path: root/MAINTAINERS
2014-11-15MAINTAINERS: Add IIO include filesDaniel Baluta
Files under include/linux/iio were not reported as part of the IIO subsystem. Reported-by: Cristina Ciocan <cristina.ciocan@intel.com> Signed-off-by: Daniel Baluta <daniel.baluta@intel.com> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-11-02Merge 3.18-rc3 into staging-nextGreg Kroah-Hartman
We want the upstream fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-02Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of six patches consisting of: - two MAINTAINER updates - two scsi-mq fixs for the old parallel interface (not every request is tagged and we need to set the right flags to populate the SPI tag message) - a fix for a memory leak in scatterlist traversal caused by a preallocation update in 3.17 - an ipv6 fix for cxgbi" [ The scatterlist fix also came in separately through the block layer tree ] * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: MAINTAINERS: ufs - remove self MAINTAINERS: change hpsa and cciss maintainer libcxgbi : support ipv6 address host_param scsi: set REQ_QUEUE for the blk-mq case Revert "block: all blk-mq requests are tagged" lib/scatterlist: fix memory leak with scsi-mq
2014-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: "There's some bug fixes or cleanups to facilitate fixes, a MAINTAINERS update, and a new syscall (bpf)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: powerpc/numa: ensure per-cpu NUMA mappings are correct on topology update powerpc/numa: use cached value of update->cpu in update_cpu_topology cxl: Fix PSL error due to duplicate segment table entries powerpc/mm: Use appropriate ESID mask in copro_calculate_slb() cxl: Refactor cxl_load_segment() and find_free_sste() cxl: Disable secondary hash in segment table Revert "powerpc/powernv: Fix endian bug in LPC bus debugfs accessors" powernv: Use _GLOBAL_TOC for opal wrappers powerpc: Wire up sys_bpf() syscall MAINTAINERS: nx-842 driver maintainer change powerpc/mm: Remove redundant #if case powerpc/mm: Fix build error with hugetlfs disabled
2014-10-28MAINTAINERS: ufs - remove selfSantosh Y
I have moved, I do not have the hardware access anymore. Signed-off-by: Santosh Y <santoshsy@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-10-28MAINTAINERS: change hpsa and cciss maintainerDon Brace
Change ownership of the hpsa driver from Stephen M. Cameron (Hewlett-Packard) to Don Brace (PMC-Sierra). Change ownership of the cciss driver from Mike Miller (Hewlett-Packard) to Don Brace (PMC-Sierra). Signed-off-by: Don Brace <don.brace@pmcs.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-10-26Merge tag 'armsoc-for-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another week, another small batch of fixes. Most of these make zynq, socfpga and sunxi platforms work a bit better: - due to new requirements for regulators, DWMMC on socfpga broke past v3.17 - SMP spinup fix for socfpga - a few DT fixes for zynq - another option (FIXED_REGULATOR) for sunxi is needed that used to be selected by other options but no longer is. - a couple of small DT fixes for at91 - ...and a couple for i.MX" * tag 'armsoc-for-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: imx28-evk: Let i2c0 run at 100kHz ARM: i.MX6: Fix "emi" clock name typo ARM: multi_v7_defconfig: enable CONFIG_MMC_DW_ROCKCHIP ARM: sunxi_defconfig: enable CONFIG_REGULATOR_FIXED_VOLTAGE ARM: dts: socfpga: Add a 3.3V fixed regulator node ARM: dts: socfpga: Fix SD card detect ARM: dts: socfpga: rename gpio nodes ARM: at91/dt: sam9263: fix PLLB frequencies power: reset: at91-reset: fix power down register MAINTAINERS: add atmel ssc driver maintainer entry arm: socfpga: fix fetching cpu1start_addr for SMP ARM: zynq: DT: trivial: Fix mc node ARM: zynq: DT: Add cadence watchdog node ARM: zynq: DT: Add missing reference for memory-controller ARM: zynq: DT: Add missing reference for ADC ARM: zynq: DT: Add missing address for L2 pl310 ARM: zynq: DT: Remove 222 MHz OPP ARM: zynq: DT: Fix GEM register area size
2014-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "overlayfs merge + leak fix for d_splice_alias() failure exits" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: overlayfs: embed middle into overlay_readdir_data overlayfs: embed root into overlay_readdir_data overlayfs: make ovl_cache_entry->name an array instead of pointer overlayfs: don't hold ->i_mutex over opening the real directory fix inode leaks on d_splice_alias() failure exits fs: limit filesystem stacking depth overlay: overlay filesystem documentation overlayfs: implement show_options overlayfs: add statfs support overlay filesystem shmem: support RENAME_WHITEOUT ext4: support RENAME_WHITEOUT vfs: add RENAME_WHITEOUT vfs: add whiteout support vfs: export check_sticky() vfs: introduce clone_private_mount() vfs: export __inode_permission() to modules vfs: export do_splice_direct() to modules vfs: add i_op->dentry_open()
2014-10-24overlay: overlay filesystem documentationNeil Brown
Document the overlay filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-22MAINTAINERS: add atmel ssc driver maintainer entryBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-10-22MAINTAINERS: nx-842 driver maintainer changeDan Streetman
Change maintainer of nx-842 compression coprocessor driver to Dan Streetman. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-21Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull email address change from Boaz Harrosh. * 'for-linus' of git://git.open-osd.org/linux-open-osd: Boaz Harrosh - fix email in Documentation Boaz Harrosh - Fix broken email address MAINTAINERS: Change Boaz Harrosh's email
2014-10-21Merge branch 'mailbox-for-linus' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox framework from Jassi Brar: "A framework for Mailbox controllers and clients have been cooking for more than a year now. Everybody in the CC list had been copied on patchset revisions and most of them have made sounds of approval, though just one concrete Reviewed-by. The patchset has also been in linux-next for a couple of weeks now and no conflict has been reported. The framework has the backing of at least 5 platforms, though I can't say if/when they upstream their drivers (some businesses have 'changed')" (Further acked-by by Arnd Bergmann and Suman Anna in the pull request thread) * 'mailbox-for-linus' of git://git.linaro.org/landing-teams/working/fujitsu/integration: dt: mailbox: add generic bindings doc: add documentation for mailbox framework mailbox: Introduce framework for mailbox mailbox: rename pl320-ipc specific mailbox.h
2014-10-20staging: bcm: remove driverJeff Kirsher
The Beceem WiMAX driver was barely function in its current state and was non-functional on 64 bit systems. Based on repeated statements from Greg KH that he wanted the driver removed, I am removing the driver. CC: Matthias Beyer <mail@beyermatthias.de> CC: Kevin McKinney <klmckinney1@gmail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-19Merge tag 'arm-soc-fixes-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A batch of fixes that have come in during the merge window. Some of them are defconfig updates for things that have now landed, some errata additions and a few general scattered fixes. There's also a qcom DT update that adds support for SATA on AP148, and basic support for Sony Xperia Z1 and CM-QS600 platforms that seemed isolated enough that we could merge it even if it's late" * tag 'arm-soc-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: corrected bcm2835 search ARM: dts: Explicitly set dr_mode on exynos5420-arndale-octa ARM: dts: Explicitly set dr_mode on exynos Peach boards ARM: dts: qcom: add CM-QS600 board ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phone ARM: dts: qcom: Add SATA support on IPQ8064/AP148 MAINTAINERS: Update Santosh Shilimkar's email id ARM: sunxi_defconfig: enable CONFIG_REGULATOR ARM: dts: Disable smc91x on n900 until bootloader dependency is removed ARM: omap2plus_defconfig: Enable ARM erratum 430973 for omap3 ARM: exynos_defconfig: enable USB gadget support ARM: exynos_defconfig: Enable Maxim 77693 and I2C GPIO drivers ARM: mm: Fix ifdef around cpu_*_do_[suspend, resume] ops ARM: EXYNOS: Fix build with PM_SLEEP=n and ARM_EXYNOS_CPUIDLE=n ARM: SAMSUNG: Restore Samsung PM Debug functionality ARM: dts: Fix pull setting in sd4_width8 pin group for exynos4x12 ARM: exynos_defconfig: Enable SBS battery support ARM: exynos_defconfig: Enable Control Groups support ARM: exynos_defconfig: Enable Atmel maXTouch support ARM: exynos_defconfig: Enable MAX77802
2014-10-19MAINTAINERS: corrected bcm2835 searchScott Branden
Corrected bcm2835 maintainer info by using N: to specify any files with bcm2835 in are directed to the proper maintainer. Also corrected minor mispelling of ARCHITECTURE in 2 comment locations. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-19Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband/RDMA updates from Roland Dreier: - large set of iSER initiator improvements - hardware driver fixes for cxgb4, mlx5 and ocrdma - small fixes to core midlayer * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (47 commits) RDMA/cxgb4: Fix ntuple calculation for ipv6 and remove duplicate line RDMA/cxgb4: Add missing neigh_release in find_route RDMA/cxgb4: Take IPv6 into account for best_mtu and set_emss RDMA/cxgb4: Make c4iw_wr_log_size_order static IB/core: Fix XRC race condition in ib_uverbs_open_qp IB/core: Clear AH attr variable to prevent garbage data RDMA/ocrdma: Save the bit environment, spare unncessary parenthesis RDMA/ocrdma: The kernel has a perfectly good BIT() macro - use it RDMA/ocrdma: Don't memset() buffers we just allocated with kzalloc() RDMA/ocrdma: Remove a unused-label warning RDMA/ocrdma: Convert kernel VA to PA for mmap in user RDMA/ocrdma: Get vlan tag from ib_qp_attrs RDMA/ocrdma: Add default GID at index 0 IB/mlx5, iser, isert: Add Signature API additions Target/iser: Centralize ib_sig_domain setting IB/iser: Centralize ib_sig_domain settings IB/mlx5: Use extended internal signature layout IB/iser: Set IP_CSUM as default guard type IB/iser: Remove redundant assignment IB/mlx5: Use enumerations for PI copy mask ...
2014-10-19MAINTAINERS: Change Boaz Harrosh's emailBoaz Harrosh
I have moved on, and do no longer have Panasas email access. Update to an email that can reach me. So change bharrosh@panasas.com => ooo@electrozaur.com Explain of email address: * electrozaur.com is a domain owned by me. * ooo - Stands for Open Osd . Org Another email alias that can be used is: openosd@gmail.com CC: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Boaz Harrosh <ooo@electrozaur.com>
2014-10-18Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "For dmaengine contributions we have: - designware cleanup by Andy - my series moving device_control users to dmanegine_xxx APIs for later removal of device_control API - minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma etc" * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits) serial: atmel: add missing dmaengine header dmaengine: remove FSLDMA_EXTERNAL_START dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method carma-fpga: move to fsl_dma_external_start() carma-fpga: use dmaengine_xxx() API dmaengine: freescale: add and export fsl_dma_external_start() dmaengine: add dmaengine_prep_dma_sg() helper video: mx3fb: use dmaengine_terminate_all() API serial: sh-sci: use dmaengine_terminate_all() API net: ks8842: use dmaengine_terminate_all() API mtd: sh_flctl: use dmaengine_terminate_all() API mtd: fsmc_nand: use dmaengine_terminate_all() API V4L2: mx3_camer: use dmaengine_pause() API dmaengine: coh901318: use dmaengine_terminate_all() API pata_arasan_cf: use dmaengine_terminate_all() API dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause() dmaengine: dw: export probe()/remove() and Co to users dmaengine: dw: enable and disable controller when needed dmaengine: dw: always export dw_dma_{en,dis}able dmaengine: dw: introduce dw_dma_on() helper ...
2014-10-18Merge tag 'for-linus-20141015' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from Brian Norris: "Sorry for delaying this a bit later than usual. There's one mild regression from 3.16 that was noticed during the 3.17 cycle, and I meant to send a fix for it along with this pull request. I'll probably try to queue it up for a later pull request once I've had a better look at it, hopefully by -rc2 at the latest. Summary for this pull: NAND - Cleanup for Denali driver - Atmel: add support for new page sizes - Atmel: fix up 'raw' mode support - Atmel: miscellaneous cleanups - New timing mode helpers for non-ONFI NAND - OMAP: allow driver to be (properly) built as a module - bcm47xx: RESET support and other cleanups SPI NOR - Miscellaneous cleanups, to prepare framework for wider use (some further work still pending) - Compile-time configuration to select 4K vs. 64K support for flash that support both (necessary for using UBIFS on some SPI NOR) A few scattered code quality fixes, detected by Coverity See the changesets for more" * tag 'for-linus-20141015' of git://git.infradead.org/linux-mtd: (59 commits) mtd: nand: omap: Correct CONFIG_MTD_NAND_OMAP_BCH help message mtd: nand: Force omap_elm to be built as a module if omap2_nand is a module mtd: move support for struct flash_platform_data into m25p80 mtd: spi-nor: add Kconfig option to disable 4K sectors mtd: nand: Move ELM driver and rename as omap_elm nand: omap2: Replace pr_err with dev_err nand: omap2: Remove horrible ifdefs to fix module probe mtd: nand: add Hynix's H27UCG8T2ATR-BC to nand_ids table mtd: nand: support ONFI timing mode retrieval for non-ONFI NANDs mtd: physmap_of: Add non-obsolete map_rom probe mtd: physmap_of: Fix ROM support via OF MAINTAINERS: add l2-mtd.git, 'next' tree for MTD mtd: denali: fix indents and other trivial things mtd: denali: remove unnecessary parentheses mtd: denali: remove another set-but-unused variable mtd: denali: fix include guard and license block of denali.h mtd: nand: don't break long print messages mtd: bcm47xxnflash: replace some magic numbers mtd: bcm47xxnflash: NAND_CMD_RESET support mtd: bcm47xxnflash: add cmd_ctrl handler ...
2014-10-18MAINTAINERS: Become the docs maintainerJonathan Corbet
It seems it's my turn to be the documentation maintainer for a bit. My plan is to work to ensure that docs patches don't fall through the cracks; I assume most changes will continue to flow through subsystem-specific trees. Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Include fixes for netrom and dsa (Fabian Frederick and Florian Fainelli) 2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO. 3) Several SKB use after free fixes (vxlan, openvswitch, vxlan, ip_tunnel, fou), from Li ROngQing. 4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy. 5) Use after free in virtio_net, from Michael S Tsirkin. 6) Fix flow mask handling for megaflows in openvswitch, from Pravin B Shelar. 7) ISDN gigaset and capi bug fixes from Tilman Schmidt. 8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin. 9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov. 10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong Wang and Eric Dumazet. 11) Don't overwrite end of SKB when parsing malformed sctp ASCONF chunks, from Daniel Borkmann. 12) Don't call sock_kfree_s() with NULL pointers, this function also has the side effect of adjusting the socket memory usage. From Cong Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits) bna: fix skb->truesize underestimation net: dsa: add includes for ethtool and phy_fixed definitions openvswitch: Set flow-key members. netrom: use linux/uaccess.h dsa: Fix conversion from host device to mii bus tipc: fix bug in bundled buffer reception ipv6: introduce tcp_v6_iif() sfc: add support for skb->xmit_more r8152: return -EBUSY for runtime suspend ipv4: fix a potential use after free in fou.c ipv4: fix a potential use after free in ip_tunnel_core.c hyperv: Add handling of IP header with option field in netvsc_set_hash() openvswitch: Create right mask with disabled megaflows vxlan: fix a free after use openvswitch: fix a use after free ipv4: dst_entry leak in ip_send_unicast_reply() ipv4: clean up cookie_v4_check() ipv4: share tcp_v4_save_options() with cookie_v4_check() ipv4: call __ip_options_echo() in cookie_v4_check() atm: simplify lanai.c by using module_pci_driver ...
2014-10-14MAINTAINERS: Update Santosh Shilimkar's email idSantosh Shilimkar
Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-15Merge tag 'mfd-for-linus-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030 - Export symbols for use in modules in max14577 - Plenty of static code analysis/Coccinelle fixes throughout the SS - Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808 - Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona - Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr - IRQ fixups in arizona, stmpe, max14577 - Regulator related changes in axp20x - Pass DMA coherency information from parent => child in MFD core - Rename DT document files for consistency - Add ACPI support to the MFD core - Add Andreas Werner to MAINTAINERS for MEN F21BMC New drivers/supported devices: - New driver for MEN 14F021P00 Board Management Controller - New driver for Ricoh RN5T618 PMIC - New driver for Rockchip RK808 - New driver for HiSilicon Hi6421 PMIC - New driver for Qualcomm SPMI PMICs - Add support for Intel Braswell in lpc_ich - Add support for Intel 9 Series PCH in lpc_ich - Add support for Intel Quark ILB in lpc_sch" [ Delayed to after the poweer/reset pull due to Kconfig problems with recursive Kconfig select/depends-on chains. - Linus ] * tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits) mfd: cros_ec: wait for completion of commands that return IN_PROGRESS i2c: i2c-cros-ec-tunnel: Set retries to 3 mfd: cros_ec: move locking into cros_ec_cmd_xfer mfd: cros_ec: stop calling ->cmd_xfer() directly mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC mfd: arizona: Correct mask to allow setting micbias external cap mfd: Add ACPI support Revert "mfd: wm5102: Manually apply register patch" mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention mfd: Inherit coherent_dma_mask from parent device mfd: Document DT bindings for Qualcomm SPMI PMICs mfd: Add support for Qualcomm SPMI PMICs mfd: dt-bindings: pm8xxx: Add new compatible string mfd: axp209x: Drop the parent supplies field mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off mfd: dt-bindings: twl4030-power: Use the standard property to mark power control mfd: syscon: Add Atmel GPBR DT bindings documention ...
2014-10-14MAINTAINERS: Update contact information for Vince BridgersVince Bridgers
Signed-off-by: Vince Bridgers <vbridger@opensource.altera.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main git pull for the drm, I pretty much froze major pulls at -rc5/6 time, and haven't had much fallout, so will probably continue doing that. Lots of changes all over, big internal header cleanup to make it clear drm features are legacy things and what are things that modern KMS drivers should be using. Also big move to use the new generic fences in all the TTM drivers. core: atomic prep work, vblank rework changes, allows immediate vblank disables major header reworking and cleanups to better delinate legacy interfaces from what KMS drivers should be using. cursor planes locking fixes ttm: move to generic fences (affects all TTM drivers) ppc64 caching fixes radeon: userptr support, uvd for old asics, reset rework for fence changes better buffer placement changes, dpm feature enablement hdmi audio support fixes intel: Cherryview work, 180 degree rotation, skylake prep work, execlist command submission full ppgtt prep work cursor improvements edid caching, vdd handling improvements nouveau: fence reworking kepler memory clock work gt21x clock work fan control improvements hdmi infoframe fixes DP audio ast: ppc64 fixes caching fix rcar: rcar-du DT support ipuv3: prep work for capture support msm: LVDS support for mdp4, new panel, gpu refactoring exynos: exynos3250 SoC support, drop bad mmap interface, mipi dsi changes, and component match support" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (640 commits) drm/mst: rework payload table allocation to conform better. drm/ast: Fix HW cursor image drm/radeon/kv: add uvd/vce info to dpm debugfs output drm/radeon/ci: add uvd/vce info to dpm debugfs output drm/radeon: export reservation_object from dmabuf to ttm drm/radeon: cope with foreign fences inside the reservation object drm/radeon: cope with foreign fences inside display drm/core: use helper to check driver features drm/radeon/cik: write gfx ucode version to ucode addr reg drm/radeon/si: print full CS when we hit a packet 0 drm/radeon: remove unecessary includes drm/radeon/combios: declare legacy_connector_convert as static drm/radeon/atombios: declare connector convert tables as static drm/radeon: drop btc_get_max_clock_from_voltage_dependency_table drm/radeon/dpm: drop clk/voltage dependency filters for BTC drm/radeon/dpm: drop clk/voltage dependency filters for CI drm/radeon/dpm: drop clk/voltage dependency filters for SI drm/radeon/dpm: drop clk/voltage dependency filters for NI drm/radeon: disable audio when we disable hdmi (v2) drm/radeon: split audio enable between eg and r600 (v2) ...
2014-10-14MAINTAINERS: remove Chirag Kantharia, invalid e-mailMichael Opdenacker
This removes Chirag Kantharia from the MAINTAINERS file, as his e-mail address is now rejected by the HP mail server. Make the driver "Orphan" until he gets back with a working e-mail address or a new maintainer steps in. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14MAINTAINERS: orphan m32rMichael Opdenacker
Update the maintenance status for m32r - Removing Hirokazu Takata as maintainer (last commit merged: Nov. 2009) - Remove mailing lists that no longer exist, as the ml.linux-m32r.org subdomain no longer exists. - Maintenance status moved to "Orphan" Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14MAINTAINERS: add atmel nand driver maintainer entryJosh Wu
Add an entry in MAINTAINERS file for ATMEL nand driver. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14MAINTAINERS: add entry for Kernel Selftest FrameworkShuah Khan
Add entry for Kernel Selftest Framework. Individual tests continue to be maintained by the maintainers for those areas. Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14MAINTAINERS: linaro-mm-sig is moderatedRandy Dunlap
Previous patch is awaiting moderator approval for posting to this mailing list. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14MAINTAINERS: remove non existent filesChristian Kujau
Inspired by some recent cleanups in MAINTAINERS the following files (F:) cannot be found any more in the tree: * arch/arm/mach-s5pv210/mach-aquila.c * arch/arm/mach-s5pv210/mach-goni.c Those two got removed in commit 28c8331d386a ("ARM: S5PV210: Remove support for board files"). Cc: Tomasz Figa <t.figa@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> * drivers/rtc/rtc-sec.c A MAINTAINERS fix was attempted in November 2012, but dismissed as rtc-sec.c was still being worked on. Alas, it's still not there. "MAINTAINERS: fix drivers/rtc/rtc-sec.c" http://lkml.iu.edu/hypermail/linux/kernel/1211.2/04820.html Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Cesar Eduardo Barros <cesarb@cesarb.eti.br> Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14MAINTAINERS: assign systemace driver to XilinxMichal Simek
Assign systemace driver to Xilinx Zynq to ensure if there is a change that someone can even test it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-13Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Ingo Molnar: "The main updates in this cycle were: - mutex MCS refactoring finishing touches: improve comments, refactor and clean up code, reduce debug data structure footprint, etc. - qrwlock finishing touches: remove old code, self-test updates. - small rwsem optimization - various smaller fixes/cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/lockdep: Revert qrwlock recusive stuff locking/rwsem: Avoid double checking before try acquiring write lock locking/rwsem: Move EXPORT_SYMBOL() lines to follow function definition locking/rwlock, x86: Delete unused asm/rwlock.h and rwlock.S locking/rwlock, x86: Clean up asm/spinlock*.h to remove old rwlock code locking/semaphore: Resolve some shadow warnings locking/selftest: Support queued rwlock locking/lockdep: Restrict the use of recursive read_lock() with qrwlock locking/spinlocks: Always evaluate the second argument of spin_lock_nested() locking/Documentation: Update locking/mutex-design.txt disadvantages locking/Documentation: Move locking related docs into Documentation/locking/ locking/mutexes: Use MUTEX_SPIN_ON_OWNER when appropriate locking/mutexes: Refactor optimistic spinning code locking/mcs: Remove obsolete comment locking/mutexes: Document quick lock release when unlocking locking/mutexes: Standardize arguments in lock/unlock slowpaths locking: Remove deprecated smp_mb__() barriers
2014-10-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris. Mostly ima, selinux, smack and key handling updates. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) integrity: do zero padding of the key id KEYS: output last portion of fingerprint in /proc/keys KEYS: strip 'id:' from ca_keyid KEYS: use swapped SKID for performing partial matching KEYS: Restore partial ID matching functionality for asymmetric keys X.509: If available, use the raw subjKeyId to form the key description KEYS: handle error code encoded in pointer selinux: normalize audit log formatting selinux: cleanup error reporting in selinux_nlmsg_perm() KEYS: Check hex2bin()'s return when generating an asymmetric key ID ima: detect violations for mmaped files ima: fix race condition on ima_rdwr_violation_check and process_measurement ima: added ima_policy_flag variable ima: return an error code from ima_add_boot_aggregate() ima: provide 'ima_appraise=log' kernel option ima: move keyring initialization to ima_init() PKCS#7: Handle PKCS#7 messages that contain no X.509 certs PKCS#7: Better handling of unsupported crypto KEYS: Overhaul key identification when searching for asymmetric keys KEYS: Implement binary asymmetric key ID handling ...
2014-10-12Merge tag 'ftracetest-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace test code from Steven Rostedt: "This patch series starts a new selftests section in the tools/testing/selftest directory called "ftrace" that holds tests aimed at testing ftrace and subsystems that use ftrace (like kprobes). So far only a few tests were written (by Masami Hiramatsu), but more will be added in the near future (3.19)" * tag 'ftracetest-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing/kprobes: Add selftest scripts testing kprobe-tracer as startup test ftracetest: Add POSIX.3 standard and XFAIL result codes ftracetest: Add kprobe basic testcases ftracetest: Add ftrace basic testcases ftracetest: Initial commit for ftracetest
2014-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "This set fixes a bunch of fallout from the changes that went in during this merge window, particularly: - Fix fsl_pq_mdio (Claudiu Manoil) and fm10k (Pranith Kumar) build failures. - Several networking drivers do atomic_set() on page counts where that's not exactly legal. From Eric Dumazet. - Make __skb_flow_get_ports() work cleanly with unaligned data, from Alexander Duyck. - Fix some kernel-doc buglets in rfkill and netlabel, from Fabian Frederick. - Unbalanced enable_irq_wake usage in bcmgenet and systemport drivers, from Florian Fainelli. - pxa168_eth needs to depend on HAS_DMA, from Geert Uytterhoeven. - Multi-dequeue in the qdisc layer severely bypasses the fairness limits the previous code used to enforce, reintroduce in a way that at the same time doesn't compromise bulk dequeue opportunities. From Jesper Dangaard Brouer. - macvlan receive path unnecessarily hops through a softirq by using netif_rx() instead of netif_receive_skb(). From Jason Baron" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (51 commits) net: systemport: avoid unbalanced enable_irq_wake calls net: bcmgenet: avoid unbalanced enable_irq_wake calls net: bcmgenet: fix off-by-one in incrementing read pointer net: fix races in page->_count manipulation mlx4: fix race accessing page->_count ixgbe: fix race accessing page->_count igb: fix race accessing page->_count fm10k: fix race accessing page->_count net/phy: micrel: Add clock support for KSZ8021/KSZ8031 flow-dissector: Fix alignment issue in __skb_flow_get_ports net: filter: fix the comments Documentation: replace __sk_run_filter with __bpf_prog_run macvlan: optimize the receive path macvlan: pass 'bool' type to macvlan_count_rx() drivers: net: xgene: Add 10GbE ethtool support drivers: net: xgene: Add 10GbE support drivers: net: xgene: Preparing for adding 10GbE support dtb: Add 10GbE node to APM X-Gene SoC device tree Documentation: dts: Update section header for APM X-Gene MAINTAINERS: Update APM X-Gene section ...
2014-10-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: "Here's a first pull request for powerpc updates for 3.18. The bulk of the additions are for the "cxl" driver, for IBM's Coherent Accelerator Processor Interface (CAPI). Most of it's in drivers/misc, which Greg & Arnd maintain, Greg said he was happy for us to take it through our tree. There's the usual minor cleanups and fixes, including a bit of noise in drivers from some of those. A bunch of updates to our EEH code, which has been getting more testing. Several nice speedups from Anton, including 20% in clear_page(). And a bunch of updates for freescale from Scott" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (130 commits) cxl: Fix afu_read() not doing finish_wait() on signal or non-blocking cxl: Add documentation for userspace APIs cxl: Add driver to Kbuild and Makefiles cxl: Add userspace header file cxl: Driver code for powernv PCIe based cards for userspace access cxl: Add base builtin support powerpc/mm: Add hooks for cxl powerpc/opal: Add PHB to cxl mode call powerpc/mm: Add new hash_page_mm() powerpc/powerpc: Add new PCIe functions for allocating cxl interrupts cxl: Add new header for call backs and structs powerpc/powernv: Split out set MSI IRQ chip code powerpc/mm: Export mmu_kernel_ssize and mmu_linear_psize powerpc/msi: Improve IRQ bitmap allocator powerpc/cell: Make spu_flush_all_slbs() generic powerpc/cell: Move data segment faulting code out of cell platform powerpc/cell: Move spu_handle_mm_fault() out of cell platform powerpc/pseries: Use new defines when calling H_SET_MODE powerpc: Update contact info in Documentation files powerpc/perf/hv-24x7: Simplify catalog_read() ...
2014-10-11Merge tag 'stable/for-linus-3.18-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from David Vrabel: "Features and fixes: - Add pvscsi frontend and backend drivers. - Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses. - Try and keep memory contiguous during PV memory setup (reduces SWIOTLB usage). - Allow front/back drivers to use threaded irqs. - Support large initrds in PV guests. - Fix PVH guests in preparation for Xen 4.5" * tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits) xen: remove DEFINE_XENBUS_DRIVER() macro xen/xenbus: Remove BUG_ON() when error string trucated xen/xenbus: Correct the comments for xenbus_grant_ring() x86/xen: Set EFER.NX and EFER.SCE in PVH guests xen: eliminate scalability issues from initrd handling xen: sync some headers with xen tree xen: make pvscsi frontend dependant on xenbus frontend arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options xen-scsifront: don't deadlock if the ring becomes full x86: remove the Xen-specific _PAGE_IOMAP PTE flag x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings x86: skip check for spurious faults for non-present faults xen/efi: Directly include needed headers xen-scsiback: clean up a type issue in scsiback_make_tpg() xen-scsifront: use GFP_ATOMIC under spin_lock MAINTAINERS: Add xen pvscsi maintainer xen-scsiback: Add Xen PV SCSI backend driver xen-scsifront: Add Xen PV SCSI frontend driver xen: Add Xen pvSCSI protocol description xen/events: support threaded irqs for interdomain event channels ...
2014-10-11Merge tag 'mmc-v3.18-1' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC updates from Ulf Hansson: "MMC core: - Fix SDIO IRQ bug - MMC regulator improvements - Fix slot-gpio card detect bug - Add support for Driver Stage Register - Convert the common MMC OF parser to use GPIO descriptors - Convert MMC_CAP2_NO_MULTI_READ into a callback, ->multi_io_quirk() - Some additional minor fixes MMC host: - mmci: Support Qualcomm specific DML layer for DMA - dw_mmc: Use common MMC regulators - dw_mmc: Add support for Rock-chips RK3288 - tmio: Enable runtime PM support - tmio: Add support for R-Car Gen2 SoCs - tmio: Several fixes and improvements - omap_hsmmc: Removed Balaji from MAINTAINERS - jz4740: add DMA and pre/post support - sdhci: Add support for Intel Braswell - sdhci: Several fixes and improvements" * tag 'mmc-v3.18-1' of git://git.linaro.org/people/ulf.hansson/mmc: (119 commits) ARM: dts: fix MMC2 regulators for Exynos5420 Arndale Octa board mmc: sdhci-acpi: Fix Braswell eMMC timeout clock frequency mmc: sdhci-acpi: Pass HID and UID to probe_slot mmc: sdhci-acpi: Get UID directly from acpi_device mmc, sdhci, bcm-kona, LLVMLinux: Remove use of __initconst mmc: sdhci-pci: Fix Braswell eMMC timeout clock frequency mmc: sdhci: Let a driver override timeout clock frequency mmc: sdhci-pci: Add Bay Trail and Braswell SD card detect mmc: sdhci-pci: Set SDHCI_QUIRK2_STOP_WITH_TC for Intel BYT host controllers mmc: sdhci-acpi: Add a HID and UID for a SD Card host controller mmc: sdhci-acpi: Set SDHCI_QUIRK2_STOP_WITH_TC for Intel host controllers mmc: sdhci: Add quirk for always getting TC with stop cmd mmc: core: restore detect line inversion semantics mmc: Fix incorrect warning when setting 0 Hz via debugfs mmc: Fix use of wrong device in mmc_gpiod_free_cd() mmc: atmel-mci: fix mismatched section on atmci_cleanup_slot mmc: rtsx_pci: Set power related cap2 macros mmc: core: Add new power_mode MMC_POWER_UNDEFINED mmc: sdhci: execute tuning when device is not busy mmc: atmel-mci: Release mmc resources on failure in probe ..
2014-10-10Merge tag 'media/v3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - new IR driver: hix5hd2-ir - the virtual test driver (vivi) was replaced by vivid, with has an almost complete set of features to emulate most v4l2 devices and properly test all sorts of userspace apps - the as102 driver had several bugs fixed and was properly split into a frontend and a core driver. With that, it got promoted from staging into mainstream - one new CI driver got added for CIMaX SP2/SP2HF (sp2 driver) - one new frontend driver for Toshiba ISDB-T/ISDB-S demod (tc90522) - one new PCI driver for ISDB-T/ISDB-S (pt3 driver) - saa7134 driver got support for go7007-based devices - added a new PCI driver for Techwell 68xx chipsets (tw68) - a new platform driver was added (coda) - new tuner drivers: mxl301rf and qm1d1c0042 - a new DVB USB driver was added for DVBSky S860 & similar devices - added a new SDR driver (hackrf) - usbtv got audio support - several platform drivers are now compiled with COMPILE_TEST - a series of compiler fixup patches, making sparse/spatch happier with the media stuff and removing several warnings, especially on those platform drivers that didn't use to compile on x86 - Support for several new modern devices got added - lots of other fixes, improvements and cleanups * tag 'media/v3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (544 commits) [media] ir-hix5hd2: fix build on c6x arch [media] pt3: fix DTV FE I2C driver load error paths Revert "[media] media: em28xx - remove reset_resume interface" [media] exynos4-is: fix some warnings when compiling on arm64 [media] usb drivers: use %zu instead of %zd [media] pci drivers: use %zu instead of %zd [media] dvb-frontends: use %zu instead of %zd [media] s5p-mfc: Fix several printk warnings [media] s5p_mfc_opr: Fix warnings [media] ti-vpe: Fix typecast [media] s3c-camif: fix dma_addr_t printks [media] s5p_mfc_opr_v6: get rid of warnings when compiled with 64 bits [media] s5p_mfc_opr_v5: Fix lots of warnings on x86_64 [media] em28xx: Fix identation [media] drxd: remove a dead code [media] saa7146: remove return after BUG() [media] cx88: remove return after BUG() [media] cx88: fix cards table CodingStyle [media] radio-sf16fmr2: declare some structs as static [media] radio-sf16fmi: declare pnp_attached as static ...
2014-10-10Merge tag 'hwmon-for-linus-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: - new driver for menf21bmc. - convert k10temp, smsc47b397, da9052, da9055 to new hwmon API. - register ntc_thermistor driver with thermal subsystem. - add support for F15h M60h to k10temp driver. - add driver for MEN14F021P00 BMC HWMON driver; this required a merge with tag mfd-hwmon-leds-watchdog-v3.18 * tag 'hwmon-for-linus-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (ab8500) Call kernel_power_off instead of pm_power_off hwmon: (menf21bmc) Introduce MEN14F021P00 BMC HWMON driver leds: leds-menf21bmc: Introduce MEN 14F021P00 BMC LED driver watchdog: menf21bmc_wdt: Introduce MEN 14F021P00 BMC Watchdog driver mfd: menf21bmc: Introduce MEN 14F021P00 BMC MFD Core driver hwmon: (ntc_thermistor) Add ntc thermistor to thermal subsystem as a sensor. hwmon: (smsc47b397) Convert to devm_hwmon_device_register_with_groups MAINTAINERS: add entry for the PWM fan driver hwmon: (k10temp) Convert to devm_hwmon_device_register_with_groups hwmon: (k10temp) Add support for F15h M60h hwmon: (da9052) Convert to devm_hwmon_device_register_with_groups hwmon: (da9055) Convert to devm_hwmon_device_register_with_groups hwmon: (ads1015) Use of_property_read_u32 at appropriate places
2014-10-10MAINTAINERS: Update APM X-Gene sectionIyappan Subramanian
Updated APM X-Gene ethernet driver maintainers list. Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: Keyur Chudgar <kchudgar@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-09Merge tag 'pm+acpi-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "Features-wise, to me the most important this time is a rework of wakeup interrupts handling in the core that makes them work consistently across all of the available sleep states, including suspend-to-idle. Many thanks to Thomas Gleixner for his help with this work. Second is an update of the generic PM domains code that has been in need of some care for quite a while. Unused code is being removed, DT support is being added and domains are now going to be attached to devices in bus type code in analogy with the ACPI PM domain. The majority of work here was done by Ulf Hansson who also has been the most active developer this time. Apart from this we have a traditional ACPICA update, this time to upstream version 20140828 and a few ACPI wakeup interrupts handling patches on top of the general rework mentioned above. There also are several cpufreq commits including renaming the cpufreq-cpu0 driver to cpufreq-dt, as this is what implements generic DT-based cpufreq support, and a new DT-based idle states infrastructure for cpuidle. In addition to that, the ACPI LPSS driver is updated, ACPI support for Apple machines is improved, a few bugs are fixed and a few cleanups are made all over. Finally, the Adaptive Voltage Scaling (AVS) subsystem now has a tree maintained by Kevin Hilman that will be merged through the PM tree. Numbers-wise, the generic PM domains update takes the lead this time with 32 non-merge commits, second is cpufreq (15 commits) and the 3rd place goes to the wakeup interrupts handling rework (13 commits). Specifics: - Rework the handling of wakeup IRQs by the IRQ core such that all of them will be switched over to "wakeup" mode in suspend_device_irqs() and in that mode the first interrupt will abort system suspend in progress or wake up the system if already in suspend-to-idle (or equivalent) without executing any interrupt handlers. Among other things that eliminates the wakeup-related motivation to use the IRQF_NO_SUSPEND interrupt flag with interrupts which don't really need it and should not use it (Thomas Gleixner and Rafael Wysocki) - Switch over ACPI to handling wakeup interrupts with the help of the new mechanism introduced by the above IRQ core rework (Rafael Wysocki) - Rework the core generic PM domains code to eliminate code that's not used, add DT support and add a generic mechanism by which devices can be added to PM domains automatically during enumeration (Ulf Hansson, Geert Uytterhoeven and Tomasz Figa). - Add debugfs-based mechanics for debugging generic PM domains (Maciej Matraszek). - ACPICA update to upstream version 20140828. Included are updates related to the SRAT and GTDT tables and the _PSx methods are in the METHOD_NAME list now (Bob Moore and Hanjun Guo). - Add _OSI("Darwin") support to the ACPI core (unfortunately, that can't really be done in a straightforward way) to prevent Thunderbolt from being turned off on Apple systems after boot (or after resume from system suspend) and rework the ACPI Smart Battery Subsystem (SBS) driver to work correctly with Apple platforms (Matthew Garrett and Andreas Noever). - ACPI LPSS (Low-Power Subsystem) driver update cleaning up the code, adding support for 133MHz I2C source clock on Intel Baytrail to it and making it avoid using UART RTS override with Auto Flow Control (Heikki Krogerus). - ACPI backlight updates removing the video_set_use_native_backlight quirk which is not necessary any more, making the code check the list of output devices returned by the _DOD method to avoid creating acpi_video interfaces that won't work and adding a quirk for Lenovo Ideapad Z570 (Hans de Goede, Aaron Lu and Stepan Bujnak) - New Win8 ACPI OSI quirks for some Dell laptops (Edward Lin) - Assorted ACPI code cleanups (Fabian Frederick, Rasmus Villemoes, Sudip Mukherjee, Yijing Wang, and Zhang Rui) - cpufreq core updates and cleanups (Viresh Kumar, Preeti U Murthy, Rasmus Villemoes) - cpufreq driver updates: cpufreq-cpu0/cpufreq-dt (driver name change among other things), ppc-corenet, powernv (Viresh Kumar, Preeti U Murthy, Shilpasri G Bhat, Lucas Stach) - cpuidle support for DT-based idle states infrastructure, new ARM64 cpuidle driver, cpuidle core cleanups (Lorenzo Pieralisi, Rasmus Villemoes) - ARM big.LITTLE cpuidle driver updates: support for DT-based initialization and Exynos5800 compatible string (Lorenzo Pieralisi, Kevin Hilman) - Rework of the test_suspend kernel command line argument and a new trace event for console resume (Srinivas Pandruvada, Todd E Brandt) - Second attempt to optimize swsusp_free() (hibernation core) to make it avoid going through all PFNs which may be way too slow on some systems (Joerg Roedel) - devfreq updates (Paul Bolle, Punit Agrawal, Ãrjan Eide). - rockchip-io Adaptive Voltage Scaling (AVS) driver and AVS entry update in MAINTAINERS (Heiko Stübner, Kevin Hilman) - PM core fix related to clock management (Geert Uytterhoeven) - PM core's sysfs code cleanup (Johannes Berg)" * tag 'pm+acpi-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (105 commits) ACPI / fan: printk replacement PM / clk: Fix crash in clocks management code if !CONFIG_PM_RUNTIME PM / Domains: Rename cpu_data to cpuidle_data cpufreq: cpufreq-dt: fix potential double put of cpu OF node cpufreq: cpu0: rename driver and internals to 'cpufreq_dt' PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free() cpufreq: ppc-corenet: remove duplicate update of cpu_data ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle PM / sleep: Rename platform suspend/resume functions in suspend.c PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq() ACPICA: Introduce acpi_enable_all_wakeup_gpes() ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block() ACPI / video: check _DOD list when creating backlight devices PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h cpufreq: Replace strnicmp with strncasecmp cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum cpufreq: Allow stop CPU callback to be used by all cpufreq drivers PM / devfreq: exynos: Enable building exynos PPMU as module PM / devfreq: Export helper functions for drivers ...
2014-10-09Merge tag 'pci-v3.18-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "The interesting things here are: - Turn on Config Request Retry Status Software Visibility. This caused hangs last time, but we included a fix this time. - Rework PCI device configuration to use _HPP/_HPX more aggressively - Allow PCI devices to be put into D3cold during system suspend - Add arm64 PCI support - Add APM X-Gene host bridge driver - Add TI Keystone host bridge driver - Add Xilinx AXI host bridge driver More detailed summary: Enumeration - Check Vendor ID only for Config Request Retry Status (Rajat Jain) - Enable Config Request Retry Status when supported (Rajat Jain) - Add generic domain handling (Catalin Marinas) - Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado) Resource management - Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu) - Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr) PCI device hotplug - Prevent NULL dereference during pciehp probe (Andreas Noever) - Move _HPP & _HPX handling into core (Bjorn Helgaas) - Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas) - Apply _HPP/_HPX to display devices (Bjorn Helgaas) - Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas) - Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas) - Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas) - Fix wait time in pciehp timeout message (Yinghai Lu) - Add more pciehp Slot Control debug output (Yinghai Lu) - Stop disabling pciehp notifications during init (Yinghai Lu) MSI - Remove arch_msi_check_device() (Alexander Gordeev) - Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev) - Move D0 check into pci_msi_check_device() (Alexander Gordeev) - Remove unused kobject from struct msi_desc (Yijing Wang) - Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang) - Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang) - Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang) - Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang) - Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang) Power management - Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki) - Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki) AER - Add additional AER error strings (Gong Chen) - Make <linux/aer.h> standalone includable (Thierry Reding) Virtualization - Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson) - Add ACS quirk for Intel 10G NICs (Alex Williamson) - Add ACS quirk for AMD A88X southbridge (Marti Raudsepp) - Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson) - Add device flag helpers (Ethan Zhao) - Assume all Mellanox devices have broken INTx masking (Gavin Shan) Generic host bridge driver - Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau) - Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau) - Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau) - Fix the conversion of IO ranges into IO resources (Liviu Dudau) - Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau) - Add support for parsing PCI host bridge resources from DT (Liviu Dudau) - Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau) - Add arm64 architectural support for PCI (Liviu Dudau) APM X-Gene - Add APM X-Gene PCIe driver (Tanmay Inamdar) - Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar) Freescale i.MX6 - Probe in module_init(), not fs_initcall() (Lucas Stach) - Delay enabling reference clock for SS until it stabilizes (Tim Harvey) Marvell MVEBU - Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni) NVIDIA Tegra - Make sure the PCIe PLL is really reset (Eric Yuen) - Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang) - Fix extended configuration space mapping (Peter Daifuku) - Implement resource hierarchy (Thierry Reding) - Clear CLKREQ# enable on port disable (Thierry Reding) - Add Tegra124 support (Thierry Reding) ST Microelectronics SPEAr13xx - Pass config resource through reg property (Pratyush Anand) Synopsys DesignWare - Use NULL instead of false (Fabio Estevam) - Parse bus-range property from devicetree (Lucas Stach) - Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach) - Remove pci_assign_unassigned_resources() (Lucas Stach) - Check private_data validity in single place (Lucas Stach) - Setup and clear exactly one MSI at a time (Lucas Stach) - Remove open-coded bitmap operations (Lucas Stach) - Fix configuration base address when using 'reg' (Minghuan Lian) - Fix IO resource end address calculation (Minghuan Lian) - Rename get_msi_data() to get_msi_addr() (Minghuan Lian) - Add get_msi_data() to pcie_host_ops (Minghuan Lian) - Add support for v3.65 hardware (Murali Karicheri) - Fold struct pcie_port_info into struct pcie_port (Pratyush Anand) TI Keystone - Add TI Keystone PCIe driver (Murali Karicheri) - Limit MRSS for all downstream devices (Murali Karicheri) - Assume controller is already in RC mode (Murali Karicheri) - Set device ID based on SoC to support multiple ports (Murali Karicheri) Xilinx AXI - Add Xilinx AXI PCIe driver (Srikanth Thokala) - Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter) Miscellaneous - Clean up whitespace (Quentin Lambert) - Remove assignments from "if" conditions (Quentin Lambert) - Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri) - x86: Mark DMI tables as initialization data (Mathias Krause) - x86: Move __init annotation to the correct place (Mathias Krause) - x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause) - x86: Constify pci_mmcfg_probes[] array (Mathias Krause) - x86: Mark PCI BIOS initialization code as such (Mathias Krause) - Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya) - Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)" * tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits) arm64: dts: Add APM X-Gene PCIe device tree nodes PCI: Add ACS quirk for AMD A88X southbridge devices PCI: xgene: Add APM X-Gene PCIe driver PCI: designware: Remove open-coded bitmap operations PCI/MSI: Remove unnecessary temporary variable PCI/MSI: Use __write_msi_msg() instead of write_msi_msg() MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg() PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg() PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib PCI/MSI: Remove unused kobject from struct msi_desc PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported() PCI/MSI: Move D0 check into pci_msi_check_device() PCI/MSI: Remove arch_msi_check_device() irqchip: armada-370-xp: Remove arch_msi_check_device() PCI/MSI/PPC: Remove arch_msi_check_device() arm64: Add architectural support for PCI PCI: Add pci_remap_iospace() to map bus I/O resources of/pci: Add support for parsing PCI host bridge resources from DT of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr() ... Conflicts: arch/arm64/boot/dts/apm-storm.dtsi
2014-10-09Merge branch 'patchwork' into v4l_for_linusMauro Carvalho Chehab
* patchwork: (544 commits) [media] ir-hix5hd2: fix build on c6x arch [media] pt3: fix DTV FE I2C driver load error paths Revert "[media] media: em28xx - remove reset_resume interface" [media] exynos4-is: fix some warnings when compiling on arm64 [media] usb drivers: use %zu instead of %zd [media] pci drivers: use %zu instead of %zd [media] dvb-frontends: use %zu instead of %zd [media] s5p-mfc: Fix several printk warnings [media] s5p_mfc_opr: Fix warnings [media] ti-vpe: Fix typecast [media] s3c-camif: fix dma_addr_t printks [media] s5p_mfc_opr_v6: get rid of warnings when compiled with 64 bits [media] s5p_mfc_opr_v5: Fix lots of warnings on x86_64 [media] em28xx: Fix identation [media] drxd: remove a dead code [media] saa7146: remove return after BUG() [media] cx88: remove return after BUG() [media] cx88: fix cards table CodingStyle [media] radio-sf16fmr2: declare some structs as static [media] radio-sf16fmi: declare pnp_attached as static ... Conflicts: Documentation/DocBook/media/v4l/compat.xml
2014-10-09Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "The irq departement delivers: - a cleanup series to get rid of mindlessly copied code. - another bunch of new pointlessly different interrupt chip drivers. Adding homebrewn irq chips (and timers) to SoCs must provide a value add which is beyond the imagination of mere mortals. - the usual SoC irq controller updates, IOW my second cat herding project" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) irqchip: gic-v3: Implement CPU PM notifier irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling irqchip: renesas-intc-irqpin: Add minimal runtime PM support irqchip: renesas-intc-irqpin: Add helper variable dev = &pdev->dev irqchip: atmel-aic5: Add sama5d4 support irqchip: atmel-aic5: The sama5d3 has 48 IRQs Documentation: bcm7120-l2: Add Broadcom BCM7120-style L2 binding irqchip: bcm7120-l2: Add Broadcom BCM7120-style Level 2 interrupt controller irqchip: renesas-irqc: Add binding docs for new R-Car Gen2 SoCs irqchip: renesas-irqc: Add DT binding documentation irqchip: renesas-intc-irqpin: Document SoC-specific bindings openrisc: Get rid of handle_IRQ arm64: Get rid of handle_IRQ ARM: omap2: irq: Convert to handle_domain_irq ARM: imx: tzic: Convert to handle_domain_irq ARM: imx: avic: Convert to handle_domain_irq irqchip: or1k-pic: Convert to handle_domain_irq irqchip: atmel-aic5: Convert to handle_domain_irq irqchip: atmel-aic: Convert to handle_domain_irq irqchip: gic-v3: Convert to handle_domain_irq ...
2014-10-09IB/iser: Bump version, add maintainerOr Gerlitz
Update the driver version and add Sagi Grimberg as maintainer Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Most notable changes in here: 1) By far the biggest accomplishment, thanks to a large range of contributors, is the addition of multi-send for transmit. This is the result of discussions back in Chicago, and the hard work of several individuals. Now, when the ->ndo_start_xmit() method of a driver sees skb->xmit_more as true, it can choose to defer the doorbell telling the driver to start processing the new TX queue entires. skb->xmit_more means that the generic networking is guaranteed to call the driver immediately with another SKB to send. There is logic added to the qdisc layer to dequeue multiple packets at a time, and the handling mis-predicted offloads in software is now done with no locks held. Finally, pktgen is extended to have a "burst" parameter that can be used to test a multi-send implementation. Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4, virtio_net Adding support is almost trivial, so export more drivers to support this optimization soon. I want to thank, in no particular or implied order, Jesper Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann, David Tat, Hannes Frederic Sowa, and Rusty Russell. 2) PTP and timestamping support in bnx2x, from Michal Kalderon. 3) Allow adjusting the rx_copybreak threshold for a driver via ethtool, and add rx_copybreak support to enic driver. From Govindarajulu Varadarajan. 4) Significant enhancements to the generic PHY layer and the bcm7xxx driver in particular (EEE support, auto power down, etc.) from Florian Fainelli. 5) Allow raw buffers to be used for flow dissection, allowing drivers to determine the optimal "linear pull" size for devices that DMA into pools of pages. The objective is to get exactly the necessary amount of headers into the linear SKB area pre-pulled, but no more. The new interface drivers use is eth_get_headlen(). From WANG Cong, with driver conversions (several had their own by-hand duplicated implementations) by Alexander Duyck and Eric Dumazet. 6) Support checksumming more smoothly and efficiently for encapsulations, and add "foo over UDP" facility. From Tom Herbert. 7) Add Broadcom SF2 switch driver to DSA layer, from Florian Fainelli. 8) eBPF now can load programs via a system call and has an extensive testsuite. Alexei Starovoitov and Daniel Borkmann. 9) Major overhaul of the packet scheduler to use RCU in several major areas such as the classifiers and rate estimators. From John Fastabend. 10) Add driver for Intel FM10000 Ethernet Switch, from Alexander Duyck. 11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric Dumazet. 12) Add Datacenter TCP congestion control algorithm support, From Florian Westphal. 13) Reorganize sk_buff so that __copy_skb_header() is significantly faster. From Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits) netlabel: directly return netlbl_unlabel_genl_init() net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers net: description of dma_cookie cause make xmldocs warning cxgb4: clean up a type issue cxgb4: potential shift wrapping bug i40e: skb->xmit_more support net: fs_enet: Add NAPI TX net: fs_enet: Remove non NAPI RX r8169:add support for RTL8168EP net_sched: copy exts->type in tcf_exts_change() wimax: convert printk to pr_foo() af_unix: remove 0 assignment on static ipv6: Do not warn for informational ICMP messages, regardless of type. Update Intel Ethernet Driver maintainers list bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING tipc: fix bug in multicast congestion handling net: better IFF_XMIT_DST_RELEASE support net/mlx4_en: remove NETDEV_TX_BUSY 3c59x: fix bad split of cpu_to_le32(pci_map_single()) net: bcmgenet: fix Tx ring priority programming ...
2014-10-08Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. Most of the new code is for the Keystone Navigator driver, which is new base support that is going to be needed for their hardware accelerated network driver and other units. Most of the commits are for moving old code around from at91 and omap for things that are done in device drivers nowadays. - at91: move reset, poweroff, memory and clocksource code into drivers directories - socfpga: add edac driver (through arm-soc, as requested by Boris) - omap: move omap-intc code to drivers/irqchip - sunxi: added an RTC driver for sun6i - omap: mailbox driver related changes - keystone: support for the "Navigator" component - versatile: new reboot, led and soc drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (92 commits) bus: arm-ccn: Fix spurious warning message leds: add device tree bindings for register bit LEDs soc: add driver for the ARM RealView power: reset: driver for the Versatile syscon reboot leds: add a driver for syscon-based LEDs drivers/soc: ti: fix build break with modules MAINTAINERS: Add Keystone Multicore Navigator drivers entry soc: ti: add Keystone Navigator DMA support Documentation: dt: soc: add Keystone Navigator DMA bindings soc: ti: add Keystone Navigator QMSS driver Documentation: dt: soc: add Keystone Navigator QMSS bindings rtc: sunxi: Depend on platforms sun4i/sun7i that actually have the rtc rtc: sun6i: Add sun6i RTC driver irqchip: omap-intc: remove unnecessary comments irqchip: omap-intc: correct maximum number or MIR registers irqchip: omap-intc: enable TURBO idle mode irqchip: omap-intc: enable IP protection irqchip: omap-intc: remove unnecesary of_address_to_resource() call irqchip: omap-intc: comment style cleanup irqchip: omap-intc: minor improvement to omap_irq_pending() ...
