path: root/MAINTAINERS
2007-07-15Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: git-battery vs git-acpi Power supply class and drivers: remove non obligatory return statements pda_power: clean up irq, timer MAINTAINERS: Add maintainers for power supply subsystem and drivers Fixed up trivial conflict in drivers/w1/slaves/w1_ds2760.c manually
2007-07-15MAINTAINERS: Add maintainers for power supply subsystem and driversAnton Vorontsov
Signed-off-by: Anton Vorontsov <cbou@mail.ru> Acked-by: David Woodhouse <dwmw2@infradead.org>
2007-07-14[NET]: Add macvlan driverPatrick McHardy
Add macvlan driver, which allows to create virtual ethernet devices based on MAC address. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (149 commits) USB: ohci-pnx4008: Remove unnecessary cast of return value of kzalloc USB: additions to the quirk list usb-storage: implement autosuspend USB: cdc-acm: add new device id to option driver USB: goku_udc trivial cleanups USB: usb gadget stack can now -DDEBUG with Kconfig usb gadget stack: remove usb_ep_*_buffer(), part 2 usb gadget stack: remove usb_ep_*_buffer(), part 1 USB: pxa2xx_udc -- cleanups, mostly removing dma hooks USB: pxa2xx_udc: use generic gpio layer USB: quirk for samsung printer USB: usb/dma doc updates USB: drivers/usb/storage/unusual_devs.h whitespace cleanup USB: remove Makefile reference to obsolete OHCI_AT91 USB: io_*: remove bogus termios no change checks USB: mos7720: remove bogus no termios change check USB: visor and whiteheat: remove bogus termios change checks USB: pl2303: remove bogus checks and fix speed support to use tty_get_baud_rate() USB: mos7840.c: turn this into a serial driver USB: make the usb_device numa_node get assigned from controller ...
2007-07-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (76 commits) IB: Update MAINTAINERS with Hal's new email address IB/mlx4: Implement query SRQ IB/mlx4: Implement query QP IB/cm: Send no match if a SIDR REQ does not match a listen IB/cm: Fix handling of duplicate SIDR REQs IB/cm: cm_msgs.h should include ib_cm.h IB/cm: Include HCA ACK delay in local ACK timeout IB/cm: Use spin_lock_irq() instead of spin_lock_irqsave() when possible IB/sa: Make sure SA queries use default P_Key IPoIB: Recycle loopback skbs instead of freeing and reallocating IB/mthca: Replace memset(<addr>, 0, PAGE_SIZE) with clear_page(<addr>) IPoIB/cm: Fix warning if IPV6 is not enabled IB/core: Take sizeof the correct pointer when calling kmalloc() IB/ehca: Improve latency by unlocking after triggering the hardware IB/ehca: Notify consumers of LID/PKEY/SM changes after nondisruptive events IB/ehca: Return QP pointer in poll_cq() IB/ehca: Change idr spinlocks into rwlocks IB/ehca: Refactor sync between completions and destroy_cq using atomic_t IB/ehca: Lock renaming, static initializers IB/ehca: Report RDMA atomic attributes in query_qp() ...
2007-07-12USB: Pete's taking over usblpPete Zaitcev
Vojtech agreed to pass usblp over to me, so if you find bugs don't bug him. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12IB: Update MAINTAINERS with Hal's new email addressRoland Dreier
Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] Hand off AGP maintainence.
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-12Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (183 commits) [TG3]: Update version to 3.78. [TG3]: Add missing NVRAM strapping. [TG3]: Enable auto MDI. [TG3]: Fix the polarity bit. [TG3]: Fix irq_sync race condition. [NET_SCHED]: ematch: module autoloading [TCP]: tcp probe wraparound handling and other changes [RTNETLINK]: rtnl_link: allow specifying initial device address [RTNETLINK]: rtnl_link API simplification [VLAN]: Fix MAC address handling [ETH]: Validate address in eth_mac_addr [NET]: Fix races in net_rx_action vs netpoll. [AF_UNIX]: Rewrite garbage collector, fixes race. [NETFILTER]: {ip, nf}_conntrack_sctp: fix remotely triggerable NULL ptr dereference (CVE-2007-2876) [NET]: Make all initialized struct seq_operations const. [UDP]: Fix length check. [IPV6]: Remove unneeded pointer idev from addrconf_cleanup(). [DECNET]: Another unnecessary net/tcp.h inclusion in net/dn.h [IPV6]: Make IPV6_{RECV,2292}RTHDR boolean options. [IPV6]: Do not send RH0 anymore. ... Fixed up trivial conflict in Documentation/feature-removal-schedule.txt manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12x86 setup: MAINTAINERS: formally take responsibility for the i386 boot codeH. Peter Anvin
Change MAINTAINERS to formally take responsibility for the i386 boot code. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: remove cpqphp driver maintainerGreg Kroah-Hartman
I'm no longer maintaining this driver as I no longer have the hardware and I doubt anyone else does either. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10[L2TP]: Add PPPoL2TP maintainerJames Chapman
Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (40 commits) bonding/bond_main.c: make 2 functions static ps3: gigabit ethernet driver for PS3, take3 [netdrvr] Fix dependencies for ax88796 ne2k clone driver eHEA: Capability flag for DLPAR support Remove sk98lin ethernet driver. sunhme.c:quattro_pci_find() must be __devinit bonding / ipv6: no addrconf for slaves separately from master atl1: remove write-only var in tx handler macmace: use "unsigned long flags;" Cleanup usbnet_probe() return value handling netxen: deinline and sparse fix eeprom_93cx6: shorten pulse timing to match spec (bis) phylib: Add Marvell 88E1112 phy id phylib: cleanup marvell.c a bit AX88796 network driver IOC3: Switch to pci refcounting safe APIs e100: Fix Tyan motherboard e100 not receiving IPMI commands QE Ethernet driver writes to wrong register to mask interrupts rrunner.c:rr_init() must be __devinit tokenring/3c359.c:xl_init() must be __devinit ...
2007-07-10ps3: gigabit ethernet driver for PS3, take3Masakazu Mokuno
Hi, This is the third submission of the network driver for PS3. The differences from the previous one are: - renamed source file names so that their prefix can match with the module name - added cbe-oss-dev@ozlabs.org line for MAINTAINER file - changed some in copyright comments If there are no more comments, please apply for 2.6.23. Thank you -- Subject: PS3: Ethernet driver From: Masakazu Mokuno <mokuno@sm.sony.co.jp> Add Gigabit Ethernet support for the PS3 game console. The module will be called ps3_gelic. CC: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10Input: update MAINTAINERS to explicitly mention touchscreensRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-07-09IB: Update mailing list addressRoland Dreier
The InfiniBand / RDMA discussion list has moved. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09IB/ipath: Update MAINTAINERS entryArthur Jones
Bryan is no longer with QLogic and we now have a public git server and a public email alias for infinipath driver patches. And, as pointed out by Hal Rosenstock, the mailing list has changed as well. Signed-off-by: Arthur Jones <arthur.jones@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-09[AGPGART] Hand off AGP maintainence.Dave Jones
Most of the AGP changes recently have been done in lock-step with DRM updates, so it's probably easier to have airlied pushing AGP changes at the same time he does DRM updates. [Also remove my name from the boot messages. Cautionary tale to others: Never do this, when computers don't boot, people assume you're responsible even if 15 other subsystems initialised after yours. :-) ] Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-08[PATCH] Add rtl8187 wireless driverMichael Wu
This patch adds a mac80211 based wireless driver for the rtl8187 USB wireless card. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-06MAINTAINERS new kernel janitors mlmaximilian attems
davem kindly moved the list from osdl to vger. Signed-of-by: maximilian attems <max@stro.at> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-02Update MAINTAINERS for USB network devicesPeter Korsgaard
>>>>> "Greg" == Greg KH <greg@kroah.com> writes: Greg> Yeah, this is the cdc_acm driver that is still in the USB drivers/ Greg> directory tree as it is a USB class driver that shows up as a tty device Greg> to userspace. It should not be moved to the networking list unless no Greg> one minds that I never see any queries about it :) Ok, here's an updated patch: Questions regarding the USB network drivers should now go to netdev. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-19[XFS] Update the MAINTAINERS file entry for XFS - change git repo name.Tim Shimmin
Make the git repository bare and so give it the conventional .git suffix. Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-06-19Merge branch 'for-linus' of git://oss.sgi.com:8090/xfs/xfs-2.6 into for-linusTim Shimmin
2007-06-11[XFS] Update the MAINTAINERS file entry for XFS.Timothy Shimmin
Remove David Chatterton from XFS entry in MAINTAINERS file. Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-06-11Blackfin RTC drivers: update MAINTAINERS informationMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Alessandro Zummo <a.zummo@towertech.it>
2007-06-11Blackfin arch: fixup Blackfin MAINTIANERS team member listBryan Wu
2007-06-08MAINTAINERS: correctionsAlan Cox
The UFS entry was misformatted The NEC V850 links are all broken The Berkshire watchdog links are all broken Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08reiserfs: mailing list has movedJeff Mahoney
This patch changes MAINTAINERS to reflect the new location of the reiserfs development mailing list. The old list forwards to the new one. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-03NET: add MAINTAINERS entry for ucc_geth driverLi Yang
Signed-off-by: Li Yang <leoli@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-03Update tulip maintainer email addressValerie Henson
I've quit Intel and gone into business as a Linux consultant. Update my email address in MAINTAINERS. Signed-off-by: Valerie Henson <val@nmt.edu> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: Install firewire-constants.h and firewire-cdev.h for userspace. firewire: Change struct fw_cdev_iso_packet to not use bitfields. firewire: Implement suspend/resume PCI driver hooks. firewire: add to MAINTAINERS firewire: fw-sbp2: implement sysfs ieee1394_id ieee1394: sbp2: offer SAM-conforming target port ID in sysfs ieee1394: fix calculation of sysfs attribute "address"
2007-06-01prism54: MAINTAINERS updateLuis R. Rodriguez
Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01add a trivial patch style checkerAndy Whitcroft
We are seeing increasing levels of minor patch style violations in submissions to the mailing lists as well as making it into the tree. These detract from the quality of the submission and cause unnessary work for reviewers. As a first step package up the current state of the patch style checker and include it in the kernel tree. Add instructions suggesting running it on submissions. This adds version v0.01 of the checkpatch.pl script. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-31firewire: add to MAINTAINERSStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@redhat.com>
2007-05-29Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] megaraid_sas: intercept cmd timeout and throttle io [SCSI] fusion: Fix |/|| confusion [SCSI] aic94xx: asd_clear_nexus should fail if the cleared task does not complete [SCSI] aic7xxx: fix aicasm build failure with gcc-3.4.6 [SCSI] aacraid: apply commit config for reset_devices flag [SCSI] sd: fix refcounting regression in suspend/resume routines [SCSI] aacraid: fix panic on short Inquiry [SCSI] aacraid: Correct sa platform support. (Was: [Bug 8469] Bad EIP value on pentium3 SMP kernel-2.6.21.1) [SCSI] NCR53C9x: correct spelling mistake in deprecation notice [SCSI] tgt: fix a rdma indirect transfer error bug [SCSI] MegaRAID: Update MAINTAINERS email-id [SCSI] stex: minor cleanup and version update [SCSI] stex: fix reset recovery for console device [SCSI] stex: extend hard reset wait time [SCSI] stex: fix id mapping issue [SCSI] ipr: Proper return codes for eh_dev_reset for SATA devices [SCSI] zfcp: IO stall after deleting and path checker changes after reenabling zfcp devices [SCSI] zfcp: avoid clutter in erp_dbf
2007-05-24mmc: add maintainer for ARM Primecell controllerRussell King
Russell King handles this driver. Signed-off-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-24mmc: add maintainer for iMX MMC interfacePavel Pisa
Pavel Pisa takes on the role of administrating this driver. Signed-off-by: Pavel Pisa <ppisa@pikron.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-24mmc: Add maintainers for TI OMAP MMC interfaceSyed Khasim
Carlos Aguiar and Anderson Briglia are interested in making sure the driver works for existing boards as they have access to them, and Syed Khasim can make it work for new omaps (2430, 3430). Signed-off-by: Syed Khasim <x0khasim@ti.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-24mmc: mark unmaintained driversPierre Ossman
Most of the host controller drivers in the MMC layer lacks an official maintainer. Make sure this is mentioned in MAINTAINERS in case someone wants to pick up the ball. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-21LDM: Fix for Windows Vista dynamic disksAnton Altaparmakov
This fixes the LDM driver so that it works with Windows Vista dynamic disks which are subtly different to Windows 2000/XP ones. The patch was needed to get a Vista formatted dynamic disk to be recognized and parsed successfully. Thanks go to Chris Teachworth for the report and testing. Cc: Richard Russon <ldm@flatcap.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17parport: mailing list is subscribers-onlyRandy Dunlap
linux-parport is subscribers-only: Your mail to 'Linux-parport' with the subject Re: [QUESTION] parallel console configuration Is being held until the list moderator can review it for approval. The reason it is being held: Post by non-member to a members-only list Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-16[SCSI] MegaRAID: Update MAINTAINERS email-idSumant Patro
Update Maintainer email-id for MegaRAID SCSI drivers. Signed-off-by: Sumant Patro <sumant.patro@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-15Revert "MAINTAINERS: remove invalid list address for TPM"Stephen Rothwell
This reverts commit b6d1c9a44744224d83125a5a89c1a6cc4db27361. Others tell me that this address has worked for them, so I can only assume that I hit a glitch in the sourceforge mail system. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-14MAINTAINERS update.Dave Jones
I've not really 'maintained' this code for years, and others are doing a much more thorough job these days. Removing myself might stem some of the crazier emails I get. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12MAINTAINERS: remove invalid list address for TPMStephen Rothwell
This address bounces with "550 Unknown user". Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[ALSA] Fix alsa-devel ML addressTakashi Iwai
Fixed MAINTAINERS, alsa-devel ML is now subscribers-only. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-10Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] MTX-1 Watchdog driver [WATCHDOG] s3c2410_wdt - initialize watchdog irq resource [WATCHDOG] Kconfig menuconfig patch [WATCHDOG] pcwd.c: Port to the new device driver model [WATCHDOG] use mutex instead of semaphore in Berkshire USB-PC Watchdog driver [WATCHDOG] the scheduled removal of the i8xx_tco watchdog driver [WATCHDOG] Semi-typical watchdog bug re early misc_register() [WATCHDOG] add support for the w83627thf chipset.
2007-05-09Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (21 commits) [MTD] [CHIPS] Remove MTD_OBSOLETE_CHIPS (jedec, amd_flash, sharp) [MTD] Delete allegedly obsolete "bank_size" field of mtd_info. [MTD] Remove unnecessary user space check from mtd.h. [MTD] [MAPS] Remove flash maps for no longer supported 405LP boards [MTD] [MAPS] Fix missing printk() parameter in physmap_of.c MTD driver [MTD] [NAND] platform NAND driver: add driver [MTD] [NAND] platform NAND driver: update header [JFFS2] Simplify and clean up jffs2_add_tn_to_tree() some more. [JFFS2] Remove another bogus optimisation in jffs2_add_tn_to_tree() [JFFS2] Remove broken insert_point optimisation in jffs2_add_tn_to_tree() [JFFS2] Remember to calculate overlap on nodes which replace older nodes [JFFS2] Don't advance c->wbuf_ofs to next eraseblock after wbuf flush [MTD] [NAND] at91_nand.c: CMDLINE_PARTS support [MTD] [NAND] Tidy up handling of page number in nand_block_bad() [MTD] block2mtd_paramline[] mustn't be __initdata [MTD] [NAND] Support multiple chips in CAFÉ driver [MTD] [NAND] Rename cafe.c to cafe_nand.c and remove the multi-obj magic [MTD] [NAND] Use rslib for CAFÉ ECC [RSLIB] Support non-canonical GF representations [JFFS2] Remove dead file histo_mips.h ...
2007-05-09MAINTAINERS: Add cxacru website/mailing listSimon Arlott
Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@stusta.de>
