Create a separate MAINTAINERS entry for jbd2
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
My existing email address may stop working in a month or two, so update
email to one that will continue working.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (75 commits)
mmc: core: eMMC bus width may not work on all platforms
mmc: sdhci: Auto-CMD23 fixes.
mmc: sdhci: Auto-CMD23 support.
mmc: core: Block CMD23 support for UHS104/SDXC cards.
mmc: sdhci: Implement MMC_CAP_CMD23 for SDHCI.
mmc: core: Use CMD23 for multiblock transfers when we can.
mmc: quirks: Add/remove quirks conditional support.
mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver
mmc: sdhci-pxa: Add quirks for DMA/ADMA to match h/w
mmc: core: duplicated trial with same freq in mmc_rescan_try_freq()
mmc: core: add support for eMMC Dual Data Rate
mmc: core: eMMC signal voltage does not use CMD11
mmc: sdhci-pxa: add platform code for UHS signaling
mmc: sdhci: add hooks for setting UHS in platform specific code
mmc: core: clear MMC_PM_KEEP_POWER flag on resume
mmc: dw_mmc: fixed wrong regulator_enable in suspend/resume
mmc: sdhi: allow powering down controller with no card inserted
mmc: tmio: runtime suspend the controller, where possible
mmc: sdhi: support up to 3 interrupt sources
mmc: sdhi: print physical base address and clock rate
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
xconfig: merge code path to conf_write()
kconfig: do not record timestamp in .config
gconfig: Hide unused left treeview when start up the interface
gconfig: enable rules hint for main treeviews
MAINTAINERS: Update KCONFIG entry
kconfig-language: add to hints
kconfig: Document the new "visible if" syntax
kconfig: quiet commands when V=0
kconfig: change update-po-config to reflect new layout of arch/um
kconfig: make update-po-config work in KBUILD_OUTPUT
kconfig: rearrange clean-files
kconfig: change gconf to modify hostprogs-y like nconf and mconf
kconfig: change qconf to modify hostprogs-y like nconf and mconf
kconfig: only build kxgettext when needed
nconfig: Silence unused return values from wattrset
kconfig: Do not record timestamp in auto.conf and autoconf.h
kconfig: get rid of unused flags
kconfig: allow multiple inclusion of the same file
kconfig: Avoid buffer underrun in choice input
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: New driver for the SMSC EMC6W201
hwmon: (abituguru) Depend on DMI
hwmon: (it87) Use request_muxed_region
hwmon: (sch5627) Trigger Vbat measurements
hwmon: (sch5627) Add sch5627_send_cmd function
i8k: Integrate with the hwmon subsystem
hwmon: (max6650) Properly support the MAX6650
hwmon: (max6650) Drop device detection
Move ACPI power meter driver to hwmon
hwmon: (f71882fg) Add support for F71808A
hwmon: (f71882fg) Split has_beep in fan_has_beep and temp_has_beep
hwmon: (asc7621) Drop duplicate dependency
hwmon: (jc42) Change detection class
hwmon: Add driver for AMD family 15h processor power information
hwmon: (k10temp) Add support for Fam15h (Bulldozer)
hwmon: Use helper functions to set and get driver data
i8k: Avoid lahf in 64-bit code
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (37 commits)
Blackfin: use new common PERCPU_INPUT define
MAINTAINERS: Fix Analog Devices mailinglist address
Blackfin: boards: update ASoC resources after machine driver overhaul
Blackfin: work around anomaly 05000480
Blackfin: fix addr type with bfin_write_{or,and} helpers
Blackfin: convert /proc/sram to seq_file
Blackfin: switch /proc/gpio to seq_file
Blackfin: fix indentation with bfin_read() helper
Blackfin: convert old cpumask API to new one
Blackfin: don't touch task->cpus_allowed directly
Blackfin: don't touch cpu_possible_map and cpu_present_map directly
Blackfin: bf548-ezkit/bf561-ezkit: update nor flash layout
Blackfin: initial perf_event support
Blackfin: update anomaly lists to latest public info
Blackfin: use on-chip reset func with newer parts
Blackfin: bf533-stamp/bf537-stamp: drop ad1980 from defconfigs
Blackfin: optimize MMR reads during startup a bit
Blackfin: bf537: demux port H mask A and emac rx ints
Blackfin: bf537: fix excessive gpio int demuxing
Blackfin: bf54x: drop unused pm gpio handling
This CPU family provides NB register values to gather following
TDP information
* ProcessorPwrWatts: Specifies in Watts the maximum amount of power
the processor can support.
* CurrPwrWatts: Specifies in Watts the current amount of power being
consumed by the processor.
This driver provides
* power1_crit (ProcessorPwrWatts)
* power1_input (CurrPwrWatts)
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Tobias's email bounces and he hasn't submitted or acked a patch in git
history.
This tree hasn't been updated since June 2008.
Signed-off-by: Lucian Adrian Grijincu <lucian.grijincu@gmail.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Nobody is currently maintaining dw_dmac. We are using dw_dmac for SPEAr13xx and
are currently maintaining it. After discussing with Vinod, sending this patch to
update maintainer-ship of dw_dmac.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
There is a small typo in the Analog Devices driver mailinglist address.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Add the maintainer of the FireWire audio drivers.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Add a driver for Elan Digital System's VUB300 chip which is a USB
connected SDIO/SDmem/MMC host controller. A VUB300 chip enables a USB 2.0
or USB 1.1 connected host computer to use SDIO/SD/MMC cards without the
need for a directly connected, for example via PCI, SDIO host controller.
Signed-off-by: Anthony F Olech <tony.olech@elandigitalsystems.com>
[cjb: various punctuation and style fixes]
Tested-by: Chris Ball <cjb@laptop.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (43 commits)
TOMOYO: Fix wrong domainname validation.
SELINUX: add /sys/fs/selinux mount point to put selinuxfs
CRED: Fix load_flat_shared_library() to initialise bprm correctly
SELinux: introduce path_has_perm
flex_array: allow 0 length elements
flex_arrays: allow zero length flex arrays
flex_array: flex_array_prealloc takes a number of elements, not an end
SELinux: pass last path component in may_create
SELinux: put name based create rules in a hashtable
SELinux: generic hashtab entry counter
SELinux: calculate and print hashtab stats with a generic function
SELinux: skip filename trans rules if ttype does not match parent dir
SELinux: rename filename_compute_type argument to *type instead of *con
SELinux: fix comment to state filename_compute_type takes an objname not a qstr
SMACK: smack_file_lock can use the struct path
LSM: separate LSM_AUDIT_DATA_DENTRY from LSM_AUDIT_DATA_PATH
LSM: split LSM_AUDIT_DATA_FS into _PATH and _INODE
SELINUX: Make selinux cache VFS RCU walks safe
SECURITY: Move exec_permission RCU checks into security modules
SELinux: security_read_policy should take a size_t not ssize_t
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits)
drivers/gpu/drm/radeon/atom.c: fix warning
drm/radeon/kms: bump kms version number
drm/radeon/kms: properly set num banks for fusion asics
drm/radeon/kms/atom: move dig phy init out of modesetting
drm/radeon/kms/cayman: fix typo in register mask
drm/radeon/kms: fix typo in spread spectrum code
drm/radeon/kms: fix tile_config value reported to userspace on cayman.
drm/radeon/kms: fix incorrect comparison in cayman setup code.
drm/radeon/kms: add wait idle ioctl for eg->cayman
drm/radeon/cayman: setup hdp to invalidate and flush when asked
drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked
agp/uninorth: Fix lockups with radeon KMS and >1x.
drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only
drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices
drm/radeon/kms: fixup eDP connector handling
drm/radeon/kms: bail early for eDP in hotplug callback
drm/radeon/kms: simplify hotplug handler logic
drm/radeon/kms: rewrite DP handling
drm/radeon/kms/atom: add support for setting DP panel mode
drm/radeon/kms: atombios.h updates for DP panel mode
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
for-linus
lib/flex_array.c
security/selinux/avc.c
security/selinux/hooks.c
security/selinux/ss/policydb.c
security/smack/smack_lsm.c
Manually resolve conflicts.
Signed-off-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits)
USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h
USB: UHCI: Support big endian GRUSBHC HC
sparc: add {read,write}*_be routines
USB: UHCI: Add support for big endian descriptors
USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier
USB: UHCI: Add support for big endian mmio
usb-storage: Correct adjust_quirks to include latest flags
usb/isp1760: Fix possible unlink problems
usb/isp1760: Move function isp1760_endpoint_disable() within file.
USB: remove remaining usages of hcd->state from usbcore and fix regression
usb: musb: ux500: add configuration and build options for ux500 dma
usb: musb: ux500: add dma glue layer for ux500
usb: musb: ux500: add dma name for ux500
usb: musb: ux500: add ux500 specific code for gadget side
usb: musb: fix compile error
usb-storage: fix up the unusual_realtek device list
USB: gadget: f_audio: Fix invalid dereference of initdata
EHCI: don't rescan interrupt QHs needlessly
OHCI: fix regression caused by nVidia shutdown workaround
USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm:
apm-emulation: apm_mutex breaks ACK; remove it
APM: take over maintainership
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits)
ASoC: core: Don't set "(null)" as a driver name
ALSA: hda - Use LPIB for ATI/AMD chipsets as default
Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets"
ASoC: Tegra: Fix compile when debugfs not enabled
ASoC: spdif-dit: Add missing MODULE_*
SOUND: OSS: Remove Au1550 driver.
ALSA: hda - add Intel Panther Point HDMI codec id
ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live!
ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek
ALSA: hda - Fix input-src parse in patch_analog.c
ASoC: davinci-mcasp: enable ping-pong SRAM buffers
ASoC: add iPAQ hx4700 machine driver
ASoC: Asahi Kasei AK4641 codec driver
ALSA: hda - Enable Realtek ALC269 codec input layer beep
ALSA: intel8x0m: enable AMD8111 modem
ALSA: HDA: Add jack detection for HDMI
ALSA: sound, core, pcm_lib: fix xrun_log
ASoC: Max98095: Move existing NULL check before pointer dereference.
ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt
ALSA: usb-audio - Add support for USB X-Fi S51 Pro
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
MAINTAINERS: Add drivers/clocksource to TIMEKEEPING
clockevents/source: Use u64 to make 32bit happy
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (110 commits)
[SCSI] qla2xxx: Refactor call to qla2xxx_read_sfp for thermal temperature.
[SCSI] qla2xxx: Unify the read/write sfp mailbox command routines.
[SCSI] qla2xxx: Clear complete initialization control block.
[SCSI] qla2xxx: Allow an override of the registered maximum LUN.
[SCSI] qla2xxx: Add host number in reset and quiescent message logs.
[SCSI] qla2xxx: Correctly read sfp single byte mailbox register.
[SCSI] qla2xxx: Add qla82xx_rom_unlock() function.
[SCSI] qla2xxx: Log if qla82xx firmware fails to load from flash.
[SCSI] qla2xxx: Use passed in host to initialize local scsi_qla_host in queuecommand function
[SCSI] qla2xxx: Correct buffer start in edc sysfs debug print.
[SCSI] qla2xxx: Update firmware version after flash update for ISP82xx.
[SCSI] qla2xxx: Fix hang during driver unload when vport is active.
[SCSI] qla2xxx: Properly set the dsd_list_len for dsd_chaining in cmd type 6.
[SCSI] qla2xxx: Fix virtual port failing to login after chip reset.
[SCSI] qla2xxx: Fix vport delete hang when logins are outstanding.
[SCSI] hpsa: Change memset using sizeof(ptr) to sizeof(*ptr)
[SCSI] ipr: Rate limit DMA mapping errors
[SCSI] hpsa: add P2000 to list of shared SAS devices
[SCSI] hpsa: do not attempt PCI power management reset method if we know it won't work.
[SCSI] hpsa: remove superfluous sleeps around reset code
It's not a random dump ground and we care about it.
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
input/atari: Fix mouse movement and button mapping
input/atari: Fix atarimouse init
input/atari: Use the correct mouse interrupt hook
m68k/atari: Do not use "/" in interrupt names
m68k: unistd - Comment out definitions for unimplemented syscalls
m68k: Really wire up sys_pselect6 and sys_ppoll
m68k: Merge mmu and non-mmu versions of sys_call_table
MAINTAINERS: Roman Zippel has been MIA for several years.
m68k: bitops - Never step beyond the end of the bitmap
m68k: bitops - offset == ((long)p - (long)vaddr) * 8
move LSM-, credentials-, and keys-related files from Documentation/
to Documentation/security/,
add Documentation/security/00-INDEX, and
update all occurrences of Documentation/<moved_file>
to Documentation/security/<moved_file>.
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs
* 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs:
Correct occurrences of - Documentation/kvm/ to Documentation/virtual/kvm - Documentation/uml/ to Documentation/virtual/uml - Documentation/lguest/ to Documentation/virtual/lguest throughout the kernel source tree.
Add a 00-INDEX file to Documentation/virtual Remove uml from the top level 00-INDEX file.
Move kvm, uml, and lguest subdirectories under a common "virtual" directory, I.E:
Hence make AFFS and HFS orphans, and remove him as an m68k maintainer.
Signed-off-by: Daniel Mack <zonque@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
Thanks for kernel.org to give me an account
on that server.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Update my email address to new employer.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
Take alphabetical orders for MAINTAINERS file.
Signed-off-by: Harry Wei <harryxiyou@gmail.com>
Cc: Joe Perches <joe@perches.com>
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
Broadcom has released cards based on a new AMBA-based bus type. From a
programming point of view, this new bus type differs from AMBA and does
not use AMBA common registers. It also differs enough from SSB. We
decided that a new bus driver is needed to keep the code clean.
In its current form, the driver detects devices present on the bus and
registers them in the system. It allows registering BCMA drivers for
specified bus devices and provides them basic operations. The bus driver
itself includes two important bus managing drivers: ChipCommon core
driver and PCI(c) core driver. They are early used to allow correct
initialization.
Currently code is limited to supporting buses on PCI(e) devices, however
the driver is designed to be used also on other hosts. The host
abstraction layer is implemented and already used for PCI(e).
Support for PCI(e) hosts is working and seems to be stable (access to
80211 core was tested successfully on a few devices). We can still
optimize it by using some fixed windows, but this can be done later
without affecting any external code. Windows are just ranges in MMIO
used for accessing cores on the bus.
Cc: Greg KH <greg@kroah.com>
Cc: Michael Büsch <mb@bu3sch.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: George Kashperko <george@znau.edu.ua>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: Andy Botting <andy@andybotting.com>
Cc: linuxdriverproject <devel@linuxdriverproject.org>
Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Signed-off-by: Rob Landley <rob@landley.net>
drivers/net/tg3.c
Roman Zippel hasn't been active for several years. Add myself as kconfig
maintainer, but change the mode to "Odd Fixes" to not set expectations
too high. Also, remove the patchwork link, since it is not used for
kbuild/kconfig.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Commit 04a6553f076 ("apm: orphan the driver") Orphaned the APM
driver as Stephen is not willing/able to maintain it any more.
As I still have some hardware that is using APM and running 2.6,
I can take it over.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits)
sysctl: net: call unregister_net_sysctl_table where needed
Revert: veth: remove unneeded ifname code from veth_newlink()
smsc95xx: fix reset check
tg3: Fix failure to enable WoL by default when possible
networking: inappropriate ioctl operation should return ENOTTY
amd8111e: trivial typo spelling: Negotitate -> Negotiate
ipv4: don't spam dmesg with "Using LC-trie" messages
af_unix: Only allow recv on connected seqpacket sockets.
mii: add support of pause frames in mii_get_an
net: ftmac100: fix scheduling while atomic during PHY link status change
usbnet: Transfer of maintainership
usbnet: add support for some Huawei modems with cdc-ether ports
bnx2: cancel timer on device removal
iwl4965: fix "Received BA when not expected"
iwlagn: fix "Received BA when not expected"
dsa/mv88e6131: fix unknown multicast/broadcast forwarding on mv88e6085
usbnet: Resubmit interrupt URB if device is open
iwl4965: fix "TX Power requested while scanning"
iwlegacy: led stay solid on when no traffic
b43: trivial: update module info about ucode16_mimo firmware
Somebody has to do it, however unfortunate be the cause.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
In order to speedup packet filtering, here is an implementation of a
JIT compiler for x86_64
It is disabled by default, and must be enabled by the admin.
echo 1 >/proc/sys/net/core/bpf_jit_enable
It uses module_alloc() and module_free() to get memory in the 2GB text
kernel range since we call helpers functions from the generated code.
EAX : BPF A accumulator
EBX : BPF X accumulator
RDI : pointer to skb (first argument given to JIT function)
RBP : frame pointer (even if CONFIG_FRAME_POINTER=n)
r9d : skb->len - skb->data_len (headlen)
r8 : skb->data
To get a trace of generated code, use :
echo 2 >/proc/sys/net/core/bpf_jit_enable
Example of generated code :
# tcpdump -p -n -s 0 -i eth1 host 192.168.20.0/24
flen=18 proglen=147 pass=3 image=ffffffffa00b5000
JIT code: ffffffffa00b5000: 55 48 89 e5 48 83 ec 60 48 89 5d f8 44 8b 4f 60
JIT code: ffffffffa00b5010: 44 2b 4f 64 4c 8b 87 b8 00 00 00 be 0c 00 00 00
JIT code: ffffffffa00b5020: e8 24 7b f7 e0 3d 00 08 00 00 75 28 be 1a 00 00
JIT code: ffffffffa00b5030: 00 e8 fe 7a f7 e0 24 00 3d 00 14 a8 c0 74 49 be
JIT code: ffffffffa00b5040: 1e 00 00 00 e8 eb 7a f7 e0 24 00 3d 00 14 a8 c0
JIT code: ffffffffa00b5050: 74 36 eb 3b 3d 06 08 00 00 74 07 3d 35 80 00 00
JIT code: ffffffffa00b5060: 75 2d be 1c 00 00 00 e8 c8 7a f7 e0 24 00 3d 00
JIT code: ffffffffa00b5070: 14 a8 c0 74 13 be 26 00 00 00 e8 b5 7a f7 e0 24
JIT code: ffffffffa00b5080: 00 3d 00 14 a8 c0 75 07 b8 ff ff 00 00 eb 02 31
JIT code: ffffffffa00b5090: c0 c9 c3
BPF program is 144 bytes long, so native program is almost same size ;)
(000) ldh [12]
(001) jeq #0x800 jt 2 jf 8
(002) ld [26]
(003) and #0xffffff00
(004) jeq #0xc0a81400 jt 16 jf 5
(005) ld [30]
(006) and #0xffffff00
(007) jeq #0xc0a81400 jt 16 jf 17
(008) jeq #0x806 jt 10 jf 9
(009) jeq #0x8035 jt 10 jf 17
(010) ld [28]
(011) and #0xffffff00
(012) jeq #0xc0a81400 jt 16 jf 13
(013) ld [38]
(014) and #0xffffff00
(015) jeq #0xc0a81400 jt 16 jf 17
(016) ret #65535
(017) ret #0
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Hagen Paul Pfeifer <hagen@jauu.net>
