path: root/MAINTAINERS
2014-02-14Merge tag 'pm+acpi-3.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These include a fix for a recent intel_pstate regression, a fix for a regression in the ACPI-based PCI hotplug (ACPIPHP) code introduced during the 3.12 cycle, fixes for two bugs in the ACPI core introduced recently and a MAINTAINERS update related to cpufreq. Specifics: - Fix for a recent regression in the intel_pstate driver that introduced a race condition causing systems to crash during initialization in some situations. This removes the affected code altogether. From Dirk Brandewie. - ACPIPHP fix for a regression introduced during the 3.12 cycle causing devices to be dropped as a result of bus check notifications after system resume on some systems due to the way ACPIPHP interprets _STA return values (arguably incorrectly). From Mika Westerberg. - ACPI dock driver fix for a problem causing docking to fail due to a check that always fails after recent ACPI core changes (found by code inspection). - ACPI container driver fix to prevent memory from being leaked in an error code path after device_register() failures. - Update of the arm_big_little cpufreq driver maintainer's e-mail address" * tag 'pm+acpi-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: MAINTAINERS / cpufreq: update Sudeep's email address intel_pstate: Remove energy reporting from pstate_sample tracepoint ACPI / container: Fix error code path in container_device_attach() ACPI / hotplug / PCI: Relax the checking of _STA return values ACPI / dock: Use acpi_device_enumerated() to check if dock is present
2014-02-13MAINTAINERS / cpufreq: update Sudeep's email addressSudeep Holla
Though my old email address continues to work as alias, updating to the new address as it's shorter, easier and more appropriate. Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-12Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Nothing too crazy. Radeon irq fixes, i915 regression fixes, exynos fixes, tda998x chip fixes, and a bunch of msm fixes" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (31 commits) drm/i915: Pair va_copy with va_end in i915_error_vprintf drm/i915: Fix intel_pipe_to_cpu_transcoder for UMS drm/i915: Disable dp aux irq on g4x drm/msm: bigger synchronization hammer drm/exynos: Convert to use the standard hdmi.h header drm/exynos: Fix trivial typo drm/exynos: Remove unnecessary semicolon drm/exynos: Fix multiplatform breakage for ipp/gsc drm/exynos: Fix freeing issues in exynos_drm_drv.c drm/radeon: add missing include in btc_dpm.c drm/radeon/dpm: fix uninitialized read from stack in kv_dpm_late_enable drm/radeon: remove useless return drm/radeon/dpm: use stored max_vddc rather than looking it up drm/radeon/dpm: use the driver state for dpm debugfs drm/radeon: fix UVD IRQ support on 7xx drm/radeon: fix UVD IRQ support on SI drm/msm: fix deadlock in bo create fail path drm/msm/mdp4: cursor fixes drm/msm/mdp4: pageflip fixes drm/msm/mdp5: fix ref leaks in error paths ...
2014-02-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix flexcan build on big endian, from Arnd Bergmann 2) Correctly attach cpsw to GPIO bitbang MDIO drive, from Stefan Roese 3) udp_add_offload has to use GFP_ATOMIC since it can be invoked from non-sleepable contexts. From Or Gerlitz 4) vxlan_gro_receive() does not iterate over all possible flows properly, fix also from Or Gerlitz 5) CAN core doesn't use a proper SKB destructor when it hooks up sockets to SKBs. Fix from Oliver Hartkopp 6) ip_tunnel_xmit() can use an uninitialized route pointer, fix from Eric Dumazet 7) Fix address family assignment in IPVS, from Michal Kubecek 8) Fix ath9k build on ARM, from Sujith Manoharan 9) Make sure fail_over_mac only applies for the correct bonding modes, from Ding Tianhong 10) The udp offload code doesn't use RCU correctly, from Shlomo Pongratz 11) Handle gigabit features properly in generic PHY code, from Florian Fainelli 12) Don't blindly invoke link operations in rtnl_link_get_slave_info_data_size, they are optional. Fix from Fernando Luis Vazquez Cao 13) Add USB IDs for Netgear Aircard 340U, from Bjørn Mork 14) Handle netlink packet padding properly in openvswitch, from Thomas Graf 15) Fix oops when deleting chains in nf_tables, from Patrick McHardy 16) Fix RX stalls in xen-netback driver, from Zoltan Kiss 17) Fix deadlock in mac80211 stack, from Emmanuel Grumbach 18) inet_nlmsg_size() forgets to consider ifa_cacheinfo, fix from Geert Uytterhoeven 19) tg3_change_mtu() can deadlock, fix from Nithin Sujir 20) Fix regression in setting SCTP local source addresses on accepted sockets, caused by some generic ipv6 socket changes. Fix from Matija Glavinic Pecotic 21) IPPROTO_* must be pure defines, otherwise module aliases don't get constructed properly. Fix from Jan Moskyto 22) IPV6 netconsole setup doesn't work properly unless an explicit source address is specified, fix from Sabrina Dubroca 23) Use __GFP_NORETRY for high order skb page allocations in sock_alloc_send_pskb and skb_page_frag_refill. From Eric Dumazet 24) Fix a regression added in netconsole over bridging, from Cong Wang 25) TCP uses an artificial offset of 1ms for SRTT, but this doesn't jive well with TCP pacing which needs the SRTT to be accurate. Fix from Eric Dumazet 26) Several cases of missing header file includes from Rashika Kheria 27) Add ZTE MF667 device ID to qmi_wwan driver, from Raymond Wanyoike 28) TCP Small Queues doesn't handle nonagle properly in some corner cases, fix from Eric Dumazet 29) Remove extraneous read_unlock in bond_enslave, whoops. From Ding Tianhong 30) Fix 9p trans_virtio handling of vmalloc buffers, from Richard Yao * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (136 commits) 6lowpan: fix lockdep splats alx: add missing stats_lock spinlock init 9p/trans_virtio.c: Fix broken zero-copy on vmalloc() buffers bonding: remove unwanted bond lock for enslave processing USB2NET : SR9800 : One chip USB2.0 USB2NET SR9800 Device Driver Support tcp: tsq: fix nonagle handling bridge: Prevent possible race condition in br_fdb_change_mac_address bridge: Properly check if local fdb entry can be deleted when deleting vlan bridge: Properly check if local fdb entry can be deleted in br_fdb_delete_by_port bridge: Properly check if local fdb entry can be deleted in br_fdb_change_mac_address bridge: Fix the way to check if a local fdb entry can be deleted bridge: Change local fdb entries whenever mac address of bridge device changes bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_address bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddr bridge: Fix the way to find old local fdb entries in br_fdb_changeaddr tcp: correct code comment stating 3 min timeout for FIN_WAIT2, we only do 1 min net: vxge: Remove unused device pointer net: qmi_wwan: add ZTE MF667 3c59x: Remove unused pointer in vortex_eisa_cleanup() net: fix 'ip rule' iif/oif device rename ...
2014-02-11Merge tag 'drm-intel-fixes-2014-02-06' of ↵Dave Airlie
ssh://git.freedesktop.org/git/drm-intel into drm-next Just minor stuff really, on vlv dp fix and two patches to tune down some opregion sanity check. Plus MAINTAINERS update for the new git repo, which is the only reason I've really bothered with this pull request. * tag 'drm-intel-fixes-2014-02-06' of ssh://git.freedesktop.org/git/drm-intel: drm/i915: demote opregion excessive timeout WARN_ONCE to DRM_INFO_ONCE drm: add DRM_INFO_ONCE() to print a one-time DRM_INFO() message MAINTAINERS: Update drm/i915 git repo drm/i915: vlv: fix DP PHY lockup due to invalid PP sequencer setup
2014-02-04MAINTAINERS: Update drm/i915 git repoDaniel Vetter
Moved to a common location so that Jani also can push to it, to avoid moving it every time I go on vacation. Please update autobuilders and everything else pointing at the drm-intel.git repo, the old one won't be updated any more. Cc: Dave Airlie <airlied@gmail.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-02-02Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's a set of patches for (hopefully) -rc1. Some of them are fixes, but a good number of them also do things such as enable new drivers in the defconfigs for platforms that have such devices, increases coverage of the multiplatform defconfig and some DTS changes that plumbs up some of the devices that now have bindings and driver support. The commit dates are recent; we've mostly collected these fixes in the last few days but I also had to rebuild the branch yesterday to sort out some internal conflicts which reset the timestamps. The changes should have been tested by each platform maintainer already (and few of them have cross-platform impact) so I'm personally not too concerned by it at this time" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: multi_v7_defconfig: remove redundant entries and re-enable TI_EDMA ARM: multi_v7_defconfig: add mvebu drivers clocksource: kona: Add basic use of external clock drivers: bus: fix CCI driver kcalloc call parameters swap ARM: dts: bcm28155-ap: Fix Card Detection GPIO ARM: multi_v7_defconfig: Select CONFIG_AT803X_PHY ARM: keystone: config: fix build warning when CONFIG_DMADEVICES is not set MAINTAINERS: ARM: SiRF: use regex patterns to involve all SiRF drivers ARM: dts: zynq: Add SDHCI nodes ARM: hisi: don't select SMP ARM: tegra: rebuild tegra_defconfig to add DEBUG_FS ARM: multi_v7: copy most options from tegra_defconfig ARM: iop32x: fix power off handling for the EM7210 board ARM: integrator: restore static map on the CP ARM: msm_defconfig: Enable MSM clock drivers ARM: dts: msm: Add clock controller nodes and hook into uart ARM: OMAP4+: move errata initialization to omap4_pm_init_early ARM: OMAP4460: cpuidle: Extend PM_OMAP4_ROM_SMP_BOOT_ERRATUM_GICD on cpuidle ARM: mvebu: fix compilation warning on Armada 370 (i.e. non-SMP) ARM: shmobile: r8a7790.dtsi: ficx i2c[0-3] clock reference ...
2014-01-31MAINTAINERS: ARM: SiRF: use regex patterns to involve all SiRF driversBarry Song
instead of listing drivers one by one, use regex patterns to involve all SiRF drivers directly. this also adds sirf UART and watchdog drivers automatically from: drivers/tty/serial/sirfsoc_uart.* drivers/watchdog/sirfsoc_wdt.c Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-01-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4) - a new dvb frontend for ds2103 chipset (m88ds2103) - a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf) - new drivers for R-Car VSP1 - a new radio driver: radio-raremono - a new tuner driver for ts2022 chipset (m88ts2022) - the analog part of em28xx is now a separate module that only load/runs if the device is not a pure digital TV device - added a staging driver for bcm2048 radio devices - the omap 2 video driver (omap24xx) was moved to staging. This driver is for an old hardware and uses a deprecated Kernel internal API. If nobody cares enough to fix it, it would be removed on a couple Kernel releases - the sn9c102 driver was moved to staging. This driver was replaced by gspca, and disabled on some distros, as almost all devices are known to work properly with gspca. It should be removed from kernel on a couple Kernel releases - lots of driver fixes, improvements and cleanups * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits) [media] media: v4l2-dev: fix video device index assignment [media] rc-core: reuse device numbers [media] em28xx-cards: properly initialize the device bitmap [media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c [media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c [media] Staging: media: Fix quoted string split across line in as102_fe.c [media] media: st-rc: Add reset support [media] m2m-deinterlace: fix allocated struct type [media] radio-usb-si4713: fix sparse non static symbol warnings [media] em28xx-audio: remove needless check before usb_free_coherent() [media] au0828: Fix sparse non static symbol warning Revert "[media] go7007-usb: only use go->dev after allocated" [media] em28xx-audio: provide an error code when URB submit fails [media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting [media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0 [media] em28xx: make 'em28xx_ctrl_ops' static em28xx-alsa: Fix error patch for init/fini [media] em28xx-audio: flush work at .fini [media] drxk: remove the option to load firmware asynchronously [media] em28xx: adjust period size at runtime ...
2014-01-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core debug changes from Ingo Molnar: "This contains mostly kernel debugging related updates: - make hung_task detection more configurable to distros - add final bits for x86 UV NMI debugging, with related KGDB changes - update the mailing-list of MAINTAINERS entries I'm involved with" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hung_task: Display every hung task warning sysctl: Add neg_one as a standard constraint x86/uv/nmi, kgdb/kdb: Fix UV NMI handler when KDB not configured x86/uv/nmi: Fix Sparse warnings kgdb/kdb: Fix no KDB config problem MAINTAINERS: Restore "L: linux-kernel@vger.kernel.org" entries
2014-01-30Merge tag 'upstream-3.14-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs updates from Artem Bityutskiy: - Improve the NOR erasure quirk - now it tries to do as little writes as possible, because the eraseblock may be in an "unstable" state and write operation sometimes causes NOR chip lock-ups. - Both UBI and UBIFS changes are now maintainer in one single tree, because the amount of changes dropped significantly. * tag 'upstream-3.14-rc1' of git://git.infradead.org/linux-ubifs: UBI: avoid program operation on NOR flash after erasure interrupted MAINTAINERS: keep UBI and UBIFS stuff in the same tree UBI: fix error return code
2014-01-30zsmalloc: add maintainersMinchan Kim
tAdd adds maintainer information for zsmalloc into the MAINTAINERS file. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zram: add zram maintainersMinchan Kim
Add maintainer information for zram into the MAINTAINERS file. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30rds: The maintainer needs to be updated.Venkat Venkatsubra
Signed-off-by: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-29Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon updates from Jean Delvare: "This include it87 driver improvements, and a tree-wide change of my e-mail address" * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: Update Jean Delvare's e-mail address hwmon: (it87) Print proper names for the IT8771E and IT8772E hwmon: (it87) Add support for the ITE IT8603E
2014-01-29MAINTAINERS: ADI Linux development mailing lists: change to the new serverSonic Zhang
Update Blackfin arch maintainer's email as well. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Cc: Michael Hennerich <michael.hennerich@analog.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Steven Miao <realmz6@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2014-01-28Merge tag 'for-linus-20140127' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: - Add me (Brian Norris) as an additional MTD maintainer (it'd be nice to get David's "ack" for this; I'm sure he approves, but he's been pretty silent lately) - Add Ezequiel Garcie as maintainer for the pxa3xx NAND driver - Last (?) round of pxa3xx improvements for supporting Armada 370/XP - Typical churn in driver boilerplate (OOM messages, printk()'s, devm_*, etc.) - Quad read mode support for SPI NOR driver (m25p80) - Update Davinci NAND driver to prepare for use on new platforms - Begin to kill off NAND_MAX_{PAGE,OOB}SIZE macros; more work is pending - Miscellaneous NAND device support (new IDs) - Add READ RETRY support for Micron MLC NAND - Support new GPMI NAND ECC layout device-tree binding - Avoid mapping stack/vmalloc() memory for GPMI NAND DMA * tag 'for-linus-20140127' of git://git.infradead.org/linux-mtd: (151 commits) mtd: gpmi: add sanity check when mapping DMA for read_buf/write_buf mtd: gpmi: allocate a proper buffer for non ECC read/write mtd: m25p80: Set rx_nbits for Quad SPI transfers mtd: m25p80: Enable Quad SPI read transfers for s25fl512s mtd: s3c2410: Merge plat/regs-nand.h into s3c2410.c mtd: mtdram: add missing 'const' mtd: m25p80: assign default read command mtd: nuc900_nand: remove redundant return value check of platform_get_resource() mtd: plat_nand: remove redundant return value check of platform_get_resource() mtd: nand: add Intel manufacturer ID mtd: nand: add SanDisk manufacturer ID mtd: nand: add support for Samsung K9LCG08U0B mtd: nand: pxa3xx: Add support for 2048 bytes page size devices mtd: m25p80: Use OPCODE_QUAD_READ_4B for 4-byte addressing mtd: nand: don't use {read,write}_buf for 8-bit transfers mtd: nand: use __packed shorthand mtd: nand: support Micron READ RETRY mtd: nand: add generic READ RETRY support mtd: nand: add ONFI vendor block for Micron mtd: nand: localize ECC failures per page ...
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull ceph updates from Sage Weil: "This is a big batch. From Ilya we have: - rbd support for more than ~250 mapped devices (now uses same scheme that SCSI does for device major/minor numbering) - crush updates for new mapping behaviors (will be needed for coming erasure coding support, among other things) - preliminary support for tiered storage pools There is also a big series fixing a pile cephfs bugs with clustered MDSs from Yan Zheng, ACL support for cephfs from Guangliang Zhao, ceph fscache improvements from Li Wang, improved behavior when we get ENOSPC from Josh Durgin, some readv/writev improvements from Majianpeng, and the usual mix of small cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (76 commits) ceph: cast PAGE_SIZE to size_t in ceph_sync_write() ceph: fix dout() compile warnings in ceph_filemap_fault() libceph: support CEPH_FEATURE_OSD_CACHEPOOL feature libceph: follow redirect replies from osds libceph: rename ceph_osd_request::r_{oloc,oid} to r_base_{oloc,oid} libceph: follow {read,write}_tier fields on osd request submission libceph: add ceph_pg_pool_by_id() libceph: CEPH_OSD_FLAG_* enum update libceph: replace ceph_calc_ceph_pg() with ceph_oloc_oid_to_pg() libceph: introduce and start using oid abstraction libceph: rename MAX_OBJ_NAME_SIZE to CEPH_MAX_OID_NAME_LEN libceph: move ceph_file_layout helpers to ceph_fs.h libceph: start using oloc abstraction libceph: dout() is missing a newline libceph: add ceph_kv{malloc,free}() and switch to them libceph: support CEPH_FEATURE_EXPORT_PEER ceph: add imported caps when handling cap export message ceph: add open export target session helper ceph: remove exported caps when handling cap import message ceph: handle session flush message ...
2014-01-26Merge tag 'mmc-updates-for-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.14: Core: - Avoid get_cd() on cards marked nonremovable Drivers: - arasan: New driver for controllers found in e.g. Xilinx Zynq SoC - dwmmc: Support Hisilicon K3 SoC controllers - esdhc-imx: Support for HS200 mode, DDR modes on MX6, runtime PM - sdhci-pci: Support O2Micro/BayHubTech controllers used in laptops like Lenovo ThinkPad W540, Dell Latitude E5440, Dell Latitude E6540 - tegra: Support Tegra124 SoCs" * tag 'mmc-updates-for-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (55 commits) mmc: sdhci-pci: Fix possibility of chip->fixes being null mmc: sdhci-pci: Fix BYT sd card getting stuck in runtime suspend mmc: sdhci: Allow for long command timeouts mmc: sdio: add a quirk for broken SDIO_CCCR_INTx polling mmc: sdhci: fix lockdep error in tuning routine mmc: dw_mmc: k3: remove clk_table mmc: dw_mmc: fix dw_mci_get_cd mmc: dw_mmc: fix sparse non static symbol warning mmc: sdhci-esdhc-imx: fix warning during module remove function mmc: sdhci-esdhc-imx: fix access hardirq-unsafe lock in atomic context mmc: core: sd: implement proper support for sd3.0 au sizes mmc: atmel-mci: add vmmc-supply support mmc: sdhci-pci: add broken HS200 quirk for Intel Merrifield mmc: sdhci: add quirk for broken HS200 support mmc: arasan: Add driver for Arasan SDHCI mmc: dw_mmc: add dw_mmc-k3 for k3 platform mmc: dw_mmc: use slot-gpio to handle cd pin mmc: sdhci-pci: add support of O2Micro/BayHubTech SD hosts mmc: sdhci-pci: break out definitions to header file mmc: tmio: fixup compile error ... Conflicts: MAINTAINERS
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-24Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband updates from Roland Dreier: "Main batch of InfiniBand/RDMA changes for 3.14: - Flow steering for InfiniBand UD traffic - IP-based addressing for IBoE aka RoCE - Pass SRP submaintainership from Dave to Bart - SRP transport fixes from Bart - Add the new Cisco usNIC low-level device driver - Various other fixes" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (75 commits) IB/mlx5: Verify reserved fields are cleared IB/mlx5: Remove old field for create mkey mailbox IB/mlx5: Abort driver cleanup if teardown hca fails IB/mlx5: Allow creation of QPs with zero-length work queues mlx5_core: Fix PowerPC support mlx5_core: Improve debugfs readability IB/mlx5: Add support for resize CQ IB/mlx5: Implement modify CQ IB/mlx5: Make sure doorbell record is visible before doorbell mlx5_core: Use mlx5 core style warning IB/mlx5: Clear out struct before create QP command mlx5_core: Fix out arg size in access_register command RDMA/nes: Slight optimization of Ethernet address compare IB/qib: Fix QP check when looping back to/from QP1 RDMA/cxgb4: Fix gcc warning on 32-bit arch IB/usnic: Remove unused includes of <linux/version.h> RDMA/amso1100: Add check if cache memory was allocated before freeing it IPoIB: Report operstate consistently when brought up without a link IB/core: Fix unused variable warning RDMA/cma: Handle global/non-linklocal IPv6 addresses in cma_check_linklocal() ...
2014-01-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "This time, the biggest change is the work of representing hardware thermal properties in device tree infrastructure. This work includes the introduction of a device tree bindings for describing the hardware thermal behavior and limits, and also a parser to read and interpret the data, and build thermal zones and thermal binding parameters. It also contains three examples on how to use the new representation on sensor devices, using three different drivers to accomplish it. One driver is in thermal subsystem, the TI SoC thermal, and the other two drivers are in hwmon subsystem. Actually, this would be the first step of the complete work because we still need to check other potential drivers to be converted and then validate the proposed API. But the reason why I include it in this pull request is that, first, this change does not hurt any others without using this approach, second, the principle and concept of this change would not break after converting the remaining drivers. BTW, as you can see, there are several points in this change that do not belong to thermal subsystem. Because it has been suggested by Guenter R that in such cases, it is recommended to send the complete series via one single subsystem. Specifics: - representing hardware thermal properties in device tree infrastructure - fix a regression that the imx thermal driver breaks system suspend. - introduce ACPI INT3403 thermal driver to retrieve temperature data from the INT3403 ACPI device object present on some systems. - introduce debug statement for thermal core and step_wise governor. - assorted fixes and cleanups for thermal core, cpu cooling, exynos thrmal, intel powerclamp and imx thermal driver" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (34 commits) thermal: remove const flag from .ops of imx thermal Thermal: update thermal zone device after setting emul_temp intel_powerclamp: Fix cstate counter detection. thermal: imx: add necessary clk operation Thermal cpu cooling: return error if no valid cpu frequency entry thermal: fix cpu_cooling max_level behavior thermal: rcar-thermal: Enable driver compilation with COMPILE_TEST thermal: debug: add debug statement for core and step_wise thermal: imx_thermal: add module device table drivers: thermal: Mark function as static in x86_pkg_temp_thermal.c thermal:samsung: fix compilation warning thermal: imx: correct suspend/resume flow thermal: exynos: fix error return code Thermal: ACPI INT3403 thermal driver MAINTAINERS: add thermal bindings entry in thermal domain arm: dts: make OMAP4460 bandgap node to belong to OCP arm: dts: make OMAP443x bandgap node to belong to OCP arm: dts: add cooling properties on omap5 cpu node arm: dts: add omap5 thermal data arm: dts: add omap5 CORE thermal data ...
2014-01-24Merge tag 'pm+acpi-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "As far as the number of commits goes, the top spot belongs to ACPI this time with cpufreq in the second position and a handful of PM core, PNP and cpuidle updates. They are fixes and cleanups mostly, as usual, with a couple of new features in the mix. The most visible change is probably that we will create struct acpi_device objects (visible in sysfs) for all devices represented in the ACPI tables regardless of their status and there will be a new sysfs attribute under those objects allowing user space to check that status via _STA. Consequently, ACPI device eject or generally hot-removal will not delete those objects, unless the table containing the corresponding namespace nodes is unloaded, which is extremely rare. Also ACPI container hotplug will be handled quite a bit differently and cpufreq will support CPU boost ("turbo") generically and not only in the acpi-cpufreq driver. Specifics: - ACPI core changes to make it create a struct acpi_device object for every device represented in the ACPI tables during all namespace scans regardless of the current status of that device. In accordance with this, ACPI hotplug operations will not delete those objects, unless the underlying ACPI tables go away. - On top of the above, new sysfs attribute for ACPI device objects allowing user space to check device status by triggering the execution of _STA for its ACPI object. From Srinivas Pandruvada. - ACPI core hotplug changes reducing code duplication, integrating the PCI root hotplug with the core and reworking container hotplug. - ACPI core simplifications making it use ACPI_COMPANION() in the code "glueing" ACPI device objects to "physical" devices. - ACPICA update to upstream version 20131218. This adds support for the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves debug facilities. From Bob Moore, Lv Zheng and Betty Dall. - Init code change to carry out the early ACPI initialization earlier. That should allow us to use ACPI during the timekeeping initialization and possibly to simplify the EFI initialization too. From Chun-Yi Lee. - Clenups of the inclusions of ACPI headers in many places all over from Lv Zheng and Rashika Kheria (work in progress). - New helper for ACPI _DSM execution and rework of the code in drivers that uses _DSM to execute it via the new helper. From Jiang Liu. - New Win8 OSI blacklist entries from Takashi Iwai. - Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava, Rashika Kheria, Tang Chen, Zhang Rui. - intel_pstate driver updates, including proper Baytrail support, from Dirk Brandewie and intel_pstate documentation from Ramkumar Ramachandra. - Generic CPU boost ("turbo") support for cpufreq from Lukasz Majewski. - powernow-k6 cpufreq driver fixes from Mikulas Patocka. - cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark Brown. - Assorted cpufreq drivers fixes and cleanups from Anson Huang, John Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh Kumar. - cpuidle cleanups from Bartlomiej Zolnierkiewicz. - Support for hibernation APM events from Bin Shi. - Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC disabled during thaw transitions from Bjørn Mork. - PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf Hansson. - PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente Kurusa, Rashika Kheria. - New tool for profiling system suspend from Todd E Brandt and a cpupower tool cleanup from One Thousand Gnomes" * tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits) thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412) cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ Documentation: cpufreq / boost: Update BOOST documentation cpufreq: exynos: Extend Exynos cpufreq driver to support boost cpufreq / boost: Kconfig: Support for software-managed BOOST acpi-cpufreq: Adjust the code to use the common boost attribute cpufreq: Add boost frequency support in core intel_pstate: Add trace point to report internal state. cpufreq: introduce cpufreq_generic_get() routine ARM: SA1100: Create dummy clk_get_rate() to avoid build failures cpufreq: stats: create sysfs entries when cpufreq_stats is a module cpufreq: stats: free table and remove sysfs entry in a single routine cpufreq: stats: remove hotplug notifiers cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly cpufreq: speedstep: remove unused speedstep_get_state platform: introduce OF style 'modalias' support for platform bus PM / tools: new tool for suspend/resume performance optimization ACPI: fix module autoloading for ACPI enumerated devices ACPI: add module autoloading support for ACPI enumerated devices ACPI: fix create_modalias() return value handling ...
2014-01-23Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - various misc bits - the rest of MM - add generic fixmap.h, use it - backlight updates - dynamic_debug updates - printk() updates - checkpatch updates - binfmt_elf - ramfs - init/ - autofs4 - drivers/rtc - nilfs - hfsplus - Documentation/ - coredump - procfs - fork - exec - kexec - kdump - partitions - rapidio - rbtree - userns - memstick - w1 - decompressors * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (197 commits) lib/decompress_unlz4.c: always set an error return code on failures romfs: fix returm err while getting inode in fill_super drivers/w1/masters/w1-gpio.c: add strong pullup emulation drivers/memstick/host/rtsx_pci_ms.c: fix ms card data transfer bug userns: relax the posix_acl_valid() checks arch/sh/kernel/dwarf.c: use rbtree postorder iteration helper instead of solution using repeated rb_erase() fs-ext3-use-rbtree-postorder-iteration-helper-instead-of-opencoding-fix fs/ext3: use rbtree postorder iteration helper instead of opencoding fs/jffs2: use rbtree postorder iteration helper instead of opencoding fs/ext4: use rbtree postorder iteration helper instead of opencoding fs/ubifs: use rbtree postorder iteration helper instead of opencoding net/netfilter/ipset/ip_set_hash_netiface.c: use rbtree postorder iteration instead of opencoding rbtree/test: test rbtree_postorder_for_each_entry_safe() rbtree/test: move rb_node to the middle of the test struct rapidio: add modular rapidio core build into powerpc and mips branches partitions/efi: complete documentation of gpt kernel param purpose kdump: add /sys/kernel/vmcoreinfo ABI documentation kdump: fix exported size of vmcoreinfo note kexec: add sysctl to disable kexec_load fs/exec.c: call arch_pick_mmap_layout() only once ...
2014-01-23Merge tag 'clk-for-linus-3.14-part1' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clk framework changes from Mike Turquette: "The first half of the clk framework pull request is made up almost entirely of new platform/driver support. There are some conversions of existing drivers to the common-clock Device Tree binding, and a few non-critical fixes to the framework. Due to an entirely unnecessary cyclical dependency with the arm-soc tree this pull request is broken into two pieces. The second piece will be sent out after arm-soc sends you the pull request that merged in core support for the HiSilicon 3620 platform. That same pull request from arm-soc depends on this pull request to merge in those HiSilicon bits without causing build failures" [ Just did the ARM SoC merges, so getting ready for the second clk tree pull request - Linus ] * tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits) devicetree: bindings: Document qcom,mmcc devicetree: bindings: Document qcom,gcc clk: qcom: Add support for MSM8660's global clock controller (GCC) clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC) clk: qcom: Add support for MSM8974's global clock controller (GCC) clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC) clk: qcom: Add support for MSM8960's global clock controller (GCC) clk: qcom: Add reset controller support clk: qcom: Add support for branches/gate clocks clk: qcom: Add support for root clock generators (RCGs) clk: qcom: Add support for phase locked loops (PLLs) clk: qcom: Add a regmap type clock struct clk: Add set_rate_and_parent() op reset: Silence warning in reset-controller.h clk: sirf: re-arch to make the codes support both prima2 and atlas6 clk: composite: pass mux_hw into determine_rate clk: shmobile: Fix MSTP clock array initialization clk: shmobile: Fix MSTP clock index ARM: dts: Add clock provider specific properties to max77686 node clk: max77686: Register OF clock provider ...
2014-01-23Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New core SoC-specific changes. New platforms: * Introduction of a vendor, Hisilicon, and one of their SoCs with some random numerical product name. * Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m, i.e. !MMU). * Marvell Berlin series of SoCs, which include the one in Chromecast. * MOXA platform support, ARM9-based platform used mostly in industrial products * Support for Freescale's i.MX50 SoC. Other work: * Renesas work for new platforms and drivers, and conversion over to more multiplatform-friendly device registration schemes. * SMP support for Allwinner sunxi platforms. * ... plus a bunch of other stuff across various platforms" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits) ARM: tegra: fix tegra_powergate_sequence_power_up() inline ARM: msm_defconfig: Update for multi-platform ARM: msm: Move MSM's DT based hardware to multi-platform support ARM: msm: Only build timer.c if required ARM: msm: Only build clock.c on proc_comm based platforms ARM: ux500: Enable system suspend with WFI support ARM: ux500: turn on PRINTK_TIME in u8500_defconfig ARM: shmobile: r8a7790: Fix I2C controller names ARM: msm: Simplify ARCH_MSM_DT config ARM: msm: Add support for MSM8974 SoC ARM: sunxi: select ARM_PSCI MAINTAINERS: Update Allwinner sunXi maintainer files ARM: sunxi: Select RESET_CONTROLLER ARM: imx: improve the comment of CCM lpm SW workaround ARM: imx: improve status check of clock gate ARM: imx: add necessary interface for pfd ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100 ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support ARM: imx: Add cpu frequency scaling support ARM i.MX35: Add devicetree support. ...
2014-01-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.14: - Improved crypto_memneq helper - Use cyprto_memneq in arch-specific crypto code - Replaced orphaned DCP driver with Freescale MXS DCP driver - Added AVX/AVX2 version of AESNI-GCM encode and decode - Added AMD Cryptographic Coprocessor (CCP) driver - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (41 commits) crypto: aesni - fix build on x86 (32bit) crypto: mxs - Fix sparse non static symbol warning crypto: ccp - CCP device enabled/disabled changes crypto: ccp - Cleanup hash invocation calls crypto: ccp - Change data length declarations to u64 crypto: ccp - Check for caller result area before using it crypto: ccp - Cleanup scatterlist usage crypto: ccp - Apply appropriate gfp_t type to memory allocations crypto: drivers - Sort drivers/crypto/Makefile ARM: mxs: dts: Enable DCP for MXS crypto: mxs - Add Freescale MXS DCP driver crypto: mxs - Remove the old DCP driver crypto: ahash - Fully restore ahash request before completing crypto: aesni - fix build on x86 (32bit) crypto: talitos - Remove redundant dev_set_drvdata crypto: ccp - Remove redundant dev_set_drvdata crypto: crypto4xx - Remove redundant dev_set_drvdata crypto: caam - simplify and harden key parsing crypto: omap-sham - Fix Polling mode for larger blocks crypto: tcrypt - Added speed tests for AEAD crypto alogrithms in tcrypt test suite ...
2014-01-23Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit update from Eric Paris: "Again we stayed pretty well contained inside the audit system. Venturing out was fixing a couple of function prototypes which were inconsistent (didn't hurt anything, but we used the same value as an int, uint, u32, and I think even a long in a couple of places). We also made a couple of minor changes to when a couple of LSMs called the audit system. We hoped to add aarch64 audit support this go round, but it wasn't ready. I'm disappearing on vacation on Thursday. I should have internet access, but it'll be spotty. If anything goes wrong please be sure to cc rgb@redhat.com. He'll make fixing things his top priority" * git://git.infradead.org/users/eparis/audit: (50 commits) audit: whitespace fix in kernel-parameters.txt audit: fix location of __net_initdata for audit_net_ops audit: remove pr_info for every network namespace audit: Modify a set of system calls in audit class definitions audit: Convert int limit uses to u32 audit: Use more current logging style audit: Use hex_byte_pack_upper audit: correct a type mismatch in audit_syscall_exit() audit: reorder AUDIT_TTY_SET arguments audit: rework AUDIT_TTY_SET to only grab spin_lock once audit: remove needless switch in AUDIT_SET audit: use define's for audit version audit: documentation of audit= kernel parameter audit: wait_for_auditd rework for readability audit: update MAINTAINERS audit: log task info on feature change audit: fix incorrect set of audit_sock audit: print error message when fail to create audit socket audit: fix dangling keywords in audit_log_set_loginuid() output audit: log on errors from filter user rules ...
2014-01-23MAINTAINERS: remove unnecessary EXYNOS DP DRIVER F: patternJingoo Han
Remove unnecessary pattern for Exynos DP header from MAINTAINERS file. After commit f9b1e013f1c6 ("video: exynos_dp: remove non-DT support for Exynos Display Port"), 'exynos_dp.h' has not been used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23MAINTAINERS: describe differences between F: and N: patternsJoe Perches
There is a difference in how scripts/get_maintainer.pl treats F: and N: file pattern matches. Describe those differences in the MAINTAINERS file. Signed-off-by: Joe Perches <joe@perches.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Brown <broonie@linaro.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23MAINTAINERS: add an entry for the Macintosh HFSPlus FilesystemGeert Uytterhoeven
To make scripts/get_maintainer.pl output something sensible. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23Add Shradha Shah as the sfc driver maintainer.Shradha Shah
I will be taking over the work from Ben Hutchings. Signed-off-by: Shradha Shah <sshah@solarflare.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-23Merge tag 'for-f2fs-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "In this round, a couple of sysfs entries were introduced to tune the f2fs at runtime. In addition, f2fs starts to support inline_data and improves the read/write performance in some workloads by refactoring bio-related flows. This patch-set includes the following major enhancement patches. - support inline_data - refactor bio operations such as merge operations and rw type assignment - enhance the direct IO path - enhance bio operations - truncate a node page when it becomes obsolete - add sysfs entries: small_discards, max_victim_search, and in-place-update - add a sysfs entry to control max_victim_search The other bug fixes are as follows. - fix a bug in truncate_partial_nodes - avoid warnings during sparse and build process - fix error handling flows - fix potential bit overflows And, there are a bunch of cleanups" * tag 'for-f2fs-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (95 commits) f2fs: drop obsolete node page when it is truncated f2fs: introduce NODE_MAPPING for code consistency f2fs: remove the orphan block page array f2fs: add help function META_MAPPING f2fs: move a branch for code redability f2fs: call mark_inode_dirty to flush dirty pages f2fs: clean checkpatch warnings f2fs: missing REQ_META and REQ_PRIO when sync_meta_pages(META_FLUSH) f2fs: avoid f2fs_balance_fs call during pageout f2fs: add delimiter to seperate name and value in debug phrase f2fs: use spinlock rather than mutex for better speed f2fs: move alloc new orphan node out of lock protection region f2fs: move grabing orphan pages out of protection region f2fs: remove the needless parameter of f2fs_wait_on_page_writeback f2fs: update documents and a MAINTAINERS entry f2fs: add a sysfs entry to control max_victim_search f2fs: improve write performance under frequent fsync calls f2fs: avoid to read inline data except first page f2fs: avoid to left uninitialized data in page when read inline data f2fs: fix truncate_partial_nodes bug ...
2014-01-22Merge branches 'cma', 'cxgb4', 'flowsteer', 'ipoib', 'misc', 'mlx4', 'mlx5', ↵Roland Dreier
'ocrdma', 'qib', 'srp' and 'usnic' into for-next
2014-01-22Merge tag 'stable/for-linus-3.14-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from Konrad Rzeszutek Wilk: "Two major features that Xen community is excited about: The first is event channel scalability by David Vrabel - we switch over from an two-level per-cpu bitmap of events (IRQs) - to an FIFO queue with priorities. This lets us be able to handle more events, have lower latency, and better scalability. Good stuff. The other is PVH by Mukesh Rathor. In short, PV is a mode where the kernel lets the hypervisor program page-tables, segments, etc. With EPT/NPT capabilities in current processors, the overhead of doing this in an HVM (Hardware Virtual Machine) container is much lower than the hypervisor doing it for us. In short we let a PV guest run without doing page-table, segment, syscall, etc updates through the hypervisor - instead it is all done within the guest container. It is a "hybrid" PV - hence the 'PVH' name - a PV guest within an HVM container. The major benefits are less code to deal with - for example we only use one function from the the pv_mmu_ops (which has 39 function calls); faster performance for syscall (no context switches into the hypervisor); less traps on various operations; etc. It is still being baked - the ABI is not yet set in stone. But it is pretty awesome and we are excited about it. Lastly, there are some changes to ARM code - you should get a simple conflict which has been resolved in #linux-next. In short, this pull has awesome features. Features: - FIFO event channels. Key advantages: support for over 100,000 events (2^17), 16 different event priorities, improved fairness in event latency through the use of FIFOs. - Xen PVH support. "It’s a fully PV kernel mode, running with paravirtualized disk and network, paravirtualized interrupts and timers, no emulated devices of any kind (and thus no qemu), no BIOS or legacy boot — but instead of requiring PV MMU, it uses the HVM hardware extensions to virtualize the pagetables, as well as system calls and other privileged operations." (from "The Paravirtualization Spectrum, Part 2: From poles to a spectrum") Bug-fixes: - Fixes in balloon driver (refactor and make it work under ARM) - Allow xenfb to be used in HVM guests. - Allow xen_platform_pci=0 to work properly. - Refactors in event channels" * tag 'stable/for-linus-3.14-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (52 commits) xen/pvh: Set X86_CR0_WP and others in CR0 (v2) MAINTAINERS: add git repository for Xen xen/pvh: Use 'depend' instead of 'select'. xen: delete new instances of __cpuinit usage xen/fb: allow xenfb initialization for hvm guests xen/evtchn_fifo: fix error return code in evtchn_fifo_setup() xen-platform: fix error return code in platform_pci_init() xen/pvh: remove duplicated include from enlighten.c xen/pvh: Fix compile issues with xen_pvh_domain() xen: Use dev_is_pci() to check whether it is pci device xen/grant-table: Force to use v1 of grants. xen/pvh: Support ParaVirtualized Hardware extensions (v3). xen/pvh: Piggyback on PVHVM XenBus. xen/pvh: Piggyback on PVHVM for grant driver (v4) xen/grant: Implement an grant frame array struct (v3). xen/grant-table: Refactor gnttab_init xen/grants: Remove gnttab_max_grant_frames dependency on gnttab_init. xen/pvh: Piggyback on PVHVM for event channels (v2) xen/pvh: Update E820 to work with PVH (v2) xen/pvh: Secondary VCPU bringup (non-bootup CPUs) ...
2014-01-22Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "First round of KVM updates for 3.14; PPC parts will come next week. Nothing major here, just bugfixes all over the place. The most interesting part is the ARM guys' virtualized interrupt controller overhaul, which lets userspace get/set the state and thus enables migration of ARM VMs" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits) kvm: make KVM_MMU_AUDIT help text more readable KVM: s390: Fix memory access error detection KVM: nVMX: Update guest activity state field on L2 exits KVM: nVMX: Fix nested_run_pending on activity state HLT KVM: nVMX: Clean up handling of VMX-related MSRs KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit KVM: nVMX: Leave VMX mode on clearing of feature control MSR KVM: VMX: Fix DR6 update on #DB exception KVM: SVM: Fix reading of DR6 KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS add support for Hyper-V reference time counter KVM: remove useless write to vcpu->hv_clock.tsc_timestamp KVM: x86: fix tsc catchup issue with tsc scaling KVM: x86: limit PIT timer frequency KVM: x86: handle invalid root_hpa everywhere kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub kvm: vfio: silence GCC warning KVM: ARM: Remove duplicate include arm/arm64: KVM: relax the requirements of VMA alignment for THP ...
2014-01-22Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI updates from James Bottomley: "This patch set is a lot of driver updates for qla4xxx, bfa, hpsa, qla2xxx. It also removes the aic7xxx_old driver (which has been deprecated for nearly a decade) and adds support for deadlines in error handling" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (75 commits) [SCSI] hpsa: allow SCSI mid layer to handle unit attention [SCSI] hpsa: do not require board "not ready" status after hard reset [SCSI] hpsa: enable unit attention reporting [SCSI] hpsa: rename scsi prefetch field [SCSI] hpsa: use workqueue instead of kernel thread for lockup detection [SCSI] ipr: increase dump size in ipr driver [SCSI] mac_scsi: Fix crash on out of memory [SCSI] st: fix enlarge_buffer [SCSI] qla1280: Annotate timer on stack so object debug does not complain [SCSI] qla4xxx: Update driver version to 5.04.00-k3 [SCSI] qla4xxx: Recreate chap data list during get chap operation [SCSI] qla4xxx: Add support for ISCSI_PARAM_LOCAL_IPADDR sysfs attr [SCSI] libiscsi: Add local_ipaddr parameter in iscsi_conn struct [SCSI] scsi_transport_iscsi: Export ISCSI_PARAM_LOCAL_IPADDR attr for iscsi_connection [SCSI] qla4xxx: Add host statistics support [SCSI] scsi_transport_iscsi: Add host statistics support [SCSI] qla4xxx: Added support for Diagnostics MBOX command [SCSI] bfa: Driver version upgrade to 3.2.23.0 [SCSI] bfa: change FC_ELS_TOV to 20sec [SCSI] bfa: Observed auto D-port mode instead of manual ...
2014-01-22MAINTAINERS: Restore "L: linux-kernel@vger.kernel.org" entriesIngo Molnar
A couple of years ago all the "L: lkml" email list entries in MAINTAINERS were removed and replaced with a 'the rest' entry at the end of the file - under the theory that this is unnecessary duplication and that people would find it intuitive: b5472cddbe2c MAINTAINERS: remove L: linux-kernel@vger.kernel.org from all but "THE REST" So it turns out that it's all but intuitive, not all people use scripts/get_maintainer.pl to extract maintainer contact info, some people read the MAINTAINERS file and see the lack of 'L:' entries of various lkml-only subsystems and are sending patches to the maintainers only, without Cc:-ing lkml. They arguably have a point. In hindsight removing all the "L: lkml" entries was probably not an overly good idea, not all mechanic duplication should be eliminated: in files read by humans it's useful to have 'at a glance' summary for all email addresses important to a subsystem's maintenance, in a single place, without too many imported rules and assumptions. So, to make the lkml fallback really apparent, add back 'L: lkml' entries to all subsystem entries whose workflow I'm involved in. This should at minimum be a per subsystem policy thing. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Cc: Joe Perches <joe@perches.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Link: http://lkml.kernel.org/n/tip-lhzlymtgmmv5bMuwsb5zyoYo@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-21Merge tag 'for-v3.14' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Dmitry Eremin-Solenikov: "I'm picking up power supply maintainership from Anton Vorontov. Could you please pull battery-2.6 git tree changes prepared for the v3.14 release. Highlights: - Power supply notifier - Several drivers gained DT support - Added Maxim 14577 driver - Change of maintainer" * tag 'for-v3.14' of git://git.infradead.org/battery-2.6: MAINTAINERS: Pick up power supply maintainership max17042_battery: Add IRQF_ONESHOT flag to use default irq handler gpio-charger: Support wakeup events power_supply: Add charger support for Maxim 14577 dt: Binding documentation for isp1704 charger isp1704_charger: Add DT support charger-manager: of_cm_parse_desc() should be static bq2415x_charger: Add DT support power_supply: Add power_supply_get_by_phandle bq2415x_charger: Use power_supply notifier for automode power: reset: Add as3722 power-off driver mfd: AS3722: Add dt node properties for system power controller charger-manager: Support deivce tree in charger manager driver charger-manager: Modify the way of checking battery's temperature power_supply: Add power_supply notifier
2014-01-21MAINTAINERS: Pass the torch of SRP submaintainershipDavid Dillow
Today was my last day at ORNL, and my future endeavors will leave even less time to maintain the SRP initiator. My thanks especially go to Bart, for keeping the pressure to improve alive, and for driving so many of those improvements. [ Add Bart as new submaintainer. - Roland ] Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-01-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "Changes for this kernel include maintenance updates for Smack, SELinux (and several networking fixes), IMA and TPM" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) SELinux: Fix memory leak upon loading policy tpm/tpm-sysfs: active_show() can be static tpm: tpm_tis: Fix compile problems with CONFIG_PM_SLEEP/CONFIG_PNP tpm: Make tpm-dev allocate a per-file structure tpm: Use the ops structure instead of a copy in tpm_vendor_specific tpm: Create a tpm_class_ops structure and use it in the drivers tpm: Pull all driver sysfs code into tpm-sysfs.c tpm: Move sysfs functions from tpm-interface to tpm-sysfs tpm: Pull everything related to /dev/tpmX into tpm-dev.c char: tpm: nuvoton: remove unused variable tpm: MAINTAINERS: Cleanup TPM Maintainers file tpm/tpm_i2c_atmel: fix coccinelle warnings tpm/tpm_ibmvtpm: fix unreachable code warning (smatch warning) tpm/tpm_i2c_stm_st33: Check return code of get_burstcount tpm/tpm_ppi: Check return value of acpi_get_name tpm/tpm_ppi: Do not compare strcmp(a,b) == -1 ima: remove unneeded size_limit argument from ima_eventdigest_init_common() ima: update IMA-templates.txt documentation ima: pass HASH_ALGO__LAST as hash algo in ima_eventdigest_init() ima: change the default hash algorithm to SHA1 in ima_eventdigest_ng_init() ...
2014-01-20Merge tag 'staging-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver tree changes from Greg KH: "Here's the big drivers/staging/ update for 3.14-rc1 Lots and lots of cleanups, IIO driver updates are also mixed in here due to the subsystem still crossing staging and drivers/iio/, and the dwc2 driver is moved out of staging. There's a new driver (rts5208), which ends up making us adding more lines than removing, but overall there was lots of work toward moving code out of here, which was good All of this has been in linux-next with no reported issues" * tag 'staging-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1084 commits) lustre: delete linux/lustre_debug.h staging: lustre: remove some unused debug macros usb: dwc2: move device tree bindings doc to correct place staging: vt6656: sparse fixes: iwctl_giwgenie use memcpy. staging: vt6656: sparse fixes: iwctl_siwgenie use memcpy. staging: vt6656: sparse fixes ethtool_ioctl Use struct ifreq * staging: vt6656: sparse fixes: dpc.c missing dpc.h staging: lustre: libcfs_debug: small whitespace cleanups staging: lustre: libcfs_debug.h: remove extra blank lines staging: lustre: libcfs_debug.h: Align backslashes in macros staging: lustre: libcfs_debug.h: align define values staging: tidspbridge: adjust error return code (bugfix) Staging: rts5139: rts51x_card: fixed style issues staging: wlags49_h2: Fix "do not use C99 //" in wl_cs.h, wl_enc.h wl_main.h and wl_wext.h Staging: rtl8188eu: Fixed "foo * bar" related coding style issues Staging: rtl8188eu: Fixed required spaces after ',' and around '=' and '==' staging: vt6655: Fix memory leak in wpa_ioctl() imx-drm: parallel-display: honor 'native-mode' property when selecting video mode from DT staging: drm/imx: don't drop crtc offsets when doing pageflip staging: drm/imx: handle framebuffer offsets correctly ...
2014-01-20Merge tag 'char-misc-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver patches for 3.14-rc1. Lots of little things, and a new "big" driver, genwqe. Full details are in the shortlog" * tag 'char-misc-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits) mei: limit the number of consecutive resets mei: revamp mei reset state machine drivers/char: don't use module_init in non-modular ttyprintk.c VMCI: fix error handling path when registering guest driver extcon: gpio: Add power resume support Documentation: HOWTO: Updates on subsystem trees, patchwork, -next (vs. -mm) in ko_KR Documentation: HOWTO: update for 2.6.x -> 3.x versioning in ko_KR Documentation: HOWTO: update stable address in ko_KR Documentation: HOWTO: update LXR web link in ko_KR char: nwbutton: open-code interruptible_sleep_on mei: fix syntax in comments and debug output mei: nfc: mei_nfc_free has to be called under lock mei: use hbm idle state to prevent spurious resets mei: do not run reset flow from the interrupt thread misc: genwqe: fix return value check in genwqe_device_create() GenWQE: Fix warnings for sparc GenWQE: Fix compile problems for Alpha Documentation/misc-devices/mei/mei-amt-version.c: remove unneeded call of mei_deinit() GenWQE: Rework return code for flash-update ioctl sgi-xp: open-code interruptible_sleep_on_timeout ...
2014-01-21MAINTAINERS: Pick up power supply maintainershipDmitry Eremin-Solenikov
Anton stated that he would have to abandon power supply maintainership due to the lack of time. By agreement with him and David, pick up power supply tree. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Anton Vorontsov <anton@enomsg.org>
2014-01-20Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: - add RCU torture scripts/tooling - static analysis improvements - update RCU documentation - miscellaneous fixes * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) rcu: Remove "extern" from function declarations in kernel/rcu/rcu.h rcu: Remove "extern" from function declarations in include/linux/*rcu*.h rcu/torture: Dynamically allocate SRCU output buffer to avoid overflow rcu: Don't activate RCU core on NO_HZ_FULL CPUs rcu: Warn on allegedly impossible rcu_read_unlock_special() from irq rcu: Add an RCU_INITIALIZER for global RCU-protected pointers rcu: Make rcu_assign_pointer's assignment volatile and type-safe bonding: Use RCU_INIT_POINTER() for better overhead and for sparse rcu: Add comment on evaluate-once properties of rcu_assign_pointer(). rcu: Provide better diagnostics for blocking in RCU callback functions rcu: Improve SRCU's grace-period comments rcu: Fix CONFIG_RCU_FANOUT_EXACT for odd fanout/leaf values rcu: Fix coccinelle warnings rcutorture: Stop tracking FSF's postal address rcutorture: Move checkarg to functions.sh rcutorture: Flag errors and warnings with color coding rcutorture: Record results from repeated runs of the same test scenario rcutorture: Test summary at end of run with less chattiness rcutorture: Update comment in kvm.sh listing typical RCU trace events rcutorture: Add tracing-enabled version of TREE08 ...
2014-01-20Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: - futex performance increases: larger hashes, smarter wakeups - mutex debugging improvements - lots of SMP ordering documentation updates - introduce the smp_load_acquire(), smp_store_release() primitives. (There are WIP patches that make use of them - not yet merged) - lockdep micro-optimizations - lockdep improvement: better cover IRQ contexts - liblockdep at last. We'll continue to monitor how useful this is * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) futexes: Fix futex_hashsize initialization arch: Re-sort some Kbuild files to hopefully help avoid some conflicts futexes: Avoid taking the hb->lock if there's nothing to wake up futexes: Document multiprocessor ordering guarantees futexes: Increase hash table size for better performance futexes: Clean up various details arch: Introduce smp_load_acquire(), smp_store_release() arch: Clean up asm/barrier.h implementations using asm-generic/barrier.h arch: Move smp_mb__{before,after}_atomic_{inc,dec}.h into asm/atomic.h locking/doc: Rename LOCK/UNLOCK to ACQUIRE/RELEASE mutexes: Give more informative mutex warning in the !lock->owner case powerpc: Full barrier for smp_mb__after_unlock_lock() rcu: Apply smp_mb__after_unlock_lock() to preserve grace periods Documentation/memory-barriers.txt: Downgrade UNLOCK+BLOCK locking: Add an smp_mb__after_unlock_lock() for UNLOCK+BLOCK barrier Documentation/memory-barriers.txt: Document ACCESS_ONCE() Documentation/memory-barriers.txt: Prohibit speculative writes Documentation/memory-barriers.txt: Add long atomic examples to memory-barriers.txt Documentation/memory-barriers.txt: Add needed ACCESS_ONCE() calls to memory-barriers.txt Revert "smp/cpumask: Make CONFIG_CPUMASK_OFFSTACK=y usable without debug dependency" ...
2014-01-20MAINTAINERS: add git repository for XenDavid Vrabel
Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c net/ipv4/tcp_metrics.c Overlapping changes between the "don't create two tcp metrics objects with the same key" race fix in net and the addition of the destination address in the lookup key in net-next. Minor overlapping changes in bnx2x driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-16ACPICA: acpidump: Update MAINTAINERS file to include tools folder for ↵Lv Zheng
ACPI/ACPICA. This patch updates MAINTAINERS file, adding tools/power/acpi for ACPI and ACPICA. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
