path: root/MAINTAINERS
2015-03-30Merge remote-tracking branch 'remotes/ubifs-v3.1/master' into tegra-nand-nextMarcel Ziswiler
Conflicts: drivers/mtd/ubi/ubi.h drivers/mtd/ubi/wl.c
2013-02-22UBI: Wire-up fastmapRichard Weinberger
Make fastmap known to Kconfig, UBI Makefile and MAINTAINERS. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-01-12MAINTAINERS: stable: Update addressJoe Perches
commit bc7a2f3abc636d7cab84258a48e77b08fb5fd3d6 upstream. The old address hasn't worked since the great intrusion of August 2011. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11MAINTANERS: update Qualcomm Atheros addressesLuis R. Rodriguez
commit fe8e084455f273b32cc57a5fbaf6c22ef984d657 upstream. Qualcomm ate up Atheros, all of the old e-mail addresses no longer work and e-mails sent to it will bounce. Update the addresses to the new shiny Qualcomm Atheros (QCA) ones. Cc: stable@kernel.org Cc: netdev@vger.kernel.org Cc: jouni@qca.qualcomm.com Cc: yangjie@qca.qualcomm.com Cc: vthiagar@qca.qualcomm.com Cc: senthilb@qca.qualcomm.com Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-24Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: fix superpage support in pfn_to_dma_pte() intel-iommu: set iommu_superpage on VM domains to lowest common denominator intel-iommu: fix return value of iommu_unmap() API MAINTAINERS: Update VT-d entry for drivers/pci -> drivers/iommu move intel-iommu: Export a flag indicating that the IOMMU is used for iGFX. intel-iommu: Workaround IOTLB hang on Ironlake GPU intel-iommu: Fix AB-BA lockdep report
2011-10-19ehea: Change maintainer to meThadeu Lima de Souza Cascardo
Breno Leitao has passed the maintainership to me. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Cc: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Breno Leitão <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19MAINTAINERS: Update VT-d entry for drivers/pci -> drivers/iommu moveRoland Dreier
Commit 166e9278a3f9 ("x86/ia64: intel-iommu: move to drivers/iommu/") moved the VT-d driver to drivers/iommu, but left the "F:" line in MAINTAINERS pointing to drivers/pci, which breaks scripts/get_maintainer.pl. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-10MAINTAINERS: Update tegra maintainer informationOlof Johansson
A couple of changes to the Tegra maintainership setup: I'm very glad to bring on Stephen Warren on board as a maintainer. The work he has done so far is excellent, and the fact that he works for Nvidia means he has long-term interest in the platform. Erik Gilling did an astounding amount of work on getting things up and running but has been a silent partner on the maintainership side for a while, and is stepping down. Thanks for your contributions so far, Erik. Finally, update the git URL since I'll take over running the main repo for a while. Overall maintainership model isn't changing much at this time: We'll all three review patches as appropriate, and one of us will collect the main repo (me at this time). Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Erik Gilling <konkers@android.com> Acked-by: Colin Cross <ccross@android.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-29MAINTAINERS: tehuti: Alexander Indenbaum's address bouncesIan Campbell
I got: Generating server: Tehuti.onmicrosoft.com baum@tehutinetworks.net #< #5.1.1 smtp;550 5.1.1 RESOLVER.ADR.RecipNotFound; not found> #SMTP# Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Alexander Indenbaum <baum@tehutinetworks.net> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-18Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: (62 commits) ipv6: don't use inetpeer to store metrics for routes. can: ti_hecc: include linux/io.h IRDA: Fix global type conflicts in net/irda/irsysctl.c v2 net: Handle different key sizes between address families in flow cache net: Align AF-specific flowi structs to long ipv4: Fix fib_info->fib_metrics leak caif: fix a potential NULL dereference sctp: deal with multiple COOKIE_ECHO chunks ibmveth: Fix checksum offload failure handling ibmveth: Checksum offload is always disabled ibmveth: Fix issue with DMA mapping failure ibmveth: Fix DMA unmap error pch_gbe: support ML7831 IOH pch_gbe: added the process of FIFO over run error pch_gbe: fixed the issue which receives an unnecessary packet. sfc: Use 64-bit writes for TX push where possible Revert "sfc: Use write-combining to reduce TX latency" and follow-ups bnx2x: Fix ethtool advertisement bnx2x: Fix 578xx link LED bnx2x: Fix XMAC loopback test ...
2011-09-15Merge branch 'for-linus' of git://github.com/tiwai/soundLinus Torvalds
* 'for-linus' of git://github.com/tiwai/sound: ALSA: pcm - fix race condition in wait_for_avail() ALSA: HDA: Cirrus - fix "Surround Speaker" volume control name ALSA: hda - Terminate the recursive connection search properly ASoC: Fix trivial build regression in Kirkwood I2S ASoC: Blackfin: bf5xx-ad193x: Fix codec device name ASoC: Fix reporting of partial jack updates ASoC: imx: Fix build warning of unused 'card' variable ASoC: Fix register cache sync register_writable WARN_ONs ASoC: snd_soc_codec_{readable,writable}_register change default to true ASoC: soc-dapm: Fix parameter comment for snd_soc_dapm_free MAINTAINERS: Add some missed Wolfson files ASoC: MPC5200: replace of_device with platform_device
2011-09-14MAINTAINERS: update e-mail address of Benny HalevyBenny Halevy
Acked-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14Merge git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6Linus Torvalds
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: (25 commits) [SCSI] bnx2i: Fixed the endian on TTT for NOP out transmission [SCSI] libfc: fix referencing to fc_fcp_pkt from the frame pointer via fr_fsp() [SCSI] libfc: block SCSI eh thread for blocked rports [SCSI] libfc: fix fc_eh_host_reset [SCSI] fcoe: Fix deadlock between fip's recv_work and rtnl [SCSI] qla2xxx: Update version number to 8.03.07.07-k. [SCSI] qla2xxx: Set the task attributes after memsetting fcp cmnd. [SCSI] qla2xxx: Correct inadvertent loop state transitions during port-update handling. [SCSI] qla2xxx: Save and restore irq in the response queue interrupt handler. [SCSI] qla2xxx: Double check for command completion if abort mailbox command fails. [SCSI] qla2xxx: Acquire hardware lock while manipulating dsd list. [SCSI] qla2xxx: Fix qla24xx revision check while enabling interrupts. [SCSI] qla2xxx: T10 DIF - Fix incorrect error reporting. [SCSI] qla2xxx: T10 DIF - Handle uninitalized sectors. [SCSI] hpsa: fix physical device lun and target numbering problem [SCSI] hpsa: fix problem that OBDR devices are not detected [SCSI] isci: add version number [SCSI] isci: fix event-get pointer increment [SCSI] isci: dynamic interrupt coalescing [SCSI] isci: Leave requests alone if already terminating. ...
2011-08-30MAINTAINERS: Update BNA 10G MaintainerIan Campbell
ddutt@brocade.com bounces with 550 "RESOLVER.ADR.RecipNotFound" Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rasesh Mody <rmody@brocade.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joe Perches <joe@perches.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30MAINTAINERS: Update Cisco VIC driver maintainersIan Campbell
vkolluri@cisco.com bounces and I get "Unknown address error 550". Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Christian Benvenuti <benve@cisco.com> Cc: Roopa Prabhu <roprabhu@cisco.com> Cc: David Wang <dwang2@cisco.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joe Perches <joe@perches.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30MAINTAINERS: Update ATLX driver maintainersIan Campbell
jie.yang@atheros.com bounces and I get a 550 "Unknown address error". Perhaps they have moved on? Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <chris.snook@gmail.com> Cc: Jie Yang <jie.yang@atheros.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joe Perches <joe@perches.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2011-08-30netfilter: update netfilter git URLPatrick McHardy
Netfilter git trees are moving to a directory shared by Pablo and myself, update git URLs. Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-08-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (42 commits) netpoll: fix incorrect access to skb data in __netpoll_rx cassini: init before use in cas_interruptN. can: ti_hecc: Fix uninitialized spinlock in probe can: ti_hecc: Fix unintialized variable net: sh_eth: fix the compile error net/phy: fix DP83865 phy interrupt handler sendmmsg/sendmsg: fix unsafe user pointer access ibmveth: Fix leak when recycling skb and hypervisor returns error arp: fix rcu lockdep splat in arp_process() bridge: fix a possible use after free bridge: Pseudo-header required for the checksum of ICMPv6 mcast: Fix source address selection for multicast listener report MAINTAINERS: Update GIT trees for network development ath9k: Fix PS wrappers in ath9k_set_coverage_class carl9170: Fix mismatch in carl9170_op_set_key mutex lock-unlock wl12xx: add max_sched_scan_ssids value to the hw description wl12xx: Fix validation of pm_runtime_get_sync return value wl12xx: Remove obsolete testmode NVS push command bcma: add uevent to the bus, to autoload drivers ath9k_hw: Fix STA (AR9485) bringup issue due to incorrect MAC address ...
2011-08-29MAINTAINERS: change framebuffer maintainerFlorian Tobias Schandinat
As Paul has not much time for it I take over maintaining the framebuffer subsystem. Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-29MAINTAINERS: Add some missed Wolfson filesMark Brown
Mostly input related. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (32 commits) ALSA: hda: Conexant: Allow different output types to share DAC ASoC: Correct element count for WM8996 sidetone HPF ASoC: Tegra: wm8903 machine driver: Drop Ventana support ASoC: Add samsung maintainer ASoC: Add Springbank I/O card to Speyside Kconfig ALSA: hda/conexant - Enable ADC-switching for auto-mic mode, too ALSA: hda - Fix double-headphone/speaker paths for Cxt auto-parser ALSA: hda - Update jack-sense info even when no automute is set ALSA: hda - Fix output-path initialization for Realtek auto-parser sound/soc/fsl/mpc8610_hpcd.c: add missing of_node_put sound/soc/fsl/p1022_ds.c: add missing of_node_put sound/soc/ep93xx/ep93xx-i2s.c: add missing kfree sound/soc/kirkwood/kirkwood-i2s.c: add missing kfree ASoC: soc-core: use GFP_KERNEL flag for kmalloc in snd_soc_cnew sound/soc/fsl/fsl_dma.c: add missing of_node_put ASoC: Clear completions from late WM8996 FLL lock IRQs ASoC: Clear any outstanding WM8962 FLL lock completions before waiting ASoC: Ensure we only run Speyside WM8962 bias level callbacks once ASoC: Fix configuration of WM8996 input enables ASoC: WM8996 record paths need AIFCLK ...
2011-08-25MAINTAINERS: Paul Menage has movedWanlong Gao
Paul said: I left Google at the end of last week - if it's not bouncing already, menage@google.com isn't going to work for much longer. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Acked-by: Paul Menage <paul@paulmenage.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25MAINTAINERS: Evgeniy has movedEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-24MAINTAINERS: Update GIT trees for network developmentNicolas de Pesloüan
Remove -2.6 from net and net-next tree names. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24ASoC: Add samsung maintainerSangbeom Kim
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-23[SCSI] isci: Update MAINTAINERS entry for the isci driverDave Jiang
Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-08-18Merge branch 'perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
2011-08-18MAINTAINERS: Fix list of perf events source filesGeunsik Lim
Recent changes made kernel/perf_event.c be split and moved to kernel/events/. Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Kosina <trivial@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1313653497-27263-1-git-send-email-leemgs1@gmail.com Signed-off-by: Geunsik Lim <geunsik.lim@samsung.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Fix compile warning in wm8750.c ASoC: omap: Update e-mail address of Jarkko Nikula ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: Terminate WM8750 SPI device ID table ASoC: Add missing break in WM8994 probe ALSA: snd-usb-caiaq: Correct offset fields of outbound iso_frame_desc ALSA: azt3328 - adjust error handling code to include debugging code ALSA: hda - Add CONFIG_SND_HDA_POWER_SAVE to stac_vrefout_set() ALSA: usb-audio - Add quirk for BOSS Micro BR-80 ASoC: Fix typo in wm8750 spi_ids ASoC: Fix warning in Speyside WM8962 ASoC: Fix SPI driver binding for WM8987 ASoC: Fix binding of WM8750 on Jive ASoC: WM8903: Free IRQ on device removal ASoC: Tegra: wm8903 machine driver: Allow re-insertion of module ASoC: Tegra: tegra_pcm_deallocate_dma_buffer: Don't OOPS
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-11MAINTAINERS: Update linus' git repositoryTracey Dent
Change to new git tree - (git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git). Signed-off-by: Tracey Dent <tdent48227@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-10Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Really fix build without CONFIG_PCI powerpc: Fix build without CONFIG_PCI powerpc/4xx: Fix build of PCI code on 405 powerpc/pseries: Simplify vpa deregistration functions powerpc/pseries: Cleanup VPA registration and deregistration errors powerpc/pseries: Fix kexec on recent firmware versions MAINTAINERS: change maintainership of mpc5xxx powerpc: Make KVM_GUEST default to n powerpc/kvm: Fix build errors with older toolchains powerpc: Lack of ibm,io-events not that important! powerpc: Move kdump default base address to half RMO size on 64bit powerpc/perf: Disable pagefaults during callchain stack read ppc: Remove duplicate definition of PV_POWER7 powerpc: pseries: Fix kexec on machines with more than 4TB of RAM powerpc: Jump label misalignment causes oops at boot powerpc: Clean up some panic messages in prom_init powerpc: Fix device tree claim code powerpc: Return the_cpu_ spec from identify_cpu powerpc: mtspr/mtmsr should take an unsigned long
2011-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits) ipv6: check for IPv4 mapped addresses when connecting IPv6 sockets mlx4: decreasing ref count when removing mac net: Fix security_socket_sendmsg() bypass problem. net: Cap number of elements for sendmmsg net: sendmmsg should only return an error if no messages were sent ixgbe: fix PHY link setup for 82599 ixgbe: fix __ixgbe_notify_dca() bail out code igb: fix WOL on second port of i350 device e1000e: minor re-order of #include files e1000e: remove unnecessary check for NULL pointer intel drivers: repair missing flush operations macb: restore wrap bit when performing underrun cleanup cdc_ncm: fix endianness problem. irda: use PCI_VENDOR_ID_* mlx4: Fixing Ethernet unicast packet steering net: fix NULL dereferences in check_peer_redir() bnx2x: Clear MDIO access warning during first driver load bnx2x: Fix BCM578xx MAC test bnx2x: Fix BCM54618se invalid link indication bnx2x: Fix BCM84833 link ...
2011-08-05MAINTAINERS: change maintainership of mpc5xxxAnatolij Gustschin
Grant intends to hand over maintainership of mpc5xxx to me. Change MPC5XXX entry in MAINTAINERS accordingly. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-08-03Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle: stop depending on pm_idle x86 idle: move mwait_idle_with_hints() to where it is used cpuidle: replace xen access to x86 pm_idle and default_idle cpuidle: create bootparam "cpuidle.off=1" mrst_pmu: driver for Intel Moorestown Power Management Unit
2011-08-03Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data target: Fix bug for transport_generic_wait_for_tasks with direct operation target: iscsi_target depends on NET target: Fix WRITE_SAME_16 lba assignment breakage MAINTAINERS: Add target-devel list for drivers/target/ iscsi-target: Fix CONFIG_SMP=n and CONFIG_MODULES=n build failure iscsi-target: Fix snprintf usage with MAX_PORTAL_LEN iscsi-target: Fix uninitialized usage of cmd->pad_bytes iscsi-target: strlen() doesn't count the terminator iscsi-target: Fix NULL dereference on allocation failure
2011-08-03mrst_pmu: driver for Intel Moorestown Power Management UnitLen Brown
The Moorestown (MRST) Power Management Unit (PMU) driver directs the SOC power states in the "Langwell" south complex (SCU). It hooks pci_platform_pm_ops[] and thus observes all PCI ".set_state" requests. For devices in the SC, the pmu driver translates those PCI requests into the appropriate commands for the SCU. The PMU driver helps implement S0i3, a deep system idle power idle state. Entry into S0i3 is via cpuidle, just like regular processor c-states. S0i3 depends on pre-conditions including uni-processor, graphics off, and certain IO devices in the SC must be off. If those pre-conditions are met, then the PMU allows cpuidle to enter S0i3, otherwise such requests are demoted, either to Atom C4 or Atom C6. This driver is based on prototype work by Bruce Flemming, Illyas Mansoor, Rajeev D. Muralidhar, Vishwesh M. Rudramuni, Hari Seshadri and Sujith Thomas. The current driver also includes contributions from H. Peter Anvin, Arjan van de Ven, Kristen Accardi, and Yong Wang. Thanks for additional review feedback from Alan Cox and Randy Dunlap. Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-02MAINTAINERS: Add keyword match for of_match_table to device tree sectionMark Brown
If a patch is working with an of_match_table it's probably adding an OF binding to a driver in which case the binding ought to be reviewed by the device tree folks to make sure that things like the device matches are set up correctly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-01doc: Update the MAINTAINERS info for Paul MoorePaul Moore
My @hp.com will no longer be valid starting August 5, 2011 so an update is necessary. My new email address is employer independent so we don't have to worry about doing this again any time soon. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01MAINTAINERS: Remove Pekka Savola from ipv6.David S. Miller
2011-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutilsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils: cpupower: Do detect IDA (opportunistic processor performance) via cpuid cpupower: Show Intel turbo ratio support via ./cpupower frequency-info cpupowerutils: increase MAX_LINE_LEN cpupower: Rename package from cpupowerutils to cpupower cpupowerutils: Rename: libcpufreq->libcpupower cpupowerutils: use kernel version-derived version string cpupowerutils: utils - ConfigStyle bugfixes cpupowerutils: helpers - ConfigStyle bugfixes cpupowerutils: idle_monitor - ConfigStyle bugfixes cpupowerutils: lib - ConfigStyle bugfixes cpupowerutils: bench - ConfigStyle bugfixes cpupowerutils: do not update po files on each and every compile cpupowerutils: remove ccdv, use kernel quiet/verbose mechanism cpupowerutils: use COPYING, CREDITS from top-level directory cpupowerutils - cpufrequtils extended with quite some features
2011-07-30Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits) hwmon: (lm90) Refactor reading of config2 register hwmon: (lm90) Make SA56004 detection more robust hwmon: (lm90) Simplify handling of extended local temp register hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066 hwmon: (max34440) Add support for peak attributes hwmon: (max8688) Add support for peak attributes hwmon: (max16064) Add support for peak attributes hwmon: (adm1275) Add support for peak attributes hwmon: (pmbus) Add support for peak attributes hwmon: Add new attributes to sysfs ABI hwmon: (pmbus) Strengthen check for status register existence hwmon: (pmbus) Add support for virtual pages hwmon: (pmbus) Support reading and writing of word registers in device specific code hwmon: (pmbus) Increase attribute name size hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices hwmon: (pmbus) Add support for VID output voltage mode hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus hwmon: (coretemp) Add core/pkg threshold support to Coretemp hwmon: (lm95241) Add support for LM95231 hwmon: LM95245 driver ...
2011-07-29cpupowerutils - cpufrequtils extended with quite some featuresDominik Brodowski
CPU power consumption vs performance tuning is no longer limited to CPU frequency switching anymore: deep sleep states, traditional dynamic frequency scaling and hidden turbo/boost frequencies are tied close together and depend on each other. The first two exist on different architectures like PPC, Itanium and ARM, the latter (so far) only on X86. On X86 the APU (CPU+GPU) will only run most efficiently if CPU and GPU has proper power management in place. Users and Developers want to have *one* tool to get an overview what their system supports and to monitor and debug CPU power management in detail. The tool should compile and work on as many architectures as possible. Once this tool stabilizes a bit, it is intended to replace the Intel-specific tools in tools/power/x86 Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-07-28MAINTAINERS: orphan FrameRelay DLCIJoe Perches
Mike McLagan hasn't contributed in many years and his email bounces. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbusGuenter Roeck
Since the number of PMBus drivers is getting large, move them into directory drivers/hwmon/pmbus to improve readability and scalability. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: Driver for MAX1668David George
This patch adds support for MAX1668 and compatible temperature sensors. Signed-off-by: David George <david.george@ska.ac.za> [guenter.roeck@ericsson.com: minor cleanup of probe error path] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits) tpm_nsc: Fix bug when loading multiple TPM drivers tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block tpm: Fix compilation warning when CONFIG_PNP is not defined TOMOYO: Update kernel-doc. tpm: Fix a typo tpm_tis: Probing function for Intel iTPM bug tpm_tis: Fix the probing for interrupts tpm_tis: Delay ACPI S3 suspend while the TPM is busy tpm_tis: Re-enable interrupts upon (S3) resume tpm: Fix display of data in pubek sysfs entry tpm_tis: Add timeouts sysfs entry tpm: Adjust interface timeouts if they are too small tpm: Use interface timeouts returned from the TPM tpm_tis: Introduce durations sysfs entry tpm: Adjust the durations if they are too small tpm: Use durations returned from TPM TOMOYO: Enable conditional ACL. TOMOYO: Allow using argv[]/envp[] of execve() as conditions. TOMOYO: Allow using executable's realpath and symlink's target as conditions. TOMOYO: Allow using owner/group etc. of file objects as conditions. ... Fix up trivial conflict in security/tomoyo/realpath.c
2011-07-27MAINTAINERS: Add target-devel list for drivers/target/Nicholas Bellinger
Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-26Merge branch 'next/soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: MAINTAINERS: add maintainer of CSR SiRFprimaII machine ARM: CSR: initializing L2 cache ARM: CSR: mapping early DEBUG_LL uart ARM: CSR: Adding CSR SiRFprimaII board support OMAP4: clocks: Update the clock tree with 4460 clock nodes OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts OMAP4: ID: add omap_has_feature for max freq supported OMAP: ID: introduce chip detection for OMAP4460 ARM: Xilinx: merge board file into main platform code ARM: Xilinx: Adding Xilinx board support Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
