path: root/MAINTAINERS
2011-11-30Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits) ARM: ux500: update defconfig ARM: u300: update defconfig ARM: at91: enable additional boards in existing soc defconfig files ARM: at91: refresh soc defconfig files for 3.2 ARM: at91: rename defconfig files appropriately ARM: OMAP2+: Fix Compilation error when omap_l3_noc built as module ARM: OMAP2+: Remove empty io.h ARM: OMAP2: select ARM_AMBA if OMAP3_EMU is defined ARM: OMAP: smartreflex: fix IRQ handling bug ARM: OMAP: PM: only register TWL with voltage layer when device is present ARM: OMAP: hwmod: Fix the addr space, irq, dma count APIs arm: mx28: fix bit operation in clock setting ARM: imx: export imx_ioremap ARM: imx/mm-imx3: conditionally compile i.MX31 and i.MX35 code ARM: mx5: Fix checkpatch warnings in cpu-imx5.c MAINTAINERS: Add missing directory ARM: imx: drop 'ARCH_MX31' and 'ARCH_MX35' ARM: imx6q: move clock register map to machine_desc.map_io ARM: pxa168/gplugd: add the correct SSP device ARM: Update mach-types to fix mxs build breakage ...
2011-11-29Merge branch 'defconfigs-for-arnd' of ↵Arnd Bergmann
git://git.linaro.org/people/triad/linux-stericsson into fixes
2011-11-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (28 commits) ALSA: hda - Fix jack-detection control of VT1708 ALSA: hda - cut and paste typo in cs420x_models[] ALSA: hda/realtek - Minor cleanup ALSA: hda/realtek - Fix missing inits of item indices for auto-mic ALSA: hda - Fix invalid pin and GPIO for Apple laptops with CS codecs ALSA: hda - Check subdevice mask in snd_hda_check_board_codec_sid_config() ALSA: hda - fail ELD reading early ALSA: lx6464es - fix device communication via command bus ALSA: lx6464es - command buffer API cleanup ALSA: hda - repoll ELD content for multiple times ALSA: hdspm - Fix PCI ID for PCIe RME MADI cards ASoC: Ensure WM8731 register cache is synced when resuming from disabled ALSA: cs5535 - Fix an endianness conversion ASoC: cs4271: Fix wrong mask parameter in some snd_soc_update_bits calls ASoC: wm_hubs: fix DB_RANGE size ASoC: wm9090: fix DB_RANGE size ASoC: wm8993: fix DB_RANGE size ASoC: wm8962: fix DB_RANGE size ASoC: sgtl5000: fix DB_RANGE size ASoC: rt5631: fix DB_RANGE size ...
2011-11-24Merge branch 'mxs/for-arnd' of ↵Arnd Bergmann
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes
2011-11-22MAINTAINERS: Add missing directorySascha Hauer
arch/arm/mach-imx/ is part of the i.MX support. Add it. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-11-21Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: TTY: ldisc, wait for ldisc infinitely in hangup TTY: ldisc, move wait idle to caller TTY: ldisc, allow waiting for ldisc arbitrarily long Revert "tty/serial: Prevent drop of DCD on suspend for Tegra UARTs" RS485: fix inconsistencies in the meaning of some variables pch_uart: Fix DMA resource leak issue serial,mfd: Fix CMSPAR setup tty/serial: Prevent drop of DCD on suspend for Tegra UARTs pch_uart: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor pch_uart: Support new device LAPIS Semiconductor ML7831 IOH pch_uart: Fix hw-flow control issue tty: hvc_dcc: Fix duplicate character inputs jsm: Change maintainership
2011-11-21Merge branch 'char-misc-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc * 'char-misc-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: misc: ad525x_dpot: Fix AD8400 spi transfer size. pch_phub: Fix MAC address writing issue for LAPIS ML7831 pch_phub: Improve ADE(Address Decode Enable) control pch_phub: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor pch_phub: Support new device LAPIS Semiconductor ML7831 IOH pcie-gadget-spear: Add "platform:" prefix for platform modalias MAINTAINERS: add CHAR and MISC driver maintainers
2011-11-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (86 commits) ipv4: fix redirect handling ping: dont increment ICMP_MIB_INERRORS sky2: fix hang in napi_disable sky2: enforce minimum ring size bonding: Don't allow mode change via sysfs with slaves present f_phonet: fix page offset of first received fragment stmmac: fix pm functions avoiding sleep on spinlock stmmac: remove spin_lock in stmmac_ioctl. stmmac: parameters auto-tuning through HW cap reg stmmac: fix advertising 1000Base capabilties for non GMII iface stmmac: use mdelay on timeout of sw reset sky2: version 1.30 sky2: used fixed RSS key sky2: reduce default Tx ring size sky2: rename up/down functions sky2: pci posting issues sky2: fix hang on shutdown (and other irq issues) r6040: fix check against MCRO_HASHEN bit in r6040_multicast_list MAINTAINERS: change email address for shemminger pch_gbe: Move #include of module.h ...
2011-11-19Xen: update MAINTAINER infoJeremy Fitzhardinge
No longer at Citrix, still interested in Xen. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-19Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: MAINTAINERS: update XFS maintainer entry xfs: use doalloc flag in xfs_qm_dqattach_one()
2011-11-18cgroup: Replace Paul Menage with Tejun Heo as cgroups maintainerPaul Menage
As is probably painfully obvious, I don't have time to be a cgroups maintainer. Rather than have me continue to hope that I'll magically find more spare time, instead Tejun has kindly agreed to take over the role, along with Li Zefan. -tj: added cgroup tree URL to MAINTAINERS file Signed-off-by: Paul Menage <paul@paulmenage.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> LKML-Reference: <1321320612-57855-1-git-send-email-paul@paulmenage.org>
2011-11-18MAINTAINERS: update XFS maintainer entryAlex Elder
I will no longer be maintaining XFS for SGI. Ben Myers (bpm@sgi.com) has agreed to be the primary maintainer for XFS in my place. I will continue to be able to push commits to the SGI XFS tree if required. As such I will continue to be a designated XFS maintainer, but plan to serve in more of a backup role. Signed-off-by: Alex Elder <aelder@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-11-16MAINTAINERS: change email address for shemmingerStephen Hemminger
My old email account at linux-foundation is no longer usable after the LF breakin. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: lantiq: use export.h in favour of module.h MAINTAINERS: The MIPS git tree has moved. MIPS: Fix build error due to missing inclusion of <linux/export.h>. MIPS: ASID conflict after CPU hotplug MIPS: Octeon: Fix compile error in arch/mips/cavium-octeon/flash_setup.c MIPS: errloongson2_clock: Fix build error by including linux/module.h STAGING: octeon-ethernet: Fix compile error caused by skb_frag_struct change MIPS: Hook up process_vm_readv and process_vm_writev system calls. MIPS: Kernel hangs occasionally during boot. MIPS: Octeon: Mark SMP-IPI interrupt as IRQF_NO_THREAD MIPS: BCM47xx: fix build with GENERIC_GPIO configuration MIPS: NXP: Remove unused source files. MIPS: Yosemite, Emma: Fix off-by-two in arcs_cmdline buffer size check
2011-11-15MAINTAINERS: add new cgroup list to CC noticeKAMEZAWA Hiroyuki
As discussed at Kernel Summit(2011), new cgroups mailing list is opened by James. This list is for discussing general cgroup design and patches including all subsystems and for getting more attentions to cgroups/namespaces related issues by developpers. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-15jsm: Change maintainershipLucas Kannebley Tavares
Breno Leitao has passed the maintainership on to me. Signed-off-by: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com> Acked-by: Breno Leitao <brenohl@br.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-14MAINTAINERS: add CHAR and MISC driver maintainersGreg Kroah-Hartman
Yes, we are fools, but humor us. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-11-14MAINTAINERS: The MIPS git tree has moved.Ralf Baechle
2011-11-12Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] v4l2-ctrl: Send change events to all fh for auto cluster slave controls [media] v4l2-event: Don't set sev->fh to NULL on unsubscribe [media] v4l2-event: Remove pending events from fh event queue when unsubscribing [media] v4l2-event: Deny subscribing with a type of V4L2_EVENT_ALL [media] MAINTAINERS: add a maintainer for s5p-mfc driver [media] v4l: s5p-mfc: fix reported capabilities [media] media: vb2: reset queued list on REQBUFS(0) call [media] media: vb2: set buffer length correctly for all buffer types [media] media: vb2: add a check for uninitialized buffer [media] mxl111sf: fix build warning [media] mxl111sf: remove pointless if condition in mxl111sf_config_spi [media] mxl111sf: check for errors after mxl111sf_write_reg in mxl111sf_idac_config [media] mxl111sf: fix return value of mxl111sf_idac_config [media] uvcvideo: GET_RES should only be checked for BITMAP type menu controls
2011-11-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: usb-audio: Use kmemdup rather than duplicating its implementation ALSA: hda - Re-enable the check NO_PRESENCE misc bit ALSA: vmaster - Free slave-links when freeing the master element ALSA: hda - Don't add elements of other codecs to vmaster slave ALSA: intel8x0: improve virtual environment detection ALSA: intel8x0: move virtual environment detection code into one place ALSA: snd_usb_audio: add Logitech HD Webcam c510 to quirk-384 ALSA: hda - fix internal mic on Dell Vostro 3500 laptop ALSA: HDA: Remove quirk for Toshiba T110 ALSA: usb-audio - Fix the missing volume quirks at delayed init ALSA: hda - Mute unused capture sources for Realtek codecs ALSA: intel8x0: Improve comments for VM optimization ASoC: Ensure we get an impedence reported for WM8958 jack detect ASoC: Don't use wm8994->control_data when requesting IRQs ASoC: Don't use wm8994->control_data in wm8994_readable_register() ASoC: Update git repository URL
2011-11-11MAINTAINERS: exynos: Add EXYNOS DRM maintainer entryKyungmin Park
As Exynos DRM is merged at mainline. Also update the maintainer entry. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-11-10MAINTAINERS: Drop inactive Samsung ASoC maintainerJassi Brar
Signed-off-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-08[media] MAINTAINERS: add a maintainer for s5p-mfc driverJeongtae Park
Add a maintainer for s5p-mfc driver. Signed-off-by: Jeongtae Park <jtp.park@samsung.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-08Merge branch 'for-3.2' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-3.2
2011-11-07Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (31 commits) ARM: OMAP: Fix export.h or module.h includes ARM: OMAP: omap_device: Include linux/export.h ARM: OMAP2: Fix H4 matrix keyboard warning ARM: OMAP1: Remove unused omap-alsa.h ARM: OMAP1: Fix warnings about enabling 32 KiHz timer ARM: OMAP2+: timer: Remove omap_device_pm_latency ARM: OMAP2+: clock data: Remove redundant timer clkdev ARM: OMAP: Devkit8000: Remove double omap_mux_init_gpio ARM: OMAP: usb: musb: OMAP: Delete unused function MAINTAINERS: Update linux-omap git repository ARM: OMAP: change get_context_loss_count ret value to int ARM: OMAP4: hsmmc: configure SDMMC1_DR0 properly ARM: OMAP4: hsmmc: Fix Pbias configuration on regulator OFF ARM: OMAP3: hwmod: fix variant registration and remove SmartReflex from common list ARM: OMAP: I2C: Fix omap_register_i2c_bus() return value on success ARM: OMAP: dmtimer: Include linux/module.h ARM: OMAP2+: l3-noc: Include linux/module.h ARM: OMAP2+: devices: Fixes for McPDM ARM: OMAP: Fix errors and warnings when building for one board ARM: OMAP3: PM: restrict erratum i443 handling to OMAP3430 only ...
2011-11-07Merge branch 'fixes-modulesplit' into fixesTony Lindgren
2011-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) forcedeth: fix a few sparse warnings (variable shadowing) forcedeth: Improve stats counters forcedeth: remove unneeded stats updates forcedeth: Acknowledge only interrupts that are being processed forcedeth: fix race when unloading module MAINTAINERS/rds: update maintainer wanrouter: Remove kernel_lock annotations usbnet: fix oops in usbnet_start_xmit ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined etherh: Add MAINTAINERS entry for etherh bonding: comparing a u8 with -1 is always false sky2: fix regression on Yukon Optima netlink: clarify attribute length check documentation netlink: validate NLA_MSECS length i825xx:xscale:8390:freescale: Fix Kconfig dependancies macvlan: receive multicast with local address tg3: Update version to 3.121 tg3: Eliminate timer race with reset_task tg3: Schedule at most one tg3_reset_task run tg3: Obtain PCI function number from device ...
2011-11-07MAINTAINERS/rds: update maintainer Or Gerlitz
update for the actual maintainer Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-05MAINTAINERS: Update eCryptfs maintainer addressTyler Hicks
Update my email address in MAINTAINERS. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-04etherh: Add MAINTAINERS entry for etherhJeff Kirsher
During the re-organization of Ethernet drivers, the MAINTAINERS entry for etherh got dropped accidentally. CC: Russell King <linux@arm.linux.org.uk> CC: Joe Perches <joe@perches.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-04MAINTAINERS: Update linux-omap git repositoryJarkko Nikula
linux-omap is back at git.kernel.org. Path is the same than before except -2.6 appendix. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-11-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits) be2net: Add detect UE feature for Lancer be2net: Prevent CQ full condition for Lancer be2net: Fix disabling multicast promiscous mode be2net: Fix endian issue in RX filter command af_packet: de-inline some helper functions MAINTAINERS: Add can-gw include to maintained files net: Add back alignment for size for __alloc_skb net: add missing bh_unlock_sock() calls l2tp: fix race in l2tp_recv_dequeue() ixgbevf: Update release version ixgbe: DCB, return max for IEEE traffic classes ixgbe: fix reading of the buffer returned by the firmware ixgbe: Fix compiler warnings ixgbe: fix smatch splat due to missing NULL check ixgbe: fix disabling of Tx laser at probe ixgbe: Fix link issues caused by a reset while interface is down igb: Fix for I347AT4 PHY cable length unit detection e100: make sure vlan support isn't advertised on old adapters e1000e: demote a debugging WARN to a debug log message net: fix typo in drivers/net/ethernet/xilinx/ll_temac_main.c ...
2011-11-03MAINTAINERS: Add can-gw include to maintained filesOliver Hartkopp
Commit c1aabdf379bc2feeb0df7057ed5bad96f492133e (can-gw: add netlink based CAN routing) added a new include file that's neither referenced by any of the CAN maintainers. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-04MAINTAINERS: add ARM/FREESCALE MXS entryShawn Guo
As suggested by Pengutronix, they want to get Sascha relieved from the burden of maintaining MXS sub-architecture. Since I brought the most of MXS core code to mainline (with the great help from Pengutronix people, thanks!), I would like to step up for maintaining MXS. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-11-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock: hwspinlock: add MAINTAINERS entries hwspinlock/omap: omap_hwspinlock_remove should be __devexit hwspinlock/u8500: add hwspinlock driver hwspinlock/core: register a bank of hwspinlocks in a single API call hwspinlock/core: remove stubs for register/unregister hwspinlock/core: use a mutex to protect the radix tree hwspinlock/core/omap: fix id issues on multiple hwspinlock devices hwspinlock/omap: simplify allocation scheme hwspinlock/core: simplify 'owner' handling hwspinlock/core: simplify Kconfig Fix up trivial conflicts (addition of omap_hwspinlock_pdata, removal of omap_spinlock_latency) in arch/arm/mach-omap2/hwspinlock.c Also, do an "evil merge" to fix a compile error in omap_hsmmc.c which for some reason was reported in the same email thread as the "please pull hwspinlock changes".
2011-11-02Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: (21 commits) MAINTAINERS: add an entry for Edac Sandy Bridge driver edac: tag sb_edac as EXPERIMENTAL, as it requires more testing EDAC: Fix incorrect edac mode reporting in sb_edac edac: sb_edac: Add it to the building system edac: Add an experimental new driver to support Sandy Bridge CPU's i7300_edac: Fix error cleanup logic i7core_edac: Initialize memory name with cpu, channel, bank i7core_edac: Fix compilation on 32 bits arch i7core_edac: scrubbing fixups EDAC: Correct Kconfig dependencies i7core_edac: return -ENODEV if no MC is found i7core_edac: use edac's own way to print errors MAINTAINERS: remove dropped edac_mce.* from the file i7core_edac: Drop the edac_mce facility x86, MCE: Use notifier chain only for MCE decoding EDAC i7core: Use mce socketid for better compatibility i7core_edac: Don't enable memory scrubbing for Xeon 35xx i7core_edac: Add scrubbing support edac: Move edac main structs to include/linux/edac.h i7core_edac: Fix oops when trying to inject errors ...
2011-11-02Merge branch 'misc-3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'misc-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: MAINTAINERS: Update entry for IA64 [IA64] gpio: GENERIC_GPIO default must be n [IA64[ add CONFIG_NET_VENDOR_INTEL=y to default config files where needed [IA64] agp/hp-agp: Allow binding user memory to the AGP GART [IA64] sn2: add missing put_cpu()
2011-11-02ASoC: Update git repository URLMark Brown
Remove the -2.6 from the name. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-02Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Cleanup metadata flags handling udf: Skip mirror metadata FE loading when metadata FE is ok ext3: Allow quota file use root reservation udf: Remove web reference from UDF MAINTAINERS entry quota: Drop path reference on error exit from quotactl udf: Neaten udf_debug uses udf: Neaten logging output, use vsprintf extension %pV udf: Convert printks to pr_<level> udf: Rename udf_warning to udf_warn udf: Rename udf_error to udf_err udf: Promote some debugging messages to udf_error ext3: Remove the obsolete broken EXT3_IOC32_WAIT_FOR_READONLY. udf: Add readpages support for udf. ext3/balloc.c: local functions should be static ext2: fix the outdated comment in ext2_nfs_get_inode() ext3: remove deprecated oldalloc fs/ext3/balloc.c: delete useless initialization fs/ext2/balloc.c: delete useless initialization ext3: fix message in ext3_remount for rw-remount case ext3: Remove i_mutex from ext3_sync_file() Fix up trivial (printf format cleanup) conflicts in fs/udf/udfdecl.h
2011-11-01Merge branch 'next/soc' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/soc' of git://git.linaro.org/people/arnd/arm-soc: (21 commits) MAINTAINERS: add ARM/FREESCALE IMX6 entry arm/imx: merge i.MX3 and i.MX6 arm/imx6q: add suspend/resume support arm/imx6q: add device tree machine support arm/imx6q: add smp and cpu hotplug support arm/imx6q: add core drivers clock, gpc, mmdc and src arm/imx: add gic_handle_irq function arm/imx6q: add core definitions and low-level debug uart arm/imx6q: add device tree source ARM: highbank: add suspend support ARM: highbank: Add cpu hotplug support ARM: highbank: add SMP support MAINTAINERS: add Calxeda Highbank ARM platform ARM: add Highbank core platform support ARM: highbank: add devicetree source ARM: l2x0: add empty l2x0_of_init picoxcell: add a definition of VMALLOC_END picoxcell: remove custom ioremap implementation picoxcell: add the DTS for the PC7302 board picoxcell: add the DTS for pc3x2 and pc3x3 devices ... Fix up trivial conflicts in arch/arm/Kconfig, and some more header file conflicts in arch/arm/mach-omap2/board-generic.c (as per an ealier merge by Arnd).
2011-11-02Merge branch 'imx/imx6q' into next/socArnd Bergmann
Conflicts: Documentation/devicetree/bindings/arm/fsl.txt arch/arm/Kconfig arch/arm/Kconfig.debug arch/arm/plat-mxc/include/mach/common.h
2011-11-02Merge branch 'highbank/soc' into next/socArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/gpio.h arch/arm/mach-omap2/board-generic.c arch/arm/plat-mxc/include/mach/gpio.h
2011-11-01Merge Qualcom Hexagon architectureLinus Torvalds
This is the fifth version of the patchset (with one tiny whitespace fix) to the Linux kernel to support the Qualcomm Hexagon architecture. Between now and the next pull requests, Richard Kuo should have his key signed, etc., and should be back on kernel.org. In the meantime, this got merged as a emailed patch-series. * Hexagon: (36 commits) Add extra arch overrides to asm-generic/checksum.h Hexagon: Add self to MAINTAINERS Hexagon: Add basic stacktrace functionality for Hexagon architecture. Hexagon: Add configuration and makefiles for the Hexagon architecture. Hexagon: Comet platform support Hexagon: kgdb support files Hexagon: Add page-fault support. Hexagon: Add page table header files & etc. Hexagon: Add ioremap support Hexagon: Provide DMA implementation Hexagon: Implement basic TLB management routines for Hexagon. Hexagon: Implement basic cache-flush support Hexagon: Provide basic implementation and/or stubs for I/O routines. Hexagon: Add user access functions Hexagon: Add locking types and functions Hexagon: Add SMP support Hexagon: Provide basic debugging and system trap support. Hexagon: Add ptrace support Hexagon: Add time and timer functions Hexagon: Add interrupts ...
2011-11-01Hexagon: Add self to MAINTAINERSRichard Kuo
Signed-off-by: Richard Kuo <rkuo@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-01MAINTAINERS: add an entry for Edac Sandy Bridge driverMauro Carvalho Chehab
2011-11-01MAINTAINERS: remove dropped edac_mce.* from the fileMauro Carvalho Chehab
2011-11-01MAINTAINERS: update netfilter maintainersPablo Neira Ayuso
Marc Boucher, James Morris and Rusty Russell were crucial in the early netfilter days. We thank them all! However, they are not actively maintaining netfilter anymore. This patch adds myself as netfilter maintainer. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-10-31Merge branch 'akpm' (Andrew's incoming)Linus Torvalds
Quoth Andrew: - Most of MM. Still waiting for the poweroc guys to get off their butts and review some threaded hugepages patches. - alpha - vfs bits - drivers/misc - a few core kerenl tweaks - printk() features - MAINTAINERS updates - backlight merge - leds merge - various lib/ updates - checkpatch updates * akpm: (127 commits) epoll: fix spurious lockdep warnings checkpatch: add a --strict check for utf-8 in commit logs kernel.h/checkpatch: mark strict_strto<foo> and simple_strto<foo> as obsolete llist-return-whether-list-is-empty-before-adding-in-llist_add-fix wireless: at76c50x: follow rename pack_hex_byte to hex_byte_pack fat: follow rename pack_hex_byte() to hex_byte_pack() security: follow rename pack_hex_byte() to hex_byte_pack() kgdb: follow rename pack_hex_byte() to hex_byte_pack() lib: rename pack_hex_byte() to hex_byte_pack() lib/string.c: fix strim() semantics for strings that have only blanks lib/idr.c: fix comment for ida_get_new_above() lib/percpu_counter.c: enclose hotplug only variables in hotplug ifdef lib/bitmap.c: quiet sparse noise about address space lib/spinlock_debug.c: print owner on spinlock lockup lib/kstrtox: common code between kstrto*() and simple_strto*() functions drivers/leds/leds-lp5521.c: check if reset is successful leds: turn the blink_timer off before starting to blink leds: save the delay values after a successful call to blink_set() drivers/leds/leds-gpio.c: use gpio_get_value_cansleep() when initializing drivers/leds/leds-lm3530.c: add __devexit_p where needed ...
2011-10-31MAINTAINERS: add ASLR maintainerJiri Kosina
Since achieving the full ASLR by merging the PIE randomization in commit cc503c1b43 ("x86: PIE executable randomization"), I have been dealing with most (if not all) of the bugreports reported against userspace address space randomization, so it might be a good idea to provide a decent contact point in MAINTAINERS. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31MAINTAINERS: Linas has movedLinas Vepstas
While ego surfing, I noticed an email address problem. Signed-off-by: Linas Vepstas <linasvepstas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
