path: root/Kbuild
2006-01-08kbuild: clean up asm-offsets.h creationBrian Gerst
- Move mkdir out of cmd_offsets - Add input file to sed command instead of using cat Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-10kbuild: fix generic asm-offsets.h supportSam Ravnborg
iThis fixes a bug where the generated asm-offsets.h file was saved in the source tree even with make O=. Thanks to Stephen Rothwell <sfr@canb.auug.org.au> for the report. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-09kbuild: mips use generic asm-offsets.h supportSam Ravnborg
Removed obsolete stuff from arch makefile. mips had a special rule for generating asm-offsets.h so preserved it using an architecture specific hook in top-level Kbuild file. Renamed .h file to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-09kbuild: full dependency check on asm-offsets.hSam Ravnborg
Building asm-offsets.h has been moved to a seperate Kbuild file located in the top-level directory. This allow us to share the functionality across the architectures. The old rules in architecture specific Makefiles will die in subsequent patches. Furhtermore the usual kbuild dependency tracking is now used when deciding to rebuild asm-offsets.s. So we no longer risk to fail a rebuild caused by asm-offsets.c dependencies being touched. With this common rule-set we now force the same name across all architectures. Following patches will fix the rest. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
