path: root/MAINTAINERS
2011-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits) usbnet: Remove over-broad module alias from zaurus. MAINTAINERS: drop Michael from bfin_mac driver net/can: activate bit-timing calculation and netlink based drivers by default rionet: fix NULL pointer dereference in rionet_remove net+crypto: Use vmalloc for zlib inflate buffers. netfilter: Fix ip_route_me_harder triggering ip_rt_bug ipv4: Fix IPsec slowpath fragmentation problem ipv4: Fix packet size calculation in __ip_append_data cxgb3: skb_record_rx_queue now records the queue index relative to the net_device. bridge: Only flood unregistered groups to routers qlge: Add maintainer. MAINTAINERS: mark socketcan-core lists as subscribers-only MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCED r8169: fix wrong register use. net/usb/kalmia: signedness bug in kalmia_bind() net/usb: kalmia: Various fixes for better support of non-x86 architectures. rtl8192cu: Fix missing firmware load udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packet ipv6/udp: Use the correct variable to determine non-blocking condition netconsole: fix build when CONFIG_NETCONSOLE_DYNAMIC is turned on ...
2011-06-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6: MAINTAINERS: update AVR32 and AT32AP maintainers
2011-06-30MAINTAINERS: update AVR32 and AT32AP maintainersHans-Christian Egtvedt
This alters the maintenance of the AVR32 architecture and the AT32AP machine code to be shared between Haavard Skinnemoen and me. The status is also changed to maintained, as we no longer are being paid to look after this architecture. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Haavard Skinnemoen <hskinnemoen@gmail.com>
2011-06-29MAINTAINERS: drop Michael from bfin_mac driverMike Frysinger
We want people to just use the list now rather than hitting up people who are no longer responsible for it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-28Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: MAINTAINERS: add myself as maintainer of USB/IP usb: r8a66597-hcd: fix cannot detect low/full speed device USB: ehci-ath79: fix a NULL pointer dereference USB: Add new FT232H chip to drivers/usb/serial/ftdi_sio.c usb/isp1760: Fix bug preventing the unlinking of control urbs USB: Fix up URB error codes to reflect implementation. xhci: Always set urb->status to zero for isoc endpoints. xhci: Add reset on resume quirk for asrock p67 host xHCI 1.0: Incompatible Device Error USB: don't let errors prevent system sleep USB: don't let the hub driver prevent system sleep USB: change maintainership of ohci-hcd and ehci-hcd xHCI 1.0: Force Stopped Event(FSE) xhci: Don't warn about zeroed bMaxBurst descriptor field. USB: Free bandwidth when usb_disable_device is called. xhci: Reject double add of active endpoints. USB: TI 3410/5052 USB Serial Driver: Fix mem leak when firmware is too big. usb: musb: gadget: clear TXPKTRDY flag when set FLUSHFIFO usb: musb: host: compare status for negative error values
2011-06-27MAINTAINERS: add myself as maintainer of USB/IPmatt mooney
Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-24qlge: Add maintainer.Ron Mercer
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-24MAINTAINERS: mark socketcan-core lists as subscribers-onlyMike Frysinger
The socketcan-core lists require subscription, so mark them as such. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-24MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCEDSven Eckelmann
I cannot speak on behalf of the batman-adv developers due to conflicts in the opinion about the ongoing development. The batman-adv module is still maintained by Marek Lindner and Simon Wunderlich. Those are the main persons behind the visions of batman-adv. Therefore, the state of module hasn't changed. Signed-off-by: Sven Eckelmann <sven@narfation.org> Cc: b.a.t.m.a.n@lists.open-mesh.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) pxa168_eth: fix race in transmit path. ipv4, ping: Remove duplicate icmp.h include netxen: fix race in skb->len access sgi-xp: fix a use after free hp100: fix an skb->len race netpoll: copy dev name of slaves to struct netpoll ipv4: fix multicast losses r8169: fix static initializers. inet_diag: fix inet_diag_bc_audit() gigaset: call module_put before restart of if_open() farsync: add module_put to error path in fst_open() net: rfs: enable RFS before first data packet is received fs_enet: fix freescale FCC ethernet dp buffer alignment netdev: bfin_mac: fix memory leak when freeing dma descriptors vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan support caif: Bugfix - XOFF removed channel from caif-mux tun: teach the tun/tap driver to support netpoll dp83640: drop PHY status frames in the driver. dp83640: fix phy status frame event parsing phylib: Allow BCM63XX PHY to be selected only on BCM63XX. ...
2011-06-18x86, MAINTAINERS: Add x86 MCE peopleIngo Molnar
Announce the new x86 MCE infrastructure maintainers. Acked-by: Borislav Petkov <bp@amd64.org> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-8hs7yob6wib4vblmrmbpbav4@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: Revert "HID: magicmouse: ignore 'ivalid report id' while switching modes" HID: hid-multitouch: fix broken eGalax HID: MAINTAINERS: Update USB HID/HIDBP DRIVERS pattern HID: hid-multitouch: add support for Chunghwa multi-touch panel HID: hiddev: fix use after free in hiddev_release HID: add quirk for HyperPen 10000U HID: hiddev: fix potential use-after-free
2011-06-16MAINTAINERS: Update EBTABLES mailing listJoe Perches
It moved to netfilter-devel@vger.kernel.org. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-15MAINTAINERS: add entry for legacy eeprom driverJean Delvare
I shall maintain the legacy eeprom driver, until we finally get rid of it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15MAINTAINERS: add videobuf2 maintainersPawel Osciak
Add maintainers for the videobuf2 V4L2 driver framework. Signed-off-by: Pawel Osciak <pawel@osciak.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15MAINTAINERS: Balbir has movedBalbir Singh
Update my email address. Email will start to the old address bouncing soon Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15USB: change maintainership of ohci-hcd and ehci-hcdAlan Stern
Following the loss of David Brownell, I volunteer to maintain the ohci-hcd and ehci-hcd drivers. This patch (as1472) makes it official. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-14Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Remove cpufreq_stats sysfs entries on module unload. MAINTAINERS: Update CPU FREQUENCY patterns
2011-06-12MAINTAINERS: Update CPU FREQUENCY patternsJoe Perches
Commit bb0a56ecc4ba ("[CPUFREQ] Move x86 drivers to drivers/cpufreq/") moved the files, remove the old pattern. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (55 commits) ISDN, hfcsusb: Don't leak in hfcsusb_ph_info() netpoll: call dev_put() on error in netpoll_setup() net: ep93xx_eth: fix DMA API violations net: ep93xx_eth: drop GFP_DMA from call to dma_alloc_coherent() net: ep93xx_eth: allocate buffers using kmalloc() net: ep93xx_eth: pass struct device to DMA API functions ep93xx: set DMA masks for the ep93xx_eth vlan: Fix the ingress VLAN_FLAG_REORDER_HDR check dl2k: EEPROM CRC calculation wrong endianess on bigendian machine NET: am79c961: fix assembler warnings NET: am79c961: ensure multicast filter is correctly set at open NET: am79c961: ensure asm() statements are marked volatile ethtool.h: fix typos ep93xx_eth: Update MAINTAINERS ipv4: Fix packet size calculation for raw IPsec packets in __ip_append_data netpoll: prevent netpoll setup on slave devices net: pmtu_expires fixes gianfar:localized filer table iwlegacy: fix channel switch locking mac80211: fix IBSS teardown race ...
2011-06-09ep93xx_eth: Update MAINTAINERSH Hartley Sweeten
Lennert stated that he has been short on time lately. Since I'm maintaining the ep93xx core stuff, I'm willing to also take over maintaining the Ethernet driver. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09unicore32: move rtc-puv3.c to drivers/rtc directoryGuan Xuetao
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/ to drivers/rtc/, with renaming it to rtc-puv3.c. Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-08MAINTAINERS: add a maintainer to Gadget FrameworkFelipe Balbi
I'll be continuing the amazing work Dave has done with the Gadget Framework. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07MAINTAINERS: Saying goodbye to David BrownellGrant Likely
We had to say goodbye when David passed away recently. David had a huge impact on our community, both personally in the lives of the people he worked with, and technically in the design and maintenance of several subsystems. He is greatly missed. He also leaves behind a number of much loved subsystems now orphaned. This patch updates the MAINTAINERS file for the areas that David was responsible for and adds an entry for him to the CREDITS file. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-07HID: MAINTAINERS: Update USB HID/HIDBP DRIVERS patternJoe Perches
It was moved by commit 1a978c50c6cf ("HID: Move hiddev.txt to the new Documentation/hid directory") so update the MAINTAINERS pattern too. cc: Jiri Kosina <jkosina@suse.cz> cc: Alan Ott <alan@signal11.us> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-29Merge branch 'x86-platform-next' into x86-platformMatthew Garrett
2011-05-28Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits) x86: poll waiting for I/OAT DMA channel status maintainers: add dma engine tree details dmaengine: add TODO items for future work on dma drivers dmaengine: Add API documentation for slave dma usage dmaengine/dw_dmac: Update maintainer-ship dmaengine: move link order dmaengine/dw_dmac: implement pause and resume in dwc_control dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called dmaengine: at_hdmac: pause: no need to wait for FIFO empty pch_dma: modify pci device table definition pch_dma: Support new device ML7223 IOH pch_dma: Support I2S for ML7213 IOH pch_dma: Fix DMA setting issue pch_dma: modify for checkpatch pch_dma: fix dma direction issue for ML7213 IOH video-in dmaengine: at_hdmac: use descriptor chaining help function dmaengine: at_hdmac: implement pause and resume in atc_control ... Fix up trivial conflict in drivers/dma/dw_dmac.c
2011-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits) [SCSI] lpfc 8.3.24: Extend BSG infrastructure and add link diagnostics [SCSI] lpfc 8.3.24: Add resource extent support [SCSI] lpfc 8.3.24: Add request-firmware support [SCSI] lpfc 8.3.24: Add SR-IOV control [SCSI] lpfc 8.3.24: Extended hardware support and support dump images [SCSI] lpfc 8.3.24: Miscellaneous Fixes and Corrections [SCSI] libsas: Add option for SATA soft reset [SCSI] libsas: check dev->gone before submitting sata i/o [SCSI] libsas: fix/amend device gone notification in sas_deform_port() [SCSI] MAINTAINERS update for SCSI (new email address) [SCSI] Fix Ultrastor asm snippet [SCSI] osst: fix warning [SCSI] osst: wrong index used in inner loop [SCSI] aic94xx: world-writable sysfs update_bios file [SCSI] MAINTAINERS: Add drivers/target/ entry [SCSI] target: Convert TASK_ATTR to scsi_tcq.h definitions [SCSI] target: Convert REPORT_LUNs to use int_to_scsilun [SCSI] target: Fix task->task_execute_queue=1 clear bug + LUN_RESET OOPs [SCSI] target: Fix bug with task_sg chained transport_free_dev_tasks release [SCSI] target: Fix interrupt context bug with stats_lock and core_tmr_alloc_req ...
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: MAINTAINERS: Update eCryptfs mailing list eCryptfs: Allow 2 scatterlist entries for encrypted filenames eCryptfs: Clear i_nlink in rmdir
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits) ASoC: Fix power down for widgetless per-card DAPM context case ASoC: wm1250-ev1: Define "WM1250 Output" with SND_SOC_DAPM_OUTPUT ASoC: Remove duplicate linux/delay.h inclusion. ASoC: sam9g20_wm8731: use the proper SYSCKL value ASoC: wm8731: fix wm8731_check_osc() connected condition ALSA: hda - Reorganize controller quriks with bit flags ALSA: hda - Use snd_printd() in snd_hda_parse_pin_def_config() ALSA: core: remove unused variables. ALSA: HDA: Increase MAX_HDMI_PINS ALSA: PCM - Don't check DMA time-out too shortly MAINTAINERS: add FireWire audio maintainer ALSA: usb-audio: more control quirks for M-Audio FastTrack devices ALSA: usb-audio: add new quirk type QUIRK_AUDIO_STANDARD_MIXER ALSA: usb-audio: export snd_usb_feature_unit_ctl ALSA: usb-audio: rework add_control_to_empty() ALSA: usb-audio: move assignment of chip->ctrl_intf ALSA: hda - Use model=auto for Lenovo G555 ALSA: HDA: Unify HDMI hotplug handling. ALSA: hda - Force AD1988_6STACK_DIG for Asus M3N-HT Deluxe ASoC: core - remove superfluous new line. ...
2011-05-27MAINTAINERS: Update eCryptfs mailing listTyler Hicks
The eCryptfs mailing list has moved from lists.launchpad.net to vger.kernel.org. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-05-27acer-wmi: Update MAINTAINERSCarlos Corbacho
I don't have the time or much interest these days in maintaining acer-wmi, as I don't have access to newer Acer hardware. As he's been doing most of the work these days anyway, Joey Lee has kindly agreed to take over. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Joey Lee <jlee@novell.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-27wmi: Orphan ACPI-WMI driverCarlos Corbacho
I no longer have the time to work on this, and haven't really been doing any work to this either. Time to let someone else take the reins. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-27tc1100-wmi: Orphan driverCarlos Corbacho
I've never owned the hardware, this was a port of an existing driver to prove that the ACPI-WMI code was useful to more than just acer-wmi. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: update email address Squashfs: add extra sanity checks at mount time Squashfs: add sanity checks to fragment reading at mount time Squashfs: add sanity checks to lookup table reading at mount time Squashfs: add sanity checks to id reading at mount time Squashfs: add sanity checks to xattr reading at mount time Squashfs: reverse order of filesystem table reading Squashfs: move table allocation into squashfs_read_table()
2011-05-26MAINTAINERS: add mm/page_cgroup.c into memcg subsystemNamhyung Kim
AFAICS mm/page_cgroup.c is for memcg subsystem, but it was directed only to generic cgroup maintainers. Fix it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26maintainers: add dma engine tree detailsVinod Koul
Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-05-26[SCSI] MAINTAINERS update for SCSI (new email address)James Bottomley
Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-26Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (57 commits) regulator: Fix 88pm8607.c printk format warning input: Add support for Qualcomm PMIC8XXX power key input: Add Qualcomm pm8xxx keypad controller driver mfd: Add omap-usbhs runtime PM support mfd: Fix ASIC3 SD Host Controller Configuration size mfd: Fix omap_usbhs_alloc_children error handling mfd: Fix omap usbhs crash when rmmoding ehci or ohci mfd: Add ASIC3 LED support leds: Add ASIC3 LED support mfd: Update twl4030-code maintainer e-mail address mfd: Correct the name and bitmask for ab8500-gpadc BTempPullUp mfd: Add manual ab8500-gpadc batt temp activation for AB8500 3.0 mfd: Provide ab8500-core enumerators for chip cuts mfd: Check twl4030-power remove script error condition after i2cwrite mfd: Fix twl6030 irq definitions mfd: Add phoenix lite (twl6025) support to twl6030 mfd: Avoid to use constraint name in 88pm860x regulator driver mfd: Remove checking on max8925 regulator[0] mfd: Remove unused parameter from 88pm860x API mfd: Avoid to allocate 88pm860x static platform data ...
2011-05-26MAINTAINERS: Add patterns for pmic 8921 files to MSM subsystemAbhijeet Dharmapurikar
Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (61 commits) jbd2: Add MAINTAINERS entry jbd2: fix a potential leak of a journal_head on an error path ext4: teach ext4_ext_split to calculate extents efficiently ext4: Convert ext4 to new truncate calling convention ext4: do not normalize block requests from fallocate() ext4: enable "punch hole" functionality ext4: add "punch hole" flag to ext4_map_blocks() ext4: punch out extents ext4: add new function ext4_block_zero_page_range() ext4: add flag to ext4_has_free_blocks ext4: reserve inodes and feature code for 'quota' feature ext4: add support for multiple mount protection ext4: ensure f_bfree returned by ext4_statfs() is non-negative ext4: protect bb_first_free in ext4_trim_all_free() with group lock ext4: only load buddy bitmap in ext4_trim_fs() when it is needed jbd2: Fix comment to match the code in jbd2__journal_start() ext4: fix waiting and sending of a barrier in ext4_sync_file() jbd2: Add function jbd2_trans_will_send_data_barrier() jbd2: fix sending of data flush on journal commit ext4: fix ext4_ext_fiemap_cb() to handle blocks before request range correctly ...
2011-05-26jbd2: Add MAINTAINERS entryTheodore Ts'o
Create a separate MAINTAINERS entry for jbd2 Cc: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-26Squashfs: update email addressPhillip Lougher
My existing email address may stop working in a month or two, so update email to one that will continue working. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2011-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (75 commits) mmc: core: eMMC bus width may not work on all platforms mmc: sdhci: Auto-CMD23 fixes. mmc: sdhci: Auto-CMD23 support. mmc: core: Block CMD23 support for UHS104/SDXC cards. mmc: sdhci: Implement MMC_CAP_CMD23 for SDHCI. mmc: core: Use CMD23 for multiblock transfers when we can. mmc: quirks: Add/remove quirks conditional support. mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver mmc: sdhci-pxa: Add quirks for DMA/ADMA to match h/w mmc: core: duplicated trial with same freq in mmc_rescan_try_freq() mmc: core: add support for eMMC Dual Data Rate mmc: core: eMMC signal voltage does not use CMD11 mmc: sdhci-pxa: add platform code for UHS signaling mmc: sdhci: add hooks for setting UHS in platform specific code mmc: core: clear MMC_PM_KEEP_POWER flag on resume mmc: dw_mmc: fixed wrong regulator_enable in suspend/resume mmc: sdhi: allow powering down controller with no card inserted mmc: tmio: runtime suspend the controller, where possible mmc: sdhi: support up to 3 interrupt sources mmc: sdhi: print physical base address and clock rate ...
2011-05-25Merge branch 'kconfig-for-40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: xconfig: merge code path to conf_write() kconfig: do not record timestamp in .config gconfig: Hide unused left treeview when start up the interface gconfig: enable rules hint for main treeviews MAINTAINERS: Update KCONFIG entry kconfig-language: add to hints kconfig: Document the new "visible if" syntax kconfig: quiet commands when V=0 kconfig: change update-po-config to reflect new layout of arch/um kconfig: make update-po-config work in KBUILD_OUTPUT kconfig: rearrange clean-files kconfig: change gconf to modify hostprogs-y like nconf and mconf kconfig: change qconf to modify hostprogs-y like nconf and mconf kconfig: only build kxgettext when needed nconfig: Silence unused return values from wattrset kconfig: Do not record timestamp in auto.conf and autoconf.h kconfig: get rid of unused flags kconfig: allow multiple inclusion of the same file kconfig: Avoid buffer underrun in choice input
2011-05-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: New driver for the SMSC EMC6W201 hwmon: (abituguru) Depend on DMI hwmon: (it87) Use request_muxed_region hwmon: (sch5627) Trigger Vbat measurements hwmon: (sch5627) Add sch5627_send_cmd function i8k: Integrate with the hwmon subsystem hwmon: (max6650) Properly support the MAX6650 hwmon: (max6650) Drop device detection Move ACPI power meter driver to hwmon hwmon: (f71882fg) Add support for F71808A hwmon: (f71882fg) Split has_beep in fan_has_beep and temp_has_beep hwmon: (asc7621) Drop duplicate dependency hwmon: (jc42) Change detection class hwmon: Add driver for AMD family 15h processor power information hwmon: (k10temp) Add support for Fam15h (Bulldozer) hwmon: Use helper functions to set and get driver data i8k: Avoid lahf in 64-bit code
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (37 commits) Blackfin: use new common PERCPU_INPUT define MAINTAINERS: Fix Analog Devices mailinglist address Blackfin: boards: update ASoC resources after machine driver overhaul Blackfin: work around anomaly 05000480 Blackfin: fix addr type with bfin_write_{or,and} helpers Blackfin: convert /proc/sram to seq_file Blackfin: switch /proc/gpio to seq_file Blackfin: fix indentation with bfin_read() helper Blackfin: convert old cpumask API to new one Blackfin: don't touch task->cpus_allowed directly Blackfin: don't touch cpu_possible_map and cpu_present_map directly Blackfin: bf548-ezkit/bf561-ezkit: update nor flash layout Blackfin: initial perf_event support Blackfin: update anomaly lists to latest public info Blackfin: use on-chip reset func with newer parts Blackfin: bf533-stamp/bf537-stamp: drop ad1980 from defconfigs Blackfin: optimize MMR reads during startup a bit Blackfin: bf537: demux port H mask A and emac rx ints Blackfin: bf537: fix excessive gpio int demuxing Blackfin: bf54x: drop unused pm gpio handling ...
2011-05-25hwmon: Add driver for AMD family 15h processor power informationAndreas Herrmann
This CPU family provides NB register values to gather following TDP information * ProcessorPwrWatts: Specifies in Watts the maximum amount of power the processor can support. * CurrPwrWatts: Specifies in Watts the current amount of power being consumed by the processor. This driver provides * power1_crit (ProcessorPwrWatts) * power1_input (CurrPwrWatts) Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-25MAINTAINERS: orphan DMFE, move Tobias Ringstrom to CREDITSJoe Perches
Tobias's email bounces and he hasn't submitted or acked a patch in git history. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
