path: root/MAINTAINERS
2011-03-28asus-nb-wmi: Asus Notebooks WMI DriverCorentin Chary
Introduce a new driver for Asus Notebooks shipped with a WMI device instead of the old ACPI device. The WMI device is almost the same as the one present in Eee PC, but the event guid and the keymap are different. The keymap comes from asus-laptop module. On Asus notebooks, when you call the WMI device, you always need a 64bit buffer, even if you only want to get the state of a device (tested on a G73). Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-03-27apm: orphan the driverStephen Rothwell
I no longer have access to any hardware that uses APM and have not provided real maintenance for several years. Hopefully someone with the hardware or energy will step forward if the driver is to be kept. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-27um: Add myself as co-maintainerRichard Weinberger
Signed-off-by: Richard Weinberger <richard@nod.at> Acked-and-appreciated-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25memstick: add driver for Ricoh R5C592 card readerMaxim Levitsky
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Acked-by: Alex Dubov <oakad@yahoo.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits) [media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t [media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly [media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE [media] v4l: soc-camera: Store negotiated buffer settings [media] rc: interim support for 32-bit NEC-ish scancodes [media] mceusb: topseed 0x0011 needs gen3 init for tx to work [media] lirc_zilog: error out if buffer read bytes != chunk size [media] lirc: silence some compile warnings [media] hdpvr: use same polling interval as other OS [media] ir-kbd-i2c: pass device code w/key in hauppauge case [media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap [media] remove the old RC_MAP_HAUPPAUGE_NEW RC map [media] rc/keymaps: Rename Hauppauge table as rc-hauppauge [media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping [media] rc-rc5-hauppauge-new: Add support for the old Black RC [media] rc-rc5-hauppauge-new: Add the old control to the table [media] rc-winfast: Fix the keycode tables [media] a800: Fix a few wrong IR key assignments [media] opera1: Use multimedia keys instead of an app-specific mapping [media] dw2102: Use multimedia keys instead of an app-specific mapping ... Fix up trivial conflicts (remove/modify and some real conflicts) in: arch/arm/mach-omap2/devices.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/dabusb/dabusb.c drivers/staging/dabusb/dabusb.h drivers/staging/easycap/easycap_ioctl.c drivers/staging/usbvideo/usbvideo.c drivers/staging/usbvideo/vicam.c
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: (140 commits) MAINTAINERS: de-orphan fbdev. MAINTAINERS: Add file pattern for fb dt bindings. video: Move sm501fb devicetree binding documentation to a better place. fbcon: fix situation where fbcon gets deinitialised and can't reinit. video, sm501: add OF binding to support SM501 video, sm501: add edid and commandline support video, sm501: add I/O functions for use on powerpc video: Fix EDID macros H_SYNC_WIDTH and H_SYNC_OFFSET fbcon: Bugfix soft cursor detection in Tile Blitting video: add missing framebuffer_release in error path video: metronomefb: add __devexit_p around reference to metronomefb_remove video: hecubafb: add __devexit_p around reference to hecubafb_remove drivers:video:aty:radeon_base Fix typo occationally to occasionally atmel_lcdfb: add fb_blank function atmel_lcdfb: implement inverted contrast pwm video: s3c-fb: return proper error if clk_get fails uvesafb,vesafb: create WC or WB PAT-entries video: ffb: fix ffb_probe error path radeonfb: Let hwmon driver probe the "monid" I2C bus fbdev: sh_mobile_lcdc: checking NULL instead of IS_ERR() ...
2011-03-22MAINTAINERS: add drivers/platform/msm to MSM subsystemKenneth Heitke
Signed-off-by: Kenneth Heitke <kheitke@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: update WINBOND CIR patternJoe Perches
commit 5b2e303f6df ("[media] rc-core: convert winbond-cir") moved the files, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David Härdeman <david@hardeman.nu> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: uSB SE401 moved to staging, update patternJoe Perches
And set the status to Orphan. Signed-off-by: Joe Perches <joe@perches.com> Cc: Jeroen Vreeken <pe1rxq@amsat.org> Cc: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: update SFI patternJoe Perches
commit 937f961a653 ("x86: Move sfi to platform") moved the files, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: remove SHARP LH7A40X sectionJoe Perches
commit 82e6923e186 ("ARM: lh7a40x: remove unmaintained platform support") removed support, remove it from MAINTAINERS. Signed-off-by: Joe Perches <joe@perches.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: update SCX200 file patternJoe Perches
commit 3b3da9d25ae ("x86: Move scx200 to platform") moved it, convert the pattern too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: remove unused TIMEKEEPING timekeeping.hJoe Perches
Commit 88606e80da0 ("MAINTAINERS: Update timer related entries") added a file pattern that didn't actually exist. Signed-off-by: Joe Perches <joe@perches.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: remove IEEE1394 entryJoe Perches
commit 66fa12c571d ("ieee1394: remove the old IEEE 1394 driver stack") removed the code, remove the MAINTAINERS entry. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: update media pathJoe Perches
Commit 52b661449ae ("[media] rc: Rename remote controller type to rc_type instead of ir_type") moved it around. Signed-off-by: Joe Perches <joe@perches.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: update clkdev locationJoe Perches
Commit 6d803ba736a ("ARM: 6483/1: arm & sh: factorised duplicated clkdev.c") moved it to a separate directory. Signed-off-by: Joe Perches <joe@perches.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: remove unnecessary linux-kernel@vger.kernel.org entriesJoe Perches
CC'ing lkml is the default and doesn't need separate entries. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: add missing : after HR Timers F tagJoe Perches
2011-03-22MAINTAINERS: remove ASOC CODEC DRIVERS files not in treeJoe Perches
Remove these patterns until such files are actually in the tree. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: change web links from wiki-analog to wiki.analogJoe Perches
wiki-analog doesn't seem to work, but wiki.analog does. Signed-off-by: Joe Perches <joe@perches.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: update ADP5520 patternJoe Perches
Typo in path. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: quote non-alphanumeric email addressesJoe Perches
Add quotes around email address with periods and commas. So they don't explode when pasted into certain email clients. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Cc: "Mark F. Brown" <mark.brown314@gmail.com> Cc: "Gustavo F. Padovan" <padovan@profusion.mobi> Cc: "Stephen M. Cameron" <scameron@beardog.cce.hp.com> Cc: "Lee, Chun-Yi" <jlee@novell.com> Acked-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22MAINTAINERS: add topgit for T:Harry Wei
At least one tree: ARM/EZX SMARTPHONES (A780, A910, A1200, E680, ROKR E2 and ROKR E6) is available via topgit. Add mention of topgit in the MAINTAINERS description section. Signed-off-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23MAINTAINERS: de-orphan fbdev.Paul Mundt
It's been a few kernel versions now without any unexpected surprises, so tentatively bump up the support status. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-23MAINTAINERS: Add file pattern for fb dt bindings.Paul Mundt
Now that Documentation/devicetree/bindings/fb/ exists, make sure it's also matched by the default framebuffer entry. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22Merge branch 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linux: i2c-pxa2xx: Don't clear isr bits too early i2c-pxa2xx: Fix register offsets i2c-pxa2xx: pass of_node from platform driver to adapter and publish i2c-pxa2xx: check timeout correctly i2c-pxa2xx: add support for shared IRQ handler i2c-pxa2xx: Add PCI support for PXA I2C controller ARM: pxa2xx: reorganize I2C files i2c-pxa2xx: use dynamic register layout i2c-mxs: set controller to pio queue mode after reset i2c-eg20t: support new device OKI SEMICONDUCTOR ML7213 IOH i2c/busses: Add support for Diolan U2C-12 USB-I2C adapter
2011-03-22[media] omap3isp: Kconfig and MakefileLaurent Pinchart
Add the OMAP3 ISP driver to the kernel build system. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22Merge branch 'for-paul' of git://gitorious.org/linux-omap-dss2/linuxPaul Mundt
Conflicts: arch/arm/mach-omap2/board-overo.c Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-21hwmon: Add support for Texas Instruments ADS1015Dirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hwmon: New driver for SMSC SCH5627Hans de Goede
SMSC SCH5627 Super I/O chips include complete hardware monitoring capabilities. They can monitor up to 5 voltages, 4 fans and 8 temperatures. The hardware monitoring part of the SMSC SCH5627 is accessed by talking through an embedded microcontroller. An application note describing the protocol for communicating with the microcontroller is available upon request. Please mail me if you want a copy. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hwmon: (abituguru*) Update my email addressHans de Goede
2011-03-21Move lis3lv02d drivers to drivers/miscJean Delvare
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't belong to drivers/hwmon. Move them to drivers/misc, short of a better home. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-20Merge branch 'for-2639/i2c/i2c-u2c12' into for-linus/2639/i2c-12Ben Dooks
2011-03-18MAINTAINERS: Add serialAlan Cox
Add an entry for serial maintainers. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (27 commits) arch/tile: support newer binutils assembler shift semantics arch/tile: fix deadlock bugs in rwlock implementation drivers/edac: provide support for tile architecture tile on-chip network driver: sync up with latest fixes arch/tile: support 4KB page size as well as 64KB arch/tile: add some more VMSPLIT options and use consistent naming arch/tile: fix some comments and whitespace arch/tile: export some additional module symbols arch/tile: enhance existing finv_buffer_remote() routine arch/tile: fix two bugs in the backtracer code arch/tile: use extended assembly to inline __mb_incoherent() arch/tile: use a cleaner technique to enable interrupt for cpu_idle() arch/tile: sync up with <arch/sim.h> and <arch/sim_def.h> changes arch/tile: fix reversed test of strict_strtol() return value arch/tile: avoid a simulator warning during bootup arch/tile: export <asm/hardwall.h> to userspace arch/tile: warn and retry if an IPI is not accepted by the target cpu arch/tile: stop disabling INTCTRL_1 interrupts during hypervisor downcalls arch/tile: fix __ndelay etc to work better arch/tile: bug fix: exec'ed task thought it was still single-stepping ... Fix up trivial conflict in arch/tile/kernel/vmlinux.lds.S (percpu alignment vs section naming convention fix)
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-17Merge tag 'v2.6.38' of ↵Chris Metcalf
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus
2011-03-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32: (40 commits) unicore32: rewrite arch-specific tlb.h to use asm-generic version unicore32: modify io_p2v and io_v2p macros, and adjust PKUNITY_mmio_BASEs unicore32: replace unicore32-specific iomap functions with generic lib implementation unicore32 machine related: add frame buffer driver for pkunity-v3 soc unicore32 machine related files: add i2c bus drivers for pkunity-v3 soc unicore32 io: redefine __REG(x) and re-use readl/writel funcs unicore32 i8042 upgrade and bugfix: adjust resource request region type unicore32 upgrade to v2.6.38-rc5: add one more paramter for pte_alloc_map call unicore32 i8042: adjust io funcs of i8042-unicore32io.h unicore32: rename PKUNITY_IOSPACE_BASE to PKUNITY_MMIO_BASE unicore32: modify function names and parameters for irq_chips unicore32: remove unused lines in arch/unicore32/include/asm/irq.h unicore32 time.c: change calculate method for clock_event_device unicore32: ADD MAINTAINER for unicore32 architecture unicore32 machine related files: ps2 driver unicore32 machine related files: pci bus handling unicore32 machine related files: hardware registers unicore32 machine related files: core files unicore32 additional architecture files: boot process unicore32 additional architecture files: low-level lib: misc ... Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-17unicore32 machine related: add frame buffer driver for pkunity-v3 socGuanXuetao
change from original version -- by advice of Paul Mundt 1. remove videomemorysize definitions 2. remove unifb_enable and unifb_setup 3. use dev_warn instead of printk in fb driver 4. remove judgement for FB_ACCEL_PUV3_UNIGFX 5. adjust clk_get and clk_set_rate calls 6. add resources definitions 7. remove unifb_option 8. adjust register for platform_device 9. adjust unifb_ops position and unifb_regs assignment position Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-17unicore32 machine related files: add i2c bus drivers for pkunity-v3 socGuanXuetao
change from original version -- by advice of Jean Delvare 1. remove global variable i2c_reg, replaced by local variables 2. replace ENXIO with ENODEV when no platform resources 3. add adapter->nr assignment before i2c_add_numbered_adapter() call 4. add judgement for i2c_del_adapter() return value 5. release adapter when driver removed 6. add __devexit for puv3_i2c_remove() function 7. modify several names to more appropriated ones Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-17unicore32: ADD MAINTAINER for unicore32 architectureGuanXuetao
Add MAINTAINER list for unicore32 architecture and pkunity soc drivers. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (961 commits) staging: hv: fix memory leaks staging: hv: Remove NULL check before kfree Staging: hv: Get rid of vmbus_child_dev_add() Staging: hv: Change the signature for vmbus_child_device_register() Staging: hv: Get rid of vmbus_cleanup() function Staging: hv: Get rid of vmbus_dev_rm() function Staging: hv: Change the signature for vmbus_on_isr() Staging: hv: Eliminate vmbus_event_dpc() Staging: hv: Get rid of the function vmbus_msg_dpc() Staging: hv: Change the signature for vmbus_cleanup() Staging: hv: Simplify root device management staging: rtl8192e: Don't copy dev pointer to skb staging: rtl8192e: Pass priv to cmdpkt functions staging: rtl8192e: Pass priv to firmware download functions staging: rtl8192e: Pass priv to rtl8192_interrupt staging: rtl8192e: Pass rtl8192_priv to dm functions staging: rtl8192e: Pass ieee80211_device to callbacks staging: rtl8192e: Pass ieee80211_device to callbacks staging: rtl8192e: Pass ieee80211_device to callbacks staging: rtl8192e: Pass ieee80211_device to callbacks ...
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-16Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (29 commits) ahci: add another PCI ID for marvell libata: Use 'bool' return value for ata_id_XXX sata_fsl: Update RX_WATER_MARK for TRANSCFG sata_fsl: Fix wrong Device Error Register usage libata: Include WWN ID in inquiry VPD emulation ata/pata_arasan_cf: fill dma chan->private from pdata->dma_priv ata: pata: Convert pr_*(DRV_NAME ...) to pr_fmt/pr_<level> pata_arasan_cf: fix printk format string warning pata_arasan_cf: Adding support for arasan compact flash host controller libata-sff: add ata_sff_queue_work() & ata_sff_queue_delayed_work() ahci: AHCI mode SATA patch for Intel Patsburg SATA RAID controller ahci: recognize Marvell 88se9125 PCIe SATA 6.0 Gb/s controller libata: remove ATA_FLAG_LPM libata: remove ATA_FLAG_NO_LEGACY libata: remove ATA_FLAG_MMIO libata: remove ATA_FLAG_{SRST|SATA_RESET} ipr/sas_ata: use mode mask macros from <linux/ata.h> sata_dwc_460ex: add debugging options sata_dwc_460ex: fix misuse of ata_get_cmd_descript() sata_dwc_460ex: fix return value of dma_dwc_xfer_setup() ...
2011-03-14Merge branch 'davinci-next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci into devel-stable
2011-03-14pata_arasan_cf: Adding support for arasan compact flash host controllerViresh Kumar
The Arasan CompactFlash Device Controller has three basic modes of operation: PC card ATA using I/O mode, PC card ATA using memory mode, PC card ATA using true IDE modes. Currently driver supports only True IDE mode. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
