Since Jassi is doing so much good work and can offer such good review
for the Samsung CPU support add an entry for the Samsung ASoC drivers
to MAINTAINERS listing him.
Acked-by: Jassi Brar <jassi.brar@samsung.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: sound/usb/format: silence uninitialized variable warnings
MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices
MAINTAINERS: Make Wolfson entry also cover CODEC drivers
ASoC: Only tweak WM8994 chip configuration on devices up to rev D
ASoC: Optimise DSP performance for WM8994
ALSA: hda - Fix dynamic ADC change working again
ALSA: hda - Restrict PCM parameters per ELD information over HDMI
sound: oss: sh_dac_audio.c removed duplicated #include
As I made significant changes to the pc87427 driver, I'll be
maintaining it for the year to come.
SMSC's EMC2103 family of temperature/fan controllers have 1
onboard and up to 3 external temperature sensors, and allow
closed-loop control of one fan. This patch adds support for
them.
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits)
ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions}
ARM: 6324/1: cam60: move cam60_spi_devices to .init.data
ARM: 6322/1: imx/pca100: Fix name of spi platform data
ARM: 6321/1: fix syntax error in main Kconfig file
ARM: 6297/1: move U300 timer to dynamic clock lookup
ARM: 6296/1: clock U300 intcon and timer properly
ARM: 6295/1: fix U300 apb_pclk split
ARM: 6306/1: fix inverted MMC card detect in U300
ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID
ARM: 6294/1: etm: do a dummy read from OSSRR during initialization
ARM: 6292/1: coresight: add ETM management registers
ARM: 6288/1: ftrace: document mcount formats
ARM: 6287/1: ftrace: clean up mcount assembly indentation
ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR"
ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE
ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h>
ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3
ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig
ARM: S5PV210: Override FIMC driver name on Aquila board
ARM: S5PC100: enable FIMC on SMDKC100
Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to
different subsystem 'setname' calls, and trivial port types in
include/linux/serial_core.h
arch/arm/Kconfig
arch/arm/mm/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (94 commits)
V4L/DVB: tvp7002: fix write to H-PLL Feedback Divider LSB register
V4L/DVB: dvb: siano: free spinlock before schedule()
V4L/DVB: media: video: pvrusb2: remove custom hex_to_bin()
V4L/DVB: drivers: usbvideo: remove custom implementation of hex_to_bin()
V4L/DVB: Report supported QAM modes on bt8xx
V4L/DVB: media: ir-keytable: null dereference in debug code
V4L/DVB: ivtv: convert to the new control framework
V4L/DVB: ivtv: convert gpio subdev to new control framework
V4L/DVB: wm8739: convert to the new control framework
V4L/DVB: cs53l32a: convert to new control framework
V4L/DVB: wm8775: convert to the new control framework
V4L/DVB: cx2341x: convert to the control framework
V4L/DVB: cx25840: convert to the new control framework
V4L/DVB: cx25840/ivtv: replace ugly priv control with s_config
V4L/DVB: saa717x: convert to the new control framework
V4L/DVB: msp3400: convert to the new control framework
V4L/DVB: saa7115: convert to the new control framework
V4L/DVB: v4l2: hook up the new control framework into the core framework
V4L/DVB: Documentation: add v4l2-controls.txt documenting the new controls API
V4L/DVB: v4l2-ctrls: Whitespace cleanups
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (59 commits)
igbvf.txt: Add igbvf Documentation
igb.txt: Add igb documentation
e100/e1000*/igb*/ixgb*: Add missing read memory barrier
ixgbe: fix build error with FCOE_CONFIG without DCB_CONFIG
netxen: protect tx timeout recovery by rtnl lock
isdn: gigaset: use after free
isdn: gigaset: add missing unlock
solos-pci: Fix race condition in tasklet RX handling
pkt_sched: Fix sch_sfq vs tcf_bind_filter oops
net: disable preemption before call smp_processor_id()
tcp: no md5sig option size check bug
iwlwifi: fix locking assertions
iwlwifi: fix TX tracer
isdn: fix information leak
net: Fix napi_gro_frags vs netpoll path
usbnet: remove noisy and hardly useful printk
rtl8180: avoid potential NULL deref in rtl8180_beacon_work
ath9k: Remove myself from the MAINTAINERS list
libertas: scan before assocation if no BSSID was given
libertas: fix association with some APs by using extended rates
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
This driver adds support for the monitoring features of the Summit
Microelectronics SMM665 Six-Channel Active DC Output Controller/Monitor.
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Samuel Ortiz <sameo@linux.intel.com>
This old address bounces and Sergey doesn't answer at another email
address.
Cc: Sergey Kostyliov <rathamahata@gmail.com>
Laurent is sending auto-replies with a new email address, so might as well
update MAINTAINERS.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Subrata Modak <subrata@linux.vnet.ibm.com>
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Jim Paris <jim@jtan.com>
Cc: Felipe Balbi <felipe.balbi@nokia.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Vitaly Bordug <vitb@kernel.crashing.org>
Cc: Marcelo Tosatti <marcelo@kvack.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Commit f80a3f62383bf673c310926d55142d51f118926d ("Staging: strip: delete
the driver") removed it.
Cc: Viresh Kumar <viresh.kumar@st.com>
Commit d6e976c0d258c9547a308bd8a9a82ec93e2bc6e2 ("UIO: Remove SMX
Cryptengine driver") removed the file.
Acked-by: Ben Nizette <bn@niasdigital.com>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Entered as 822 (10 key typo?).
Acked-by: Maxim Levitsky <maximlevitsky@gmail.com>
Commit 21b4aaa14329db793832e865f15000c5c0192ac3 ("l2tp: Relocate pppol2tp
driver to new net/l2tp directory") moved the file.
Cc: James Chapman <jchapman@katalix.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Use correct file location.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: Leo Chen <leochen@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: check kmalloc() result
arch/tile: catch up on various minor cleanups.
arch/tile: avoid erroneous error return for PTRACE_POKEUSR.
tile: set ARCH_KMALLOC_MINALIGN
tile: remove homegrown L1_CACHE_ALIGN macro
arch/tile: Miscellaneous cleanup changes.
arch/tile: Split the icache flush code off to a generic <arch> header.
arch/tile: Fix bug in support for atomic64_xx() ops.
arch/tile: Shrink the tile-opcode files considerably.
arch/tile: Add driver to enable access to the user dynamic network.
arch/tile: Enable more sophisticated IRQ model for 32-bit chips.
Move list types from <linux/list.h> to <linux/types.h>.
Add wait4() back to the set of <asm-generic/unistd.h> syscalls.
Revert adding some arch-specific signal syscalls to <linux/syscalls.h>.
arch/tile: Do not use GFP_KERNEL for dma_alloc_coherent(). Feedback from fujita.tomonori@lab.ntt.co.jp.
arch/tile: core support for Tilera 32-bit chips.
Fix up the "generic" unistd.h ABI to be more useful.
* 'for-linus' of git://android.kernel.org/kernel/tegra:
[ARM] tegra: add MAINTAINERS entry
[ARM] tegra: harmony: Add harmony board file
[ARM] tegra: add pinmux support
[ARM] tegra: add GPIO support
[ARM] tegra: Add timer support
[ARM] tegra: SMP support
[ARM] tegra: Add clock support
[ARM] tegra: Add IRQ support
[ARM] tegra: initial tegra support
* 'for-linus' of git://github.com/schandinat/linux-2.6:
drivers/video/via/via-gpio.c: fix warning
viafb: Depends on X86
fbdev: section cleanup in viafb driver
viafb: fix accel_flags check_var bug
viafb: probe cleanups
viafb: remove ioctls which break the framebuffer interface
viafb: update fix before calculating depth
viafb: PLL value cleanup
viafb: simplify lcd size "detection"
viafb: fix PCI table
viafb: add lcd scaling support for some IGPs
viafb: improve lcd code readability
viafb: remove duplicated scaling code
MAINTAINERS: update viafb entry
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (82 commits)
firewire: core: add forgotten dummy driver methods, remove unused ones
firewire: add isochronous multichannel reception
firewire: core: small clarifications in core-cdev
firewire: core: remove unused code
firewire: ohci: release channel in error path
firewire: ohci: use memory barriers to order descriptor updates
tools/firewire: nosy-dump: increment program version
tools/firewire: nosy-dump: remove unused code
tools/firewire: nosy-dump: use linux/firewire-constants.h
tools/firewire: nosy-dump: break up a deeply nested function
tools/firewire: nosy-dump: make some symbols static or const
tools/firewire: nosy-dump: change to kernel coding style
tools/firewire: nosy-dump: work around segfault in decode_fcp
tools/firewire: nosy-dump: fix it on x86-64
tools/firewire: add userspace front-end of nosy
firewire: nosy: note ioctls in ioctl-number.txt
firewire: nosy: use generic printk macros
firewire: nosy: endianess fixes and annotations
firewire: nosy: annotate __user pointers and __iomem pointers
firewire: nosy: fix device shutdown with active client
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
ext3: Fix dirtying of journalled buffers in data=journal mode
ext3: default to ordered mode
quota: Use mark_inode_dirty_sync instead of mark_inode_dirty
quota: Change quota error message to print out disk and function name
MAINTAINERS: Update entries of ext2 and ext3
MAINTAINERS: Update address of Andreas Dilger
ext3: Avoid filesystem corruption after a crash under heavy delete load
ext3: remove vestiges of nobh support
ext3: Fix set but unused variables
quota: clean up quota active checks
quota: Clean up the namespace in dqblk_xfs.h
quota: check quota reservation on remove_dquot_ref
devel-stable
drivers/net/irda/sh_irda.c
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/palmt5.c
arch/arm/mach-pxa/palmtreo.c
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
Signed-off-by: Erik Gilling <konkers@android.com>
Signed-off-by: Colin Cross <ccross@android.com>
Acked-by: Olof Johansson <olof@lixom.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
scripts/dtc: Fix a resource leak
Documentation: fix ubuntu distro name
MAINTAINERS: Update kbuild git URLs
Add support for the C variable in the coccicheck script
Add scripts/coccinelle/deref_null.cocci
Add scripts/coccinelle/err_cast.cocci
Add scripts/coccinelle/resource_size.cocci
Add scripts/coccinelle/alloc/kzalloc-simple.cocci
Add scripts/coccinelle/alloc/drop_kmalloc_cast.cocci
Add Documentation/coccinelle.txt
Add a target to use the Coccinelle checker
scripts: decodecode: remove bashisms
Makefile: clarify a comment
checkkconfigsymbols.sh: Kconfig symbols sometimes have lowercase letters
scripts: add nconf into gitignore file
