path: root/MAINTAINERS
2013-08-30MAINTAINERS: change my DT related maintainer addressIan Campbell
Filtering capabilities on my work email are pretty much non-existent and this has turned out to be something of a firehose... Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Olof Johansson <olof@lixom.net> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A handful of fixes for 3.11 are still trickling in. These are: - A couple of fixes for older OMAP platforms - Another few fixes for at91 (lateish due to European summer vacations) - A late-found problem with USB on Tegra, fix is to keep VBUS regulator on at all times - One fix for Exynos 5440 dealing with CPU detection - One MAINTAINERS update" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: tegra: always enable USB VBUS regulators ARM: davinci: nand: specify ecc strength ARM: OMAP: rx51: change musb mode to OTG ARM: OMAP2: fix musb usage for n8x0 MAINTAINERS: Update email address for Benoit Cousson ARM: at91/DT: fix at91sam9n12ek memory node ARM: at91: add missing uart clocks DT entries ARM: SAMSUNG: fix to support for missing cpu specific map_io ARM: at91/DT: at91sam9x5ek: fix USB host property to enable port C
2013-08-16MAINTAINERS: Change ownership for SGI specific modules.Robin Holt
I have taken a different job. I am removing myself as maintainer of GRU. Dimitri will continue to maintain the SGI GRU driver, changing the XP/XPC/XPNET maintainer to Cliff Whickman, but leaving behind my personal email address to answer any questions about the design or operation of the XP family of drivers. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-16MAINTAINERS: Update email address for Benoit CoussonBenoit Cousson
Goodbye TI. Welcome new life! Signed-off-by: Benoit Cousson <bcousson@baylibre.com> Cc: Javier Martinez Canillas <javier.martinez@collabora.co.uk> [tony@atomide.com: updated subject for the name] Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix SKB leak in 8139cp, from Dave Jones. 2) Fix use of *_PAGES interfaces with mlx5 firmware, from Moshe Lazar. 3) RCU conversion of macvtap introduced two races, fixes by Eric Dumazet 4) Synchronize statistic flows in bnx2x driver to prevent corruption, from Dmitry Kravkov 5) Undo optimization in IP tunneling, we were using the inner IP header in some cases to inherit the IP ID, but that isn't correct in some circumstances. From Pravin B Shelar 6) Use correct struct size when parsing netlink attributes in rtnl_bridge_getlink(). From Asbjoern Sloth Toennesen 7) Length verifications in tun_get_user() are bogus, from Weiping Pan and Dan Carpenter 8) Fix bad merge resolution during 3.11 networking development in openvswitch, albeit a harmless one which added some unreachable code. From Jesse Gross 9) Wrong size used in flexible array allocation in openvswitch, from Pravin B Shelar 10) Clear out firmware capability flags the be2net driver isn't ready to handle yet, from Sarveshwar Bandi 11) Revert DMA mapping error checking addition to cxgb3 driver, it's buggy. From Alexey Kardashevskiy 12) Fix regression in packet scheduler rate limiting when working with a link layer of ATM. From Jesper Dangaard Brouer 13) Fix several errors in TCP Cubic congestion control, in particular overflow errors in timestamp calculations. From Eric Dumazet and Van Jacobson 14) In ipv6 routing lookups, we need to backtrack if subtree traversal don't result in a match. From Hannes Frederic Sowa 15) ipgre_header() returns incorrect packet offset. Fix from Timo Teräs 16) Get "low latency" out of the new MIB counter names. From Eliezer Tamir 17) State check in ndo_dflt_fdb_del() is inverted, from Sridhar Samudrala 18) Handle TCP Fast Open properly in netfilter conntrack, from Yuchung Cheng 19) Wrong memcpy length in pcan_usb driver, from Stephane Grosjean 20) Fix dealock in TIPC, from Wang Weidong and Ding Tianhong 21) call_rcu() call to destroy SCTP transport is done too early and might result in an oops. From Daniel Borkmann 22) Fix races in genetlink family dumps, from Johannes Berg 23) Flags passed into macvlan by the user need to be validated properly, from Michael S Tsirkin 24) Fix skge build on 32-bit, from Stephen Hemminger 25) Handle malformed TCP headers properly in xt_TCPMSS, from Pablo Neira Ayuso 26) Fix handling of stacked vlans in vlan_dev_real_dev(), from Nikolay Aleksandrov 27) Eliminate MTU calculation overflows in esp{4,6}, from Daniel Borkmann 28) neigh_parms need to be setup before calling the ->ndo_neigh_setup() method. From Veaceslav Falico 29) Kill out-of-bounds prefetch in fib_trie, from Eric Dumazet 30) Don't dereference MLD query message if the length isn't value in the bridge multicast code, from Linus Lüssing 31) Fix VXLAN IGMP join regression due to an inverted check, from Cong Wang * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (70 commits) net/mlx5_core: Support MANAGE_PAGES and QUERY_PAGES firmware command changes tun: signedness bug in tun_get_user() qlcnic: Fix diagnostic interrupt test for 83xx adapters qlcnic: Fix beacon state return status handling qlcnic: Fix set driver version command net: tg3: fix NULL pointer dereference in tg3_io_error_detected and tg3_io_slot_reset net_sched: restore "linklayer atm" handling drivers/net/ethernet/via/via-velocity.c: update napi implementation Revert "cxgb3: Check and handle the dma mapping errors" be2net: Clear any capability flags that driver is not interested in. openvswitch: Reset tunnel key between input and output. openvswitch: Use correct type while allocating flex array. openvswitch: Fix bad merge resolution. tun: compare with 0 instead of total_len rtnetlink: rtnl_bridge_getlink: Call nlmsg_find_attr() with ifinfomsg header ethernet/arc/arc_emac - fix NAPI "work > weight" warning ip_tunnel: Do not use inner ip-header-id for tunnel ip-header-id. bnx2x: prevent crash in shutdown flow with CNIC bnx2x: fix PTE write access error bnx2x: fix memory leak in VF ...
2013-08-13myri10ge: Update MAINTAINERSHyong-Youb Kim
Remove Andrew Gallatin, as he is no longer with Myricom. Add Hyong-Youb Kim as the new maintainer. Update the website URL. Signed-off-by: Hyong-Youb Kim <hykim@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-10Merge tag 'usb-3.11-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are 3 small USB fixes for 3.11-rc5. One is a fix that the ChromeOS developers ran into on some Intel hardware, one is a build fix, and the last is a MAINTAINERS update to help people figure out where to send USB network driver patches. All of these have been in linux-next for a while" * tag 'usb-3.11-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: MAINTAINERS: Add separate section for USB NETWORKING DRIVERS usb: xhci: add missing dma-mapping.h includes usb: core: don't try to reset_device() a port that got just disconnected
2013-08-08Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: - MSM: GPIO fixes (includes old code removal) - OMAP: earlyprintk regression, AM33xx cpgmac PM regression - OMAP5: urgent fix for potentially harmful voltage regulator values - Renesas: gpio-keys fix, fix SD card detection, fix shdma calculation error - STi: critical SMP boot fix - tegra: DTS fix for usb-phy - a couple MAINTAINERS updates (Arnd is on paternity leave, Kevin is stepping up to help arm-soc maintenance) * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: add TI Keystone ARM platform MAINTAINERS: delete Srinidhi from ux500 ARM: tegra: enable ULPI phy on Colibri T20 ARM: STi: remove sti_secondary_start from INIT section. ARM: STi: Fix cpu nodes with correct device_type. ARM: shmobile: lager: do not annotate gpio_buttons as __initdata ARM: shmobile: BOCK-W: fix SDHI0 PFC settings shdma: fixup sh_dmae_get_partial() calculation error ARM: OMAP2+: hwmod: AM335x: fix cpgmac address space ARM: OMAP2+: hwmod: rt address space index for DT ARM: OMAP2+: Sync hwmod state with the pm_runtime and omap_device state ARM: OMAP2+: Avoid idling memory controllers with no drivers ARM: OMAP2+: hwmod: Fix a crash in _setup_reset() with DEBUG_LL ARM: dts: omap5-uevm: update optional/unused regulator configurations ARM: dts: omap5-uevm: fix regulator configurations mandatory for SoC ARM: dts: omap5-uevm: document regulator signals used on the actual board ARM: msm: Consolidate gpiomux for older architectures ARM: shmobile: armadillo800eva: Don't request GPIO 166 in board code ARM: msm: dts: Fix the gpio register address for msm8960
2013-08-07MAINTAINERS: add TI Keystone ARM platformSantosh Shilimkar
Adding maintainer for arch/arm/mach-keystone/ Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-08-07MAINTAINERS: delete Srinidhi from ux500Linus Walleij
Srinidhi's mail address is now bouncing and he has requested me to delete this entry. Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-08-05MAINTAINERS: Add separate section for USB NETWORKING DRIVERSJoe Perches
There are several drivers in drivers/net/usb/ that do not have specific MAINTAINERS that should have emails forwarded to the linux-usb mailing list. Add a section for those drivers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Don't ignore user initiated wireless regulatory settings on cards with custom regulatory domains, from Arik Nemtsov. 2) Fix length check of bluetooth information responses, from Jaganath Kanakkassery. 3) Fix misuse of PTR_ERR in btusb, from Adam Lee. 4) Handle rfkill properly while iwlwifi devices are offline, from Emmanuel Grumbach. 5) Fix r815x devices DMA'ing to stack buffers, from Hayes Wang. 6) Kernel info leak in ATM packet scheduler, from Dan Carpenter. 7) 8139cp doesn't check for DMA mapping errors, from Neil Horman. 8) Fix bridge multicast code to not snoop when no querier exists, otherwise mutlicast traffic is lost. From Linus Lüssing. 9) Avoid soft lockups in fib6_run_gc(), from Michal Kubecek. 10) Fix races in automatic address asignment on ipv6, which can result in incorrect lifetime assignments. From Jiri Benc. 11) Cure build bustage when CONFIG_NET_LL_RX_POLL is not set and rename it CONFIG_NET_RX_BUSY_POLL to eliminate the last reference to the original naming of this feature. From Cong Wang. 12) Fix crash in TIPC when server socket creation fails, from Ying Xue. 13) macvlan_changelink() silently succeeds when it shouldn't, from Michael S Tsirkin. 14) HTB packet scheduler can crash due to sign extension, fix from Stephen Hemminger. 15) With the cable unplugged, r8169 prints out a message every 10 seconds, make it netif_dbg() instead of netif_warn(). From Peter Wu. 16) Fix memory leak in rtm_to_ifaddr(), from Daniel Borkmann. 17) sis900 gets spurious TX queue timeouts due to mismanagement of link carrier state, from Denis Kirjanov. 18) Validate somaxconn sysctl to make sure it fits inside of a u16. From Roman Gushchin. 19) Fix MAC address filtering on qlcnic, from Shahed Shaikh. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits) qlcnic: Fix for flash update failure on 83xx adapter qlcnic: Fix link speed and duplex display for 83xx adapter qlcnic: Fix link speed display for 82xx adapter qlcnic: Fix external loopback test. qlcnic: Removed adapter series name from warning messages. qlcnic: Free up memory in error path. qlcnic: Fix ingress MAC learning qlcnic: Fix MAC address filter issue on 82xx adapter net: ethernet: davinci_emac: drop IRQF_DISABLED netlabel: use domain based selectors when address based selectors are not available net: check net.core.somaxconn sysctl values sis900: Fix the tx queue timeout issue net: rtm_to_ifaddr: free ifa if ifa_cacheinfo processing fails r8169: remove "PHY reset until link up" log spam net: ethernet: cpsw: drop IRQF_DISABLED htb: fix sign extension bug macvlan: handle set_promiscuity failures macvlan: better mode validation tipc: fix oops when creating server socket fails net: rename CONFIG_NET_LL_RX_POLL to CONFIG_NET_RX_BUSY_POLL ...
2013-08-01Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-07-31MAINTAINERS: dynamic debug: Jason's not there...Joe Perches
He must be too, umm, busy to update his own bouncing email address too. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31MAINTAINERS: change email of TI WiLink drivers' maintainerLuciano Coelho
Soon the coelho@ti.com email will not be valid anymore, so change it to my private one. Cc: Luciano Coelho <luca@coelho.fi> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-26Merge tag 'staging-3.11-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging fixes from Greg KH: "Here are some tiny drivers/staging/ fixes for 3.11-rc3 A number of bugfixes, all pretty tiny, but resolve issues that have been reported (the kstrtos32 change fixes a data corruption problem that Dan found). And a MAINTAINERS file update for the comedi drivers" * tag 'staging-3.11-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: MAINTAINERS: Update the list of maintainers for staging/comedi driver. staging: tidspbridge: replace strict_strtol() with kstrtos32() staging: android: logger: Correct write offset reset on error staging: zram: protect zram_reset_device() call staging: gdm72xx: potential use after free in send_qos_list() staging: drm/imx: drop "select OF_VIDEOMODE" staging: frontier: use after free in disconnect() staging: comedi: fix a race between do_cmd_ioctl() and read/write staging: comedi: COMEDI_CANCEL ioctl should wake up read/write
2013-07-24MAINTAINERS: Update the list of maintainers for staging/comedi driver.Lidza Louina
This patch updates the list of maintainers for the staging/comedi driver. Signed-off-by: Lidza Louina <lidza.louina@gmail.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree bug fixes and maintainership updates from Grant Likely: "This branch contains a couple of minor bug fixes and documentation additions, but the bulk of it are several changes to the MAINTAINERS file regarding the subsystems I've been involved with" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: of/irq: init struct resource to 0 in of_irq_to_resource() of/irq: Avoid calling list_first_entry() for empty list of: add vendor prefixes for hisilicon of: add vendor prefix for Qualcomm Atheros, Inc. MAINTAINERS: Fix incorrect status tag MAINTAINERS: Refactor device tree maintainership MAINTAINERS: Change device tree mailing list MAINTAINERS: Remove Grant Likely
2013-07-22Merge branch 'for-3.11/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO driver bits from Jens Axboe: "As I mentioned in the core block pull request, due to real life circumstances the driver pull request would be late. Now it looks like -rc2 late... On the plus side, apart form the rsxx update, these are all things that I could argue could go in later in the cycle as they are fixes and not features. So even though things are late, it's not ALL bad. The pull request contains: - Updates to bcache, all bug fixes, from Kent. - A pile of drbd bug fixes (no big features this time!). - xen blk front/back fixes. - rsxx driver updates, some of them deferred form 3.10. So should be well cooked by now" * 'for-3.11/drivers' of git://git.kernel.dk/linux-block: (63 commits) bcache: Allocation kthread fixes bcache: Fix GC_SECTORS_USED() calculation bcache: Journal replay fix bcache: Shutdown fix bcache: Fix a sysfs splat on shutdown bcache: Advertise that flushes are supported bcache: check for allocation failures bcache: Fix a dumb race bcache: Use standard utility code bcache: Update email address bcache: Delete fuzz tester bcache: Document shrinker reserve better bcache: FUA fixes drbd: Allow online change of al-stripes and al-stripe-size drbd: Constants should be UPPERCASE drbd: Ignore the exit code of a fence-peer handler if it returns too late drbd: Fix rcu_read_lock balance on error path drbd: fix error return code in drbd_init() drbd: Do not sleep inside rcu bcache: Refresh usage docs ...
2013-07-22MAINTAINERS: Fix incorrect status tagGrant Likely
When I removed myself from the xilinx drivers I used the wrong tag. Fix it. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-07-22MAINTAINERS: Refactor device tree maintainershipGrant Likely
Device tree bindings require a lot more attention than they used to. We've got a group of volunteers willing to take over maintaining bindings. This patch adds them to the MAINTAINERS file. This group still needs to work out a process for maintainership and how they are going to work together. I recommend that they set up a shared tree on git.kernel.org that they each have commit access to similar to the tip tree or the arm-soc tree, but it is up to them. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Rob Herring <rob.herring@calxeda.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-07-22MAINTAINERS: Change device tree mailing listGrant Likely
New list on vger.kernel.org. The old list was a pain to moderate. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-07-22MAINTAINERS: Remove Grant LikelyGrant Likely
Unfortunately, I'm no longer to spend the time needed on maintainership. It is time for me to step aside and pass maintainership to other engineers. I'm not disappearing from Linux development, but it would be irresponsible for me to hold onto a job that I am unable to do. v2: Leave my name on devicetree core code maintainership. Rob NAKed that part of the patch. :) Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Linux Walleij <linus.walleij@linaro.org> Cc: Mark Brown <broonie@kernel.org> Cc: Rob Herring <rob.herring@calxeda.com>
2013-07-22MAINTAINERS: update ath6kl git locationKalle Valo
The git tree is in github.com nowadays. Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
2013-07-22MAINTAINERS: add ath10kKalle Valo
I forgot to add an entry to MAINTAINERS when submitting the driver. Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-13Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - lots of devm_ conversions and cleanup - platform_set_drvdata cleanups - s3c2410: dev_err/dev_info + dev_pm_ops - watchdog_core: don't try to stop device if not running fix - wdrtas: use print_hex_dump - xilinx cleanups - orion_wdt fixes - softdog cleanup - hpwdt: check on UEFI bits - deletion of mpcore_wdt driver - addition of broadcom BCM2835 watchdog timer driver - addition of MEN A21 watcdog devices * git://www.linux-watchdog.org/linux-watchdog: (38 commits) watchdog: hpwdt: Add check for UEFI bits watchdog: softdog: remove replaceable ping operation watchdog: New watchdog driver for MEN A21 watchdogs Watchdog: fix clearing of the watchdog interrupt Watchdog: allow orion_wdt to be built for Dove watchdog: Add Broadcom BCM2835 watchdog timer driver watchdog: delete mpcore_wdt driver watchdog: xilinx: Setup the origin compatible string watchdog: xilinx: Fix driver header watchdog: wdrtas: don't use custom version of print_hex_dump watchdog: core: don't try to stop device if not running watchdog: jz4740: Pass device to clk_get watchdog: twl4030: Remove redundant platform_set_drvdata() watchdog: mpcore: Remove redundant platform_set_drvdata() watchdog: da9055: use platform_{get,set}_drvdata() watchdog: da9052: use platform_{get,set}_drvdata() watchdog: cpwd: use platform_{get,set}_drvdata() watchdog: s3c2410_wdt: convert s3c2410wdt to dev_pm_ops watchdog: s3c2410_wdt: use dev_err()/dev_info() instead of pr_err()/pr_info() watchdog: wm831x: use platform_{get,set}_drvdata() ...
2013-07-13Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - AF_IB (native IB addressing) for CMA from Sean Hefty - new mlx5 driver for Mellanox Connect-IB adapters (including post merge request fixes) - SRP fixes from Bart Van Assche (including fix to first merge request) - qib HW driver updates - resurrection of ocrdma HW driver development - uverbs conversion to create fds with O_CLOEXEC set - other small changes and fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (66 commits) mlx5: Return -EFAULT instead of -EPERM IB/qib: Log all SDMA errors unconditionally IB/qib: Fix module-level leak mlx5_core: Adjust hca_cap.uar_page_sz to conform to Connect-IB spec IB/srp: Let srp_abort() return FAST_IO_FAIL if TL offline IB/uverbs: Use get_unused_fd_flags(O_CLOEXEC) instead of get_unused_fd() mlx5_core: Fixes for sparse warnings IB/mlx5: Make profile[] static in main.c mlx5: Fix parameter type of health_handler_t mlx5: Add driver for Mellanox Connect-IB adapters IB/core: Add reserved values to enums for low-level driver use IB/srp: Bump driver version and release date IB/srp: Make HCA completion vector configurable IB/srp: Maintain a single connection per I_T nexus IB/srp: Fail I/O fast if target offline IB/srp: Skip host settle delay IB/srp: Avoid skipping srp_reset_host() after a transport error IB/srp: Fix remove_one crash due to resource exhaustion IB/qib: New transmitter tunning settings for Dell 1.1 backplane IB/core: Fix error return code in add_port() ...
2013-07-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series contain: - new i2c video drivers: ml86v7667 (video decoder), ths8200 (video encoder) - a new video driver for EasyCap cards based on Fushicai USBTV007 - Improved support for OF and embedded systems, with V4L2 async initialization and a better support for clocks - API cleanups on the ioctls used by the v4l2 debug tool - Lots of cleanups - As usual, several driver improvements and new cards additions - Revert two changesets that change the minimal symbol rate for stv0399, as request by Manu - Update MAINTAINERS and other files to point to my new e-mail" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (378 commits) MAINTAINERS & ABI: Update to point to my new email [media] stb0899: restore minimal rate to 5Mbauds [media] exynos4-is: Correct colorspace handling at FIMC-LITE [media] exynos4-is: Set valid initial format on FIMC.n subdevs [media] exynos4-is: Set valid initial format on FIMC-IS-ISP subdev pads [media] exynos4-is: Fix format propagation on FIMC-IS-ISP subdev [media] exynos4-is: Set valid initial format at FIMC-LITE [media] exynos4-is: Fix format propagation on FIMC-LITE.n subdevs [media] MAINTAINERS: Update S5P/Exynos FIMC driver entry [media] Documentation: Update driver's directory in video4linux/fimc.txt [media] exynos4-is: Change fimc-is firmware file names [media] exynos4-is: Add support for Exynos5250 MIPI-CSIS [media] exynos4-is: Add Exynos5250 SoC support to fimc-lite driver [media] exynos4-is: Drop drvdata handling in fimc-lite for non-dt platforms [media] media: i2c: tvp514x: remove manual setting of subdev name [media] media: i2c: tvp7002: remove manual setting of subdev name [media] mem2mem: set missing v4l2_dev pointer [media] wl128x: add missing struct v4l2_device [media] tvp514x: Fix init seqeunce [media] saa7134: Fix sparse warnings by adding __user annotation ...
2013-07-11qlcnic: Adding Maintainers.Jitendra Kalsaria
Signed-off-by: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11watchdog: New watchdog driver for MEN A21 watchdogsJohannes Thumshirn
This patch adds the driver for the watchdog devices found on MEN Mikro Elektronik A21 VMEbus CPU Carrier Boards. It has DT-support and uses the watchdog framework. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-11Merge tag 'dm-3.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper changes from Alasdair G Kergon: "Add a device-mapper target called dm-switch to provide a multipath framework for storage arrays that dynamically reconfigure their preferred paths for different device regions. Fix a bug in the verity target that prevented its use with some specific sizes of devices. Improve some locking mechanisms in the device-mapper core and bufio. Add Mike Snitzer as a device-mapper maintainer. A few more clean-ups and fixes" * tag 'dm-3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: dm: add switch target dm: update maintainers dm: optimize reorder structure dm: optimize use SRCU and RCU dm bufio: submit writes outside lock dm cache: fix arm link errors with inline dm verity: use __ffs and __fls dm flakey: correct ctr alloc failure mesg dm verity: remove pointless comparison dm: use __GFP_HIGHMEM in __vmalloc dm verity: fix inability to use a few specific devices sizes dm ioctl: set noio flag to avoid __vmalloc deadlock dm mpath: fix ioctl deadlock when no paths
2013-07-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "There are not too many changes this time, except two new platform thermal drivers, ti-soc-thermal driver and x86_pkg_temp_thermal driver, and a couple of small fixes. Highlights: - move the ti-soc-thermal driver out of the staging tree to the thermal tree. - introduce the x86_pkg_temp_thermal driver. This driver registers CPU digital temperature package level sensor as a thermal zone. - small fixes/cleanups including removing redundant use of platform_set_drvdata() and of_match_ptr for all platform thermal drivers" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (34 commits) thermal: cpu_cooling: fix stub function thermal: ti-soc-thermal: use standard GPIO DT bindings thermal: MAINTAINERS: Add git tree path for SoC specific updates thermal: fix x86_pkg_temp_thermal.c build and Kconfig Thermal: Documentation for x86 package temperature thermal driver Thermal: CPU Package temperature thermal thermal: consider emul_temperature while computing trend thermal: ti-soc-thermal: add DT example for DRA752 chip thermal: ti-soc-thermal: add dra752 chip to device table thermal: ti-soc-thermal: add thermal data for DRA752 chips thermal: ti-soc-thermal: remove usage of IS_ERR_OR_NULL thermal: ti-soc-thermal: freeze FSM while computing trend thermal: ti-soc-thermal: remove external heat while extrapolating hotspot thermal: ti-soc-thermal: update DT reference for OMAP5430 x86, mcheck, therm_throt: Process package thresholds thermal: cpu_cooling: fix 'descend' check in get_property() Thermal: spear: Remove redundant use of of_match_ptr Thermal: kirkwood: Remove redundant use of of_match_ptr Thermal: dove: Remove redundant use of of_match_ptr Thermal: armada: Remove redundant use of of_match_ptr ...
2013-07-10Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull coccinelle updates from Michal Marek: "The misc branch is reserved for Coccinelle this time: - 'report' is the default mode - MAINTAINERS update for Coccinelle - documentation udate - use new option format for spatch(1) - J=<n> variable to mimic make -j for coccicheck - check for missing pci_free_consistent() calls There are some patches for rpm-pkg and deb-pkg waiting for the 3.12-rc1 merge window" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Coccinelle: Update information about the minimal version required Coccinelle: Update the options used to the new option scheme scripts: Coccinelle script for pci_free_consistent() Coccinelle: Update the documentation Coccinelle: Update section of MAINTAINERS coccicheck: span checks across CPUs scripts/coccinelle: check for field address argument to kfree Coccinelle: Update the Coccinelle section of MAINTAINERS Coccinelle: Make 'report' the default mode
2013-07-10dm: update maintainersAlasdair G Kergon
Add Mike Snitzer as an additional device-mapper maintainer. Recognise uapi dm-*.h include files as device-mapper files. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Yann Droneaud <ydroneaud@opteya.com> Cc: Mike Snitzer <snitzer@redhat.com>
2013-07-10Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "No real surprises" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MAINTAINERS: add tools/virtio/ under virtio tools/virtio: move module license stub to module.h virtio: include asm/barrier explicitly virtio: VIRTIO_F_ANY_LAYOUT feature lguest: fix example launcher compilation for broken glibc headers. virtio-net: fix the race between channels setting and refill tools/lguest: real barriers. tools/lguest: fix missing rmb(). virtio_balloon: leak_balloon(): only tell host if we got pages deflated virtio-pci: fix leaks of msix_affinity_masks Fix comment typo "CONFIG_PAE"
2013-07-10Merge tag 'iommu-updates-v3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "A few updates this time, most important and exiciting (to me) is: - The new ARM SMMU driver. This is a common IOMMU driver that will hopefully be used in a lot of upcoming ARM chips. So the mess in the past where every SOC had its own IOMMU will be over. Besides that: - Some important fixes in the IOMMU unmap path. There are fixes in the common code and also in the AMD IOMMU driver. - Other random fixes" * tag 'iommu-updates-v3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: MAINTAINERS: add entry for ARM system MMU driver iommu/arm: Add support for ARM Ltd. System MMU architecture documentation/iommu: Add description of ARM System MMU binding iommu: Use %pa and %zx instead of casting iommu/amd: Only unmap large pages from the first pte iommu: Fix compiler warning on pr_debug iommu/amd: Fix memory leak in free_pagetable iommu: Split iommu_unmaps iommu/{vt-d,amd}: Remove multifunction assumption around grouping iommu/omap: fix checkpatch warnings in omap iommu code iommu/omap: fix printk formats for dma_addr_t iommu/vt-d: DMAR reporting table needs at least one DRHD iommu/vt-d: Downgrade the warning if enabling irq remapping fails
2013-07-10Merge tag 'for-3.11-rc1' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull pwm changes from Thierry Reding: "A new driver supports driving PWM signals using the TPU unit found on various Renesas SoCs. Furthermore support is added for the NXP PCA9685 LED controller. Another big chunk is the sysfs interface which has been in the works for quite some time. The remaining patches are a random assortment of cleanups and fixes" * tag 'for-3.11-rc1' of git://gitorious.org/linux-pwm/linux-pwm: pwm: pwm-tiehrpwm: Use clk_enable/disable instead clk_prepare/unprepare. pwm: pca9685: Fix wrong argument to set MODE1_SLEEP bit pwm: renesas-tpu: Add MODULE_ALIAS to make module auto loading work pwm: renesas-tpu: fix return value check in tpu_probe() pwm: Add Renesas TPU PWM driver pwm: Add sysfs interface pwm: Fill in missing .owner fields pwm: add pca9685 driver pwm: atmel-tcb: prepare clk before calling enable pwm: devm: alloc correct pointer size pwm: mxs: Let device core handle pinctrl MAINTAINERS: Update PWM subsystem entry
2013-07-10Merge tag 'for-v3.11' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery subsystem update from Anton Vorontsov: "Nothing exciting this time, just assorted fixes and cleanups" * tag 'for-v3.11' of git://git.infradead.org/battery-2.6: (25 commits) charger-manager: Fix regulator_get() return check charger-manager: Fix a bug when it unregisters notifier block of extcon tps65090-charger: Add dt node to power_supply sbs-battery: Add dt to power_supply struct power_supply: Add of_node_put to fix refcount power_supply: Move of_node out of the #ifdef CONFIG_OF power/reset: Make the vexpress driver optional on arm and arm64 charger-manager: Add missing newlines, fix a couple of typos, add pr_fmt tps65090-charger: Fix AC detect MAINTAINERS: Update email address for Anton Vorontsov charger-manager: Ensure event is not used as format string power_supply: Replace strict_strtoul() with kstrtoul() generic-adc-battery: Fix checking if none of the channels are supported power: Use platform_{get,set}_drvdata() pm2301_charger: Return error if create_singlethread_workqueue fails pm2301_charger: Fix NULL pointer dereference lp8727_charger: Support the device tree feature twl4030_charger: Remove unnecessary platform_set_drvdata() rx51_battery: Remove unnecessary platform_set_drvdata() jz4740-battery: Remove unnecessary platform_set_drvdata() ...
2013-07-10Merge tag 'mfd-3.11-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next Pull MFD update from Samuel Ortiz: "For the 3.11 merge we only have one new MFD driver for the Kontron PLD. But we also have: - Support for the TPS659038 PMIC from the palmas driver. - Intel's Coleto Creek and Avoton SoCs support from the lpc_ich driver. - RTL8411B support from the rtsx driver. - More DT support for the Arizona, max8998, twl4030-power and the ti_am335x_tsadc drivers. - The SSBI driver move under MFD. - A conversion to the devm_* API for most of the MFD drivers. - The twl4030-power got split from twl-core into its own module. - A major ti_am335x_adc cleanup, leading to a proper DT support. - Our regular arizona and wm* updates and cleanups from the Wolfson folks. - A better error handling and initialization, and a regulator subdevice addition for the 88pm80x driver. - A bulk platform_set_drvdata() call removal that's no longer need since commit 0998d0631001 ("device-core: Ensure drvdata = NULL when no driver is bound") * tag 'mfd-3.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (102 commits) mfd: sec: Provide max_register to regmap mfd: wm8994: Remove duplicate check for active JACKDET MAINTAINERS: Add include directory to MFD file patterns mfd: sec: Remove fields not used since regmap conversion watchdog: Kontron PLD watchdog timer driver mfd: max8998: Add support for Device Tree regulator: max8998: Use arrays for specifying voltages in platform data mfd: max8998: Add irq domain support regulator: palmas: Add TPS659038 support mfd: Kontron PLD mfd driver mfd: palmas: Add TPS659038 PMIC support mfd: palmas: Add SMPS10_BOOST feature mfd: palmas: Check if irq is valid mfd: lpc_ich: iTCO_wdt patch for Intel Coleto Creek DeviceIDs mfd: twl-core: Change TWL6025 references to TWL6032 mfd: davinci_voicecodec: Fix build breakage mfd: vexpress: Make the driver optional for arm and arm64 mfd: htc-egpio: Use devm_ioremap_nocache() instead of ioremap_nocache() mfd: davinci_voicecodec: Convert to use devm_* APIs mfd: twl4030-power: Fix relocking on error ...
2013-07-10Merge tag 'regulator-v3.11-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "Fixes for the merge window A set of small fixes for issues noticed during the merge window, all very much non-invasive" * tag 'regulator-v3.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: MAINTAINERS: Update git repository regulator: max8997: Fix a trivial typo in documentation regulator: s5m8767: Fix a trivial typo in documentation regulator: s2mps11: Convert ramp rate to uV/us and set default ramp rate regulator: s5m8767: Update s5m8767-regulator bindings document
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-09Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Okay this is the big one, I was stalled on the fbdev pull req as I stupidly let fbdev guys merge a patch I required to fix a warning with some patches I had, they ended up merging the patch from the wrong place, but the warning should be fixed. In future I'll just take the patch myself! Outside drm: There are some snd changes for the HDMI audio interactions on haswell, they've been acked for inclusion via my tree. This relies on the wound/wait tree from Ingo which is already merged. Major changes: AMD finally released the dynamic power management code for all their GPUs from r600->present day, this is great, off by default for now but also a huge amount of code, in fact it is most of this pull request. Since it landed there has been a lot of community testing and Alex has sent a lot of fixes for any bugs found so far. I suspect radeon might now be the biggest kernel driver ever :-P p.s. radeon.dpm=1 to enable dynamic powermanagement for anyone. New drivers: Renesas r-car display unit. Other highlights: - core: GEM CMA prime support, use new w/w mutexs for TTM reservations, cursor hotspot, doc updates - dvo chips: chrontel 7010B support - i915: Haswell (fbc, ips, vecs, watermarks, audio powerwell), Valleyview (enabled by default, rc6), lots of pll reworking, 30bpp support (this time for sure) - nouveau: async buffer object deletion, context/register init updates, kernel vp2 engine support, GF117 support, GK110 accel support (with external nvidia ucode), context cleanups. - exynos: memory leak fixes, Add S3C64XX SoC series support, device tree updates, common clock framework support, - qxl: cursor hotspot support, multi-monitor support, suspend/resume support - mgag200: hw cursor support, g200 mode limiting - shmobile: prime support - tegra: fixes mostly I've been banging on this quite a lot due to the size of it, and it seems to okay on everything I've tested it on." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (811 commits) drm/radeon/dpm: implement vblank_too_short callback for si drm/radeon/dpm: implement vblank_too_short callback for cayman drm/radeon/dpm: implement vblank_too_short callback for btc drm/radeon/dpm: implement vblank_too_short callback for evergreen drm/radeon/dpm: implement vblank_too_short callback for 7xx drm/radeon/dpm: add checks against vblank time drm/radeon/dpm: add helper to calculate vblank time drm/radeon: remove stray line in old pm code drm/radeon/dpm: fix display_gap programming on rv7xx drm/nvc0/gr: fix gpc firmware regression drm/nouveau: fix minor thinko causing bo moves to not be async on kepler drm/radeon/dpm: implement force performance level for TN drm/radeon/dpm: implement force performance level for ON/LN drm/radeon/dpm: implement force performance level for SI drm/radeon/dpm: implement force performance level for cayman drm/radeon/dpm: implement force performance levels for 7xx/eg/btc drm/radeon/dpm: add infrastructure to force performance levels drm/radeon: fix surface setup on r1xx drm/radeon: add support for 3d perf states on older asics drm/radeon: set default clocks for SI when DPM is disabled ...
2013-07-09Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - misc fixes - audit stuff - fanotify/inotify/dnotify things - most of the rest of MM. The new cache shrinker code from Glauber and Dave Chinner probably isn't quite stabilized yet. - ptrace - ipc - partitions - reboot cleanups - add LZ4 decompressor, use it for kernel compression * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits) lib/scatterlist: error handling in __sg_alloc_table() scsi_debug: fix do_device_access() with wrap around range crypto: talitos: use sg_pcopy_to_buffer() lib/scatterlist: introduce sg_pcopy_from_buffer() and sg_pcopy_to_buffer() lib/scatterlist: factor out sg_miter_get_next_page() from sg_miter_next() crypto: add lz4 Cryptographic API lib: add lz4 compressor module arm: add support for LZ4-compressed kernel lib: add support for LZ4-compressed kernel decompressor: add LZ4 decompressor module lib: add weak clz/ctz functions reboot: move arch/x86 reboot= handling to generic kernel reboot: arm: change reboot_mode to use enum reboot_mode reboot: arm: prepare reboot_mode for moving to generic kernel code reboot: arm: remove unused restart_mode fields from some arm subarchs reboot: unicore32: prepare reboot_mode for moving to generic kernel code reboot: x86: prepare reboot_mode for moving to generic kernel code reboot: checkpatch.pl the new kernel/reboot.c file reboot: move shutdown/reboot related functions to kernel/reboot.c reboot: remove -stable friendly PF_THREAD_BOUND define ...
2013-07-09Merge tag 'for-linus-3.11-merge-window-part-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull 9p update from Eric Van Hensbergen: "Grab bag of little fixes and enhancements: - optional security enhancements - fix path coverage in MAINTAINERS - switch to using most used protocol and transport as default - clean up buffer dumps in trace code Held off on RDMA patches as they need to be cleaned up a bit, but will try to get the cleaned, checked, and pushed by mid-week" * tag 'for-linus-3.11-merge-window-part-1' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: Add rest of 9p files to MAINTAINERS entry 9p: trace: use %*ph to dump buffer net/9p: Handle error in zero copy request correctly for 9p2000.u net/9p: Use virtio transpart as the default transport net/9p: Make 9P2000.L the default protocol for 9p file system
2013-07-09MAINTAINERS: add zswap and zbud maintainerSeth Jennings
Add maintainer information for zswap and zbud into the MAINTAINERS file. Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09MAINTAINERS: add tools/virtio/ under virtioMichael S. Tsirkin
This should help make sure patches go to the correct list. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-07-08mlx5: Add driver for Mellanox Connect-IB adaptersEli Cohen
The driver is comprised of two kernel modules: mlx5_ib and mlx5_core. This partitioning resembles what we have for mlx4, except that mlx5_ib is the pci device driver and not mlx5_core. mlx5_core is essentially a library that provides general functionality that is intended to be used by other Mellanox devices that will be introduced in the future. mlx5_ib has a similar role as any hardware device under drivers/infiniband/hw. Signed-off-by: Eli Cohen <eli@mellanox.com> Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> [ Merge in coccinelle fixes from Fengguang Wu <fengguang.wu@intel.com>. - Roland ] Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-08thermal: MAINTAINERS: Add git tree path for SoC specific updatesEduardo Valentin
To reduce thermal maintenance load on Rui, SoC specific patches would be applied by me now. Rui Zhang will pull in these changes from time to time (at rc's). Additionally I would be sending him pull request for every merge window and rc's (for fixes). Branch names would be: next and fixes. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
2013-07-08MAINTAINERS & ABI: Update to point to my new emailMauro Carvalho Chehab
As mchehab@redhat.com is no longer valid, update it to reflect the new one. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
