path: root/MAINTAINERS
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-06-01MAINTAINERS: take maintainership of the cpmac Ethernet driverFlorian Fainelli
This patch adds me as the maintainer of the CPMAC (AR7) Ethernet driver. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/scsi/fcoe/fcoe.c
2009-05-18can: Update MAINTAINERS and CREDITS fileWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-05Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix setting of oprofile cpu type powerpc: Update MPC5xxx and Xilinx Virtex maintainer entries powerpc adjust oprofile_cpu_type version 3
2009-05-02Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: Change repository in MAINTAINERS. ocfs2: Fix a missing credit when deleting from indexed directories. ocfs2/trivial: Remove unused variable in ocfs2_rename. ocfs2: Add missing iput() during error handling in ocfs2_dentry_attach_lock() ocfs2: Fix some printk() warnings. ocfs2: Fix 2 warning during ocfs2 make. ocfs2: Reserve 1 more cluster in expanding_inline_dir for indexed dir.
2009-05-02MAINTAINERS: add ptrace entryChristoph Hellwig
Add Roland and Oleg as formal ptrace maintainers, they've been doing the job for a while. Includes the file patterns requested by Joe. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02MAINTAINERS: Florian has movedFlorian Fainelli
I will finish school soon, so replace my student address with this one. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-01powerpc: Update MPC5xxx and Xilinx Virtex maintainer entriesGrant Likely
- Add git tree URLs - Drop Sylvain from the 5xxx maintainers list. He hasn't been active for a while now. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-30ocfs2: Change repository in MAINTAINERS.Joel Becker
The ocfs2.git repository is moving to my kernel.org account. Signed-off-by: Joel Becker <joel.becker@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com>
2009-04-28Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc/ps3: Fix build error on UP powerpc/cell: Select PCI for IBM_CELL_BLADE AND CELLEB powerpc: ppc32 needs elf_read_implies_exec() powerpc/86xx: Add device_type entry to soc for ppc9a powerpc/44x: Correct memory size calculation for denali-based boards maintainers: Fix PowerPC 4xx git tree powerpc: fix for long standing bug noticed by gcc 4.4.0 Revert "powerpc: Add support for early tlbilx opcode"
2009-04-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: MAINTAINERS: update IDE entry palm_bk3710: palm_bk3710_udmatimings[] CodingStyle fixup palm_bk3710: those registers/bitfields don't exist mediabay: fix build for CONFIG_BLOCK=n ide: Stop disks on reboot for laptop which cuts power ide-cd: fix kernel crash on hppa regression palm_bk3710: UDMA performance fix
2009-04-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (94 commits) netfilter: ctnetlink: fix gcc warning during compilation net/netrom: Fix socket locking netlabel: Always remove the correct address selector ucc_geth.c: Fix upsmr setting in RMII mode 8139too: fix HW initial flow af_iucv: Fix race when queuing incoming iucv messages af_iucv: Test additional sk states in iucv_sock_shutdown af_iucv: Reject incoming msgs if RECV_SHUTDOWN is set af_iucv: fix oops in iucv_sock_recvmsg() for MSG_PEEK flag af_iucv: consider state IUCV_CLOSING when closing a socket iwlwifi: DMA fixes iwlwifi: add debugging for TX path mwl8: fix build warning. mac80211: fix alignment calculation bug mac80211: do not print WARN if config interface iwl3945: use cancel_delayed_work_sync to cancel rfkill_poll iwlwifi: fix EEPROM validation mask to include OTP only devices atmel: fix netdev ops conversion pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCM mlx4_en: Fix cleanup if workqueue create in mlx4_en_add() fails ...
2009-04-24Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Fix modular build of ide-pmac when mediabay is built in powerpc/pasemi: Fix build error on UP powerpc: Make macintosh/mediabay driver depend on CONFIG_BLOCK maintainers: Fix PS3 patterns powerpc/ps3: Fix CONFIG_PS3_FLASH=n build warning powerpc/32: Don't clobber personality flags on exec powerpc: Fix crash on CPU hotplug powerpc/85xx: Remove defconfigs that mpc85xx_{smp_}defconfig cover powerpc/85xx: Added SMP defconfig powerpc/85xx: Enabled a bunch of FSL specific drivers/options powerpc/85xx: Updated generic mpc85xx_defconfig powerpc: don't disable SATA interrupts on Freescale MPC8610 HPCD fsl_rio: Pass the proper device to dma mapping routines powerpc: Fix of_node_put() exit path in of_irq_map_one() powerpc/5200: defconfig updates powerpc/5200: Add FLASH nodes to lite5200 device tree powerpc/device-tree: Document MTD nodes with multiple "reg" tuples powerpc/of-device-tree: Factor MTD physmap bindings out of booting-without-of powerpc/5200: Bring the legacy fsl_spi_platform_data hooks back
2009-04-24maintainers: Fix PowerPC 4xx git treeJosh Boyer
Update the git tree URL for the PowerPC 4xx git tree. Reported-by: Denis ChengRq <crquan@gmail.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-04-23MAINTAINERS: update IDE entryBartlomiej Zolnierkiewicz
By a popular demand quilt tree was replaced by a git one. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-22net/ps3: Update maintainerMasakazu Mokuno
Update the MAINTAINERS entry for PS3 NETWORK SUPPORT. CC: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22ath9k: Update maintainers for ath9kLuis R. Rodriguez
This has been the case really, we just forgot to update it. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22maintainers: Fix PS3 patternsGeoff Levand
Correct the MAINTAINERS file patterns for PS3. Removes some PS3 patterns that were under 'CELL BROADBAND ENGINE ARCHITECTURE', and adds missing PS3 sound and RTC driver patterns. CC: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-21MAINTAINERS: add a more searchable string for the H8300 architecture.Robert P. J. Day
Add a parenthesized string of "H8300" for more convenient searchability in the MAINTAINERS file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: add Matt Mackall to embedded maintainersMatt Mackall
Impact: make more work for myself Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: update KMEMTRACE pattern after file renameJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21MAINTAINERS: remove include/asm-*/suspend* file patternsJoe Perches
There are no more arches with suspend support using these directories. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2009-04-20FS-Cache: Add MAINTAINERS record for FS-Cache and CacheFilesDavid Howells
Add MAINTAINERS record for FS-Cache and CacheFiles. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-19Merge branch 'fix/misc' into for-linusTakashi Iwai
* fix/misc: ALSA: MAINTAINERS - Update SOUND ALSA: emu10k1 - off by 1 in snd_emu10k1_wait()
2009-04-17Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (48 commits) [ARM] S3C24XX: ADC: Check pending queue before freeing adc client [ARM] S3C: Fix ADC driver sparse warning [ARM] Osiris: Fix double initialisation in machine block [ARM] Anubis: Fix sparse warnings for items that should be static [ARM] JIVE: Fix sparse warnings about items which should be static [ARM] S3C: Fix sparse warning from missing 's3c_device_hwmon' [ARM] S3C24XX: Fix sparse error in gpiolib.c [ARM] 5455/1: Fix IRQ noise from VIC code [ARM] 5454/1: ep93xx_eth: fix sparse warnings [ARM] remove .gitignore from include/asm-arm Update MAINTAINERS mxc defconfig updates mx31ads: Mark as having full regulatoion constraints with 1133-EV1 board mx31ads: Depend on all the WM8350 core dependencies for WM1133-EV1 board Fix ifdef in plat-mxc/irc.c MX1ADS: remove I2C ifdefs qong: remove AIPS[12] mappings from machine-specific iotable mx31ads: imoux pins should be passed in as unsigned int MXC: remove orphan imx_init_uart() definition mx31: pin definition for csi ...
2009-04-17ALSA: MAINTAINERS - Update SOUNDJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-16MAINTAINERS - Update NETWORKING W: url and standardize T: git urlJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16MAINTAINERS - Add section NETWORKING DRIVERSJoe Perches
2009-04-16Merge branch 'master' of ↵David S. Miller
2009-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (64 commits) phylib: Fix delay argument of schedule_delayed_work NET/ixgbe: Fix powering off during shutdown NET/e1000e: Fix powering off during shutdown NET/e1000: Fix powering off during shutdown packet: avoid warnings when high-order page allocation fails gianfar: stop send queue before resetting gianfar myr10ge: again fix lro_gen_skb() alignment declance: convert to net_device_ops bfin_mac: convert to net_device_ops au1000: convert to net_device_ops atarilance: convert to net_device_ops a2065: convert to net_device_ops ixgbe: update real_num_tx_queues on changing num_rx_queues ixgbe: fix tx queue index Revert "rose: zero length frame filtering in af_rose.c" sfc: Use correct macro to set event bitfield sfc: Match calls to netif_napi_add() and netif_napi_del() bonding: Remove debug printk e1000/e1000: fix compile warning ehea: Fix incomplete conversion to net_device_ops ...
2009-04-16Update MAINTAINERSRussell King
Update rmk's email address, and expand on what he's responsible for. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-14Merge branch 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Add missing FILE tag to MAINTAINERS microblaze: remove duplicated #include's microblaze: struct device - replace bus_id with dev_name() microblaze: Simplify copy_thread() microblaze: Add TIMESTAMPING constants to socket.h microblaze: Add missing empty ftrace.h file microblaze: Fix problem with removing zero length files
2009-04-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Add in PCI bus for DMA API debugging. sh: Pre-allocate a reasonable number of DMA debug entries. sh: sh7786: modify usb setup timeout judgment bug. MAINTAINERS: Update sh architecture file patterns. sh: ap325: use edge control for ov772x camera sh: Plug in support for ARCH=sh64 using sh SRCARCH. sh: urquell: Fix up address mapping in board comments. sh: Add support for DMA API debugging. sh: Provide cpumask_of_pcibus() to fix NUMA build. sh: urquell: Add board comment sh: wire up sys_preadv/sys_pwritev() syscalls. sh: sh7785lcr: fix PCI address map for 32-bit mode sh: intc: Added resume from hibernation support to the intc
2009-04-14microblaze: Add missing FILE tag to MAINTAINERSMichal Simek
2009-04-13sgi-xpc: update SGI XP/XPC/XPNET maintainerRobin Holt
Dean has moved on to other work. His responsibilities for XP/XPC/XPNET have been handed to me. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13MAINTAINERS: bluesmoke-devel list is moderated for non-subscribersJean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13MAINTAINERS: fix Andreas's email addressRandy Dunlap
Correct typo in email address. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13MAINTAINERS: switch maintainer of the hso driverJan Dumon
Since Denis is no longer working for Option, I will maintain the driver from now on. Signed-off-by: Jan Dumon <j.dumon@option.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: MAINTAINERS
2009-04-14MAINTAINERS: Update sh architecture file patterns.Paul Mundt
Fill in missing entries for drivers/sh/ and Documentation/sh/. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-13Merge branch 'gm_20090410' of git://repo.or.cz/linux-2.6/trivial-modsLinus Torvalds
* 'gm_20090410' of git://repo.or.cz/linux-2.6/trivial-mods: MAINTAINERS - Update MN10300 patterns MAINTAINERS - Update frv arch patterns scripts/get_maintainer.pl - Allow multiple files on command line MAINTAINERS - Update Freescale sound patterns MAINTAINERS - Add additional patterns MAINTAINERS - Add missing "/" to some pattern directories MAINTAINERS - Update DRIVER CORE patterns MAINTAINERS - Update M68K patterns MAINTAINERS - Coalesce sections "DVB" and "Video for Linux" MAINTAINERS - Remove cyblafb frame buffer no longer in tree MAINTAINERS - Remove x86/Voyager no longer in tree MAINTAINERS - Update FPU Emulator contact address and web page MAINTAINERS - i2c_tiny_usb T: should be W: MAINTAINERS - Add Linus Torvalds' git MAINTAINERS - standardize "T: git urls" MAINTAINERS - Remove HP Fibre Channel HBA no longer in tree MAINTAINERS - Standardize style MAINTAINERS - Add file patterns Add scripts/get_maintainer.pl Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Andrew Morton <akpm@linux-foundation.org>
2009-04-13Merge branch 'for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (60 commits) microblaze_v8: Add MAINTAINERS fragment microblaze_v8: Uartlite for Microblaze microblaze_v8: Makefiles for Microblaze cpu microblaze_v8: Kconfig patches microblaze_v8: Interrupt handling and timer support microblaze_v8: syscalls.h microblaze_v8: pci headers microblaze_v8: Kbuild file microblaze_v8: string.h thread_info.h microblaze_v8: unistd.h microblaze_v8: fcntl.h sockios.h ucontext.h microblaze_v8: pool.h socket.h microblaze_v8: device.h param.h topology.h microblaze_v8: headers files entry.h current.h mman.h registers.h sembuf.h microblaze_v8: namei.h microblaze_v8: gpio.h, serial.h microblaze_v8: headers simple files - empty or redirect to asm-generic microblaze_v8: sigcontext.h siginfo.h microblaze_v8: termbits.h termios.h microblaze_v8: stats headers ...
2009-04-11net: Update maintainersBen Hutchings
Essentially all networking changes go through David Miller. Jeff Garzik no longer handles device drivers separately. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-10MAINTAINERS - Update MN10300 patternsJoe Perches
2009-04-10MAINTAINERS - Update frv arch patternsJoe Perches
2009-04-10MAINTAINERS - Update Freescale sound patternsJoe Perches
2009-04-10MAINTAINERS - Add additional patternsJoe Perches
for sections: FINTEK F75375S HARDWARE MONITOR PCA9532 LED DRIVER S390 ZCRYPT DRIVER SERIAL ATA (SATA) SUBSYSTEM TMIO MMC DRIVER Signed-off-by: Joe Perches <joe@perches.com>
2009-04-10MAINTAINERS - Add missing "/" to some pattern directoriesJoe Perches
