path: root/MAINTAINERS
2006-01-10[PATCH] Add git tree for DocBookMartin Waitz
Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
2006-01-10MAINTAINERS: remove BUSLOGIC entryAdrian Bunk
Leonard N. Zubkoff passed away in August 2002. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-09[PATCH] PCI Error Recovery: documentationlinas@austin.ibm.com
Various PCI bus errors can be signaled by newer PCI controllers. Recovering from those errors requires an infrastructure to notify affected device drivers of the error, and a way of walking through a reset sequence. This patch adds documentation describing the current error recovery proposal. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] remove bouncing mail address of mv643xx_eth maintainerOlaf Hering
Remove bouncing mail address of mv643xx maintainer. Signed-off-by: Olaf Hering <olh@suse.de> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-08[PATCH] MAINTAINERS: line duplicationNicolas Kaiser
uniq -d MAINTAINERS Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-07Auto-update from upstreamLen Brown
2006-01-06Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/i2c-2.6Linus Torvalds
2006-01-06[PATCH] MAINTAINERS: remove the outdated DAC960 entryAdrian Bunk
Randy Dunlap: "Dave is no longer at OSDL and is no longer maintaining that driver." Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06Auto-update from upstreamLen Brown
2006-01-06Merge ../torvalds-2.6/Greg Kroah-Hartman
2006-01-06[PATCH] Base support for AMD Geode GX/LX processorsJordan Crouse
Provide basic support for the AMD Geode GX and LX processors. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05[PATCH] hwmon: New vt8231 driverRoger Lucas
Port the vt8231 hardware monitoring driver from lm_sensors CVS to Linux 2.6. Signed-off-by: Roger Lucas <roger@planbit.co.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05Merge http://oss.oracle.com/git/ocfs2Linus Torvalds
2006-01-05Update MAINTAINERS - Jody is no longer at Steamballoon.Jody McIntyre
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-04[PATCH] remove CONFIG_KOBJECT_UEVENT optionKay Sievers
It makes zero sense to have hotplug, but not the netlink events enabled today. Remove this option and merge the kobject_uevent.h header into the kobject.h header file. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB Storage: update MAINTAINERSMatthew Dharm
Someone recently pointed out to me that the MAINTAINERS entry for usb-storage was, perhaps, in need of changing. Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: isp116x-hcd: cleanupOlav Kongas
The attached patch makes a cleanup of isp116x-hcd. Most of the volume of the patch comes from 2 sources: moving the code around to get rid of a few function prototypes and reworking register dumping functions/macros. Among other things, switched over from using procfs to debugfs. Cleanup. The following changes were made: - Rework register dumping code so it can be used for dumping to both syslog and debugfs. - Switch from procfs to debugfs.. - Die gracefully on Unrecoverable Error interrupt. - Fix memory leak in isp116x_urb_enqueue(), if HC happens to die in a narrow time window. - Fix a 'sparce' warning (unnecessary cast). - Report Devices Removable for root hub ports by default (was Devices Permanently Attached). - Move bus suspend/resume functions down in code to get rid of a few function prototypes. - A number of one-line cleanups. - Add an entry to MAINTAINERS. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> MAINTAINERS | 6 drivers/usb/host/isp116x-hcd.c | 429 ++++++++++++++++------------------------- drivers/usb/host/isp116x.h | 83 +++++-- 3 files changed, 230 insertions(+), 288 deletions(-)
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
2006-01-03[PATCH] configfs: User-driven configuration filesystemJoel Becker
Configfs, a file system for userspace-driven kernel object configuration. The OCFS2 stack makes extensive use of this for propagation of cluster configuration information into kernel. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2006-01-03update the email address of Randy DunlapAdrian Bunk
This patch removes all references to the bouncing address rddunlap@osdl.org and one dead web page from the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2006-01-03remove pointers to the defunct UDF mailing listAdrian Bunk
This patch removes pointers to the defunct UDF mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-03[ALSA] Add support for the CS5535 Audio deviceJaya Kumar
Add support for the CS5535 Audio device. I've fixed up some errors as per Takashi's advice from the thread: http://lkml.org/lkml/2005/9/15/119 From: Alan Cox <alan@lxorguk.ukuu.org.uk> cs5535 is a 32bit x86 only device using weird CPU features Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-12-30[ACPI] linux-acpi@vger.kernel.org replaces acpi-devel@lists.sourceforge.netLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-19[PATCH] V4L/DVB SCM Maintainers UpdateMauro Carvalho Chehab
- This patch updates MAINTAINERS file by replacing quilt to git SCM Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-13[PATCH] Dmitry Torokhov is input subsystem maintainerVojtech Pavlik
I haven't been very actively maintaining the input layer in past months, mostly because of my lack of time to concentrate on that. For that reason, I've decided to pass the maintainership of the Linux Input Layer to Dmitry Torokhov, whom I trust to do the job very well. Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Cc: Dmitry Torokhov <dtor_core@ameritech.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-02Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2005-12-01[PATCH] V4L/DVB: SCM updateMauro Carvalho Chehab
Add v4l/dvb quilt tree to MAINTAINERS file. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[SCSI] mptfusion: Add maintainersMoore, Eric Dean
Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-23[PATCH] Add more SCM trees to MAINTAINERSJosh Boyer
Greg requested a patch to update MAINTAINERS with more SCM entries. The patch below is what I've found so far. Signed-off-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] Clarify T: field in MAINTAINERSJody McIntyre
Pavel Machek points out that for git repos, what we include is not actually a URL. It is undesirable to use a URL since git repos can be accessed in many different ways. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] MTD git tree location added to MAINTAINERSJosh Boyer
Here's the MTD one. More later as I find them. Signed-off-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-20Input: add Wistron driverDmitry Torokhov
A driver for laptop buttons using an x86 BIOS interface that is apparently used on quite a few laptops and seems to be originating from Wistron. This driver currently "knows" only about Fujitsu-Siemens Amilo Pro V2000 (i.e. it can detect the laptop using DMI and it contains the keycode->key meaning mapping for this laptop) and Xeron SonicPro X 155G (probably can't be reliably autodetected, requires a module parameter), adding other laptops should be easy. In addition to reporting button presses to the input layer the driver also allows enabling/disabling the embedded wireless NIC (using the "Wifi" button); this is done using the same BIOS interface, so it seems only logical to keep the implementation together. Any flexibility possibly gained by allowing users to remap the function of the "Wifi" button is IMHO not worth it when weighted against the necessity to run an user-space daemon to convert button presses to wifi state changes. Signed-off-by: Miloslav Trmac <mitr@volny.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-18[PATCH] Add SCM info to MAINTAINERSJody McIntyre
Add tree information to MAINTAINERS file. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] Update email address for KumarKumar Gala
Changed jobs and the Freescale address is no longer valid. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] New Omnikey Cardman 4000 driverHarald Welte
Add new Omnikey Cardman 4000 smartcard reader driver Signed-off-by: Harald Welte <laforge@gnumonks.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] New Omnikey Cardman 4040 driverHarald Welte
Add new Omnikey Cardman 4040 smartcard reader driver Signed-off-by: Harald Welte <laforge@gnumonks.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-10[DCCP]: Alter website for DCCP in MAINTAINERSIan McDonald
Website for DCCP is now hosted at OSDL Signed-off-by: Ian McDonald <imcdnzl@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09Merge rsync://bughost.org/repos/ipw-delta/Jeff Garzik
2005-11-08MAINTAINERS: PKTCDVD DRIVER: remove entry for a subscribers-only listAdrian Bunk
This patch was already ACK'ed by Peter Osterlund.
2005-11-07Updated READMEs and MAINTAINERS for the ipw2100 and ipw2200 drivers.James Ketrenos
Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] HPET, MaintainersBob Picco
This patch identifies the HPET Maintainers. Clemens in taking over as primary maintainer for the HPET driver. Clemens has i386 hardware with HPET and is a better choice than me because of this. I've shared this patch with all cc: recipients and there is agreement on ownership. Hopefully this eliminates future confusion in terms of where HPET maintenance is owned. Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: <clemens@ladisch.de> Cc: <venkatesh.pallipadi@intel.com> Cc: <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Merge with http://www.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitAdrian Bunk
2005-11-06Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
