path: root/Documentation
2015-08-16Merge tag 'armsoc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A smallish batch of fixes, a little more than expected this late, but all fixes are contained to their platforms and seem reasonably low risk: - a somewhat large SMP fix for ux500 that still seemed warranted to include here - OMAP DT fixes for pbias regulator specification that broke due to some DT reshuffling - PCIe IRQ routing bugfix for i.MX - networking fixes for keystone - runtime PM for OMAP GPMC - a couple of error path bug fixes for exynos" * tag 'armsoc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific file ARM: dts: keystone: fix the clock node for mdio memory: omap-gpmc: Don't try to save uninitialized GPMC context ARM: imx6: correct i.MX6 PCIe interrupt routing ARM: ux500: add an SMP enablement type and move cpu nodes ARM: dts: dra7: Fix broken pbias device creation ARM: dts: OMAP5: Fix broken pbias device creation ARM: dts: OMAP4: Fix broken pbias device creation ARM: dts: omap243x: Fix broken pbias device creation ARM: EXYNOS: fix double of_node_put() on error path ARM: EXYNOS: Fix potentian kfree() of ro memory
2015-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "Just small ALPS and Elan touchpads, and other driver fixups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elantech - add special check for fw_version 0x470f01 touchpad Input: twl4030-vibra - fix ERROR: Bad of_node_put() warning Input: alps - only Dell laptops have separate button bits for v2 dualpoint sticks Input: axp20x-pek - add module alias Input: turbografx - fix potential out of bound access
2015-08-08Merge tag 'usb-4.2-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are some USB and PHY fixes for 4.2-rc6 that resolve some reported issues. All of these have been in the linux-next tree for a while, full details on the patches are in the shortlog below" * tag 'usb-4.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: ARM: dts: dra7: Add syscon-pllreset syscon to SATA PHY drivers/usb: Delete XHCI command timer if necessary xhci: fix off by one error in TRB DMA address boundary check usb: udc: core: add device_del() call to error pathway phy: ti-pipe3: i783 workaround for SATA lockup after dpll unlock/relock phy-sun4i-usb: Add missing EXPORT_SYMBOL_GPL for sun4i_usb_phy_set_squelch_detect USB: sierra: add 1199:68AB device ID usb: gadget: f_printer: actually limit the number of instances usb: gadget: f_hid: actually limit the number of instances usb: gadget: f_uac2: fix calculation of uac2->p_interval usb: gadget: bdc: fix a driver crash on disconnect usb: chipidea: ehci_init_driver is intended to call one time USB: qcserial: Add support for Dell Wireless 5809e 4G Modem USB: qcserial/option: make AT URCs work for Sierra Wireless MC7305/MC7355
2015-08-06ARM: ux500: add an SMP enablement type and move cpu nodesLinus Walleij
The "cpus" node cannot be inside the "soc" node, while this works for the CoreSight blocks, the early boot code will look for "cpus" directly under the root node, so this is a hard convention. So move the CPU nodes. Augment the "reg" property to match what is actually in the hardware: 0x300 and 0x301 respectively. Then add an SMP enablement type to be used by the SMP init code, "ste,dbx500-smp". Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-05Merge tag 'phy-for-4.2-rc6' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/kishon/linux-phy into usb-linus Kishon writes: phy: for 4.2-rc6 *) Fix compiler error when sun4i usb phy driver is built as module *) Fix SATA Lockup issue in dra7 SoC Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-08-03Input: alps - only Dell laptops have separate button bits for v2 dualpoint ↵Hans de Goede
sticks It turns out that only Dell laptops have the separate button bits for v2 dualpoint sticks and that commit 92bac83dd79e ("Input: alps - non interleaved V2 dualpoint has separate stick button bits") causes regressions on Toshiba laptops. This commit adds a check for Dell laptops to the code for handling these extra button bits, fixing this regression. This patch has been tested on a Dell Latitude D620 to make sure that it does not reintroduce the original problem. Reported-and-tested-by: Douglas Christman <douglaschristman@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-08-01Merge tag 'dmaengine-fix-4.2-rc5' of ↵Linus Torvalds
git://git.infradead.org/users/vkoul/slave-dma Pull dmaengine fixes from Vinod Koul: "We had a regression due to reuse of descriptor so we have reverted that. The rest are driver fixes: - at_hdmac and at_xdmac for residue, trannfer width, and channel config - pl330 final fix for dma fails and overflow issue - xgene resouce map fix - mv_xor big endian op fix" * tag 'dmaengine-fix-4.2-rc5' of git://git.infradead.org/users/vkoul/slave-dma: Revert "dmaengine: virt-dma: don't always free descriptor upon completion" dmaengine: mv_xor: fix big endian operation in register mode dmaengine: xgene-dma: Fix the resource map to handle overlapping dmaengine: at_xdmac: fix transfer data width in at_xdmac_prep_slave_sg() dmaengine: at_hdmac: fix residue computation dmaengine: at_xdmac: fix bug about channel configuration dmaengine: pl330: Really fix choppy sound because of wrong residue calculation dmaengine: pl330: Fix overflow when reporting residue in memcpy
2015-08-01phy: ti-pipe3: i783 workaround for SATA lockup after dpll unlock/relockRoger Quadros
SATA_PLL_SOFT_RESET bit of CTRL_CORE_SMA_SW_0 must be toggled between a SATA DPLL unlock and re-lock to prevent SATA lockup. Introduce a new DT parameter 'syscon-pllreset' to provide the syscon regmap access to this register which sits in the control module. If the register is not provided we fallback to the old behaviour i.e. SATA DPLL refclk will not be disabled and we prevent SoC low power states. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-07-31Merge tag 'sound-4.2-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This became a relative big update as it includes the collected ASoC fixes. There are a few fixes in ASoC core side, mostly for DAPM and the new topology API. The rest are various ASoC driver-specific fixes, as well as the usual HD-audio and USB-audio quirks" * tag 'sound-4.2-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (29 commits) ALSA: hda - Fix MacBook Pro 5,2 quirk ALSA: hda - Fix race between PM ops and HDA init/probe ALSA: usb-audio: add dB range mapping for some devices ALSA: hda - Apply a fixup to Dell Vostro 5480 ALSA: hda - Add pin quirk for the headset mic jack detection on Dell laptop ALSA: hda - Apply fixup for another Toshiba Satellite S50D ALSA: fireworks: add support for AudioFire2 quirk ALSA: hda - Fix the headset mic that will not work on Dell desktop machine ALSA: hda - fix cs4210_spdif_automute() ASoC: pcm1681: Fix setting de-emphasis sampling rate selection ASoC: ssm4567: Keep TDM_BCLKS in ssm4567_set_dai_fmt ASoC: sgtl5000: Fix up define for SGTL5000_SMALL_POP ASoC: dapm: Don't add prefix to widget stream name ASoC: rt5645: Check if codec is initialized in workqueue handler ASoC: Intel: Get correct usage_count value to load firmware ASoC: topology: Fix to add dapm mixer info ASoC: zx: spdif: Fix devm_ioremap_resource return value check ASoC: zx: i2s: Fix devm_ioremap_resource return value check ASoC: mediatek: Use platform_of_node for machine drivers ASoC: Free card DAPM context on snd_soc_instantiate_card() error path ...
2015-07-31dmaengine: xgene-dma: Fix the resource map to handle overlappingRameshwar Prasad Sahu
There is an overlap in dma ring cmd csr region due to sharing of ethernet ring cmd csr region. This patch fix the resource overlapping by mapping the entire dma ring cmd csr region. Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-07-30Merge tag 'hwmon-for-linus-v4.2-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "Two patches headed for -stable. nct7802: Fix integer overflow seen when writing voltage limits nct7904: Rename pwm attributes to match hwmon ABI" * tag 'hwmon-for-linus-v4.2-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (nct7802) Fix integer overflow seen when writing voltage limits hwmon: (nct7904) Rename pwm attributes to match hwmon ABI
2015-07-29hwmon: (nct7904) Rename pwm attributes to match hwmon ABIGuenter Roeck
pwm attributes have well defined names, which should be used. Cc: Vadim V. Vlasov <vvlasov@dev.rtsoft.ru> Cc: stable@vger.kernel.org #v4.1+ Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-07-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "This series is larger than what I'd normally be conformable with sending for a -rc5 PULL request.. However, the bulk of the series is localized to qla2xxx target specific fixes that address a number of real-world correctness issues, that have been outstanding on the list for ~6 weeks now. They where submitted + verified + acked by the HW LLD vendor, contributed by a major production customer of the code, and are marked for v3.18.y stable code. That said, I don't see a good reason to wait another month to get these fixes into mainline. Beyond the qla2xx specific fixes, this series also includes: - bugfix for a long standing use-after-free in iscsi-target during TPG shutdown + demo-mode sessions. - bugfix for a >= v4.0 regression OOPs in iscsi-target during a iscsi_start_kthreads() failure. - bugfix for a >= v4.0 regression hang in iscsi-target for iser explicit session/connection logout. - bugfix for a iser-target bug where a early CMA REJECTED status during login triggers a NULL pointer dereference OOPs. - bugfixes for a handful of v4.2-rc1 specific regressions related to the larger set of recent backend configfs attribute changes. A big thanks to QLogic + Pure Storage for the qla2xxx target bugfixes" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (28 commits) Documentation/target: Fix tcm_mod_builder.py build breakage iser-target: Fix REJECT CM event use-after-free OOPs iscsi-target: Fix iser explicit logout TX kthread leak iscsi-target: Fix iscsit_start_kthreads failure OOPs iscsi-target: Fix use-after-free during TPG session shutdown qla2xxx: terminate exchange when command is aborted by LIO qla2xxx: drop cmds/tmrs arrived while session is being deleted qla2xxx: disable scsi_transport_fc registration in target mode qla2xxx: added sess generations to detect RSCN update races qla2xxx: Abort stale cmds on qla_tgt_wq when plogi arrives qla2xxx: delay plogi/prli ack until existing sessions are deleted qla2xxx: cleanup cmd in qla workqueue before processing TMR qla2xxx: kill sessions/log out initiator on RSCN and port down events qla2xxx: fix command initialization in target mode. qla2xxx: Remove msleep in qlt_send_term_exchange qla2xxx: adjust debug flags qla2xxx: release request queue reservation. qla2xxx: Add flush after updating ATIOQ consumer index. qla2xxx: Enable target mode for ISP27XX qla2xxx: Fix hardware lock/unlock issue causing kernel panic. ...
2015-07-27DEVICETREE: Misc fix for the AR7100 SPI controller bindingAlban Bedel
Fix the clocks property documentation and use lower case for hex values in the example. Signed-off-by: Alban Bedel <albeu@free.fr> Signed-off-by: Rob Herring <robh@kernel.org>
2015-07-24Documentation/target: Fix tcm_mod_builder.py build breakageSebastian Herbszt
Fix build breakage and set the protocol identifier based on the parameter. Fixes: 9ac8928e6a3e ("target: simplify the target template registration API") Fixes: e4aae5af810e ("target: change core_tpg_register prototype") Signed-off-by: Sebastian Herbszt <herbszt@gmx.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-07-24Merge tag 'mmc-4.2-rc3' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC fixes from Ulf Hansson: "Here are some mmc fixes intended for v4.2 rc4. Note, most of the changes are for the sdhci-esdhc-imx controller, which also required us to modify some related DTS files. Those changes have been acked by the SoC maintainer. MMC core: - Fix a reference inbalance issue for power_ro_lock_show() sysfs handler MMC host: - omap_hsmmc: Fix IRQ errorhandling for CD, DTO, and CRC - sdhci: Prevent a kernel panic while using DMA - mtk-sd: Let it depend on HAS_DMA to prevent build errors - sdhci-esdhc: Make 8BIT bus work - sdhci-esdhc-imx: Fix some regressions for DT based platforms - sdhci-pxav3: Fix a regression for DT based platforms" * tag 'mmc-4.2-rc3' of git://git.linaro.org/people/ulf.hansson/mmc: mmc: sdhci-pxav3: fix platform_data is not initialized dts: mmc: fsl-imx-esdhc: remove fsl,cd-controller support mmc: sdhci-esdhc-imx: clear f_max in boarddata mmc: sdhci-esdhc-imx: remove duplicated dts parsing mmc: sdhci: make max-frequency property in device tree work mmc: sdhci-esdhc-imx: move all non dt probe code into one function mmc: sdhci-esdhc-imx: fix cd regression for dt platform dts: imx7: fix sd card gpio polarity specified in device tree dts: imx25: fix sd card gpio polarity specified in device tree dts: imx6: fix sd card gpio polarity specified in device tree dts: imx53: fix sd card gpio polarity specified in device tree dts: imx51: fix sd card gpio polarity specified in device tree mmc: sdhci-esdhc: Make 8BIT bus work mmc: block: Add missing mmc_blk_put() in power_ro_lock_show() mmc: MMC_MTK should depend on HAS_DMA mmc: sdhci check parameters before call dma_free_coherent mmc: omap_hsmmc: Handle BADA, DEB and CEB interrupts mmc: omap_hsmmc: Fix DTO and DCRC handling
2015-07-24Merge remote-tracking branches 'asoc/fix/fsl-ssi', 'asoc/fix/intel', ↵Mark Brown
'asoc/fix/intel-kconfig' and 'asoc/fix/mediatek' into asoc-linus
2015-07-24dts: mmc: fsl-imx-esdhc: remove fsl,cd-controller supportDong Aisheng
It's not supported by driver anymore after using runtime pm and there's no user of it, so delete it now. Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> Reviewed-by: Johan Derycke <johan.derycke@barco.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2015-07-23Merge tag 'iommu-fixes-v4.2-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull iommu fixes from Joerg Roedel: "The fixes include: - a couple of fixes for the new ARM-SMMUv3 driver to fix issues found on the first real implementation of that hardware. - a patch for the Intel VT-d driver to fix a domain-id leak" * tag 'iommu-fixes-v4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/vt-d: Fix VM domain ID leak iommu/arm-smmu: Skip the execution of CMD_PREFETCH_CONFIG iommu/arm-smmu: Enlarge STRTAB_L1_SZ_SHIFT to support larger sidsize iommu/arm-smmu: Fix the values of ARM64_TCR_{I,O}RGN0_SHIFT iommu/arm-smmu: Fix LOG2SIZE setting for 2-level stream tables iommu/arm-smmu: Fix the index calculation of strtab
2015-07-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "25 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits) lib/decompress: set the compressor name to NULL on error mm/cma_debug: correct size input to bitmap function mm/cma_debug: fix debugging alloc/free interface mm/page_owner: set correct gfp_mask on page_owner mm/page_owner: fix possible access violation fsnotify: fix oops in fsnotify_clear_marks_by_group_flags() /proc/$PID/cmdline: fixup empty ARGV case dma-debug: skip debug_dma_assert_idle() when disabled hexdump: fix for non-aligned buffers checkpatch: fix long line messages about patch context mm: clean up per architecture MM hook header files MAINTAINERS: uclinux-h8-devel is moderated for non-subscribers mailmap: update Sudeep Holla's email id Update Viresh Kumar's email address mm, meminit: suppress unused memory variable warning configfs: fix kernel infoleak through user-controlled format string include, lib: add __printf attributes to several function prototypes s390/hugetlb: add hugepages_supported define mm: hugetlb: allow hugepages_supported to be architecture specific revert "s390/mm: make hugepages_supported a boot time decision" ...
2015-07-17Merge tag 'dm-4.2-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: - revert a request-based DM core change that caused IO latency to increase and adversely impact both throughput and system load - fix for a use after free bug in DM core's device cleanup - a couple DM btree removal fixes (used by dm-thinp) - a DM thinp fix for order-5 allocation failure - a DM thinp fix to not degrade to read-only metadata mode when in out-of-data-space mode for longer than the 'no_space_timeout' - fix a long-standing oversight in both dm-thinp and dm-cache by now exporting 'needs_check' in status if it was set in metadata - fix an embarrassing dm-cache busy-loop that caused worker threads to eat cpu even if no IO was actively being issued to the cache device * tag 'dm-4.2-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm cache: avoid calls to prealloc_free_structs() if possible dm cache: avoid preallocation if no work in writeback_some_dirty_blocks() dm cache: do not wake_worker() in free_migration() dm cache: display 'needs_check' in status if it is set dm thin: display 'needs_check' in status if it is set dm thin: stay in out-of-data-space mode once no_space_timeout expires dm: fix use after free crash due to incorrect cleanup sequence Revert "dm: only run the queue on completion if congested or no requests pending" dm btree: silence lockdep lock inversion in dm_btree_del() dm thin: allocate the cell_sort_array dynamically dm btree remove: fix bug in redistribute3
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17Merge tag 'staging-4.2-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging and IIO driver fixes from Greg KH: "Here's some staging and IIO driver fixes for 4.2-rc3. Nothing major, the majority are IIO issues that were reported, with a few other minor staging driver fixes. All have been in linux-next for a while with no reported issues" * tag 'staging-4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (25 commits) staging: vt6656: check ieee80211_bss_conf bssid not NULL staging: vt6655: check ieee80211_bss_conf bssid not NULL staging:lustre: remove irq.h from socklnd.h staging: make board support depend on OF_IRQ and CLKDEV_LOOKUP iio: tmp006: Check channel info on write iio: sx9500: Add missing init in sx9500_buffer_pre{en,dis}able() iio:light:ltr501: fix regmap dependency iio:light:ltr501: fix variable in ltr501_init iio: sx9500: fix bug in compensation code iio: sx9500: rework error handling of raw readings iio: magnetometer: mmc35240: fix available sampling frequencies iio:light:stk3310: Fix REGMAP_I2C dependency iio: light: STK3310: un-invert proximity values iio:adc:cc10001_adc: fix Kconfig dependency iio: light: tcs3414: Fix bug preventing to set integration time iio:accel:bmc150-accel: fix counting direction iio:light:cm3323: clear bitmask before set iio: adc: at91_adc: allow to use full range of startup time iio: DAC: ad5624r_spi: fix bit shift of output data value iio: proximity: sx9500: Fix proximity value ...
2015-07-17Merge tag 'imx-drm-fixes-2015-07-14' of ↵Dave Airlie
git://git.pengutronix.de/git/pza/linux into drm-fixes imx-drm: fixes for parallel-display, imx-tve, and ipu-common These patches fix the parallel-display driver to use the standard OF graph bindings for connecting a drm_panel via device tree instead of an undocumented, driver specific device tree property, take care to disable all IPU interrupts before setting up the irq chip to fix a kexec lockup, and fix VGA output on i.MX53-QSB boards by correcting the media bus format set by the imx-tve driver. * tag 'imx-drm-fixes-2015-07-14' of git://git.pengutronix.de/git/pza/linux: drm/imx: tve: fix media bus format for VGA output GPU: ipu: fix lockup caused by pending chained interrupts drm/imx: parallel-display: fix drm_panel support
2015-07-17Merge tag 'topic/drm-fixes-2015-07-16' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes Ok next attempt at drm-fixes pull. Big thing really is just the compat32 one for addfb2.1. * tag 'topic/drm-fixes-2015-07-16' of git://anongit.freedesktop.org/drm-intel: drm: Provide compat ioctl for addfb2.1 Documentation: drm: Fix tablulation in KMS properties table drm: add a check for x/y in drm_mode_setcrtc drm/rockchip: use drm_gem_mmap helpers
2015-07-16dm cache: display 'needs_check' in status if it is setMike Snitzer
There is currently no way to see that the needs_check flag has been set in the metadata. Display 'needs_check' in the cache status if it is set in the cache metadata. Also, update cache documentation. Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-07-16dm thin: display 'needs_check' in status if it is setMike Snitzer
There is currently no way to see that the needs_check flag has been set in the metadata. Display 'needs_check' in the thin-pool status if it is set in the thinp metadata. Also, update thinp documentation. Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-07-15Merge tag 'arc-v4.2-rc3-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: - Makefile changes (top-level+ARC) reinstates -O3 builds (regression since 3.16) - IDU intc related fixes, IRQ affinity - patch to make bitops safer for ARC - perf fix from Alexey to remove signed PC braino - Futex backend gets llock/scond support * tag 'arc-v4.2-rc3-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARCv2: support HS38 releases ARC: make sure instruction_pointer() returns unsigned value ARC: slightly refactor macros for boot logging ARC: Add llock/scond to futex backend arc:irqchip: prepare for drivers/irqchip/irqchip.h removal ARC: Make ARC bitops "safer" (add anti-optimization) ARCv2: [axs103] bump CPU frequency from 75 to 90 MHZ ARCv2: intc: IDU: Fix potential race in installing a chained IRQ handler ARCv2: intc: IDU: support irq affinity ARC: fix unused var wanring ARC: Don't memzero twice in dma_alloc_coherent for __GFP_ZERO ARC: Override toplevel default -O2 with -O3 kbuild: Allow arch Makefiles to override {cpp,ld,c}flags ARCv2: guard SLC DMA ops with spinlock ARC: Kconfig: better way to disable ARC_HAS_LLSC for ARC_CPU_750D
2015-07-13Merge tag 'iio-fixes-for-4.2a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: First set of IIO fixes for the 4.2 cycle. * Fix a regression in hid sensors suspend time as a result of adding runtime pm. The normal flow of waking up devices in order to go into suspend (given the devices are normally suspended when not reading) to a regression in suspend time on some laptops (reports of an additional 8 seconds). Fix this by checking to see if a user action resulting in the wake up, and make it a null operation if it didn't. Note that for hid sensors, there is nothing useful to be done when moving into a full suspend from a runtime suspend so they might as well be left alone. * rochip_saradc: fix some missing MODULE_* data including the licence so that the driver does not taint the kernel incorrectly and can build as a module. * twl4030 - mark irq as oneshot as it always should have been. * inv-mpu - write formats for attributes not specified, leading to miss interpretation of the gyro scale channel when written. * Proximity ABI clarification. This had snuck through as a mess. Some drivers thought proximity went in one direction, some the other. We went with the most common option, documented it and fixed up the drivers going the other way. Fix for sx9500 included in this set. * ad624r - fix a wrong shift in the output data. * at91_adc - remove a false limit on the value of the STARTUP register applied by too small a type for the device tree parameter. * cm3323 - clear the bits when setting the integration time (otherwise we can only ever set more bits in the relevant field). * bmc150-accel - multiple triggers are registered, but on error were not being unwound in the opposite order leading to removal of triggers that had not yet successfully been registered (count down instead of up when unwinding). * tcs3414 - ensure right part of val / val2 pair read so that the integration time is not always 0. * cc10001_adc - bug in kconfig dependency. Use of OR when AND was intended.
2015-07-11Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: "A fairly random colletion of fixes based on -rc1 for OMAP, sunxi and prima2 as well as a few arm64-specific DT fixes. This series also includes a late to support a new Allwinner (sunxi) SoC, but since it's rather simple and isolated to the platform-specific code, it's included it for this -rc" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MG arm: dts: vexpress: add missing CCI PMU device node to TC2 arm: dts: vexpress: describe all PMUs in TC2 dts GICv3: Add ITS entry to THUNDER dts arm64: dts: Add poweroff button device node for APM X-Gene platform ARM: dts: am4372.dtsi: disable rfbi ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2 ARM: dts: am4372: Add emif node Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep" ARM: sunxi: Enable simplefb in the defconfig ARM: Remove deprecated symbol from defconfig files ARM: sunxi: Add Machine support for A33 ARM: sunxi: Introduce Allwinner H3 support Documentation: sunxi: Update Allwinner SoC documentation ARM: prima2: move to use REGMAP APIs for rtciobrg ARM: dts: atlas7: add pinctrl and gpio descriptions ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps memory: omap-gpmc: Fix parsing of devices
2015-07-10drm/imx: parallel-display: fix drm_panel supportPhilipp Zabel
The parallel-display driver used an undocumented, non-standard property "fsl,panel" to optionally associate with a drm_panel device. This patch fixes the driver to use the same OF graph bindings as the LDB driver instead: parallel-display { compatible = "fsl,imx-parallel-display"; ... port@1 { reg = <1>; parallel_out: endpoint { remote_endpoint = <&panel_in>; }; }; }; panel { ... port { panel_in: endpoint { remote-endpoint = <&parallel_out>; }; }; }; Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Tested-by: Gary Bisson <gary.bisson@boundarydevices.com>
2015-07-09Merge tag 'omap-for-v4.2/fixes-rc1' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v4.2-rc1" from Tony Lindgren: Minor fixes for omaps against v4.2-rc1. Mostly just minor dts changes except for a GPMC fix to not use names for probing devices. Also a one liner clean-up to remove unecessary return from a void function. The summary for the changes being: - Fix probe for GPMC devices by reoving limitations based on device name - Remove unnecessary return from a void function - Revert beaglebone RTC sleep fix, we now have a better fix merged - Add am4372 EMIF node to fix a warning - Add am57xx-beagle-x15 power supply to fix USB2 if USB1 is disabled - Disable rfbi for am4372 as it does not have a driver * tag 'omap-for-v4.2/fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: am4372.dtsi: disable rfbi ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2 ARM: dts: am4372: Add emif node Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep" ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps memory: omap-gpmc: Fix parsing of devices
2015-07-09Merge tag 'sunxi-late-for-4.2' of ↵Kevin Hilman
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into fixes Merge "Allwinner late changes for 4.2" from Maxime Ripard: Allwinner late changes for 4.2 A bunch of defconfig changes, and some patches to make the Allwinner H3 and A33 boot properly. * tag 'sunxi-late-for-4.2' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux: ARM: sunxi: Enable simplefb in the defconfig ARM: Remove deprecated symbol from defconfig files ARM: sunxi: Add Machine support for A33 ARM: sunxi: Introduce Allwinner H3 support Documentation: sunxi: Update Allwinner SoC documentation
2015-07-09ASoC: mediatek: Use platform_of_node for machine driversKoro Chen
This replaces the platform_name in snd_soc_dai_link by device tree node. Signed-off-by: Koro Chen <koro.chen@mediatek.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-08iommu/arm-smmu: Skip the execution of CMD_PREFETCH_CONFIGZhen Lei
Hisilicon SMMUv3 devices treat CMD_PREFETCH_CONFIG as a illegal command, execute it will trigger GERROR interrupt. Although the gerror code manage to turn the prefetch into a SYNC, and the system can continue to run normally, but it's ugly to print error information. Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com> [will: extended binding documentation] Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-07-07Documentation: drm: Fix tablulation in KMS properties tableGraham Whaley
Commit 712a0dd91c4a ("Documentation/drm: Update rotation property") left an extra 'rowspan' for the row omap, which pushed the following qxl rows columns out to column 8 and broke the tabulation. Remove the errant rowspan. Signed-off-by: Graham Whaley <graham.whaley@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-07-07PM / hibernate: clarify resume documentationUwe Geuder
it was not the whole truth that kernel mode cannot be used with swap on LVM Signed-off-by: Uwe Geuder <linuxkernel2015-ugeuder@snkmail.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-06ARM: dts: am4372: Add emif nodeDave Gerlach
Add node for TI AM4372 EMIF. Without this we get a warning with the recent commit fabbe6df (ARM: OMAP: AM43xx hwmod: Add data for am43xx emif hwmod). Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Tested-by: Felipe Balbi <balbi@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-06kbuild: Allow arch Makefiles to override {cpp,ld,c}flagsMichal Marek
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command line options), the arch Makefile is included earlier by the main Makefile, preventing the arc architecture to set its -O3 compiler option. Since there might be more use cases for an arch Makefile to fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and ARCH_CFLAGS variables that are appended to the respective kbuild variables. The user still has the final say via the KCPPFLAGS, KAFLAGS and KCFLAGS variables. Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: stable@vger.kernel.org # 3.16+ Signed-off-by: Michal Marek <mmarek@suse.com>
2015-07-05ARM: sunxi: Add Machine support for A33Vishnu Patekar
Add machine support for the Allwinner A33 quad core cortex-a7 based SoC, which is similar to the A23 SoC. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Tested-by: Chen-Yu Tsai <wens@csie.org>
2015-07-05ARM: sunxi: Introduce Allwinner H3 supportJens Kuske
The Allwinner H3 is a quad-core Cortex-A7-based SoC. It is very similar to other sun8i family SoCs like the A23. Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-07-05Documentation: sunxi: Update Allwinner SoC documentationJens Kuske
There are some new Allwinner SoCs available, namely A33, A83T and H3. Update the documentation to mention those and the related documents. Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "It's been a busy development cycle for target-core in a number of different areas. The fabric API usage for se_node_acl allocation is now within target-core code, dropping the external API callers for all fabric drivers tree-wide. There is a new conversion to RCU hlists for se_node_acl and se_portal_group LUN mappings, that turns fast-past LUN lookup into a completely lockless code-path. It also removes the original hard-coded limitation of 256 LUNs per fabric endpoint. The configfs attributes for backends can now be shared between core and driver code, allowing existing drivers to use common code while still allowing flexibility for new backend provided attributes. The highlights include: - Merge sbc_verify_dif_* into common code (sagi) - Remove iscsi-target support for obsolete IFMarker/OFMarker (Christophe Vu-Brugier) - Add bidi support in target/user backend (ilias + vangelis + agover) - Move se_node_acl allocation into target-core code (hch) - Add crc_t10dif_update common helper (akinobu + mkp) - Handle target-core odd SGL mapping for data transfer memory (akinobu) - Move transport ID handling into target-core (hch) - Move task tag into struct se_cmd + support 64-bit tags (bart) - Convert se_node_acl->device_list[] to RCU hlist (nab + hch + paulmck) - Convert se_portal_group->tpg_lun_list[] to RCU hlist (nab + hch + paulmck) - Simplify target backend driver registration (hch) - Consolidate + simplify target backend attribute implementations (hch + nab) - Subsume se_port + t10_alua_tg_pt_gp_member into se_lun (hch) - Drop lun_sep_lock for se_lun->lun_se_dev RCU usage (hch + nab) - Drop unnecessary core_tpg_register TFO parameter (nab) - Use 64-bit LUNs tree-wide (hannes) - Drop left-over TARGET_MAX_LUNS_PER_TRANSPORT limit (hannes)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (76 commits) target: Bump core version to v5.0 target: remove target_core_configfs.h target: remove unused TARGET_CORE_CONFIG_ROOT define target: consolidate version defines target: implement WRITE_SAME with UNMAP bit using ->execute_unmap target: simplify UNMAP handling target: replace se_cmd->execute_rw with a protocol_data field target/user: Fix inconsistent kmap_atomic/kunmap_atomic target: Send UA when changing LUN inventory target: Send UA upon LUN RESET tmr completion target: Send UA on ALUA target port group change target: Convert se_lun->lun_deve_lock to normal spinlock target: use 'se_dev_entry' when allocating UAs target: Remove 'ua_nacl' pointer from se_ua structure target_core_alua: Correct UA handling when switching states xen-scsiback: Fix compile warning for 64-bit LUN target: Remove TARGET_MAX_LUNS_PER_TRANSPORT target: use 64-bit LUNs target: Drop duplicate + unused se_dev_check_wce target: Drop unnecessary core_tpg_register TFO parameter ...
2015-07-04Merge tag 'ntb-4.2' of git://github.com/jonmason/ntbLinus Torvalds
Pull NTB updates from Jon Mason: "This includes a pretty significant reworking of the NTB core code, but has already produced some significant performance improvements. An abstraction layer was added to allow the hardware and clients to be easily added. This required rewriting the NTB transport layer for this abstraction layer. This modification will allow future "high performance" NTB clients. In addition to this change, a number of performance modifications were added. These changes include NUMA enablement, using CPU memcpy instead of asyncdma, and modification of NTB layer MTU size" * tag 'ntb-4.2' of git://github.com/jonmason/ntb: (22 commits) NTB: Add split BAR output for debugfs stats NTB: Change WARN_ON_ONCE to pr_warn_once on unsafe NTB: Print driver name and version in module init NTB: Increase transport MTU to 64k from 16k NTB: Rename Intel code names to platform names NTB: Default to CPU memcpy for performance NTB: Improve performance with write combining NTB: Use NUMA memory in Intel driver NTB: Use NUMA memory and DMA chan in transport NTB: Rate limit ntb_qp_link_work NTB: Add tool test client NTB: Add ping pong test client NTB: Add parameters for Intel SNB B2B addresses NTB: Reset transport QP link stats on down NTB: Do not advance transport RX on link down NTB: Differentiate transport link down messages NTB: Check the device ID to set errata flags NTB: Enable link for Intel root port mode in probe NTB: Read peer info from local SPAD in transport NTB: Split ntb_hw_intel and ntb_transport drivers ...
2015-07-04dax: Add block size note to documentationMatthew Wilcox
For block devices which are small enough, mkfs will default to creating a filesystem with block sizes smaller than page size. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-04NTB: Rename Intel code names to platform namesDave Jiang
Instead of using the platform code names, use the correct platform names to identify the respective Intel NTB hardware. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add tool test clientAllen Hubbe
This is a simple debugging driver that enables the doorbell and scratch pad registers to be read and written from the debugfs. This tool enables more complicated debugging to be scripted from user space. This driver may be used to test that your ntb hardware and drivers are functioning at a basic level. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add ping pong test clientAllen Hubbe
This is a simple ping pong driver that exercises the scratch pads and doorbells of the ntb hardware. This driver may be used to test that your ntb hardware and drivers are functioning at a basic level. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add parameters for Intel SNB B2B addressesAllen Hubbe
Add module parameters for the addresses to be used in B2B topology. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
