path: root/MAINTAINERS
2011-01-03Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
2010-12-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) ipv4: dont create routes on down devices epic100: hamachi: yellowfin: Fix skb allocation size sundance: Fix oopses with corrupted skb_shared_info Revert "ipv4: Allow configuring subnets as local addresses" USB: mcs7830: return negative if auto negotiate fails irda: prevent integer underflow in IRLMP_ENUMDEVICES tcp: fix listening_get_next() atl1c: Do not use legacy PCI power management mac80211: fix mesh forwarding MAINTAINERS: email address change net: Fix range checks in tcf_valid_offset(). net_sched: sch_sfq: fix allot handling hostap: remove netif_stop_queue from init mac80211/rt2x00: add ieee80211_tx_status_ni() typhoon: memory corruption in typhoon_get_drvinfo() net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant net_sched: always clone skbs ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed. netlink: fix gcc -Wconversion compilation warning asix: add USB ID for Logitec LAN-GTJ U2A ...
2010-12-24ARM: 6537/1: update Nomadik, U300 and Ux500 maintainersLinus Walleij
Adding in self as maintainer for Nomadik and Ux500, I'm running an active -next tree for that stuff now. Extend file matchers to cover a few more relevant drivers and add git references. Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22MAINTAINERS: update geode entryAndres Salomon
Remove Jordan as the geode maintainer (he's not been interested in geode for some time), and add myself as the maintainer. Signed-off-by: Andres Salomon <dilinger@queued.net> Cc: Daniel Drake <dsd@laptop.org> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-21MAINTAINERS: email address changeDon Fry
My ISP has changed and therefore my email address. Signed-off-by: Don Fry <pcnet32@frontier.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-15MAINTAINERS: update MSM git treeDaniel Walker
The MSM main git tree has changed over to this new address. Signed-off-by: Daniel Walker <dwalker@codeaurora.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: It is likely that WORKER_NOT_RUNNING is true MAINTAINERS: Add workqueue entry workqueue: check the allocation of system_unbound_wq
2010-12-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6535/1: V6 MPCore v6_dma_inv_range and v6_dma_flush_range RWFO fix ARM: 6534/1: Make CONFIG_FPE_NWFPE depend on !CONFIG_THUMB2_KERNEL ARM: 6533/1: Thumb-2: Make CONFIG_THUMB2_KERNEL depend on !CPU_V6 Change bcmring Maintainer list. ARM: Update mach-types ARM: 6528/1: Use CTR for the I-cache line size on ARMv7 ARM: 6527/1: Use CTR instead of CCSIDR for the D-cache line size on ARMv7 ARM: pxa/palm: fix ifdef around gen_nand driver registration ARM: pxa: fix pxa2xx-flash section mismatch ARM: mmp2: remove not used clk_rtc
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (75 commits) pppoe.c: Fix kernel panic caused by __pppoe_xmit WAN: Fix a TX IRQ causing BUG() in PC300 and PCI200SYN drivers. bnx2x: Advance a version number to 1.60.01-0 bnx2x: Fixed a compilation warning bnx2x: LSO code was broken on BE platforms qlge: Fix deadlock when cancelling worker. net: fix skb_defer_rx_timestamp() cxgb4vf: Ingress Queue Entry Size needs to be 64 bytes phy: add the IC+ IP1001 driver atm: correct sysfs 'device' link creation and parent relationships MAINTAINERS: remove me from tulip SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped address enic: Bug Fix: Pass napi reference to the isr that services receive queue ipv6: fix nl group when advertising a new link connector: add module alias net: Document the kernel_recvmsg() function r8169: Fix runtime power management hso: IP checksuming doesn't work on GE0301 option cards xfrm: Fix xfrm_state_migrate leak net: Convert netpoll blocking api in bonding driver to be a counter ...
2010-12-14Change bcmring Maintainer list.Jiandong Zheng
I am Jiandong Zheng working on BCMRING in Broadcom Canada Ltd. I am replacing Leo Chen (leochen@broadcom.com) as "ARM/BCMRING ARM ARCHITECTURE" and "ARM/BCMRING MTD NAND DRIVER" maintainer from Broadcom as he is no longer the maintainer of these components. Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Acked-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-14MAINTAINERS: Add workqueue entryTejun Heo
2010-12-10MAINTAINERS: remove me from tulipKyle McMartin
It was a nice idea, but -ENOTIME and -ENOHW. I never got around to doing a lot of the clean up that I intended to. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: uio: Change mail address of Hans J. Koch driver core: prune docs about device_interface driver core: the development tree has switched to git
2010-12-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB: Fix information leak in marshalling code IB/pack: Remove some unused code added by the IBoE patches IB/mlx4: Fix IBoE link state IB/mlx4: Fix IBoE reported link rate mlx4_core: Workaround firmware bug in query dev cap IB/mlx4: Fix memory ordering of VLAN insertion control bits MAINTAINERS: Update NetEffect entry
2010-12-01MAINTAINERS: Update NetEffect entryChien Tung
Correct web link as www.neteffect.com is no longer valid. Remove Chien Tung as maintainer. I am moving on to other responsibilities at Intel. Thanks for all the fish. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-11-30Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: add workaround for dce3 ddc line vbios bug drm/radeon/kms: fix interlaced and doublescan handling drm/radeon/kms: fix typos in disabled vbios code Revert "drm/i915/dp: use VBT provided eDP params if available" drm/i915: Clear pfit registers when not used by any outputs drm: record monitor status in output_poll_execute drm: Set connector DPMS status to ON in drm_crtc_helper_set_config drm/i915: fix regression due to ba3d8d749b01548b9 Revert "drm/radeon/kms: fix typo in r600 cs checker" drm/i915/sdvo: Always add a 30ms delay to make SDVO TV detection reliable MAINTAINERS: INTEL DRM DRIVERS list (intel-gfx) is subscribers-only drm/i915/sdvo: Always fallback to querying the shared DDC line drm/i915: Handle pagefaults in execbuffer user relocations drm/i915/sdvo: Only enable HDMI encodings only if the commandset is supported drm/radeon/kms: fix resume regression for some r5xx laptops drm/radeon/kms: fix regression in rs4xx i2c setup drm/i915: Only save/restore cursor regs if !KMS drm/i915: Prevent integer overflow when validating the execbuffer
2010-11-25Merge branch 'drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile * 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: pci root complex: support for tile architecture drivers/net/tile/: on-chip network drivers for the tile architecture MAINTAINERS: add drivers/char/hvc_tile.c as maintained by tile
2010-11-25Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: sisfb: delete osdef.h sisfb: move the CONFIG warning to sis_main.c sisfb: replace SiS_SetMemory with memset_io sisfb: remove InPort/OutPort wrappers sisfb: use CONFIG_FB_SIS_301/315 instead of SIS301/315H sisfb: delete redudant #define SIS_LINUX_KERNEL sisfb: delete dead SIS_XORG_XF86 code sisfb: delete fallback code for pci_map_rom() sisfb: delete obsolete PCI ROM bug workaround fbdev: Update documentation index file. lxfb: Program panel v/h sync output polarity correctly fbcmap: integer overflow bug fbcmap: cleanup white space in fb_alloc_cmap() MAINTAINERS: Add fbdev patchwork entry, tidy up file patterns. fbdev: da8xx: punt duplicated FBIO_WAITFORVSYNC define fbdev: sh_mobile_lcdcfb: fix bug in reconfig()
2010-11-24drivers/net/tile/: on-chip network drivers for the tile architectureChris Metcalf
This change adds the first network driver for the tile architecture, supporting the on-chip XGBE and GBE shims. The infrastructure is present for the TILE-Gx networking drivers (another three source files in the new directory) but for now the the actual tilegx sources are waiting on releasing hardware to initial customers. Note that arch/tile/include/hv/* are "upstream" headers from the Tilera hypervisor and will probably benefit less from LKML review. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-24MAINTAINERS: INTEL DRM DRIVERS list (intel-gfx) is subscribers-onlyJoe Perches
Mark it so. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: of/phylib: Use device tree properties to initialize Marvell PHYs. phylib: Add support for Marvell 88E1149R devices. phylib: Use common page register definition for Marvell PHYs. qlge: Fix incorrect usage of module parameters and netdev msg level ipv6: fix missing in6_ifa_put in addrconf SuperH IrDA: correct Baud rate error correction atl1c: Fix hardware type check for enabling OTP CLK net: allow GFP_HIGHMEM in __vmalloc() bonding: change list contact to netdev@vger.kernel.org e1000: fix screaming IRQ
2010-11-21bonding: change list contact to netdev@vger.kernel.orgSimon Horman
bonding-devel@lists.sourceforge.net seems only receive spam and discussion seems to already occur on netdev@vger.kernel.org. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) net: fix kernel-doc for sk_filter_rcu_release be2net: Fix to avoid firmware update when interface is not open. netfilter: fix IP_VS dependencies net: irda: irttp: sync error paths of data- and udata-requests ipv6: Expose reachable and retrans timer values as msecs ipv6: Expose IFLA_PROTINFO timer values in msecs instead of jiffies 3c59x: fix build failure on !CONFIG_PCI ipg.c: remove id [SUNDANCE, 0x1021] net: caif: spi: fix potential NULL dereference ath9k_htc: Avoid setting QoS control for non-QoS frames net: zero kobject in rx_queue_release net: Fix duplicate volatile warning. MAINTAINERS: Add stmmac maintainer bonding: fix a race in IGMP handling cfg80211: fix can_beacon_sec_chan, reenable HT40 gianfar: fix signedness issue net: bnx2x: fix error value sign 8139cp: fix checksum broken r8169: fix checksum broken rds: Integer overflow in RDS cmsg handling ...
2010-11-18MAINTAINERS: update documentation entriesRandy Dunlap
Update kernel-doc and Documentation maintainers info. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-18MAINTAINERS: Add stmmac maintainerGiuseppe Cavallaro
Add STMMAC to the list of supported Ethernet drivers and myself as maintainer. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17MAINTAINERS: Add fbdev patchwork entry, tidy up file patterns.Paul Mundt
Now that the patchwork queue is up, add it in. While we're at it, fix up the file patterns, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-15Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: fsl-diu-fb: drop dead ioctl define MAINTAINERS: Add an fbdev git tree entry. OMAP: DSS: Fix documentation regarding 'vram' kernel parameter OMAP: VRAM: Fix boot-time memory allocation OMAP: VRAM: improve VRAM error prints sisfb: limit POST memory test according to PCI resource length fbdev: sh_mobile_lcdc: use correct number of modes, when using the default fbdev: sh_mobile_lcdc: use the standard CEA-861 720p timing fbdev: sh_mobile_hdmi: properly clean up modedb on monitor unplug
2010-11-15Merge branches 'sh-fixes-for-linus' and 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: intc: Fix up build failure introduced by radix tree changes. MAINTAINERS: update the sh git tree entry. sh: clkfwk: fix up compiler warnings. sh: intc: Fix up initializers for gcc 4.5. rtc: rtc-sh - fix a memory leak * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: ARM: mach-shmobile: ap4evb: add fsib 44100Hz rate MAINTAINERS: update the ARM SH-Mobile git tree entry. ARM: mach-shmobile: ap4evb: Mark NOR boot loader partitions read-only. ARM: mach-shmobile: intc-sh7372: fix interrupt number
2010-11-15Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh/urgent
2010-11-15MAINTAINERS: Add an fbdev git tree entry.Paul Mundt
Now that there's an fbdev git tree (this is also what is pulled in to -next), stub it in to the MAINTAINERS entry. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-12Merge branch 'staging-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (38 commits) Revert "staging: tidspbridge: replace iommu custom for opensource implementation" Revert "staging: tidspbridge - move shared memory iommu maps to tiomap3430.c" Revert "staging: tidspbridge - rename bridge_brd_mem_map/unmap to a proper name" Revert "staging: tidspbridge - remove custom mmu code from tiomap3430.c" Revert "staging: tidspbridge - fix mmufault support" Revert "staging: tidspbridge - remove hw directory" Revert "staging: tidspbridge - move all iommu related code to a new file" Revert "staging: tidspbridge: remove dw_dmmu_base from cfg_hostres struct" Revert "staging: tidspbridge - remove reserved memory clean up" Revert "staging: tidspbridge - deprecate reserve/unreserve_memory funtions" Revert "staging: tidspbridge - remove dmm custom module" Revert "staging: tidspbridge - update Kconfig to select IOMMU module" staging: tidspbridge: hardcode SCM macros while fix is upstreamed Staging: keucr driver: fix uninitialized variable & proper memset length omap: dsp: remove shm from normal memory Staging: wlan-ng: Fix wrong #ifdef #endif sequence Staging: Update parameters for cfg80211 key management operation Staging: ath6kl: Fix pointer casts on 64-bit architectures Staging: batman-adv: suppress false warning when changing the mac address Staging: batman-adv: fix interface alternating and bonding reggression ...
2010-11-12Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (28 commits) Revert "USB: xhci: Use GFP_ATOMIC under spin_lock" USB: ohci-jz4740: Fix spelling in MODULE_ALIAS UWB: Return UWB_RSV_ALLOC_NOT_FOUND rather than crashing on NULL dereference if kzalloc fails usb: core: fix information leak to userland usb: misc: iowarrior: fix information leak to userland usb: misc: sisusbvga: fix information leak to userland usb: subtle increased memory usage in u_serial USB: option: fix when the driver is loaded incorrectly for some Huawei devices. USB: xhci: Use GFP_ATOMIC under spin_lock usb: gadget: goku_udc: add registered flag bit, fixing build USB: ehci/mxc: compile fix USB: Fix FSL USB driver on non Open Firmware systems USB: the development of the usb tree is now in git usb: musb: fail unaligned DMA transfers on v1.8 and above USB: ftdi_sio: add device IDs for Milkymist One JTAG/serial usb.h: fix ioctl kernel-doc info usb: musb: gadget: kill duplicate code in musb_gadget_queue() usb: musb: Fix handling of spurious SESSREQ usb: musb: fix kernel oops when loading musb_hdrc module for the 2nd time USB: musb: blackfin: push clkin value to platform resources ...
2010-11-12Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: n_gsm: Fix length handling n_gsm: Copy n2 over when configuring via ioctl interface serial: bfin_5xx: grab port lock before making port termios changes serial: bfin_5xx: disable CON_PRINTBUFFER for consoles serial: bfin_5xx: remove redundant SSYNC to improve TX speed serial: bfin_5xx: always include DMA headers vcs: make proper usage of the poll flags amiserial: Remove unused variable icount 8250: Fix tcsetattr to avoid ioctl(TIOCMIWAIT) hang tty_ldisc: Fix BUG() on hangup TTY: restore tty_ldisc_wait_idle SERIAL: blacklist si3052 chip drivers/serial/bfin_5xx.c: Fix line continuation defects tty: prevent DOS in the flush_to_ldisc 8250: add support for Kouwell KW-L221N-2 nozomi: Fix warning from the previous TIOCGCOUNT changes tty: fix warning in synclink driver tty: Fix formatting in tty.h tty: the development tree is now done in git
2010-11-11MAINTAINERS: Mark XEN lists as moderatedJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-11-10MAINTAINERS: update the ARM SH-Mobile git tree entry.Paul Mundt
Reflect the recent tree restructuring. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-10MAINTAINERS: update the sh git tree entry.Paul Mundt
2010-11-09tty: the development tree is now done in gitGreg Kroah-Hartman
So properly mark it as such in the MAINTAINERS file. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-09Staging: the MAINTAINERS git location was incorrectGreg Kroah-Hartman
The tree has moved to "staging-2.6" not "staging-next-2.6" as all of the staging development is now done in git, not just for the next tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-09driver core: the development tree has switched to gitGreg Kroah-Hartman
So change the MAINTAINERS file to show where the tree now is at. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-09USB: the development of the usb tree is now in gitGreg Kroah-Hartman
So change the MAINTAINERS file to properly reflect this. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-08MAINTAINERS: Update mailing list name for Xen pieces.Konrad Rzeszutek Wilk
While the 'xen-devel@lists.xen.org' is more apt, it is not yet ready. Revert the name back to the old lists.xensource.com for right now. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-11-02MAINTAINERS: add drivers/char/hvc_tile.c as maintained by tileChris Metcalf
2010-11-01Merge branch 'for-linus' of git://www.jni.nu/crisLinus Torvalds
* 'for-linus' of git://www.jni.nu/cris: CRIS: Add paths for CRISv10 serial driver CRIS: Fix RS485 delay handling. Add missing "struct" to in sizeof.
2010-11-01CRIS: Add paths for CRISv10 serial driverJesper Nilsson
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2010-10-28Merge branch 'stable/xen-pcifront-0.8.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm * 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: register xen pci notifier xen: initialize cpu masks for pv guests in xen_smp_init xen: add a missing #include to arch/x86/pci/xen.c xen: mask the MTRR feature from the cpuid xen: make hvc_xen console work for dom0. xen: add the direct mapping area for ISA bus access xen: Initialize xenbus for dom0. xen: use vcpu_ops to setup cpu masks xen: map a dummy page for local apic and ioapic in xen_set_fixmap xen: remap MSIs into pirqs when running as initial domain xen: remap GSIs as pirqs when running as initial domain xen: introduce XEN_DOM0 as a silent option xen: map MSIs into pirqs xen: support GSI -> pirq remapping in PV on HVM guests xen: add xen hvm acpi_register_gsi variant acpi: use indirect call to register gsi in different modes xen: implement xen_hvm_register_pirq xen: get the maximum number of pirqs from xen xen: support pirq != irq * 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits) X86/PCI: Remove the dependency on isapnp_disable. xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright. x86: xen: Sanitse irq handling (part two) swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it. MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer. xen/pci: Request ACS when Xen-SWIOTLB is activated. xen-pcifront: Xen PCI frontend driver. xenbus: prevent warnings on unhandled enumeration values xenbus: Xen paravirtualised PCI hotplug support. xen/x86/PCI: Add support for the Xen PCI subsystem x86: Introduce x86_msi_ops msi: Introduce default_[teardown|setup]_msi_irqs with fallback. x86/PCI: Export pci_walk_bus function. x86/PCI: make sure _PAGE_IOMAP it set on pci mappings x86/PCI: Clean up pci_cache_line_size xen: fix shared irq device passthrough xen: Provide a variant of xen_poll_irq with timeout. xen: Find an unbound irq number in reverse order (high to low). xen: statically initialize cpu_evtchn_mask_p ... Fix up trivial conflicts in drivers/pci/Makefile
2010-10-28Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (39 commits) Revert "namespace: add source file location exceptions" Coccinelle: Add contextual message Coccinelle: Fix documentation Coccinelle: Find doubled arguments to boolean or bit operators. Coccinelle: Find nested lock+irqsave functions that use the same flags variables. namespace: add source file location exceptions scripts/extract-ikconfig: add support for bzip2, lzma and lzo kbuild: check return value of asprintf() scripts/namespace.pl: improve to get more correct results scripts/namespace.pl: some bug fixes scripts/namespace.pl: update file exclusion list scripts/namespace.pl: fix wrong source path Coccinelle: Use the -no_show_diff option for org and report mode Coccinelle: Add a new mode named 'chain' Coccinelle: Use new comment format to explain kfree.cocci Coccinelle: Improve user information with a new kind of comment Coccinelle: Update documentation MAINTAINERS: Coccinelle: Update email address Documentation/kbuild: modules.txt cleanup Documentation/kbuild: major edit of modules.txt sections 5-8 ...
2010-10-28Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (68 commits) hwmon: (it87) Add support for the IT8721F/IT8758E hwmon: (it87) Move conversion functions hwmon: Remove many EXPERIMENTAL flags hwmon: (lm85) Add support for ADT7468 high-frequency PWM mode hwmon: (lm85) Document the ADT7468 as supported hwmon: (lm85) Fix ADT7468 frequency table hwmon: I2C addresses are constant Move ams driver to macintosh hwmon: (pcf8591) Don't attempt to detect devices hwmon: (pcf8591) Register as a hwmon device hwmon: (w83795) Use standard attributes for chassis intrusion hwmon: (w83795) Exclude fan control feature by default hwmon: (w83795) Add myself as co-author and maintainer hwmon: (w83795) More style cleanups hwmon: (w83795) Fix LSB reading of voltage limits hwmon: (w83795) Use dev_get_drvdata() where possible hwmon: (w83795) Delay reading pwm config registers hwmon: (w83795) Delay reading limit registers hwmon: (w83795) Move register reads to dedicated functions hwmon: (w83795) Pack similar register reads ...
2010-10-28Move ams driver to macintoshJean Delvare
The ams driver isn't a hardware monitoring driver, so it shouldn't live under driver/hwmon. drivers/macintosh seems much more appropriate, as the driver is only useful on PowerBooks and iBooks. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Stelian Pop <stelian@popies.net> Cc: Michael Hanselmann <linux-kernel@hansmi.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca>
2010-10-28hwmon: (w83795) Add myself as co-author and maintainerJean Delvare
I've made so many changes to the w83795 driver that it's only fair to list myself as a co-author. I'll also maintain the driver for some time. There's more work needed on the driver for sure. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
