path: root/MAINTAINERS
2019-05-07dt-bindings: mtd: Add bindings for TI's AM654 HyperBus memory controllerVignesh Raghavendra
Add binding documentation for TI's HyperBus memory controller present on AM654 SoC. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2019-05-07mtd: Add support for HyperBus memory devicesVignesh Raghavendra
Cypress' HyperBus is Low Signal Count, High Performance Double Data Rate Bus interface between a host system master and one or more slave interfaces. HyperBus is used to connect microprocessor, microcontroller, or ASIC devices with random access NOR flash memory (called HyperFlash) or self refresh DRAM (called HyperRAM). Its a 8-bit data bus (DQ[7:0]) with Read-Write Data Strobe (RWDS) signal and either Single-ended clock(3.0V parts) or Differential clock (1.8V parts). It uses ChipSelect lines to select b/w multiple slaves. At bus level, it follows a separate protocol described in HyperBus specification[1]. HyperFlash follows CFI AMD/Fujitsu Extended Command Set (0x0002) similar to that of existing parallel NORs. Since HyperBus is x8 DDR bus, its equivalent to x16 parallel NOR flash wrt bits per clock cycle. But HyperBus operates at >166MHz frequencies. HyperRAM provides direct random read/write access to flash memory array. But, HyperBus memory controllers seem to abstract implementation details and expose a simple MMIO interface to access connected flash. Add support for registering HyperFlash devices with MTD framework. MTD maps framework along with CFI chip support framework are used to support communicating with flash. Framework is modelled along the lines of spi-nor framework. HyperBus memory controller (HBMC) drivers calls hyperbus_register_device() to register a single HyperFlash device. HyperFlash core parses MMIO access information from DT, sets up the map_info struct, probes CFI flash and registers it with MTD framework. Some HBMC masters need calibration/training sequence[3] to be carried out, in order for DLL inside the controller to lock, by reading a known string/pattern. This is done by repeatedly reading CFI Query Identification String. Calibration needs to be done before trying to detect flash as part of CFI flash probe. HyperRAM is not supported at the moment. HyperBus specification can be found at[1] HyperFlash datasheet can be found at[2] [1] https://www.cypress.com/file/213356/download [2] https://www.cypress.com/file/213346/download [3] http://www.ti.com/lit/ug/spruid7b/spruid7b.pdf Table 12-5741. HyperFlash Access Sequence Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2018-12-01MAINTAINERS: Add Sasha as a stable branch maintainerGreg Kroah-Hartman
commit cb5d21946d2a2f4687c482ab4604af1d29dac35a upstream. Sasha has somehow been convinced into helping me with the stable kernel maintenance. Codify this slip in good judgement before he realizes what he really signed up for :) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-15dt-bindings: Document mti,mips-cpc bindingPaul Burton
commit aece34cd576c7625181b0488a8129c1e165355f7 upstream. Document a binding for the MIPS Cluster Power Controller (CPC) that allows the device tree to specify where the CPC registers are located. Signed-off-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com> Reviewed-by: Rob Herring <robh@kernel.org> Cc: linux-mips@linux-mips.org Cc: devicetree@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/18512/ Signed-off-by: James Hogan <jhogan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22kmemcheck: rip it outLevin, Alexander (Sasha Levin)
commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream. Fix up makefiles, remove references, and git rm kmemcheck. Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Vegard Nossum <vegardno@ifi.uio.no> Cc: Pekka Enberg <penberg@kernel.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexander Potapenko <glider@google.com> Cc: Tim Hansen <devtimhansen@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-09Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "2 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: MAINTAINERS: update TPM driver infrastructure changes sysctl: add register_sysctl() dummy helper
2017-11-09MAINTAINERS: update TPM driver infrastructure changesJarkko Sakkinen
[akpm@linux-foundation.org: alpha-sort CREDITS, per Randy] Link: http://lkml.kernel.org/r/20170915223811.21368-1-jarkko.sakkinen@linux.intel.com Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Ashley Lai <ashleydlai@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Borislav Petkov <bp@suse.de> Cc: Håvard Skinnemoen <hskinnemoen@gmail.com> Cc: Martin Kepplinger <martink@posteo.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mauro Carvalho Chehab <mchehab@kernel.org> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-09Merge tag 'pci-v4.14-fixes-7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI maintainership updates from Bjorn Helgaas: "Update MAINTAINERS for HiSilicon, Microsemi Switchtec, and native host bridge drivers (Gabriele Paoloni, Sebastian Andrzej Siewior). Note that starting with changes intended for v4.16, Lorenzo Pieralisi will maintain the drivers/pci/{dwc,endpoint,host} directories. My intent is to continue to merge those changes via my tree, so this should be transparent to you" * tag 'pci-v4.14-fixes-7' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: MAINTAINERS: Add Lorenzo Pieralisi for PCI host bridge drivers MAINTAINERS: Remove Gabriele Paoloni as HiSilicon PCI maintainer MAINTAINERS: Remove Stephen Bates as Microsemi Switchtec maintainer
2017-11-08MAINTAINERS: Add Lorenzo Pieralisi for PCI host bridge driversBjorn Helgaas
Add Lorenzo Pieralisi as maintainer for PCI native host bridge drivers and the endpoint driver framework. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2017-11-07MAINTAINERS: Remove Gabriele Paoloni as HiSilicon PCI maintainerGabriele Paoloni
Gabriele is now moving to a different role, so remove him as HiSilicon PCI maintainer. Signed-off-by: Gabriele Paoloni <gabriele.paoloni@huawei.com> [bhelgaas: Thanks for all your help, Gabriele, and best wishes!] Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Zhou Wang <wangzhou1@hisilicon.com>
2017-11-07MAINTAINERS: Remove Stephen Bates as Microsemi Switchtec maintainerSebastian Andrzej Siewior
Just sent an email there and received an autoreply because he no longer works there. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-11-06scripts: add leaking_addresses.plTobin C. Harding
Currently we are leaking addresses from the kernel to user space. This script is an attempt to find some of those leakages. Script parses `dmesg` output and /proc and /sys files for hex strings that look like kernel addresses. Only works for 64 bit kernels, the reason being that kernel addresses on 64 bit kernels have 'ffff' as the leading bit pattern making greping possible. On 32 kernels we don't have this luxury. Scripts is _slightly_ smarter than a straight grep, we check for false positives (all 0's or all 1's, and vsyscall start/finish addresses). [ I think there is a lot of room for improvement here, but it's already useful, so I'm merging it as-is. The whole "hash %p format" series is expected to go into 4.15, but will not fix %x users, and will not incentivize people to look at what they are leaking. - Linus ] Signed-off-by: Tobin C. Harding <me@tobin.cc> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-04Merge tag 'mips_fixes_4.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips Pull MIPS fixes from James Hogan: "A selection of important MIPS fixes for 4.14, and some MAINTAINERS / email address updates: Maintainership updates: - imgtec.com -> mips.com email addresses (this trivially updates comments in quite a few files, as well as MAINTAINERS) - Pistachio SoC maintainership update Fixes: - NI 169445 build (new platform in 4.14) - EVA regression (4.14) - SMP-CPS build & preemption regressions (4.14) - SMP/hotplug deadlock & race (deadlock reintroduced 4.13) - ebpf_jit error return (4.13) - SMP-CMP build regressions (4.11 and 4.14) - bad UASM microMIPS encoding (3.16) - CM definitions (3.15)" [ I had taken the email address updates separately, because I didn't expect James to send a pull request, so those got applied twice. - Linus] * tag 'mips_fixes_4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips: MIPS: Update email address for Marcin Nowakowski MIPS: smp-cmp: Fix vpe_id build error MAINTAINERS: Update Pistachio platform maintainers MIPS: smp-cmp: Use right include for task_struct MIPS: Update Goldfish RTC driver maintainer email address MIPS: Update RINT emulation maintainer email address MIPS: CPS: Fix use of current_cpu_data in preemptible code MIPS: SMP: Fix deadlock & online race MIPS: bpf: Fix a typo in build_one_insn() MIPS: microMIPS: Fix incorrect mask in insn_table_MM MIPS: Fix CM region target definitions MIPS: generic: Fix compilation error from include asm/mips-cpc.h MIPS: Fix exception entry when CONFIG_EVA enabled MIPS: generic: Fix NI 169445 its build Update MIPS email addresses
2017-11-03Update MIPS email addressesPaul Burton
MIPS will soon not be a part of Imagination Technologies, and as such many @imgtec.com email addresses will no longer be valid. This patch updates the addresses for those who: - Have 10 or more patches in mainline authored using an @imgtec.com email address, or any patches dated within the past year. - Are still with Imagination but leaving as part of the MIPS business unit, as determined from an internal email address list. - Haven't already updated their email address (ie. JamesH) or expressed a desire to be excluded (ie. Maciej). - Acked v2 or earlier of this patch, which leaves Deng-Cheng, Matt & myself. New addresses are of the form firstname.lastname@mips.com, and all verified against an internal email address list. An entry is added to .mailmap for each person such that get_maintainer.pl will report the new addresses rather than @imgtec.com addresses which will soon be dead. Instances of the affected addresses throughout the tree are then mechanically replaced with the new @mips.com address. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@mips.com> Acked-by: Dengcheng Zhu <dengcheng.zhu@mips.com> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Matt Redfearn <matt.redfearn@mips.com> Acked-by: Matt Redfearn <matt.redfearn@mips.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: trivial@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-01MAINTAINERS: Update Pistachio platform maintainersJames Hartley
Neither of the current maintainers works for Imagination any more. Removed both imgtec email addresses and added back mine for occasional reviews, also changed from Maintained to Odd Fixes to reflect the time that I will be able to spend on it. Signed-off-by: James Hartley <james.hartley@sondrel.com> Patchwork: https://patchwork.linux-mips.org/patch/17475/ Signed-off-by: James Hogan <jhogan@kernel.org>
2017-11-01MIPS: Update Goldfish RTC driver maintainer email addressAleksandar Markovic
Change all relevant instances of miodrag.dinic@imgtec.com email address to miodrag.dinic@mips.com. Signed-off-by: Miodrag Dinic <miodrag.dinic@mips.com> Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/17515/ [jhogan@kernel.org: Fix .mailmap direction] Signed-off-by: James Hogan <jhogan@kernel.org>
2017-11-01MIPS: Update RINT emulation maintainer email addressAleksandar Markovic
Change all relevant instances of aleksandar.markovic@imgtec.com email address to aleksandar.markovic@mips.com. Signed-off-by: Miodrag Dinic <miodrag.dinic@mips.com> Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/17514/ Signed-off-by: James Hogan <jhogan@kernel.org>
2017-11-01MAINTAINERS: Remove Yotam from mlxfwYuval Mintz
Provide a mailing list for maintenance of the module instead. Signed-off-by: Yuval Mintz <yuvalm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-11-01MAINTAINERS: Update Yotam's E-mailYotam Gigi
For the time being I will be available in my private mail. Update both the MAINTAINERS file and the individual modules MODULE_AUTHOR directive with the new address. Signed-off-by: Yotam Gigi <yotam.gi@gmail.com> Signed-off-by: Yuval Mintz <yuvalm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-31Update MIPS email addressesPaul Burton
MIPS will soon not be a part of Imagination Technologies, and as such many @imgtec.com email addresses will no longer be valid. This patch updates the addresses for those who: - Have 10 or more patches in mainline authored using an @imgtec.com email address, or any patches dated within the past year. - Are still with Imagination but leaving as part of the MIPS business unit, as determined from an internal email address list. - Haven't already updated their email address (ie. JamesH) or expressed a desire to be excluded (ie. Maciej). - Acked v2 or earlier of this patch, which leaves Deng-Cheng, Matt & myself. New addresses are of the form firstname.lastname@mips.com, and all verified against an internal email address list. An entry is added to .mailmap for each person such that get_maintainer.pl will report the new addresses rather than @imgtec.com addresses which will soon be dead. Instances of the affected addresses throughout the tree are then mechanically replaced with the new @mips.com address. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@mips.com> Acked-by: Dengcheng Zhu <dengcheng.zhu@mips.com> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Matt Redfearn <matt.redfearn@mips.com> Acked-by: Matt Redfearn <matt.redfearn@mips.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: trivial@kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17540/ Signed-off-by: James Hogan <jhogan@kernel.org>
2017-10-27Merge tag 'for-linus-4.14c-rc7-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen fixes from Juergen Gross: - a fix for the Xen gntdev device repairing an issue in case of partial failure of mapping multiple pages of another domain - a fix of a regression in the Xen balloon driver introduced in 4.13 - a build fix for Xen on ARM which will trigger e.g. for Linux RT - a maintainers update for pvops (not really Xen, but carrying through this tree just for convenience) * tag 'for-linus-4.14c-rc7-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: maintainers: drop Chris Wright from pvops arm/xen: don't inclide rwlock.h directly. xen: fix booting ballooned down hvm guest xen/gntdev: avoid out of bounds access in case of partial gntdev_mmap()
2017-10-27maintainers: drop Chris Wright from pvopsJuergen Gross
Mails to chrisw@sous-sol.org are not deliverable since several months. Drop him as PARAVIRT_OPS maintainer. Signed-off-by: Juergen Gross <jgross@suse.com> Acked-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Juergen Gross <jgross@suse.com>
2017-10-23Merge tag 'usb-4.14-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB/PHY fixes from Greg KH: "Here are a small number of USB and PHY driver fixes for 4.14-rc6 There is the usual musb and xhci fixes in here, as well as some needed phy patches. Also is a nasty regression fix for usbfs that has started to hit a lot of people using virtual machines. All of these have been in linux-next with no reported problems" * tag 'usb-4.14-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (26 commits) usb: hub: Allow reset retry for USB2 devices on connect bounce USB: core: fix out-of-bounds access bug in usb_get_bos_descriptor() MAINTAINERS: fix git tree url for musb module usb: quirks: add quirk for WORLDE MINI MIDI keyboard usb: musb: sunxi: Explicitly release USB PHY on exit usb: musb: Check for host-mode using is_host_active() on reset interrupt usb: musb: musb_cppi41: Configure the number of channels for DA8xx usb: musb: musb_cppi41: Fix cppi41_set_dma_mode() for DA8xx usb: musb: musb_cppi41: Fix the address of teardown and autoreq registers USB: musb: fix late external abort on suspend USB: musb: fix session-bit runtime-PM quirk usb: cdc_acm: Add quirk for Elatec TWN3 USB: devio: Revert "USB: devio: Don't corrupt user memory" usb: xhci: Handle error condition in xhci_stop_device() usb: xhci: Reset halted endpoint if trb is noop xhci: Cleanup current_cmd in xhci_cleanup_command_queue() xhci: Identify USB 3.1 capable hosts by their port protocol capability USB: serial: metro-usb: add MS7820 device id phy: rockchip-typec: Check for errors from tcphy_phy_init() phy: rockchip-typec: Don't set the aux voltage swing to 400 mV ...
2017-10-20Merge tag 'perf-urgent-for-mingo-4.14-20171019' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: - Fix crash in perf_hpp__reset_output_field() (Jiri Olsa) - Fix eBPF file/vendor events ambiguity in event specification (Jiri Olsa) - Fix closing evsel fd in 'perf stat' (Jin Yao) - Make perf test shell trace+probe_libc_inet_pton.sh pass in Debian/Ubuntu (Li Zhijian) - Fix 'perf buildid-list --with-hits' crash when processing PERF_RECORD_NAMESPACE (Namhyung Kim) - Fix documentation for an inexistent option 'perf record -l' (Taeung Song) - Add long time reviewers to MAINTAINERS (Arnaldo Carvalho de Melo) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-17MAINTAINERS: fix git tree url for musb moduleBin Liu
Commit 3b2435192fe91 ("MAINTAINERS: drop OMAP USB and MUSB maintainership") switched the maintainer for musb module, but didn't update the git tree location. Delete the git tree information, since the current maintainer doesn't have a public tree. Reported-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Bin Liu <b-liu@ti.com> Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-16perf tools: Add long time reviewers to MAINTAINERSArnaldo Carvalho de Melo
Jiri and Namhyung have long contributed a lot of code and time reviewing patches to tools/, so lets make that reflected in the MAINTAINERS file to encourage patch submitters to add them to the CC list, speeding up the process of tools/perf/ patch processing. Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-onicopw68bg6kn56lnybfpns@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-10-12Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Another latent bug related to PCID, an out-of-bounds access, and a submaintainer change being finally made official" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: MAINTAINERS: Add Paul Mackerras as maintainer for KVM/powerpc KVM: nVMX: fix guest CR4 loading when emulating L2 to L1 exit KVM: MMU: always terminate page walks at level 1 KVM: nVMX: update last_nonleaf_level when initializing nested EPT
2017-10-12MAINTAINERS: Add Paul Mackerras as maintainer for KVM/powerpcThomas Huth
Paul is handling almost all of the powerpc related KVM patches nowadays, so he should be mentioned in the MAINTAINERS file accordingly. Signed-off-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2017-10-10Merge tag 'nfsd-4.14-1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fix from Bruce Fields: "One fix for a 4.14 regression, and one minor fix to the MAINTAINERs file. (I was weirdly flattered by the idea that lots of random people suddenly seemed to think Jeff and I were VFS experts. Turns out it was just a typo)" * tag 'nfsd-4.14-1' of git://linux-nfs.org/~bfields/linux: nfsd4: define nfsd4_secinfo_no_name_release() MAINTAINERS: associate linux/fs.h with VFS instead of file locking
2017-10-06Merge tag 'arc-4.14-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC udpates from Vineet Gupta: - updates for various platforms - boot log updates for upcoming HS48 family of cores (dual issue) * tag 'arc-4.14-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: [plat-hsdk]: Add reset controller node to manage ethernet reset ARC: [plat-hsdk]: Temporary fix to set CPU frequency to 1GHz ARC: fix allnoconfig build warning ARCv2: boot log: identify HS48 cores (dual issue) ARC: boot log: decontaminate ARCv2 ISA_CONFIG register arc: remove redundant UTS_MACHINE define in arch/arc/Makefile ARC: [plat-eznps] Update platform maintainer as Noam left ARC: [plat-hsdk] use actual clk driver to manage cpu clk ARC: [*defconfig] Reenable soft lock-up detector ARC: [plat-axs10x] sdio: Temporary fix of sdio ciu frequency ARC: [plat-hsdk] sdio: Temporary fix of sdio ciu frequency ARC: [plat-axs103] Add temporary quirk to reset ethernet IP
2017-10-06Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A collection of fixes for this series. This contains: - NVMe pull request from Christoph, one uuid attribute fix, and one fix for the controller memory buffer address for remapped BARs. - use-after-free fix for bsg, from Benjamin Block. - bcache race/use-after-free fix for a list traversal, fixing a regression in this merge window. From Coly Li. - null_blk change configfs dependency change from a 'depends' to a 'select'. This is a change from this merge window as well. From me. - nbd signal fix from Josef, fixing a regression introduced with the status code changes. - nbd MAINTAINERS mailing list entry update. - blk-throttle stall fix from Joseph Qi. - blk-mq-debugfs fix from Omar, fixing an issue where we don't register the IO scheduler debugfs directory, if the driver is loaded with it. Only shows up if you switch through the sysfs interface" * 'for-linus' of git://git.kernel.dk/linux-block: bsg-lib: fix use-after-free under memory-pressure nvme-pci: Use PCI bus address for data/queues in CMB blk-mq-debugfs: fix device sched directory for default scheduler null_blk: change configfs dependency to select blk-throttle: fix possible io stall when upgrade to max MAINTAINERS: update list for NBD nbd: fix -ERESTARTSYS handling nvme: fix visibility of "uuid" ns attribute bcache: use llist_for_each_entry_safe() in __closure_wake_up()
2017-10-04Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Our first batch of fixes this release cycle, unfortunately a bit noisier than usual. Two major groups stand out: - Some pinctril dts/dtsi changes for stm32 due to a new driver being merged during the merge window, and this aligns the DT contents between the old format and the new. This could arguably be moved to the next merge window but it also seemed relatively harmless to include now. - Amlogic/meson had driver changes merged that required devicetree changes to avoid functional/performance regressions. I've already asked them to be more careful about this going forward, and making sure drivers are compatible with older DTs when they make these kind of changes. The platform is actively being upstreamed so there's a few things in flight, we've seen this happen before and sometimes it's hard to catch in time. Besides that there is the usual mix of minor fixes" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (33 commits) ARM: dts: stm32: use right pinctrl compatible for stm32f469 ARM: dts: stm32: Fix STMPE1600 binding on stm32429i-eval board ARM: defconfig: update Gemini defconfig ARM: defconfig: FRAMEBUFFER_CONSOLE can no longer be =m arm64: dts: rockchip: add the grf clk for dw-mipi-dsi on rk3399 reset: Restrict RESET_HSDK to ARC_SOC_HSDK or COMPILE_TEST ARM: dts: da850-evm: add serial and ethernet aliases ARM: dts: am43xx-epos-evm: Remove extra CPSW EMAC entry ARM: dts: am33xx: Add spi alias to match SOC schematics ARM: OMAP2+: hsmmc: fix logic to call either omap_hsmmc_init or omap_hsmmc_late_init but not both ARM: dts: dra7: Set a default parent to mcasp3_ahclkx_mux ARM: OMAP2+: dra7xx: Set OPT_CLKS_IN_RESET flag for gpio1 ARM: dts: nokia n900: drop unneeded/undocumented parts of the dts arm64: dts: rockchip: Correct MIPI DPHY PLL clock on rk3399 arm64: dt marvell: Fix AP806 system controller size MAINTAINERS: add Macchiatobin maintainers entry ARC: reset: remove the misleading v1 suffix all over ARC: reset: add missing DT binding documentation for HSDKv1 reset driver ARC: reset: Only build on archs that have IOMEM ARM: at91: Replace uses of virt_to_phys with __pa_symbol ...
2017-10-04Update James Hogan's email addressJames Hogan
Update my imgtec.com and personal email address to my kernel.org one in a few places as MIPS will soon no longer be part of Imagination Technologies, and add mappings in .mailcap so get_maintainer.pl reports the right address. Signed-off-by: James Hogan <jhogan@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-03ARC: [plat-eznps] Update platform maintainer as Noam leftVineet Gupta
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2017-10-03Merge tag 'mvebu-fixes-4.14-1' of git://git.infradead.org/linux-mvebu into fixesOlof Johansson
mvebu fixes for 4.14 (part 1) Update MAINTAINERS for the Macchiatobin board (Armada 8K based) Fix AP806 system controller size on Armada 7K/8K * tag 'mvebu-fixes-4.14-1' of git://git.infradead.org/linux-mvebu: arm64: dt marvell: Fix AP806 system controller size MAINTAINERS: add Macchiatobin maintainers entry Signed-off-by: Olof Johansson <olof@lixom.net>
2017-10-03Merge tag 'reset-fixes-for-4.14' of git://git.pengutronix.de/git/pza/linux ↵Olof Johansson
into fixes Reset controller fixes for v4.14 - Remove misleading HSDK v1 suffix, as there is no v2 planned - Add missing DT binding documentation for HSDK reset driver - Fix HSDK reset driver dependencies * tag 'reset-fixes-for-4.14' of git://git.pengutronix.de/git/pza/linux: reset: Restrict RESET_HSDK to ARC_SOC_HSDK or COMPILE_TEST ARC: reset: remove the misleading v1 suffix all over ARC: reset: add missing DT binding documentation for HSDKv1 reset driver ARC: reset: Only build on archs that have IOMEM Signed-off-by: Olof Johansson <olof@lixom.net>
2017-10-03MAINTAINERS: update list for NBDWouter Verhelst
nbd-general@sourceforge.net becomes nbd@other.debian.org, because sourceforge is just a spamtrap these days. Signed-off-by: Wouter Verhelst <w@uter.be> Reviewed-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-09-29Merge tag 'led_fixes-4.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds Pull LED fixes from Jacek Anaszewski: "Four fixes for the as3645a LED flash controller and one update to MAINTAINERS" * tag 'led_fixes-4.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds: MAINTAINERS: Add entry for MediaTek PMIC LED driver as3645a: Unregister indicator LED on device unbind as3645a: Use integer numbers for parsing LEDs dt: bindings: as3645a: Use LED number to refer to LEDs as3645a: Use ams,input-max-microamp as documented in DT bindings
2017-09-25MAINTAINERS: Add entry for MediaTek PMIC LED driverSean Wang
Add myself as a maintainer to support existing SoCs and push forward following MediaTek PMICs with LEDs to reuse the driver. Signed-off-by: Sean Wang <sean.wang@mediatek.com> Signed-off-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
2017-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix NAPI poll list corruption in enic driver, from Christian Lamparter. 2) Fix route use after free, from Eric Dumazet. 3) Fix regression in reuseaddr handling, from Josef Bacik. 4) Assert the size of control messages in compat handling since we copy it in from userspace twice. From Meng Xu. 5) SMC layer bug fixes (missing RCU locking, bad refcounting, etc.) from Ursula Braun. 6) Fix races in AF_PACKET fanout handling, from Willem de Bruijn. 7) Don't use ARRAY_SIZE on spinlock array which might have zero entries, from Geert Uytterhoeven. 8) Fix miscomputation of checksum in ipv6 udp code, from Subash Abhinov Kasiviswanathan. 9) Push the ipv6 header properly in ipv6 GRE tunnel driver, from Xin Long. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) inet: fix improper empty comparison net: use inet6_rcv_saddr to compare sockets net: set tb->fast_sk_family net: orphan frags on stand-alone ptype in dev_queue_xmit_nit MAINTAINERS: update git tree locations for ieee802154 subsystem net: prevent dst uses after free net: phy: Fix truncation of large IRQ numbers in phy_attached_print() net/smc: no close wait in case of process shut down net/smc: introduce a delay net/smc: terminate link group if out-of-sync is received net/smc: longer delay for client link group removal net/smc: adapt send request completion notification net/smc: adjust net_device refcount net/smc: take RCU read lock for routing cache lookup net/smc: add receive timeout check net/smc: add missing dev_put net: stmmac: Cocci spatch "of_table" lan78xx: Use default values loaded from EEPROM/OTP after reset lan78xx: Allow EEPROM write for less than MAX_EEPROM_SIZE lan78xx: Fix for eeprom read/write when device auto suspend ...
2017-09-22MAINTAINERS: update git tree locations for ieee802154 subsystemStefan Schmidt
Patches for ieee802154 will go through my new trees towards netdev from now on. The 6LoWPAN subsystem will stay as is (shared between ieee802154 and bluetooth) and go through the bluetooth tree as usual. Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-19MAINTAINERS: Remove Yuval Mintz from maintainers listAriel Elior
Remove Yuval from maintaining the bnx2x & qed* modules as he is no longer working for the company. Thanks Yuval for your huge contributions and tireless efforts over the many years and various companies. Ariel Signed-off-by: Ariel Elior <aelior@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-19MAINTAINERS: add Macchiatobin maintainers entryRussell King
Add a maintainers entry for the Macchiatobin board. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2017-09-18MAINTAINERS: associate linux/fs.h with VFS instead of file lockingEric Biggers
include/linux/fs.h and include/uapi/linux/fs.h deal with much more than just file locking. Move them to the "FILESYSTEMS (VFS and infrastructure)" section of the MAINTAINERS file so that the first suggestion from get_maintainer.pl isn't the file locking maintainers, which has caused some confusion. Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Eric Biggers <ebiggers@google.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2017-09-18ACPI / PMIC: Add code reviewers to MAINTAINERSRafael Wysocki
Andy and Mika review code changes under drivers/acpi/pmic/ on a regular basis and I rely on their help with that, so add them as code reviwewers for that part of the kernel. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Lee Jones <lee.jones@linaro.org> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-09-18ARC: reset: remove the misleading v1 suffix all overVineet Gupta
There is no plan yet to do a v2 board. And even if we were to do it only some IPs would actually change, so it be best to add suffixes at that point, not now ! Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
2017-09-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix hotplug deadlock in hv_netvsc, from Stephen Hemminger. 2) Fix double-free in rmnet driver, from Dan Carpenter. 3) INET connection socket layer can double put request sockets, fix from Eric Dumazet. 4) Don't match collect metadata-mode tunnels if the device is down, from Haishuang Yan. 5) Do not perform TSO6/GSO on ipv6 packets with extensions headers in be2net driver, from Suresh Reddy. 6) Fix scaling error in gen_estimator, from Eric Dumazet. 7) Fix 64-bit statistics deadlock in systemport driver, from Florian Fainelli. 8) Fix use-after-free in sctp_sock_dump, from Xin Long. 9) Reject invalid BPF_END instructions in verifier, from Edward Cree. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits) mlxsw: spectrum_router: Only handle IPv4 and IPv6 events Documentation: link in networking docs tcp: fix data delivery rate bpf/verifier: reject BPF_ALU64|BPF_END sctp: do not mark sk dumped when inet_sctp_diag_fill returns err sctp: fix an use-after-free issue in sctp_sock_dump netvsc: increase default receive buffer size tcp: update skb->skb_mstamp more carefully net: ipv4: fix l3slave check for index returned in IP_PKTINFO net: smsc911x: Quieten netif during suspend net: systemport: Fix 64-bit stats deadlock net: vrf: avoid gcc-4.6 warning qed: remove unnecessary call to memset tg3: clean up redundant initialization of tnapi tls: make tls_sw_free_resources static sctp: potential read out of bounds in sctp_ulpevent_type_enabled() MAINTAINERS: review Renesas DT bindings as well net_sched: gen_estimator: fix scaling error in bytes/packets samples nfp: wait for the NSP resource to appear on boot nfp: wait for board state before talking to the NSP ...
2017-09-15Merge branch '4.14-features' of ↵Linus Torvalds
git://git.linux-mips.org/pub/scm/ralf/upstream-linus Pull MIPS updates from Ralf Baechle: "This is the main pull request for 4.14 for MIPS; below a summary of the non-merge commits: CM: - Rename mips_cm_base to mips_gcr_base - Specify register size when generating accessors - Use BIT/GENMASK for register fields, order & drop shifts - Add cluster & block args to mips_cm_lock_other() CPC: - Use common CPS accessor generation macros - Use BIT/GENMASK for register fields, order & drop shifts - Introduce register modify (set/clear/change) accessors - Use change_*, set_* & clear_* where appropriate - Add CM/CPC 3.5 register definitions - Use GlobalNumber macros rather than magic numbers - Have asm/mips-cps.h include CM & CPC headers - Cluster support for topology functions - Detect CPUs in secondary clusters CPS: - Read GIC_VL_IDENT directly, not via irqchip driver DMA: - Consolidate coherent and non-coherent dma_alloc code - Don't use dma_cache_sync to implement fd_cacheflush FPU emulation / FP assist code: - Another series of 14 commits fixing corner cases such as NaN propgagation and other special input values. - Zero bits 32-63 of the result for a CLASS.D instruction. - Enhanced statics via debugfs - Do not use bools for arithmetic. GCC 7.1 moans about this. - Correct user fault_addr type Generic MIPS: - Enhancement of stack backtraces - Cleanup from non-existing options - Handle non word sized instructions when examining frame - Fix detection and decoding of ADDIUSP instruction - Fix decoding of SWSP16 instruction - Refactor handling of stack pointer in get_frame_info - Remove unreachable code from force_fcr31_sig() - Convert to using %pOF instead of full_name - Remove the R6000 support. - Move FP code from *_switch.S to *_fpu.S - Remove unused ST_OFF from r2300_switch.S - Allow platform to specify multiple its.S files - Add #includes to various files to ensure code builds reliable and without warning.. - Remove __invalidate_kernel_vmap_range - Remove plat_timer_setup - Declare various variables & functions static - Abstract CPU core & VP(E) ID access through accessor functions - Store core & VP IDs in GlobalNumber-style variable - Unify checks for sibling CPUs - Add CPU cluster number accessors - Prevent direct use of generic_defconfig - Make CONFIG_MIPS_MT_SMP default y - Add __ioread64_copy - Remove unnecessary inclusions of linux/irqchip/mips-gic.h GIC: - Introduce asm/mips-gic.h with accessor functions - Use new GIC accessor functions in mips-gic-timer - Remove counter access functions from irq-mips-gic.c - Remove gic_read_local_vp_id() from irq-mips-gic.c - Simplify shared interrupt pending/mask reads in irq-mips-gic.c - Simplify gic_local_irq_domain_map() in irq-mips-gic.c - Drop gic_(re)set_mask() functions in irq-mips-gic.c - Remove gic_set_polarity(), gic_set_trigger(), gic_set_dual_edge(), gic_map_to_pin() and gic_map_to_vpe() from irq-mips-gic.c. - Convert remaining shared reg access, local int mask access and remaining local reg access to new accessors - Move GIC_LOCAL_INT_* to asm/mips-gic.h - Remove GIC_CPU_INT* macros from irq-mips-gic.c - Move various definitions to the driver - Remove gic_get_usm_range() - Remove __gic_irq_dispatch() forward declaration - Remove gic_init() - Use mips_gic_present() in place of gic_present and remove gic_present - Move gic_get_c0_*_int() to asm/mips-gic.h - Remove linux/irqchip/mips-gic.h - Inline __gic_init() - Inline gic_basic_init() - Make pcpu_masks a per-cpu variable - Use pcpu_masks to avoid reading GIC_SH_MASK* - Clean up mti, reserved-cpu-vectors handling - Use cpumask_first_and() in gic_set_affinity() - Let the core set struct irq_common_data affinity microMIPS: - Fix microMIPS stack unwinding on big endian systems MIPS-GIC: - SYNC after enabling GIC region NUMA: - Remove the unused parent_node() macro R6: - Constify r2_decoder_tables - Add accessor & bit definitions for GlobalNumber SMP: - Constify smp ops - Allow boot_secondary SMP op to return errors VDSO: - Drop gic_get_usm_range() usage - Avoid use of linux/irqchip/mips-gic.h Platform changes: Alchemy: - Add devboard machine type to cpuinfo - update cpu feature overrides - Threaded carddetect irqs for devboards AR7: - allow NULL clock for clk_get_rate BCM63xx: - Fix ENETDMA_6345_MAXBURST_REG offset - Allow NULL clock for clk_get_rate CI20: - Enable GPIO and RTC drivers in defconfig - Add ethernet and fixed-regulator nodes to DTS Generic platform: - Move Boston and NI 169445 FIT image source to their own files - Include asm/bootinfo.h for plat_fdt_relocated() - Include asm/time.h for get_c0_*_int() - Include asm/bootinfo.h for plat_fdt_relocated() - Include asm/time.h for get_c0_*_int() - Allow filtering enabled boards by requirements - Don't explicitly disable CONFIG_USB_SUPPORT - Bump default NR_CPUS to 16 JZ4700: - Probe the jz4740-rtc driver from devicetree Lantiq: - Drop check of boot select from the spi-falcon driver. - Drop check of boot select from the lantiq-flash MTD driver. - Access boot cause register in the watchdog driver through regmap - Add device tree binding documentation for the watchdog driver - Add docs for the RCU DT bindings. - Convert the fpi bus driver to a platform_driver - Remove ltq_reset_cause() and ltq_boot_select( - Switch to a proper reset driver - Switch to a new drivers/soc GPHY driver - Add an USB PHY driver for the Lantiq SoCs using the RCU module - Use of_platform_default_populate instead of __dt_register_buses - Enable MFD_SYSCON to be able to use it for the RCU MFD - Replace ltq_boot_select() with dummy implementation. Loongson 2F: - Allow NULL clock for clk_get_rate Malta: - Use new GIC accessor functions NI 169445: - Add support for NI 169445 board. - Only include in 32r2el kernels Octeon: - Add support for watchdog of 78XX SOCs. - Add support for watchdog of CN68XX SOCs. - Expose support for mips32r1, mips32r2 and mips64r1 - Enable more drivers in config file - Add support for accessing the boot vector. - Remove old boot vector code from watchdog driver - Define watchdog registers for 70xx, 73xx, 78xx, F75xx. - Make CSR functions node aware. - Allow access to CIU3 IRQ domains. - Misc cleanups in the watchdog driver Omega2+: - New board, add support and defconfig Pistachio: - Enable Root FS on NFS in defconfig Ralink: - Add Mediatek MT7628A SoC - Allow NULL clock for clk_get_rate - Explicitly request exclusive reset control in the pci-mt7620 PCI driver. SEAD3: - Only include in 32 bit kernels by default VoCore: - Add VoCore as a vendor t0 dt-bindings - Add defconfig file" * '4.14-features' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (167 commits) MIPS: Refactor handling of stack pointer in get_frame_info MIPS: Stacktrace: Fix microMIPS stack unwinding on big endian systems MIPS: microMIPS: Fix decoding of swsp16 instruction MIPS: microMIPS: Fix decoding of addiusp instruction MIPS: microMIPS: Fix detection of addiusp instruction MIPS: Handle non word sized instructions when examining frame MIPS: ralink: allow NULL clock for clk_get_rate MIPS: Loongson 2F: allow NULL clock for clk_get_rate MIPS: BCM63XX: allow NULL clock for clk_get_rate MIPS: AR7: allow NULL clock for clk_get_rate MIPS: BCM63XX: fix ENETDMA_6345_MAXBURST_REG offset mips: Save all registers when saving the frame MIPS: Add DWARF unwinding to assembly MIPS: Make SAVE_SOME more standard MIPS: Fix issues in backtraces MIPS: jz4780: DTS: Probe the jz4740-rtc driver from devicetree MIPS: Ci20: Enable RTC driver watchdog: octeon-wdt: Add support for 78XX SOCs. watchdog: octeon-wdt: Add support for cn68XX SOCs. watchdog: octeon-wdt: File cleaning. ...
2017-09-13i2c: altera: Add Altera I2C Controller driverThor Thayer
Add driver support for the Altera I2C Controller. The I2C controller is soft IP for use in FPGAs. Signed-off-by: Thor Thayer <thor.thayer@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2017-09-13MAINTAINERS: review Renesas DT bindings as wellSergei Shtylyov
When adding myself as a reviewer for the Renesas Ethernet drivers I somehow forgot about the bindings -- I want to review them as well. Fixes: 8e6569af3a1b ("MAINTAINERS: add myself as Renesas Ethernet drivers reviewer") Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
