path: root/MAINTAINERS
2011-09-14Merge git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6Linus Torvalds
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: (25 commits) [SCSI] bnx2i: Fixed the endian on TTT for NOP out transmission [SCSI] libfc: fix referencing to fc_fcp_pkt from the frame pointer via fr_fsp() [SCSI] libfc: block SCSI eh thread for blocked rports [SCSI] libfc: fix fc_eh_host_reset [SCSI] fcoe: Fix deadlock between fip's recv_work and rtnl [SCSI] qla2xxx: Update version number to 8.03.07.07-k. [SCSI] qla2xxx: Set the task attributes after memsetting fcp cmnd. [SCSI] qla2xxx: Correct inadvertent loop state transitions during port-update handling. [SCSI] qla2xxx: Save and restore irq in the response queue interrupt handler. [SCSI] qla2xxx: Double check for command completion if abort mailbox command fails. [SCSI] qla2xxx: Acquire hardware lock while manipulating dsd list. [SCSI] qla2xxx: Fix qla24xx revision check while enabling interrupts. [SCSI] qla2xxx: T10 DIF - Fix incorrect error reporting. [SCSI] qla2xxx: T10 DIF - Handle uninitalized sectors. [SCSI] hpsa: fix physical device lun and target numbering problem [SCSI] hpsa: fix problem that OBDR devices are not detected [SCSI] isci: add version number [SCSI] isci: fix event-get pointer increment [SCSI] isci: dynamic interrupt coalescing [SCSI] isci: Leave requests alone if already terminating. ...
2011-08-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (42 commits) netpoll: fix incorrect access to skb data in __netpoll_rx cassini: init before use in cas_interruptN. can: ti_hecc: Fix uninitialized spinlock in probe can: ti_hecc: Fix unintialized variable net: sh_eth: fix the compile error net/phy: fix DP83865 phy interrupt handler sendmmsg/sendmsg: fix unsafe user pointer access ibmveth: Fix leak when recycling skb and hypervisor returns error arp: fix rcu lockdep splat in arp_process() bridge: fix a possible use after free bridge: Pseudo-header required for the checksum of ICMPv6 mcast: Fix source address selection for multicast listener report MAINTAINERS: Update GIT trees for network development ath9k: Fix PS wrappers in ath9k_set_coverage_class carl9170: Fix mismatch in carl9170_op_set_key mutex lock-unlock wl12xx: add max_sched_scan_ssids value to the hw description wl12xx: Fix validation of pm_runtime_get_sync return value wl12xx: Remove obsolete testmode NVS push command bcma: add uevent to the bus, to autoload drivers ath9k_hw: Fix STA (AR9485) bringup issue due to incorrect MAC address ...
2011-08-29MAINTAINERS: change framebuffer maintainerFlorian Tobias Schandinat
As Paul has not much time for it I take over maintaining the framebuffer subsystem. Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (32 commits) ALSA: hda: Conexant: Allow different output types to share DAC ASoC: Correct element count for WM8996 sidetone HPF ASoC: Tegra: wm8903 machine driver: Drop Ventana support ASoC: Add samsung maintainer ASoC: Add Springbank I/O card to Speyside Kconfig ALSA: hda/conexant - Enable ADC-switching for auto-mic mode, too ALSA: hda - Fix double-headphone/speaker paths for Cxt auto-parser ALSA: hda - Update jack-sense info even when no automute is set ALSA: hda - Fix output-path initialization for Realtek auto-parser sound/soc/fsl/mpc8610_hpcd.c: add missing of_node_put sound/soc/fsl/p1022_ds.c: add missing of_node_put sound/soc/ep93xx/ep93xx-i2s.c: add missing kfree sound/soc/kirkwood/kirkwood-i2s.c: add missing kfree ASoC: soc-core: use GFP_KERNEL flag for kmalloc in snd_soc_cnew sound/soc/fsl/fsl_dma.c: add missing of_node_put ASoC: Clear completions from late WM8996 FLL lock IRQs ASoC: Clear any outstanding WM8962 FLL lock completions before waiting ASoC: Ensure we only run Speyside WM8962 bias level callbacks once ASoC: Fix configuration of WM8996 input enables ASoC: WM8996 record paths need AIFCLK ...
2011-08-25MAINTAINERS: Paul Menage has movedWanlong Gao
Paul said: I left Google at the end of last week - if it's not bouncing already, menage@google.com isn't going to work for much longer. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Acked-by: Paul Menage <paul@paulmenage.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25MAINTAINERS: Evgeniy has movedEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-24MAINTAINERS: Update GIT trees for network developmentNicolas de Pesloüan
Remove -2.6 from net and net-next tree names. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24ASoC: Add samsung maintainerSangbeom Kim
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-23[SCSI] isci: Update MAINTAINERS entry for the isci driverDave Jiang
Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-18Merge branch 'perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
2011-08-18MAINTAINERS: Fix list of perf events source filesGeunsik Lim
Recent changes made kernel/perf_event.c be split and moved to kernel/events/. Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Kosina <trivial@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1313653497-27263-1-git-send-email-leemgs1@gmail.com Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Fix compile warning in wm8750.c ASoC: omap: Update e-mail address of Jarkko Nikula ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: Terminate WM8750 SPI device ID table ASoC: Add missing break in WM8994 probe ALSA: snd-usb-caiaq: Correct offset fields of outbound iso_frame_desc ALSA: azt3328 - adjust error handling code to include debugging code ALSA: hda - Add CONFIG_SND_HDA_POWER_SAVE to stac_vrefout_set() ALSA: usb-audio - Add quirk for BOSS Micro BR-80 ASoC: Fix typo in wm8750 spi_ids ASoC: Fix warning in Speyside WM8962 ASoC: Fix SPI driver binding for WM8987 ASoC: Fix binding of WM8750 on Jive ASoC: WM8903: Free IRQ on device removal ASoC: Tegra: wm8903 machine driver: Allow re-insertion of module ASoC: Tegra: tegra_pcm_deallocate_dma_buffer: Don't OOPS
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-11MAINTAINERS: Update linus' git repositoryTracey Dent
Change to new git tree - (git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git). Signed-off-by: Tracey Dent <tdent48227@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-10Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Really fix build without CONFIG_PCI powerpc: Fix build without CONFIG_PCI powerpc/4xx: Fix build of PCI code on 405 powerpc/pseries: Simplify vpa deregistration functions powerpc/pseries: Cleanup VPA registration and deregistration errors powerpc/pseries: Fix kexec on recent firmware versions MAINTAINERS: change maintainership of mpc5xxx powerpc: Make KVM_GUEST default to n powerpc/kvm: Fix build errors with older toolchains powerpc: Lack of ibm,io-events not that important! powerpc: Move kdump default base address to half RMO size on 64bit powerpc/perf: Disable pagefaults during callchain stack read ppc: Remove duplicate definition of PV_POWER7 powerpc: pseries: Fix kexec on machines with more than 4TB of RAM powerpc: Jump label misalignment causes oops at boot powerpc: Clean up some panic messages in prom_init powerpc: Fix device tree claim code powerpc: Return the_cpu_ spec from identify_cpu powerpc: mtspr/mtmsr should take an unsigned long
2011-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits) ipv6: check for IPv4 mapped addresses when connecting IPv6 sockets mlx4: decreasing ref count when removing mac net: Fix security_socket_sendmsg() bypass problem. net: Cap number of elements for sendmmsg net: sendmmsg should only return an error if no messages were sent ixgbe: fix PHY link setup for 82599 ixgbe: fix __ixgbe_notify_dca() bail out code igb: fix WOL on second port of i350 device e1000e: minor re-order of #include files e1000e: remove unnecessary check for NULL pointer intel drivers: repair missing flush operations macb: restore wrap bit when performing underrun cleanup cdc_ncm: fix endianness problem. irda: use PCI_VENDOR_ID_* mlx4: Fixing Ethernet unicast packet steering net: fix NULL dereferences in check_peer_redir() bnx2x: Clear MDIO access warning during first driver load bnx2x: Fix BCM578xx MAC test bnx2x: Fix BCM54618se invalid link indication bnx2x: Fix BCM84833 link ...
2011-08-05MAINTAINERS: change maintainership of mpc5xxxAnatolij Gustschin
Grant intends to hand over maintainership of mpc5xxx to me. Change MPC5XXX entry in MAINTAINERS accordingly. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-03Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle: stop depending on pm_idle x86 idle: move mwait_idle_with_hints() to where it is used cpuidle: replace xen access to x86 pm_idle and default_idle cpuidle: create bootparam "cpuidle.off=1" mrst_pmu: driver for Intel Moorestown Power Management Unit
2011-08-03Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data target: Fix bug for transport_generic_wait_for_tasks with direct operation target: iscsi_target depends on NET target: Fix WRITE_SAME_16 lba assignment breakage MAINTAINERS: Add target-devel list for drivers/target/ iscsi-target: Fix CONFIG_SMP=n and CONFIG_MODULES=n build failure iscsi-target: Fix snprintf usage with MAX_PORTAL_LEN iscsi-target: Fix uninitialized usage of cmd->pad_bytes iscsi-target: strlen() doesn't count the terminator iscsi-target: Fix NULL dereference on allocation failure
2011-08-03mrst_pmu: driver for Intel Moorestown Power Management UnitLen Brown
The Moorestown (MRST) Power Management Unit (PMU) driver directs the SOC power states in the "Langwell" south complex (SCU). It hooks pci_platform_pm_ops[] and thus observes all PCI ".set_state" requests. For devices in the SC, the pmu driver translates those PCI requests into the appropriate commands for the SCU. The PMU driver helps implement S0i3, a deep system idle power idle state. Entry into S0i3 is via cpuidle, just like regular processor c-states. S0i3 depends on pre-conditions including uni-processor, graphics off, and certain IO devices in the SC must be off. If those pre-conditions are met, then the PMU allows cpuidle to enter S0i3, otherwise such requests are demoted, either to Atom C4 or Atom C6. This driver is based on prototype work by Bruce Flemming, Illyas Mansoor, Rajeev D. Muralidhar, Vishwesh M. Rudramuni, Hari Seshadri and Sujith Thomas. The current driver also includes contributions from H. Peter Anvin, Arjan van de Ven, Kristen Accardi, and Yong Wang. Thanks for additional review feedback from Alan Cox and Randy Dunlap. Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-02MAINTAINERS: Add keyword match for of_match_table to device tree sectionMark Brown
If a patch is working with an of_match_table it's probably adding an OF binding to a driver in which case the binding ought to be reviewed by the device tree folks to make sure that things like the device matches are set up correctly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-01doc: Update the MAINTAINERS info for Paul MoorePaul Moore
My @hp.com will no longer be valid starting August 5, 2011 so an update is necessary. My new email address is employer independent so we don't have to worry about doing this again any time soon. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01MAINTAINERS: Remove Pekka Savola from ipv6.David S. Miller
2011-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutilsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils: cpupower: Do detect IDA (opportunistic processor performance) via cpuid cpupower: Show Intel turbo ratio support via ./cpupower frequency-info cpupowerutils: increase MAX_LINE_LEN cpupower: Rename package from cpupowerutils to cpupower cpupowerutils: Rename: libcpufreq->libcpupower cpupowerutils: use kernel version-derived version string cpupowerutils: utils - ConfigStyle bugfixes cpupowerutils: helpers - ConfigStyle bugfixes cpupowerutils: idle_monitor - ConfigStyle bugfixes cpupowerutils: lib - ConfigStyle bugfixes cpupowerutils: bench - ConfigStyle bugfixes cpupowerutils: do not update po files on each and every compile cpupowerutils: remove ccdv, use kernel quiet/verbose mechanism cpupowerutils: use COPYING, CREDITS from top-level directory cpupowerutils - cpufrequtils extended with quite some features
2011-07-30Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits) hwmon: (lm90) Refactor reading of config2 register hwmon: (lm90) Make SA56004 detection more robust hwmon: (lm90) Simplify handling of extended local temp register hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066 hwmon: (max34440) Add support for peak attributes hwmon: (max8688) Add support for peak attributes hwmon: (max16064) Add support for peak attributes hwmon: (adm1275) Add support for peak attributes hwmon: (pmbus) Add support for peak attributes hwmon: Add new attributes to sysfs ABI hwmon: (pmbus) Strengthen check for status register existence hwmon: (pmbus) Add support for virtual pages hwmon: (pmbus) Support reading and writing of word registers in device specific code hwmon: (pmbus) Increase attribute name size hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices hwmon: (pmbus) Add support for VID output voltage mode hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus hwmon: (coretemp) Add core/pkg threshold support to Coretemp hwmon: (lm95241) Add support for LM95231 hwmon: LM95245 driver ...
2011-07-29cpupowerutils - cpufrequtils extended with quite some featuresDominik Brodowski
CPU power consumption vs performance tuning is no longer limited to CPU frequency switching anymore: deep sleep states, traditional dynamic frequency scaling and hidden turbo/boost frequencies are tied close together and depend on each other. The first two exist on different architectures like PPC, Itanium and ARM, the latter (so far) only on X86. On X86 the APU (CPU+GPU) will only run most efficiently if CPU and GPU has proper power management in place. Users and Developers want to have *one* tool to get an overview what their system supports and to monitor and debug CPU power management in detail. The tool should compile and work on as many architectures as possible. Once this tool stabilizes a bit, it is intended to replace the Intel-specific tools in tools/power/x86 Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-07-28MAINTAINERS: orphan FrameRelay DLCIJoe Perches
Mike McLagan hasn't contributed in many years and his email bounces. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbusGuenter Roeck
Since the number of PMBus drivers is getting large, move them into directory drivers/hwmon/pmbus to improve readability and scalability. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: Driver for MAX1668David George
This patch adds support for MAX1668 and compatible temperature sensors. Signed-off-by: David George <david.george@ska.ac.za> [guenter.roeck@ericsson.com: minor cleanup of probe error path] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits) tpm_nsc: Fix bug when loading multiple TPM drivers tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block tpm: Fix compilation warning when CONFIG_PNP is not defined TOMOYO: Update kernel-doc. tpm: Fix a typo tpm_tis: Probing function for Intel iTPM bug tpm_tis: Fix the probing for interrupts tpm_tis: Delay ACPI S3 suspend while the TPM is busy tpm_tis: Re-enable interrupts upon (S3) resume tpm: Fix display of data in pubek sysfs entry tpm_tis: Add timeouts sysfs entry tpm: Adjust interface timeouts if they are too small tpm: Use interface timeouts returned from the TPM tpm_tis: Introduce durations sysfs entry tpm: Adjust the durations if they are too small tpm: Use durations returned from TPM TOMOYO: Enable conditional ACL. TOMOYO: Allow using argv[]/envp[] of execve() as conditions. TOMOYO: Allow using executable's realpath and symlink's target as conditions. TOMOYO: Allow using owner/group etc. of file objects as conditions. ... Fix up trivial conflict in security/tomoyo/realpath.c
2011-07-27MAINTAINERS: Add target-devel list for drivers/target/Nicholas Bellinger
Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-26Merge branch 'next/soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: MAINTAINERS: add maintainer of CSR SiRFprimaII machine ARM: CSR: initializing L2 cache ARM: CSR: mapping early DEBUG_LL uart ARM: CSR: Adding CSR SiRFprimaII board support OMAP4: clocks: Update the clock tree with 4460 clock nodes OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts OMAP4: ID: add omap_has_feature for max freq supported OMAP: ID: introduce chip detection for OMAP4460 ARM: Xilinx: merge board file into main platform code ARM: Xilinx: Adding Xilinx board support Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
2011-07-26Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (31 commits) MIPS: Close races in TLB modify handlers. MIPS: Add uasm UASM_i_SRL_SAFE macro. MIPS: RB532: Use hex_to_bin() MIPS: Enable cpu_has_clo_clz for MIPS Technologies' platforms MIPS: PowerTV: Provide cpu-feature-overrides.h MIPS: Remove pointless return statement from empty void functions. MIPS: Limit fixrange_init() to the FIXMAP region MIPS: Install handlers for software IRQs MIPS: Move FIXADDR_TOP into spaces.h MIPS: Add SYNC after cacheflush MIPS: pfn_valid() is broken on low memory HIGHMEM systems MIPS: HIGHMEM DMA on noncoherent MIPS32 processors MIPS: topdown mmap support MIPS: Remove redundant addr_limit assignment on exec. MIPS: AR7: Replace __attribute__((__packed__)) with __packed MIPS: AR7: Remove 'space before tabs' in platform.c MIPS: Lantiq: Add missing clk_enable and clk_disable functions. MIPS: AR7: Fix trailing semicolon bug in clock.c MAINTAINERS: Update MIPS entry. MIPS: BCM63xx: Remove duplicate PERF_IRQSTAT_REG definition ...
2011-07-25Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (741 commits) staging:iio:meter:ade7753 should be 16 bit read not 8 bit for mode register. staging:iio:kfifo_buf fix double initialization of the ring device structure. staging:iio:accel:lis3l02dq: fix incorrect pointer passed to spi_set_drvdata. staging:iio:imu fix missing register table index for some channels spectra: enable device before poking it staging: rts_pstor: Fix a miswriting staging/lirc_bt829: Return -ENODEV when no hardware is found. staging/lirc_parallel: remove pointless prototypes. staging/lirc_parallel: fix panic on rmmod staging:iio:adc:ad7476: Incorrect pointer into spi_set_drvdata. Staging: zram: Fix kunmapping order Revert "gma500: Fix dependencies" gma500: Add medfield header gma500: wire up the mrst i2c bus from chip_info gma500: Fix DPU build gma500: Clean up the DPU config and make it runtime gma500: resync with Medfield progress gma500: Use the mrst helpers and power control for mode commit gma500@ Fix backlight range error gma500: More Moorestown muddle meddling means MM maybe might modeset ... Fix up fairly trivial conflicts all over, mostly due to header file cleanup conflicts, but some deleted files and some just context changes: - Documentation/feature-removal-schedule.txt - drivers/staging/bcm/headers.h - drivers/staging/brcm80211/brcmfmac/dhd_linux.c - drivers/staging/brcm80211/brcmfmac/dhd_sdio.c - drivers/staging/brcm80211/brcmfmac/wl_cfg80211.h - drivers/staging/brcm80211/brcmfmac/wl_iw.c - drivers/staging/et131x/et131x_netdev.c - drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c - drivers/staging/rtl8192e/r8192E.h - drivers/staging/usbip/userspace/src/utils.h
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25MAINTAINERS: update HIGH RESOLUTION TIMERS patternsJoe Perches
clockchips.h was typoed as clockevents.h Signed-off-by: Joe Perches <joe@perches.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (lm78) Become the maintainer hwmon: (lm78) Make ISA interface depend on CONFIG_ISA hwmon: (lm78) Avoid forward declarations hwmon: (sht15) Correct a comment mistake hwmon: (max1111) Avoid extra memory allocations hwmon: (it87) Add chassis intrusion detection support hwmon: (via-cputemp) Add VID reporting support hwmon-vid: Add support for VIA family 6 model D CPU hwmon: New driver sch5636 hwmon: (sch5627) Factor out some code shared with sch5636 driver
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25hwmon: (lm78) Become the maintainerJean Delvare
Declare myself the maintainer of the lm78 driver. I still have a running system with one of these chips. Also count myself as a co-author of the driver. With 34 commits over 6 years, it seems fair. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits) bnx2x: use pci_pcie_cap() bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_task bnx2x: enable internal target-read for 57712 and up only bnx2x: count statistic ramrods on EQ to prevent MC assert bnx2x: fix loopback for non 10G link bnx2x: dcb - send all unmapped priorities to same COS as L2 iwlwifi: Fix build with CONFIG_PM disabled. gre: fix improper error handling ipv4: use RT_TOS after some rt_tos conversions via-velocity: remove duplicated #include qlge: remove duplicated #include igb: remove duplicated #include can: c_can: remove duplicated #include bnad: remove duplicated #include net: allow netif_carrier to be called safely from IRQ bna: Header File Consolidation bna: HW Error Counter Fix bna: Add HW Semaphore Unlock Logic bna: IOC Event Name Change bna: Mboxq Flush When IOC Disabled ...
2011-07-24Merge branch 'for-upstream' of git://openrisc.net/jonas/linuxLinus Torvalds
* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits) OpenRISC: Add MAINTAINERS entry OpenRISC: Miscellaneous OpenRISC: Library routines OpenRISC: Headers OpenRISC: Traps OpenRISC: Module support OpenRISC: GPIO OpenRISC: Scheduling/Process management OpenRISC: Idle/Power management OpenRISC: System calls OpenRISC: IRQ OpenRISC: Timekeeping OpenRISC: DMA OpenRISC: PTrace OpenRISC: Build infrastructure OpenRISC: Signal handling OpenRISC: Memory management OpenRISC: Device tree OpenRISC: Boot code iomap: make IOPORT/PCI mapping functions conditional ...
2011-07-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regulator: Convert tps65023 to use regmap API regmap: Add SPI bus support regmap: Add I2C bus support regmap: Add generic non-memory mapped register access API
2011-07-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (77 commits) [SCSI] fix crash in scsi_dispatch_cmd() [SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwise [SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpu [SCSI] bfa: Update the driver version to 3.0.2.1 [SCSI] bfa: Driver and BSG enhancements. [SCSI] bfa: Added support to query PHY. [SCSI] bfa: Added HBA diagnostics support. [SCSI] bfa: Added support for flash configuration [SCSI] bfa: Added support to obtain SFP info. [SCSI] bfa: Added support for CEE info and stats query. [SCSI] bfa: Extend BSG interface. [SCSI] bfa: FCS bug fixes. [SCSI] bfa: DMA memory allocation enhancement. [SCSI] bfa: Brocade-1860 Fabric Adapter vHBA support. [SCSI] bfa: Brocade-1860 Fabric Adapter PLL init fixes. [SCSI] bfa: Added Fabric Assigned Address(FAA) support [SCSI] bfa: IOC bug fixes. [SCSI] bfa: Enable ASIC block configuration and query. [SCSI] bnx2i: Updated copyright and bump version [SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supported ... Fix up some trivial conflicts in: - drivers/scsi/bnx2fc/{bnx2fc.h,bnx2fc_fcoe.c}: Crazy broadcom version number conflicts - drivers/target/tcm_fc/tfc_cmd.c Just trivial cleanups done on adjacent lines
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits) ALSA: asihpi - Replace with snd_ctl_boolean_mono_info() ALSA: asihpi - HPI version 4.08 ALSA: asihpi - Add volume mute controls ALSA: asihpi - Control name updates ALSA: asihpi - Use size_t for sizeof result ALSA: asihpi - Explicitly include mutex.h ALSA: asihpi - Add new node and message defines ALSA: asihpi - Make local function static ALSA: asihpi - Fix minor typos and spelling ALSA: asihpi - Remove unused structures, macros and functions ALSA: asihpi - Remove spurious adapter index check ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro ALSA: asihpi - DSP code loader API now independent of OS ALSA: asihpi - Remove controlex structs and associated special data transfer code ALSA: asihpi - Increase request and response buffer sizes ALSA: asihpi - Give more meaningful name to hpi request message type ALSA: usb-audio - Add quirk for Roland / BOSS BR-800 ALSA: hda - Remove a superfluous argument of via_auto_init_output() ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs ALSA: hda - Add documentation for codec-specific mixer controls ...
2011-07-23Merge branch 'scsi-fixes'James Bottomley
2011-07-23regmap: Add generic non-memory mapped register access APIMark Brown
There are many places in the tree where we implement register access for devices on non-memory mapped buses, especially I2C and SPI. Since hardware designers seem to have settled on a relatively consistent set of register interfaces this can be effectively factored out into shared code. There are a standard set of formats for marshalling data for exchange with the device, with the actual I/O mechanisms generally being simple byte streams. We create an abstraction for marshaling data into formats which can be sent on the control interfaces, and create a standard method for plugging in actual transport underneath that. This is mostly a refactoring and renaming of the bottom level of the existing code for sharing register I/O which we have in ASoC. A subsequent patch in this series converts ASoC to use this. The main difference in interface is that reads return values by writing to a location provided by a pointer rather than in the return value, ensuring we can use the full range of the type for register data. We also use unsigned types rather than ints for the same reason. As some of the devices can have very large register maps the existing ASoC code also contains infrastructure for managing register caches. This cache work will be moved over in a future stage to allow for separate review, the current patch only deals with the physical I/O. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-22Merge branch 'for-davem' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-07-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits) IB/qib: Defer HCA error events to tasklet mlx4_core: Bump the driver version to 1.0 RDMA/cxgb4: Use printk_ratelimited() instead of printk_ratelimit() IB/mlx4: Support PMA counters for IBoE IB/mlx4: Use flow counters on IBoE ports IB/pma: Add include file for IBA performance counters definitions mlx4_core: Add network flow counters mlx4_core: Fix location of counter index in QP context struct mlx4_core: Read extended capabilities into the flags field mlx4_core: Extend capability flags to 64 bits IB/mlx4: Generate GID change events in IBoE code IB/core: Add GID change event RDMA/cma: Don't allow IPoIB port space for IBoE RDMA: Allow for NULL .modify_device() and .modify_port() methods IB/qib: Update active link width IB/qib: Fix potential deadlock with link down interrupt IB/qib: Add sysfs interface to read free contexts IB/mthca: Remove unnecessary read of PCI_CAP_ID_EXP IB/qib: Remove double define IB/qib: Remove unnecessary read of PCI_CAP_ID_EXP ...
