO breakage. qlge: bugfix: Add missing dev_kfree_skb_any() call. qlge: bugfix: Add missing put_page() call. qlge: bugfix: Fix fatal error recovery hang. qlge: bugfix: Use netif_receive_skb() and vlan_hwaccel_receive_skb(). ...
2009-02-12Documentation/connector/cn_test.c: don't use gfp_any()Andrew Morton
cn_test_timer_func() is a timer handler and can never use GFP_KERNEL - there's no point in using gfp_any() here. Also, use setup_timer(). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-11kernel-doc: preferred ending marker and examplesRandy Dunlap
Fix kernel-doc-nano-HOWTO.txt to use */ as the ending marker in kernel-doc examples and state that */ is the preferred ending marker. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-by: Robert Love <robert.w.love@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptrace, x86: fix the usage of ptrace_fork() i8327: fix outb() parameter order x86: fix math_emu register frame access x86: math_emu info cleanup x86: include correct %gs in a.out core dump x86, vmi: put a missing paravirt_release_pmd in pgd_dtor x86: find nr_irqs_gsi with mp_ioapic_routing x86: add clflush before monitor for Intel 7400 series x86: disable intel_iommu support by default x86: don't apply __supported_pte_mask to non-present ptes x86: fix grammar in user-visible BIOS warning x86/Kconfig.cpu: make Kconfig help readable in the console x86, 64-bit: print DMI info in the oops trace
2009-02-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI PM: make the PM core more careful with drivers using the new PM framework PCI PM: Read power state from device after trying to change it on resume PCI PM: Do not disable and enable bridges during suspend-resume PCI: PCIe portdrv: Simplify suspend and resume PCI PM: Fix saving of device state in pci_legacy_suspend PCI PM: Check if the state has been saved before trying to restore it PCI PM: Fix handling of devices without drivers PCI: return error on failure to read PCI ROMs PCI: properly clean up ASPM link state on device remove
2009-02-05x86: disable intel_iommu support by defaultKyle McMartin
Due to recurring issues with DMAR support on certain platforms. There's a number of filesystem corruption incidents reported: https://bugzilla.redhat.com/show_bug.cgi?id=479996 http://bugzilla.kernel.org/show_bug.cgi?id=12578 Provide a Kconfig option to change whether it is enabled by default. If disabled, it can still be reenabled by passing intel_iommu=on to the kernel. Keep the .config option off by default. Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-04PCI: return error on failure to read PCI ROMsTimothy S. Nelson
This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04ACPI: cpufreq: Remove deprecated /proc/acpi/processor/../performance proc ↵Thomas Renninger
entries They were long enough set deprecated... Update Documentation/cpu-freq/users-guide.txt: The deprecated files listed there seen not to exist for some time anymore already. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-03Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: UBIFS: remove fast unmounting UBIFS: return sensible error codes UBIFS: remount ro fixes UBIFS: spelling fix 'date' -> 'data' UBIFS: sync wbufs after syncing inodes and pages UBIFS: fix LPT out-of-space bug (again) UBIFS: fix no_chk_data_crc UBIFS: fix assertions UBIFS: ensure orphan area head is initialized UBIFS: always clean up GC LEB space UBIFS: add re-mount debugging checks UBIFS: fix LEB list freeing UBIFS: simplify locking UBIFS: document dark_wm and dead_wm better UBIFS: do not treat all data as short term UBIFS: constify operations UBIFS: do not commit twice
2009-02-02Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: fbdev/atyfb: Fix DSP config on some PowerMacs & PowerBooks powerpc: Fix oops on some machines due to incorrect pr_debug() powerpc/ps3: Printing fixups for l64 to ll64 convserion drivers/net powerpc/5200: update device tree binding documentation powerpc/5200: Bugfix for PCI mapping of memory and IMMR powerpc/5200: update defconfigs
2009-02-02Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (45 commits) V4L/DVB (10411): s5h1409: Perform s5h1409 soft reset after tuning V4L/DVB (10403): saa7134-alsa: saa7130 doesn't support digital audio V4L/DVB (10229): ivtv: fix memory leak V4L/DVB (10385): gspca - main: Fix memory leak when USB disconnection while streaming. V4L/DVB (10325): em28xx: Fix for fail to submit URB with IRQs and Pre-emption Disabled V4L/DVB (10317): radio-mr800: fix radio->muted and radio->stereo V4L/DVB (10314): cx25840: ignore TUNER_SET_CONFIG in the command callback. V4L/DVB (10288): af9015: bug fix: stick does not work always when plugged V4L/DVB (10287): af9015: fix second FE V4L/DVB (10270): saa7146: fix unbalanced mutex_lock/unlock V4L/DVB (10265): budget.c driver: Kernel oops: "BUG: unable to handle kernel paging request at ffffffff V4L/DVB (10261): em28xx: fix kernel panic on audio shutdown V4L/DVB (10257): em28xx: Fix for KWorld 330U Board V4L/DVB (10256): em28xx: Fix for KWorld 330U AC97 V4L/DVB (10254): em28xx: Fix audio URB transfer buffer race condition V4L/DVB (10250): cx25840: fix regression: fw not loaded on first use V4L/DVB (10248): v4l-dvb: fix a bunch of compile warnings. V4L/DVB (10243): em28xx: fix compile warning V4L/DVB (10240): Fix obvious swapped names in v4l2_subdev logic V4L/DVB (10233): [PATCH] Terratec Cinergy DT XS Diversity new USB ID (0ccd:0081) ...
2009-02-02block: add text file detailing queue/ sysfs filesJens Axboe
2009-01-30Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: Allow RT requests to pre-empt ongoing BE timeslice block: add sysfs file for controlling io stats accounting Mark mandatory elevator functions in the biodoc.txt include/linux: Add bsg.h to the Kernel exported headers block: silently error an unsupported barrier bio block: Fix documentation for blkdev_issue_flush() block: add bio_rw_flagged() for testing bio->bi_rw block: seperate bio/request unplug and sync bits block: export SSD/non-rotational queue flag through sysfs Fix small typo in bio.h's documentation block: get rid of the manual directory counting in blktrace block: Allow empty integrity profile block: Remove obsolete BUG_ON block: Don't verify integrity metadata on read error
2009-01-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) tulip: fix 21142 with 10Mbps without negotiation drivers/net/skfp: if !capable(CAP_NET_ADMIN): inverted logic gianfar: Fix Wake-on-LAN support smsc911x: timeout reaches -1 smsc9420: fix interrupt signalling test failures ucc_geth: Change uec phy id to the same format as gianfar's wimax: fix build issue when debugfs is disabled netxen: fix memory leak in drivers/net/netxen_nic_init.c tun: Add some missing TUN compat ioctl translations. ipv4: fix infinite retry loop in IP-Config net: update documentation ip aliases net: Fix OOPS in skb_seq_read(). net: Fix frag_list handling in skb_seq_read netxen: revert jumbo ringsize ath5k: fix locking in ath5k_config cfg80211: print correct intersected regulatory domain cfg80211: Fix sanity check on 5 GHz when processing country IE iwlwifi: fix kernel oops when ucode DMA memory allocation failure rtl8187: Fix error in setting OFDM power settings for RTL8187L mac80211: remove Michael Wu as maintainer ...
