path: root/MAINTAINERS
2010-06-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) mac80211: fix deauth before assoc iwlwifi: add missing rcu_read_lock mac80211: fix function pointer check wireless: remove my name from the maintainer list ath5k: fix NULL pointer in antenna configuration p54usb: Add device ID for Dell WLA3310 USB wl1251: fix a memory leak in probe ipmr: dont corrupt lists 8139too: fix buffer overrun in rtl8139_init_board asix: check packet size against mtu+ETH_HLEN instead of ETH_FRAME_LEN r8169: fix random mdio_write failures ip6mr: fix a typo in ip6mr_for_each_table() iwlwifi: move sysfs_create_group to post request firmware iwlwifi: add name to Maintainers list iwl3945: fix internal scan iwl3945: enable stuck queue detection on 3945 ipv6: avoid high order allocations ath5k: retain promiscuous setting ath5k: depend on CONFIG_PM_SLEEP for suspend/resume functions mac80211: process station blockack action frames from work ...
2010-06-09Merge branch 'master' of ↵David S. Miller
2010-06-07wireless: remove my name from the maintainer listZhu Yi
Remove my name from the MAINTAINERS file. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-05iwlwifi: add name to Maintainers listWey-Yi Guy
Add "Wey-Yi Guy" to maintainers list for iwlwifi. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-06-04Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (87 commits) V4L/DVB: ivtv: Timing tweaks and code re-order to try and improve stability V4L/DVB: ivtv: Avoid accidental video standard change V4L/DVB: ivtvfb : Module load / unload fixes V4L/DVB: cx2341x: Report correct temporal setting for log-status V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email address V4L/DVB: drivers/media: Eliminate a NULL pointer dereference V4L/DVB: dvb-core: Fix ULE decapsulation bug V4L/DVB: Bug fix: make IR work again for dm1105 V4L/DVB: media/IR: nec-decoder needs to select BITREV V4L/DVB: video/saa7134: change dprintk() to i2cdprintk() V4L/DVB: video/saa7134: remove duplicate break V4L/DVB: IR/imon: add auto-config for 0xffdc rf device V4L/DVB: IR/imon: clean up usage of bools V4L/DVB: em28xx: remove unneeded null checks V4L/DVB: ngene: remove unused #include <linux/version.h> V4L/DVB: ak881x needs slab.h V4L/DVB: FusionHDTV: Use quick reads for I2C IR device probing V4L/DVB: Technotrend S2-3200 ships with a TT 1500 remote V4L/DVB: drivers/media: Use kzalloc V4L/DVB: m920x: Select simple tuner ...
2010-06-02powerpc/pasemi: Update MAINTAINERS fileOlof Johansson
PWRficient platform work is definitely in maintenance mode these days, update MAINTAINERS file to reflect reality. Website is long gone as well. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-06-01V4L/DVB: cx18, cx23885, v4l2 doc, MAINTAINERS: Update Andy Walls' email addressAndy Walls
A trivial change to update my email address from my dead awalls@radix.net address to my current awalls@md.metrocast.net address. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-28Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: native hardware cpuidle driver for latest Intel processors ACPI: acpi_idle: touch TS_POLLING only in the non-MWAIT case acpi_pad: uses MONITOR/MWAIT, so it doesn't need to clear TS_POLLING sched: clarify commment for TS_POLLING ACPI: allow a native cpuidle driver to displace ACPI cpuidle: make cpuidle_curr_driver static cpuidle: add cpuidle_unregister_driver() error check cpuidle: fail to register if !CONFIG_CPU_IDLE
2010-05-28intel_idle: native hardware cpuidle driver for latest Intel processorsLen Brown
This EXPERIMENTAL driver supersedes acpi_idle on Intel Atom Processors, Intel Core i3/i5/i7 Processors and associated Intel Xeon processors. It does not support the Intel Core2 processor or earlier. For kernels configured with ACPI, CONFIG_INTEL_IDLE=y allows intel_idle to probe before the ACPI processor driver. Booting with "intel_idle.max_cstate=0" disables intel_idle and the system will fall back on ACPI's "acpi_idle". Typical Linux distributions load ACPI processor module early, making CONFIG_INTEL_IDLE=m not easily useful on ACPI platforms. intel_idle probes all processors at module_init time. Processors that are hot-added later will be limited to using C1 in idle. Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-27Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] fill out file list in s390 MAINTAINERS entry [S390] Add support for LZO-compressed kernels. [S390] cmm: get rid of CMM_PROC config option [S390] cmm: remove superfluous EXPORT_SYMBOLs plus cleanups [S390] dasd: unit check handling during internal cio I/O [S390] cio: unit check handling during internal I/O [S390] ccwgroup: add locking around drvdata access [S390] cio: remove stsch [S390] spp: remove KVM_AWARE_CMF config option [S390] kprobes: forbid probing of stnsm/stosm/epsw [S390] spp: fix compilation for CONFIG_32BIT [S390] atomic: implement atomic64_dec_if_positive [S390] cmm: fix crash on module unload
2010-05-27sdhci-spear: ST SPEAr based SDHCI controller glueViresh KUMAR
Add a glue layer to support the sdhci driver on the ST SPEAr platform. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: <shiraz.hashim@st.com> Cc: Linus Walleij <linus.ml.walleij@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26[S390] fill out file list in s390 MAINTAINERS entryJonathan Nieder
Noticed with scripts/get_maintainer.pl -f fs/partitions/ibm.c Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-26nuc900: add maintainer entries for Wan ZongShunWan ZongShun
2010-05-21Merge branch 'kdb-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'kdb-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: (25 commits) kdb,debug_core: Allow the debug core to receive a panic notification MAINTAINERS: update kgdb, kdb, and debug_core info debug_core,kdb: Allow the debug core to process a recursive debug entry printk,kdb: capture printk() when in kdb shell kgdboc,kdb: Allow kdb to work on a non open console port kgdb: Add the ability to schedule a breakpoint via a tasklet mips,kgdb: kdb low level trap catch and stack trace powerpc,kgdb: Introduce low level trap catching x86,kgdb: Add low level debug hook kgdb: remove post_primary_code references kgdb,docs: Update the kgdb docs to include kdb kgdboc,keyboard: Keyboard driver for kdb with kgdb kgdb: gdb "monitor" -> kdb passthrough sparc,sunzilog: Add console polling support for sunzilog serial driver sh,sh-sci: Use NO_POLL_CHAR in the SCIF polled console code kgdb,8250,pl011: Return immediately from console poll kgdb: core changes to support kdb kdb: core for kgdb back end (2 of 2) kdb: core for kgdb back end (1 of 2) kgdb,blackfin: Add in kgdb_arch_set_pc for blackfin ...
2010-05-21Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (154 commits) mtd: cfi_cmdset_0002: use AMD standard command-set with Winbond flash chips mtd: cfi_cmdset_0002: Fix MODULE_ALIAS and linkage for new 0701 commandset ID mtd: mxc_nand: Remove duplicate NAND_CMD_RESET case value mtd: update gfp/slab.h includes jffs2: Stop triggering block erases from jffs2_write_super() jffs2: Rename jffs2_erase_pending_trigger() to jffs2_dirty_trigger() jffs2: Use jffs2_garbage_collect_trigger() to trigger pending erases jffs2: Require jffs2_garbage_collect_trigger() to be called with lock held jffs2: Wake GC thread when there are blocks to be erased jffs2: Erase pending blocks in GC pass, avoid invalid -EIO return jffs2: Add 'work_done' return value from jffs2_erase_pending_blocks() mtd: mtdchar: Do not corrupt backing device of device node inode mtd/maps/pcmciamtd: Fix printk format for ssize_t in debug messages drivers/mtd: Use kmemdup mtd: cfi_cmdset_0002: Fix argument order in bootloc warning mtd: nand: add Toshiba TC58NVG0 device ID pcmciamtd: add another ID pcmciamtd: coding style cleanups pcmciamtd: fixing obvious errors mtd: chips: add SST39WF160x NOR-flashes ... Trivial conflicts due to dev_node removal in drivers/mtd/maps/pcmciamtd.c
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (182 commits) [SCSI] aacraid: add an ifdef'd device delete case instead of taking the device offline [SCSI] aacraid: prohibit access to array container space [SCSI] aacraid: add support for handling ATA pass-through commands. [SCSI] aacraid: expose physical devices for models with newer firmware [SCSI] aacraid: respond automatically to volumes added by config tool [SCSI] fcoe: fix fcoe module ref counting [SCSI] libfcoe: FIP Keep-Alive messages for VPorts are sent with incorrect port_id and wwn [SCSI] libfcoe: Fix incorrect MAC address clearing [SCSI] fcoe: fix a circular locking issue with rtnl and sysfs mutex [SCSI] libfc: Move the port_id into lport [SCSI] fcoe: move link speed checking into its own routine [SCSI] libfc: Remove extra pointer check [SCSI] libfc: Remove unused fc_get_host_port_type [SCSI] fcoe: fixes wrong error exit in fcoe_create [SCSI] libfc: set seq_id for incoming sequence [SCSI] qla2xxx: Updates to ISP82xx support. [SCSI] qla2xxx: Optionally disable target reset. [SCSI] qla2xxx: ensure flash operation and host reset via sg_reset are mutually exclusive [SCSI] qla2xxx: Silence bogus warning by gcc for wrap and did. [SCSI] qla2xxx: T10 DIF support added. ...
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits) qlcnic: adding co maintainer ixgbe: add support for active DA cables ixgbe: dcb, do not tag tc_prio_control frames ixgbe: fix ixgbe_tx_is_paused logic ixgbe: always enable vlan strip/insert when DCB is enabled ixgbe: remove some redundant code in setting FCoE FIP filter ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp ixgbe: fix header len when unsplit packet overflows to data buffer ipv6: Never schedule DAD timer on dead address ipv6: Use POSTDAD state ipv6: Use state_lock to protect ifa state ipv6: Replace inet6_ifaddr->dead with state cxgb4: notify upper drivers if the device is already up when they load cxgb4: keep interrupts available when the ports are brought down cxgb4: fix initial addition of MAC address cnic: Return SPQ credit to bnx2x after ring setup and shutdown. cnic: Convert cnic_local_flags to atomic ops. can: Fix SJA1000 command register writes on SMP systems bridge: fix build for CONFIG_SYSFS disabled ARCNET: Limit com20020 PCI ID matches for SOHARD cards ... Fix up various conflicts with pcmcia tree drivers/net/ {pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and wireless/orinoco/spectrum_cs.c} and feature removal (Documentation/feature-removal-schedule.txt). Also fix a non-content conflict due to pm_qos_requirement getting renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
2010-05-20MAINTAINERS: update kgdb, kdb, and debug_core infoJason Wessel
Update the maintained files sections. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20MAINTAINERS: update kgdb, and debug_core infoJason Wessel
Update the kgdb section. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-05-20Merge branch 'for-linus/i2c-2635' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c-2635' of git://git.fluff.org/bjdooks/linux: (21 commits) i2c-highlander: remover superflous variable i2c-ibm-iic: drop NO_IRQ i2c-cpm: drop NO_IRQ i2c-mpc: drop NO_IRQ MAINTAINERS: add i2c tree for embedded platforms i2c-pxa: only define 'blue_murder'-function if DEBUG is #defined i2c-pxa: remove unused macro i2c-nomadik: fix operator precedence warning i2c-nomadik: release region when removed OMAP3: I2C: Clean up Errata 1p153 handling OMAP2/3: I2C: Errata ID i207: Clear wrong RDR interrupt omap: i2c: add a timeout to the busy waiting omap: i2c: make errata 1.153 workaround a separate function i2c-omap: add mpu wake up latency constraint in i2c omap: i2c: Add i2c support on omap4 platform i2c-bfin-twi: return completion in interrupt for smbus quick transfers i2c-bfin-twi: remove redundant retry i2c-bfin-twi: fix lost interrupts at high speeds i2c-bfin-twi: add debug output for error status i2c-bfin-twi: integrate timeout timer with completion interface ...
2010-05-20Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (534 commits) V4L/DVB (13554a): v4l: Use the video_drvdata function in drivers V4L/DVB: vivi and mem2mem_testdev need slab.h to build V4L/DVB: tm6000: bugfix image position V4L/DVB: IR/imon: remove dead IMON_KEY_RELEASE_OFFSET V4L/DVB: tm6000: README - add vbi V4L/DVB: Fix unlock logic at medusa_video_init V4L/DVB: fix dvb frontend lockup V4L/DVB: s2255drv: remove dead code V4L/DVB: s2255drv: return if vdev not found V4L/DVB: ov511: cleanup: remove unneeded null check V4L/DVB: media/mem2mem: dereferencing free memory V4L/DVB: media/IR: Add missing include file to rc-map.c V4L/DVB: dvb/stv6110x: cleanup error handling V4L/DVB: ngene: Add lgdt3303 and mt2131 deps to Kconfig V4L/DVB: ngene: start separating out DVB functions into separate file V4L/DVB: ngene: split out card specific code into a separate file V4L/DVB: ngene: split out i2c code into a separate file V4L/DVB: ngene: add initial support for digital side of Avermedia m780 V4L/DVB: ngene: properly support boards where channel 0 isn't a TS input V4L-DVB: ngene: make sure that tuner headers are included ...
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/core: Use kmemdup() instead of kmalloc()+memcpy() IB/iser: Fix error flow in iser_create_ib_conn_res() IB/iser: Enhance disconnection logic for multi-pathing IB/iser: Remove buggy back-pointer setting IB/iser: Add asynchronous event handler MAINTAINERS: Add cxgb4 and iw_cxgb4 entries RDMA/cxgb3: Shrink .text with compile-time init of handlers arrays IPoIB: Allow disabling/enabling TSO on the fly through ethtool IB/mlx4: Add support for masked atomic operations IB/core: Add support for masked atomic operations RDMA/cma: Randomize local port allocation RDMA/nes: Make unnecessarily global functions static RDMA/nes: Make nesadapter->phy_lock usage consistent RDMA/cxgb4: Add driver for Chelsio T4 RNIC IB/mthca: Use the dma state API instead of pci equivalents RDMA/amso1100: Use the dma state API instead of pci equivalents RDMA/cxgb3: Don't free skbs on NET_XMIT_* indications from LLD RDMA/cxgb3: Use the dma state API instead of pci equivalents IB: Explicitly rule out llseek to avoid BKL in default_llseek()
2010-05-20MAINTAINERS: add i2c tree for embedded platformsUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2010-05-19Merge branch 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msmLinus Torvalds
* 'msm-core' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: (72 commits) msm: 7x30 Kconfig and makefile changes msm: clock support for the MSM7x30 CPU. msm: physical offset for MSM7X30 msm: io: add io support for 7x30 msm: Add extern for 7x30 clock list. msm: dma: add 7x30 security domain abstraction msm: update basic board layout for MSM7x30 msm: add devices-msm7x30.c msm: add msm_iomap-7x30.h for MSM7x30 support msm: irqs: add irqs-7x30.h for MSM7x30 support msm: 8x50 Kconfig changes msm: physical offset for QSD8x50 msm: io: add io support for 8x50 msm: add extern for 8x50 clock list. msm: add devices-qsd8x50.c msm: update basic board layout for QSD8x50 msm: add msm_iomap-8x50.h for QSD8x50 support msm: irqs: add irqs-8x50.h for QSD8x50 support msm: timer: allow MSM_DGT_BASE to be overriden msm: add Qualcomm 7x30 interrupt controller driver. ...
2010-05-19Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (224 commits) ARM: remove 'select GENERIC_TIME' ARM: 6136/1: ARCH_REQUIRE_GPIOLIB selects GENERIC_GPIO ARM: 6074/1: oprofile: convert from sysdev to platform device ARM: 6073/1: oprofile: remove old files and update KConfig ARM: 6072/1: oprofile: use perf-events framework as backend ARM: 6071/1: perf-events: allow modules to query the number of hardware counters ARM: 6070/1: perf-events: add support for xscale PMUs ARM: 6069/1: perf-events: use numeric ID to identify PMU ARM: 6064/1: pmu: register IRQs at runtime ARM: Optionally allow ARMv6 to use 'normal, bufferable' memory for DMA ARM: 6134/1: Handle instruction cache maintenance fault properly ARM: nwfpe: allow debugging output to be configured at runtime ARM: rename mach_cpu_disable() to platform_cpu_disable() ARM: 6132/1: PL330: Add common core driver ARM: 6094/1: Extend cache-l2x0 to support the 16-way PL310 ARM: Move memory mapping into mmu.c ARM: Ensure meminfo is sorted prior to sanity_check_meminfo ARM: Remove useless linux/bootmem.h includes ARM: convert /proc/cpu/aligment to seq_file arm: use asm-generic/scatterlist.h ...
2010-05-19V4L/DVB: MAINTAINERS: Update uvcvideo web site addressLaurent Pinchart
The web site has moved to a new location, update the MAINTAINERS file. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/linux/mod_devicetable.h scripts/mod/file2alias.c
2010-05-18qlcnic: adding co maintainerAmit Kumar Salecha
Adding Anirban as co maintainer Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18Merge branch 'x86-txt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-txt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, tboot: Add support for S3 memory integrity protection
2010-05-18Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits) perf tools: Add mode to build without newt support perf symbols: symbol inconsistency message should be done only at verbose=1 perf tui: Add explicit -lslang option perf options: Type check all the remaining OPT_ variants perf options: Type check OPT_BOOLEAN and fix the offenders perf options: Check v type in OPT_U?INTEGER perf options: Introduce OPT_UINTEGER perf tui: Add workaround for slang < 2.1.4 perf record: Fix bug mismatch with -c option definition perf options: Introduce OPT_U64 perf tui: Add help window to show key associations perf tui: Make <- exit menus too perf newt: Add single key shortcuts for zoom into DSO and threads perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed perf newt: Fix the 'A'/'a' shortcut for annotate perf newt: Make <- exit the ui_browser x86, perf: P4 PMU - fix counters management logic perf newt: Make <- zoom out filters perf report: Report number of events, not samples perf hist: Clarify events_stats fields usage ... Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
2010-05-18Merge branch 'oprofile-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) oprofile/x86: make AMD IBS hotplug capable oprofile/x86: notify cpus only when daemon is running oprofile/x86: reordering some functions oprofile/x86: stop disabled counters in nmi handler oprofile/x86: protect cpu hotplug sections oprofile/x86: remove CONFIG_SMP macros oprofile/x86: fix uninitialized counter usage during cpu hotplug oprofile/x86: remove duplicate IBS capability check oprofile/x86: move IBS code oprofile/x86: return -EBUSY if counters are already reserved oprofile/x86: moving shutdown functions oprofile/x86: reserve counter msrs pairwise oprofile/x86: rework error handler in nmi_setup() oprofile: update file list in MAINTAINERS file oprofile: protect from not being in an IRQ context oprofile: remove double ring buffering ring-buffer: Add lost event count to end of sub buffer tracing: Show the lost events in the trace_pipe output ring-buffer: Add place holder recording of dropped events tracing: Fix compile error in module tracepoints when MODULE_UNLOAD not set ...
2010-05-18[SCSI] Merge scsi-misc-2.6 into scsi-rc-fixes-2.6James Bottomley
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-14hughd: update email addressHugh Dickins
My old address will shut down in a couple of weeks: update the tree. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-14Merge branch 'master' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/nico/orion into devel-stable
2010-05-13Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
2010-05-12MAINTAINERS: add MSM mailing listDaniel Walker
Just adds a mailing list to the MSM maintainer entry. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-05-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ar9170/usb.c drivers/scsi/iscsi_tcp.c net/ipv4/ipmr.c
2010-05-11MAINTAINERS: New MAINTAINERS entries for Zipit Z2 and Voipac PXA270Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-05-10Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Pull in the bdi fixes and ARM platform changes that other outstanding patches depend on.
2010-05-10Merge commit 'v2.6.34-rc7' into oprofileIngo Molnar
Merge reason: Update to Linus's latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-05MAINTAINERS: Add cxgb4 and iw_cxgb4 entriesRoland Dreier
Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-05-03oprofile: update file list in MAINTAINERS fileRobert Richter
File list now catches: $ xargs | eval ls -d $(cat) | sort -u arch/*/include/asm/oprofile*.h arch/*/oprofile/ drivers/oprofile/ include/linux/oprofile.h arch/alpha/oprofile/ arch/arm/oprofile/ arch/avr32/oprofile/ arch/blackfin/oprofile/ arch/ia64/oprofile/ arch/m32r/oprofile/ arch/microblaze/oprofile/ arch/mips/oprofile/ arch/mn10300/oprofile/ arch/parisc/oprofile/ arch/powerpc/include/asm/oprofile_impl.h arch/powerpc/oprofile/ arch/s390/oprofile/ arch/sh/oprofile/ arch/sparc/oprofile/ arch/x86/oprofile/ drivers/oprofile/ include/linux/oprofile.h Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-05-03update MAINTAINERS fileNicolas Pitre
I'm no longer at Marvell. Ditto for Lennert. I don't hack on SMC91x much either these days. Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-02[SCSI] Adding MAINTAINERS for qla4xxx iSCSI driver.Ravi Anand
Signed-off-by: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-02ARM: cns3xxx: Add basic support for Cavium Networks CNS3xxx processorsAnton Vorontsov
This patch adds very basic support for ECONA CNS3xxx ARM11 MPcore (ARMv6) dual-core processors. Note that SMP is not yet supported, as well as many peripheral devices. Support for these features will be added later. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
2010-04-30Merge commit 'v2.6.34-rc6' into perf/coreIngo Molnar
Merge reason: update to the latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
