git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
clockchips.h was typoed as clockevents.h
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (lm78) Become the maintainer
hwmon: (lm78) Make ISA interface depend on CONFIG_ISA
hwmon: (lm78) Avoid forward declarations
hwmon: (sht15) Correct a comment mistake
hwmon: (max1111) Avoid extra memory allocations
hwmon: (it87) Add chassis intrusion detection support
hwmon: (via-cputemp) Add VID reporting support
hwmon-vid: Add support for VIA family 6 model D CPU
hwmon: New driver sch5636
hwmon: (sch5627) Factor out some code shared with sch5636 driver
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Declare myself the maintainer of the lm78 driver. I still have a
running system with one of these chips.
Also count myself as a co-author of the driver. With 34 commits over
6 years, it seems fair.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits)
bnx2x: use pci_pcie_cap()
bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_task
bnx2x: enable internal target-read for 57712 and up only
bnx2x: count statistic ramrods on EQ to prevent MC assert
bnx2x: fix loopback for non 10G link
bnx2x: dcb - send all unmapped priorities to same COS as L2
iwlwifi: Fix build with CONFIG_PM disabled.
gre: fix improper error handling
ipv4: use RT_TOS after some rt_tos conversions
via-velocity: remove duplicated #include
qlge: remove duplicated #include
igb: remove duplicated #include
can: c_can: remove duplicated #include
bnad: remove duplicated #include
net: allow netif_carrier to be called safely from IRQ
bna: Header File Consolidation
bna: HW Error Counter Fix
bna: Add HW Semaphore Unlock Logic
bna: IOC Event Name Change
bna: Mboxq Flush When IOC Disabled
* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits)
OpenRISC: Add MAINTAINERS entry
OpenRISC: Miscellaneous
OpenRISC: Library routines
OpenRISC: Headers
OpenRISC: Traps
OpenRISC: Module support
OpenRISC: GPIO
OpenRISC: Scheduling/Process management
OpenRISC: Idle/Power management
OpenRISC: System calls
OpenRISC: IRQ
OpenRISC: Timekeeping
OpenRISC: DMA
OpenRISC: PTrace
OpenRISC: Build infrastructure
OpenRISC: Signal handling
OpenRISC: Memory management
OpenRISC: Device tree
OpenRISC: Boot code
iomap: make IOPORT/PCI mapping functions conditional
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regulator: Convert tps65023 to use regmap API
regmap: Add SPI bus support
regmap: Add I2C bus support
regmap: Add generic non-memory mapped register access API
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (77 commits)
[SCSI] fix crash in scsi_dispatch_cmd()
[SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwise
[SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpu
[SCSI] bfa: Update the driver version to 3.0.2.1
[SCSI] bfa: Driver and BSG enhancements.
[SCSI] bfa: Added support to query PHY.
[SCSI] bfa: Added HBA diagnostics support.
[SCSI] bfa: Added support for flash configuration
[SCSI] bfa: Added support to obtain SFP info.
[SCSI] bfa: Added support for CEE info and stats query.
[SCSI] bfa: Extend BSG interface.
[SCSI] bfa: FCS bug fixes.
[SCSI] bfa: DMA memory allocation enhancement.
[SCSI] bfa: Brocade-1860 Fabric Adapter vHBA support.
[SCSI] bfa: Brocade-1860 Fabric Adapter PLL init fixes.
[SCSI] bfa: Added Fabric Assigned Address(FAA) support
[SCSI] bfa: IOC bug fixes.
[SCSI] bfa: Enable ASIC block configuration and query.
[SCSI] bnx2i: Updated copyright and bump version
[SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supported
Fix up some trivial conflicts in:
- drivers/scsi/bnx2fc/{bnx2fc.h,bnx2fc_fcoe.c}:
Crazy broadcom version number conflicts
- drivers/target/tcm_fc/tfc_cmd.c
Just trivial cleanups done on adjacent lines
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits)
ALSA: asihpi - Replace with snd_ctl_boolean_mono_info()
ALSA: asihpi - HPI version 4.08
ALSA: asihpi - Add volume mute controls
ALSA: asihpi - Control name updates
ALSA: asihpi - Use size_t for sizeof result
ALSA: asihpi - Explicitly include mutex.h
ALSA: asihpi - Add new node and message defines
ALSA: asihpi - Make local function static
ALSA: asihpi - Fix minor typos and spelling
ALSA: asihpi - Remove unused structures, macros and functions
ALSA: asihpi - Remove spurious adapter index check
ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro
ALSA: asihpi - DSP code loader API now independent of OS
ALSA: asihpi - Remove controlex structs and associated special data transfer code
ALSA: asihpi - Increase request and response buffer sizes
ALSA: asihpi - Give more meaningful name to hpi request message type
ALSA: usb-audio - Add quirk for Roland / BOSS BR-800
ALSA: hda - Remove a superfluous argument of via_auto_init_output()
ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs
ALSA: hda - Add documentation for codec-specific mixer controls
There are many places in the tree where we implement register access for
devices on non-memory mapped buses, especially I2C and SPI. Since hardware
designers seem to have settled on a relatively consistent set of register
interfaces this can be effectively factored out into shared code. There
are a standard set of formats for marshalling data for exchange with the
device, with the actual I/O mechanisms generally being simple byte
streams.
We create an abstraction for marshaling data into formats which can be
sent on the control interfaces, and create a standard method for
plugging in actual transport underneath that.
This is mostly a refactoring and renaming of the bottom level of the
existing code for sharing register I/O which we have in ASoC. A
subsequent patch in this series converts ASoC to use this. The main
difference in interface is that reads return values by writing to a
location provided by a pointer rather than in the return value, ensuring
we can use the full range of the type for register data. We also use
unsigned types rather than ints for the same reason.
As some of the devices can have very large register maps the existing
ASoC code also contains infrastructure for managing register caches.
This cache work will be moved over in a future stage to allow for
separate review, the current patch only deals with the physical I/O.
Acked-by: Liam Girdwood <lrg@ti.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits)
IB/qib: Defer HCA error events to tasklet
mlx4_core: Bump the driver version to 1.0
RDMA/cxgb4: Use printk_ratelimited() instead of printk_ratelimit()
IB/mlx4: Support PMA counters for IBoE
IB/mlx4: Use flow counters on IBoE ports
IB/pma: Add include file for IBA performance counters definitions
mlx4_core: Add network flow counters
mlx4_core: Fix location of counter index in QP context struct
mlx4_core: Read extended capabilities into the flags field
mlx4_core: Extend capability flags to 64 bits
IB/mlx4: Generate GID change events in IBoE code
IB/core: Add GID change event
RDMA/cma: Don't allow IPoIB port space for IBoE
RDMA: Allow for NULL .modify_device() and .modify_port() methods
IB/qib: Update active link width
IB/qib: Fix potential deadlock with link down interrupt
IB/qib: Add sysfs interface to read free contexts
IB/mthca: Remove unnecessary read of PCI_CAP_ID_EXP
IB/qib: Remove double define
IB/qib: Remove unnecessary read of PCI_CAP_ID_EXP
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1287 commits)
icmp: Fix regression in nexthop resolution during replies.
net: Fix ppc64 BPF JIT dependencies.
acenic: include NET_SKB_PAD headroom to incoming skbs
ixgbe: convert to ndo_fix_features
ixgbe: only enable WoL for magic packet by default
ixgbe: remove ifdef check for non-existent define
ixgbe: Pass staterr instead of re-reading status and error bits from descriptor
ixgbe: Move interrupt related values out of ring and into q_vector
ixgbe: add structure for containing RX/TX rings to q_vector
ixgbe: inline the ixgbe_maybe_stop_tx function
ixgbe: Update ATR to use recorded TX queues instead of CPU for routing
igb: Fix for DH89xxCC near end loopback test
e1000: always call e1000_check_for_link() on e1000_ce4100 MACs.
netxen: add fw version compatibility check
be2net: request native mode each time the card is reset
ipv4: Constrain UFO fragment sizes to multiples of 8 bytes
virtio_net: Fix panic in virtnet_remove
ipv6: make fragment identifications less predictable
ipv6: unshare inetpeers
can: make function can_get_bittiming static
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (78 commits)
mmc: MAINTAINERS: add myself as a tmio-mmc maintainer
mmc: print debug messages for runtime PM actions
mmc: fix runtime PM with -ENOSYS suspend case
mmc: at91_mci: move register header from include/ to drivers/
mmc: mxs-mmc: fix clock rate setting
mmc: tmio: fix a deadlock
mmc: tmio: fix a recently introduced bug in DMA code
mmc: sh_mmcif: maximize power saving
mmc: tmio: maximize power saving
mmc: tmio: fix recursive spinlock, don't schedule with interrupts disabled
mmc: Added quirks for Ricoh 1180:e823 lower base clock frequency
mmc: omap_hsmmc: fix oops in omap_hsmmc_dma_cb()
mmc: omap_hsmmc: refactor duplicated code
mmc: omap_hsmmc: fix a few bugs when setting the clock divisor
mmc: omap_hsmmc: introduce start_clock and re-use stop_clock
mmc: omap_hsmmc: split duplicate code to calc_divisor() function
mmc: omap_hsmmc: move hardcoded frequency constants to defines
mmc: omap_hsmmc: correct debug report error status mnemonics
mmc: block: fixed NULL pointer dereference
mmc: documentation of mmc non-blocking request usage and design.
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (32 commits)
MAINTAINERS: change e-mail of Adrian Hunter
UBIFS: fix master node recovery
UBIFS: improve power cut emulation testing
UBIFS: rename recovery testing variables
UBIFS: remove custom list of superblocks
UBIFS: stop re-defining UBI operations
UBIFS: switch to I/O helpers
UBIFS: switch to ubifs_leb_write
UBIFS: switch to ubifs_leb_read
UBIFS: introduce more I/O helpers
UBIFS: always print stacktrace when switching to R/O mode
UBIFS: remove unused and unneeded debugging function
UBIFS: add global debugfs knobs
UBIFS: introduce debugfs helpers
UBIFS: re-arrange debugging code a bit
UBIFS: be more informative in failure mode
UBIFS: switch self-check knobs to debugfs
UBIFS: lessen amount of debugging check types
UBIFS: introduce helper functions for debugging checks and tests
UBIFS: amend debugging inode size check function prototype
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
... he does not work in Nokia any longer.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Chris Ball <cjb@laptop.org>
Update the OMAP HSMMC entry from the MAINTAINERS file as I will
no longer be able to maintain this driver.
Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com>
[khilman@ti.com: change to Orphan rather than complete removal]
Signed-off-by: Kevin Hilman <khilman@ti.com>
Acked-by: Venkatraman S <svenkatr@ti.com>
Kalle Valo has asked me to take over the maintenance of the wl1251
driver. Thanks Kalle for all his work on the wl1251 driver, I'll try
to keep up with his good work from now on.
At the same time, update the Web URL to something more specific.
There's not much in that page, but we will try to update it soon.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Acked-by: Kalle Valo <kvalo@adurom.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
net/bluetooth/l2cap_core.c
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Update my email address
Signed-off-by: Josh Boyer <jwboyer@gmail.com>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6994/1: smp_twd: Fix typo in 'twd_timer_rate' printing
ARM: 6987/1: l2x0: fix disabling function to avoid deadlock
ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1
ARM: 6980/1: mmci: use StartBitErr to detect bad connections
ARM: 6979/1: mach-vt8500: add forgotten irq_data conversion
ARM: move memory layout sanity checking before meminfo initialization
ARM: 6990/1: MAINTAINERS: add entry for ARM PMU profiling and debugging
ARM: 6989/1: perf: do not start the PMU when no events are present
ARM: dmabounce: fix map_single() error return value
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Michael Buesch <m@bues.ch>
Move location of quilt series for kernel-doc patches.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (46 commits)
[media] rc: call input_sync after scancode reports
[media] imon: allow either proto on unknown 0xffdc
[media] imon: auto-config ffdc 7e device
[media] saa7134: fix raw IR timeout value
[media] rc: fix ghost keypresses with certain hw
[media] [staging] lirc_serial: allocate irq at init time
[media] lirc_zilog: fix spinning rx thread
[media] keymaps: fix table for pinnacle pctv hd devices
[media] ite-cir: 8709 needs to use pnp resource 2
[media] V4L: mx1-camera: fix uninitialized variable
[media] omap_vout: Added check in reqbuf & mmap for buf_size allocation
[media] OMAP_VOUT: Change hardcoded device node number to -1
[media] OMAP_VOUTLIB: Fix wrong resizer calculation
[media] uvcvideo: Disable the queue when failing to start
[media] uvcvideo: Remove buffers from the queues when freeing
[media] uvcvideo: Ignore entities for terminals with no supported format
[media] v4l: Don't access media entity after is has been destroyed
[media] media: omap3isp: fix a potential NULL deref
[media] media: vb2: fix allocation failure check
[media] media: vb2: reset queued_count value during queue reinitialization
Fix up trivial conflict in MAINTAINERS as per Mauro
Following a request from Russell King:
http://lists.infradead.org/pipermail/linux-arm-kernel/2011-June/055031.html
Add myself as the ARM PMU profiling and debugging maintainer. This
covers the ARM implementations of perf, oprofile and hw_breakpoint along
with the glue for this to work on different platforms.
Cc: Jean Pihet <j-pihet@ti.com>
Acked-by: Jamie Iles <jamie@jamieiles.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits)
usbnet: Remove over-broad module alias from zaurus.
MAINTAINERS: drop Michael from bfin_mac driver
net/can: activate bit-timing calculation and netlink based drivers by default
rionet: fix NULL pointer dereference in rionet_remove
net+crypto: Use vmalloc for zlib inflate buffers.
netfilter: Fix ip_route_me_harder triggering ip_rt_bug
ipv4: Fix IPsec slowpath fragmentation problem
ipv4: Fix packet size calculation in __ip_append_data
cxgb3: skb_record_rx_queue now records the queue index relative to the net_device.
bridge: Only flood unregistered groups to routers
qlge: Add maintainer.
MAINTAINERS: mark socketcan-core lists as subscribers-only
MAINTAINERS: Remove Sven Eckelmann from BATMAN ADVANCED
r8169: fix wrong register use.
net/usb/kalmia: signedness bug in kalmia_bind()
net/usb: kalmia: Various fixes for better support of non-x86 architectures.
rtl8192cu: Fix missing firmware load
udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packet
ipv6/udp: Use the correct variable to determine non-blocking condition
netconsole: fix build when CONFIG_NETCONSOLE_DYNAMIC is turned on
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6:
MAINTAINERS: update AVR32 and AT32AP maintainers
This alters the maintenance of the AVR32 architecture and the AT32AP machine
code to be shared between Haavard Skinnemoen and me. The status is also changed
to maintained, as we no longer are being paid to look after this architecture.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
We want people to just use the list now rather than hitting up people
who are no longer responsible for it.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Update MAINTAINERS to refelect new people working on myri10ge
Signed-off-by: Jon Mason <mason@myri.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
MAINTAINERS: add myself as maintainer of USB/IP
usb: r8a66597-hcd: fix cannot detect low/full speed device
USB: ehci-ath79: fix a NULL pointer dereference
USB: Add new FT232H chip to drivers/usb/serial/ftdi_sio.c
usb/isp1760: Fix bug preventing the unlinking of control urbs
USB: Fix up URB error codes to reflect implementation.
xhci: Always set urb->status to zero for isoc endpoints.
xhci: Add reset on resume quirk for asrock p67 host
xHCI 1.0: Incompatible Device Error
USB: don't let errors prevent system sleep
USB: don't let the hub driver prevent system sleep
USB: change maintainership of ohci-hcd and ehci-hcd
xHCI 1.0: Force Stopped Event(FSE)
xhci: Don't warn about zeroed bMaxBurst descriptor field.
USB: Free bandwidth when usb_disable_device is called.
xhci: Reject double add of active endpoints.
USB: TI 3410/5052 USB Serial Driver: Fix mem leak when firmware is too big.
usb: musb: gadget: clear TXPKTRDY flag when set FLUSHFIFO
usb: musb: host: compare status for negative error values
This patch adds support for the Analog Devices ADAV801 and ADAV803 audio codec.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com>
The socketcan-core lists require subscription, so mark them as such.
