path: root/Documentation
2017-03-12samples: move mic/mpssd example code from DocumentationShuah Khan
commit 6bee835dd54e279f3d3ae2eca92a9c394b4fd028 upstream. Move mic/mpssd examples to samples and remove it from Documentation Makefile. Create a new Makefile to build mic/mpssd. It can be built from top level directory or from mic/mpssd directory: Run make -C samples/mic/mpssd or cd samples/mic/mpssd; make Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> [backported to 4.4-stable as this code is broken on newer versions of gcc and we don't want to break the build for a Documentation sample. - gregkh] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-26x86/platform/goldfish: Prevent unconditional loadingThomas Gleixner
commit 47512cfd0d7a8bd6ab71d01cd89fca19eb2093eb upstream. The goldfish platform code registers the platform device unconditionally which causes havoc in several ways if the goldfish_pdev_bus driver is enabled: - Access to the hardcoded physical memory region, which is either not available or contains stuff which is completely unrelated. - Prevents that the interrupt of the serial port can be requested - In case of a spurious interrupt it goes into a infinite loop in the interrupt handler of the pdev_bus driver (which needs to be fixed seperately). Add a 'goldfish' command line option to make the registration opt-in when the platform is compiled in. I'm seriously grumpy about this engineering trainwreck, which has seven SOBs from Intel developers for 50 lines of code. And none of them figured out that this is broken. Impressive fail! Fixes: ddd70cf93d78 ("goldfish: platform device for x86") Reported-by: Gabriel C <nix.or.die@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26ARM: dts: imx31: fix clock control module interrupts descriptionVladimir Zapolskiy
commit 2e575cbc930901718cc18e084566ecbb9a4b5ebb upstream. The type of AVIC interrupt controller found on i.MX31 is one-cell, namely 31 for CCM DVFS and 53 for CCM, however for clock control module its interrupts are specified as 3-cells, fix it. Fixes: ef0e4a606fb6 ("ARM: mx31: Replace clk_register_clkdev with clock DT lookup") Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09KVM: PPC: Book3S HV: Save/restore XER in checkpointed register statePaul Mackerras
commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 upstream. When switching from/to a guest that has a transaction in progress, we need to save/restore the checkpointed register state. Although XER is part of the CPU state that gets checkpointed, the code that does this saving and restoring doesn't save/restore XER. This fixes it by saving and restoring the XER. To allow userspace to read/write the checkpointed XER value, we also add a new ONE_REG specifier. The visible effect of this bug is that the guest may see its XER value being corrupted when it uses transactions. Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support") Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit") Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Reviewed-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31Revert "x86/mm: Expand the exception table logic to allow new handling options"Greg Kroah-Hartman
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream. Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31x86/mm: Expand the exception table logic to allow new handling optionsTony Luck
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream. Huge amounts of help from Andy Lutomirski and Borislav Petkov to produce this. Andy provided the inspiration to add classes to the exception table with a clever bit-squeezing trick, Boris pointed out how much cleaner it would all be if we just had a new field. Linus Torvalds blessed the expansion with: ' I'd rather not be clever in order to save just a tiny amount of space in the exception table, which isn't really criticial for anybody. ' The third field is another relative function pointer, this one to a handler that executes the actions. We start out with three handlers: 1: Legacy - just jumps the to fixup IP 2: Fault - provide the trap number in %ax to the fixup code 3: Cleaned up legacy for the uaccess error hack Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28Input: i8042 - skip selftest on ASUS laptopsMarcos Paulo de Souza
commit 930e19248e9b61da36c967687ca79c4d5f977919 upstream. On suspend/resume cycle, selftest is executed to reset i8042 controller. But when this is done in Asus devices, subsequent calls to detect/init functions to elantech driver fails. Skipping selftest fixes this problem. An easier step to reproduce this problem is adding i8042.reset=1 as a kernel parameter. On Asus laptops, it'll make the system to start with the touchpad already stuck, since psmouse_probe forcibly calls the selftest function. This patch was inspired by John Hiesey's change[1], but, since this problem affects a lot of models of Asus, let's avoid running selftests on them. All models affected by this problem: A455LD K401LB K501LB K501LX R409L V502LX X302LA X450LCP X450LD X455LAB X455LDB X455LF Z450LA [1]: https://marc.info/?l=linux-input&m=144312209020616&w=2 Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend" (https://bugzilla.kernel.org/show_bug.cgi?id=107971) Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07regulator: qcom_spmi: Update mvs1/mvs2 switches on pm8941Stephen Boyd
commit 93bfe79b03365f410aa91caf04263173c008ecdf upstream. The mvs1 and mvs2 switches are actually called 5vs1 and 5vs2 on some datasheets. Let's rename them to match the datasheets and also match the RPM based regulator driver which calls these by their 5vs names (see qcom_smd-regulator.c). There aren't any users of these regulators so far, so there aren't any concerns of DT ABI breakage here. While we're here making updates to the switches, also mandate usage of the OCP irq for these switches too. Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07regulator: qcom_spmi: Add support for S4 supply on pm8941Stephen Boyd
commit c333dfe8dba7d3e47e97e1cee3c38123e19ae73c upstream. The S4 supply is sometimes called the boost regulator because it outputs 5V. Typically it's connected to the 5vs1 and 5vs2 switches for use in USB OTG and HDMI applications. Add support for this regulator which was mistakenly left out from the initial submission of this driver. Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07pinctrl: Flag strict is a field in struct pinmux_opsAndy Shevchenko
commit 7440926ed9623dceca3310c5f437d06c859dc02b upstream. Documentation incorrectly refers to struct pinctrl_desc, where no such flag is available. Replace the name of the struct. Fixes: commit 8c4c2016345f ("pinctrl: move strict option to pinmux_ops") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24mpssd: fix buffer overflow warningMike Danese
commit 3610a2add39365a0f153154c60169a66c616d50f upstream. The compilation emits a warning in function ‘snprintf’, inlined from ‘set_cmdline’ at ../Documentation/mic/mpssd/mpssd.c:1541:9: /usr/include/x86_64-linux-gnu/bits/stdio2.h:64:10: warning: call to __builtin___snprintf_chk will always overflow destination buffer This was introduced in commit f4a66c204482 ("misc: mic: Update MIC host daemon with COSM changes") and is fixed by reverting the changes to the size argument of these snprintf statements. Cc: Ashutosh Dixit <ashutosh.dixit@intel.com> Signed-off-by: Mike Danese <mikedanese@google.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24iio: adc: rockchip_saradc: reset saradc controller before programming itCaesar Wang
commit 543852af8e5902aee8f7c72c89e1513663e0f696 upstream. SARADC controller needs to be reset before programming it, otherwise it will not function properly. Signed-off-by: Caesar Wang <wxt@rock-chips.com> Cc: Jonathan Cameron <jic23@kernel.org> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: linux-iio@vger.kernel.org Cc: linux-rockchip@lists.infradead.org Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15proc: revert /proc/<pid>/maps [stack:TID] annotationJohannes Weiner
[ Upstream commit 65376df582174ffcec9e6471bf5b0dd79ba05e4a ] Commit b76437579d13 ("procfs: mark thread stack correctly in proc/<pid>/maps") added [stack:TID] annotation to /proc/<pid>/maps. Finding the task of a stack VMA requires walking the entire thread list, turning this into quadratic behavior: a thousand threads means a thousand stacks, so the rendering of /proc/<pid>/maps needs to look at a million combinations. The cost is not in proportion to the usefulness as described in the patch. Drop the [stack:TID] annotation to make /proc/<pid>/maps (and /proc/<pid>/numa_maps) usable again for higher thread counts. The [stack] annotation inside /proc/<pid>/task/<tid>/maps is retained, as identifying the stack VMA there is an O(1) operation. Siddesh said: "The end users needed a way to identify thread stacks programmatically and there wasn't a way to do that. I'm afraid I no longer remember (or have access to the resources that would aid my memory since I changed employers) the details of their requirement. However, I did do this on my own time because I thought it was an interesting project for me and nobody really gave any feedback then as to its utility, so as far as I am concerned you could roll back the main thread maps information since the information is available in the thread-specific files" Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com> Cc: Shaohua Li <shli@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20Documentation/module-signing.txt: Note need for version info if reusing a keyBen Hutchings
commit b8612e517c3c9809e1200b72c474dbfd969e5a83 upstream. Signing a module should only make it trusted by the specific kernel it was built for, not anything else. If a module signing key is used for multiple ABI-incompatible kernels, the modules need to include enough version information to distinguish them. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16x86/pat: Document the PAT initialization sequenceToshi Kani
commit b6350c21cfe8aa9d65e189509a23c0ea4b8362c2 upstream. Update PAT documentation to describe how PAT is initialized under various configurations. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Toshi Kani <toshi.kani@hp.com> Cc: elliott@hpe.com Cc: konrad.wilk@oracle.com Cc: paul.gortmaker@windriver.com Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1458769323-24491-8-git-send-email-toshi.kani@hpe.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27scsi: fix race between simultaneous decrements of ->host_failedWei Fang
commit 72d8c36ec364c82bf1bf0c64dfa1041cfaf139f7 upstream. sas_ata_strategy_handler() adds the works of the ata error handler to system_unbound_wq. This workqueue asynchronously runs work items, so the ata error handler will be performed concurrently on different CPUs. In this case, ->host_failed will be decreased simultaneously in scsi_eh_finish_cmd() on different CPUs, and become abnormal. It will lead to permanently inequality between ->host_failed and ->host_busy, and scsi error handler thread won't start running. IO errors after that won't be handled. Since all scmds must have been handled in the strategy handler, just remove the decrement in scsi_eh_finish_cmd() and zero ->host_busy after the strategy handler to fix this race. Fixes: 50824d6c5657 ("[SCSI] libsas: async ata-eh") Signed-off-by: Wei Fang <fangwei1@huawei.com> Reviewed-by: James Bottomley <jejb@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27iio: proximity: as3935: correct IIO_CHAN_INFO_RAW outputMatt Ranostay
commit 5138806f16c74c7cb8ac3e408a859c79eb7c9567 upstream. IIO_CHAN_INFO_RAW was returning processed data which was incorrect. This also adds the IIO_CHAN_INFO_SCALE value to convert to a processed value. Signed-off-by: Matt Ranostay <mranostay@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-07pipe: limit the per-user amount of pages allocated in pipesWilly Tarreau
commit 759c01142a5d0f364a462346168a56de28a80f52 upstream. On no-so-small systems, it is possible for a single process to cause an OOM condition by filling large pipes with data that are never read. A typical process filling 4000 pipes with 1 MB of data will use 4 GB of memory. On small systems it may be tricky to set the pipe max size to prevent this from happening. This patch makes it possible to enforce a per-user soft limit above which new pipes will be limited to a single page, effectively limiting them to 4 kB each, as well as a hard limit above which no new pipes may be created for this user. This has the effect of protecting the system against memory abuse without hurting other users, and still allowing pipes to work correctly though with less data at once. The limit are controlled by two new sysctls : pipe-user-pages-soft, and pipe-user-pages-hard. Both may be disabled by setting them to zero. The default soft limit allows the default number of FDs per process (1024) to create pipes of the default size (64kB), thus reaching a limit of 64MB before starting to create only smaller pipes. With 256 processes limited to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB = 1084 MB of memory allocated for a user. The hard limit is disabled by default to avoid breaking existing applications that make intensive use of pipes (eg: for splicing). Reported-by: socketpair@gmail.com Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Mitigates: CVE-2013-4312 (Linux 2.0+) Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Moritz Muehlenhoff <moritz@wikimedia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-07ARM: dts: imx35: restore existing used clock enumerationAlexander Kurz
commit 3397c2c45b1b6f54834dfeae30a73046f33ca943 upstream. A new element got inserted into enum mx35_clks with commit 3713e3f5e927 ("clk: imx35: define two clocks for rtc"). This insertion shifted most nummerical clock assignments to a new nummerical value which in turn rendered most hardcoded nummeric values in imx35.dtsi incorrect. Restore the existing order by moving the newly introduced clock to the end of the enum. Update the dts documentation accordingly. Signed-off-by: Alexander Kurz <akurz@blala.de> Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc") Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01Fix OpenSSH pty regression on closeBrian Bloniarz
commit 0f40fbbcc34e093255a2b2d70b6b0fb48c3f39aa upstream. OpenSSH expects the (non-blocking) read() of pty master to return EAGAIN only if it has received all of the slave-side output after it has received SIGCHLD. This used to work on pre-3.12 kernels. This fix effectively forces non-blocking read() and poll() to block for parallel i/o to complete for all ttys. It also unwinds these changes: 1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12 tty: Fix pty master read() after slave closes 2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73 pty, n_tty: Simplify input processing on final close 3) 1a48632ffed61352a7810ce089dc5a8bcd505a60 pty: Fix input race when closing Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net> Reported-by: Volth <openssh@volth.com> Reported-by: Marc Aurele La France <tsi@tuyoix.net> BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52 BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492 Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ata: ahci-platform: Add ports-implemented DT bindings.Srinivas Kandagatla
commit 17dcc37e3e847bc0e67a5b1ec52471fcc6c18682 upstream. On some SOCs PORTS_IMPL register value is never programmed by the firmware and left at zero value. Which means that no sata ports are available for software. AHCI driver used to cope up with this by fabricating the port_map if the PORTS_IMPL register is read zero, but recent patch broke this workaround as zero value was valid for NVMe disks. This patch adds ports-implemented DT bindings as workaround for this issue in a way that DT can can override the PORTS_IMPL register in cases where the firmware did not program it already. Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3") Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20pinctrl: pistachio: fix mfio84-89 function description and pinmux.Govindraj Raja
commit e9adb336d0bf391be23e820975ca5cd12c31d781 upstream. mfio 84 to 89 are described wrongly, fix it to describe the right pin and add them to right pin-mux group. The correct order is: pll1_lock => mips_pll -- MFIO_83 pll2_lock => audio_pll -- MFIO_84 pll3_lock => rpu_v_pll -- MFIO_85 pll4_lock => rpu_l_pll -- MFIO_86 pll5_lock => sys_pll -- MFIO_87 pll6_lock => wifi_pll -- MFIO_88 pll7_lock => bt_pll -- MFIO_89 Cc: linux-gpio@vger.kernel.org Cc: devicetree@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: James Hartley <James.Hartley@imgtec.com> Fixes: cefc03e5995e("pinctrl: Add Pistachio SoC pin control driver") Signed-off-by: Govindraj Raja <Govindraj.Raja@imgtec.com> Acked-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20USB: uas: Add a new NO_REPORT_LUNS quirkHans de Goede
commit 1363074667a6b7d0507527742ccd7bbed5e3ceaa upstream. Add a new NO_REPORT_LUNS quirk and set it for Seagate drives with an usb-id of: 0bc2:331a, as these will fail to respond to a REPORT_LUNS command. Reported-and-tested-by: David Webb <djw@noc.ac.uk> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-16KVM: MMU: fix ept=0/pte.u=1/pte.w=0/CR0.WP=0/CR4.SMEP=1/EFER.NX=0 comboPaolo Bonzini
commit 844a5fe219cf472060315971e15cbf97674a3324 upstream. Yes, all of these are needed. :) This is admittedly a bit odd, but kvm-unit-tests access.flat tests this if you run it with "-cpu host" and of course ept=0. KVM runs the guest with CR0.WP=1, so it must handle supervisor writes specially when pte.u=1/pte.w=0/CR0.WP=0. Such writes cause a fault when U=1 and W=0 in the SPTE, but they must succeed because CR0.WP=0. When KVM gets the fault, it sets U=0 and W=1 in the shadow PTE and restarts execution. This will still cause a user write to fault, while supervisor writes will succeed. User reads will fault spuriously now, and KVM will then flip U and W again in the SPTE (U=1, W=0). User reads will be enabled and supervisor writes disabled, going back to the originary situation where supervisor writes fault spuriously. When SMEP is in effect, however, U=0 will enable kernel execution of this page. To avoid this, KVM also sets NX=1 in the shadow PTE together with U=0. If the guest has not enabled NX, the result is a continuous stream of page faults due to the NX bit being reserved. The fix is to force EFER.NX=1 even if the CPU is taking care of the EFER switch. (All machines with SMEP have the CPU_LOAD_IA32_EFER vm-entry control, so they do not use user-return notifiers for EFER---if they did, EFER.NX would be forced to the same value as the host). There is another bug in the reserved bit check, which I've split to a separate patch for easier application to stable kernels. Cc: Andy Lutomirski <luto@amacapital.net> Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Fixes: f6577a5fa15d82217ca73c74cd2dcbc0f6c781dd Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-16ARM: OMAP2+: hwmod: Introduce ti,no-idle dt propertyLokesh Vutla
commit 2e18f5a1bc18e8af7031b3b26efde25307014837 upstream. Introduce a dt property, ti,no-idle, that prevents an IP to idle at any point. This is to handle Errata i877, which tells that GMAC clocks cannot be disabled. Acked-by: Roger Quadros <rogerq@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03efi: Make efivarfs entries immutable by defaultPeter Jones
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream. "rm -rf" is bricking some peoples' laptops because of variables being used to store non-reinitializable firmware driver data that's required to POST the hardware. These are 100% bugs, and they need to be fixed, but in the mean time it shouldn't be easy to *accidentally* brick machines. We have to have delete working, and picking which variables do and don't work for deletion is quite intractable, so instead make everything immutable by default (except for a whitelist), and make tools that aren't quite so broad-spectrum unset the immutable flag. Signed-off-by: Peter Jones <pjones@redhat.com> Tested-by: Lee, Chun-Yi <jlee@suse.com> Acked-by: Matthew Garrett <mjg59@coreos.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-31usb: core: lpm: fix usb3_hardware_lpm sysfs nodeLu Baolu
commit bf5ce5bf3cc7136fd7fe5e8999a580bc93a9c8f6 upstream. Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3 hardware LPM") introduced usb3_hardware_lpm sysfs node. This doesn't show the correct status of USB3 U1 and U2 LPM status. This patch fixes this by replacing usb3_hardware_lpm with two nodes, usb3_hardware_lpm_u1 (for U1) and usb3_hardware_lpm_u2 (for U2), and recording the U1/U2 LPM status in right places. This patch should be back-ported to kernels as old as 4.3, that contains Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3 hardware LPM"). Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Prevent XFRM per-cpu counter updates for one namespace from being applied to another namespace. Fix from DanS treetman. 2) Fix RCU de-reference in iwl_mvm_get_key_sta_id(), from Johannes Berg. 3) Remove ethernet header assumption in nft_do_chain_netdev(), from Pablo Neira Ayuso. 4) Fix cpsw PHY ident with multiple slaves and fixed-phy, from Pascal Speck. 5) Fix use after free in sixpack_close and mkiss_close. 6) Fix VXLAN fw assertion on bnx2x, from Yuval Mintz. 7) natsemi doesn't check for DMA mapping errors, from Alexey Khoroshilov. 8) Fix inverted test in ip6addrlbl_get(), from ANdrey Ryabinin. 9) Missing initialization of needed_headroom in geneve tunnel driver, from Paolo Abeni. 10) Fix conntrack template leak in openvswitch, from Joe Stringer. 11) Mission initialization of wq->flags in sock_alloc_inode(), from Nicolai Stange. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits) sctp: sctp should release assoc when sctp_make_abort_user return NULL in sctp_close net, socket, socket_wq: fix missing initialization of flags drivers: net: cpsw: fix error return code openvswitch: Fix template leak in error cases. sctp: label accepted/peeled off sockets sctp: use GFP_USER for user-controlled kmalloc qlcnic: fix a loop exit condition better net: cdc_ncm: avoid changing RX/TX buffers on MTU changes geneve: initialize needed_headroom ipv6: honor ifindex in case we receive ll addresses in router advertisements addrconf: always initialize sysctl table data ipv6/addrlabel: fix ip6addrlbl_get() switchdev: bridge: Pass ageing time as clock_t instead of jiffies sh_eth: fix 16-bit descriptor field access endianness too veth: don’t modify ip_summed; doing so treats packets with bad checksums as good. net: usb: cdc_ncm: Adding Dell DW5813 LTE AT&T Mobile Broadband Card net: usb: cdc_ncm: Adding Dell DW5812 LTE Verizon Mobile Broadband Card natsemi: add checks for dma mapping errors rhashtable: Kill harmless RCU warning in rhashtable_walk_init openvswitch: correct encoding of set tunnel action attributes ...
2015-12-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input fixes from Dmitry Torokhov: "Just a few assorted driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elants_i2c - fix wake-on-touch Input: elan_i2c - set input device's vendor and product IDs Input: sun4i-lradc-keys - fix typo in binding documentation Input: atmel_mxt_ts - add maxtouch to I2C table for module autoload Input: arizona-haptic - fix disabling of haptics device Input: aiptek - fix crash on detecting device without endpoints Input: atmel_mxt_ts - add generic platform data for Chromebooks Input: parkbd - clear unused function pointers Input: walkera0701 - clear unused function pointers Input: turbografx - clear unused function pointers Input: gamecon - clear unused function pointers Input: db9 - clear unused function pointers
2015-12-18drivers: net: cpsw: fix RMII/RGMII mode when used with fixed-link PHYDavid Rivshin
Commit 1f71e8c96fc654724723ce987e0a8b2aeb81746d ("drivers: net: cpsw: Add support for fixed-link PHY") did not parse the "phy-mode" property in the case of a fixed-link PHY, leaving slave_data->phy_if with its default of PHY_INTERFACE_MODE_NA(0). This later gets passed to phy_connect() in cpsw_slave_open(), and eventually to cpsw_phy_sel() where it hits a default case that configures the MAC for MII mode. The user visible symptom is that while kernel log messages seem to indicate that the interface is set up, there is no network communication. Eventually a watchdog error occurs: NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out Fixes: 1f71e8c96fc6 ("drivers: net: cpsw: Add support for fixed-link PHY") Signed-off-by: David Rivshin <drivshin@allworx.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-18Merge tag 'for-linus-20151217' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD fixes from Brian Norris: "I was holding out on this pull request for a bit, since there are a few other small issues being discussed that look like 4.4-rc regressions. Hopefully I can get those stabilized soon, but these are ready at any rate: - A little bit of a last-minute change for the device tree "fixed partition" binding. This is needed because we might want to reuse the 'partitions' subnode for other sorts of partitioning descriptions -- e.g., for describing which on-flash partition format(s) might be used on the system. - Also tone down a warning message, since it is probably going to show up on a lot of systems where it should just be ignored" * tag 'for-linus-20151217' of git://git.infradead.org/linux-mtd: doc: dt: mtd: partitions: add compatible property to "partitions" node mtd: ofpart: don't complain about missing 'partitions' node too loudly
2015-12-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix uninitialized variable warnings in nfnetlink_queue, a lot of people reported this... From Arnd Bergmann. 2) Don't init mutex twice in i40e driver, from Jesse Brandeburg. 3) Fix spurious EBUSY in rhashtable, from Herbert Xu. 4) Missing DMA unmaps in mvpp2 driver, from Marcin Wojtas. 5) Fix race with work structure access in pppoe driver causing corruptions, from Guillaume Nault. 6) Fix OOPS due to sh_eth_rx() not checking whether netdev_alloc_skb() actually succeeded or not, from Sergei Shtylyov. 7) Don't lose flags when settifn IFA_F_OPTIMISTIC in ipv6 code, from Bjørn Mork. 8) VXLAN_HD_RCO defined incorrectly, fix from Jiri Benc. 9) Fix clock source used for cookies in SCTP, from Marcelo Ricardo Leitner. 10) aurora driver needs HAS_DMA dependency, from Geert Uytterhoeven. 11) ndo_fill_metadata_dst op of vxlan has to handle ipv6 tunneling properly as well, from Jiri Benc. 12) Handle request sockets properly in xfrm layer, from Eric Dumazet. 13) Double stats update in ipv6 geneve transmit path, fix from Pravin B Shelar. 14) sk->sk_policy[] needs RCU protection, and as a result xfrm_policy_destroy() needs to free policies using an RCU grace period, from Eric Dumazet. 15) SCTP needs to clone ipv6 tx options in order to avoid use after free, from Eric Dumazet. 16) Missing kbuild export if ila.h, from Stephen Hemminger. 17) Missing mdiobus_alloc() return value checking in mdio-mux.c, from Tobias Klauser. 18) Validate protocol value range in ->create() methods, from Hannes Frederic Sowa. 19) Fix early socket demux races that result in illegal dst reuse, from Eric Dumazet. 20) Validate socket address length in pptp code, from WANG Cong. 21) skb_reorder_vlan_header() uses incorrect offset and can corrupt packets, from Vlad Yasevich. 22) Fix memory leaks in nl80211 registry code, from Ola Olsson. 23) Timeout loop count handing fixes in mISDN, xgbe, qlge, sfc, and qlcnic. From Dan Carpenter. 24) msg.msg_iocb needs to be cleared in recvfrom() otherwise, for example, AF_ALG will interpret it as an async call. From Tadeusz Struk. 25) inetpeer_set_addr_v4 forgets to initialize the 'vif' field, from Eric Dumazet. 26) rhashtable enforces the minimum table size not early enough, breaking how we calculate the per-cpu lock allocations. From Herbert Xu. 27) Fix FCC port lockup in 82xx driver, from Martin Roth. 28) FOU sockets need to be freed using RCU, from Hannes Frederic Sowa. 29) Fix out-of-bounds access in __skb_complete_tx_timestamp() and sock_setsockopt() wrt. timestamp handling. From WANG Cong. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (117 commits) net: check both type and procotol for tcp sockets drivers: net: xgene: fix Tx flow control tcp: restore fastopen with no data in SYN packet af_unix: Revert 'lock_interruptible' in stream receive code fou: clean up socket with kfree_rcu 82xx: FCC: Fixing a bug causing to FCC port lock-up gianfar: Don't enable RX Filer if not supported net: fix warnings in 'make htmldocs' by moving macro definition out of field declaration rhashtable: Fix walker list corruption rhashtable: Enforce minimum size on initial hash table inet: tcp: fix inetpeer_set_addr_v4() ipv6: automatically enable stable privacy mode if stable_secret set net: fix uninitialized variable issue bluetooth: Validate socket address length in sco_sock_bind(). net_sched: make qdisc_tree_decrease_qlen() work for non mq ser_gigaset: remove unnecessary kfree() calls from release method ser_gigaset: fix deallocation of platform device structure ser_gigaset: turn nonsense checks into WARN_ON ser_gigaset: fix up NULL checks qlcnic: fix a timeout loop ...
2015-12-15Merge tag 'dmaengine-fix-4.4-rc6' of ↵Linus Torvalds
git://git.infradead.org/users/vkoul/slave-dma Pull dmaengine fixes from Vinod Koul: "This has fixes spread thru driver, notably among them: - edma fixes for recent edma DT changes which went into 4.4 - odd fixes for at_hdmac - minor fixes on bc dma and mic dma" * tag 'dmaengine-fix-4.4-rc6' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: at_xdmac: fix at_xdmac_prep_dma_memcpy() dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit type dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit type dmaengine: mic_x100: add missing spin_unlock dmaengine: bcm2835-dma: Convert to use DMA pool dmaengine: at_xdmac: fix bad behavior in interleaved mode dmaengine: at_xdmac: fix false condition for memset_sg transfers dmaengine: at_xdmac: fix macro typo
2015-12-12Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "Here are a bunch of small bug fixes for various ARM platforms, nothing really sticks out this week, most of either fixes bugs in code that was just added in 4.4, or that has been broken for many years without anyone noticing. at91/sama5d2: - fix sama5de hardware setup of sd/mmc interface - proper selection of pinctrl drivers. PIO4 is necessary for sama5d2 berlin: - fix incorrect clock input for SDIO exynos: - Fix potential NULL pointer dereference in Exynos PMU driver. imx: - Fix vf610 SAI clock configuration bug which is discovered by the newly added master mode support in SAI audio driver. - Fix buggy L2 cache latency values in vf610 device trees, which may cause system hang when cpu runs at a higher frequency. ixp4xx: - fix prototypes for readl/writel functions ls2080a: - use little-endian register access for GPIO and SDHCI omap: - Fix clock source for ARM TWD and global timers on am437x - Always select REGULATOR_FIXED_VOLTAGE for omap2+ instead of when MACH_OMAP3_PANDORA is selected - Fix SPI DMA handles for dm816x as only some were mapped - Fix up mbox cells for dm816x to make mailbox usable pxa: - use PWM lookup table for all ezx machines s3c24xx: - Remove incorrect __init annotation from s3c24xx cpufreq driver structures. versatile: - fix PCI IRQ mapping on Versatile PB" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ls2080a/dts: Add little endian property for GPIO IP block dt-bindings: define little-endian property for QorIQ GPIO ARM64: dts: ls2080a: fix eSDHC endianness ARM: dts: vf610: use reset values for L2 cache latencies ARM: pxa: use PWM lookup table for all machines ARM: dts: berlin: add 2nd clock for BG2Q sdhci0 and sdhci1 ARM: dts: berlin: correct BG2Q's sdhci2 2nd clock ARM: dts: am4372: fix clock source for arm twd and global timers ARM: at91: fix pinctrl driver selection ARM: at91/dt: add always-on to 1.8V regulator ARM: dts: vf610: fix clock definition for SAI2 ARM: imx: clk-vf610: fix SAI clock tree ARM: ixp4xx: fix read{b,w,l} return types irqchip/versatile-fpga: Fix PCI IRQ mapping on Versatile PB ARM: OMAP2+: enable REGULATOR_FIXED_VOLTAGE ARM: dts: add dm816x missing spi DT dma handles ARM: dts: add dm816x missing #mbox-cells cpufreq: s3c24xx: Do not mark s3c2410_plls_add as __init ARM: EXYNOS: Fix potential NULL pointer access in exynos_sys_powerdown_conf
2015-12-12Input: sun4i-lradc-keys - fix typo in binding documentationKarsten Merker
Trivial typo fix ("mut" -> "must") in the sunxi LRADC-keys binding documentation. Signed-off-by: Karsten Merker <merker@debian.org> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-12-11dt-bindings: define little-endian property for QorIQ GPIOLi Yang
The GPIO block on different QorIQ chips could have registers in different endianess. Define the property to specify which endian is used by the hardware. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-12-10Merge branch 'fix/edma' into fixesVinod Koul
2015-12-10dmaengine: edma: DT: Change reserved slot array from 16bit to 32bit typePeter Ujfalusi
This change makes the DT file to be easier to read since the reserved slots array does not need the '/bits/ 16' to be specified, which might confuse some people. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-12-10dmaengine: edma: DT: Change memcpy channel array from 16bit to 32bit typePeter Ujfalusi
This change makes the DT file to be easier to read since the memcpy channels array does not need the '/bits/ 16' to be specified, which might confuse some people. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-12-08doc: dt: mtd: partitions: add compatible property to "partitions" nodeBrian Norris
As noted here [1], there are potentially future conflicts if we try to use MTD's "partitions" subnode to describe anything besides just the fixed-in-the-device-tree partitions currently described in this document. Particularly, there was a proposal to use this node for the AFS parser too. It can pose a (small) problem to try to differentiate the following nodes: // using binding as currently specified partitions { #address-cells = <x>; #size-cells = <y>; partition@0 { ...; }; }; and // proposed future binding partitions { compatible = "arm,arm-flash-structure"; }; It's especially difficult if other uses of this node start having subnodes. So, since the "partitions" node is new in v4.4, let's fixup the binding before release so that it requires a compatible property, so it's much clearer to distinguish. e.g.: // proposed partitions { compatible = "fixed-partitions"; #address-cells = <x>; #size-cells = <y>; partition@0 { ...; }; }; [1] Subject: "mtd: create a partition type device tree binding" http://lkml.kernel.org/g/20151113220039.GA74382@google.com http://lists.infradead.org/pipermail/linux-mtd/2015-November/063355.html http://lists.infradead.org/pipermail/linux-mtd/2015-November/063364.html Cc: Michal Suchanek <hramrach@gmail.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Acked-by: Rob Herring <robh@kernel.org>
2015-12-05Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net-queue Jeff Kirsher says: ==================== Intel Wired LAN Driver Updates 2015-12-03 This series contains updates to ixgbe, i40e/i40evf, MAINTAINERS and e100.txt Alex provides a fix for ixgbe where enabling SR-IOV and then bringing the interface up was resulting in the PF MAC addresses getting into a bad state. The workaround for this issue is to bring up the interface first and then enable SR-IOV as this will trigger the reset in the existing code. I clean up legacy license stuff in the e100.txt documentation and then update the maintainers/reviewers list for our drivers. Jesse fixes an issue with the i40e/i40evf drivers, where if the driver were to happen to have a mutex held while the i40e_init_adminq() call was called, the init_adminq might inadvertently call mutex_init on a lock that was held which is a violation of the calling semantices. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A lot of Thanksgiving turkey leftovers accumulated, here goes: 1) Fix bluetooth l2cap_chan object leak, from Johan Hedberg. 2) IDs for some new iwlwifi chips, from Oren Givon. 3) Fix rtlwifi lockups on boot, from Larry Finger. 4) Fix memory leak in fm10k, from Stephen Hemminger. 5) We have a route leak in the ipv6 tunnel infrastructure, fix from Paolo Abeni. 6) Fix buffer pointer handling in arm64 bpf JIT,f rom Zi Shen Lim. 7) Wrong lockdep annotations in tcp md5 support, fix from Eric Dumazet. 8) Work around some middle boxes which prevent proper handling of TCP Fast Open, from Yuchung Cheng. 9) TCP repair can do huge kmalloc() requests, build paged SKBs instead. From Eric Dumazet. 10) Fix msg_controllen overflow in scm_detach_fds, from Daniel Borkmann. 11) Fix device leaks on ipmr table destruction in ipv4 and ipv6, from Nikolay Aleksandrov. 12) Fix use after free in epoll with AF_UNIX sockets, from Rainer Weikusat. 13) Fix double free in VRF code, from Nikolay Aleksandrov. 14) Fix skb leaks on socket receive queue in tipc, from Ying Xue. 15) Fix ifup/ifdown crach in xgene driver, from Iyappan Subramanian. 16) Fix clearing of persistent array maps in bpf, from Daniel Borkmann. 17) In TCP, for the cross-SYN case, we don't initialize tp->copied_seq early enough. From Eric Dumazet. 18) Fix out of bounds accesses in bpf array implementation when updating elements, from Daniel Borkmann. 19) Fill gaps in RCU protection of np->opt in ipv6 stack, from Eric Dumazet. 20) When dumping proxy neigh entries, we have to accomodate NULL device pointers properly, from Konstantin Khlebnikov. 21) SCTP doesn't release all ipv6 socket resources properly, fix from Eric Dumazet. 22) Prevent underflows of sch->q.qlen for multiqueue packet schedulers, also from Eric Dumazet. 23) Fix MAC and unicast list handling in bnxt_en driver, from Jeffrey Huang and Michael Chan. 24) Don't actively scan radar channels, from Antonio Quartulli" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (110 commits) net: phy: reset only targeted phy bnxt_en: Setup uc_list mac filters after resetting the chip. bnxt_en: enforce proper storing of MAC address bnxt_en: Fixed incorrect implementation of ndo_set_mac_address net: lpc_eth: remove irq > NR_IRQS check from probe() net_sched: fix qdisc_tree_decrease_qlen() races openvswitch: fix hangup on vxlan/gre/geneve device deletion ipv4: igmp: Allow removing groups from a removed interface ipv6: sctp: implement sctp_v6_destroy_sock() arm64: bpf: add 'store immediate' instruction ipv6: kill sk_dst_lock ipv6: sctp: add rcu protection around np->opt net/neighbour: fix crash at dumping device-agnostic proxy entries sctp: use GFP_USER for user-controlled kmalloc sctp: convert sack_needed and sack_generation to bits ipv6: add complete rcu protection around np->opt bpf: fix allocation warnings in bpf maps and integer overflow mvebu: dts: enable IP checksum with jumbo frames for Armada 38x on Port0 net: mvneta: enable setting custom TX IP checksum limit net: mvneta: fix error path for building skb ...
2015-12-03e100.txt: Cleanup license info in kernel docJeff Kirsher
Apparently the e100.txt document contained a "License" section left over from days of old, which does not need to be in the kernel documentation. So clean it up.. CC: John Ronciak <john.ronciak@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com>
2015-12-02net: mvneta: enable setting custom TX IP checksum limitMarcin Wojtas
Since Armada 38x SoC can support IP checksum for jumbo frames only on a single port, it means that this feature should be enabled per-port, rather than for the whole SoC. This patch enables setting custom TX IP checksum limit by adding new optional property to the mvneta device tree node. If not used, by default 1600B is set for "marvell,armada-370-neta" and 9800B for other strings, which ensures backward compatibility. Binding documentation is updated accordingly. Signed-off-by: Marcin Wojtas <mw@semihalf.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-29Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management fixes from Zhang Rui: "Specifics: - several fixes and cleanups on Rockchip thermal drivers. - add the missing support of RK3368 SoCs in Rockchip driver. - small fixes on of-thermal, power_allocator, rcar driver, IMX, and QCOM drivers, and also compilation fixes, on thermal.h, when thermal is not selected" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: imx: thermal: use CPU temperature grade info for thresholds thermal: fix thermal_zone_bind_cooling_device prototype Revert "thermal: qcom_spmi: allow compile test" thermal: rcar_thermal: remove redundant operation thermal: of-thermal: Reduce log level for message when can't fine thermal zone thermal: power_allocator: Use temperature reading from tz thermal: rockchip: Support the RK3368 SoCs in thermal driver thermal: rockchip: consistently use int for temperatures thermal: rockchip: Add the sort mode for adc value increment or decrement thermal: rockchip: improve the conversion function thermal: rockchip: trivial: fix typo in commit thermal: rockchip: better to compatible the driver for different SoCs dt-bindings: rockchip-thermal: Support the RK3368 SoCs compatible
2015-11-27Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "There is a small backlog of at91 patches here, the most significant is the addition of some sama5d2 Xplained nodes that were waiting on an MFD include file to get merged through another tree. We normally try to sort those out before the merge window opens, but the maintainer wasn't aware of that here and I decided to merge the changes this time as an exception. On OMAP a series of audio changes for dra7 missed the merge window but turned out to be necessary to fix a boot time imprecise external abort error and to get audio working. The other changes are the usual simple changes, here is a list sorted by platform: at91: removal of a useless defconfig option removal of some legacy DT pieces use of the proper watchdog compatible string update of the MAINTAINERS entries for some Atmel drivers drivers/scpi: hide get_scpi_ops in module from built-in code imx: add missing .irq_set_type for i.MX GPC irq_chip. fix the wrong spi-num-chipselects settings for Vybrid DSPI devices. fix a merge error in Vybrid dts regarding to ADC device property keystone: fix the optional PDSP firmware loading fix linking RAM setup for QMs fix crash with clk_ignore_unused mediatek: Enable SCPSYS power domain driver by default mvebu: fix QNAP TS219 power-off in dts fix legacy get_irqnr_and_base for dove and orion5x omap: fix l4 related boot time errors for dm81xx use lockless cldm/pwrdm api in omap4_boot_secondary remove t410 abort handler to avoid hiding other critical errors mark cpuidle tracepoints as _rcuidle fix module alias for omap-ocp2scp pxa: palm: Fix typos in PWM lookup table code renesas: missing __initconst annotation for r8a7793_boards_compat_dt rockchip: disable mmc-tuning on the veyron-minnie board adding the init state for the over-temperature-protection zx: only build power domain code when CONFIG_PM=y" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (31 commits) ARM: OMAP4+: SMP: use lockless clkdm/pwrdm api in omap4_boot_secondary arm: omap2+: add missing HWMOD_NO_IDLEST in 81xx hwmod data ARM: orion5x: Fix legacy get_irqnr_and_base ARM: dove: Fix legacy get_irqnr_and_base soc: Mediatek: Enable SCPSYS power domain driver by default ARM: dts: vfxxx: Fix dspi[01] spi-num-chipselects. ARM: dts: keystone: k2l: fix kernel crash when clk_ignore_unused is not in bootargs soc: ti: knav_qmss_queue: Fix linking RAM setup for queue managers soc: ti: use request_firmware_direct() as acc firmware is optional ARM: imx: add platform irq type setting in gpc ARM: dts: vfxxx: Fix erroneous property in esdhc0 node ARM: shmobile: r8a7793: proper constness with __initconst scpi: hide get_scpi_ops in module from built-in code ARM: zx: only build power domain code when CONFIG_PM=y ARM: pxa: palm: Fix typos in PWM lookup table code ARM: dts: Kirkwood: Fix QNAP TS219 power-off ARM: dts: rockchip: Add OTP gpio pinctrl to rk3288 tsadc node ARM: dts: rockchip: temporarily remove emmc hs200 speed from rk3288 minnie MAINTAINERS: Atmel drivers: change NAND and ISI entries ARM: at91/dt: sama5d2 Xplained: add several devices ...
2015-11-24Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A round of fixes/updates for the current series. This looks a little bigger than it is, but that's mainly because we pushed the lightnvm enabled null_blk change out of the merge window so it could be updated a bit. The rest of the volume is also mostly lightnvm. In particular: - Lightnvm. Various fixes, additions, updates from Matias and Javier, as well as from Wenwei Tao. - NVMe: - Fix for potential arithmetic overflow from Keith. - Also from Keith, ensure that we reap pending completions from a completion queue before deleting it. Fixes kernel crashes when resetting a device with IO pending. - Various little lightnvm related tweaks from Matias. - Fixup flushes to go through the IO scheduler, for the cases where a flush is not required. Fixes a case in CFQ where we would be idling and not see this request, hence not break the idling. From Jan Kara. - Use list_{first,prev,next} in elevator.c for cleaner code. From Gelian Tang. - Fix for a warning trigger on btrfs and raid on single queue blk-mq devices, where we would flush plug callbacks with preemption disabled. From me. - A mac partition validation fix from Kees Cook. - Two merge fixes from Ming, marked stable. A third part is adding a new warning so we'll notice this quicker in the future, if we screw up the accounting. - Cleanup of thread name/creation in mtip32xx from Rasmus Villemoes" * 'for-linus' of git://git.kernel.dk/linux-block: (32 commits) blk-merge: warn if figured out segment number is bigger than nr_phys_segments blk-merge: fix blk_bio_segment_split block: fix segment split blk-mq: fix calling unplug callbacks with preempt disabled mac: validate mac_partition is within sector mtip32xx: use formatting capability of kthread_create_on_node NVMe: reap completion entries when deleting queue lightnvm: add free and bad lun info to show luns lightnvm: keep track of block counts nvme: lightnvm: use admin queues for admin cmds lightnvm: missing free on init error lightnvm: wrong return value and redundant free null_blk: do not del gendisk with lightnvm null_blk: use device addressing mode null_blk: use ppa_cache pool NVMe: Fix possible arithmetic overflow for max segments blk-flush: Queue through IO scheduler when flush not required null_blk: register as a LightNVM device elevator: use list_{first,prev,next}_entry lightnvm: cleanup queue before target removal ...
2015-11-23ARM: dts: keystone: k2l: fix kernel crash when clk_ignore_unused is not in ↵Murali Karicheri
bootargs Currently kernel crash randomly when K2L EVM is booted without clk_ignore_unused in the bootargs. This workaround is not needed on other K2 devices such as K2HK and K2E and with this fix, we can remove the workaround altogether. netcp driver on K2L uses linked ram on OSR (On chip Static RAM) and requires the clock to this peripheral enabled for proper functioning. This is the reason for the kernel crash. So add the clock node to fix this issue. While at it, remove the workaround documentation as well. With the fix applied, clk_summary dump shows the clock to OSR enabled. cat /sys/kernel/debug/clk/clk_summary ------cut-------------- tcp3d-1 0 0 399360000 0 0 tcp3d-0 0 0 399360000 0 0 osr 1 1 399360000 0 0 fftc-0 0 0 399360000 0 0 -----cut---------------- Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2015-11-20Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "A few bugfixes and one PCI ID addition from I2C" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: i801: add Intel Lewisburg device IDs i2c: fix wakeup irq parsing i2c: xiic: Prevent concurrent running of the IRQ handler and __xiic_start_xfer() i2c: Revert "i2c: xiic: Do not reset controller before every transfer" i2c: imx: fix a compiling error
2015-11-20Merge tag 'pm+acpi-4.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: "These are mostly fixes and cleanups (ACPI core, PM core, cpufreq, ACPI EC driver, device properties) including three reverts of recent intel_pstate driver commits due to a regression introduced by one of them plus support for Atom Airmont cores in intel_pstate (which really boils down to adding new frequency tables for Airmont) and additional turbostat updates. Specifics: - Revert three recent intel_pstate driver commits one of which introduced a regression and the remaining two depend on the problematic one (Rafael Wysocki). - Fix breakage related to the recently introduced ACPI _CCA object support in the PCI DMA setup code (Suravee Suthikulpanit). - Fix up the recently introduced ACPI CPPC support to only use the hardware-reduced version of the PCCT structure as the only architecture to support it (ARM64) will only use hardware-reduced ACPI anyway (Ashwin Chaugule). - Fix a cpufreq mediatek driver build problem (Arnd Bergmann). - Fix the SMBus transaction handling implementation in the ACPI core to avoid re-entrant calls to wait_event_timeout() which makes intermittent boot stalls related to the Smart Battery Subsystem initialization go away and revert a workaround of another problem with the same underlying root cause (Chris Bainbridge). - Fix the generic wakeup interrupts framework to avoid using invalid IRQ numbers (Dmitry Torokhov). - Remove a redundant check from the ACPI EC driver (Markus Elfring). - Modify the intel_pstate driver so it can support more Atom flavors than just one (Baytrail) and add support for Atom Airmont cores (which require new freqnency tables) to it (Philippe Longepe). - Clean up MSR-related symbols in turbostat (Len Brown)" * tag 'pm+acpi-4.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PCI: Fix OF logic in pci_dma_configure() Revert "Documentation: kernel_parameters for Intel P state driver" cpufreq: mediatek: fix build error cpufreq: intel_pstate: Add separate support for Airmont cores cpufreq: intel_pstate: Replace BYT with ATOM Revert "cpufreq: intel_pstate: Use ACPI perf configuration" Revert "cpufreq: intel_pstate: Avoid calculation for max/min" ACPI-EC: Drop unnecessary check made before calling acpi_ec_delete_query() Revert "ACPI / SBS: Add 5 us delay to fix SBS hangs on MacBook" ACPI / SMBus: Fix boot stalls / high CPU caused by reentrant code PM / wakeirq: check that wake IRQ is valid before accepting it ACPI / CPPC: Use h/w reduced version of the PCCT structure x86: remove unused definition of MSR_NHM_PLATFORM_INFO tools/power turbostat: use new name for MSR_PLATFORM_INFO
