path: root/MAINTAINERS
2006-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (21 commits) BUG_ON() Conversion in drivers/video/ BUG_ON() Conversion in drivers/parisc/ BUG_ON() Conversion in drivers/block/ BUG_ON() Conversion in sound/sparc/cs4231.c BUG_ON() Conversion in drivers/s390/block/dasd.c BUG_ON() Conversion in lib/swiotlb.c BUG_ON() Conversion in kernel/cpu.c BUG_ON() Conversion in ipc/msg.c BUG_ON() Conversion in block/elevator.c BUG_ON() Conversion in fs/coda/ BUG_ON() Conversion in fs/binfmt_elf_fdpic.c BUG_ON() Conversion in input/serio/hil_mlc.c BUG_ON() Conversion in md/dm-hw-handler.c BUG_ON() Conversion in md/bitmap.c The comment describing how MS_ASYNC works in msync.c is confusing rcu: undeclared variable used in documentation fix typos "wich" -> "which" typo patch for fs/ufs/super.c Fix simple typos tabify drivers/char/Makefile ...
2006-03-25[PATCH] MAINTAINERS: remove dead URLJohannes Stezenbach
http://mpeg.openprojects.net/ doesn't exist Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] remove dead address from maintainers list.Dave Jones
Mailing this address gives.. Sorry your message to max_mk@yahoo.com cannot be delivered. This account has been disabled or discontinued [#102]. mta129.mail.re4.yahoo.com) Signed-off-by: Dave Jones <davej@redhat.com> Cc: <maxk@qualcomm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] remove MAINTAINERS entry for rtlinuxAdrian Bunk
It's already big enough and there's no reason to list maintainers of external patches. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] 9p: fix name consistency problemsEric Van Hensbergen
There were a number of conflicting naming schemes used in the v9fs project. The directory was fs/9p, but MAINTAINERS and Documentation referred to v9fs. The module name itself was 9p2000, and the file system type was 9P. This patch attempts to clean that up, changing all references to 9p in order to match the directory name. We'll also start using 9p instead of v9fs as our patch prefix. There is also a minor consistency cleanup in the options changing the name option to uname in order to more closely match the Plan 9 options. Signed-off-by: Eric Van Hensbergevan <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24Re-alphabetize a couple MAINTANTER entries.Jim Cromie
2006-03-24[PATCH] mmc: Secure Digital Host Controller Interface driverPierre Ossman
Driver for the Secure Digital Host Controller Interface specification. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (78 commits) [PATCH] powerpc: Add FSL SEC node to documentation [PATCH] macintosh: tidy-up driver_register() return values [PATCH] powerpc: tidy-up of_register_driver()/driver_register() return values [PATCH] powerpc: via-pmu warning fix [PATCH] macintosh: cleanup the use of i2c headers [PATCH] powerpc: dont allow old RTC to be selected [PATCH] powerpc: make powerbook_sleep_grackle static [PATCH] powerpc: Fix warning in add_memory [PATCH] powerpc: update mailing list addresses [PATCH] powerpc: Remove calculation of io hole [PATCH] powerpc: iseries: Add bootargs to /chosen [PATCH] powerpc: iseries: Add /system-id, /model and /compatible [PATCH] powerpc: Add strne2a() to convert a string from EBCDIC to ASCII [PATCH] powerpc: iseries: Make more stuff static in platforms/iseries/mf.c [PATCH] powerpc: iseries: Remove pointless iSeries_(restart|power_off|halt) [PATCH] powerpc: iseries: mf related cleanups [PATCH] powerpc: Replace platform_is_lpar() with a firmware feature [PATCH] powerpc: trivial: Cleanup whitespace in cputable.h [PATCH] powerpc: Remove unused iommu_off logic from pSeries_init_early() [PATCH] powerpc: Unconfuse htab_bolt_mapping() callers ...
2006-03-22Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (138 commits) [SCSI] libata: implement minimal transport template for ->eh_timed_out [SCSI] eliminate rphy allocation in favour of expander/end device allocation [SCSI] convert mptsas over to end_device/expander allocations [SCSI] allow displaying and setting of cache type via sysfs [SCSI] add scsi_mode_select to scsi_lib.c [SCSI] 3ware 9000 add big endian support [SCSI] qla2xxx: update MAINTAINERS [SCSI] scsi: move target_destroy call [SCSI] fusion - bump version [SCSI] fusion - expander hotplug suport in mptsas module [SCSI] fusion - exposing raid components in mptsas [SCSI] fusion - memory leak, and initializing fields [SCSI] fusion - exclosure misspelled [SCSI] fusion - cleanup mptsas event handling functions [SCSI] fusion - removing target_id/bus_id from the VirtDevice structure [SCSI] fusion - static fix's [SCSI] fusion - move some debug firmware event debug msgs to verbose level [SCSI] fusion - loginfo header update [SCSI] add scsi_reprobe_device [SCSI] megaraid_sas: fix extended timeout handling ...
2006-03-22[PATCH] powerpc: update mailing list addressesStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-21Merge branch 'e1000-fixes' of git://198.78.49.142/~jbrandeb/linux-2.6Jeff Garzik
2006-03-21Merge ../linux-2.6James Bottomley
2006-03-21Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (81 commits) [PATCH] USB: omninet: fix up debugging comments [PATCH] USB serial: add navman driver [PATCH] USB: Fix irda-usb use after use [PATCH] USB: rtl8150 small fix [PATCH] USB: ftdi_sio: add Icom ID1 USB product and vendor ids [PATCH] USB: cp2101: add new device IDs [PATCH] USB: fix check_ctrlrecip to allow control transfers in state ADDRESS [PATCH] USB: vicam.c: fix a NULL pointer dereference [PATCH] USB: ZC0301 driver bugfix [PATCH] USB: add support for Creativelabs Silvercrest USB keyboard [PATCH] USB: storage: new unusual_devs.h entry: Mitsumi 7in1 Card Reader [PATCH] USB: storage: unusual_devs.h entry 0420:0001 [PATCH] USB: storage: another unusual_devs.h entry [PATCH] USB: storage: sandisk unusual_devices entry [PATCH] USB: fix initdata issue in isp116x-hcd [PATCH] USB: usbcore: usb_set_configuration oops (NULL ptr dereference) [PATCH] USB: usbcore: Don't assume a USB configuration includes any interfaces [PATCH] USB: ub 03 drop stall clearing [PATCH] USB: ub 02 remove diag [PATCH] USB: ub 01 remove first_open ...
2006-03-20[PATCH] USB: Add ZC0301 Video4Linux2 driverLuca Risolia
This patch adds a Video4Linux2 driver for ZC0301 Image Processor and Control Chip. Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20MAINTAINERS: remove the LANMEDIA entryAdrian Bunk
Remove the maintainers entry pointing to a no longer existing domain. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-18Update MAINTAINERS entry for MIPS.Ralf Baechle
2006-03-14[SCSI] qla2xxx: update MAINTAINERSAndrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14e100/e1000/ixgb: update MAINTAINERS to current developersJesse Brandeburg
Remove Ganesh, add Jeff and Jesse Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
2006-03-11[PATCH] LSM mail list has movedChris Wright
LSM mail list has moved. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] update email addressChris Wright
Update email address. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03V4L/DVB (3300a): Removing personal email from DVB maintainersMauro Carvalho Chehab
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-11[PATCH] s390: update maintainers fileHeiko Carstens
Update URL for s390 and add maintainers for s390 networking and zfcp driver. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/i2c-2.6Linus Torvalds
2006-02-06[PATCH] hwmon: New f71805f driverJean Delvare
This is my f71805f hardware monitoring driver ported from lm_sensors to Linux 2.6. This new driver differs from the other hardware monitoring drivers in that it is implemented as a platform driver. This might not be optimal yet (we would probably need a generic infrastructure and bus type for Super-I/O logical devices) but it is certainly much better than the i2c-isa solution. Note that this driver requires lm_sensors CVS. I hope to get it released as 2.10.0 soon. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06Merge branch 'origin'Mauro Carvalho Chehab
2006-02-05[PATCH] MAINTAINERS/CREDITS: Update SELinux contact infoStephen Smalley
Update my contact info. Please apply. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03Merge branch 'upstream-linus' of git://oss.oracle.com/home/sourcebo/git/ocfs2Linus Torvalds
2006-02-03configfs: Clean up MAINTAINERS entryJoel Becker
Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-03[PATCH] parport: remove dead address in MAINTAINERSArnaud Giersch
Remove dead address for David Campbell in MAINTAINERS. Signed-off-by: Arnaud Giersch <arnaud.giersch@free.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[PATCH] USB: Add ET61X[12]51 Video4Linux2 driverLuca Risolia
This patch adds a Video4Linux2 driver giving support to ET61X151 and ET61X251 PC Camera Controllers made by Etoms Electronics. Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-27V4L/DVB (3453a): Alters MAINTAINERS file to point to newer v4l-dvb emailMauro Carvalho Chehab
- V4L/DVB Maintainers list changed. This patch alters the email to the new address. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-By: Johannes Stezenbach <js@linuxtv.org>
2006-01-24[IA64] sn2 maintainer update (Jes Sorensen)Greg Edwards
We lured Jes to the dark side, and he's going to take over as the sn2 maintainer. His experience and thoroughness will serve him well here. Signed-off-by: Greg Edwards <edwardsg@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-18[PATCH] EDAC: core EDAC support codeAlan Cox
This is a subset of the bluesmoke project core code, stripped of the NMI work which isn't ready to merge and some of the "interesting" proc functionality that needs reworking or just has no place in kernel. It requires no core kernel changes except the added scrub functions already posted. The goal is to merge further functionality only after the core code is accepted and proven in the base kernel, and only at the point the upstream extras are really ready to merge. From: doug thompson <norsk5@xmission.com> This converts EDAC to sysfs and is the final chunk neccessary before EDAC has a stable user space API and can be considered for submission into the base kernel. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: doug thompson <norsk5@xmission.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[MAINTAINERS]: add entry for wireless networkingJohn W. Linville
Add an entry to MAINTAINERS for wireless networking, just so people know whom to bless with patches. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[MAINTAINERS]: correct location for net-2.6.gitJohn W. Linville
Correct location info for net-2.6 git tree. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18Merge git://tipc.cslab.ericsson.net/pub/git/tipcDavid S. Miller
2006-01-18[IRDA]: maintainer statusStephen Hemminger
Jean says he really doesn't have time to much IRDA any more. The following would help motivate someone who has more time. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Provide real email addresses in MAINTAINERSPer Liden
Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-17[PATCH] mv643xx_eth: Add Dale Farnsworth as a maintainerDale Farnsworth
MAINTAINERS | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-) Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-15[PATCH] MAINTAINERS: watchdog device driversWim Van Sebroeck
Add a MAINTAINER entry for the watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-01-14[PATCH] fbdev: Update maintainers listAntonino A. Daplas
Update maintainers list. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15MAINTAINERS: CIFS: add linux-cifs-client@lists.samba.org listJesper Juhl
Add linux-cifs-client@lists.samba.org to CIFS entry in MAINTAINERS Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-15MAINTAINERS: better list for "POSIX CLOCKS and TIMERS"Horms
POSIX CLOCKS and TIMERS disscussion is more appropriate on linux-kernel than linux-net. As suggested by the maintainer, George Anzinger. Signed-off-by: Horms <horms@verge.net.au> Acked-by: George Anzinger <george@mvista.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-12[TIPC] Added entry for TIPC in MAINTAINERSPer Liden
Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-11[PATCH] MAINTAINERS: remove dead projectAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11MAINTAINERS: sh: update the mailing listAdrian Bunk
2006-01-10[PATCH] Add git tree for DocBookMartin Waitz
Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
2006-01-10MAINTAINERS: remove BUSLOGIC entryAdrian Bunk
Leonard N. Zubkoff passed away in August 2002. Signed-off-by: Adrian Bunk <bunk@stusta.de>
