git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"Lots of tweaks, small fixes, optimizations, and some helper functions
to help out the rest of the kernel to ease their use of trace events.
The big change for this release is the allowing of other tracers, such
as the latency tracers, to be used in the trace instances and allow
for function or function graph tracing to be in the top level
simultaneously"
* tag 'trace-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (44 commits)
tracing: Fix memory leak on instance deletion
tracing: Fix leak of ring buffer data when new instances creation fails
tracing/kprobes: Avoid self tests if tracing is disabled on boot up
tracing: Return error if ftrace_trace_arrays list is empty
tracing: Only calculate stats of tracepoint benchmarks for 2^32 times
tracing: Convert stddev into u64 in tracepoint benchmark
tracing: Introduce saved_cmdlines_size file
tracing: Add __get_dynamic_array_len() macro for trace events
tracing: Remove unused variable in trace_benchmark
tracing: Eliminate double free on failure of allocation on boot up
ftrace/x86: Call text_ip_addr() instead of the duplicated code
tracing: Print max callstack on stacktrace bug
tracing: Move locking of trace_cmdline_lock into start/stop seq calls
tracing: Try again for saved cmdline if failed due to locking
tracing: Have saved_cmdlines use the seq_read infrastructure
tracing: Add tracepoint benchmark tracepoint
tracing: Print nasty banner when trace_printk() is in use
tracing: Add funcgraph_tail option to print function name after closing braces
tracing: Eliminate duplicate TRACE_GRAPH_PRINT_xx defines
tracing: Add __bitmask() macro to trace events to cpumasks and other bitmasks
Matt aded this plane property before we had a table giving a summary of
the properties. Add it there.
Cc: Matt Roper <matthew.d.roper@intel.com>
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
git://anongit.freedesktop.org/tegra/linux into drm-next
drm/panel: Changes for v3.16-rc1
This set of commits contains a couple of fixes to existing panel drivers
and support for some new panels.
One commit touches the DRM core in that in modifies the MIPI DSI support
to hook up the shutdown function so that drivers can provide code that's
run on shutdown. This is used by a subsequent commit to make the simple
panel driver power off the backlight on shutdown.
* tag 'drm/panel/for-3.16-rc1' of git://anongit.freedesktop.org/tegra/linux:
drm/panel: simple - Add AUO B133XTN01 panel support
drm/panel: simple - Disable panel on shutdown
drm/panel: add support for EDT ET057090DHU panel
drm/panel: Add support for EDT ETM0700G0DH6 and ET070080DH6 panels
drm/panel: ld9040: add power control sequence
drm/panel: s6e8aa0: silence array overflow warning
drm/dsi: Support device shutdown
drm/tegra: Changes for v3.16-rc1
The majority of these changes are a slew of cleanups across the board.
A more noteworthy change is the addition of drm_dev_set_unique() and the
conversion of the Tegra DRM driver to use it. This allows us to get rid
of the host1x drm_bus implementation. Other USB and platform drivers can
be changed in a similar way. Unfortunately for most PCI devices there is
some userspace that relies on the old functionality and cannot be as
easily converted.
HDMI and hardware cursor support is added for Tegra124. The SOR output
gains support for exposing CRCs via debugfs, which can be used for
automated testing. Many values that were hardcoded in the SOR/eDP code
are now computed at runtime to increase compatibility with more devices.
* tag 'drm/tegra/for-3.16-rc1' of git://anongit.freedesktop.org/tegra/linux: (47 commits)
drm/tegra: sor - Remove obsolete comment
drm/tegra: sor - Enable only the necessary number of lanes
drm/tegra: sor - Power on only the necessary lanes
drm/tegra: sor - Do not program interlaced mode registers
drm/tegra: sor - Do not hardcode link speed
drm/tegra: sor - Do not hardcode number of blank symbols
drm/tegra: sor - Don't hardcode link parameters
drm/tegra: sor - Change power down ordering
drm/tegra: sor - Fix copy/paste error
drm/tegra: sor - Remove pixel clock rounding
drm/tegra: sor - Make debugfs setup consistent
drm/tegra: sor - Recursively remove debugfs tree
drm/tegra: dp - Mark the connector as hotplug capable
drm/tegra: dp - Implement hotplug detection in work queue
drm/tegra: Add hardware cursor support
drm/tegra: Remove host1x drm_bus implementation
drm: Document how to register devices without struct drm_bus
drm: Add device registration documentation
drm: Introduce drm_dev_set_unique()
gpu: host1x: Rename internal functions for clarity
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"A lot of activities on cgroup side. Heavy restructuring including
locking simplification took place to improve the code base and enable
implementation of the unified hierarchy, which currently exists behind
a __DEVEL__ mount option. The core support is mostly complete but
individual controllers need further work. To explain the design and
rationales of the the unified hierarchy
Documentation/cgroups/unified-hierarchy.txt
is added.
Another notable change is css (cgroup_subsys_state - what each
controller uses to identify and interact with a cgroup) iteration
update. This is part of continuing updates on css object lifetime and
visibility. cgroup started with reference count draining on removal
way back and is now reaching a point where csses behave and are
iterated like normal refcnted objects albeit with some complexities to
allow distinguishing the state where they're being deleted. The css
iteration update isn't taken advantage of yet but is planned to be
used to simplify memcg significantly"
* 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (77 commits)
cgroup: disallow disabled controllers on the default hierarchy
cgroup: don't destroy the default root
cgroup: disallow debug controller on the default hierarchy
cgroup: clean up MAINTAINERS entries
cgroup: implement css_tryget()
device_cgroup: use css_has_online_children() instead of has_children()
cgroup: convert cgroup_has_live_children() into css_has_online_children()
cgroup: use CSS_ONLINE instead of CGRP_DEAD
cgroup: iterate cgroup_subsys_states directly
cgroup: introduce CSS_RELEASED and reduce css iteration fallback window
cgroup: move cgroup->serial_nr into cgroup_subsys_state
cgroup: link all cgroup_subsys_states in their sibling lists
cgroup: move cgroup->sibling and ->children into cgroup_subsys_state
cgroup: remove cgroup->parent
device_cgroup: remove direct access to cgroup->children
memcg: update memcg_has_children() to use css_next_child()
memcg: remove tasks/children test from mem_cgroup_force_empty()
cgroup: remove css_parent()
cgroup: skip refcnting on normal root csses and cgrp_dfl_root self css
cgroup: use cgroup->self.refcnt for cgroup refcnting
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
"Nothing too interesting - another ahci platform driver variant,
additional controller support, minor fixes and cleanups"
* 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci: Add Device ID for HighPoint RocketRaid 642L
ata: ep93xx: use dmaengine_prep_slave_sg api instead of internal callback
ahci: add PCI ID for Marvell 88SE91A0 SATA Controller
sata_fsl: remove check for CONFIG_MPC8315_DS
ahci: add support for Hisilicon sata
libahci_platform: add host_flags parameter in ahci_platform_init_host()
ata: ahci: append new hflag AHCI_HFLAG_NO_FBS
ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host drivers
ata: ahci_mvebu: new driver for Marvell Armada 380 AHCI interfaces
Documentation: dt-bindings: reformat and order list of ahci-platform compatibles
libata-sff: remove dead code
ata: SATL compliance for Inquiry Product Revision
pata_octeon_cf: use devm_kzalloc() to allocate cf_port
Extend the year to 2014 in the copyright.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
This panel is used by nyan-big and can be supported by the simple-panel
driver.
Signed-off-by: Stéphane Marchesin <marcheu@chromium.org>
[treding@nvidia.com: add device tree binding document]
Signed-off-by: Thierry Reding <treding@nvidia.com>
git://git.linaro.org/people/mike.turquette/linux into next
Pull clock framework updates from Mike Turquette:
"The clock framework changes for 3.16 are pretty typical: mostly clock
driver additions and fixes. There are additions to the clock core
code for some of the basic types (e.g. the common divider type has
some fixes and featured added to it).
One minor annoyance is a last-minute dependency that wasn't handled
quite right. Commit ba0fae3b06a6 ("clk: berlin: add core clock driver
for BG2/BG2CD") in this pull request depends on
include/dt-bindings/clock/berlin2.h, which is already in your tree via
the arm-soc pull request. Building for the berlin platform will break
when the clk tree is built on it's own, but merged into your master
branch everything should be fine"
* tag 'clk-for-linus-3.16' of git://git.linaro.org/people/mike.turquette/linux: (75 commits)
mmc: sunxi: Add driver for SD/MMC hosts found on Allwinner sunxi SoCs
clk: export __clk_round_rate for providers
clk: versatile: free icst on error return
clk: qcom: Return error pointers for unimplemented clocks
clk: qcom: Support msm8974pro global clock control hardware
clk: qcom: Properly support display clocks on msm8974
clk: qcom: Support display RCG clocks
clk: qcom: Return highest rate when round_rate() exceeds plan
clk: qcom: Fix mmcc-8974's PLL configurations
clk: qcom: Fix clk_rcg2_is_enabled() check
clk: berlin: add core clock driver for BG2Q
clk: berlin: add core clock driver for BG2/BG2CD
clk: berlin: add driver for BG2x complex divider cells
clk: berlin: add driver for BG2x simple PLLs
clk: berlin: add driver for BG2x audio/video PLL
clk: st: Terminate of match table
clk/exynos4: Fix compilation warning
ARM: shmobile: r8a7779: Add clock index macros for DT sources
clk: divider: Fix overflow in clk_divider_bestdiv
clk: u300: Terminate of match table
into next
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 3.16:
- Added test vectors for SHA/AES-CCM/DES-CBC/3DES-CBC.
- Fixed a number of error-path memory leaks in tcrypt.
- Fixed error-path memory leak in caam.
- Removed unnecessary global mutex from mxs-dcp.
- Added ahash walk interface that can actually be asynchronous.
- Cleaned up caam error reporting.
- Allow crypto_user get operation to be used by non-root users.
- Add support for SSS module on Exynos.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/cryptodev-2.6: (60 commits)
crypto: testmgr - add aead cbc des, des3_ede tests
crypto: testmgr - Fix DMA-API warning
crypto: cesa - tfm->__crt_alg->cra_type directly
crypto: sahara - tfm->__crt_alg->cra_name directly
crypto: padlock - tfm->__crt_alg->cra_name directly
crypto: n2 - tfm->__crt_alg->cra_name directly
crypto: dcp - tfm->__crt_alg->cra_name directly
crypto: cesa - tfm->__crt_alg->cra_name directly
crypto: ccp - tfm->__crt_alg->cra_name directly
crypto: geode - Don't use tfm->__crt_alg->cra_name directly
crypto: geode - Weed out printk() from probe()
crypto: geode - Consistently use AES_KEYSIZE_128
crypto: geode - Kill AES_IV_LENGTH
crypto: geode - Kill AES_MIN_BLOCK_SIZE
crypto: mxs-dcp - Remove global mutex
crypto: hash - Add real ahash walk interface
hwrng: n2-drv - Introduce the use of the managed version of kzalloc
crypto: caam - reinitialize keys_fit_inline for decrypt and givencrypt
crypto: s5p-sss - fix multiplatform build
hwrng: timeriomem - remove unnecessary OOM messages
Merge more updates from Andrew Morton:
- Most of the rest of MM.
This includes "mark remap_file_pages syscall as deprecated" but the
actual "replace remap_file_pages syscall with emulation" is held
back. I guess we'll need to work out when to pull the trigger on
that one.
- various minor cleanups to obscure filesystems
- the drivers/rtc queue
- hfsplus updates
- ufs, hpfs, fatfs, affs, reiserfs
- Documentation/
- signals
- procfs
- cpu hotplug
- lib/idr.c
- rapidio
- sysctl
- ipc updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (171 commits)
ufs: sb mutex merge + mutex_destroy
powerpc: update comments for generic idle conversion
cris: update comments for generic idle conversion
idle: remove cpu_idle() forward declarations
nbd: zero from and len fields in NBD_CMD_DISCONNECT.
mm: convert some level-less printks to pr_*
MAINTAINERS: adi-buildroot-devel is moderated
MAINTAINERS: add linux-api for review of API/ABI changes
mm/kmemleak-test.c: use pr_fmt for logging
fs/dlm/debug_fs.c: replace seq_printf by seq_puts
fs/dlm/lockspace.c: convert simple_str to kstr
fs/dlm/config.c: convert simple_str to kstr
mm: mark remap_file_pages() syscall as deprecated
mm: memcontrol: remove unnecessary memcg argument from soft limit functions
mm: memcontrol: clean up memcg zoneinfo lookup
mm/memblock.c: call kmemleak directly from memblock_(alloc|free)
mm/mempool.c: update the kmemleak stack trace for mempool allocations
lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations
mm: introduce kmemleak_update_trace()
mm/kmemleak.c: use %u to print ->checksum
The remap_file_pages() system call is used to create a nonlinear
mapping, that is, a mapping in which the pages of the file are mapped
into a nonsequential order in memory. The advantage of using
remap_file_pages() over using repeated calls to mmap(2) is that the
former approach does not require the kernel to create additional VMA
(Virtual Memory Area) data structures.
Supporting of nonlinear mapping requires significant amount of
non-trivial code in kernel virtual memory subsystem including hot paths.
Also to get nonlinear mapping work kernel need a way to distinguish
normal page table entries from entries with file offset (pte_file).
Kernel reserves flag in PTE for this purpose. PTE flags are scarce
resource especially on some CPU architectures. It would be nice to free
up the flag for other usage.
Fortunately, there are not many users of remap_file_pages() in the wild.
It's only known that one enterprise RDBMS implementation uses the
syscall on 32-bit systems to map files bigger than can linearly fit into
32-bit virtual address space. This use-case is not critical anymore
since 64-bit systems are widely available.
The plan is to deprecate the syscall and replace it with an emulation.
The emulation will create new VMAs instead of nonlinear mappings. It's
going to work slower for rare users of remap_file_pages() but ABI is
preserved.
One side effect of emulation (apart from performance) is that user can
hit vm.max_map_count limit more easily due to additional VMAs. See
comment for DEFAULT_MAX_MAP_COUNT for more details on the limit.
[akpm@linux-foundation.org: fix spello]
Cc: Dave Jones <davej@redhat.com>
Cc: Armin Rigo <arigo@tunes.org>
The memory allocation stack trace is not always useful for debugging a
memory leak (e.g. radix_tree_preload). This function, when called,
updates the stack trace for an already allocated object.
Memory reclaim always uses swappiness of the reclaim target memcg
(origin of the memory pressure) or vm_swappiness for global memory
reclaim. This behavior was consistent (except for difference between
global and hard limit reclaim) because swappiness was enforced to be
consistent within each memcg hierarchy.
After "mm: memcontrol: remove hierarchy restrictions for swappiness and
oom_control" each memcg can have its own swappiness independent of
hierarchical parents, though, so the consistency guarantee is gone.
This can lead to an unexpected behavior. Say that a group is explicitly
configured to not swapout by memory.swappiness=0 but its memory gets
swapped out anyway when the memory pressure comes from its parent with a
It is also unexpected that the knob is meaningless without setting the
hard limit which would trigger the reclaim and enforce the swappiness.
There are setups where the hard limit is configured higher in the
hierarchy by an administrator and children groups are under control of
somebody else who is interested in the swapout behavior but not
necessarily about the memory limit.
From a semantic point of view swappiness is an attribute defining anon
vs.
file proportional scanning of LRU which is memcg specific (unlike
charges which are propagated up the hierarchy) so it should be applied
to the particular memcg's LRU regardless where the memory pressure comes
from.
This patch removes vmscan_swappiness() and stores the swappiness into
the scan_control structure. mem_cgroup_swappiness is then used to
provide the correct value before shrink_lruvec is called. The global
vm_swappiness is used for the root memcg.
[hughd@google.com: oopses immediately when booted with cgroup_disable=memory]
Cc: Tejun Heo <tj@kernel.org>
When writing to a sysctl string, each write, regardless of VFS position,
begins writing the string from the start. This means the contents of
the last write to the sysctl controls the string contents instead of the
first:
open("/proc/sys/kernel/modprobe", O_WRONLY) = 1
write(1, "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"..., 4096) = 4096
write(1, "/bin/true", 9) = 9
close(1) = 0
$ cat /proc/sys/kernel/modprobe
/bin/true
Expected behaviour would be to have the sysctl be "AAAA..." capped at
maxlen (in this case KMOD_PATH_LEN: 256), instead of truncating to the
contents of the second write. Similarly, multiple short writes would
not append to the sysctl.
The old behavior is unlike regular POSIX files enough that doing audits
of software that interact with sysctls can end up in unexpected or
dangerous situations. For example, "as long as the input starts with a
trusted path" turns out to be an insufficient filter, as what must also
happen is for the input to be entirely contained in a single write
syscall -- not a common consideration, especially for high level tools.
This provides kernel.sysctl_writes_strict as a way to make this behavior
act in a less surprising manner for strings, and disallows non-zero file
position when writing numeric sysctls (similar to what is already done
when reading from non-zero file positions). For now, the default (0) is
to warn about non-zero file position use, but retain the legacy
behavior. Setting this to -1 disables the warning, and setting this to
1 enables the file position respecting behavior.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: move misplaced hunk, per Randy]
Cc: Randy Dunlap <rdunlap@infradead.org>
panic_notifers
Add a "crash_kexec_post_notifiers" boot option to run kdump after
running panic_notifiers and dump kmsg. This can help rare situations
where kdump fails because of unstable crashed kernel or hardware failure
(memory corruption on critical data/code), or the 2nd kernel is already
broken by the 1st kernel (it's a broken behavior, but who can guarantee
that the "crashed" kernel works correctly?).
Usage: add "crash_kexec_post_notifiers" to kernel boot option.
Note that this actually increases risks of the failure of kdump. This
option should be set only if you worry about the rare case of kdump
failure rather than increasing the chance of success.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Acked-by: Motohiro Kosaki <Motohiro.Kosaki@us.fujitsu.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com>
Cc: Satoru MORIYA <satoru.moriya.br@hitachi.com>
Cc: Tomoki Sekiyama <tomoki.sekiyama@hds.com>
Examples introducing neccesity of RMB+WMP pair reads as
A=3 READ B
www rrrrrr
B=4 READ A
Note the opposite order of reads vs writes.
But the first example without barriers reads as
A=3 READ A
B=4 READ B
There are 4 outcomes in the first example.
But if someone new to the concept tries to insert barriers like this:
A=3 READ A
www rrrrrr
B=4 READ B
he will still get all 4 possible outcomes, because "READ A" is first.
All this can be utterly confusing because barrier pair seems to be
superfluous. In short, fixup first example to match latter examples
with barriers.
Linked article in seq_file.txt still uses create_proc_entry which was
removed in commit 80e928f7ebb9 ("proc: Kill create_proc_entry()").
This patch adds information for kernel 3.10 and above
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Jonathan Corbet <corbet@lwn.net>
Update the SubmittingPatches process to include howto about the new
'Fixes:' tag to be used when a patch fixes an issue in a previous commit
(found by git-bisect for example).
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Add structure for parsed BPB information, struct fat_bios_param_block,
and move all of the deserialization and validation logic from
fat_fill_super() into fat_read_bpb().
Add a 'dos1xfloppy' mount option to infer DOS 2.x BIOS Parameter Block
defaults from block device geometry for ancient floppies and floppy
images, as a fall-back from the default BPB parsing logic.
When fat_read_bpb() finds an invalid FAT filesystem and dos1xfloppy is
set, fall back to fat_read_static_bpb(). fat_read_static_bpb()
validates that the entire BPB is zero, and that the floppy has a
DOS-style 8086 code bootstrapping header. Then it fills in default BPB
values from media size and a table.[0]
Media size is assumed to be static for archaic FAT volumes. See also:
[1].
Fixes kernel.org bug #42617.
[0]: https://en.wikipedia.org/wiki/File_Allocation_Table#Exceptions
[1]: http://www.win.tue.nl/~aeb/linux/fs/fat/fat-1.html
[hirofumi@mail.parknet.co.jp: fix missed error code]
Signed-off-by: Conrad Meyer <cse.cem@gmail.com>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Tested-by: Alan Cox <alan@linux.intel.com>
This enables the setting of a custom clock name for the clock provided by
the hym8563 rtc.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Mike Turquette <mturquette@linaro.org>
RTC DTS binding
Signed-off-by: Rameshwar Prasad Sahu <rsahu@apm.com>
Signed-off-by: Loc Ho <lho@apm.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into next
Pull i2c updates from Wolfram Sang:
"I2C has the following updates for 3.16:
- major cleanups to the rcar and sh_mobile drivers
- removal of nuc900 driver which had a compile error for years
- usual bunch of driver updates, bugfixes and cleanups"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (44 commits)
i2c: pca954x: Fix compilation without CONFIG_GPIOLIB
i2c: mux: pca954x: Use the descriptor-based GPIO API
i2c: mpc: insert DR read in i2c_fixup()
i2c: bfin: turn to Resource-managed API in probe function
i2c: Make of_device_id array const
i2c: remove unnecessary OOM messages
i2c: designware-pci: Add Haswell PCI IDs
i2c: designware: Add runtime PM hooks
i2c: designware: Disable device on system suspend
i2c: nuc900: remove driver
i2c: imx: update i2c clock divider for each transaction
i2c: imx: fix the i2c bus hang issue when do repeat restart
i2c: rcar: update copyright and license information
i2c: rcar: janitorial cleanup after refactoring
i2c: rcar: reuse status bits as enable bits
i2c: rcar: remove spinlock
i2c: rcar: refactor status bit handling
i2c: rcar: refactor setting up msg
i2c: rcar: check bus free before first message
i2c: rcar: refactor irq state machine
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd into next
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- increase DT coverage: arizona, mc13xxx, stmpe-i2c, syscon,
sun6i-prcm
- regmap use of and/or clean-up: tps65090, twl6040
- basic renaming: max14577
- use new cpufreq helpers: db8500-prcmu
- increase regulator support: stmpe, arizona, wm5102
- reduce legacy GPIO overhead: stmpe
- provide necessary remove path: bcm590xx
- expand sysfs presence: kempld
- move driver specific code out to drivers: rtc-s5m, arizona
- clk handling: twl6040
- use managed (devm_*) resources: ipaq-micro
- clean-up/remove unused/duplicated code: tps65218, sec, pm8921,
abx500-core, db8500-prcmu, menelaus
- build/boot/sematic bug fixes: rtsx_usb, stmpe, bcm590xx, abx500,
mc13xxx, rdc321x-southbridge, mfd-core, sec, max14577, syscon,
cros_ec_spi
- constify stuff: sm501, tps65910, tps6507x, tps6586x, max77686,
max8997, kempld, max77693, max8907, rtsx_usb, db8500-prcmu,
max8998, wm8400, sec, lp3943, max14577, as3711, omap-usb-host,
ipaq-micro
Support for new devices:
- add support for max77836 into max14577
- add support for tps658640 into tps6586x
- add support for cros-ec-i2c-tunnel into cros_ec
- add new driver for rtsx_usb_sdmmc and rtsx_usb_ms
- add new driver for axp20x
- add new driver for sun6i-prcm
- add new driver for ipaq-micro"
* tag 'mfd-for-linus-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (77 commits)
mfd: wm5102: Correct default for LDO Control 2 register
mfd: menelaus: Use module_i2c_driver
mfd: tps65218: Terminate of match table
mfd: db8500-prcmu: Remove check for CONFIG_DBX500_PRCMU_DEBUG
mfd: ti-keystone-devctrl: Add bindings for device state control
mfd: palmas: Format the header file
mfd: abx500-core: Remove unused function abx500_dump_all_banks()
mfd: arizona: Correct addresses of always-on trigger registers
mfd: max14577: Cast to architecture agnostic data type
i2c: ChromeOS EC tunnel driver
mfd: cros_ec: Sync to the latest cros_ec_commands.h from EC sources
mfd: cros_ec: spi: Increase cros_ec_spi deadline from 5ms to 100ms
mfd: cros_ec: spi: Make the cros_ec_spi timeout more reliable
mfd: cros_ec: spi: Add mutex to cros_ec_spi
mfd: cros_ec: spi: Calculate delay between transfers correctly
mfd: arizona: Correct error message for addition of main IRQ chip
mfd: wm8997: Add registers for high power mode
mfd: arizona: Add MICVDD to mapped regulators
mfd: ipaq-micro: Make mfd_cell array const
mfd: ipaq-micro: Use devm_ioremap_resource()
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media into next
Pull updates and DT support for media engines from Mauro Carvalho Chehab.
For Analog Devices ADV7604 and the Renesas VSP1 video processing engines.
* 'topic/vsp1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] v4l: vsp1: Add DT support
[media] v4l: vsp1: Add DT bindings documentation
[media] v4l: vsp1: Add BRU support
[media] v4l: vsp1: Support multi-input entities
[media] v4l: vsp1: uds: Enable scaling of alpha layer
[media] v4l: vsp1: Remove unexisting rt clocks
* 'topic/adv76xx' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (21 commits)
[media] adv7604: Add LLC polarity configuration
[media] adv7604: Set HPD GPIO direction to output
[media] adv7604: Add endpoint properties to DT bindings
[media] adv7604: Add DT support
[media] adv7604: Specify the default input through platform data
[media] adv7604: Support hot-plug detect control through a GPIO
[media] adv7604: Sort headers alphabetically
[media] adv7604: Replace *_and_or() functions with *_clr_set()
[media] adv7604: Store I2C addresses and clients in arrays
[media] adv7604: Inline the to_sd function
[media] v4l: subdev: Remove deprecated video-level DV timings operations
[media] adv7604: Remove deprecated video-level DV timings operations
[media] adv7604: Add pad-level DV timings support
[media] adv7604: Make output format configurable through pad format operations
[media] adv7604: Add sink pads
[media] adv7604: Remove subdev control handlers
[media] adv7604: Add adv7611 support
[media] adv7604: Cache register contents when reading multiple bits
[media] adv7604: Add 16-bit read functions for CP and HDMI
[media] adv7604: Don't put info string arrays on the stack
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu into next
Pull IOMMU updates from Joerg Roedel:
"The changes include:
- a new IOMMU driver for ARM Renesas SOCs
- updates and fixes for the ARM Exynos driver to bring it closer to a
usable state again
- convert the AMD IOMMUv2 driver to use the mmu_notifier->release
call-back instead of the task_exit notifier
- random other fixes and minor improvements to a number of other
IOMMU drivers"
* tag 'iommu-updates-v3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (54 commits)
iommu/msm: Use devm_ioremap_resource to simplify code
iommu/amd: Fix recently introduced compile warnings
arm/ipmmu-vmsa: Fix compile error
iommu/exynos: Fix checkpatch warning
iommu/exynos: Fix trivial typo
iommu/exynos: Remove invalid symbol dependency
iommu: fsl_pamu.c: Fix for possible null pointer dereference
iommu/amd: Remove duplicate checking code
iommu/amd: Handle parallel invalidate_range_start/end calls correctly
iommu/amd: Remove IOMMUv2 pasid_state_list
iommu/amd: Implement mmu_notifier_release call-back
iommu/amd: Convert IOMMUv2 state_table into state_list
iommu/amd: Don't access IOMMUv2 state_table directly
iommu/ipmmu-vmsa: Support clearing mappings
iommu/ipmmu-vmsa: Remove stage 2 PTE bits definitions
iommu/ipmmu-vmsa: Support 2MB mappings
iommu/ipmmu-vmsa: Rewrite page table management
iommu/ipmmu-vmsa: PMD is never folded, PUD always is
iommu/ipmmu-vmsa: Set the PTE contiguous hint bit when possible
iommu/ipmmu-vmsa: Define driver-specific page directory sizes
frequencies
MPU DPLL on OMAP5, DRA75x, DRA72x has a limitation on the maximum
frequency it can be locked at. Duty Cycle Correction circuit is used
to recover a correct duty cycle for achieving higher frequencies
(hardware internally switches output to M3 output(CLKOUTHIF) from M2
output (CLKOUT)).
So provide support to setup required data to handle Duty cycle by
the setting up the minimum frequency for DPLL. 1.4GHz is common
for all these devices and is based on Technical Reference Manual
information for OMAP5432((SWPU282U) chapter 3.6.3.3.1 "DPLLs Output
Clocks Parameters", and equivalent information from DRA75x, DRA72x
documentation(SPRUHP2E, SPRUHI2P).
Signed-off-by: Nishanth Menon <nm@ti.com>
[t-kristo@ti.com: updated for latest dpll init API call]
Signed-off-by: Tero Kristo <t-kristo@ti.com>
prepare for new patches
arch/x86/kernel/traps.c
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
This patch provides the documentation of the device bindings
for the AMD 10GbE platform driver.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Douglas Anderson, recently pointed out an interesting problem due to which
udelay() was expiring earlier than it should.
While transitioning between frequencies few platforms may temporarily switch to
a stable frequency, waiting for the main PLL to stabilize.
For example: When we transition between very low frequencies on exynos, like
between 200MHz and 300MHz, we may temporarily switch to a PLL running at 800MHz.
No CPUFREQ notification is sent for that. That means there's a period of time
when we're running at 800MHz but loops_per_jiffy is calibrated at between 200MHz
and 300MHz. And so udelay behaves badly.
To get this fixed in a generic way, introduce another set of callbacks
get_intermediate() and target_intermediate(), only for drivers with
target_index() and CPUFREQ_ASYNC_NOTIFICATION unset.
get_intermediate() should return a stable intermediate frequency platform wants
to switch to, and target_intermediate() should set CPU to that frequency,
before jumping to the frequency corresponding to 'index'. Core will take care of
sending notifications and driver doesn't have to handle them in
target_intermediate() or target_index().
NOTE: ->target_index() should restore to policy->restore_freq in case of
failures as core would send notifications for that.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Doug Anderson <dianders@chromium.org>
With the recent addition of the drm_set_unique() function, devices can
now be registered without requiring a drm_bus. Add a brief description
to the DRM docbook to show how that can be achieved.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Describe how devices are registered using the drm_*_init() functions.
Adding this to docbook requires a largish set of changes to the comments
in drm_{pci,usb,platform}.c since they are doxygen-style rather than
proper kernel-doc and therefore mess with the docbook generation.
While at it, mark usage of drm_put_dev() as discouraged in favour of
calling drm_dev_unregister() and drm_dev_unref() directly.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
The DSI controllers are powered by a (typically 1.2V) regulator. Usually
this is always on, so there was no need to support enabling or disabling
it thus far. But in order not to consume any power when DSI is inactive,
give the driver a chance to enable or disable the supply as needed.
Revert commit 18ebc0f404d5 "drm/tegra: hdmi: Enable VDD earlier for
hotplug/DDC" and instead add a new supply for the +5V pin on the HDMI
connector.
The vdd-supply property refers to the regulator that supplies the
AVDD_HDMI input on Tegra, rather than the +5V HDMI connector pin. This
was never a problem before, because all boards had that pin hooked up to
a regulator that was always on. Starting with Dalmore and continuing
with Venice2, the +5V pin is controllable via a GPIO. For reasons
unknown, the GPIO ended up as the controlling GPIO of the AVDD_HDMI
supply in the Dalmore and Venice2 DTS files. But that's not correct.
Instead, a separate supply must be introduced so that the +5V pin can be
controlled separately from the supplies that feed the HDMI block within
Tegra.
A new hdmi-supply property is introduced that takes the place of the
vdd-supply and vdd-supply is only enabled when HDMI is enabled rather
than all the time.
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull ARM64 EFI update from Peter Anvin:
"By agreement with the ARM64 EFI maintainers, we have agreed to make
-tip the upstream for all EFI patches. That is why this patchset
comes from me :)
This patchset enables EFI stub support for ARM64, like we already have
on x86"
* 'arm64-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
arm64: efi: only attempt efi map setup if booting via EFI
efi/arm64: ignore dtb= when UEFI SecureBoot is enabled
doc: arm64: add description of EFI stub support
arm64: efi: add EFI stub
doc: arm: add UEFI support documentation
arm64: add EFI runtime services
efi: Add shared FDT related functions for ARM/ARM64
arm64: Add function to create identity mappings
efi: add helper function to get UEFI params from FDT
doc: efi-stub.txt updates for ARM
lib: add fdt_empty_tree.c
This panel is sold by Toradex for Colibri T20/T30 and Apalis T30
evaluation kits.
Signed-off-by: Stefan Agner <stefan@agner.ch>
The EDT ETM0700G0DH6 and ET070080DH6 are 7" 800x480 panels,
which can be supported by the simple panel driver.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Pull x86-64 espfix changes from Peter Anvin:
"This is the espfix64 code, which fixes the IRET information leak as
well as the associated functionality problem. With this code applied,
16-bit stack segments finally work as intended even on a 64-bit
kernel.
Consequently, this patchset also removes the runtime option that we
added as an interim measure.
To help the people working on Linux kernels for very small systems,
this patchset also makes these compile-time configurable features"
* 'x86/espfix' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "x86-64, modify_ldt: Make support for 16-bit segments a runtime option"
x86, espfix: Make it possible to disable 16-bit support
x86, espfix: Make espfix64 a Kconfig option, fix UML
x86, espfix: Fix broken header guard
x86, espfix: Move espfix definitions into a separate header file
x86-32, espfix: Remove filter for espfix32 due to race
x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stack
Our mutexes have gone a long ways since the original
implementation back in 2005/2006. However, the mutex-design.txt
document is still stuck in the past, to the point where most of
the information there is practically useless and, more
important, simply incorrect. This patch pretty much rewrites it
to resemble what we have nowadays.
Since regular semaphores are almost much extinct in the kernel
(most users now rely on mutexes or rwsems), it no longer makes
sense to have such a close comparison, which was copied from
most of the cover letter when Ingo introduced the generic mutex
subsystem.
Note that ww_mutexes are intentionally left out, leaving things
as generic as possible.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: tim.c.chen@linux.intel.com
Cc: paulmck@linux.vnet.ibm.com
Cc: waiman.long@hp.com
Cc: jason.low2@hp.com
Cc: aswin@hp.com
Link: http://lkml.kernel.org/r/1401338203.2618.11.camel@buesod1.americas.hpqcorp.net
Merge drm-fixes into drm-next.
Both i915 and radeon need this done for later patches.
drivers/gpu/drm/drm_crtc_helper.c
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem.c
drivers/gpu/drm/i915/i915_gem_execbuffer.c
drivers/gpu/drm/i915/i915_gem_gtt.c
The kprobes enhancements are fully cooked, ship them upstream.
This patch adds some documentation on the different cpu families
supported by arch/powerpc.
Merge misc updates from Andrew Morton:
- a few fixes for 3.16. Cc'ed to stable so they'll get there somehow.
- various misc fixes and cleanups
- most of the ocfs2 queue. Review is slow...
- most of MM. The MM queue is pretty huge this time, but not much in
the way of feature work.
- some tweaks under kernel/
- printk maintenance work
- updates to lib/
- checkpatch updates
- tweaks to init/
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (276 commits)
fs/autofs4/dev-ioctl.c: add __init to autofs_dev_ioctl_init
fs/ncpfs/getopt.c: replace simple_strtoul by kstrtoul
init/main.c: remove an ifdef
kthreads: kill CLONE_KERNEL, change kernel_thread(kernel_init) to avoid CLONE_SIGHAND
init/main.c: add initcall_blacklist kernel parameter
init/main.c: don't use pr_debug()
fs/binfmt_flat.c: make old_reloc() static
fs/binfmt_elf.c: fix bool assignements
fs/efs: convert printk(KERN_DEBUG to pr_debug
fs/efs: add pr_fmt / use __func__
fs/efs: convert printk to pr_foo()
scripts/checkpatch.pl: device_initcall is not the only __initcall substitute
checkpatch: check stable email address
checkpatch: warn on unnecessary void function return statements
checkpatch: prefer kstrto<foo> to sscanf(buf, "%<lhuidx>", &bar);
checkpatch: add warning for kmalloc/kzalloc with multiply
checkpatch: warn on #defines ending in semicolon
checkpatch: make --strict a default for files in drivers/net and net/
checkpatch: always warn on missing blank line after variable declaration block
checkpatch: fix wildcard DT compatible string checking
For atomic, it will be quite necessary to not need to care so much
about locking order. And 'state' gives us a convenient place to stash a
ww_ctx for any sort of update that needs to grab multiple crtc locks.
Because we will want to eventually make locking even more fine grained
(giving locks to planes, connectors, etc), split out drm_modeset_lock
and drm_modeset_acquire_ctx to track acquired locks.
Atomic will use this to keep track of which locks have been acquired
in a transaction.
v1: original
v2: remove a few things not needed until atomic, for now
v3: update for v3 of connection_mutex patch..
v4: squash in docbook
v5: doc tweaks/fixes
Signed-off-by: Rob Clark <robdclark@gmail.com>
When a module is built into the kernel the module_init() function
becomes an initcall. Sometimes debugging through dynamic debug can
help, however, debugging built in kernel modules is typically done by
changing the .config, recompiling, and booting the new kernel in an
effort to determine exactly which module caused a problem.
This patchset can be useful stand-alone or combined with initcall_debug.
There are cases where some initcalls can hang the machine before the
console can be flushed, which can make initcall_debug output inaccurate.
Having the ability to skip initcalls can help further debugging of these
scenarios.
Usage: initcall_blacklist=<list of comma separated initcalls>
ex) added "initcall_blacklist=sgi_uv_sysfs_init" as a kernel parameter and
the log contains:
blacklisting initcall sgi_uv_sysfs_init
initcall sgi_uv_sysfs_init blacklisted
ex) added "initcall_blacklist=foo_bar,sgi_uv_sysfs_init" as a kernel parameter
and the log contains:
blacklisting initcall foo_bar
[akpm@linux-foundation.org: tweak printk text]
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Weinberger <richard.weinberger@gmail.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Rob Landley <rob@landley.net>
The pr_debug() and related debug print macros all differ from the normal
pr_XXX() macros, in that the normal ones print unconditionally, while
the debug macros are compiled out unless DEBUG is defined or
CONFIG_DYNAMIC_DEBUG is set. This isn't obvious, and the only way to
find this out is either to review the actual printk.h code or to read
CodingStyle, and the message there doesn't highlight the fact.
Change Documentation/CodingStyle to clearly indicate that pr_debug() and
related debug printing macros behave differently than all other pr_XXX()
macros, and attempt to clarify when and where the different debug
printing methods might be used.
Add short comment to printk.h above the pr_XXX() macros indicating that
while these macros print unconditionally, pr_debug() does not.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Cc: Joe Perches <joe@perches.com>
Cc: Fabian Frederick <fabf@skynet.be>
